MOAB: Mesh Oriented datABase
(version 5.4.1)
Helper class to isolate reading of several different nc file formats. More...
#include <NCHelper.hpp>
Inheritance diagram for moab::NCHelper:
Collaboration diagram for moab::NCHelper:Classes | |
| class | Node3D |
Public Member Functions | |
| NCHelper (ReadNC *readNC, int fileId, const FileOptions &opts, EntityHandle fileSet) | |
| virtual | ~NCHelper () |
| virtual ErrorCode | init_mesh_vals ()=0 |
| Interfaces to be implemented in child classes. | |
| virtual ErrorCode | check_existing_mesh ()=0 |
| virtual ErrorCode | create_mesh (Range &faces)=0 |
| virtual ErrorCode | read_variables (std::vector< std::string > &var_names, std::vector< int > &tstep_nums)=0 |
| virtual std::string | get_mesh_type_name ()=0 |
| ErrorCode | create_conventional_tags (const std::vector< int > &tstep_nums) |
| Create NC conventional tags. | |
| ErrorCode | update_time_tag_vals () |
| Update time tag values if timesteps spread across files. | |
Static Public Member Functions | |
| static NCHelper * | get_nc_helper (ReadNC *readNC, int fileId, const FileOptions &opts, EntityHandle fileSet) |
| Get appropriate helper instance for ReadNC class. | |
Protected Member Functions | |
| ErrorCode | read_variables_setup (std::vector< std::string > &var_names, std::vector< int > &tstep_nums, std::vector< ReadNC::VarData > &vdatas, std::vector< ReadNC::VarData > &vsetdatas) |
| Separate set and non-set variables (common to scd mesh and ucd mesh) | |
| ErrorCode | read_variables_to_set (std::vector< ReadNC::VarData > &vdatas, std::vector< int > &tstep_nums) |
| Read set variables (common to scd mesh and ucd mesh) | |
| ErrorCode | read_coordinate (const char *var_name, int lmin, int lmax, std::vector< double > &cvals) |
| ErrorCode | get_tag_to_set (ReadNC::VarData &var_data, int tstep_num, Tag &tagh) |
| ErrorCode | get_tag_to_nonset (ReadNC::VarData &var_data, int tstep_num, Tag &tagh, int num_lev) |
| ErrorCode | create_attrib_string (const std::map< std::string, ReadNC::AttData > &attMap, std::string &attString, std::vector< int > &attLen) |
| ErrorCode | create_dummy_variables () |
Protected Attributes | |
| ReadNC * | _readNC |
| Allow NCHelper to directly access members of ReadNC. | |
| int | _fileId |
| Cache some information from ReadNC. | |
| const FileOptions & | _opts |
| EntityHandle | _fileSet |
| int | nTimeSteps |
| Dimensions of time and level. | |
| int | nLevels |
| std::vector< double > | tVals |
| Values for time and level. | |
| std::vector< double > | levVals |
| int | tDim |
| Dimension numbers for time and level. | |
| int | levDim |
| std::set< std::string > | ignoredVarNames |
| Ignored variables. | |
| std::set< std::string > | dummyVarNames |
| Dummy variables. | |
Private Member Functions | |
| ErrorCode | read_variables_to_set_allocate (std::vector< ReadNC::VarData > &vdatas, std::vector< int > &tstep_nums) |
| Used by read_variables_to_set() | |
Definition at line 24 of file NCHelper.hpp.
| moab::NCHelper::NCHelper | ( | ReadNC * | readNC, |
| int | fileId, | ||
| const FileOptions & | opts, | ||
| EntityHandle | fileSet | ||
| ) | [inline] |
Definition at line 27 of file NCHelper.hpp.
| virtual moab::NCHelper::~NCHelper | ( | ) | [inline, virtual] |
Definition at line 32 of file NCHelper.hpp.
| virtual ErrorCode moab::NCHelper::check_existing_mesh | ( | ) | [pure virtual] |
Implemented in moab::ScdNCHelper, moab::NCHelperGCRM, moab::NCHelperMPAS, and moab::NCHelperHOMME.
Referenced by moab::ReadNC::load_file().
| ErrorCode moab::NCHelper::create_attrib_string | ( | const std::map< std::string, ReadNC::AttData > & | attMap, |
| std::string & | attString, | ||
| std::vector< int > & | attLen | ||
| ) | [protected] |
Create a character string attString of attMap. with '\0' terminating each attribute name, ';' separating the data type and value, and ';' separating one name/data type/value from the next'. attLen stores the end position for each name/data type/ value.
Definition at line 676 of file NCHelper.cpp.
References _fileId, MB_SET_ERR, MB_SUCCESS, and NCFUNC.
Referenced by create_conventional_tags().
int success;
std::stringstream ssAtt;
unsigned int sz = 0;
std::map< std::string, ReadNC::AttData >::const_iterator attIt = attMap.begin();
for( ; attIt != attMap.end(); ++attIt )
ssAtt << attIt->second.attName;
ssAtt << '\0';
void* attData = NULL;
switch( attIt->second.attDataType )
case NC_BYTE:
case NC_CHAR:
sz = attIt->second.attLen;
attData = (char*)malloc( sz );
success = NCFUNC( get_att_text )( _fileId, attIt->second.attVarId, attIt->second.attName.c_str(),
(char*)attData );
if( success )
MB_SET_ERR( MB_FAILURE, "Failed to read byte/char data for attribute " << attIt->second.attName );
ssAtt << "char;";
break;
case NC_SHORT:
sz = attIt->second.attLen * sizeof( short );
attData = (short*)malloc( sz );
success = NCFUNC( get_att_short )( _fileId, attIt->second.attVarId, attIt->second.attName.c_str(),
(short*)attData );
if( success )
MB_SET_ERR( MB_FAILURE, "Failed to read short data for attribute " << attIt->second.attName );
ssAtt << "short;";
break;
case NC_INT:
sz = attIt->second.attLen * sizeof( int );
attData = (int*)malloc( sz );
success = NCFUNC( get_att_int )( _fileId, attIt->second.attVarId, attIt->second.attName.c_str(),
(int*)attData );
if( success )
MB_SET_ERR( MB_FAILURE, "Failed to read int data for attribute " << attIt->second.attName );
ssAtt << "int;";
break;
case NC_FLOAT:
sz = attIt->second.attLen * sizeof( float );
attData = (float*)malloc( sz );
success = NCFUNC( get_att_float )( _fileId, attIt->second.attVarId, attIt->second.attName.c_str(),
(float*)attData );
if( success )
MB_SET_ERR( MB_FAILURE, "Failed to read float data for attribute " << attIt->second.attName );
ssAtt << "float;";
break;
case NC_DOUBLE:
sz = attIt->second.attLen * sizeof( double );
attData = (double*)malloc( sz );
success = NCFUNC( get_att_double )( _fileId, attIt->second.attVarId, attIt->second.attName.c_str(),
(double*)attData );
if( success )
MB_SET_ERR( MB_FAILURE, "Failed to read double data for attribute " << attIt->second.attName );
ssAtt << "double;";
break;
default:
MB_SET_ERR( MB_FAILURE, "Unexpected data type for attribute " << attIt->second.attName );
char* tmpc = (char*)attData;
for( unsigned int counter = 0; counter != sz; ++counter )
ssAtt << tmpc[counter];
free( attData );
ssAtt << ';';
attLen.push_back( ssAtt.str().size() - 1 );
attVal = ssAtt.str();
return MB_SUCCESS;
| ErrorCode moab::NCHelper::create_conventional_tags | ( | const std::vector< int > & | tstep_nums | ) |
Definition at line 73 of file NCHelper.cpp.
References _fileSet, _readNC, create_attrib_string(), moab::ReadNC::dbgOut, moab::ReadNC::dimLens, moab::ReadNC::dimNames, dummyVarNames, ErrorCode, get_mesh_type_name(), moab::ReadNC::globalAtts, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MB_TAG_ANY, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TAG_VARLEN, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, moab::ReadNC::mbImpl, nTimeSteps, moab::ScdInterface::part_method_tag(), moab::ReadNC::partMethod, moab::ReadNC::scdi, moab::Interface::tag_get_handle(), moab::Interface::tag_set_by_ptr(), moab::Interface::tag_set_data(), moab::DebugOutput::tprintf(), tVals, and moab::ReadNC::varInfo.
Interface*& mbImpl = _readNC->mbImpl;
std::vector< std::string >& dimNames = _readNC->dimNames;
std::vector< int >& dimLens = _readNC->dimLens;
std::map< std::string, ReadNC::AttData >& globalAtts = _readNC->globalAtts;
std::map< std::string, ReadNC::VarData >& varInfo = _readNC->varInfo;
DebugOutput& dbgOut = _readNC->dbgOut;
int& partMethod = _readNC->partMethod;
ScdInterface* scdi = _readNC->scdi;
ErrorCode rval;
std::string tag_name;
// <__NUM_DIMS>
Tag numDimsTag = 0;
tag_name = "__NUM_DIMS";
int numDims = dimNames.size();
rval = mbImpl->tag_get_handle( tag_name.c_str(), 1, MB_TYPE_INTEGER, numDimsTag, MB_TAG_SPARSE | MB_TAG_CREAT );MB_CHK_SET_ERR( rval, "Trouble creating conventional tag " << tag_name );
rval = mbImpl->tag_set_data( numDimsTag, &_fileSet, 1, &numDims );MB_CHK_SET_ERR( rval, "Trouble setting data to conventional tag " << tag_name );
dbgOut.tprintf( 2, "Conventional tag %s created\n", tag_name.c_str() );
// <__NUM_VARS>
Tag numVarsTag = 0;
tag_name = "__NUM_VARS";
int numVars = varInfo.size();
rval = mbImpl->tag_get_handle( tag_name.c_str(), 1, MB_TYPE_INTEGER, numVarsTag, MB_TAG_SPARSE | MB_TAG_CREAT );MB_CHK_SET_ERR( rval, "Trouble creating conventional tag " << tag_name );
rval = mbImpl->tag_set_data( numVarsTag, &_fileSet, 1, &numVars );MB_CHK_SET_ERR( rval, "Trouble setting data to conventional tag " << tag_name );
// <__DIM_NAMES>
Tag dimNamesTag = 0;
tag_name = "__DIM_NAMES";
std::string dimnames;
unsigned int dimNamesSz = dimNames.size();
for( unsigned int i = 0; i != dimNamesSz; i++ )
dimnames.append( dimNames[i] );
dimnames.push_back( '\0' );
int dimnamesSz = dimnames.size();
rval = mbImpl->tag_get_handle( tag_name.c_str(), 0, MB_TYPE_OPAQUE, dimNamesTag,
MB_TAG_CREAT | MB_TAG_SPARSE | MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Trouble creating conventional tag " << tag_name );
const void* ptr = dimnames.c_str();
rval = mbImpl->tag_set_by_ptr( dimNamesTag, &_fileSet, 1, &ptr, &dimnamesSz );MB_CHK_SET_ERR( rval, "Trouble setting data to conventional tag " << tag_name );
// <__DIM_LENS>
Tag dimLensTag = 0;
tag_name = "__DIM_LENS";
int dimLensSz = dimLens.size();
rval = mbImpl->tag_get_handle( tag_name.c_str(), 0, MB_TYPE_INTEGER, dimLensTag,
ptr = &( dimLens[0] );
rval = mbImpl->tag_set_by_ptr( dimLensTag, &_fileSet, 1, &ptr, &dimLensSz );MB_CHK_SET_ERR( rval, "Trouble setting data to conventional tag " << tag_name );
// <__VAR_NAMES>
Tag varNamesTag = 0;
tag_name = "__VAR_NAMES";
std::string varnames;
std::map< std::string, ReadNC::VarData >::iterator mapIter;
for( mapIter = varInfo.begin(); mapIter != varInfo.end(); ++mapIter )
varnames.append( mapIter->first );
varnames.push_back( '\0' );
int varnamesSz = varnames.size();
rval = mbImpl->tag_get_handle( tag_name.c_str(), 0, MB_TYPE_OPAQUE, varNamesTag,
ptr = varnames.c_str();
rval = mbImpl->tag_set_by_ptr( varNamesTag, &_fileSet, 1, &ptr, &varnamesSz );MB_CHK_SET_ERR( rval, "Trouble setting data to conventional tag " << tag_name );
// __<dim_name>_LOC_MINMAX (for time)
if( dimNames[i] == "time" || dimNames[i] == "Time" || dimNames[i] == "t" )
// some files might have Time dimension as 0, it will not appear in any
// variables, so skip it
if( nTimeSteps == 0 ) continue;
std::stringstream ss_tag_name;
ss_tag_name << "__" << dimNames[i] << "_LOC_MINMAX";
tag_name = ss_tag_name.str();
Tag tagh = 0;
std::vector< int > val( 2, 0 );
val[0] = 0;
val[1] = nTimeSteps - 1;
rval = mbImpl->tag_get_handle( tag_name.c_str(), 2, MB_TYPE_INTEGER, tagh, MB_TAG_SPARSE | MB_TAG_CREAT );MB_CHK_SET_ERR( rval, "Trouble creating conventional tag " << tag_name );
rval = mbImpl->tag_set_data( tagh, &_fileSet, 1, &val[0] );MB_CHK_SET_ERR( rval, "Trouble setting data to conventional tag " << tag_name );
// __<dim_name>_LOC_VALS (for time)
std::vector< int > val;
if( !tstep_nums.empty() )
val = tstep_nums;
else
if( tVals.empty() ) continue;
val.resize( tVals.size() );
for( unsigned int j = 0; j != tVals.size(); j++ )
val[j] = j;
Tag tagh = 0;
ss_tag_name << "__" << dimNames[i] << "_LOC_VALS";
rval = mbImpl->tag_get_handle( tag_name.c_str(), val.size(), MB_TYPE_INTEGER, tagh,
// __<var_name>_DIMS
Tag varNamesDimsTag = 0;
ss_tag_name << "__" << mapIter->first << "_DIMS";
unsigned int varDimSz = varInfo[mapIter->first].varDims.size();
if( varDimSz == 0 ) continue;
std::vector< Tag > varDimTags( varDimSz );
for( unsigned int i = 0; i != varDimSz; i++ )
Tag tmptag = 0;
std::string tmptagname = dimNames[varInfo[mapIter->first].varDims[i]];
rval = mbImpl->tag_get_handle( tmptagname.c_str(), 0, MB_TYPE_OPAQUE, tmptag, MB_TAG_ANY );MB_CHK_SET_ERR( rval, "Trouble getting tag " << tmptagname );
varDimTags[i] = tmptag;
// rval = mbImpl->tag_get_handle(tag_name.c_str(), varDimSz, MB_TYPE_HANDLE,
// varNamesDimsTag, MB_TAG_SPARSE | MB_TAG_CREAT); We should not use MB_TYPE_HANDLE for Tag
// here. Tag is a pointer, which is 4 bytes on 32 bit machines and 8 bytes on 64 bit
// machines. Normally, entity handle is 8 bytes on 64 bit machines, but it can also be
// configured to 4 bytes.
rval = mbImpl->tag_get_handle( tag_name.c_str(), varDimSz * sizeof( Tag ), MB_TYPE_OPAQUE, varNamesDimsTag,
rval = mbImpl->tag_set_data( varNamesDimsTag, &_fileSet, 1, &( varDimTags[0] ) );MB_CHK_SET_ERR( rval, "Trouble setting data to conventional tag " << tag_name );
// <PARTITION_METHOD>
Tag part_tag = scdi->part_method_tag();
if( !part_tag ) MB_SET_ERR( MB_FAILURE, "Trouble getting PARTITION_METHOD tag" );
rval = mbImpl->tag_set_data( part_tag, &_fileSet, 1, &partMethod );MB_CHK_SET_ERR( rval, "Trouble setting data to PARTITION_METHOD tag" );
// <__GLOBAL_ATTRIBS>
tag_name = "__GLOBAL_ATTRIBS";
Tag globalAttTag = 0;
rval = mbImpl->tag_get_handle( tag_name.c_str(), 0, MB_TYPE_OPAQUE, globalAttTag,
std::string gattVal;
std::vector< int > gattLen;
rval = create_attrib_string( globalAtts, gattVal, gattLen );MB_CHK_SET_ERR( rval, "Trouble creating global attribute string" );
const void* gattptr = gattVal.c_str();
int globalAttSz = gattVal.size();
rval = mbImpl->tag_set_by_ptr( globalAttTag, &_fileSet, 1, &gattptr, &globalAttSz );MB_CHK_SET_ERR( rval, "Trouble setting data to conventional tag " << tag_name );
// <__GLOBAL_ATTRIBS_LEN>
tag_name = "__GLOBAL_ATTRIBS_LEN";
Tag globalAttLenTag = 0;
if( gattLen.size() == 0 ) gattLen.push_back( 0 );
rval = mbImpl->tag_get_handle( tag_name.c_str(), gattLen.size(), MB_TYPE_INTEGER, globalAttLenTag,
rval = mbImpl->tag_set_data( globalAttLenTag, &_fileSet, 1, &gattLen[0] );MB_CHK_SET_ERR( rval, "Trouble setting data to conventional tag " << tag_name );
// __<var_name>_ATTRIBS and __<var_name>_ATTRIBS_LEN
std::stringstream ssTagName;
ssTagName << "__" << mapIter->first << "_ATTRIBS";
tag_name = ssTagName.str();
Tag varAttTag = 0;
rval = mbImpl->tag_get_handle( tag_name.c_str(), 0, MB_TYPE_OPAQUE, varAttTag,
std::string varAttVal;
std::vector< int > varAttLen;
if( mapIter->second.numAtts < 1 )
if( dummyVarNames.find( mapIter->first ) != dummyVarNames.end() )
// This variable is a dummy coordinate variable
varAttVal = "DUMMY_VAR";
else
// This variable has no attributes
varAttVal = "NO_ATTRIBS";
else
rval = create_attrib_string( mapIter->second.varAtts, varAttVal, varAttLen );MB_CHK_SET_ERR( rval, "Trouble creating attribute string for variable " << mapIter->first );
const void* varAttPtr = varAttVal.c_str();
int varAttSz = varAttVal.size();
if( 0 == varAttSz ) varAttSz = 1;
rval = mbImpl->tag_set_by_ptr( varAttTag, &_fileSet, 1, &varAttPtr, &varAttSz );MB_CHK_SET_ERR( rval, "Trouble setting data to conventional tag " << tag_name );
ssTagName << "_LEN";
Tag varAttLenTag = 0;
if( 0 == varAttLen.size() ) varAttLen.push_back( 0 );
rval = mbImpl->tag_get_handle( tag_name.c_str(), varAttLen.size(), MB_TYPE_INTEGER, varAttLenTag,
rval = mbImpl->tag_set_data( varAttLenTag, &_fileSet, 1, &varAttLen[0] );MB_CHK_SET_ERR( rval, "Trouble setting data to conventional tag " << tag_name );
// <__VAR_NAMES_LOCATIONS>
tag_name = "__VAR_NAMES_LOCATIONS";
Tag varNamesLocsTag = 0;
std::vector< int > varNamesLocs( varInfo.size() );
rval = mbImpl->tag_get_handle( tag_name.c_str(), varNamesLocs.size(), MB_TYPE_INTEGER, varNamesLocsTag,
MB_TAG_CREAT | MB_TAG_SPARSE );MB_CHK_SET_ERR( rval, "Trouble creating conventional tag " << tag_name );
varNamesLocs[std::distance( varInfo.begin(), mapIter )] = mapIter->second.entLoc;
rval = mbImpl->tag_set_data( varNamesLocsTag, &_fileSet, 1, &varNamesLocs[0] );MB_CHK_SET_ERR( rval, "Trouble setting data to conventional tag " << tag_name );
// <__MESH_TYPE>
Tag meshTypeTag = 0;
tag_name = "__MESH_TYPE";
std::string meshTypeName = get_mesh_type_name();
rval = mbImpl->tag_get_handle( tag_name.c_str(), 0, MB_TYPE_OPAQUE, meshTypeTag,
ptr = meshTypeName.c_str();
int leng = meshTypeName.size();
rval = mbImpl->tag_set_by_ptr( meshTypeTag, &_fileSet, 1, &ptr, &leng );MB_CHK_SET_ERR( rval, "Trouble setting data to conventional tag " << tag_name );
return MB_SUCCESS;
| ErrorCode moab::NCHelper::create_dummy_variables | ( | ) | [protected] |
For a dimension that does not have a corresponding coordinate variable (e.g. ncol for HOMME), create a dummy variable with a sparse tag to store the dimension length
Definition at line 752 of file NCHelper.cpp.
References _fileSet, _readNC, moab::ReadNC::dbgOut, moab::ReadNC::dimLens, moab::ReadNC::dimNames, dummyVarNames, moab::ReadNC::VarData::entLoc, moab::ReadNC::ENTLOCSET, ErrorCode, MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TAG_VARLEN, MB_TYPE_INTEGER, moab::ReadNC::mbImpl, moab::ReadNC::VarData::numAtts, size, moab::Interface::tag_get_handle(), moab::Interface::tag_set_by_ptr(), moab::DebugOutput::tprintf(), moab::ReadNC::VarData::varDataType, moab::ReadNC::VarData::varDims, moab::ReadNC::VarData::varId, moab::ReadNC::varInfo, moab::ReadNC::VarData::varName, and moab::ReadNC::VarData::varTags.
Referenced by moab::NCHelperHOMME::init_mesh_vals(), moab::NCHelperFV::init_mesh_vals(), and moab::NCHelperEuler::init_mesh_vals().
// Hack: look at all dimensions, and see if we have one that does not appear in the list of
// varInfo names Right now, candidates are from unstructured meshes, such as ncol (HOMME) and
// nCells (MPAS) For each of them, create a dummy coordinate variable with a sparse tag to store
// the dimension length
for( unsigned int i = 0; i < dimNames.size(); i++ )
// If there is a variable with this dimension name, skip
if( varInfo.find( dimNames[i] ) != varInfo.end() ) continue;
// Create a dummy coordinate variable
int sizeTotalVar = varInfo.size();
std::string var_name( dimNames[i] );
ReadNC::VarData& data = varInfo[var_name];
data.varName = var_name;
data.varId = sizeTotalVar;
data.varTags.resize( 1, 0 );
data.varDataType = NC_INT;
data.varDims.resize( 1 );
data.varDims[0] = (int)i;
data.numAtts = 0;
data.entLoc = ReadNC::ENTLOCSET;
dummyVarNames.insert( var_name );
dbgOut.tprintf( 2, "Dummy coordinate variable created for dimension %s\n", var_name.c_str() );
// Create a corresponding sparse tag
Tag tagh;
ErrorCode rval = mbImpl->tag_get_handle( var_name.c_str(), 0, MB_TYPE_INTEGER, tagh,
MB_TAG_CREAT | MB_TAG_SPARSE | MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Trouble creating tag for dummy coordinate variable " << var_name );
// Tag value is the dimension length
const void* ptr = &dimLens[i];
// Tag size is 1
int size = 1;
rval = mbImpl->tag_set_by_ptr( tagh, &_fileSet, 1, &ptr, &size );MB_CHK_SET_ERR( rval, "Trouble setting tag data for dummy coordinate variable " << var_name );
dbgOut.tprintf( 2, "Sparse tag created for dimension %s\n", var_name.c_str() );
return MB_SUCCESS;
| virtual ErrorCode moab::NCHelper::create_mesh | ( | Range & | faces | ) | [pure virtual] |
Implemented in moab::ScdNCHelper, moab::NCHelperGCRM, moab::NCHelperMPAS, moab::NCHelperHOMME, moab::NCHelperScrip, and moab::NCHelperDomain.
| virtual std::string moab::NCHelper::get_mesh_type_name | ( | ) | [pure virtual] |
Implemented in moab::NCHelperEuler, moab::NCHelperScrip, moab::NCHelperGCRM, moab::NCHelperMPAS, moab::NCHelperHOMME, moab::NCHelperDomain, and moab::NCHelperFV.
| NCHelper * moab::NCHelper::get_nc_helper | ( | ReadNC * | readNC, |
| int | fileId, | ||
| ) | [static] |
Definition at line 23 of file NCHelper.cpp.
References moab::NCHelperHOMME::can_read_file(), moab::NCHelperDomain::can_read_file(), moab::NCHelperGCRM::can_read_file(), moab::NCHelperScrip::can_read_file(), moab::NCHelperMPAS::can_read_file(), moab::NCHelperFV::can_read_file(), moab::NCHelperEuler::can_read_file(), moab::ReadNC::globalAtts, and NCFUNC.
// Check if CF convention is being followed
bool is_CF = false;
std::map< std::string, ReadNC::AttData >& globalAtts = readNC->globalAtts;
std::map< std::string, ReadNC::AttData >::iterator attIt = globalAtts.find( "conventions" );
if( attIt == globalAtts.end() ) attIt = globalAtts.find( "Conventions" );
if( attIt != globalAtts.end() )
unsigned int sz = attIt->second.attLen;
std::string att_data;
att_data.resize( sz + 1 );
att_data[sz] = '\000';
int success =
NCFUNC( get_att_text )( fileId, attIt->second.attVarId, attIt->second.attName.c_str(), &att_data[0] );
if( 0 == success && att_data.find( "CF" ) != std::string::npos ) is_CF = true;
if( is_CF )
if( NCHelperEuler::can_read_file( readNC, fileId ) )
return new( std::nothrow ) NCHelperEuler( readNC, fileId, opts, fileSet );
else if( NCHelperFV::can_read_file( readNC, fileId ) )
return new( std::nothrow ) NCHelperFV( readNC, fileId, opts, fileSet );
else if( NCHelperHOMME::can_read_file( readNC, fileId ) )
return new( std::nothrow ) NCHelperHOMME( readNC, fileId, opts, fileSet );
else if( NCHelperDomain::can_read_file( readNC, fileId ) )
return new( std::nothrow ) NCHelperDomain( readNC, fileId, opts, fileSet );
else
if( NCHelperMPAS::can_read_file( readNC ) )
return new( std::nothrow ) NCHelperMPAS( readNC, fileId, opts, fileSet );
// For a HOMME connectivity file, there might be no CF convention
// gcrm reader
else if( NCHelperGCRM::can_read_file( readNC ) )
return new( std::nothrow ) NCHelperGCRM( readNC, fileId, opts, fileSet );
// SCRIP can be CF or non CF, if it comes from MPAS :)
if( NCHelperScrip::can_read_file( readNC, fileId ) )
return new( std::nothrow ) NCHelperScrip( readNC, fileId, opts, fileSet );
// Unknown NetCDF grid (will fill this in later for POP, CICE and CLM)
return NULL;
| ErrorCode moab::NCHelper::get_tag_to_nonset | ( | ReadNC::VarData & | var_data, |
| int | tstep_num, | ||
| Tag & | tagh, | ||
| int | num_lev | ||
| ) | [protected] |
Definition at line 637 of file NCHelper.cpp.
References _readNC, moab::ReadNC::dbgOut, ErrorCode, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_DOUBLE, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, moab::ReadNC::mbImpl, moab::Interface::tag_get_handle(), moab::DebugOutput::tprintf(), moab::ReadNC::tStepBase, moab::ReadNC::VarData::varDataType, and moab::ReadNC::VarData::varName.
Referenced by moab::ScdNCHelper::read_scd_variables_to_nonset_allocate(), and moab::NCHelperHOMME::read_ucd_variables_to_nonset_allocate().
int& tStepBase = _readNC->tStepBase;
if( tStepBase > 0 ) tstep_num += tStepBase;
std::ostringstream tag_name;
tag_name << var_data.varName << tstep_num;
ErrorCode rval = MB_SUCCESS;
tagh = 0;
switch( var_data.varDataType )
case NC_BYTE:
case NC_CHAR:
rval = mbImpl->tag_get_handle( tag_name.str().c_str(), num_lev, MB_TYPE_OPAQUE, tagh,
MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_SET_ERR( rval, "Trouble creating tag " << tag_name.str() );
break;
case NC_SHORT:
case NC_INT:
rval = mbImpl->tag_get_handle( tag_name.str().c_str(), num_lev, MB_TYPE_INTEGER, tagh,
break;
case NC_FLOAT:
case NC_DOUBLE:
rval = mbImpl->tag_get_handle( tag_name.str().c_str(), num_lev, MB_TYPE_DOUBLE, tagh,
break;
default:
MB_SET_ERR( MB_FAILURE, "Unexpected data type for variable " << var_data.varName );
dbgOut.tprintf( 2, "Tag %s created\n", tag_name.str().c_str() );
return rval;
| ErrorCode moab::NCHelper::get_tag_to_set | ( | ReadNC::VarData & | var_data, |
| Tag & | tagh | ||
| ) | [protected] |
Definition at line 595 of file NCHelper.cpp.
References _readNC, moab::ReadNC::dbgOut, ErrorCode, moab::ReadNC::VarData::has_tsteps, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TAG_VARLEN, MB_TYPE_DOUBLE, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, moab::ReadNC::mbImpl, moab::Interface::tag_get_handle(), moab::DebugOutput::tprintf(), moab::ReadNC::tStepBase, moab::ReadNC::VarData::varDataType, and moab::ReadNC::VarData::varName.
Referenced by read_variables_to_set_allocate().
if( var_data.has_tsteps )
else
tag_name << var_data.varName;
tagh = 0;
case NC_BYTE:
case NC_CHAR:
rval = mbImpl->tag_get_handle( tag_name.str().c_str(), 0, MB_TYPE_OPAQUE, tagh,
MB_TAG_CREAT | MB_TAG_SPARSE | MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Trouble creating tag " << tag_name.str() );
break;
case NC_SHORT:
case NC_INT:
rval = mbImpl->tag_get_handle( tag_name.str().c_str(), 0, MB_TYPE_INTEGER, tagh,
break;
case NC_FLOAT:
case NC_DOUBLE:
rval = mbImpl->tag_get_handle( tag_name.str().c_str(), 0, MB_TYPE_DOUBLE, tagh,
break;
default:
return rval;
| virtual ErrorCode moab::NCHelper::init_mesh_vals | ( | ) | [pure virtual] |
Implemented in moab::NCHelperEuler, moab::NCHelperScrip, moab::NCHelperDomain, moab::NCHelperFV, moab::NCHelperGCRM, moab::NCHelperMPAS, and moab::NCHelperHOMME.
| ErrorCode moab::NCHelper::read_coordinate | ( | const char * | var_name, |
| int | lmin, | ||
| int | lmax, | ||
| std::vector< double > & | cvals | ||
| ) | [protected] |
Definition at line 563 of file NCHelper.cpp.
References _fileId, _readNC, MB_SET_ERR, MB_SUCCESS, NCDF_DIFF, NCDF_SIZE, NCFUNCAG, and moab::ReadNC::varInfo.
Referenced by moab::NCHelperHOMME::init_mesh_vals(), moab::NCHelperMPAS::init_mesh_vals(), moab::NCHelperFV::init_mesh_vals(), moab::NCHelperGCRM::init_mesh_vals(), and moab::NCHelperEuler::init_mesh_vals().
std::map< std::string, ReadNC::VarData >::iterator vmit = varInfo.find( var_name );
if( varInfo.end() == vmit ) MB_SET_ERR( MB_FAILURE, "Couldn't find variable " << var_name );
assert( lmin >= 0 && lmax >= lmin );
NCDF_SIZE tstart = lmin;
NCDF_SIZE tcount = lmax - lmin + 1;
NCDF_DIFF dum_stride = 1;
int success;
// Check size
if( (std::size_t)tcount != cvals.size() ) cvals.resize( tcount );
// Check to make sure it's a float or double
switch( ( *vmit ).second.varDataType )
case NC_FLOAT:
case NC_DOUBLE:
// Read float as double
success =
NCFUNCAG( _vars_double )( _fileId, ( *vmit ).second.varId, &tstart, &tcount, &dum_stride, &cvals[0] );
if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read float/double data for variable " << var_name );
break;
default:
MB_SET_ERR( MB_FAILURE, "Unexpected data type for variable " << var_name );
return MB_SUCCESS;
| virtual ErrorCode moab::NCHelper::read_variables | ( | std::vector< std::string > & | var_names, |
| std::vector< int > & | tstep_nums | ||
Implemented in moab::UcdNCHelper, and moab::ScdNCHelper.
| ErrorCode moab::NCHelper::read_variables_setup | ( | std::vector< std::string > & | var_names, |
| std::vector< int > & | tstep_nums, | ||
| std::vector< ReadNC::VarData > & | vdatas, | ||
| std::vector< ReadNC::VarData > & | vsetdatas | ||
| ) | [protected] |
Definition at line 374 of file NCHelper.cpp.
References _readNC, moab::ReadNC::dimNames, dummyVarNames, moab::ReadNC::VarData::entLoc, moab::ReadNC::ENTLOCSET, ignoredVarNames, MB_SET_ERR, MB_SUCCESS, nTimeSteps, tDim, moab::ReadNC::varInfo, and moab::ReadNC::VarData::varName.
Referenced by moab::ScdNCHelper::read_variables(), and moab::UcdNCHelper::read_variables().
std::map< std::string, ReadNC::VarData >::iterator mit;
// If empty read them all (except ignored variables)
if( var_names.empty() )
for( mit = varInfo.begin(); mit != varInfo.end(); ++mit )
ReadNC::VarData vd = ( *mit ).second;
// If read all variables at once, skip ignored ones
if( ignoredVarNames.find( vd.varName ) != ignoredVarNames.end() ) continue;
// Coordinate variables (include dummy ones) were read to the file set by default
if( std::find( dimNames.begin(), dimNames.end(), vd.varName ) != dimNames.end() ) continue;
if( vd.entLoc == ReadNC::ENTLOCSET )
vsetdatas.push_back( vd );
else
vdatas.push_back( vd );
else
// Read specified variables (might include ignored ones)
for( unsigned int i = 0; i < var_names.size(); i++ )
mit = varInfo.find( var_names[i] );
if( mit != varInfo.end() )
// Upon creation of dummy coordinate variables, tag values have already been set
if( dummyVarNames.find( vd.varName ) != dummyVarNames.end() ) continue;
else
else
MB_SET_ERR( MB_FAILURE, "Couldn't find specified variable " << var_names[i] );
if( tstep_nums.empty() && nTimeSteps > 0 )
// No timesteps input, get them all
for( int i = 0; i < nTimeSteps; i++ )
tstep_nums.push_back( i );
for( unsigned int i = 0; i < vdatas.size(); i++ )
vdatas[i].varTags.resize( tstep_nums.size(), 0 );
vdatas[i].varDatas.resize( tstep_nums.size() );
// NC reader assumes that non-set variables always have timesteps
assert( std::find( vdatas[i].varDims.begin(), vdatas[i].varDims.end(), tDim ) != vdatas[i].varDims.end() );
vdatas[i].has_tsteps = true;
for( unsigned int i = 0; i < vsetdatas.size(); i++ )
if( ( std::find( vsetdatas[i].varDims.begin(), vsetdatas[i].varDims.end(), tDim ) !=
vsetdatas[i].varDims.end() ) &&
( vsetdatas[i].varName != dimNames[tDim] ) )
// Set variables with timesteps: e.g. xtime(Time) or xtime(Time, StrLen)
vsetdatas[i].varTags.resize( tstep_nums.size(), 0 );
vsetdatas[i].varDatas.resize( tstep_nums.size() );
vsetdatas[i].has_tsteps = true;
else
// Set variables without timesteps: no time dimension, or time itself
vsetdatas[i].varTags.resize( 1, 0 );
vsetdatas[i].varDatas.resize( 1 );
vsetdatas[i].has_tsteps = false;
return MB_SUCCESS;
| ErrorCode moab::NCHelper::read_variables_to_set | ( | std::vector< ReadNC::VarData > & | vdatas, |
| ) | [protected] |
Definition at line 470 of file NCHelper.cpp.
References _fileId, _fileSet, _readNC, moab::ReadNC::dbgOut, ErrorCode, moab::DebugOutput::get_verbosity(), MB_CHK_SET_ERR, MB_SET_ERR, moab::ReadNC::mbImpl, NCFUNCAG, moab::DebugOutput::printf(), read_variables_to_set_allocate(), t, moab::Interface::tag_set_by_ptr(), and moab::DebugOutput::tprintf().
ErrorCode rval = read_variables_to_set_allocate( vdatas, tstep_nums );MB_CHK_SET_ERR( rval, "Trouble allocating space to read set variables" );
// Finally, read into that space
int success;
// Note, for set variables without timesteps, loop one time and then break
for( unsigned int t = 0; t < tstep_nums.size(); t++ )
void* data = vdatas[i].varDatas[t];
// Set variables with timesteps, e.g. xtime(Time) or xtime(Time, StrLen)
if( vdatas[i].has_tsteps )
// Set readStart for each timestep along time dimension
vdatas[i].readStarts[0] = tstep_nums[t];
switch( vdatas[i].varDataType )
case NC_BYTE:
case NC_CHAR:
success = NCFUNCAG( _vara_text )( _fileId, vdatas[i].varId, &vdatas[i].readStarts[0],
&vdatas[i].readCounts[0], (char*)data );
if( success )
MB_SET_ERR( MB_FAILURE, "Failed to read byte/char data for variable " << vdatas[i].varName );
break;
case NC_SHORT:
case NC_INT:
success = NCFUNCAG( _vara_int )( _fileId, vdatas[i].varId, &vdatas[i].readStarts[0],
&vdatas[i].readCounts[0], (int*)data );
if( success )
MB_SET_ERR( MB_FAILURE, "Failed to read short/int data for variable " << vdatas[i].varName );
break;
case NC_FLOAT:
case NC_DOUBLE:
success = NCFUNCAG( _vara_double )( _fileId, vdatas[i].varId, &vdatas[i].readStarts[0],
&vdatas[i].readCounts[0], (double*)data );
if( success )
MB_SET_ERR( MB_FAILURE, "Failed to read float/double data for variable " << vdatas[i].varName );
break;
default:
MB_SET_ERR( MB_FAILURE, "Unexpected data type for variable " << vdatas[i].varName );
dbgOut.tprintf( 2, "Setting data for variable %s, time step %d\n", vdatas[i].varName.c_str(),
tstep_nums[t] );
rval = mbImpl->tag_set_by_ptr( vdatas[i].varTags[t], &_fileSet, 1, &data, &vdatas[i].sz );MB_CHK_SET_ERR( rval, "Trouble setting tag data for variable " << vdatas[i].varName );
// Memory pointed by pointer data can be deleted, as tag_set_by_ptr() has already copied
// the tag values
case NC_BYTE:
case NC_CHAR:
delete[]( char* ) data;
break;
case NC_SHORT:
case NC_INT:
delete[]( int* ) data;
break;
case NC_FLOAT:
case NC_DOUBLE:
delete[]( double* ) data;
break;
default:
break;
vdatas[i].varDatas[t] = NULL;
// Loop continues only for set variables with timesteps, e.g. xtime(Time) or xtime(Time,
// StrLen)
if( !vdatas[i].has_tsteps ) break;
// Debug output, if requested
if( 1 == dbgOut.get_verbosity() )
dbgOut.printf( 1, "Read variables: %s", vdatas.begin()->varName.c_str() );
for( unsigned int i = 1; i < vdatas.size(); i++ )
dbgOut.printf( 1, ", %s ", vdatas[i].varName.c_str() );
dbgOut.tprintf( 1, "\n" );
return rval;
| ErrorCode moab::NCHelper::read_variables_to_set_allocate | ( | std::vector< ReadNC::VarData > & | vdatas, |
| ) | [private] |
Definition at line 801 of file NCHelper.cpp.
References _readNC, moab::ReadNC::dbgOut, moab::ReadNC::dimLens, ErrorCode, get_tag_to_set(), MB_CHK_SET_ERR, MB_INDEX_OUT_OF_RANGE, MB_SET_ERR, MB_SUCCESS, t, tDim, and moab::DebugOutput::tprintf().
Referenced by read_variables_to_set().
// Set up readStarts and readCounts
// First: time
vdatas[i].readStarts.push_back( 0 ); // This value is timestep dependent, will be set later
vdatas[i].readCounts.push_back( 1 );
// Next: other dimensions
for( unsigned int idx = 1; idx != vdatas[i].varDims.size(); idx++ )
vdatas[i].readCounts.push_back( dimLens[vdatas[i].varDims[idx]] );
else
if( vdatas[i].varDims.empty() )
// Scalar variable
else
for( unsigned int idx = 0; idx != vdatas[i].varDims.size(); idx++ )
// Get variable size
vdatas[i].sz = 1;
for( std::size_t idx = 0; idx != vdatas[i].readCounts.size(); idx++ )
vdatas[i].sz *= vdatas[i].readCounts[idx];
dbgOut.tprintf( 2, "Reading variable %s, time step %d\n", vdatas[i].varName.c_str(), tstep_nums[t] );
if( tstep_nums[t] >= dimLens[tDim] )
MB_SET_ERR( MB_INDEX_OUT_OF_RANGE, "Wrong value for timestep number " << tstep_nums[t] );
// Get the tag to read into
if( !vdatas[i].varTags[t] )
rval = get_tag_to_set( vdatas[i], tstep_nums[t], vdatas[i].varTags[t] );MB_CHK_SET_ERR( rval, "Trouble getting tag to set variable " << vdatas[i].varName );
case NC_BYTE:
case NC_CHAR:
vdatas[i].varDatas[t] = new char[vdatas[i].sz];
break;
case NC_SHORT:
case NC_INT:
vdatas[i].varDatas[t] = new int[vdatas[i].sz];
break;
case NC_FLOAT:
case NC_DOUBLE:
vdatas[i].varDatas[t] = new double[vdatas[i].sz];
break;
default:
// StrLen)
return rval;
Definition at line 325 of file NCHelper.cpp.
References _fileSet, _readNC, moab::ReadNC::dimNames, dummyVarNames, ErrorCode, MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_VARLEN, MB_TYPE_DOUBLE, moab::ReadNC::mbImpl, nTimeSteps, moab::Interface::tag_get_by_ptr(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_by_ptr(), tDim, and tVals.
ErrorCode rval;
// The time tag might be a dummy one (e.g. 'Time' for MPAS)
std::string time_tag_name = dimNames[tDim];
if( dummyVarNames.find( time_tag_name ) != dummyVarNames.end() ) return MB_SUCCESS;
Tag time_tag = 0;
const void* data = NULL;
int time_tag_size = 0;
rval = mbImpl->tag_get_handle( time_tag_name.c_str(), 0, MB_TYPE_DOUBLE, time_tag, MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Trouble getting tag " << time_tag_name );
rval = mbImpl->tag_get_by_ptr( time_tag, &_fileSet, 1, &data, &time_tag_size );MB_CHK_SET_ERR( rval, "Trouble getting data of tag " << time_tag_name );
const double* time_tag_vals = static_cast< const double* >( data );
// Merge tVals (read from current file) to existing time tag
// Assume that time_tag_vals and tVals are both sorted
std::vector< double > merged_time_vals;
merged_time_vals.reserve( time_tag_size + nTimeSteps );
int i = 0;
int j = 0;
// Merge time values from time_tag_vals and tVals
while( i < time_tag_size && j < nTimeSteps )
if( time_tag_vals[i] < tVals[j] )
merged_time_vals.push_back( time_tag_vals[i++] );
else
merged_time_vals.push_back( tVals[j++] );
// Append remaining time values of time_tag_vals (if any)
while( i < time_tag_size )
// Append remaining time values of tVals (if any)
while( j < nTimeSteps )
data = &merged_time_vals[0];
time_tag_size = merged_time_vals.size();
rval = mbImpl->tag_set_by_ptr( time_tag, &_fileSet, 1, &data, &time_tag_size );MB_CHK_SET_ERR( rval, "Trouble setting data to tag " << time_tag_name );
return MB_SUCCESS;
int moab::NCHelper::_fileId [protected] |
Definition at line 103 of file NCHelper.hpp.
Referenced by create_attrib_string(), moab::NCHelperDomain::create_mesh(), moab::NCHelperScrip::create_mesh(), moab::NCHelperHOMME::init_mesh_vals(), moab::NCHelperScrip::init_mesh_vals(), read_coordinate(), moab::ScdNCHelper::read_scd_variables_to_nonset(), moab::NCHelperHOMME::read_ucd_variables_to_nonset(), and read_variables_to_set().
EntityHandle moab::NCHelper::_fileSet [protected] |
Definition at line 105 of file NCHelper.hpp.
Referenced by moab::NCHelperHOMME::check_existing_mesh(), moab::ScdNCHelper::check_existing_mesh(), create_conventional_tags(), create_dummy_variables(), moab::NCHelperDomain::create_mesh(), moab::NCHelperScrip::create_mesh(), moab::NCHelperHOMME::create_mesh(), moab::ScdNCHelper::create_mesh(), moab::ScdNCHelper::create_quad_coordinate_tag(), moab::NCHelperFV::init_mesh_vals(), moab::NCHelperDomain::init_mesh_vals(), moab::NCHelperScrip::init_mesh_vals(), moab::NCHelperEuler::init_mesh_vals(), moab::ScdNCHelper::read_scd_variables_to_nonset_allocate(), moab::NCHelperHOMME::read_ucd_variables_to_nonset_allocate(), read_variables_to_set(), and update_time_tag_vals().
const FileOptions& moab::NCHelper::_opts [protected] |
Definition at line 104 of file NCHelper.hpp.
Referenced by moab::NCHelperHOMME::create_mesh(), moab::NCHelperFV::init_mesh_vals(), and moab::NCHelperEuler::init_mesh_vals().
ReadNC* moab::NCHelper::_readNC [protected] |
Definition at line 100 of file NCHelper.hpp.
Referenced by moab::NCHelperHOMME::check_existing_mesh(), moab::ScdNCHelper::check_existing_mesh(), create_conventional_tags(), create_dummy_variables(), moab::NCHelperDomain::create_mesh(), moab::NCHelperScrip::create_mesh(), moab::NCHelperHOMME::create_mesh(), moab::ScdNCHelper::create_mesh(), moab::ScdNCHelper::create_quad_coordinate_tag(), get_tag_to_nonset(), get_tag_to_set(), moab::NCHelperHOMME::init_mesh_vals(), moab::NCHelperFV::init_mesh_vals(), moab::NCHelperGCRM::init_mesh_vals(), moab::NCHelperMPAS::init_mesh_vals(), moab::NCHelperDomain::init_mesh_vals(), moab::NCHelperScrip::init_mesh_vals(), moab::NCHelperEuler::init_mesh_vals(), read_coordinate(), moab::ScdNCHelper::read_scd_variables_to_nonset(), moab::ScdNCHelper::read_scd_variables_to_nonset_allocate(), moab::NCHelperHOMME::read_ucd_variables_to_nonset(), moab::NCHelperHOMME::read_ucd_variables_to_nonset_allocate(), read_variables_setup(), read_variables_to_set(), read_variables_to_set_allocate(), and update_time_tag_vals().
std::set< std::string > moab::NCHelper::dummyVarNames [protected] |
Dummy variables.
Definition at line 120 of file NCHelper.hpp.
Referenced by create_conventional_tags(), create_dummy_variables(), read_variables_setup(), and update_time_tag_vals().
std::set< std::string > moab::NCHelper::ignoredVarNames [protected] |
Ignored variables.
Definition at line 117 of file NCHelper.hpp.
Referenced by moab::NCHelperMPAS::init_mesh_vals(), moab::NCHelperGCRM::NCHelperGCRM(), moab::NCHelperMPAS::NCHelperMPAS(), and read_variables_setup().
int moab::NCHelper::levDim [protected] |
Definition at line 114 of file NCHelper.hpp.
Referenced by moab::NCHelperHOMME::init_mesh_vals(), moab::NCHelperMPAS::init_mesh_vals(), moab::NCHelperGCRM::init_mesh_vals(), moab::NCHelperDomain::init_mesh_vals(), moab::NCHelperFV::init_mesh_vals(), and moab::NCHelperEuler::init_mesh_vals().
std::vector< double > moab::NCHelper::levVals [protected] |
Definition at line 111 of file NCHelper.hpp.
Referenced by moab::NCHelperHOMME::create_mesh(), moab::ScdNCHelper::create_mesh(), and moab::NCHelperHOMME::init_mesh_vals().
int moab::NCHelper::nLevels [protected] |
Definition at line 108 of file NCHelper.hpp.
int moab::NCHelper::nTimeSteps [protected] |
Referenced by create_conventional_tags(), moab::NCHelperHOMME::init_mesh_vals(), moab::NCHelperMPAS::init_mesh_vals(), moab::NCHelperGCRM::init_mesh_vals(), moab::NCHelperDomain::init_mesh_vals(), moab::NCHelperFV::init_mesh_vals(), moab::NCHelperEuler::init_mesh_vals(), read_variables_setup(), and update_time_tag_vals().
int moab::NCHelper::tDim [protected] |
Referenced by moab::NCHelperHOMME::init_mesh_vals(), moab::NCHelperDomain::init_mesh_vals(), moab::NCHelperGCRM::init_mesh_vals(), moab::NCHelperMPAS::init_mesh_vals(), moab::NCHelperFV::init_mesh_vals(), moab::NCHelperEuler::init_mesh_vals(), moab::ScdNCHelper::read_scd_variables_to_nonset_allocate(), moab::NCHelperHOMME::read_ucd_variables_to_nonset_allocate(), read_variables_setup(), read_variables_to_set_allocate(), and update_time_tag_vals().
std::vector< double > moab::NCHelper::tVals [protected] |
Referenced by create_conventional_tags(), moab::NCHelperHOMME::init_mesh_vals(), moab::NCHelperDomain::init_mesh_vals(), moab::NCHelperFV::init_mesh_vals(), moab::NCHelperMPAS::init_mesh_vals(), moab::NCHelperGCRM::init_mesh_vals(), moab::NCHelperEuler::init_mesh_vals(), and update_time_tag_vals().
