MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* 00002 * NCWriteMPAS.cpp 00003 * 00004 * Created on: April 9, 2014 00005 */ 00006 00007 #include "NCWriteMPAS.hpp" 00008 #include "MBTagConventions.hpp" 00009 00010 namespace moab 00011 { 00012 00013 NCWriteMPAS::~NCWriteMPAS() 00014 { 00015 // TODO Auto-generated destructor stub 00016 } 00017 00018 ErrorCode NCWriteMPAS::collect_mesh_info() 00019 { 00020 Interface*& mbImpl = _writeNC->mbImpl; 00021 std::vector< std::string >& dimNames = _writeNC->dimNames; 00022 std::vector< int >& dimLens = _writeNC->dimLens; 00023 Tag& mGlobalIdTag = _writeNC->mGlobalIdTag; 00024 00025 ErrorCode rval; 00026 00027 // Look for time dimension 00028 std::vector< std::string >::iterator vecIt; 00029 if( ( vecIt = std::find( dimNames.begin(), dimNames.end(), "Time" ) ) != dimNames.end() ) 00030 tDim = vecIt - dimNames.begin(); 00031 else if( ( vecIt = std::find( dimNames.begin(), dimNames.end(), "time" ) ) != dimNames.end() ) 00032 tDim = vecIt - dimNames.begin(); 00033 else 00034 { 00035 MB_SET_ERR( MB_FAILURE, "Couldn't find 'Time' or 'time' dimension" ); 00036 } 00037 nTimeSteps = dimLens[tDim]; 00038 00039 // Get number of levels 00040 if( ( vecIt = std::find( dimNames.begin(), dimNames.end(), "nVertLevels" ) ) != dimNames.end() ) 00041 levDim = vecIt - dimNames.begin(); 00042 else 00043 { 00044 MB_SET_ERR( MB_FAILURE, "Couldn't find 'nVertLevels' dimension" ); 00045 } 00046 nLevels = dimLens[levDim]; 00047 00048 // Get local vertices 00049 rval = mbImpl->get_entities_by_dimension( _fileSet, 0, localVertsOwned );MB_CHK_SET_ERR( rval, "Trouble getting local vertices in current file set" ); 00050 assert( !localVertsOwned.empty() ); 00051 00052 // Get local edges 00053 rval = mbImpl->get_entities_by_dimension( _fileSet, 1, localEdgesOwned );MB_CHK_SET_ERR( rval, "Trouble getting local edges in current file set" ); 00054 // There are no edges if NO_EDGES read option is set 00055 00056 // Get local cells 00057 rval = mbImpl->get_entities_by_dimension( _fileSet, 2, localCellsOwned );MB_CHK_SET_ERR( rval, "Trouble getting local cells in current file set" ); 00058 assert( !localCellsOwned.empty() ); 00059 00060 #ifdef MOAB_HAVE_MPI 00061 bool& isParallel = _writeNC->isParallel; 00062 if( isParallel ) 00063 { 00064 ParallelComm*& myPcomm = _writeNC->myPcomm; 00065 int rank = myPcomm->proc_config().proc_rank(); 00066 int procs = myPcomm->proc_config().proc_size(); 00067 if( procs > 1 ) 00068 { 00069 #ifndef NDEBUG 00070 unsigned int num_local_verts = localVertsOwned.size(); 00071 #endif 00072 rval = myPcomm->filter_pstatus( localVertsOwned, PSTATUS_NOT_OWNED, PSTATUS_NOT );MB_CHK_SET_ERR( rval, "Trouble getting owned vertices in current file set" ); 00073 00074 // Assume that PARALLEL_RESOLVE_SHARED_ENTS option is set 00075 // Verify that not all local vertices are owned by the last processor 00076 if( procs - 1 == rank ) 00077 assert( "PARALLEL_RESOLVE_SHARED_ENTS option is set" && localVertsOwned.size() < num_local_verts ); 00078 00079 if( !localEdgesOwned.empty() ) 00080 { 00081 rval = myPcomm->filter_pstatus( localEdgesOwned, PSTATUS_NOT_OWNED, PSTATUS_NOT );MB_CHK_SET_ERR( rval, "Trouble getting owned edges in current file set" ); 00082 } 00083 00084 rval = myPcomm->filter_pstatus( localCellsOwned, PSTATUS_NOT_OWNED, PSTATUS_NOT );MB_CHK_SET_ERR( rval, "Trouble getting owned cells in current file set" ); 00085 } 00086 } 00087 #endif 00088 00089 std::vector< int > gids( localVertsOwned.size() ); 00090 rval = mbImpl->tag_get_data( mGlobalIdTag, localVertsOwned, &gids[0] );MB_CHK_SET_ERR( rval, "Trouble getting global IDs on local vertices" ); 00091 00092 // Get localGidVertsOwned 00093 std::copy( gids.rbegin(), gids.rend(), range_inserter( localGidVertsOwned ) ); 00094 00095 if( !localEdgesOwned.empty() ) 00096 { 00097 gids.resize( localEdgesOwned.size() ); 00098 rval = mbImpl->tag_get_data( mGlobalIdTag, localEdgesOwned, &gids[0] );MB_CHK_SET_ERR( rval, "Trouble getting global IDs on local edges" ); 00099 00100 // Get localGidEdgesOwned 00101 std::copy( gids.rbegin(), gids.rend(), range_inserter( localGidEdgesOwned ) ); 00102 } 00103 00104 gids.resize( localCellsOwned.size() ); 00105 rval = mbImpl->tag_get_data( mGlobalIdTag, localCellsOwned, &gids[0] );MB_CHK_SET_ERR( rval, "Trouble getting global IDs on local cells" ); 00106 00107 // Get localGidCellsOwned 00108 std::copy( gids.rbegin(), gids.rend(), range_inserter( localGidCellsOwned ) ); 00109 00110 return MB_SUCCESS; 00111 } 00112 00113 ErrorCode NCWriteMPAS::collect_variable_data( std::vector< std::string >& var_names, std::vector< int >& tstep_nums ) 00114 { 00115 NCWriteHelper::collect_variable_data( var_names, tstep_nums ); 00116 00117 std::vector< std::string >& dimNames = _writeNC->dimNames; 00118 std::vector< int >& dimLens = _writeNC->dimLens; 00119 00120 // Dimension indices for other optional levels 00121 std::vector< unsigned int > opt_lev_dims; 00122 00123 unsigned int lev_idx; 00124 std::vector< std::string >::iterator vecIt; 00125 00126 // Get index of vertex levels P1 00127 if( ( vecIt = std::find( dimNames.begin(), dimNames.end(), "nVertLevelsP1" ) ) != dimNames.end() ) 00128 { 00129 lev_idx = vecIt - dimNames.begin(); 00130 opt_lev_dims.push_back( lev_idx ); 00131 } 00132 00133 // Get index of vertex levels P2 00134 if( ( vecIt = std::find( dimNames.begin(), dimNames.end(), "nVertLevelsP2" ) ) != dimNames.end() ) 00135 { 00136 lev_idx = vecIt - dimNames.begin(); 00137 opt_lev_dims.push_back( lev_idx ); 00138 } 00139 00140 // Get index of soil levels 00141 if( ( vecIt = std::find( dimNames.begin(), dimNames.end(), "nSoilLevels" ) ) != dimNames.end() ) 00142 { 00143 lev_idx = vecIt - dimNames.begin(); 00144 opt_lev_dims.push_back( lev_idx ); 00145 } 00146 00147 std::map< std::string, WriteNC::VarData >& varInfo = _writeNC->varInfo; 00148 00149 for( size_t i = 0; i < var_names.size(); i++ ) 00150 { 00151 std::string varname = var_names[i]; 00152 std::map< std::string, WriteNC::VarData >::iterator vit = varInfo.find( varname ); 00153 if( vit == varInfo.end() ) MB_SET_ERR( MB_FAILURE, "Can't find variable " << varname ); 00154 00155 WriteNC::VarData& currentVarData = vit->second; 00156 std::vector< int >& varDims = currentVarData.varDims; 00157 00158 // Skip edge variables, if there are no edges 00159 if( localEdgesOwned.empty() && currentVarData.entLoc == WriteNC::ENTLOCEDGE ) continue; 00160 00161 // If nVertLevels dimension is not found, try other optional levels such as nVertLevelsP1 00162 if( std::find( varDims.begin(), varDims.end(), levDim ) == varDims.end() ) 00163 { 00164 for( unsigned int j = 0; j < opt_lev_dims.size(); j++ ) 00165 { 00166 if( std::find( varDims.begin(), varDims.end(), opt_lev_dims[j] ) != varDims.end() ) 00167 { 00168 currentVarData.numLev = dimLens[opt_lev_dims[j]]; 00169 break; 00170 } 00171 } 00172 } 00173 00174 // Skip set variables, which were already processed in 00175 // NCWriteHelper::collect_variable_data() 00176 if( WriteNC::ENTLOCSET == currentVarData.entLoc ) continue; 00177 00178 // Set up writeStarts and writeCounts (maximum number of dimensions is 3) 00179 currentVarData.writeStarts.resize( 3 ); 00180 currentVarData.writeCounts.resize( 3 ); 00181 unsigned int dim_idx = 0; 00182 00183 // First: Time 00184 if( currentVarData.has_tsteps ) 00185 { 00186 // Non-set variables with timesteps 00187 // 3 dimensions like (Time, nCells, nVertLevels) 00188 // 2 dimensions like (Time, nCells) 00189 assert( 3 == varDims.size() || 2 == varDims.size() ); 00190 00191 // Time should be the first dimension 00192 assert( tDim == varDims[0] ); 00193 00194 currentVarData.writeStarts[dim_idx] = 0; // This value is timestep dependent, will be set later 00195 currentVarData.writeCounts[dim_idx] = 1; 00196 dim_idx++; 00197 } 00198 else 00199 { 00200 // Non-set variables without timesteps 00201 // 2 dimensions like (nCells, nVertLevels) 00202 // 1 dimension like (nCells) 00203 assert( 2 == varDims.size() || 1 == varDims.size() ); 00204 } 00205 00206 // Next: nVertices / nCells / nEdges 00207 switch( currentVarData.entLoc ) 00208 { 00209 case WriteNC::ENTLOCVERT: 00210 // Vertices 00211 // Start from the first localGidVerts 00212 // Actually, this will be reset later for writing 00213 currentVarData.writeStarts[dim_idx] = localGidVertsOwned[0] - 1; 00214 currentVarData.writeCounts[dim_idx] = localGidVertsOwned.size(); 00215 break; 00216 case WriteNC::ENTLOCFACE: 00217 // Faces 00218 // Start from the first localGidCells 00219 // Actually, this will be reset later for writing 00220 currentVarData.writeStarts[dim_idx] = localGidCellsOwned[0] - 1; 00221 currentVarData.writeCounts[dim_idx] = localGidCellsOwned.size(); 00222 break; 00223 case WriteNC::ENTLOCEDGE: 00224 // Edges 00225 // Start from the first localGidEdges 00226 // Actually, this will be reset later for writing 00227 currentVarData.writeStarts[dim_idx] = localGidEdgesOwned[0] - 1; 00228 currentVarData.writeCounts[dim_idx] = localGidEdgesOwned.size(); 00229 break; 00230 default: 00231 MB_SET_ERR( MB_FAILURE, "Unexpected entity location type for variable " << varname ); 00232 } 00233 dim_idx++; 00234 00235 // Finally: nVertLevels or other optional levels, it is possible that there is no 00236 // level dimension (numLev is 0) for this non-set variable, e.g. (Time, nCells) 00237 if( currentVarData.numLev > 0 ) 00238 { 00239 // Non-set variables with levels 00240 // 3 dimensions like (Time, nCells, nVertLevels) 00241 // 2 dimensions like (nCells, nVertLevels) 00242 assert( 3 == varDims.size() || 2 == varDims.size() ); 00243 00244 currentVarData.writeStarts[dim_idx] = 0; 00245 currentVarData.writeCounts[dim_idx] = currentVarData.numLev; 00246 dim_idx++; 00247 } 00248 else 00249 { 00250 // Non-set variables without levels 00251 // 2 dimensions like (Time, nCells) 00252 // 1 dimension like (nCells) 00253 assert( 2 == varDims.size() || 1 == varDims.size() ); 00254 } 00255 00256 // Get variable size 00257 currentVarData.sz = 1; 00258 for( std::size_t idx = 0; idx < dim_idx; idx++ ) 00259 currentVarData.sz *= currentVarData.writeCounts[idx]; 00260 } 00261 00262 return MB_SUCCESS; 00263 } 00264 00265 ErrorCode NCWriteMPAS::write_nonset_variables( std::vector< WriteNC::VarData >& vdatas, std::vector< int >& tstep_nums ) 00266 { 00267 Interface*& mbImpl = _writeNC->mbImpl; 00268 00269 int success; 00270 00271 // For each variable tag in the indexed lists, write a time step data 00272 for( unsigned int i = 0; i < vdatas.size(); i++ ) 00273 { 00274 WriteNC::VarData& variableData = vdatas[i]; 00275 00276 // Skip edge variables, if there are no edges 00277 if( localEdgesOwned.empty() && variableData.entLoc == WriteNC::ENTLOCEDGE ) continue; 00278 00279 // Get local owned entities of this variable 00280 Range* pLocalEntsOwned = NULL; 00281 Range* pLocalGidEntsOwned = NULL; 00282 switch( variableData.entLoc ) 00283 { 00284 case WriteNC::ENTLOCVERT: 00285 // Vertices 00286 pLocalEntsOwned = &localVertsOwned; 00287 pLocalGidEntsOwned = &localGidVertsOwned; 00288 break; 00289 case WriteNC::ENTLOCEDGE: 00290 // Edges 00291 pLocalEntsOwned = &localEdgesOwned; 00292 pLocalGidEntsOwned = &localGidEdgesOwned; 00293 break; 00294 case WriteNC::ENTLOCFACE: 00295 // Cells 00296 pLocalEntsOwned = &localCellsOwned; 00297 pLocalGidEntsOwned = &localGidCellsOwned; 00298 break; 00299 default: 00300 MB_SET_ERR( MB_FAILURE, "Unexpected entity location type for variable " << variableData.varName ); 00301 } 00302 00303 unsigned int num_timesteps; 00304 unsigned int ents_idx = 0; 00305 if( variableData.has_tsteps ) 00306 { 00307 // Non-set variables with timesteps 00308 // 3 dimensions like (Time, nCells, nVertLevels) 00309 // 2 dimensions like (Time, nCells) 00310 num_timesteps = tstep_nums.size(); 00311 ents_idx++; 00312 } 00313 else 00314 { 00315 // Non-set variables without timesteps 00316 // 2 dimensions like (nCells, nVertLevels) 00317 // 1 dimension like (nCells) 00318 num_timesteps = 1; 00319 } 00320 00321 unsigned int num_lev; 00322 if( variableData.numLev > 0 ) 00323 { 00324 // Non-set variables with levels 00325 // 3 dimensions like (Time, nCells, nVertLevels) 00326 // 2 dimensions like (nCells, nVertLevels) 00327 num_lev = variableData.numLev; 00328 } 00329 else 00330 { 00331 // Non-set variables without levels 00332 // 2 dimensions like (Time, nCells) 00333 // 1 dimension like (nCells) 00334 num_lev = 1; 00335 } 00336 00337 for( unsigned int t = 0; t < num_timesteps; t++ ) 00338 { 00339 // We will write one time step, and count will be one; start will be different 00340 // Use tag_get_data instead of tag_iterate to copy tag data, as localEntsOwned 00341 // might not be contiguous. 00342 if( tDim == variableData.varDims[0] ) variableData.writeStarts[0] = t; // This is start for time 00343 std::vector< double > tag_data( pLocalEntsOwned->size() * num_lev ); 00344 ErrorCode rval = mbImpl->tag_get_data( variableData.varTags[t], *pLocalEntsOwned, &tag_data[0] );MB_CHK_SET_ERR( rval, "Trouble getting tag data on owned entities" ); 00345 00346 #ifdef MOAB_HAVE_PNETCDF 00347 size_t nb_writes = pLocalGidEntsOwned->psize(); 00348 std::vector< int > requests( nb_writes ), statuss( nb_writes ); 00349 size_t idxReq = 0; 00350 #endif 00351 00352 // Now write copied tag data 00353 // Use nonblocking put (request aggregation) 00354 switch( variableData.varDataType ) 00355 { 00356 case NC_DOUBLE: { 00357 size_t indexInDoubleArray = 0; 00358 size_t ic = 0; 00359 for( Range::pair_iterator pair_iter = pLocalGidEntsOwned->pair_begin(); 00360 pair_iter != pLocalGidEntsOwned->pair_end(); ++pair_iter, ic++ ) 00361 { 00362 EntityHandle starth = pair_iter->first; 00363 EntityHandle endh = pair_iter->second; 00364 variableData.writeStarts[ents_idx] = (NCDF_SIZE)( starth - 1 ); 00365 variableData.writeCounts[ents_idx] = (NCDF_SIZE)( endh - starth + 1 ); 00366 00367 // Do a partial write, in each subrange 00368 #ifdef MOAB_HAVE_PNETCDF 00369 // Wait outside this loop 00370 success = 00371 NCFUNCREQP( _vara_double )( _fileId, variableData.varId, &( variableData.writeStarts[0] ), 00372 &( variableData.writeCounts[0] ), 00373 &( tag_data[indexInDoubleArray] ), &requests[idxReq++] ); 00374 #else 00375 success = NCFUNCAP( 00376 _vara_double )( _fileId, variableData.varId, &( variableData.writeStarts[0] ), 00377 &( variableData.writeCounts[0] ), &( tag_data[indexInDoubleArray] ) ); 00378 #endif 00379 if( success ) 00380 MB_SET_ERR( MB_FAILURE, 00381 "Failed to write double data in a loop for variable " << variableData.varName ); 00382 // We need to increment the index in double array for the 00383 // next subrange 00384 indexInDoubleArray += ( endh - starth + 1 ) * num_lev; 00385 } 00386 assert( ic == pLocalGidEntsOwned->psize() ); 00387 #ifdef MOAB_HAVE_PNETCDF 00388 success = ncmpi_wait_all( _fileId, requests.size(), &requests[0], &statuss[0] ); 00389 if( success ) MB_SET_ERR( MB_FAILURE, "Failed on wait_all" ); 00390 #endif 00391 break; 00392 } 00393 default: 00394 MB_SET_ERR( MB_NOT_IMPLEMENTED, "Writing non-double data is not implemented yet" ); 00395 } 00396 } 00397 } 00398 00399 return MB_SUCCESS; 00400 } 00401 00402 } /* namespace moab */
