smoab::detail::ReadSparseTag Struct Reference
#include <ReadSparseTag.h>
+ Collaboration diagram for smoab::detail::ReadSparseTag:
Public Member Functions
 ReadSparseTag (const smoab::CellSets &mSets, const smoab::Range &cells, const smoab::Interface &interface)
void fill (vtkIntArray *array, const Tag *cellTag) const
void fill (vtkIdTypeArray *array, const Tag *cellTag) const
Private Member Functions
template<typename T >
void fillRawArray (T *sparseTagArray, std::size_t length, const Tag *cellTag) const
void singleSetRead (T *sparseTagArray, const std::vector< int > &values, std::size_t length) const
void multiSetRead (T *sparseTagArray, const std::vector< int > &values, std::size_t length, int defaultTagValue) const
Private Attributes
const smoab::Interface & Interface
const smoab::CellSets & MeshSets
const smoab::Range & Cells
Detailed Description
Definition at line 17 of file ReadSparseTag.h.
smoab::detail::ReadSparseTag::ReadSparseTag ( const smoab::CellSets &  mSets,
const smoab::Range &  cells,
const smoab::Interface &  interface
) [inline]
Definition at line 20 of file ReadSparseTag.h.
            : Interface( interface ), MeshSets( mSets ), Cells( cells )
Member Function Documentation
void smoab::detail::ReadSparseTag::fill ( vtkIntArray *  array,
const Tag *  cellTag
) const
Definition at line 49 of file ReadSparseTag.h.
References Cells, fillRawArray(), length(), and moab::Range::size().
Referenced by smoab::DataSetConverter::fill(), multiSetRead(), and singleSetRead().
        const std::size_t length = this->Cells.size();
        array->SetNumberOfValues( length );
        int* raw = static_cast< int* >( array->GetVoidPointer( 0 ) );
        this->fillRawArray( raw, length, cellTag );
void smoab::detail::ReadSparseTag::fill ( vtkIdTypeArray *  array,
const Tag *  cellTag
) const
Definition at line 58 of file ReadSparseTag.h.
        vtkIdType* raw = static_cast< vtkIdType* >( array->GetVoidPointer( 0 ) );
void smoab::detail::ReadSparseTag::fillRawArray ( T *  sparseTagArray,
std::size_t  length,
const Tag *  cellTag
) const [private]
Definition at line 68 of file ReadSparseTag.h.
References smoab::Interface::getDefaultTagVaue(), smoab::Interface::getMoabTag(), smoab::Interface::getTagData(), MeshSets, multiSetRead(), and singleSetRead().
Referenced by fill().
        typedef std::vector< int >::const_iterator IdConstIterator;
        typedef std::vector< int >::iterator IdIterator;
        typedef smoab::CellSets::const_iterator CellSetIterator;
        std::vector< int > sparseTagValues( this->MeshSets.size() );
        //first off iterate the entities and determine which ones
        //have moab material ids
        //todo get proper default value from moab
        //wrap this area with scope, to remove local variables
            const moab::Tag stag = this->Interface.getMoabTag( *sparseTag );
            IdIterator tagIds    = sparseTagValues.begin();
            for( CellSetIterator i = this->MeshSets.begin(); i != this->MeshSets.end(); ++i, ++tagIds )
                //getTagData clobbers defaultValue
                int defaultValue = this->Interface.getDefaultTagVaue< int >( stag );
                *tagIds          = this->Interface.getTagData( stag, i->entity(), defaultValue );
            //now determine ids for all entities that don't have materials
            IdConstIterator maxPos = std::max_element( sparseTagValues.begin(), sparseTagValues.end() );
            int maxValue           = *maxPos;
            for( IdIterator i = sparseTagValues.begin(); i != sparseTagValues.end(); ++i )
                if( *i == -1 )
                    *i = ++maxValue;
        if( this->MeshSets.size() == 1 )
            this->singleSetRead( sparseTagArray, sparseTagValues, length );
        else
            int defaultValue = this->Interface.getDefaultTagVaue< int >( *sparseTag );
            this->multiSetRead( sparseTagArray, sparseTagValues, length, defaultValue );
void smoab::detail::ReadSparseTag::multiSetRead ( T *  sparseTagArray,
const std::vector< int > &  values,
std::size_t  length,
int  defaultTagValue
) const [private]
Definition at line 127 of file ReadSparseTag.h.
References moab::Range::begin(), Cells, moab::Range::end(), fill(), MeshSets, smoab::RangeToVector(), and T.
Referenced by fillRawArray().
        typedef std::vector< smoab::EntityHandle >::const_iterator EntityHandleIterator;
        typedef smoab::Range::const_iterator RangeIterator;
        //create the search structure as a range is really slow to search with
        //lower_bounds
        std::vector< smoab::EntityHandle > searchableCells;
        smoab::RangeToVector( this->Cells, searchableCells );
        //pre fill with -1 to mark cells we don't touch, since some cells
        //might no have a default tag
        T defaultValue = T( defaultTagValue );
        std::fill( sparseTagArray, sparseTagArray + numCells, defaultValue );
        EntityHandleIterator s_begin = searchableCells.begin();
        EntityHandleIterator s_end   = searchableCells.end();
        IdConstIterator currentTagValue = sparseTagValues.begin();
        for( CellSetIterator i = this->MeshSets.begin(); i != this->MeshSets.end(); ++i, ++currentTagValue )
            T value = static_cast< T >( *currentTagValue );
            const smoab::Range& entitiesCells = i->cells();
            for( RangeIterator j = entitiesCells.begin(); j != entitiesCells.end(); ++j )
                EntityHandleIterator result = std::lower_bound( s_begin, s_end, *j );
                std::size_t newId           = std::distance( s_begin, result );
                sparseTagArray[newId]       = value;
void smoab::detail::ReadSparseTag::singleSetRead ( T *  sparseTagArray,
std::size_t  length
) const [private]
Definition at line 116 of file ReadSparseTag.h.
References fill(), and T.
        //now we set all the values as this has a single meshset so we
        //have no complicated logic for mapping each cell to a meshset
        T value = static_cast< T >( values[0] );
        std::fill( sparseTagArray, sparseTagArray + length, value );
Member Data Documentation
Definition at line 45 of file ReadSparseTag.h.
Referenced by fill(), and multiSetRead().
Definition at line 43 of file ReadSparseTag.h.
Definition at line 44 of file ReadSparseTag.h.
Referenced by fillRawArray(), and multiSetRead().
List of all members.
The documentation for this struct was generated from the following file:
