MOAB: Mesh Oriented datABase
(version 5.4.1)
ASCII and Binary Stereo Lithography File writers. More...
#include <WriteSTL.hpp>
Inheritance diagram for moab::WriteSTL:
Collaboration diagram for moab::WriteSTL:Public Member Functions | |
| WriteSTL (Interface *impl) | |
| Constructor. | |
| virtual | ~WriteSTL () |
| Destructor. | |
| ErrorCode | write_file (const char *file_name, const bool overwrite, const FileOptions &opts, const EntityHandle *output_list, const int num_sets, const std::vector< std::string > &qa_list, const Tag *tag_list=NULL, int num_tags=0, int export_dimension=3) |
| writes out a file | |
Static Public Member Functions | |
| static WriterIface * | factory (Interface *) |
| factory method forSTL writer | |
Protected Types | |
| enum | ByteOrder { STL_BIG_ENDIAN, STL_LITTLE_ENDIAN, STL_UNKNOWN_BYTE_ORDER } |
Protected Member Functions | |
| ErrorCode | ascii_write_triangles (FILE *file, const char header[81], const Range &triangles, int precision) |
| Write list of triangles to an STL file. | |
| ErrorCode | binary_write_triangles (FILE *file, const char header[81], ByteOrder byte_order, const Range &triangles) |
| ErrorCode | get_triangle_data (const double vtx_coords[9], float v1[3], float v2[3], float v3[3], float n[3]) |
| ErrorCode | get_triangle_data (const double vtx_coords[9], CartVect &v1, CartVect &v2, CartVect &v3, CartVect &n) |
Protected Attributes | |
| Interface * | mbImpl |
| interface instance | |
| WriteUtilIface * | mWriteIface |
Private Member Functions | |
| ErrorCode | make_header (char header[81], const std::vector< std::string > &qa_list) |
| ErrorCode | get_triangles (const EntityHandle *set_array, int set_array_length, Range &triangles) |
| FILE * | open_file (const char *name, bool overwrite, bool binary) |
This writer will write only the MBTRI elements in the mesh. It will not decompose other 2-D elements into triangles, nor will it skin the mesh or do any other high-level operation to generate triangles from 3-D elements.
Binary files will be written with a little-endian byte order by default. The byte order can be controlled with writer options.
Definition at line 42 of file WriteSTL.hpp.
enum moab::WriteSTL::ByteOrder [protected] |
Definition at line 67 of file WriteSTL.hpp.
| WriteSTL::WriteSTL | ( | Interface * | impl | ) |
Constructor.
Definition at line 59 of file WriteSTL.cpp.
References mWriteIface, and moab::Interface::query_interface().
Referenced by factory().
: mbImpl( impl ) { impl->query_interface( mWriteIface ); }
| WriteSTL::~WriteSTL | ( | ) | [virtual] |
Destructor.
Definition at line 64 of file WriteSTL.cpp.
References mbImpl, mWriteIface, and moab::Interface::release_interface().
mbImpl->release_interface( mWriteIface );
| ErrorCode WriteSTL::ascii_write_triangles | ( | FILE * | file, |
| const char | header[81], | ||
| const Range & | triangles, | ||
| int | precision | ||
| ) | [protected] |
Definition at line 234 of file WriteSTL.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), get_triangle_data(), MB_FILE_WRITE_ERROR, MB_SUCCESS, and mbImpl.
Referenced by write_file().
const char solid_name[] = "MOAB";
char myheader[81] = "solid ";
strcat( myheader, solid_name );
strncat( myheader, header, 80 );
if( EOF == fputs( myheader, file ) || EOF == fputs( "\n", file ) ) return MB_FILE_WRITE_ERROR;
ErrorCode rval;
double coords[9];
CartVect v1, v2, v3, n;
for( Range::const_iterator iter = triangles.begin(); iter != triangles.end(); ++iter )
const EntityHandle* conn;
int num_vtx;
rval = mbImpl->get_connectivity( *iter, conn, num_vtx );
if( MB_SUCCESS != rval ) return rval;
if( num_vtx != 3 ) return MB_FAILURE;
rval = mbImpl->get_coords( conn, 3, coords );
rval = get_triangle_data( coords, v1, v2, v3, n );
fprintf( file, "facet normal %e %e %e\n", n[0], n[1], n[2] );
fprintf( file, "outer loop\n" );
fprintf( file, "vertex %.*e %.*e %.*e\n", prec, (float)v1[0], prec, (float)v1[1], prec, (float)v1[2] );
fprintf( file, "vertex %.*e %.*e %.*e\n", prec, (float)v2[0], prec, (float)v2[1], prec, (float)v2[2] );
fprintf( file, "vertex %.*e %.*e %.*e\n", prec, (float)v3[0], prec, (float)v3[1], prec, (float)v3[2] );
fprintf( file, "endloop\n" );
fprintf( file, "endfacet\n" );
fprintf( file, "endsolid %s\n", solid_name );
return MB_SUCCESS;
| ErrorCode WriteSTL::binary_write_triangles | ( | FILE * | file, |
| ByteOrder | byte_order, | ||
| const Range & | triangles | ||
| ) | [protected] |
Definition at line 284 of file WriteSTL.cpp.
References moab::Range::begin(), moab::SysUtil::byteswap(), moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), get_triangle_data(), moab::SysUtil::little_endian(), MB_FILE_WRITE_ERROR, MB_SUCCESS, mbImpl, moab::BinTri::normal, moab::BinTri::pad, moab::Range::size(), STL_BIG_ENDIAN, moab::SysUtil::swap_bytes(), moab::BinTri::vertex1, moab::BinTri::vertex2, and moab::BinTri::vertex3.
ErrorCode rval;
if( 1 != fwrite( header, 80, 1, file ) ) return MB_FILE_WRITE_ERROR;
// Default to little endian if byte_order == UNKNOWN_BYTE_ORDER
const bool want_big_endian = ( byte_order == STL_BIG_ENDIAN );
const bool am_big_endian = !SysUtil::little_endian();
const bool swap_bytes = ( want_big_endian == am_big_endian );
if( triangles.size() > INT_MAX ) // Can't write that many triangles
return MB_FAILURE;
uint32_t count = (uint32_t)triangles.size();
if( swap_bytes ) SysUtil::byteswap( &count, 1 );
if( 1 != fwrite( &count, 4, 1, file ) ) return MB_FILE_WRITE_ERROR;
double coords[9];
BinTri tri;
tri.pad[0] = tri.pad[1] = '\0';
int num_vtx;
rval = get_triangle_data( coords, tri.vertex1, tri.vertex2, tri.vertex3, tri.normal );
if( swap_bytes )
SysUtil::byteswap( tri.normal, 3 );
SysUtil::byteswap( tri.vertex1, 3 );
SysUtil::byteswap( tri.vertex2, 3 );
SysUtil::byteswap( tri.vertex3, 3 );
if( 1 != fwrite( &tri, 50, 1, file ) ) return MB_FILE_WRITE_ERROR;
return MB_SUCCESS;
| WriterIface * WriteSTL::factory | ( | Interface * | iface | ) | [static] |
Definition at line 54 of file WriteSTL.cpp.
References WriteSTL().
Referenced by moab::ReaderWriterSet::ReaderWriterSet().
| ErrorCode WriteSTL::get_triangle_data | ( | const double | vtx_coords[9], |
| float | v1[3], | ||
| float | v2[3], | ||
| float | v3[3], | ||
| float | n[3] | ||
| ) | [protected] |
Given an array of vertex coordinates for a triangle, pass back individual point coordinates as floats and calculate triangle normal.
Definition at line 207 of file WriteSTL.cpp.
References ErrorCode, moab::CartVect::get(), and MB_SUCCESS.
Referenced by ascii_write_triangles(), and binary_write_triangles().
CartVect cv1, cv2, cv3, cn;
ErrorCode rval = get_triangle_data( coords, cv1, cv2, cv3, cn );
cv1.get( v1 );
cv2.get( v2 );
cv3.get( v3 );
cn.get( n );
return MB_SUCCESS;
| CartVect & | v1, | ||
| CartVect & | v2, | ||
| CartVect & | v3, | ||
| CartVect & | n | ||
| ) | [protected] |
Definition at line 221 of file WriteSTL.cpp.
References MB_SUCCESS, and moab::CartVect::normalize().
v1 = coords;
v2 = coords + 3;
v3 = coords + 6;
n = ( v2 - v1 ) * ( v3 - v1 );
n.normalize();
return MB_SUCCESS;
| ErrorCode WriteSTL::get_triangles | ( | const EntityHandle * | set_array, |
| int | set_array_length, | ||
| ) | [private] |
Get triangles to write from input array of entity sets. If no sets, gets all triangles.
Definition at line 190 of file WriteSTL.cpp.
References ErrorCode, moab::Interface::get_entities_by_type(), MB_SUCCESS, mbImpl, MBTRI, and moab::Range::merge().
if( !set_array || 0 == set_array_length ) return mbImpl->get_entities_by_type( 0, MBTRI, triangles );
const EntityHandle* iter = set_array;
const EntityHandle* end = iter + set_array_length;
for( ; iter != end; ++iter )
Range r;
ErrorCode rval = mbImpl->get_entities_by_type( *iter, MBTRI, r, true );
triangles.merge( r );
return MB_SUCCESS;
| ErrorCode WriteSTL::make_header | ( | char | header[81], |
| const std::vector< std::string > & | qa_list | ||
| ) | [private] |
Construct 80-byte, null-terminated description string from qa_list. Unused space in header will be null-char padded.
Definition at line 172 of file WriteSTL.cpp.
References MB_SUCCESS.
memset( header, 0, 81 );
std::string result;
for( std::vector< std::string >::const_iterator i = qa_list.begin(); i != qa_list.end(); ++i )
result += " ";
result += *i;
size_t len = result.size();
if( len > 80 ) len = 80;
memcpy( header, result.c_str(), len );
return MB_SUCCESS;
| FILE * WriteSTL::open_file | ( | const char * | name, |
| bool | overwrite, | ||
| bool | binary | ||
| ) | [private] |
Open a file, respecting passed overwrite value and subclass-specified value for need_binary_io().
Definition at line 134 of file WriteSTL.cpp.
References _S_IREAD, _S_IWRITE, and MB_SET_ERR_RET_VAL.
// Open file with write access, and create it if it doesn't exist.
int flags = O_WRONLY | O_CREAT;
// Select behavior if the named file already exists. If
// overwrite is true, truncate the file. If it is false,
// make the call to open() fail.
if( overwrite )
flags |= O_TRUNC;
else
flags |= O_EXCL;
// If platform defines a "binary" bit in the file access
// flags (i.e. we're building on windows), then set it
// if we're writing a binary file.
#ifdef O_BINARY
if( binary ) flags |= O_BINARY;
#endif
// Give everyone read and write, but not execute, permission.
// These are not the final permissions for the file. Permissions
// are removed according to the user's umask. All we want to
// say here is that the executable bits should not be set because
// this isn't an executable file. Everything else is a user
// preference and should be left up to the umask.
int creat_mode = _S_IREAD | _S_IWRITE;
// Open the file.
int fd = open( name, flags, creat_mode );
if( fd < 0 )
MB_SET_ERR_RET_VAL( name << ": " << strerror( errno ), NULL );
FILE* result = fdopen( fd, binary ? "wb" : "w" );
if( !result ) close( fd );
return result;
| ErrorCode WriteSTL::write_file | ( | const char * | file_name, |
| const bool | overwrite, | ||
| const FileOptions & | opts, | ||
| const EntityHandle * | output_list, | ||
| const int | num_sets, | ||
| const std::vector< std::string > & | qa_list, | ||
| const Tag * | tag_list = NULL, |
| int | num_tags = 0, |
| int | export_dimension = 3 |
| ) | [virtual] |
writes out a file
Implements moab::WriterIface.
Definition at line 69 of file WriteSTL.cpp.
References ascii_write_triangles(), moab::SysUtil::big_endian(), binary_write_triangles(), moab::DEFAULT_PRECISION, moab::Range::empty(), ErrorCode, moab::FileOptions::get_int_option(), moab::FileOptions::get_null_option(), get_triangles(), moab::SysUtil::little_endian(), make_header(), MB_ENTITY_NOT_FOUND, MB_FILE_DOES_NOT_EXIST, MB_SET_ERR, MB_SUCCESS, MB_TYPE_OUT_OF_RANGE, open_file(), STL_BIG_ENDIAN, STL_LITTLE_ENDIAN, and STL_UNKNOWN_BYTE_ORDER.
char header[81];
Range triangles;
ErrorCode rval;
if( tag_list && num_tags )
MB_SET_ERR( MB_TYPE_OUT_OF_RANGE, "STL file does not support tag data" );
rval = make_header( header, qa_list );
rval = get_triangles( ent_handles, num_sets, triangles );
if( triangles.empty() )
MB_SET_ERR( MB_ENTITY_NOT_FOUND, "No triangles to write" );
bool is_ascii = false, is_binary = false;
if( MB_SUCCESS == opts.get_null_option( "ASCII" ) ) is_ascii = true;
if( MB_SUCCESS == opts.get_null_option( "BINARY" ) ) is_binary = true;
if( is_ascii && is_binary )
MB_SET_ERR( MB_FAILURE, "Conflicting options: BINARY ASCII" );
bool big_endian = false, little_endian = false;
if( MB_SUCCESS == opts.get_null_option( "BIG_ENDIAN" ) ) big_endian = true;
if( MB_SUCCESS == opts.get_null_option( "LITTLE_ENDIAN" ) ) little_endian = true;
if( big_endian && little_endian )
MB_SET_ERR( MB_FAILURE, "Conflicting options: BIG_ENDIAN LITTLE_ENDIAN" );
ByteOrder byte_order = big_endian ? STL_BIG_ENDIAN : little_endian ? STL_LITTLE_ENDIAN : STL_UNKNOWN_BYTE_ORDER;
FILE* file = open_file( file_name, overwrite, is_binary );
if( !file ) return MB_FILE_DOES_NOT_EXIST;
if( is_binary )
rval = binary_write_triangles( file, header, byte_order, triangles );
else
// Get precision for node coordinates
int precision;
if( MB_SUCCESS != opts.get_int_option( "PRECISION", precision ) ) precision = DEFAULT_PRECISION;
rval = ascii_write_triangles( file, header, triangles, precision );
fclose( file );
return rval;
Interface* moab::WriteSTL::mbImpl [protected] |
interface instance
Definition at line 87 of file WriteSTL.hpp.
Referenced by ascii_write_triangles(), binary_write_triangles(), get_triangles(), and ~WriteSTL().
WriteUtilIface* moab::WriteSTL::mWriteIface [protected] |
Definition at line 88 of file WriteSTL.hpp.
Referenced by WriteSTL(), and ~WriteSTL().
