moab::RayIntersectSets Class Reference
+ Inheritance diagram for moab::RayIntersectSets:
+ Collaboration diagram for moab::RayIntersectSets:
Public Member Functions
 RayIntersectSets (OrientedBoxTreeTool *tool_ptr, const double *ray_point, const double *unit_ray_dir, const double tolerance, OrientedBoxTreeTool::IntersectSearchWindow &win, unsigned int *ray_tri_test_count, OrientedBoxTreeTool::IntRegCtxt &intRegCallback)
virtual ErrorCode visit (EntityHandle node, int depth, bool &descend)
 Visit a node in the tree during a traversal.
virtual ErrorCode leaf (EntityHandle node)
 Process a leaf node during tree traversal.
Private Attributes
OrientedBoxTreeTool * tool
const CartVect ray_origin
const CartVect ray_direction
OrientedBoxTreeTool::IntersectSearchWindow & search_win
const double tol
OrientedBoxTreeTool::IntRegCtxt & int_reg_callback
int * surfTriOrient
int surfTriOrient_val
unsigned int * raytri_test_count
EntityHandle lastSet
int lastSetDepth
Detailed Description
Definition at line 888 of file OrientedBoxTreeTool.cpp.
moab::RayIntersectSets::RayIntersectSets ( OrientedBoxTreeTool *  tool_ptr,
const double *  ray_point,
const double *  unit_ray_dir,
OrientedBoxTreeTool::IntersectSearchWindow &  win,
unsigned int *  ray_tri_test_count,
OrientedBoxTreeTool::IntRegCtxt &  intRegCallback
) [inline]
Definition at line 911 of file OrientedBoxTreeTool.cpp.
        : tool( tool_ptr ), ray_origin( ray_point ), ray_direction( unit_ray_dir ), search_win( win ), tol( tolerance ),
          int_reg_callback( intRegCallback ), surfTriOrient_val( 0 ), raytri_test_count( ray_tri_test_count ),
          lastSet( 0 ), lastSetDepth( 0 )
        // specified orientation should be 1 or -1, indicating ray and surface
        // normal in the same or opposite directions, respectively.
        if( int_reg_callback.getDesiredOrient() )
            surfTriOrient = &surfTriOrient_val;
        else
            surfTriOrient = NULL;
        // check the limits
        if( search_win.first )
            assert( 0 <= *( search_win.first ) );
        if( search_win.second )
            assert( 0 >= *( search_win.second ) );
Member Function Documentation
Implements moab::OrientedBoxTreeTool::Op.
Definition at line 981 of file OrientedBoxTreeTool.cpp.
References ErrorCode, MB_SUCCESS, MBTRI, NONE, moab::GeomUtil::plucker_ray_tri_intersect(), t, and moab::TYPE_FROM_HANDLE().
    assert( lastSet );
    if( !lastSet )  // if no surface has been visited yet, something's messed up.
        return MB_FAILURE;
#ifndef MB_OBB_USE_VECTOR_QUERIES
    Range tris;
#ifdef MB_OBB_USE_TYPE_QUERIES
    ErrorCode rval = tool->get_moab_instance()->get_entities_by_type( node, MBTRI, tris );
#else
    ErrorCode rval = tool->get_moab_instance()->get_entities_by_handle( node, tris );
#endif
#else
    std::vector< EntityHandle > tris;
#endif
    assert( MB_SUCCESS == rval );
    if( MB_SUCCESS != rval ) return rval;
    for( Range::iterator t = tris.begin(); t != tris.end(); ++t )
#else
    for( std::vector< EntityHandle >::iterator t = tris.begin(); t != tris.end(); ++t )
#endif
#ifndef MB_OBB_USE_TYPE_QUERIES
        if( TYPE_FROM_HANDLE( *t ) != MBTRI ) continue;
#endif
        const EntityHandle* conn;
        int num_conn;
        rval = tool->get_moab_instance()->get_connectivity( *t, conn, num_conn, true );
        CartVect coords[3];
        rval = tool->get_moab_instance()->get_coords( conn, 3, coords[0].array() );
        if( raytri_test_count ) *raytri_test_count += 1;
        double int_dist;
        GeomUtil::intersection_type int_type = GeomUtil::NONE;
        if( GeomUtil::plucker_ray_tri_intersect( coords, ray_origin, ray_direction, int_dist, search_win.first,
                                                 search_win.second, surfTriOrient, &int_type ) )
            int_reg_callback.register_intersection( lastSet, *t, int_dist, search_win, int_type );
    return MB_SUCCESS;
ErrorCode moab::RayIntersectSets::visit ( EntityHandle  node,
int  depth,
bool &  descend
) [virtual]
This method is called for each node in the tree visited during a pre-order traversal.
Parameters:
nodeThe EntityHandle for the entity set for the tree node.
depthThe current depth in the tree.
descendOutput: if false, traversal will skip children of the current node, or if the current node is a leaf, the 'leaf' method will not be called.
Definition at line 949 of file OrientedBoxTreeTool.cpp.
References moab::Range::begin(), moab::OrientedBoxTreeTool::box(), moab::Range::empty(), ErrorCode, moab::OrientedBox::intersect_ray(), MB_SUCCESS, MBENTITYSET, and moab::Range::size().
    OrientedBox box;
    ErrorCode rval = tool->box( node, box );
    descend = box.intersect_ray( ray_origin, ray_direction, tol, search_win.first, search_win.second );
    if( lastSet && depth <= lastSetDepth ) lastSet = 0;
    if( descend && !lastSet )
        Range tmp_sets;
        rval = tool->get_moab_instance()->get_entities_by_type( node, MBENTITYSET, tmp_sets );
        if( !tmp_sets.empty() )
            if( tmp_sets.size() > 1 ) return MB_FAILURE;
            lastSet      = *tmp_sets.begin();
            lastSetDepth = depth;
            rval = int_reg_callback.update_orient( lastSet, surfTriOrient );
    return MB_SUCCESS;
Member Data Documentation
Definition at line 908 of file OrientedBoxTreeTool.cpp.
Definition at line 894 of file OrientedBoxTreeTool.cpp.
Definition at line 893 of file OrientedBoxTreeTool.cpp.
Definition at line 906 of file OrientedBoxTreeTool.cpp.
Definition at line 902 of file OrientedBoxTreeTool.cpp.
Definition at line 903 of file OrientedBoxTreeTool.cpp.
const double moab::RayIntersectSets::tol [private]
Definition at line 896 of file OrientedBoxTreeTool.cpp.
List of all members.
