MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 #ifdef WIN32 00017 #ifdef _DEBUG 00018 // turn off warnings that say they debugging identifier has been truncated 00019 // this warning comes up when using some STL containers 00020 #pragma warning( disable : 4786 ) 00021 #endif 00022 #endif 00023 00024 #include "WriteAns.hpp" 00025 00026 #include <utility> 00027 #include <algorithm> 00028 #include <ctime> 00029 #include <string> 00030 #include <vector> 00031 #include <cstdio> 00032 #include <iostream> 00033 #include <fstream> 00034 #include <iomanip> 00035 00036 #include "moab/Interface.hpp" 00037 #include "moab/Range.hpp" 00038 #include <cassert> 00039 #include "Internals.hpp" 00040 #include "ExoIIUtil.hpp" 00041 #include "MBTagConventions.hpp" 00042 00043 #define INS_ID( stringvar, prefix, id ) sprintf( stringvar, prefix, id ) 00044 00045 namespace moab 00046 { 00047 00048 WriterIface* WriteAns::factory( Interface* iface ) 00049 { 00050 return new WriteAns( iface ); 00051 } 00052 00053 WriteAns::WriteAns( Interface* impl ) : mbImpl( impl ), mCurrentMeshHandle( 0 ), mGlobalIdTag( 0 ), mMatSetIdTag( 0 ) 00054 { 00055 assert( impl != NULL ); 00056 00057 // impl->query_interface( mWriteIface ); 00058 00059 // initialize in case tag_get_handle fails below 00060 //! get and cache predefined tag handles 00061 const int negone = -1; 00062 impl->tag_get_handle( MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mMaterialSetTag, MB_TAG_SPARSE | MB_TAG_CREAT, 00063 &negone ); 00064 00065 impl->tag_get_handle( DIRICHLET_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mDirichletSetTag, MB_TAG_SPARSE | MB_TAG_CREAT, 00066 &negone ); 00067 00068 impl->tag_get_handle( NEUMANN_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mNeumannSetTag, MB_TAG_SPARSE | MB_TAG_CREAT, 00069 &negone ); 00070 } 00071 00072 WriteAns::~WriteAns() 00073 { 00074 // mbImpl->release_interface(mWriteIface); 00075 } 00076 00077 ErrorCode WriteAns::write_file( const char* file_name, 00078 const bool /* overwrite (commented out to remove warning) */, 00079 const FileOptions&, 00080 const EntityHandle* ent_handles, 00081 const int num_sets, 00082 const std::vector< std::string >&, 00083 const Tag*, 00084 int, 00085 int ) 00086 { 00087 assert( 0 != mMaterialSetTag && 0 != mNeumannSetTag && 0 != mDirichletSetTag ); 00088 00089 ErrorCode result; 00090 00091 // set SOLID45 element type to #60000, hope nobody has already... 00092 const char* ETSolid45 = "60045"; 00093 const char* ETSolid92 = "60042"; 00094 const char* ETSolid95 = "60095"; 00095 00096 // set Material id # to be used as default for all elements 00097 // will need to be subsequently reassigned inside ANSYS 00098 // Can, although have not, declare similar defaults for other attributes 00099 const char* MATDefault = "1"; 00100 00101 // create file streams for writing 00102 std::ofstream node_file; 00103 std::ofstream elem_file; 00104 std::ofstream ans_file; 00105 00106 // get base filename from filename.ans 00107 std::string temp_string; 00108 std::string base_string; 00109 base_string.assign( file_name ); 00110 base_string.replace( base_string.find_last_of( ".ans" ) - 3, 4, "" ); 00111 00112 // open node file for writing 00113 temp_string = base_string + ".node"; 00114 node_file.open( temp_string.c_str() ); 00115 node_file.setf( std::ios::scientific, std::ios::floatfield ); 00116 node_file.precision( 13 ); 00117 00118 // open elem file for writing 00119 temp_string = base_string + ".elem"; 00120 elem_file.open( temp_string.c_str() ); 00121 00122 // open ans file for writing 00123 ans_file.open( file_name ); 00124 ans_file << "/prep7" << std::endl; 00125 00126 // gather single output set 00127 EntityHandle output_set = 0; 00128 if( ent_handles && num_sets > 0 ) 00129 { 00130 for( int i = 0; i < num_sets; i++ ) 00131 { 00132 // from template, maybe can be removed 00133 result = mbImpl->unite_meshset( output_set, ent_handles[i] ); 00134 if( result != MB_SUCCESS ) return result; 00135 } 00136 } 00137 00138 // search for all nodes 00139 Range node_range; 00140 result = mbImpl->get_entities_by_type( output_set, MBVERTEX, node_range, true ); 00141 if( result != MB_SUCCESS ) return result; 00142 00143 // Commented out until Seg Fault taken care of in gather_nodes... 00144 // get any missing nodes which are needed for elements 00145 // Range all_ent_range,missing_range; 00146 // result=mbImpl->get_entities_by_handle(output_set,all_ent_range,true); 00147 // if(result !=MB_SUCCESS) return result; 00148 // result=mWriteIface->gather_nodes_from_elements(all_ent_range,0,missing_range); 00149 // node_range.merge(missing_range); 00150 00151 // write the nodes 00152 double coord[3]; 00153 for( Range::iterator it = node_range.begin(); it != node_range.end(); ++it ) 00154 { 00155 EntityHandle node_handle = *it; 00156 00157 result = mbImpl->get_coords( &node_handle, 1, coord ); 00158 if( result != MB_SUCCESS ) return result; 00159 00160 node_file.width( 8 ); 00161 node_file << mbImpl->id_from_handle( node_handle ); 00162 node_file.width( 20 ); 00163 node_file << coord[0]; 00164 node_file.width( 20 ); 00165 node_file << coord[1]; 00166 node_file.width( 20 ); 00167 node_file << coord[2] << std::endl; 00168 } 00169 00170 // update header to load nodes 00171 ans_file << "nread," << base_string << ",node" << std::endl; 00172 00173 // search for all node sets (Dirichlet Sets) 00174 Range node_mesh_sets; 00175 int ns_id; 00176 result = mbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET, &mDirichletSetTag, NULL, 1, node_mesh_sets ); 00177 if( result != MB_SUCCESS ) return result; 00178 00179 for( Range::iterator ns_it = node_mesh_sets.begin(); ns_it != node_mesh_sets.end(); ++ns_it ) 00180 { 00181 result = mbImpl->tag_get_data( mDirichletSetTag, &( *ns_it ), 1, &ns_id ); 00182 if( result != MB_SUCCESS ) return result; 00183 std::vector< EntityHandle > node_vector; 00184 result = mbImpl->get_entities_by_handle( *ns_it, node_vector, true ); 00185 if( result != MB_SUCCESS ) return result; 00186 // for every nodeset found, cycle through nodes in set: 00187 for( std::vector< EntityHandle >::iterator node_it = node_vector.begin(); node_it != node_vector.end(); 00188 ++node_it ) 00189 { 00190 int ns_node_id = mbImpl->id_from_handle( *node_it ); 00191 if( node_it == node_vector.begin() ) 00192 { 00193 // select first node in new list 00194 ans_file << "nsel,s,node,," << std::setw( 8 ) << ns_node_id << std::endl; 00195 } 00196 else 00197 { 00198 // append node to list 00199 ans_file << "nsel,a,node,," << std::setw( 8 ) << ns_node_id << std::endl; 00200 } 00201 } 00202 // create NS(#) nodeset 00203 ans_file << "cm,NS" << ns_id << ",node" << std::endl; 00204 } 00205 00206 // ANSYS Element format: 00207 // I, J, K, L, M, N, O, P,etc... MAT, TYPE, REAL, SECNUM, ESYS, IEL 00208 // I-P are nodes of element 00209 // MAT = material number 00210 // TYPE = Element type number 00211 // REAL = Real constant set number 00212 // SECNUM = section attribute number 00213 // ESYS = coordinate system for nodes 00214 // IEL = element # (unique?) 00215 // For all nodes past 8, write on second line 00216 00217 // Write all MBTET elements 00218 Range tet_range; 00219 result = mbImpl->get_entities_by_type( output_set, MBTET, tet_range, true ); 00220 if( result != MB_SUCCESS ) return result; 00221 for( Range::iterator elem_it = tet_range.begin(); elem_it != tet_range.end(); ++elem_it ) 00222 { 00223 EntityHandle elem_handle = *elem_it; 00224 int elem_id = mbImpl->id_from_handle( elem_handle ); 00225 std::vector< EntityHandle > conn; 00226 result = mbImpl->get_connectivity( &elem_handle, 1, conn, false ); 00227 if( result != MB_SUCCESS ) return result; 00228 // make sure 4 or 10 node tet 00229 if( conn.size() != 4 && conn.size() != 10 ) 00230 { 00231 std::cout << "Support not added for element type. \n"; 00232 return MB_FAILURE; 00233 } 00234 // write information for 4 node tet 00235 if( conn.size() == 4 ) 00236 { 00237 elem_file << std::setw( 8 ) << conn[0] << std::setw( 8 ) << conn[1]; 00238 elem_file << std::setw( 8 ) << conn[2] << std::setw( 8 ) << conn[2]; 00239 elem_file << std::setw( 8 ) << conn[3] << std::setw( 8 ) << conn[3]; 00240 elem_file << std::setw( 8 ) << conn[3] << std::setw( 8 ) << conn[3]; 00241 00242 elem_file << std::setw( 8 ) << MATDefault << std::setw( 8 ) << ETSolid45; 00243 elem_file << std::setw( 8 ) << "1" << std::setw( 8 ) << "1"; 00244 elem_file << std::setw( 8 ) << "0" << std::setw( 8 ) << elem_id; 00245 elem_file << std::endl; 00246 } 00247 00248 // write information for 10 node tet 00249 if( conn.size() == 10 ) 00250 { 00251 elem_file << std::setw( 8 ) << conn[0] << std::setw( 8 ) << conn[1]; 00252 elem_file << std::setw( 8 ) << conn[2] << std::setw( 8 ) << conn[3]; 00253 elem_file << std::setw( 8 ) << conn[4] << std::setw( 8 ) << conn[5]; 00254 elem_file << std::setw( 8 ) << conn[6] << std::setw( 8 ) << conn[7]; 00255 00256 elem_file << std::setw( 8 ) << MATDefault << std::setw( 8 ) << ETSolid92; 00257 elem_file << std::setw( 8 ) << "1" << std::setw( 8 ) << "1"; 00258 elem_file << std::setw( 8 ) << "0" << std::setw( 8 ) << elem_id; 00259 elem_file << std::endl; 00260 00261 elem_file << std::setw( 8 ) << conn[8] << std::setw( 8 ) << conn[9]; 00262 elem_file << std::endl; 00263 } 00264 } 00265 00266 // Write all MBHEX elements 00267 Range hex_range; 00268 result = mbImpl->get_entities_by_type( output_set, MBHEX, hex_range, true ); 00269 if( result != MB_SUCCESS ) return result; 00270 for( Range::iterator elem_it = hex_range.begin(); elem_it != hex_range.end(); ++elem_it ) 00271 { 00272 EntityHandle elem_handle = *elem_it; 00273 int elem_id = mbImpl->id_from_handle( elem_handle ); 00274 std::vector< EntityHandle > conn; 00275 result = mbImpl->get_connectivity( &elem_handle, 1, conn, false ); 00276 if( result != MB_SUCCESS ) return result; 00277 // make sure supported hex type 00278 if( conn.size() != 8 && conn.size() != 20 ) 00279 { 00280 std::cout << "Support not added for element type. \n"; 00281 return MB_FAILURE; 00282 } 00283 00284 // write information for 8 node hex 00285 if( conn.size() == 8 ) 00286 { 00287 elem_file << std::setw( 8 ) << conn[0] << std::setw( 8 ) << conn[1]; 00288 elem_file << std::setw( 8 ) << conn[2] << std::setw( 8 ) << conn[3]; 00289 elem_file << std::setw( 8 ) << conn[4] << std::setw( 8 ) << conn[5]; 00290 elem_file << std::setw( 8 ) << conn[6] << std::setw( 8 ) << conn[7]; 00291 00292 elem_file << std::setw( 8 ) << MATDefault << std::setw( 8 ) << ETSolid45; 00293 elem_file << std::setw( 8 ) << "1" << std::setw( 8 ) << "1"; 00294 elem_file << std::setw( 8 ) << "0" << std::setw( 8 ) << elem_id; 00295 elem_file << std::endl; 00296 } 00297 00298 // write information for 20 node hex 00299 if( conn.size() == 20 ) 00300 { 00301 00302 elem_file << std::setw( 8 ) << conn[4] << std::setw( 8 ) << conn[5]; 00303 elem_file << std::setw( 8 ) << conn[1] << std::setw( 8 ) << conn[0]; 00304 elem_file << std::setw( 8 ) << conn[7] << std::setw( 8 ) << conn[6]; 00305 elem_file << std::setw( 8 ) << conn[2] << std::setw( 8 ) << conn[3]; 00306 00307 elem_file << std::setw( 8 ) << MATDefault << std::setw( 8 ) << ETSolid95; 00308 elem_file << std::setw( 8 ) << "1" << std::setw( 8 ) << "1"; 00309 elem_file << std::setw( 8 ) << "0" << std::setw( 8 ) << elem_id; 00310 elem_file << std::endl; 00311 00312 elem_file << std::setw( 8 ) << conn[16] << std::setw( 8 ) << conn[13]; 00313 elem_file << std::setw( 8 ) << conn[8] << std::setw( 8 ) << conn[12]; 00314 elem_file << std::setw( 8 ) << conn[18] << std::setw( 8 ) << conn[14]; 00315 elem_file << std::setw( 8 ) << conn[10] << std::setw( 8 ) << conn[15]; 00316 elem_file << std::setw( 8 ) << conn[19] << std::setw( 8 ) << conn[17]; 00317 elem_file << std::setw( 8 ) << conn[9] << std::setw( 8 ) << conn[11]; 00318 elem_file << std::endl; 00319 } 00320 } 00321 // Write all MBPRISM elements 00322 Range prism_range; 00323 result = mbImpl->get_entities_by_type( output_set, MBPRISM, prism_range, true ); 00324 if( result != MB_SUCCESS ) return result; 00325 for( Range::iterator elem_it = prism_range.begin(); elem_it != prism_range.end(); ++elem_it ) 00326 { 00327 EntityHandle elem_handle = *elem_it; 00328 int elem_id = mbImpl->id_from_handle( elem_handle ); 00329 std::vector< EntityHandle > conn; 00330 result = mbImpl->get_connectivity( &elem_handle, 1, conn, false ); 00331 if( result != MB_SUCCESS ) return result; 00332 // make sure supported prism type 00333 if( conn.size() != 6 ) 00334 { 00335 std::cout << "Support not added for element type. \n"; 00336 return MB_FAILURE; 00337 } 00338 00339 // write information for 6 node prism 00340 if( conn.size() == 6 ) 00341 { 00342 elem_file << std::setw( 8 ) << conn[0] << std::setw( 8 ) << conn[3]; 00343 elem_file << std::setw( 8 ) << conn[4] << std::setw( 8 ) << conn[4]; 00344 elem_file << std::setw( 8 ) << conn[1] << std::setw( 8 ) << conn[2]; 00345 elem_file << std::setw( 8 ) << conn[5] << std::setw( 8 ) << conn[5]; 00346 00347 elem_file << std::setw( 8 ) << MATDefault << std::setw( 8 ) << ETSolid45; 00348 elem_file << std::setw( 8 ) << "1" << std::setw( 8 ) << "1"; 00349 elem_file << std::setw( 8 ) << "0" << std::setw( 8 ) << elem_id; 00350 elem_file << std::endl; 00351 } 00352 } 00353 00354 // create element types (for now writes all, even if not used) 00355 ans_file << "et," << ETSolid45 << ",SOLID45" << std::endl; 00356 ans_file << "et," << ETSolid92 << ",SOLID92" << std::endl; 00357 ans_file << "et," << ETSolid95 << ",SOLID95" << std::endl; 00358 00359 // xxx pyramids, other elements later... 00360 00361 // write header to load elements 00362 ans_file << "eread," << base_string << ",elem" << std::endl; 00363 00364 // search for all side sets (Neumann) 00365 Range side_mesh_sets; 00366 int ss_id; 00367 result = mbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET, &mNeumannSetTag, NULL, 1, side_mesh_sets ); 00368 if( result != MB_SUCCESS ) return result; 00369 // cycle through all sets found 00370 for( Range::iterator ss_it = side_mesh_sets.begin(); ss_it != side_mesh_sets.end(); ++ss_it ) 00371 { 00372 result = mbImpl->tag_get_data( mNeumannSetTag, &( *ss_it ), 1, &ss_id ); 00373 if( result != MB_SUCCESS ) return result; 00374 std::vector< EntityHandle > elem_vector; 00375 result = mbImpl->get_entities_by_handle( *ss_it, elem_vector, true ); 00376 if( result != MB_SUCCESS ) return result; 00377 00378 // cycle through elements in current side set 00379 for( std::vector< EntityHandle >::iterator elem_it = elem_vector.begin(); elem_it != elem_vector.end(); 00380 ++elem_it ) 00381 { 00382 EntityHandle elem_handle = *elem_it; 00383 00384 // instead of selecting current element in set, select its nodes... 00385 std::vector< EntityHandle > conn; 00386 result = mbImpl->get_connectivity( &elem_handle, 1, conn ); 00387 if( result != MB_SUCCESS ) return result; 00388 if( elem_it == elem_vector.begin() ) 00389 { 00390 ans_file << "nsel,s,node,," << std::setw( 8 ) << conn[0] << std::endl; 00391 for( unsigned int i = 1; i < conn.size(); i++ ) 00392 { 00393 ans_file << "nsel,a,node,," << std::setw( 8 ) << conn[i] << std::endl; 00394 } 00395 } 00396 else 00397 { 00398 for( unsigned int i = 0; i < conn.size(); i++ ) 00399 { 00400 ans_file << "nsel,a,node,," << std::setw( 8 ) << conn[i] << std::endl; 00401 } 00402 } 00403 } 00404 // create SS(#) node set 00405 ans_file << "cm,SS" << ss_id << ",node" << std::endl; 00406 } 00407 00408 // Gather all element blocks 00409 Range matset; 00410 int mat_id; 00411 result = mbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET, &mMaterialSetTag, NULL, 1, matset ); 00412 if( result != MB_SUCCESS ) return result; 00413 // cycle through all elem blocks 00414 for( Range::iterator mat_it = matset.begin(); mat_it != matset.end(); ++mat_it ) 00415 { 00416 EntityHandle matset_handle = *mat_it; 00417 result = mbImpl->tag_get_data( mMaterialSetTag, &matset_handle, 1, &mat_id ); 00418 if( result != MB_SUCCESS ) return result; 00419 std::vector< EntityHandle > mat_vector; 00420 result = mbImpl->get_entities_by_handle( *mat_it, mat_vector, true ); 00421 if( result != MB_SUCCESS ) return result; 00422 // cycle through elements in current mat set 00423 for( std::vector< EntityHandle >::iterator elem_it = mat_vector.begin(); elem_it != mat_vector.end(); 00424 ++elem_it ) 00425 { 00426 EntityHandle elem_handle = *elem_it; 00427 int elem_id = mbImpl->id_from_handle( elem_handle ); 00428 if( elem_it == mat_vector.begin() ) 00429 { 00430 ans_file << "esel,s,elem,," << std::setw( 8 ) << elem_id << std::endl; 00431 } 00432 else 00433 { 00434 ans_file << "esel,a,elem,," << std::setw( 8 ) << elem_id << std::endl; 00435 } 00436 } 00437 // for each matset, write block command 00438 ans_file << "cm,EB" << mat_id << ",elem" << std::endl; 00439 } 00440 00441 // close all file streams 00442 node_file.close(); 00443 elem_file.close(); 00444 ans_file.close(); 00445 00446 return MB_SUCCESS; 00447 } 00448 00449 } // namespace moab
