moab::UcdNCWriteHelper Class Reference
Child helper class for ucd mesh, e.g. CAM_SE (HOMME) or MPAS. More...
#include <NCWriteHelper.hpp>
+ Inheritance diagram for moab::UcdNCWriteHelper:
+ Collaboration diagram for moab::UcdNCWriteHelper:
Public Member Functions
 UcdNCWriteHelper (WriteNC *writeNC, int fileId, const FileOptions &opts, EntityHandle fileSet)
virtual ~UcdNCWriteHelper ()
Protected Member Functions
template<typename T >
void jik_to_kji_stride (size_t, size_t nj, size_t nk, T *dest, T *source, Range &localGid)
Protected Attributes
int cDim
 Dimension numbers for nCells, nEdges and nVertices.
int eDim
int vDim
Range localGidCellsOwned
 Local global ID for owned cells, edges and vertices.
Range localGidEdgesOwned
Range localGidVertsOwned
Detailed Description
Definition at line 124 of file NCWriteHelper.hpp.
moab::UcdNCWriteHelper::UcdNCWriteHelper ( WriteNC *  writeNC,
int  fileId,
const FileOptions &  opts,
) [inline]
Definition at line 127 of file NCWriteHelper.hpp.
        : NCWriteHelper( writeNC, fileId, opts, fileSet ), cDim( -1 ), eDim( -1 ), vDim( -1 )
virtual moab::UcdNCWriteHelper::~UcdNCWriteHelper ( ) [inline, virtual]
Definition at line 131 of file NCWriteHelper.hpp.
Member Function Documentation
void moab::UcdNCWriteHelper::jik_to_kji_stride ( size_t  ,
size_t  nj,
size_t  nk,
T *  dest,
T *  source,
Range &  localGid
) [inline, protected]
This version takes as input the moab range, from which we actually need just the size of each sequence, for a proper transpose of the data
Definition at line 137 of file NCWriteHelper.hpp.
References moab::Range::pair_begin(), and moab::Range::pair_end().
Referenced by moab::NCWriteHOMME::write_nonset_variables().
        std::size_t idxInSource = 0;  // Position of the start of the stride
        // For each subrange, we will transpose a matrix of size
        // subrange*nj*nk (subrange takes the role of ni)
        for( Range::pair_iterator pair_iter = localGid.pair_begin(); pair_iter != localGid.pair_end(); ++pair_iter )
            std::size_t size_range = pair_iter->second - pair_iter->first + 1;
            std::size_t nik = size_range * nk, nij = size_range * nj;
            for( std::size_t k = 0; k != nk; k++ )
                for( std::size_t j = 0; j != nj; j++ )
                    for( std::size_t i = 0; i != size_range; i++ )
                        dest[idxInSource + k * nij + j * size_range + i] = source[idxInSource + j * nik + i * nk + k];
            idxInSource += ( size_range * nj * nk );
Member Data Documentation
Definition at line 155 of file NCWriteHelper.hpp.
List of all members.
