MOAB: Mesh Oriented datABase
(version 5.4.1)
#include <NCWriteMPAS.hpp>
Inheritance diagram for moab::NCWriteMPAS:
Collaboration diagram for moab::NCWriteMPAS:Public Member Functions | |
| NCWriteMPAS (WriteNC *writeNC, int fileId, const FileOptions &opts, EntityHandle fileSet) | |
| virtual | ~NCWriteMPAS () |
Private Member Functions | |
| virtual ErrorCode | collect_mesh_info () |
| Implementation of NCWriteHelper::collect_mesh_info() | |
| virtual ErrorCode | collect_variable_data (std::vector< std::string > &var_names, std::vector< int > &tstep_nums) |
| Collect data for specified variables. | |
| virtual ErrorCode | write_nonset_variables (std::vector< WriteNC::VarData > &vdatas, std::vector< int > &tstep_nums) |
| Implementation of NCWriteHelper::write_nonset_variables() | |
Definition at line 17 of file NCWriteMPAS.hpp.
| moab::NCWriteMPAS::NCWriteMPAS | ( | WriteNC * | writeNC, |
| int | fileId, | ||
| const FileOptions & | opts, | ||
| EntityHandle | fileSet | ||
| ) | [inline] |
Definition at line 20 of file NCWriteMPAS.hpp.
: UcdNCWriteHelper( writeNC, fileId, opts, fileSet ) { }
| moab::NCWriteMPAS::~NCWriteMPAS | ( | ) | [virtual] |
Definition at line 13 of file NCWriteMPAS.cpp.
// TODO Auto-generated destructor stub
| ErrorCode moab::NCWriteMPAS::collect_mesh_info | ( | ) | [private, virtual] |
Implements moab::NCWriteHelper.
Definition at line 18 of file NCWriteMPAS.cpp.
References moab::NCWriteHelper::_fileSet, moab::NCWriteHelper::_writeNC, moab::WriteNC::dimLens, moab::WriteNC::dimNames, moab::Range::empty(), ErrorCode, moab::ParallelComm::filter_pstatus(), moab::Interface::get_entities_by_dimension(), moab::WriteNC::isParallel, moab::NCWriteHelper::levDim, moab::NCWriteHelper::localCellsOwned, moab::NCWriteHelper::localEdgesOwned, moab::UcdNCWriteHelper::localGidCellsOwned, moab::UcdNCWriteHelper::localGidEdgesOwned, moab::UcdNCWriteHelper::localGidVertsOwned, moab::NCWriteHelper::localVertsOwned, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, moab::WriteNC::mbImpl, moab::WriteNC::mGlobalIdTag, moab::NCWriteHelper::nLevels, moab::NCWriteHelper::nTimeSteps, moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::ProcConfig::proc_size(), PSTATUS_NOT, PSTATUS_NOT_OWNED, rank, moab::Range::size(), moab::Interface::tag_get_data(), and moab::NCWriteHelper::tDim.
Interface*& mbImpl = _writeNC->mbImpl;
std::vector< std::string >& dimNames = _writeNC->dimNames;
std::vector< int >& dimLens = _writeNC->dimLens;
Tag& mGlobalIdTag = _writeNC->mGlobalIdTag;
ErrorCode rval;
// Look for time dimension
std::vector< std::string >::iterator vecIt;
if( ( vecIt = std::find( dimNames.begin(), dimNames.end(), "Time" ) ) != dimNames.end() )
tDim = vecIt - dimNames.begin();
else if( ( vecIt = std::find( dimNames.begin(), dimNames.end(), "time" ) ) != dimNames.end() )
else
MB_SET_ERR( MB_FAILURE, "Couldn't find 'Time' or 'time' dimension" );
nTimeSteps = dimLens[tDim];
// Get number of levels
if( ( vecIt = std::find( dimNames.begin(), dimNames.end(), "nVertLevels" ) ) != dimNames.end() )
levDim = vecIt - dimNames.begin();
else
MB_SET_ERR( MB_FAILURE, "Couldn't find 'nVertLevels' dimension" );
nLevels = dimLens[levDim];
// Get local vertices
rval = mbImpl->get_entities_by_dimension( _fileSet, 0, localVertsOwned );MB_CHK_SET_ERR( rval, "Trouble getting local vertices in current file set" );
assert( !localVertsOwned.empty() );
// Get local edges
rval = mbImpl->get_entities_by_dimension( _fileSet, 1, localEdgesOwned );MB_CHK_SET_ERR( rval, "Trouble getting local edges in current file set" );
// There are no edges if NO_EDGES read option is set
// Get local cells
rval = mbImpl->get_entities_by_dimension( _fileSet, 2, localCellsOwned );MB_CHK_SET_ERR( rval, "Trouble getting local cells in current file set" );
assert( !localCellsOwned.empty() );
#ifdef MOAB_HAVE_MPI
bool& isParallel = _writeNC->isParallel;
if( isParallel )
ParallelComm*& myPcomm = _writeNC->myPcomm;
int rank = myPcomm->proc_config().proc_rank();
int procs = myPcomm->proc_config().proc_size();
if( procs > 1 )
#ifndef NDEBUG
unsigned int num_local_verts = localVertsOwned.size();
#endif
rval = myPcomm->filter_pstatus( localVertsOwned, PSTATUS_NOT_OWNED, PSTATUS_NOT );MB_CHK_SET_ERR( rval, "Trouble getting owned vertices in current file set" );
// Assume that PARALLEL_RESOLVE_SHARED_ENTS option is set
// Verify that not all local vertices are owned by the last processor
if( procs - 1 == rank )
assert( "PARALLEL_RESOLVE_SHARED_ENTS option is set" && localVertsOwned.size() < num_local_verts );
if( !localEdgesOwned.empty() )
rval = myPcomm->filter_pstatus( localEdgesOwned, PSTATUS_NOT_OWNED, PSTATUS_NOT );MB_CHK_SET_ERR( rval, "Trouble getting owned edges in current file set" );
rval = myPcomm->filter_pstatus( localCellsOwned, PSTATUS_NOT_OWNED, PSTATUS_NOT );MB_CHK_SET_ERR( rval, "Trouble getting owned cells in current file set" );
#endif
std::vector< int > gids( localVertsOwned.size() );
rval = mbImpl->tag_get_data( mGlobalIdTag, localVertsOwned, &gids[0] );MB_CHK_SET_ERR( rval, "Trouble getting global IDs on local vertices" );
// Get localGidVertsOwned
std::copy( gids.rbegin(), gids.rend(), range_inserter( localGidVertsOwned ) );
gids.resize( localEdgesOwned.size() );
rval = mbImpl->tag_get_data( mGlobalIdTag, localEdgesOwned, &gids[0] );MB_CHK_SET_ERR( rval, "Trouble getting global IDs on local edges" );
// Get localGidEdgesOwned
std::copy( gids.rbegin(), gids.rend(), range_inserter( localGidEdgesOwned ) );
gids.resize( localCellsOwned.size() );
rval = mbImpl->tag_get_data( mGlobalIdTag, localCellsOwned, &gids[0] );MB_CHK_SET_ERR( rval, "Trouble getting global IDs on local cells" );
// Get localGidCellsOwned
std::copy( gids.rbegin(), gids.rend(), range_inserter( localGidCellsOwned ) );
return MB_SUCCESS;
| ErrorCode moab::NCWriteMPAS::collect_variable_data | ( | std::vector< std::string > & | var_names, |
| std::vector< int > & | tstep_nums | ||
Reimplemented from moab::NCWriteHelper.
Definition at line 113 of file NCWriteMPAS.cpp.
References moab::NCWriteHelper::_writeNC, moab::WriteNC::dimLens, moab::WriteNC::dimNames, moab::Range::empty(), moab::WriteNC::VarData::entLoc, moab::WriteNC::ENTLOCEDGE, moab::WriteNC::ENTLOCFACE, moab::WriteNC::ENTLOCSET, moab::WriteNC::ENTLOCVERT, moab::WriteNC::VarData::has_tsteps, moab::NCWriteHelper::levDim, moab::NCWriteHelper::localEdgesOwned, moab::UcdNCWriteHelper::localGidCellsOwned, moab::UcdNCWriteHelper::localGidEdgesOwned, moab::UcdNCWriteHelper::localGidVertsOwned, MB_SET_ERR, MB_SUCCESS, moab::WriteNC::VarData::numLev, moab::Range::size(), moab::WriteNC::VarData::sz, moab::NCWriteHelper::tDim, moab::WriteNC::VarData::varDims, moab::WriteNC::varInfo, moab::WriteNC::VarData::writeCounts, and moab::WriteNC::VarData::writeStarts.
NCWriteHelper::collect_variable_data( var_names, tstep_nums );
// Dimension indices for other optional levels
std::vector< unsigned int > opt_lev_dims;
unsigned int lev_idx;
// Get index of vertex levels P1
if( ( vecIt = std::find( dimNames.begin(), dimNames.end(), "nVertLevelsP1" ) ) != dimNames.end() )
lev_idx = vecIt - dimNames.begin();
opt_lev_dims.push_back( lev_idx );
// Get index of vertex levels P2
if( ( vecIt = std::find( dimNames.begin(), dimNames.end(), "nVertLevelsP2" ) ) != dimNames.end() )
// Get index of soil levels
if( ( vecIt = std::find( dimNames.begin(), dimNames.end(), "nSoilLevels" ) ) != dimNames.end() )
std::map< std::string, WriteNC::VarData >& varInfo = _writeNC->varInfo;
for( size_t i = 0; i < var_names.size(); i++ )
std::string varname = var_names[i];
std::map< std::string, WriteNC::VarData >::iterator vit = varInfo.find( varname );
if( vit == varInfo.end() ) MB_SET_ERR( MB_FAILURE, "Can't find variable " << varname );
WriteNC::VarData& currentVarData = vit->second;
std::vector< int >& varDims = currentVarData.varDims;
// Skip edge variables, if there are no edges
if( localEdgesOwned.empty() && currentVarData.entLoc == WriteNC::ENTLOCEDGE ) continue;
// If nVertLevels dimension is not found, try other optional levels such as nVertLevelsP1
if( std::find( varDims.begin(), varDims.end(), levDim ) == varDims.end() )
for( unsigned int j = 0; j < opt_lev_dims.size(); j++ )
if( std::find( varDims.begin(), varDims.end(), opt_lev_dims[j] ) != varDims.end() )
currentVarData.numLev = dimLens[opt_lev_dims[j]];
break;
// Skip set variables, which were already processed in
// NCWriteHelper::collect_variable_data()
if( WriteNC::ENTLOCSET == currentVarData.entLoc ) continue;
// Set up writeStarts and writeCounts (maximum number of dimensions is 3)
currentVarData.writeStarts.resize( 3 );
currentVarData.writeCounts.resize( 3 );
unsigned int dim_idx = 0;
// First: Time
if( currentVarData.has_tsteps )
// Non-set variables with timesteps
// 3 dimensions like (Time, nCells, nVertLevels)
// 2 dimensions like (Time, nCells)
assert( 3 == varDims.size() || 2 == varDims.size() );
// Time should be the first dimension
assert( tDim == varDims[0] );
currentVarData.writeStarts[dim_idx] = 0; // This value is timestep dependent, will be set later
currentVarData.writeCounts[dim_idx] = 1;
dim_idx++;
else
// Non-set variables without timesteps
// 2 dimensions like (nCells, nVertLevels)
// 1 dimension like (nCells)
assert( 2 == varDims.size() || 1 == varDims.size() );
// Next: nVertices / nCells / nEdges
switch( currentVarData.entLoc )
case WriteNC::ENTLOCVERT:
// Vertices
// Start from the first localGidVerts
// Actually, this will be reset later for writing
currentVarData.writeStarts[dim_idx] = localGidVertsOwned[0] - 1;
currentVarData.writeCounts[dim_idx] = localGidVertsOwned.size();
break;
case WriteNC::ENTLOCFACE:
// Faces
// Start from the first localGidCells
currentVarData.writeStarts[dim_idx] = localGidCellsOwned[0] - 1;
currentVarData.writeCounts[dim_idx] = localGidCellsOwned.size();
break;
case WriteNC::ENTLOCEDGE:
// Edges
// Start from the first localGidEdges
currentVarData.writeStarts[dim_idx] = localGidEdgesOwned[0] - 1;
currentVarData.writeCounts[dim_idx] = localGidEdgesOwned.size();
break;
default:
MB_SET_ERR( MB_FAILURE, "Unexpected entity location type for variable " << varname );
dim_idx++;
// Finally: nVertLevels or other optional levels, it is possible that there is no
// level dimension (numLev is 0) for this non-set variable, e.g. (Time, nCells)
if( currentVarData.numLev > 0 )
// Non-set variables with levels
currentVarData.writeCounts[dim_idx] = currentVarData.numLev;
dim_idx++;
else
// Non-set variables without levels
// Get variable size
currentVarData.sz = 1;
for( std::size_t idx = 0; idx < dim_idx; idx++ )
currentVarData.sz *= currentVarData.writeCounts[idx];
return MB_SUCCESS;
| ErrorCode moab::NCWriteMPAS::write_nonset_variables | ( | std::vector< WriteNC::VarData > & | vdatas, |
Definition at line 265 of file NCWriteMPAS.cpp.
References moab::NCWriteHelper::_fileId, moab::NCWriteHelper::_writeNC, moab::Range::empty(), moab::WriteNC::VarData::entLoc, moab::WriteNC::ENTLOCEDGE, moab::WriteNC::ENTLOCFACE, moab::WriteNC::ENTLOCVERT, ErrorCode, moab::WriteNC::VarData::has_tsteps, moab::NCWriteHelper::localCellsOwned, moab::NCWriteHelper::localEdgesOwned, moab::UcdNCWriteHelper::localGidCellsOwned, moab::UcdNCWriteHelper::localGidEdgesOwned, moab::UcdNCWriteHelper::localGidVertsOwned, moab::NCWriteHelper::localVertsOwned, MB_CHK_SET_ERR, MB_NOT_IMPLEMENTED, MB_SET_ERR, MB_SUCCESS, moab::WriteNC::mbImpl, NCDF_SIZE, NCFUNCAP, moab::WriteNC::VarData::numLev, moab::Range::pair_begin(), moab::Range::pair_end(), moab::Range::psize(), moab::Range::size(), t, moab::Interface::tag_get_data(), moab::NCWriteHelper::tDim, moab::WriteNC::VarData::varDataType, moab::WriteNC::VarData::varDims, moab::WriteNC::VarData::varId, moab::WriteNC::VarData::varName, moab::WriteNC::VarData::varTags, moab::WriteNC::VarData::writeCounts, and moab::WriteNC::VarData::writeStarts.
int success;
// For each variable tag in the indexed lists, write a time step data
for( unsigned int i = 0; i < vdatas.size(); i++ )
WriteNC::VarData& variableData = vdatas[i];
if( localEdgesOwned.empty() && variableData.entLoc == WriteNC::ENTLOCEDGE ) continue;
// Get local owned entities of this variable
Range* pLocalEntsOwned = NULL;
Range* pLocalGidEntsOwned = NULL;
switch( variableData.entLoc )
// Vertices
pLocalEntsOwned = &localVertsOwned;
pLocalGidEntsOwned = &localGidVertsOwned;
break;
// Edges
pLocalEntsOwned = &localEdgesOwned;
pLocalGidEntsOwned = &localGidEdgesOwned;
break;
// Cells
pLocalEntsOwned = &localCellsOwned;
pLocalGidEntsOwned = &localGidCellsOwned;
break;
default:
MB_SET_ERR( MB_FAILURE, "Unexpected entity location type for variable " << variableData.varName );
unsigned int num_timesteps;
unsigned int ents_idx = 0;
if( variableData.has_tsteps )
num_timesteps = tstep_nums.size();
ents_idx++;
else
num_timesteps = 1;
unsigned int num_lev;
if( variableData.numLev > 0 )
num_lev = variableData.numLev;
else
num_lev = 1;
for( unsigned int t = 0; t < num_timesteps; t++ )
// We will write one time step, and count will be one; start will be different
// Use tag_get_data instead of tag_iterate to copy tag data, as localEntsOwned
// might not be contiguous.
if( tDim == variableData.varDims[0] ) variableData.writeStarts[0] = t; // This is start for time
std::vector< double > tag_data( pLocalEntsOwned->size() * num_lev );
ErrorCode rval = mbImpl->tag_get_data( variableData.varTags[t], *pLocalEntsOwned, &tag_data[0] );MB_CHK_SET_ERR( rval, "Trouble getting tag data on owned entities" );
#ifdef MOAB_HAVE_PNETCDF
size_t nb_writes = pLocalGidEntsOwned->psize();
std::vector< int > requests( nb_writes ), statuss( nb_writes );
size_t idxReq = 0;
#endif
// Now write copied tag data
// Use nonblocking put (request aggregation)
switch( variableData.varDataType )
case NC_DOUBLE: {
size_t indexInDoubleArray = 0;
size_t ic = 0;
for( Range::pair_iterator pair_iter = pLocalGidEntsOwned->pair_begin();
pair_iter != pLocalGidEntsOwned->pair_end(); ++pair_iter, ic++ )
EntityHandle starth = pair_iter->first;
EntityHandle endh = pair_iter->second;
variableData.writeStarts[ents_idx] = (NCDF_SIZE)( starth - 1 );
variableData.writeCounts[ents_idx] = (NCDF_SIZE)( endh - starth + 1 );
// Do a partial write, in each subrange
// Wait outside this loop
success =
NCFUNCREQP( _vara_double )( _fileId, variableData.varId, &( variableData.writeStarts[0] ),
&( variableData.writeCounts[0] ),
&( tag_data[indexInDoubleArray] ), &requests[idxReq++] );
#else
success = NCFUNCAP(
&( variableData.writeCounts[0] ), &( tag_data[indexInDoubleArray] ) );
#endif
if( success )
"Failed to write double data in a loop for variable " << variableData.varName );
// We need to increment the index in double array for the
// next subrange
indexInDoubleArray += ( endh - starth + 1 ) * num_lev;
assert( ic == pLocalGidEntsOwned->psize() );
success = ncmpi_wait_all( _fileId, requests.size(), &requests[0], &statuss[0] );
if( success ) MB_SET_ERR( MB_FAILURE, "Failed on wait_all" );
#endif
break;
default:
MB_SET_ERR( MB_NOT_IMPLEMENTED, "Writing non-double data is not implemented yet" );
return MB_SUCCESS;
