moab::WriteAns Class Reference
#include <WriteAns.hpp>
+ Inheritance diagram for moab::WriteAns:
+ Collaboration diagram for moab::WriteAns:
Classes
struct  DirichletSetData
struct  MaterialSetData
class  MeshInfo
 number of dimensions in this file More...
struct  NeumannSetData
Public Member Functions
 WriteAns (Interface *impl)
 Constructor.
virtual ~WriteAns ()
 Destructor.
ErrorCode write_file (const char *file_name, const bool overwrite, const FileOptions &opts, const EntityHandle *output_list, const int num_sets, const std::vector< std::string > &qa_list, const Tag *tag_list=NULL, int num_tags=0, int export_dimension=3)
 writes out a file
Static Public Member Functions
static WriterIface * factory (Interface *)
Private Member Functions
ErrorCode write_nodes (const int num_nodes, const Range &nodes, const int dimension, const char *file_name)
Private Attributes
Interface * mbImpl
 interface instance
std::string fileName
 file name
EntityHandle mCurrentMeshHandle
 Meshset Handle for the mesh that is currently being read.
Tag mMaterialSetTag
Tag mDirichletSetTag
Tag mNeumannSetTag
Tag mGlobalIdTag
Tag mMatSetIdTag
Detailed Description
Definition at line 49 of file WriteAns.hpp.
Constructor.
get and cache predefined tag handles
Definition at line 53 of file WriteAns.cpp.
References DIRICHLET_SET_TAG_NAME, MATERIAL_SET_TAG_NAME, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_INTEGER, mDirichletSetTag, mMaterialSetTag, mNeumannSetTag, NEUMANN_SET_TAG_NAME, and moab::Interface::tag_get_handle().
Referenced by factory().
                                    : mbImpl( impl ), mCurrentMeshHandle( 0 ), mGlobalIdTag( 0 ), mMatSetIdTag( 0 )
    assert( impl != NULL );
    // impl->query_interface( mWriteIface );
    // initialize in case tag_get_handle fails below
    //! get and cache predefined tag handles
    const int negone = -1;
    impl->tag_get_handle( MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mMaterialSetTag, MB_TAG_SPARSE | MB_TAG_CREAT,
                          &negone );
    impl->tag_get_handle( DIRICHLET_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mDirichletSetTag, MB_TAG_SPARSE | MB_TAG_CREAT,
                          &negone );
    impl->tag_get_handle( NEUMANN_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mNeumannSetTag, MB_TAG_SPARSE | MB_TAG_CREAT,
                          &negone );
Destructor.
Definition at line 72 of file WriteAns.cpp.
    // mbImpl->release_interface(mWriteIface);
Member Function Documentation
Definition at line 48 of file WriteAns.cpp.
References WriteAns().
Referenced by moab::ReaderWriterSet::ReaderWriterSet().
    return new WriteAns( iface );
ErrorCode moab::WriteAns::write_file ( const char *  file_name,
const FileOptions &  opts,
const EntityHandle *  output_list,
const int  num_sets,
const std::vector< std::string > &  qa_list,
const Tag *  tag_list = NULL,
int  num_tags = 0,
int  export_dimension = 3
) [virtual]
writes out a file
Implements moab::WriterIface.
Definition at line 77 of file WriteAns.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_handle(), moab::Interface::get_entities_by_type(), moab::Interface::get_entities_by_type_and_tag(), moab::Interface::id_from_handle(), MB_SUCCESS, MBENTITYSET, MBHEX, mbImpl, MBPRISM, MBTET, MBVERTEX, mDirichletSetTag, mMaterialSetTag, mNeumannSetTag, moab::Interface::tag_get_data(), and moab::Interface::unite_meshset().
    assert( 0 != mMaterialSetTag && 0 != mNeumannSetTag && 0 != mDirichletSetTag );
    ErrorCode result;
    // set SOLID45 element type to #60000, hope nobody has already...
    const char* ETSolid45 = "60045";
    const char* ETSolid92 = "60042";
    const char* ETSolid95 = "60095";
    // set Material id # to be used as default for all elements
    // will need to be subsequently reassigned inside ANSYS
    // Can, although have not, declare similar defaults for other attributes
    const char* MATDefault = "1";
    // create file streams for writing
    std::ofstream node_file;
    std::ofstream elem_file;
    std::ofstream ans_file;
    // get base filename from filename.ans
    std::string temp_string;
    std::string base_string;
    base_string.assign( file_name );
    base_string.replace( base_string.find_last_of( ".ans" ) - 3, 4, "" );
    // open node file for writing
    temp_string = base_string + ".node";
    node_file.open( temp_string.c_str() );
    node_file.setf( std::ios::scientific, std::ios::floatfield );
    node_file.precision( 13 );
    // open elem file for writing
    temp_string = base_string + ".elem";
    elem_file.open( temp_string.c_str() );
    // open ans file for writing
    ans_file.open( file_name );
    ans_file << "/prep7" << std::endl;
    // gather single output set
    EntityHandle output_set = 0;
    if( ent_handles && num_sets > 0 )
        for( int i = 0; i < num_sets; i++ )
            // from template, maybe can be removed
            result = mbImpl->unite_meshset( output_set, ent_handles[i] );
            if( result != MB_SUCCESS ) return result;
    // search for all nodes
    Range node_range;
    result = mbImpl->get_entities_by_type( output_set, MBVERTEX, node_range, true );
    // Commented out until Seg Fault taken care of in gather_nodes...
    // get any missing nodes which are needed for elements
    // Range all_ent_range,missing_range;
    // result=mbImpl->get_entities_by_handle(output_set,all_ent_range,true);
    // if(result !=MB_SUCCESS) return result;
    // result=mWriteIface->gather_nodes_from_elements(all_ent_range,0,missing_range);
    // node_range.merge(missing_range);
    // write the nodes
    double coord[3];
    for( Range::iterator it = node_range.begin(); it != node_range.end(); ++it )
        EntityHandle node_handle = *it;
        result = mbImpl->get_coords( &node_handle, 1, coord );
        node_file.width( 8 );
        node_file << mbImpl->id_from_handle( node_handle );
        node_file.width( 20 );
        node_file << coord[0];
        node_file << coord[1];
        node_file << coord[2] << std::endl;
    // update header to load nodes
    ans_file << "nread," << base_string << ",node" << std::endl;
    // search for all node sets (Dirichlet Sets)
    Range node_mesh_sets;
    int ns_id;
    result = mbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET, &mDirichletSetTag, NULL, 1, node_mesh_sets );
    for( Range::iterator ns_it = node_mesh_sets.begin(); ns_it != node_mesh_sets.end(); ++ns_it )
        result = mbImpl->tag_get_data( mDirichletSetTag, &( *ns_it ), 1, &ns_id );
        std::vector< EntityHandle > node_vector;
        result = mbImpl->get_entities_by_handle( *ns_it, node_vector, true );
        // for every nodeset found, cycle through nodes in set:
        for( std::vector< EntityHandle >::iterator node_it = node_vector.begin(); node_it != node_vector.end();
             ++node_it )
            int ns_node_id = mbImpl->id_from_handle( *node_it );
            if( node_it == node_vector.begin() )
                // select first node in new list
                ans_file << "nsel,s,node,," << std::setw( 8 ) << ns_node_id << std::endl;
            else
                // append node to list
                ans_file << "nsel,a,node,," << std::setw( 8 ) << ns_node_id << std::endl;
        // create NS(#) nodeset
        ans_file << "cm,NS" << ns_id << ",node" << std::endl;
    // ANSYS Element format:
    // I, J, K, L, M, N, O, P,etc... MAT, TYPE, REAL, SECNUM, ESYS, IEL
    // I-P are nodes of element
    // MAT = material number
    // TYPE = Element type number
    // REAL = Real constant set number
    // SECNUM = section attribute number
    // ESYS = coordinate system for nodes
    // IEL = element # (unique?)
    // For all nodes past 8, write on second line
    // Write all MBTET elements
    Range tet_range;
    result = mbImpl->get_entities_by_type( output_set, MBTET, tet_range, true );
    for( Range::iterator elem_it = tet_range.begin(); elem_it != tet_range.end(); ++elem_it )
        EntityHandle elem_handle = *elem_it;
        int elem_id              = mbImpl->id_from_handle( elem_handle );
        std::vector< EntityHandle > conn;
        result = mbImpl->get_connectivity( &elem_handle, 1, conn, false );
        // make sure 4 or 10 node tet
        if( conn.size() != 4 && conn.size() != 10 )
            std::cout << "Support not added for element type. \n";
            return MB_FAILURE;
        // write information for 4 node tet
        if( conn.size() == 4 )
            elem_file << std::setw( 8 ) << conn[0] << std::setw( 8 ) << conn[1];
            elem_file << std::setw( 8 ) << conn[2] << std::setw( 8 ) << conn[2];
            elem_file << std::setw( 8 ) << conn[3] << std::setw( 8 ) << conn[3];
            elem_file << std::setw( 8 ) << MATDefault << std::setw( 8 ) << ETSolid45;
            elem_file << std::setw( 8 ) << "1" << std::setw( 8 ) << "1";
            elem_file << std::setw( 8 ) << "0" << std::setw( 8 ) << elem_id;
            elem_file << std::endl;
        // write information for 10 node tet
        if( conn.size() == 10 )
            elem_file << std::setw( 8 ) << conn[2] << std::setw( 8 ) << conn[3];
            elem_file << std::setw( 8 ) << conn[4] << std::setw( 8 ) << conn[5];
            elem_file << std::setw( 8 ) << conn[6] << std::setw( 8 ) << conn[7];
            elem_file << std::setw( 8 ) << MATDefault << std::setw( 8 ) << ETSolid92;
            elem_file << std::setw( 8 ) << conn[8] << std::setw( 8 ) << conn[9];
    // Write all MBHEX elements
    Range hex_range;
    result = mbImpl->get_entities_by_type( output_set, MBHEX, hex_range, true );
    for( Range::iterator elem_it = hex_range.begin(); elem_it != hex_range.end(); ++elem_it )
        // make sure supported hex type
        if( conn.size() != 8 && conn.size() != 20 )
            return MB_FAILURE;
        // write information for 8 node hex
        if( conn.size() == 8 )
        // write information for 20 node hex
        if( conn.size() == 20 )
            elem_file << std::setw( 8 ) << conn[1] << std::setw( 8 ) << conn[0];
            elem_file << std::setw( 8 ) << conn[7] << std::setw( 8 ) << conn[6];
            elem_file << std::setw( 8 ) << MATDefault << std::setw( 8 ) << ETSolid95;
            elem_file << std::setw( 8 ) << conn[16] << std::setw( 8 ) << conn[13];
            elem_file << std::setw( 8 ) << conn[8] << std::setw( 8 ) << conn[12];
            elem_file << std::setw( 8 ) << conn[18] << std::setw( 8 ) << conn[14];
            elem_file << std::setw( 8 ) << conn[10] << std::setw( 8 ) << conn[15];
            elem_file << std::setw( 8 ) << conn[19] << std::setw( 8 ) << conn[17];
            elem_file << std::setw( 8 ) << conn[9] << std::setw( 8 ) << conn[11];
    // Write all MBPRISM elements
    Range prism_range;
    result = mbImpl->get_entities_by_type( output_set, MBPRISM, prism_range, true );
    for( Range::iterator elem_it = prism_range.begin(); elem_it != prism_range.end(); ++elem_it )
        // make sure supported prism type
        if( conn.size() != 6 )
            return MB_FAILURE;
        // write information for 6 node prism
        if( conn.size() == 6 )
            elem_file << std::setw( 8 ) << conn[0] << std::setw( 8 ) << conn[3];
            elem_file << std::setw( 8 ) << conn[4] << std::setw( 8 ) << conn[4];
            elem_file << std::setw( 8 ) << conn[1] << std::setw( 8 ) << conn[2];
            elem_file << std::setw( 8 ) << conn[5] << std::setw( 8 ) << conn[5];
    // create element types (for now writes all, even if not used)
    ans_file << "et," << ETSolid45 << ",SOLID45" << std::endl;
    ans_file << "et," << ETSolid92 << ",SOLID92" << std::endl;
    ans_file << "et," << ETSolid95 << ",SOLID95" << std::endl;
    // xxx pyramids, other elements later...
    // write header to load elements
    ans_file << "eread," << base_string << ",elem" << std::endl;
    // search for all side sets (Neumann)
    Range side_mesh_sets;
    int ss_id;
    result = mbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET, &mNeumannSetTag, NULL, 1, side_mesh_sets );
    // cycle through all sets found
    for( Range::iterator ss_it = side_mesh_sets.begin(); ss_it != side_mesh_sets.end(); ++ss_it )
        result = mbImpl->tag_get_data( mNeumannSetTag, &( *ss_it ), 1, &ss_id );
        std::vector< EntityHandle > elem_vector;
        result = mbImpl->get_entities_by_handle( *ss_it, elem_vector, true );
        // cycle through elements in current side set
        for( std::vector< EntityHandle >::iterator elem_it = elem_vector.begin(); elem_it != elem_vector.end();
             ++elem_it )
            // instead of selecting current element in set, select its nodes...
            result = mbImpl->get_connectivity( &elem_handle, 1, conn );
            if( elem_it == elem_vector.begin() )
                ans_file << "nsel,s,node,," << std::setw( 8 ) << conn[0] << std::endl;
                for( unsigned int i = 1; i < conn.size(); i++ )
                    ans_file << "nsel,a,node,," << std::setw( 8 ) << conn[i] << std::endl;
            else
                for( unsigned int i = 0; i < conn.size(); i++ )
        // create SS(#) node set
        ans_file << "cm,SS" << ss_id << ",node" << std::endl;
    // Gather all element blocks
    Range matset;
    int mat_id;
    result = mbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET, &mMaterialSetTag, NULL, 1, matset );
    // cycle through all elem blocks
    for( Range::iterator mat_it = matset.begin(); mat_it != matset.end(); ++mat_it )
        EntityHandle matset_handle = *mat_it;
        result                     = mbImpl->tag_get_data( mMaterialSetTag, &matset_handle, 1, &mat_id );
        std::vector< EntityHandle > mat_vector;
        result = mbImpl->get_entities_by_handle( *mat_it, mat_vector, true );
        // cycle through elements in current mat set
        for( std::vector< EntityHandle >::iterator elem_it = mat_vector.begin(); elem_it != mat_vector.end();
             ++elem_it )
            if( elem_it == mat_vector.begin() )
                ans_file << "esel,s,elem,," << std::setw( 8 ) << elem_id << std::endl;
            else
                ans_file << "esel,a,elem,," << std::setw( 8 ) << elem_id << std::endl;
        // for each matset, write block command
        ans_file << "cm,EB" << mat_id << ",elem" << std::endl;
    // close all file streams
    node_file.close();
    elem_file.close();
    ans_file.close();
    return MB_SUCCESS;
ErrorCode moab::WriteAns::write_nodes ( const int  num_nodes,
const Range &  nodes,
) [private]
Member Data Documentation
std::string moab::WriteAns::fileName [private]
file name
Definition at line 137 of file WriteAns.hpp.
interface instance
Definition at line 133 of file WriteAns.hpp.
Referenced by write_file().
Definition at line 140 of file WriteAns.hpp.
Definition at line 145 of file WriteAns.hpp.
Referenced by write_file(), and WriteAns().
Definition at line 147 of file WriteAns.hpp.
Cached tags for reading. Note that all these tags are defined when the core is initialized.
Definition at line 144 of file WriteAns.hpp.
Definition at line 148 of file WriteAns.hpp.
Definition at line 146 of file WriteAns.hpp.
List of all members.
