MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* 00002 * NCWriteHOMME.cpp 00003 * 00004 * Created on: April 9, 2014 00005 */ 00006 00007 #include "NCWriteHOMME.hpp" 00008 #include "MBTagConventions.hpp" 00009 00010 namespace moab 00011 { 00012 00013 NCWriteHOMME::~NCWriteHOMME() 00014 { 00015 // TODO Auto-generated destructor stub 00016 } 00017 00018 ErrorCode NCWriteHOMME::collect_mesh_info() 00019 { 00020 Interface*& mbImpl = _writeNC->mbImpl; 00021 std::vector< std::string >& dimNames = _writeNC->dimNames; 00022 std::vector< int >& dimLens = _writeNC->dimLens; 00023 Tag& mGlobalIdTag = _writeNC->mGlobalIdTag; 00024 00025 ErrorCode rval; 00026 00027 // Look for time dimension 00028 std::vector< std::string >::iterator vecIt; 00029 if( ( vecIt = std::find( dimNames.begin(), dimNames.end(), "time" ) ) != dimNames.end() ) 00030 tDim = vecIt - dimNames.begin(); 00031 else 00032 { 00033 MB_SET_ERR( MB_FAILURE, "Couldn't find 'time' dimension" ); 00034 } 00035 nTimeSteps = dimLens[tDim]; 00036 00037 // Get number of levels 00038 if( ( vecIt = std::find( dimNames.begin(), dimNames.end(), "lev" ) ) != dimNames.end() ) 00039 levDim = vecIt - dimNames.begin(); 00040 else 00041 { 00042 MB_SET_ERR( MB_FAILURE, "Couldn't find 'lev' dimension" ); 00043 } 00044 nLevels = dimLens[levDim]; 00045 00046 // Get local vertices 00047 rval = mbImpl->get_entities_by_dimension( _fileSet, 0, localVertsOwned );MB_CHK_SET_ERR( rval, "Trouble getting local vertices in current file set" ); 00048 assert( !localVertsOwned.empty() ); 00049 00050 #ifdef MOAB_HAVE_MPI 00051 bool& isParallel = _writeNC->isParallel; 00052 if( isParallel ) 00053 { 00054 ParallelComm*& myPcomm = _writeNC->myPcomm; 00055 int rank = myPcomm->proc_config().proc_rank(); 00056 int procs = myPcomm->proc_config().proc_size(); 00057 if( procs > 1 ) 00058 { 00059 #ifndef NDEBUG 00060 unsigned int num_local_verts = localVertsOwned.size(); 00061 #endif 00062 rval = myPcomm->filter_pstatus( localVertsOwned, PSTATUS_NOT_OWNED, PSTATUS_NOT );MB_CHK_SET_ERR( rval, "Trouble getting owned vertices in current set" ); 00063 00064 // Assume that PARALLEL_RESOLVE_SHARED_ENTS option is set 00065 // Verify that not all local vertices are owned by the last processor 00066 if( procs - 1 == rank ) 00067 assert( "PARALLEL_RESOLVE_SHARED_ENTS option is set" && localVertsOwned.size() < num_local_verts ); 00068 } 00069 } 00070 #endif 00071 00072 std::vector< int > gids( localVertsOwned.size() ); 00073 rval = mbImpl->tag_get_data( mGlobalIdTag, localVertsOwned, &gids[0] );MB_CHK_SET_ERR( rval, "Trouble getting global IDs on local vertices" ); 00074 00075 // Get localGidVertsOwned 00076 std::copy( gids.rbegin(), gids.rend(), range_inserter( localGidVertsOwned ) ); 00077 00078 return MB_SUCCESS; 00079 } 00080 00081 ErrorCode NCWriteHOMME::collect_variable_data( std::vector< std::string >& var_names, std::vector< int >& tstep_nums ) 00082 { 00083 NCWriteHelper::collect_variable_data( var_names, tstep_nums ); 00084 00085 std::map< std::string, WriteNC::VarData >& varInfo = _writeNC->varInfo; 00086 00087 for( size_t i = 0; i < var_names.size(); i++ ) 00088 { 00089 std::string varname = var_names[i]; 00090 std::map< std::string, WriteNC::VarData >::iterator vit = varInfo.find( varname ); 00091 if( vit == varInfo.end() ) MB_SET_ERR( MB_FAILURE, "Can't find variable " << varname ); 00092 ; 00093 00094 WriteNC::VarData& currentVarData = vit->second; 00095 #ifndef NDEBUG 00096 std::vector< int >& varDims = currentVarData.varDims; 00097 #endif 00098 00099 // Skip set variables, which were already processed in 00100 // NCWriteHelper::collect_variable_data() 00101 if( WriteNC::ENTLOCSET == currentVarData.entLoc ) continue; 00102 00103 // Set up writeStarts and writeCounts (maximum number of dimensions is 3) 00104 currentVarData.writeStarts.resize( 3 ); 00105 currentVarData.writeCounts.resize( 3 ); 00106 unsigned int dim_idx = 0; 00107 00108 // First: time 00109 if( currentVarData.has_tsteps ) 00110 { 00111 // Non-set variables with timesteps 00112 // 3 dimensions like (time, lev, ncol) 00113 // 2 dimensions like (time, ncol) 00114 assert( 3 == varDims.size() || 2 == varDims.size() ); 00115 00116 // Time should be the first dimension 00117 assert( tDim == varDims[0] ); 00118 00119 currentVarData.writeStarts[dim_idx] = 0; // This value is timestep dependent, will be set later 00120 currentVarData.writeCounts[dim_idx] = 1; 00121 dim_idx++; 00122 } 00123 else 00124 { 00125 // Non-set variables without timesteps 00126 // 2 dimensions like (lev, ncol) 00127 // 1 dimension like (ncol) 00128 assert( 2 == varDims.size() || 1 == varDims.size() ); 00129 } 00130 00131 // Next: lev 00132 if( currentVarData.numLev > 0 ) 00133 { 00134 // Non-set variables with levels 00135 // 3 dimensions like (time, lev, ncol) 00136 // 2 dimensions like (lev, ncol) 00137 assert( 3 == varDims.size() || 2 == varDims.size() ); 00138 00139 currentVarData.writeStarts[dim_idx] = 0; 00140 currentVarData.writeCounts[dim_idx] = currentVarData.numLev; 00141 dim_idx++; 00142 } 00143 else 00144 { 00145 // Non-set variables without levels 00146 // 2 dimensions like (time, ncol) 00147 // 1 dimension like (ncol) 00148 assert( 2 == varDims.size() || 1 == varDims.size() ); 00149 } 00150 00151 // Finally: ncol 00152 switch( currentVarData.entLoc ) 00153 { 00154 case WriteNC::ENTLOCVERT: 00155 // Vertices 00156 // Start from the first localGidVerts 00157 // Actually, this will be reset later for writing 00158 currentVarData.writeStarts[dim_idx] = localGidVertsOwned[0] - 1; 00159 currentVarData.writeCounts[dim_idx] = localGidVertsOwned.size(); 00160 break; 00161 default: 00162 MB_SET_ERR( MB_FAILURE, "Unexpected entity location type for variable " << varname ); 00163 } 00164 dim_idx++; 00165 00166 // Get variable size 00167 currentVarData.sz = 1; 00168 for( std::size_t idx = 0; idx < dim_idx; idx++ ) 00169 currentVarData.sz *= currentVarData.writeCounts[idx]; 00170 } 00171 00172 return MB_SUCCESS; 00173 } 00174 00175 ErrorCode NCWriteHOMME::write_nonset_variables( std::vector< WriteNC::VarData >& vdatas, 00176 std::vector< int >& tstep_nums ) 00177 { 00178 Interface*& mbImpl = _writeNC->mbImpl; 00179 00180 int success; 00181 int num_local_verts_owned = localVertsOwned.size(); 00182 00183 // For each indexed variable tag, write a time step data 00184 for( unsigned int i = 0; i < vdatas.size(); i++ ) 00185 { 00186 WriteNC::VarData& variableData = vdatas[i]; 00187 00188 // Assume this variable is on vertices for the time being 00189 switch( variableData.entLoc ) 00190 { 00191 case WriteNC::ENTLOCVERT: 00192 // Vertices 00193 break; 00194 default: 00195 MB_SET_ERR( MB_FAILURE, "Unexpected entity location type for variable " << variableData.varName ); 00196 } 00197 00198 unsigned int num_timesteps; 00199 unsigned int ncol_idx = 0; 00200 if( variableData.has_tsteps ) 00201 { 00202 // Non-set variables with timesteps 00203 // 3 dimensions like (time, lev, ncol) 00204 // 2 dimensions like (time, ncol) 00205 num_timesteps = tstep_nums.size(); 00206 ncol_idx++; 00207 } 00208 else 00209 { 00210 // Non-set variables without timesteps 00211 // 2 dimensions like (lev, ncol) 00212 // 1 dimension like (ncol) 00213 num_timesteps = 1; 00214 } 00215 00216 unsigned int num_lev; 00217 if( variableData.numLev > 0 ) 00218 { 00219 // Non-set variables with levels 00220 // 3 dimensions like (time, lev, ncol) 00221 // 2 dimensions like (lev, ncol) 00222 num_lev = variableData.numLev; 00223 ncol_idx++; 00224 } 00225 else 00226 { 00227 // Non-set variables without levels 00228 // 2 dimensions like (time, ncol) 00229 // 1 dimension like (ncol) 00230 num_lev = 1; 00231 } 00232 00233 // At each timestep, we need to transpose tag format (ncol, lev) back 00234 // to NC format (lev, ncol) for writing 00235 for( unsigned int t = 0; t < num_timesteps; t++ ) 00236 { 00237 // We will write one time step, and count will be one; start will be different 00238 // Use tag_get_data instead of tag_iterate to copy tag data, as localVertsOwned 00239 // might not be contiguous. We should also transpose for level so that means 00240 // deep copy for transpose 00241 if( tDim == variableData.varDims[0] ) variableData.writeStarts[0] = t; // This is start for time 00242 std::vector< double > tag_data( num_local_verts_owned * num_lev ); 00243 ErrorCode rval = mbImpl->tag_get_data( variableData.varTags[t], localVertsOwned, &tag_data[0] );MB_CHK_SET_ERR( rval, "Trouble getting tag data on owned vertices" ); 00244 00245 #ifdef MOAB_HAVE_PNETCDF 00246 size_t nb_writes = localGidVertsOwned.psize(); 00247 std::vector< int > requests( nb_writes ), statuss( nb_writes ); 00248 size_t idxReq = 0; 00249 #endif 00250 00251 // Now transpose and write copied tag data 00252 // Use nonblocking put (request aggregation) 00253 switch( variableData.varDataType ) 00254 { 00255 case NC_DOUBLE: { 00256 std::vector< double > tmpdoubledata( num_local_verts_owned * num_lev ); 00257 if( num_lev > 1 ) 00258 { 00259 // Transpose (ncol, lev) back to (lev, ncol) 00260 // Note, num_local_verts_owned is not used by jik_to_kji_stride() 00261 jik_to_kji_stride( num_local_verts_owned, 1, num_lev, &tmpdoubledata[0], &tag_data[0], 00262 localGidVertsOwned ); 00263 } 00264 00265 size_t indexInDoubleArray = 0; 00266 size_t ic = 0; 00267 for( Range::pair_iterator pair_iter = localGidVertsOwned.pair_begin(); 00268 pair_iter != localGidVertsOwned.pair_end(); ++pair_iter, ic++ ) 00269 { 00270 EntityHandle starth = pair_iter->first; 00271 EntityHandle endh = pair_iter->second; 00272 variableData.writeStarts[ncol_idx] = (NCDF_SIZE)( starth - 1 ); 00273 variableData.writeCounts[ncol_idx] = (NCDF_SIZE)( endh - starth + 1 ); 00274 00275 // Do a partial write, in each subrange 00276 #ifdef MOAB_HAVE_PNETCDF 00277 // Wait outside this loop 00278 success = 00279 NCFUNCREQP( _vara_double )( _fileId, variableData.varId, &( variableData.writeStarts[0] ), 00280 &( variableData.writeCounts[0] ), 00281 &( tmpdoubledata[indexInDoubleArray] ), &requests[idxReq++] ); 00282 #else 00283 success = NCFUNCAP( 00284 _vara_double )( _fileId, variableData.varId, &( variableData.writeStarts[0] ), 00285 &( variableData.writeCounts[0] ), &( tmpdoubledata[indexInDoubleArray] ) ); 00286 #endif 00287 if( success ) 00288 MB_SET_ERR( MB_FAILURE, 00289 "Failed to write double data in a loop for variable " << variableData.varName ); 00290 // We need to increment the index in double array for the 00291 // next subrange 00292 indexInDoubleArray += ( endh - starth + 1 ) * num_lev; 00293 } 00294 assert( ic == localGidVertsOwned.psize() ); 00295 #ifdef MOAB_HAVE_PNETCDF 00296 success = ncmpi_wait_all( _fileId, requests.size(), &requests[0], &statuss[0] ); 00297 if( success ) MB_SET_ERR( MB_FAILURE, "Failed on wait_all" ); 00298 #endif 00299 break; 00300 } 00301 default: 00302 MB_SET_ERR( MB_NOT_IMPLEMENTED, "Writing non-double data is not implemented yet" ); 00303 } 00304 } 00305 } 00306 00307 return MB_SUCCESS; 00308 } 00309 00310 } /* namespace moab */
