MOAB: Mesh Oriented datABase
(version 5.4.1)
Dummy EntitySequence for use in querying set container. More...
#include <TypeSequenceManager.hpp>
Inheritance diagram for moab::TypeSequenceManager::DummySequence:
Collaboration diagram for moab::TypeSequenceManager::DummySequence:Public Member Functions | |
| DummySequence (EntityHandle start) | |
| EntitySequence * | split (EntityHandle) |
| Split this sequence into two consecutive sequences. | |
| SequenceData * | create_data_subset (EntityHandle, EntityHandle) const |
| Create a new SequenceData that is a copy of a subset of the one referenced by this sequence. | |
| void | get_const_memory_use (unsigned long &a, unsigned long &b) const |
| Get memory characteristcs that are the same for all entities. | |
| unsigned long | get_per_entity_memory_use (EntityHandle, EntityHandle) const |
| Get portion of memory use that varies per entity. | |
Definition at line 40 of file TypeSequenceManager.hpp.
| moab::TypeSequenceManager::DummySequence::DummySequence | ( | EntityHandle | start | ) | [inline] |
Definition at line 43 of file TypeSequenceManager.hpp.
: EntitySequence( start ) {}
| SequenceData* moab::TypeSequenceManager::DummySequence::create_data_subset | ( | EntityHandle | start_handle, |
| EntityHandle | end_handle | ||
| ) | const [inline, virtual] |
Create a new SequenceData that is a copy of a subset of the SequenceData referenced by this EntitySequence. Do not make any changes to this EntitySequence or the current SequenceData.
Implements moab::EntitySequence.
Definition at line 49 of file TypeSequenceManager.hpp.
return 0;
| void moab::TypeSequenceManager::DummySequence::get_const_memory_use | ( | unsigned long & | bytes_per_entity, |
| unsigned long & | size_of_sequence | ||
Get charactersitic constant memory use for all entities in sequence.
| bytes_per_entity | The total bytes consumed for each entity in the underlying SequenceData. It is assumed that the same amount of memory is consumed for unused portions of the SequenceData. |
| size_of_sequence | The size of the leaf subclass of this class |
Definition at line 54 of file TypeSequenceManager.hpp.
a = b = 0;
| unsigned long moab::TypeSequenceManager::DummySequence::get_per_entity_memory_use | ( | EntityHandle | first, |
| EntityHandle | last | ||
Reimplemented from moab::EntitySequence.
Definition at line 58 of file TypeSequenceManager.hpp.
return 0;
| EntitySequence* moab::TypeSequenceManager::DummySequence::split | ( | EntityHandle | here | ) | [inline, virtual] |
Split this sequence into two sequences.
| here | New sequences should be [start_handle(),here) & [here,end_handle()] |
Definition at line 45 of file TypeSequenceManager.hpp.
return 0;
