moab::LloydSmoother Class Reference
#include <LloydSmoother.hpp>
+ Collaboration diagram for moab::LloydSmoother:
Public Member Functions
 LloydSmoother (Interface *impl)
 LloydSmoother (Interface *impl, ParallelComm *pc, Range &elems, Tag cds_tag=0, Tag fixed_tag=0, double abs_tol=-1.0, double rel_tol=1.0e-6)
 ~LloydSmoother ()
ErrorCode perform_smooth ()
Interface * mb_impl ()
ParallelComm * pcomm ()
void pcomm (ParallelComm *pc)
Range & elems ()
const Range & elems () const
Tag fixed_tag ()
void fixed_tag (Tag fixed)
Tag coords_tag ()
void coords_tag (Tag coords)
double abs_tol ()
void abs_tol (double tol)
double rel_tol ()
void rel_tol (double tol)
int num_its ()
void num_its (int num)
int report_its ()
void report_its (int num)
Private Member Functions
ErrorCode initialize ()
Private Attributes
Interface * mbImpl
ParallelComm * myPcomm
Range myElems
Tag coordsTag
Tag fixedTag
double absTol
double relTol
int reportIts
int numIts
bool iCreatedTag
Detailed Description
Examples:
DeformMeshRemap.cpp.
Definition at line 26 of file LloydSmoother.hpp.
moab::LloydSmoother::LloydSmoother ( Interface *  impl,
ParallelComm *  pc,
Range &  elems,
Tag  cds_tag = 0,
Tag  fixed_tag = 0,
double  abs_tol = -1.0,
double  rel_tol = 1.0e-6
Definition at line 17 of file LloydSmoother.cpp.
    : mbImpl( impl ), myPcomm( pc ), myElems( elms ), coordsTag( ctag ), fixedTag( ftag ), absTol( at ), relTol( rt ),
      reportIts( 0 ), numIts( 0 ), iCreatedTag( false )
Definition at line 23 of file LloydSmoother.cpp.
References ErrorCode, fixedTag, iCreatedTag, MB_CHK_SET_ERR_RET, mbImpl, and moab::Interface::tag_delete().
    if( iCreatedTag && fixedTag )
        ErrorCode rval = mbImpl->tag_delete( fixedTag );MB_CHK_SET_ERR_RET( rval, "Failed to delete the fixed tag" );
Member Function Documentation
double moab::LloydSmoother::abs_tol ( ) [inline]
Definition at line 127 of file LloydSmoother.hpp.
References absTol.
        return absTol;
void moab::LloydSmoother::abs_tol ( double  tol) [inline]
Definition at line 134 of file LloydSmoother.hpp.
References absTol.
        absTol = tol;
Definition at line 113 of file LloydSmoother.hpp.
References coordsTag.
        return coordsTag;
void moab::LloydSmoother::coords_tag ( Tag  coords) [inline]
Definition at line 120 of file LloydSmoother.hpp.
        coordsTag = coords;
Definition at line 85 of file LloydSmoother.hpp.
References myElems.
        return myElems;
const Range& moab::LloydSmoother::elems ( ) const [inline]
Definition at line 92 of file LloydSmoother.hpp.
References myElems.
        return myElems;
Definition at line 99 of file LloydSmoother.hpp.
References fixedTag.
        return fixedTag;
void moab::LloydSmoother::fixed_tag ( Tag  fixed) [inline]
Definition at line 106 of file LloydSmoother.hpp.
        fixedTag = fixed;
Definition at line 207 of file LloydSmoother.cpp.
References ErrorCode, moab::ParallelComm::filter_pstatus(), moab::Skinner::find_skin(), fixedTag, moab::Interface::get_adjacencies(), iCreatedTag, MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_OPAQUE, mbImpl, myElems, myPcomm, PSTATUS_GHOST, PSTATUS_INTERFACE, PSTATUS_NOT, moab::Range::size(), skin(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), and moab::Interface::UNION.
Referenced by perform_smooth().
    ErrorCode rval = MB_SUCCESS;
    // first, check for tag; if we don't have it, make one and mark skin as fixed
    if( !fixedTag )
        unsigned char fixed = 0x0;
        rval = mbImpl->tag_get_handle( "", 1, MB_TYPE_OPAQUE, fixedTag, MB_TAG_DENSE | MB_TAG_CREAT, &fixed );MB_CHK_SET_ERR( rval, "Trouble making fixed tag" );
        iCreatedTag = true;
        // get the skin; get facets, because we might need to filter on shared entities
        Skinner skinner( mbImpl );
        Range skin, skin_verts;
        rval = skinner.find_skin( 0, myElems, false, skin );MB_CHK_SET_ERR( rval, "Unable to find skin" );
#ifdef MOAB_HAVE_MPI
        // need to do a little extra if we're working in parallel
        if( myPcomm )
            // filter out ghost and interface facets
            rval = myPcomm->filter_pstatus( skin, PSTATUS_GHOST | PSTATUS_INTERFACE, PSTATUS_NOT );MB_CHK_SET_ERR( rval, "Failed to filter on shared status" );
#endif
        // get the vertices from those entities
        rval = mbImpl->get_adjacencies( skin, 0, false, skin_verts, Interface::UNION );MB_CHK_SET_ERR( rval, "Trouble getting vertices" );
        // mark them fixed
        std::vector< unsigned char > marks( skin_verts.size(), 0x1 );
        rval = mbImpl->tag_set_data( fixedTag, skin_verts, &marks[0] );MB_CHK_SET_ERR( rval, "Unable to set tag on skin" );
    return MB_SUCCESS;
Definition at line 64 of file LloydSmoother.hpp.
References mbImpl.
        return mbImpl;
int moab::LloydSmoother::num_its ( ) [inline]
Definition at line 155 of file LloydSmoother.hpp.
References numIts.
Referenced by DeformMeshRemap::execute(), and main().
        return numIts;
void moab::LloydSmoother::num_its ( int  num) [inline]
Definition at line 159 of file LloydSmoother.hpp.
References numIts.
        numIts = num;
Definition at line 71 of file LloydSmoother.hpp.
References myPcomm.
        return myPcomm;
void moab::LloydSmoother::pcomm ( ParallelComm *  pc) [inline]
Definition at line 78 of file LloydSmoother.hpp.
References myPcomm.
        myPcomm = pc;
Definition at line 31 of file LloydSmoother.cpp.
References absTol, moab::Range::begin(), moab::ParallelComm::comm(), coordsTag, moab::BoundBox::diagonal_length(), dim, moab::Interface::dimension_from_handle(), moab::Range::empty(), moab::Range::end(), ErrorCode, moab::ParallelComm::exchange_tags(), moab::ParallelComm::filter_pstatus(), fixedTag, moab::Interface::get_adjacencies(), moab::Interface::get_connectivity(), moab::Interface::get_coords(), initialize(), moab::Range::insert(), length(), moab::CN::MAX_NODES_PER_ELEMENT, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_DOUBLE, mbImpl, myElems, myPcomm, numIts, PSTATUS_AND, PSTATUS_NOT, PSTATUS_NOT_OWNED, PSTATUS_SHARED, moab::ParallelComm::rank(), moab::Range::rbegin(), relTol, reportIts, moab::Interface::set_coords(), moab::Range::size(), moab::ParallelComm::size(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), moab::Interface::UNION, and moab::BoundBox::update().
Referenced by DeformMeshRemap::execute(), main(), and run_local_smoother().
    ErrorCode rval;
    if( myElems.empty() )
        MB_SET_ERR( MB_FAILURE, "No elements specified to Lloyd smoother" );
    else if( mbImpl->dimension_from_handle( *myElems.begin() ) != mbImpl->dimension_from_handle( *myElems.rbegin() ) )
        MB_SET_ERR( MB_FAILURE, "Elements of unequal dimension specified to Lloyd smoother" );
    int dim = mbImpl->dimension_from_handle( *myElems.begin() );
    // first figure out tolerance to use
    if( 0 > absTol )
        // no tolerance set - get one relative to bounding box around elements
        BoundBox bb;
        rval = bb.update( *mbImpl, myElems );MB_CHK_SET_ERR( rval, "Failed to compute bounding box around elements" );
        absTol = relTol * bb.diagonal_length();
    // initialize if we need to
    rval = initialize();MB_CHK_SET_ERR( rval, "Failed to initialize" );
    // get all vertices
    Range verts;
    rval = mbImpl->get_adjacencies( myElems, 0, false, verts, Interface::UNION );MB_CHK_SET_ERR( rval, "Failed to get all vertices" );
    // perform Lloyd relaxation:
    // 1. setup: set vertex centroids from vertex coords; filter to owned verts; get fixed tags
    // get all verts coords into tag; don't need to worry about filtering out fixed verts,
    // we'll just be setting to their fixed coords
    std::vector< double > vcentroids( 3 * verts.size() );
    if( !coordsTag )
        rval = mbImpl->get_coords( verts, &vcentroids[0] );MB_CHK_SET_ERR( rval, "Failed to get vert coords" );
    else
        rval = mbImpl->tag_get_data( coordsTag, verts, &vcentroids[0] );MB_CHK_SET_ERR( rval, "Failed to get vert coords tag values" );
    Tag centroid;
    rval = mbImpl->tag_get_handle( "", 3, MB_TYPE_DOUBLE, centroid, MB_TAG_CREAT | MB_TAG_DENSE );MB_CHK_SET_ERR( rval, "Couldn't get tag handle" );
    rval = mbImpl->tag_set_data( centroid, verts, &vcentroids[0] );MB_CHK_SET_ERR( rval, "Failed setting centroid tag" );
    Range owned_verts, shared_owned_verts;
    // filter verts down to owned ones and get fixed tag for them
    if( myPcomm && myPcomm->size() > 1 )
        rval = myPcomm->filter_pstatus( verts, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &owned_verts );MB_CHK_SET_ERR( rval, "Failed to filter on pstatus" );
        // get shared owned verts, for exchanging tags
        rval = myPcomm->filter_pstatus( owned_verts, PSTATUS_SHARED, PSTATUS_AND, -1, &shared_owned_verts );MB_CHK_SET_ERR( rval, "Failed to filter for shared owned" );
        // workaround: if no shared owned verts, put a non-shared one in the list, to prevent
        // exchanging tags for all shared entities
        if( shared_owned_verts.empty() ) shared_owned_verts.insert( *verts.begin() );
    else
        owned_verts = verts;
#else
#endif
    std::vector< unsigned char > fix_tag( owned_verts.size() );
    rval = mbImpl->tag_get_data( fixedTag, owned_verts, &fix_tag[0] );MB_CHK_SET_ERR( rval, "Failed to get fixed tag" );
    // now fill vcentroids array with positions of just owned vertices, since those are the ones
    // we're actually computing
    vcentroids.resize( 3 * owned_verts.size() );
    rval = mbImpl->tag_get_data( centroid, owned_verts, &vcentroids[0] );MB_CHK_SET_ERR( rval, "Failed to get centroid tag" );
    // some declarations for later iterations
    std::vector< double > fcentroids( 3 * myElems.size() );  // fcentroids for element centroids
    std::vector< double > ctag(
        3 * CN::MAX_NODES_PER_ELEMENT );  // temporary coordinate storage for verts bounding an element
    const EntityHandle* conn;             // const ptr & size to elem connectivity
    int nconn;
    Range::iterator eit, vit;               // for iterating over elems, verts
    int e, v;                               // for indexing into centroid vectors
    std::vector< EntityHandle > adj_elems;  // used in vertex iteration
    // 2. while !converged
    double resid = DBL_MAX;
    numIts       = 0;
    while( resid > absTol )
        numIts++;
        resid = 0.0;
        // 2a. foreach elem: centroid = sum(vertex centroids)/num_verts_in_cell
        for( eit = myElems.begin(), e = 0; eit != myElems.end(); ++eit, e++ )
            // get verts for this elem
            rval = mbImpl->get_connectivity( *eit, conn, nconn );MB_CHK_SET_ERR( rval, "Failed to get connectivity" );
            // get centroid tags for those verts
            rval = mbImpl->tag_get_data( centroid, conn, nconn, &ctag[0] );MB_CHK_SET_ERR( rval, "Failed to get centroid" );
            fcentroids[3 * e + 0] = fcentroids[3 * e + 1] = fcentroids[3 * e + 2] = 0.0;
            for( v = 0; v < nconn; v++ )
                fcentroids[3 * e + 0] += ctag[3 * v + 0];
                fcentroids[3 * e + 1] += ctag[3 * v + 1];
                fcentroids[3 * e + 2] += ctag[3 * v + 2];
            for( v = 0; v < 3; v++ )
                fcentroids[3 * e + v] /= nconn;
        rval = mbImpl->tag_set_data( centroid, myElems, &fcentroids[0] );MB_CHK_SET_ERR( rval, "Failed to set elem centroid" );
        // 2b. foreach owned vertex:
        for( vit = owned_verts.begin(), v = 0; vit != owned_verts.end(); ++vit, v++ )
            // if !fixed
            if( fix_tag[v] ) continue;
            // vertex centroid = sum(cell centroids)/ncells
            adj_elems.clear();
            rval = mbImpl->get_adjacencies( &( *vit ), 1, dim, false, adj_elems );MB_CHK_SET_ERR( rval, "Failed getting adjs" );
            rval = mbImpl->tag_get_data( centroid, &adj_elems[0], adj_elems.size(), &fcentroids[0] );MB_CHK_SET_ERR( rval, "Failed to get elem centroid" );
            double vnew[] = { 0.0, 0.0, 0.0 };
            for( e = 0; e < (int)adj_elems.size(); e++ )
                vnew[0] += fcentroids[3 * e + 0];
                vnew[1] += fcentroids[3 * e + 1];
                vnew[2] += fcentroids[3 * e + 2];
            for( e = 0; e < 3; e++ )
                vnew[e] /= adj_elems.size();
            double delta = ( CartVect( vnew ) - CartVect( &vcentroids[3 * v] ) ).length();
            resid        = ( v ? std::max( resid, delta ) : delta );
                vcentroids[3 * v + e] = vnew[e];
        // set the centroid tag; having them only in vcentroids array isn't enough, as vertex
        // centroids are accessed randomly in loop over faces
        rval = mbImpl->tag_set_data( centroid, owned_verts, &vcentroids[0] );MB_CHK_SET_ERR( rval, "Failed to set vertex centroid" );
        // 2c. exchange tags on owned verts
            rval = myPcomm->exchange_tags( centroid, shared_owned_verts );MB_CHK_SET_ERR( rval, "Failed to exchange tags" );
#endif
        if( reportIts && !( numIts % reportIts ) )
            double global_max = resid;
            // global reduce for maximum delta, then report it
                MPI_Reduce( &resid, &global_max, 1, MPI_DOUBLE, MPI_MAX, 0, myPcomm->comm() );
            if( !myPcomm || !myPcomm->rank() )
#endif
                std::cout << "Max residual = " << global_max << std::endl;
    }  // end while
    // write the tag back onto vertex coordinates
    if( !coordsTag )
        rval = mbImpl->set_coords( owned_verts, &vcentroids[0] );MB_CHK_SET_ERR( rval, "Failed to set vertex coords" );
    else
        rval = mbImpl->tag_set_data( coordsTag, owned_verts, &vcentroids[0] );MB_CHK_SET_ERR( rval, "Failed to set vert coords tag values" );
    return MB_SUCCESS;
double moab::LloydSmoother::rel_tol ( ) [inline]
Definition at line 141 of file LloydSmoother.hpp.
References relTol.
        return relTol;
void moab::LloydSmoother::rel_tol ( double  tol) [inline]
Definition at line 148 of file LloydSmoother.hpp.
References relTol.
        relTol = tol;
Definition at line 166 of file LloydSmoother.hpp.
References reportIts.
Referenced by main().
        return reportIts;
void moab::LloydSmoother::report_its ( int  num) [inline]
Definition at line 170 of file LloydSmoother.hpp.
        reportIts = num;
Member Data Documentation
double moab::LloydSmoother::absTol [private]
Definition at line 195 of file LloydSmoother.hpp.
Referenced by abs_tol(), and perform_smooth().
Definition at line 189 of file LloydSmoother.hpp.
Referenced by coords_tag(), and perform_smooth().
Definition at line 204 of file LloydSmoother.hpp.
Referenced by initialize(), and ~LloydSmoother().
Definition at line 186 of file LloydSmoother.hpp.
Referenced by elems(), initialize(), and perform_smooth().
Definition at line 183 of file LloydSmoother.hpp.
Referenced by initialize(), pcomm(), and perform_smooth().
Definition at line 201 of file LloydSmoother.hpp.
Referenced by num_its(), and perform_smooth().
double moab::LloydSmoother::relTol [private]
Referenced by perform_smooth(), and rel_tol().
Definition at line 198 of file LloydSmoother.hpp.
Referenced by perform_smooth(), and report_its().
List of all members.
