MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* 00002 * NCWriteHelper.hpp 00003 * 00004 * Purpose : Climate NC writer file helper; abstract, will be implemented for each type 00005 * 00006 * Created on: Mar 28, 2014 00007 */ 00008 00009 #ifndef NCWRITEHELPER_HPP_ 00010 #define NCWRITEHELPER_HPP_ 00011 #include "WriteNC.hpp" 00012 00013 #ifdef WIN32 00014 #ifdef size_t 00015 #undef size_t 00016 #endif 00017 #endif 00018 00019 namespace moab 00020 { 00021 00022 class NCWriteHelper 00023 { 00024 public: 00025 NCWriteHelper( WriteNC* writeNC, int fileId, const FileOptions& opts, EntityHandle fileSet ) 00026 : _writeNC( writeNC ), _fileId( fileId ), _opts( opts ), _fileSet( fileSet ), nTimeSteps( 0 ), nLevels( 1 ), 00027 tDim( -1 ), levDim( -1 ) 00028 { 00029 } 00030 virtual ~NCWriteHelper(){}; 00031 00032 //! Get appropriate helper instance for WriteNC class based on some info in the file set 00033 static NCWriteHelper* get_nc_helper( WriteNC* writeNC, int fileId, const FileOptions& opts, EntityHandle fileSet ); 00034 00035 //! Collect necessary info about local mesh (implemented in child classes) 00036 virtual ErrorCode collect_mesh_info() = 0; 00037 00038 //! Collect data for specified variables (partially implemented in child classes) 00039 virtual ErrorCode collect_variable_data( std::vector< std::string >& var_names, std::vector< int >& tstep_nums ); 00040 00041 //! Initialize file: this is where all defines are done 00042 //! The VarData dimension ids are filled up after define 00043 ErrorCode init_file( std::vector< std::string >& var_names, 00044 std::vector< std::string >& desired_names, 00045 bool _append ); 00046 00047 //! Take the info from VarData and write first non-set variables, then set variables 00048 ErrorCode write_values( std::vector< std::string >& var_names, std::vector< int >& tstep_nums ); 00049 00050 private: 00051 // Write set variables (common to scd mesh and ucd mesh) 00052 ErrorCode write_set_variables( std::vector< WriteNC::VarData >& vsetdatas, std::vector< int >& tstep_nums ); 00053 00054 protected: 00055 // Write non-set variables (implemented in child classes) 00056 virtual ErrorCode write_nonset_variables( std::vector< WriteNC::VarData >& vdatas, 00057 std::vector< int >& tstep_nums ) = 0; 00058 00059 //! Allow NCWriteHelper to directly access members of WriteNC 00060 WriteNC* _writeNC; 00061 00062 //! Cache some information from WriteNC 00063 int _fileId; 00064 const FileOptions& _opts; 00065 EntityHandle _fileSet; 00066 00067 //! Dimensions of time and level 00068 int nTimeSteps, nLevels; 00069 00070 //! Dimension numbers for time and level 00071 int tDim, levDim; 00072 00073 //! Local owned cells, edges and vertices 00074 Range localCellsOwned, localEdgesOwned, localVertsOwned; 00075 00076 //! Time values of output timesteps 00077 std::vector< double > timeStepVals; 00078 }; 00079 00080 //! Child helper class for scd mesh, e.g. CAM_EL or CAM_FV 00081 class ScdNCWriteHelper : public NCWriteHelper 00082 { 00083 public: 00084 ScdNCWriteHelper( WriteNC* writeNC, int fileId, const FileOptions& opts, EntityHandle fileSet ) 00085 : NCWriteHelper( writeNC, fileId, opts, fileSet ) 00086 { 00087 for( unsigned int i = 0; i < 6; i++ ) 00088 { 00089 lDims[i] = -1; 00090 lCDims[i] = -1; 00091 } 00092 } 00093 virtual ~ScdNCWriteHelper() {} 00094 00095 private: 00096 //! Implementation of NCWriteHelper::collect_mesh_info() 00097 virtual ErrorCode collect_mesh_info(); 00098 00099 //! Collect data for specified variables 00100 virtual ErrorCode collect_variable_data( std::vector< std::string >& var_names, std::vector< int >& tstep_nums ); 00101 00102 //! Implementation of NCWriteHelper::write_nonset_variables() 00103 virtual ErrorCode write_nonset_variables( std::vector< WriteNC::VarData >& vdatas, std::vector< int >& tstep_nums ); 00104 00105 template < typename T > 00106 void jik_to_kji( size_t ni, size_t nj, size_t nk, T* dest, T* source ) 00107 { 00108 size_t nik = ni * nk, nij = ni * nj; 00109 for( std::size_t k = 0; k != nk; k++ ) 00110 for( std::size_t j = 0; j != nj; j++ ) 00111 for( std::size_t i = 0; i != ni; i++ ) 00112 dest[k * nij + j * ni + i] = source[j * nik + i * nk + k]; 00113 } 00114 00115 protected: 00116 //! Dimensions of my local part of grid 00117 int lDims[6]; 00118 00119 //! Center dimensions of my local part of grid 00120 int lCDims[6]; 00121 }; 00122 00123 //! Child helper class for ucd mesh, e.g. CAM_SE (HOMME) or MPAS 00124 class UcdNCWriteHelper : public NCWriteHelper 00125 { 00126 public: 00127 UcdNCWriteHelper( WriteNC* writeNC, int fileId, const FileOptions& opts, EntityHandle fileSet ) 00128 : NCWriteHelper( writeNC, fileId, opts, fileSet ), cDim( -1 ), eDim( -1 ), vDim( -1 ) 00129 { 00130 } 00131 virtual ~UcdNCWriteHelper() {} 00132 00133 protected: 00134 //! This version takes as input the moab range, from which we actually need just the 00135 //! size of each sequence, for a proper transpose of the data 00136 template < typename T > 00137 void jik_to_kji_stride( size_t, size_t nj, size_t nk, T* dest, T* source, Range& localGid ) 00138 { 00139 std::size_t idxInSource = 0; // Position of the start of the stride 00140 // For each subrange, we will transpose a matrix of size 00141 // subrange*nj*nk (subrange takes the role of ni) 00142 for( Range::pair_iterator pair_iter = localGid.pair_begin(); pair_iter != localGid.pair_end(); ++pair_iter ) 00143 { 00144 std::size_t size_range = pair_iter->second - pair_iter->first + 1; 00145 std::size_t nik = size_range * nk, nij = size_range * nj; 00146 for( std::size_t k = 0; k != nk; k++ ) 00147 for( std::size_t j = 0; j != nj; j++ ) 00148 for( std::size_t i = 0; i != size_range; i++ ) 00149 dest[idxInSource + k * nij + j * size_range + i] = source[idxInSource + j * nik + i * nk + k]; 00150 idxInSource += ( size_range * nj * nk ); 00151 } 00152 } 00153 00154 //! Dimension numbers for nCells, nEdges and nVertices 00155 int cDim, eDim, vDim; 00156 00157 //! Local global ID for owned cells, edges and vertices 00158 Range localGidCellsOwned, localGidEdgesOwned, localGidVertsOwned; 00159 }; 00160 00161 } // namespace moab 00162 00163 #endif
