moab::Skinner Class Reference
Class for constructing and querying skin of a mesh Class for constructing and querying skin of a mesh, defined as the outside lower-dimensional boundary of a mesh or a given set of entities. This class provides options for finding the forward- and reverse-oriented members of the skin. Several methods are available for computing the skin, e.g. using geometric topology sets, vertex-entity adjacencies, or directly from (n-1)-dimensional entities. More...
#include <Skinner.hpp>
+ Collaboration diagram for moab::Skinner:
Public Member Functions
 Skinner (Interface *mdb)
 constructor, takes mdb instance
 ~Skinner ()
 destructor
ErrorCode find_geometric_skin (const EntityHandle meshset, Range &forward_target_entities)
ErrorCode find_skin (const EntityHandle meshset, const Range &entities, bool get_vertices, Range &output_handles, Range *output_reverse_handles=0, bool create_vert_elem_adjs=false, bool create_skin_elements=true, bool look_for_scd=false)
 will accept entities all of one dimension and return entities of n-1 dimension; NOTE: get_vertices argument controls whether vertices or entities of n-1 dimension are returned, and only one of these is allowed (i.e. this function returns only vertices or (n-1)-dimensional entities, but not both)
ErrorCode find_skin (const EntityHandle this_set, const EntityHandle *entities, int num_entities, bool get_vertices, Range &output_handles, Range *output_reverse_handles=0, bool create_vert_elem_adjs=false, bool create_skin_elements=true, bool look_for_scd=false)
ErrorCode find_skin (const EntityHandle this_set, const Range &entities, int dim, Range &skin_entities, bool create_vert_elem_adjs=false, bool create_skin_elements=true)
 get skin entities of prescribed dimension
ErrorCode classify_2d_boundary (const Range &boundary, const Range &bar_elements, EntityHandle boundary_edges, EntityHandle inferred_edges, EntityHandle non_manifold_edges, EntityHandle other_edges, int &number_boundary_nodes)
ErrorCode classify_2d_boundary (const Range &boundary, const Range &mesh_1d_elements, Range &boundary_edges, Range &inferred_edges, Range &non_manifold_edges, Range &other_edges, int &number_boundary_nodes)
Protected Member Functions
ErrorCode initialize ()
ErrorCode deinitialize ()
ErrorCode find_skin_noadj (const Range &source_entities, Range &forward_target_entities, Range &reverse_target_entities)
ErrorCode add_adjacency (EntityHandle entity)
void add_adjacency (EntityHandle entity, const EntityHandle *conn, const int num_nodes)
ErrorCode remove_adjacency (EntityHandle entity)
bool entity_deletable (EntityHandle entity)
void find_match (EntityType type, const EntityHandle *conn, const int num_nodes, EntityHandle &match, Skinner::direction &direct)
bool connectivity_match (const EntityHandle *conn1, const EntityHandle *conn2, const int num_verts, Skinner::direction &direct)
void find_inferred_edges (Range &skin_boundary, Range &candidate_edges, Range &inferred_edges, double reference_angle_degrees)
bool has_larger_angle (EntityHandle &entity1, EntityHandle &entity2, double reference_angle_cosine)
ErrorCode find_skin_vertices (const EntityHandle this_set, const Range &entities, Range *skin_verts=0, Range *skin_elems=0, Range *rev_elems=0, bool create_if_missing=true, bool corners_only=false)
 Find vertices on the skin of a set of mesh entities.
ErrorCode find_skin_vertices_1D (Tag tag, const Range &edges, Range &skin_verts)
 Skin edges.
ErrorCode find_skin_vertices_2D (const EntityHandle this_set, Tag tag, const Range &faces, Range *skin_verts=0, Range *skin_edges=0, Range *reverse_edges=0, bool create_edges=false, bool corners_only=false)
 Skin faces.
ErrorCode find_skin_vertices_3D (const EntityHandle this_set, Tag tag, const Range &entities, Range *skin_verts=0, Range *skin_faces=0, Range *reverse_faces=0, bool create_faces=false, bool corners_only=false)
 Skin volume mesh.
ErrorCode create_side (const EntityHandle this_set, EntityHandle element, EntityType side_type, const EntityHandle *side_corners, EntityHandle &side_elem_handle_out)
bool edge_reversed (EntityHandle face, const EntityHandle edge_ends[2])
bool face_reversed (EntityHandle region, const EntityHandle *face_conn, EntityType face_type)
ErrorCode find_skin_scd (const Range &source_entities, bool get_vertices, Range &output_handles, bool create_skin_elements)
ErrorCode skin_box (ScdBox *box, bool get_vertices, Range &output_handles, bool create_skin_elements)
 skin a structured box, taking advantage of structured information
Protected Attributes
Interface * thisMB
 the MB instance that this works with
Tag mDeletableMBTag
Tag mAdjTag
int mTargetDim
Private Types
enum  direction { FORWARD = 1, REVERSE = -1 }
Detailed Description
Examples:
DeformMeshRemap.cpp, LaplacianSmoother.cpp, and LloydRelaxation.cpp.
Definition at line 36 of file Skinner.hpp.
Member Enumeration Documentation
enum moab::Skinner::direction [private]
Enumerator:
FORWARD
REVERSE
Definition at line 39 of file Skinner.hpp.
        FORWARD = 1,
        REVERSE = -1
moab::Skinner::Skinner ( Interface *  mdb) [inline]
Definition at line 55 of file Skinner.hpp.
: thisMB( mdb ), mDeletableMBTag( 0 ), mAdjTag( 0 ), mTargetDim( 0 ) {}
destructor
Definition at line 48 of file Skinner.cpp.
    // delete the adjacency tag
Member Function Documentation
Definition at line 129 of file Skinner.cpp.
References ErrorCode, moab::Interface::get_connectivity(), mAdjTag, MB_CHK_ERR, MB_SUCCESS, moab::Interface::tag_get_data(), moab::Interface::tag_set_data(), and thisMB.
Referenced by classify_2d_boundary(), find_skin_noadj(), and initialize().
    std::vector< EntityHandle >* adj = NULL;
    const EntityHandle* nodes;
    int num_nodes;
    ErrorCode result = thisMB->get_connectivity( entity, nodes, num_nodes, true );MB_CHK_ERR( result );
    const EntityHandle* iter = std::min_element( nodes, nodes + num_nodes );
    if( iter == nodes + num_nodes ) return MB_SUCCESS;
    // add this entity to the node
    if( thisMB->tag_get_data( mAdjTag, iter, 1, &adj ) == MB_SUCCESS && adj != NULL )
        adj->push_back( entity );
    // create a new vector and add it
    else
        adj = new std::vector< EntityHandle >;
        result = thisMB->tag_set_data( mAdjTag, iter, 1, &adj );MB_CHK_ERR( result );
    return MB_SUCCESS;
void moab::Skinner::add_adjacency ( EntityHandle  entity,
const EntityHandle *  conn,
const int  num_nodes
) [protected]
Definition at line 155 of file Skinner.cpp.
References mAdjTag, MB_SUCCESS, MBPOLYGON, moab::Interface::tag_get_data(), moab::Interface::tag_set_data(), thisMB, moab::TYPE_FROM_HANDLE(), and moab::CN::VerticesPerEntity().
    if( iter == nodes + num_nodes ) return;
    // should not be setting adjacency lists in ho-nodes
    assert( TYPE_FROM_HANDLE( entity ) == MBPOLYGON ||
            num_nodes == CN::VerticesPerEntity( TYPE_FROM_HANDLE( entity ) ) );
    else
ErrorCode moab::Skinner::classify_2d_boundary ( const Range &  boundary,
const Range &  bar_elements,
int &  number_boundary_nodes
Definition at line 659 of file Skinner.cpp.
References moab::Interface::add_entities(), moab::Interface::clear_meshset(), ErrorCode, MB_CHK_ERR, MB_SUCCESS, and thisMB.
    Range bedges, iedges, nmedges, oedges;
    ErrorCode result =
        classify_2d_boundary( boundary, bar_elements, bedges, iedges, nmedges, oedges, number_boundary_nodes );MB_CHK_ERR( result );
    // now set the input meshsets to the output ranges
    result = thisMB->clear_meshset( &boundary_edges, 1 );MB_CHK_ERR( result );
    result = thisMB->add_entities( boundary_edges, bedges );MB_CHK_ERR( result );
    result = thisMB->clear_meshset( &inferred_edges, 1 );MB_CHK_ERR( result );
    result = thisMB->add_entities( inferred_edges, iedges );MB_CHK_ERR( result );
    result = thisMB->clear_meshset( &non_manifold_edges, 1 );MB_CHK_ERR( result );
    result = thisMB->add_entities( non_manifold_edges, nmedges );MB_CHK_ERR( result );
    result = thisMB->clear_meshset( &other_edges, 1 );MB_CHK_ERR( result );
    result = thisMB->add_entities( other_edges, oedges );MB_CHK_ERR( result );
    return MB_SUCCESS;
const Range &  mesh_1d_elements,
Range &  boundary_edges,
Range &  inferred_edges,
Range &  non_manifold_edges,
Range &  other_edges,
given a skin of dimension 2, will classify and return edges as boundary, inferred, and non-manifold, and the rest (other)
Definition at line 687 of file Skinner.cpp.
References add_adjacency(), moab::Range::begin(), moab::Range::clear(), moab::Interface::create_element(), deinitialize(), moab::CN::Dimension(), moab::Range::empty(), moab::Range::end(), entity_deletable(), moab::Range::erase(), ErrorCode, moab::Range::find(), find_inferred_edges(), find_match(), moab::Interface::get_connectivity(), initialize(), moab::Range::insert(), moab::MAX_SUB_ENTITY_VERTICES, MB_CHK_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_INTEGER, MBEDGE, moab::CN::mConnectivityMap, mTargetDim, moab::CN::ConnMap::num_corners_per_sub_element, moab::CN::NumSubEntities(), moab::Range::size(), moab::CN::SubEntityNodeIndices(), moab::CN::SubEntityVertexIndices(), moab::Interface::tag_delete(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), thisMB, moab::Interface::type_from_handle(), and moab::CN::VerticesPerEntity().
    // clear out the edge lists
    boundary_edges.clear();
    inferred_edges.clear();
    non_manifold_edges.clear();
    other_edges.clear();
    number_boundary_nodes = 0;
    // make sure we have something to work with
    if( boundary.empty() )
        return MB_FAILURE;
    // get our working dimensions
    EntityType type      = thisMB->type_from_handle( *( boundary.begin() ) );
    const int source_dim = CN::Dimension( type );
    // make sure we can handle the working dimensions
    if( source_dim != 2 )
        return MB_FAILURE;
    mTargetDim = source_dim - 1;
    // initialize
    initialize();
    // additional initialization for this routine
    // define a tag for MBEDGE which counts the occurrences of the edge below
    // default should be 0 for existing edges, if any
    Tag count_tag;
    int default_count = 0;
    ErrorCode result =
        thisMB->tag_get_handle( 0, 1, MB_TYPE_INTEGER, count_tag, MB_TAG_DENSE | MB_TAG_CREAT, &default_count );MB_CHK_ERR( result );
    Range::const_iterator iter, end_iter;
    end_iter = boundary.end();
    std::vector< EntityHandle > conn;
    EntityHandle sub_conn[2];
    EntityHandle match;
    Range edge_list;
    Range boundary_nodes;
    Skinner::direction direct;
    EntityType sub_type;
    int num_edge, num_sub_ent_vert;
    const short* edge_verts;
    // now, process each entity in the boundary
    for( iter = boundary.begin(); iter != end_iter; ++iter )
        // get the connectivity of this entity
        conn.clear();
        result = thisMB->get_connectivity( &( *iter ), 1, conn, false );
        assert( MB_SUCCESS == result );
        // add node handles to boundary_node range
        std::copy( conn.begin(), conn.begin() + CN::VerticesPerEntity( type ), range_inserter( boundary_nodes ) );
        type = thisMB->type_from_handle( *iter );
        // get connectivity of each n-1 dimension entity (edge in this case)
        const struct CN::ConnMap* conn_map = &( CN::mConnectivityMap[type][0] );
        num_edge                           = CN::NumSubEntities( type, 1 );
        for( int i = 0; i < num_edge; i++ )
            edge_verts = CN::SubEntityVertexIndices( type, 1, i, sub_type, num_sub_ent_vert );
            assert( sub_type == MBEDGE && num_sub_ent_vert == 2 );
            sub_conn[0]       = conn[edge_verts[0]];
            sub_conn[1]       = conn[edge_verts[1]];
            int num_sub_nodes = conn_map->num_corners_per_sub_element[i];
            // see if we can match this connectivity with
            // an existing entity
            find_match( MBEDGE, sub_conn, num_sub_nodes, match, direct );
            // if there is no match, create a new entity
            if( match == 0 )
                EntityHandle tmphndl = 0;
                int indices[MAX_SUB_ENTITY_VERTICES];
                EntityType new_type;
                int num_new_nodes;
                CN::SubEntityNodeIndices( type, conn.size(), 1, i, new_type, num_new_nodes, indices );
                for( int j = 0; j < num_new_nodes; j++ )
                    sub_conn[j] = conn[indices[j]];
                result = thisMB->create_element( new_type, sub_conn, num_new_nodes, tmphndl );
                add_adjacency( tmphndl, sub_conn, num_sub_nodes );
                // target_entities.insert(tmphndl);
                edge_list.insert( tmphndl );
                int count;
                result = thisMB->tag_get_data( count_tag, &tmphndl, 1, &count );
                count++;
                result = thisMB->tag_set_data( count_tag, &tmphndl, 1, &count );
            else
                // We found a match, we must increment the count on the match
                int count;
                result = thisMB->tag_get_data( count_tag, &match, 1, &count );
                count++;
                result = thisMB->tag_set_data( count_tag, &match, 1, &count );
                // if the entity is not deletable, it was pre-existing in
                // the database.  We therefore may need to add it to the
                // edge_list.  Since it will not hurt the range, we add
                // whether it was added before or not
                if( !entity_deletable( match ) )
                    edge_list.insert( match );
    // Any bar elements in the model should be classified separately
    // If the element is in the skin edge_list, then it should be put in
    // the non-manifold edge list.  Edges not in the edge_list are stand-alone
    // bars, and we make them simply boundary elements
    if( !bar_elements.empty() )
        Range::iterator bar_iter;
        for( iter = bar_elements.begin(); iter != bar_elements.end(); ++iter )
            EntityHandle handle = *iter;
            bar_iter            = edge_list.find( handle );
            if( bar_iter != edge_list.end() )
                // it is in the list, erase it and put in non-manifold list
                edge_list.erase( bar_iter );
                non_manifold_edges.insert( handle );
            else
                // not in the edge list, make it a boundary edge
                boundary_edges.insert( handle );
    // now all edges should be classified.  Go through the edge_list,
    // and put all in the appropriate lists
    Range::iterator edge_iter, edge_end_iter;
    edge_end_iter = edge_list.end();
    int count;
    for( edge_iter = edge_list.begin(); edge_iter != edge_end_iter; ++edge_iter )
        // check the count_tag
        result = thisMB->tag_get_data( count_tag, &( *edge_iter ), 1, &count );
        if( count == 1 )
            boundary_edges.insert( *edge_iter );
        else if( count == 2 )
            other_edges.insert( *edge_iter );
        else
            non_manifold_edges.insert( *edge_iter );
    // find the inferred edges from the other_edge_list
    double min_angle_degrees = 20.0;
    find_inferred_edges( const_cast< Range& >( boundary ), other_edges, inferred_edges, min_angle_degrees );
    // we now want to remove the inferred_edges from the other_edges
    Range temp_range;
    std::set_difference( other_edges.begin(), other_edges.end(), inferred_edges.begin(), inferred_edges.end(),
                         range_inserter( temp_range ), std::less< EntityHandle >() );
    other_edges = temp_range;
    // get rid of count tag and deinitialize
    result = thisMB->tag_delete( count_tag );
    deinitialize();
    // set the node count
    number_boundary_nodes = boundary_nodes.size();
    return MB_SUCCESS;
bool moab::Skinner::connectivity_match ( const EntityHandle *  conn1,
const EntityHandle *  conn2,
Skinner::direction &  direct
) [protected]
Definition at line 582 of file Skinner.cpp.
References FORWARD, and REVERSE.
Referenced by find_match().
    const EntityHandle* iter = std::find( conn2, conn2 + num_verts, conn1[0] );
    if( iter == conn2 + num_verts ) return false;
    bool they_match = true;
    int i;
    unsigned int j = iter - conn2;
    // first compare forward
    for( i = 1; i < num_verts; ++i )
        if( conn1[i] != conn2[( j + i ) % num_verts] )
            they_match = false;
            break;
    if( they_match == true )
        // need to check for reversed edges here
        direct = ( num_verts == 2 && j ) ? REVERSE : FORWARD;
        return true;
    they_match = true;
    // then compare reverse
    j += num_verts;
    for( i = 1; i < num_verts; )
        if( conn1[i] != conn2[( j - i ) % num_verts] )
            they_match = false;
            break;
        ++i;
    if( they_match )
        direct = REVERSE;
    return they_match;
ErrorCode moab::Skinner::create_side ( const EntityHandle  this_set,
const EntityHandle *  side_corners,
EntityHandle &  side_elem_handle_out
) [protected]
Definition at line 1432 of file Skinner.cpp.
References moab::CN::Dimension(), ErrorCode, MB_CHK_ERR, MB_SUCCESS, MBEDGE, MBPOLYGON, moab::CN::SideNumber(), moab::CN::SubEntityNodeIndices(), moab::TYPE_FROM_HANDLE(), and moab::CN::VerticesPerEntity().
    const int max_side = 9;
    const EntityHandle* conn;
    int len, side_len, side, sense, offset, indices[max_side];
    ErrorCode rval;
    EntityType type   = TYPE_FROM_HANDLE( elem ), tmp_type;
    const int ncorner = CN::VerticesPerEntity( side_type );
    const int d       = CN::Dimension( side_type );
    std::vector< EntityHandle > storage;
    // Get the connectivity of the parent element
    rval = thisMB->get_connectivity( elem, conn, len, false, &storage );
    if( MB_SUCCESS != rval ) return rval;
    // treat separately MBPOLYGON; we want to create the edge in the
    // forward sense always ; so figure out the sense first, then get out
    if( MBPOLYGON == type && 1 == d && MBEDGE == side_type )
        // first find the first vertex in the conn list
        int i = 0;
        for( i = 0; i < len; i++ )
            if( conn[i] == side_conn[0] ) break;
        if( len == i ) return MB_FAILURE;  // not found, big error
        // now, what if the polygon is padded?
        // the previous index is fine always. but the next one could be trouble :(
        int prevIndex = ( i + len - 1 ) % len;
        int nextIndex = ( i + 1 ) % len;
        // if the next index actually point to the same node, as current, it means it is padded
        if( conn[nextIndex] == conn[i] )
            // it really means we are at the end of proper nodes, the last nodes are repeated, so it
            // should be the first node
            nextIndex = 0;  // this is the first node!
        EntityHandle conn2[2] = { side_conn[0], side_conn[1] };
        if( conn[prevIndex] == side_conn[1] )
            // reverse, so the edge will be forward
            conn2[0] = side_conn[1];
            conn2[1] = side_conn[0];
        else if( conn[nextIndex] != side_conn[1] )
            return MB_FAILURE;  // it is not adjacent to the polygon
        rval = thisMB->create_element( MBEDGE, conn2, 2, side_elem );MB_CHK_ERR( rval );
        if( this_set )
            rval = thisMB->add_entities( this_set, &side_elem, 1 );MB_CHK_ERR( rval );
        return MB_SUCCESS;
    // Find which side we are creating and get indices of all nodes
    // (including higher-order, if any.)
    CN::SideNumber( type, conn, side_conn, ncorner, d, side, sense, offset );
    CN::SubEntityNodeIndices( type, len, d, side, tmp_type, side_len, indices );
    assert( side_len <= max_side );
    assert( side_type == tmp_type );
    // NOTE: re-create conn array even when no higher-order nodes
    //      because we want it to always be forward with respect
    //      to the side ordering.
    EntityHandle side_conn_full[max_side];
    for( int i = 0; i < side_len; ++i )
        side_conn_full[i] = conn[indices[i]];
    rval = thisMB->create_element( side_type, side_conn_full, side_len, side_elem );MB_CHK_ERR( rval );
    if( this_set )
    return MB_SUCCESS;
Definition at line 98 of file Skinner.cpp.
References entities, ErrorCode, moab::Interface::get_entities_by_type_and_tag(), mAdjTag, MB_CHK_ERR, MB_SUCCESS, MBMAXTYPE, MBVERTEX, mDeletableMBTag, moab::Range::size(), t, moab::Interface::tag_delete(), moab::Interface::tag_get_data(), and thisMB.
Referenced by classify_2d_boundary(), and find_skin_noadj().
    ErrorCode result;
    if( 0 != mDeletableMBTag )
        result          = thisMB->tag_delete( mDeletableMBTag );
        mDeletableMBTag = 0;MB_CHK_ERR( result );
    // remove the adjacency tag
    std::vector< std::vector< EntityHandle >* > adj_arr;
    std::vector< std::vector< EntityHandle >* >::iterator i;
    if( 0 != mAdjTag )
        for( EntityType t = MBVERTEX; t != MBMAXTYPE; ++t )
            Range entities;
            result = thisMB->get_entities_by_type_and_tag( 0, t, &mAdjTag, 0, 1, entities );MB_CHK_ERR( result );
            adj_arr.resize( entities.size() );
            result = thisMB->tag_get_data( mAdjTag, entities, &adj_arr[0] );MB_CHK_ERR( result );
            for( i = adj_arr.begin(); i != adj_arr.end(); ++i )
                delete *i;
        result  = thisMB->tag_delete( mAdjTag );
        mAdjTag = 0;MB_CHK_ERR( result );
    return MB_SUCCESS;
bool moab::Skinner::edge_reversed ( EntityHandle  face,
) [protected]
Definition at line 1515 of file Skinner.cpp.
References ErrorCode, and MB_SUCCESS.
    int len, idx;
    ErrorCode rval = thisMB->get_connectivity( face, conn, len, true );
        assert( false );
        return false;
    idx = std::find( conn, conn + len, edge_ends[0] ) - conn;
    if( idx == len )
        assert( false );
        return false;
    return ( edge_ends[1] == conn[( idx + len - 1 ) % len] );
bool moab::Skinner::entity_deletable ( EntityHandle  entity) [protected]
Definition at line 650 of file Skinner.cpp.
References ErrorCode, MB_SUCCESS, mDeletableMBTag, moab::Interface::tag_get_data(), and thisMB.
    unsigned char deletable = 0;
    ErrorCode result        = thisMB->tag_get_data( mDeletableMBTag, &entity, 1, &deletable );
    if( MB_SUCCESS == result && deletable == 1 ) return false;
    return true;
bool moab::Skinner::face_reversed ( EntityHandle  region,
const EntityHandle *  face_conn,
) [protected]
Definition at line 1537 of file Skinner.cpp.
References moab::CN::Dimension(), ErrorCode, MB_SUCCESS, moab::CN::SideNumber(), moab::TYPE_FROM_HANDLE(), and moab::CN::VerticesPerEntity().
    int len, side, sense, offset;
    ErrorCode rval = thisMB->get_connectivity( region, conn, len, true );
        assert( false );
        return false;
    short r = CN::SideNumber( TYPE_FROM_HANDLE( region ), conn, face_corners, CN::VerticesPerEntity( face_type ),
                              CN::Dimension( face_type ), side, sense, offset );
    assert( 0 == r );
    return ( !r && sense == -1 );
ErrorCode moab::Skinner::find_geometric_skin ( const EntityHandle  meshset,
Range &  forward_target_entities
Definition at line 180 of file Skinner.cpp.
References moab::Range::begin(), moab::debug, moab::Range::empty(), moab::Range::end(), ErrorCode, GEOM_DIMENSION_TAG_NAME, geom_tag, moab::Interface::get_entities_by_handle(), moab::Interface::get_entities_by_type_and_tag(), moab::Range::insert(), MB_ENTITY_NOT_FOUND, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBENTITYSET, moab::Interface::num_parent_meshsets(), moab::Range::size(), moab::Interface::tag_get_handle(), and thisMB.
    // attempts to find whole model skin, using geom topo sets first then
    // normal find_skin function
    bool debug = true;
    // look for geom topo sets
    Tag geom_tag;
    ErrorCode result =
        thisMB->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, geom_tag, MB_TAG_SPARSE | MB_TAG_CREAT );
    if( MB_SUCCESS != result ) return result;
    // get face sets (dimension = 2)
    Range face_sets;
    int two             = 2;
    const void* two_ptr = &two;
    result = thisMB->get_entities_by_type_and_tag( meshset, MBENTITYSET, &geom_tag, &two_ptr, 1, face_sets );
    Range::iterator it;
        return result;
    else if( face_sets.empty() )
        return MB_ENTITY_NOT_FOUND;
    // ok, we have face sets; use those to determine skin
    Range skin_sets;
    if( debug ) std::cout << "Found " << face_sets.size() << " face sets total..." << std::endl;
    for( it = face_sets.begin(); it != face_sets.end(); ++it )
        int num_parents;
        result = thisMB->num_parent_meshsets( *it, &num_parents );
            return result;
        else if( num_parents == 1 )
            skin_sets.insert( *it );
    if( debug ) std::cout << "Found " << skin_sets.size() << " 1-parent face sets..." << std::endl;
    if( skin_sets.empty() ) return MB_FAILURE;
    // ok, we have the shell; gather up the elements, putting them all in forward for now
    for( it = skin_sets.begin(); it != skin_sets.end(); ++it )
        result = thisMB->get_entities_by_handle( *it, forward_target_entities, true );
    return result;
void moab::Skinner::find_inferred_edges ( Range &  skin_boundary,
Range &  candidate_edges,
) [protected]
Definition at line 900 of file Skinner.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, moab::Interface::get_adjacencies(), has_larger_angle(), moab::Range::insert(), MB_SUCCESS, MB_TAG_CREAT, MB_TYPE_BIT, SKINNER_PI, moab::Interface::tag_clear_data(), moab::Interface::tag_delete(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), and thisMB.
Referenced by classify_2d_boundary().
    // mark all the entities in the skin boundary
    Tag mark_tag;
    ErrorCode result = thisMB->tag_get_handle( 0, 1, MB_TYPE_BIT, mark_tag, MB_TAG_CREAT );
    unsigned char bit = true;
    result            = thisMB->tag_clear_data( mark_tag, skin_boundary, &bit );
    // find the cosine of the reference angle
    double reference_cosine = cos( reference_angle_degrees * SKINNER_PI / 180.0 );
    // check all candidate edges for an angle greater than the minimum
    Range::iterator iter, end_iter = candidate_edges.end();
    std::vector< EntityHandle > adjacencies;
    std::vector< EntityHandle >::iterator adj_iter;
    EntityHandle face[2];
    for( iter = candidate_edges.begin(); iter != end_iter; ++iter )
        // get the 2D elements connected to this edge
        adjacencies.clear();
        result = thisMB->get_adjacencies( &( *iter ), 1, 2, false, adjacencies );
        if( MB_SUCCESS != result ) continue;
        // there should be exactly two, that is why the edge is classified as nonBoundary
        // and manifold
        int faces_found = 0;
        for( adj_iter = adjacencies.begin(); adj_iter != adjacencies.end() && faces_found < 2; ++adj_iter )
            // we need to find two of these which are in the skin
            unsigned char is_marked = 0;
            result                  = thisMB->tag_get_data( mark_tag, &( *adj_iter ), 1, &is_marked );
            if( is_marked )
                face[faces_found] = *adj_iter;
                faces_found++;
        //    assert(faces_found == 2 || faces_found == 0);
        if( 2 != faces_found ) continue;
        // see if the two entities have a sufficient angle
        if( has_larger_angle( face[0], face[1], reference_cosine ) )
            inferred_edges.insert( *iter );
    result = thisMB->tag_delete( mark_tag );
void moab::Skinner::find_match ( EntityType  type,
EntityHandle &  match,
) [protected]
Definition at line 532 of file Skinner.cpp.
References connectivity_match(), ErrorCode, FORWARD, moab::Interface::get_connectivity(), mAdjTag, MB_SUCCESS, MBVERTEX, moab::Interface::tag_get_data(), thisMB, moab::Interface::type_from_handle(), and moab::CN::VerticesPerEntity().
    match = 0;
    if( type == MBVERTEX )
        match  = *conn;
        direct = FORWARD;
        return;
    const EntityHandle* iter = std::min_element( conn, conn + num_nodes );
    ErrorCode result = thisMB->tag_get_data( mAdjTag, iter, 1, &adj );
    if( result == MB_FAILURE || adj == NULL )
        return;
    std::vector< EntityHandle >::iterator jter, end_jter;
    end_jter = adj->end();
    const EntityHandle* tmp;
    int num_verts;
    for( jter = adj->begin(); jter != end_jter; ++jter )
        EntityType tmp_type;
        tmp_type = thisMB->type_from_handle( *jter );
        if( type != tmp_type ) continue;
        result = thisMB->get_connectivity( *jter, tmp, num_verts, false );
        assert( MB_SUCCESS == result && num_verts >= CN::VerticesPerEntity( type ) );
        // FIXME: connectivity_match appears to work only for linear elements,
        //        so ignore higher-order nodes.
        if( connectivity_match( conn, tmp, CN::VerticesPerEntity( type ), direct ) )
            match = *jter;
            break;
ErrorCode moab::Skinner::find_skin ( const EntityHandle  meshset,
const Range &  entities,
bool  get_vertices,
Range &  output_handles,
Range *  output_reverse_handles = 0,
bool  create_vert_elem_adjs = false,
bool  create_skin_elements = true,
bool  look_for_scd = false
Parameters:
entitiesThe elements for which to find the skin
get_verticesIf true, vertices on the skin are returned in the range, otherwise elements are returned
output_handlesRange holding skin entities returned
output_reverse_handlesRange holding entities on skin which are reversed wrt entities
create_vert_elem_adjsIf true, this function will cause vertex-element adjacencies to be generated
create_skin_elementsIf true, this function will cause creation of skin entities, otherwise only skin entities already extant will be returned
Definition at line 233 of file Skinner.cpp.
References moab::Core::a_entity_factory(), moab::AEntityFactory::create_vert_elem_adjacencies(), moab::Range::empty(), ErrorCode, find_skin_scd(), find_skin_vertices(), MB_SUCCESS, thisMB, and moab::AEntityFactory::vert_elem_adjacencies().
Referenced by add_dead_elems_to_impl_compl(), MetisPartitioner::assemble_taggedsets_graph(), moab::GeomTopoTool::check_model(), create_input_file(), moab::ParallelComm::create_interface_sets(), DeformMeshRemap::execute(), find_skin(), moab::GeomTopoTool::geometrize_surface_set(), get_imesh_mesh(), moab::LloydSmoother::initialize(), main(), mb_skin_adjacent_surf_patches(), mb_skin_curve_test_common(), mb_skin_full_common(), mb_skin_higher_order_faces_common(), mb_skin_higher_order_regions_common(), mb_skin_poly_test(), mb_skin_reversed_common(), mb_skin_scd_test(), mb_skin_subset_common(), mb_skin_surface_test_common(), mb_skin_verts_common(), mb_skin_volume_test_common(), moab::MergeMesh::merge_entities(), moab::MergeMesh::merge_higher_dimensions(), moab::ParallelMergeMesh::PopulateMySkinEnts(), print_output(), moab::ParallelComm::resolve_shared_ents(), tag_depth(), and moab::WriteCCMIO::write_cells_and_faces().
    if( source_entities.empty() ) return MB_SUCCESS;
    if( look_for_scd )
        ErrorCode rval = find_skin_scd( source_entities, get_vertices, output_handles, create_skin_elements );
        // if it returns success, it's all scd, and we don't need to do anything more
        if( MB_SUCCESS == rval ) return rval;
    Core* this_core = dynamic_cast< Core* >( thisMB );
    if( this_core && create_vert_elem_adjs && !this_core->a_entity_factory()->vert_elem_adjacencies() )
        this_core->a_entity_factory()->create_vert_elem_adjacencies();
    return find_skin_vertices( meshset, source_entities, get_vertices ? &output_handles : 0,
                               get_vertices ? 0 : &output_handles, output_reverse_handles, create_skin_elements );
ErrorCode moab::Skinner::find_skin ( const EntityHandle  this_set,
const EntityHandle *  entities,
int  num_entities,
bool  get_vertices,
) [inline]
Parameters:
entitiesPointer to elements for which to find the skin
num_entitiesNumber of entities in vector
Definition at line 286 of file Skinner.hpp.
References find_skin().
    Range ents;
    std::copy( entities, entities + num_entities, range_inserter( ents ) );
    return find_skin( this_set, ents, get_vertices, output_handles, output_reverse_handles, create_vert_elem_adjs,
                      create_skin_elements, look_for_scd );
int  dim,
Range &  skin_entities,
Parameters:
dimDimension of skin entities requested
skin_entitiesRange holding skin entities returned
Definition at line 985 of file Skinner.cpp.
References moab::Interface::add_entities(), moab::Range::all_of_dimension(), moab::Range::empty(), ErrorCode, find_skin(), moab::Interface::get_adjacencies(), MB_CHK_ERR, MB_SUCCESS, moab::Range::merge(), moab::Range::swap(), thisMB, and moab::Interface::UNION.
    Range tmp_skin;
    ErrorCode result =
        find_skin( this_set, entities, ( dim == 0 ), tmp_skin, 0, create_vert_elem_adjs, create_skin_elements );
    if( MB_SUCCESS != result || tmp_skin.empty() ) return result;
    if( tmp_skin.all_of_dimension( dim ) )
        if( skin_entities.empty() )
            skin_entities.swap( tmp_skin );
        else
            skin_entities.merge( tmp_skin );
    else
        result = thisMB->get_adjacencies( tmp_skin, dim, create_skin_elements, skin_entities, Interface::UNION );MB_CHK_ERR( result );
        if( this_set ) result = thisMB->add_entities( this_set, skin_entities );
    return result;
ErrorCode moab::Skinner::find_skin_noadj ( const Range &  source_entities,
Range &  forward_target_entities,
Range &  reverse_target_entities
) [protected]
use_adjs &&
use_adjs &&
Definition at line 386 of file Skinner.cpp.
References add_adjacency(), moab::Range::begin(), moab::Interface::create_element(), deinitialize(), moab::Interface::delete_entities(), moab::CN::Dimension(), moab::Range::empty(), moab::Range::end(), entity_deletable(), moab::Range::erase(), ErrorCode, moab::Range::find(), find_match(), FORWARD, moab::Interface::get_connectivity(), initialize(), moab::Range::insert(), moab::MAX_SUB_ENTITY_VERTICES, MB_SUCCESS, MBEDGE, MBPOLYGON, mTargetDim, moab::CN::NumSubEntities(), remove_adjacency(), moab::CN::SubEntityNodeIndices(), thisMB, moab::Interface::type_from_handle(), and moab::CN::VerticesPerEntity().
    if( source_entities.empty() ) return MB_FAILURE;
    EntityType type      = thisMB->type_from_handle( *( source_entities.begin() ) );
    if( mTargetDim < 0 || source_dim > 3 ) return MB_FAILURE;
    initialize();
    end_iter = source_entities.end();
    EntityHandle match;
    direction direct;
    ErrorCode result;
    // assume we'll never have more than 32 vertices on a facet (checked
    // with assert later)
    EntityHandle sub_conn[32];
    std::vector< EntityHandle > tmp_conn_vec;
    int num_nodes, num_sub_nodes, num_sides;
    int sub_indices[32];  // Also, assume that no polygon has more than 32 nodes
    // we could increase that, but we will not display it right in visit moab h5m , anyway
    // for each source entity
    for( iter = source_entities.begin(); iter != end_iter; ++iter )
        int actual_num_nodes_polygon = 0;
        result                       = thisMB->get_connectivity( *iter, conn, num_nodes, false, &tmp_conn_vec );
        Range::iterator seek_iter;
        // treat separately polygons (also, polyhedra will need special handling)
        if( MBPOLYGON == type )
            // treat padded polygons, if existing; count backwards, see how many of the last nodes
            // are repeated assume connectivity is fine, otherwise we could be in trouble
            actual_num_nodes_polygon = num_nodes;
            while( actual_num_nodes_polygon >= 3 &&
                   conn[actual_num_nodes_polygon - 1] == conn[actual_num_nodes_polygon - 2] )
                actual_num_nodes_polygon--;
            num_sides     = actual_num_nodes_polygon;
            sub_type      = MBEDGE;
            num_sub_nodes = 2;
        else  // get connectivity of each n-1 dimension entity
            num_sides = CN::NumSubEntities( type, mTargetDim );
        for( int i = 0; i < num_sides; i++ )
                sub_conn[0] = conn[i];
                sub_conn[1] = conn[i + 1];
                if( i + 1 == actual_num_nodes_polygon ) sub_conn[1] = conn[0];
            else
                CN::SubEntityNodeIndices( type, num_nodes, mTargetDim, i, sub_type, num_sub_nodes, sub_indices );
                assert( (size_t)num_sub_nodes <= sizeof( sub_indices ) / sizeof( sub_indices[0] ) );
                for( int j = 0; j < num_sub_nodes; j++ )
                    sub_conn[j] = conn[sub_indices[j]];
            find_match( sub_type, sub_conn, num_sub_nodes, match, direct );
            if( match == 0 )
                int num_new_nodes;
                    new_type      = MBEDGE;
                    num_new_nodes = 2;
                else
                    CN::SubEntityNodeIndices( type, num_nodes, mTargetDim, i, new_type, num_new_nodes, indices );
                add_adjacency( tmphndl, sub_conn, CN::VerticesPerEntity( new_type ) );
                forward_target_entities.insert( tmphndl );
            // if there is a match, delete the matching entity
            // if we can.
            else
                if( ( seek_iter = forward_target_entities.find( match ) ) != forward_target_entities.end() )
                    forward_target_entities.erase( seek_iter );
                    remove_adjacency( match );
                    if( /*!use_adjs &&*/ entity_deletable( match ) )
                        result = thisMB->delete_entities( &match, 1 );
                else if( ( seek_iter = reverse_target_entities.find( match ) ) != reverse_target_entities.end() )
                    reverse_target_entities.erase( seek_iter );
                else
                    if( direct == FORWARD )
                        forward_target_entities.insert( match );
                    else
                        reverse_target_entities.insert( match );
    deinitialize();
    return MB_SUCCESS;
ErrorCode moab::Skinner::find_skin_scd ( const Range &  source_entities,
bool  get_vertices,
) [protected]
look for structured box comprising source_entities, and if one is found use structured information to find the skin
Definition at line 259 of file Skinner.cpp.
References moab::Range::contains(), ErrorCode, moab::ScdInterface::find_boxes(), MB_SUCCESS, moab::Range::merge(), moab::Interface::query_interface(), moab::Range::size(), skin_box(), and thisMB.
Referenced by find_skin().
    // get the scd interface and check if it's been initialized
    ScdInterface* scdi = NULL;
    ErrorCode rval     = thisMB->query_interface( scdi );
    if( !scdi ) return MB_FAILURE;
    // ok, there's scd mesh; see if the entities passed in are all in a scd box
    // a box needs to be wholly included in entities for this to work
    std::vector< ScdBox* > boxes, myboxes;
    Range myrange;
    rval = scdi->find_boxes( boxes );
    for( std::vector< ScdBox* >::iterator bit = boxes.begin(); bit != boxes.end(); ++bit )
        Range belems( ( *bit )->start_element(), ( *bit )->start_element() + ( *bit )->num_elements() - 1 );
        if( source_entities.contains( belems ) )
            myboxes.push_back( *bit );
            myrange.merge( belems );
    if( myboxes.empty() || myrange.size() != source_entities.size() ) return MB_FAILURE;
    // ok, we're all structured; get the skin for each box
        rval = skin_box( *bit, get_vertices, output_handles, create_skin_elements );
    return MB_SUCCESS;
ErrorCode moab::Skinner::find_skin_vertices ( const EntityHandle  this_set,
Range *  skin_verts = 0,
Range *  skin_elems = 0,
Range *  rev_elems = 0,
bool  create_if_missing = true,
bool  corners_only = false
) [protected]
Parameters:
entitiesThe elements for which to find the skin. Range may NOT contain vertices, polyhedra, or entity sets. All elements in range must be of the same dimension.
skin_vertsOutput: the vertices on the skin.
skin_elemsOptional output: elements representing sides of entities that are on the skin
create_if_missingIf skin_elemts is non-null and this is true, create new elements representing the sides of entities on the skin. If this is false, skin_elems will contain only those skin elements that already exist.
Definition at line 1013 of file Skinner.cpp.
References moab::Range::all_of_dimension(), dim, moab::CN::Dimension(), moab::Range::empty(), ErrorCode, find_skin_vertices_1D(), find_skin_vertices_2D(), find_skin_vertices_3D(), moab::Range::front(), moab::Interface::get_number_entities_by_dimension(), MB_SUCCESS, MB_TAG_CREAT, MB_TYPE_BIT, MB_TYPE_OUT_OF_RANGE, moab::Range::size(), moab::Interface::tag_delete(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), thisMB, and moab::TYPE_FROM_HANDLE().
    ErrorCode rval;
    if( entities.empty() ) return MB_SUCCESS;
    const int dim = CN::Dimension( TYPE_FROM_HANDLE( entities.front() ) );
    if( dim < 1 || dim > 3 || !entities.all_of_dimension( dim ) ) return MB_TYPE_OUT_OF_RANGE;
    // are we skinning all entities
    size_t count = entities.size();
    int num_total;
    rval = thisMB->get_number_entities_by_dimension( this_set, dim, num_total );
    bool all = ( count == (size_t)num_total );
    // Create a bit tag for fast intersection with input entities range.
    // If we're skinning all the entities in the mesh, we really don't
    // need the tag.  To save memory, just create it with a default value
    // of one and don't set it.  That way MOAB will return 1 for all
    // entities.
    Tag tag;
    char bit = all ? 1 : 0;
    rval     = thisMB->tag_get_handle( NULL, 1, MB_TYPE_BIT, tag, MB_TAG_CREAT, &bit );
    // tag all entities in input range
    if( !all )
        std::vector< unsigned char > vect( count, 1 );
        rval = thisMB->tag_set_data( tag, entities, &vect[0] );
            thisMB->tag_delete( tag );
            return rval;
    switch( dim )
        case 1:
            if( skin_verts )
                rval = find_skin_vertices_1D( tag, entities, *skin_verts );
            else if( skin_elems )
                rval = find_skin_vertices_1D( tag, entities, *skin_elems );
            else
                rval = MB_SUCCESS;
            break;
        case 2:
            rval = find_skin_vertices_2D( this_set, tag, entities, skin_verts, skin_elems, skin_rev_elems,
                                          create_skin_elems, corners_only );
            break;
        case 3:
            rval = find_skin_vertices_3D( this_set, tag, entities, skin_verts, skin_elems, skin_rev_elems,
            break;
        default:
            rval = MB_TYPE_OUT_OF_RANGE;
            break;
    return rval;
ErrorCode moab::Skinner::find_skin_vertices_1D ( Tag  tag,
const Range &  edges,
Range &  skin_verts
) [protected]
Skin edges.
Return any vertices adjacent to exactly one of the input edges.
Definition at line 1083 of file Skinner.cpp.
References moab::Range::all_of_dimension(), moab::Range::begin(), moab::Range::end(), ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_connectivity(), moab::Range::insert(), MB_SUCCESS, MB_TYPE_OUT_OF_RANGE, moab::Interface::tag_get_data(), and thisMB.
Referenced by find_skin_vertices().
    // This rather simple algorithm is provided for completeness
    // (not sure how often one really wants the 'skin' of a chain
    // or tangle of edges.)
    // A vertex is on the skin of the edges if it is contained in exactly
    // one of the edges *in the input range*.
    // This function expects the caller to have tagged all edges in the
    // input range with a value of one for the passed bit tag, and all
    // other edges with a value of zero.  This allows us to do a faster
    // intersection with the input range and the edges adjacent to a vertex.
    ErrorCode rval;
    Range::iterator hint = skin_verts.begin();
    // All input entities must be edges.
    if( !edges.all_of_dimension( 1 ) ) return MB_TYPE_OUT_OF_RANGE;
    // get all the vertices
    Range verts;
    rval = thisMB->get_connectivity( edges, verts, true );
    // Test how many edges each input vertex is adjacent to.
    std::vector< char > tag_vals;
    std::vector< EntityHandle > adj;
    int n;
    for( Range::const_iterator it = verts.begin(); it != verts.end(); ++it )
        // get edges adjacent to vertex
        adj.clear();
        rval = thisMB->get_adjacencies( &*it, 1, 1, false, adj );
        if( adj.empty() ) continue;
        // Intersect adjacent edges with the input list of edges
        tag_vals.resize( adj.size() );
        rval = thisMB->tag_get_data( tag, &adj[0], adj.size(), &tag_vals[0] );
#ifdef MOAB_OLD_STD_COUNT
        n = 0;
        std::count( tag_vals.begin(), tag_vals.end(), '\001' );
#else
        n = std::count( tag_vals.begin(), tag_vals.end(), '\001' );
#endif
        // If adjacent to only one input edge, then vertex is on skin
        if( n == 1 )
            hint = skin_verts.insert( hint, *it );
    return MB_SUCCESS;
ErrorCode moab::Skinner::find_skin_vertices_2D ( const EntityHandle  this_set,
Tag  tag,
const Range &  faces,
Range *  skin_edges = 0,
Range *  reverse_edges = 0,
bool  create_edges = false,
) [protected]
Skin faces.
For the set of face sides (logical edges), return vertices on such sides and/or edges equivalent to such sides.
Parameters:
facesSet of toplogically 2D entities to skin.
skin_vertsIf non-NULL, skin vertices will be added to this container.
skin_edgesIf non-NULL, skin edges will be added to this container
reverse_edgesIf skin_edges is not NULL and this is not NULL, then any existing skin edges that are reversed with respect to the skin side will be placed in this range instead of skin_edges. Note: this argument is ignored if skin_edges is NULL.
create_edgesIf true, edges equivalent to face sides on the skin that don't already exist will be created. Note: this parameter is honored regardless of whether or not skin edges or vertices are returned.
corners_onlyIf true, only skin vertices that correspond to the corners of sides will be returned (i.e. no higher-order nodes.) This argument is ignored if skin_verts is NULL.
Definition at line 1553 of file Skinner.cpp.
References moab::Range::all_of_dimension(), moab::Range::begin(), moab::AdjSides< CORNERS >::begin(), moab::AdjSides< CORNERS >::clear(), moab::Range::end(), moab::AdjSides< CORNERS >::end(), ErrorCode, moab::AdjSides< CORNERS >::find_and_unmark(), moab::CN::HasMidEdgeNodes(), moab::CN::HONodeIndex(), moab::ID_FROM_HANDLE(), moab::Range::insert(), moab::AdjSides< CORNERS >::insert(), MB_SUCCESS, MB_TYPE_OUT_OF_RANGE, MBEDGE, MBQUAD, MBTRI, moab::AdjSides< CORNERS >::num_skin(), moab::CN::SideNumber(), and moab::TYPE_FROM_HANDLE().
    // This function iterates over all the vertices contained in the
    // input face list.  For each such vertex, it then iterates over
    // all of the sides of the face elements adjacent to the vertex.
    // If an adjacent side is the side of only one of the input
    // faces, then that side is on the skin.
    // This algorithm will visit each skin vertex exactly once.  It
    // will visit each skin side once for each vertex in the side.
    // This function expects the caller to have created the passed bit
    // tag and set it to one only for the faces in the passed range.  This
    // tag is used to do a fast intersection of the faces adjacent to a
    // vertex with the faces in the input range (discard any for which the
    // tag is not set to one.)
    ErrorCode rval;
    std::vector< EntityHandle >::iterator i, j;
    Range::iterator hint;
    if( skin_verts ) hint = skin_verts->begin();
    int len;
    bool find_edges                      = skin_edges || create_edges;
    bool printed_nonconformal_ho_warning = false;
    EntityHandle face;
    if( !faces.all_of_dimension( 2 ) ) return MB_TYPE_OUT_OF_RANGE;
    Range verts;
    rval = thisMB->get_connectivity( faces, verts, true );
    AdjSides< 2 > adj_edges;
        bool higher_order = false;
        // get all adjacent faces
        adj.clear();
        rval = thisMB->get_adjacencies( &*it, 1, 2, false, adj );
        // remove those not in the input list (intersect with input list)
        i = j = adj.begin();
        // remove non-tagged entries
        for( ; i != adj.end(); ++i )
            if( tag_vals[i - adj.begin()] ) *( j++ ) = *i;
        adj.erase( j, adj.end() );
        // For each adjacent face, check the edges adjacent to the current vertex
        adj_edges.clear();  // other vertex for adjacent edges
        for( i = adj.begin(); i != adj.end(); ++i )
            rval = thisMB->get_connectivity( *i, conn, len, false, &storage );
            // For a single face element adjacent to this vertex, there
            // will be exactly two sides (edges) adjacent to the vertex.
            // Find the other vertex for each of the two edges.
            EntityHandle prev, next;  // vertices of two adjacent edge-sides
            const int idx = std::find( conn, conn + len, *it ) - conn;
            assert( idx != len );
            if( TYPE_FROM_HANDLE( *i ) == MBTRI && len > 3 )
                len          = 3;
                higher_order = true;
                if( idx > 2 )
                {  // skip higher-order nodes for now
                    if( !printed_nonconformal_ho_warning )
                        printed_nonconformal_ho_warning = true;
                        std::cerr << "Non-conformal higher-order mesh detected in skinner: "
                                  << "vertex " << ID_FROM_HANDLE( *it ) << " is a corner in "
                                  << "some elements and a higher-order node in others" << std::endl;
                    continue;
            else if( TYPE_FROM_HANDLE( *i ) == MBQUAD && len > 4 )
                len          = 4;
                if( idx > 3 )
                    continue;
            // so it must be a MBPOLYGON
            const int prev_idx = ( idx + len - 1 ) % len;  // this should be fine, always, even for padded case
            prev               = conn[prev_idx];
            next               = conn[( idx + 1 ) % len];
            if( next == conn[idx] )  // it must be the padded case, so roll to the beginning
                next = conn[0];
            // Insert sides (edges) in our list of candidate skin sides
            adj_edges.insert( &prev, 1, *i, prev_idx );
            adj_edges.insert( &next, 1, *i, idx );
        // If vertex is not on skin, advance to next vertex.
        // adj_edges handled checking for duplicates on insertion.
        // If every candidate skin edge occurred more than once (was
        // not in fact on the skin), then we're done with this vertex.
        if( 0 == adj_edges.num_skin() ) continue;
        // If user requested Range of *vertices* on the skin...
        if( skin_verts )
            // Put skin vertex in output list
            hint = skin_verts->insert( hint, *it );
            // Add mid edge nodes to vertex list
            if( !corners_only && higher_order )
                for( AdjSides< 2 >::const_iterator p = adj_edges.begin(); p != adj_edges.end(); ++p )
                    if( p->skin() )
                        face            = p->adj_elem;
                        EntityType type = TYPE_FROM_HANDLE( face );
                        rval = thisMB->get_connectivity( face, conn, len, false );
                        if( !CN::HasMidEdgeNodes( type, len ) ) continue;
                        EntityHandle ec[2] = { *it, p->handles[0] };
                        int side, sense, offset;
                        CN::SideNumber( type, conn, ec, 2, 1, side, sense, offset );
                        offset = CN::HONodeIndex( type, len, 1, side );
                        assert( offset >= 0 && offset < len );
                        skin_verts->insert( conn[offset] );
        // If user requested Range of *edges* on the skin...
        if( find_edges )
            // Search list of existing adjacent edges for any that are on the skin
            adj.clear();
                rval = thisMB->get_connectivity( *i, conn, len, true );
                // bool equality expression within find_and_unmark call
                // will be evaluate to the index of *it in the conn array.
                // Note that the order of the terms in the if statement is important.
                // We want to unmark any existing skin edges even if we aren't
                // returning them.  Otherwise we'll end up creating duplicates
                // if create_edges is true and skin_edges is not.
                if( adj_edges.find_and_unmark( conn, ( conn[1] == *it ), face ) && skin_edges )
                    if( reversed_edges && edge_reversed( face, conn ) )
                        reversed_edges->insert( *i );
                    else
                        skin_edges->insert( *i );
        // If the user requested that we create new edges for sides
        // on the skin for which there is no existing edge, and there
        // are still skin sides for which no corresponding edge was found...
        if( create_edges && adj_edges.num_skin() )
            // Create any skin edges that don't exist
                if( p->skin() )
                    EntityHandle edge, ec[] = { *it, p->handles[0] };
                    rval = create_side( this_set, p->adj_elem, MBEDGE, ec, edge );
                    if( skin_edges ) skin_edges->insert( edge );
    }  // end for each vertex
    return MB_SUCCESS;
ErrorCode moab::Skinner::find_skin_vertices_3D ( const EntityHandle  this_set,
Tag  tag,
Range *  skin_faces = 0,
Range *  reverse_faces = 0,
bool  create_faces = false,
) [protected]
Skin volume mesh.
For the set of element sides (logical faces), return vertices on such sides and/or faces equivalent to such sides.
Parameters:
entitiesSet of toplogically 3D entities to skin.
skin_facesIf non-NULL, skin faces will be added to this container
reverse_facesIf skin_faces is not NULL and this is not NULL, then any existing skin faces that are reversed with respect to the skin side will be placed in this range instead of skin_faces. Note: this argument is ignored if skin_faces is NULL.
create_facesIf true, face equivalent to sides on the skin that don't already exist will be created. Note: this parameter is honored regardless of whether or not skin faces or vertices are returned.
Definition at line 1768 of file Skinner.cpp.
References moab::Range::all_of_dimension(), moab::Range::begin(), moab::AdjSides< CORNERS >::begin(), moab::AdjSides< CORNERS >::clear(), moab::Range::end(), moab::AdjSides< CORNERS >::end(), moab::Range::erase(), ErrorCode, moab::AdjSides< CORNERS >::find_and_unmark(), moab::CN::HasMidNodes(), moab::ID_FROM_HANDLE(), moab::Range::insert(), moab::AdjSides< CORNERS >::insert(), MB_SUCCESS, MB_TYPE_OUT_OF_RANGE, MBPOLYHEDRON, MBQUAD, MBTRI, MBVERTEX, moab::Range::merge(), moab::AdjSides< CORNERS >::num_skin(), moab::CN::NumSubEntities(), moab::CN::SideNumber(), moab::CN::SubEntityNodeIndices(), moab::CN::SubEntityVertexIndices(), t, moab::TYPE_FROM_HANDLE(), moab::Range::upper_bound(), and moab::CN::VerticesPerEntity().
    // input vol elem list.  For each such vertex, it then iterates over
    // all of the sides of the vol elements adjacent to the vertex.
    // elements, then that side is on the skin.
    // tag and set it to one only for the elements in the passed range.  This
    // tag is used to do a fast intersection of the elements adjacent to a
    // vertex with the elements in the input range (discard any for which the
    // For each vertex, iterate over each adjacent element.  Construct
    // lists of the sides of each adjacent element that contain the vertex.
    // A list of three-vertex sides is kept for all triangular faces,
    // included three-vertex faces of type MBPOLYGON.  Putting polygons
    // in the same list ensures that we find polyhedron and non-polyhedron
    // elements that are adjacent.
    // A list of four-vertex sides is kept for all quadrilateral faces,
    // including four-vertex faces of type MBPOLYGON.
    // Sides with more than four vertices must have an explicit MBPOLYGON
    // element representing them because MBPOLYHEDRON connectivity is a
    // list of faces rather than vertices.  So the third list (vertices>=5),
    // need contain only the handle of the face rather than the vertex handles.
    ErrorCode rval;
    std::vector< EntityHandle > storage, storage2;  // temp storage for conn lists
    const EntityHandle *conn, *conn2;
    int len, len2;
    bool find_faces = skin_faces || create_faces;
    int clen, side, sense, offset, indices[9];
    EntityType face_type;
    EntityHandle elem;
    if( !entities.all_of_dimension( 3 ) ) return MB_TYPE_OUT_OF_RANGE;
    Range verts;
    rval = thisMB->get_connectivity( entities, verts, true );
    // if there are polyhedra in the input list, need to make another
    // call to get vertices from faces
    if( !verts.all_of_dimension( 0 ) )
        Range::iterator it = verts.upper_bound( MBVERTEX );
        Range pfaces;
        pfaces.merge( it, verts.end() );
        verts.erase( it, verts.end() );
        rval = thisMB->get_connectivity( pfaces, verts, true );
        assert( verts.all_of_dimension( 0 ) );
    AdjSides< 4 > adj_quads;  // 4-node sides adjacent to a vertex
    AdjSides< 3 > adj_tris;   // 3-node sides adjacent to a vertex
    AdjSides< 2 > adj_poly;   // n-node sides (n>5) adjacent to vertex
                              // (must have an explicit polygon, so store
                              // polygon handle rather than vertices.)
        // get all adjacent elements
        adj.clear();
        rval = thisMB->get_adjacencies( &*it, 1, 3, false, adj );
        // remove those not tagged (intersect with input range)
        // Build lists of sides of 3D element adjacent to the current vertex
        adj_quads.clear();  // store three other vertices for each adjacent quad face
        adj_tris.clear();   // store two other vertices for each adjacent tri face
        adj_poly.clear();   // store handle of each adjacent polygonal face
        int idx;
            const EntityType type = TYPE_FROM_HANDLE( *i );
            // Special case for POLYHEDRA
            if( type == MBPOLYHEDRON )
                rval = thisMB->get_connectivity( *i, conn, len );
                for( int k = 0; k < len; ++k )
                    rval = thisMB->get_connectivity( conn[k], conn2, len2, true, &storage2 );
                    idx = std::find( conn2, conn2 + len2, *it ) - conn2;
                    if( idx == len2 )  // vertex not in this face
                        continue;
                    // Treat 3- and 4-vertex faces specially, so that
                    // if the mesh contains both elements and polyhedra,
                    // we don't miss one type adjacent to the other.
                    switch( len2 )
                        case 3:
                            adj_tris.insert( conn2, idx, *i, k );
                            break;
                        case 4:
                            adj_quads.insert( conn2, idx, *i, k );
                            break;
                        default:
                            adj_poly.insert( conn + k, 1, *i, k );
                            break;
            else
                if( len > CN::VerticesPerEntity( type ) )
                    if( idx >= CN::VerticesPerEntity( type ) )
                        continue;
                // For each side of the element...
                const int num_faces = CN::NumSubEntities( type, 2 );
                for( int f = 0; f < num_faces; ++f )
                    int num_vtx;
                    const short* face_indices = CN::SubEntityVertexIndices( type, 2, f, face_type, num_vtx );
                    const short face_idx = std::find( face_indices, face_indices + num_vtx, (short)idx ) - face_indices;
                    // skip sides that do not contain vertex from outer loop
                    if( face_idx == num_vtx ) continue;  // current vertex not in this face
                    assert( num_vtx <= 4 );  // polyhedra handled above
                    switch( face_type )
                        case MBTRI:
                            adj_tris.insert( conn, face_idx, *i, f, face_indices );
                            break;
                        case MBQUAD:
                            adj_quads.insert( conn, face_idx, *i, f, face_indices );
                            break;
                        default:
        }  // end for (adj[3])
        if( 0 == ( adj_tris.num_skin() + adj_quads.num_skin() + adj_poly.num_skin() ) ) continue;
        // If user requested that skin *vertices* be passed back...
        if( skin_verts )
            // Add mid-edge and mid-face nodes to vertex list
                for( AdjSides< 3 >::const_iterator t = adj_tris.begin(); t != adj_tris.end(); ++t )
                    if( t->skin() )
                        elem            = t->adj_elem;
                        EntityType type = TYPE_FROM_HANDLE( elem );
                        rval = thisMB->get_connectivity( elem, conn, len, false );
                        if( !CN::HasMidNodes( type, len ) ) continue;
                        EntityHandle ec[3] = { *it, t->handles[0], t->handles[1] };
                        CN::SideNumber( type, conn, ec, 3, 2, side, sense, offset );
                        CN::SubEntityNodeIndices( type, len, 2, side, face_type, clen, indices );
                        assert( MBTRI == face_type );
                        for( int k = 3; k < clen; ++k )
                            skin_verts->insert( conn[indices[k]] );
                for( AdjSides< 4 >::const_iterator q = adj_quads.begin(); q != adj_quads.end(); ++q )
                    if( q->skin() )
                        elem            = q->adj_elem;
                        EntityHandle ec[4] = { *it, q->handles[0], q->handles[1], q->handles[2] };
                        CN::SideNumber( type, conn, ec, 4, 2, side, sense, offset );
                        assert( MBQUAD == face_type );
                        for( int k = 4; k < clen; ++k )
        // If user requested that we pass back the list of 2D elements
        // representing the skin of the mesh...
        if( find_faces )
            // Search list of adjacent faces for any that are on the skin
            adj.clear();
                const int idx2 = std::find( conn, conn + len, *it ) - conn;
                if( idx2 >= len )
                    assert( printed_nonconformal_ho_warning );
                    continue;
                // Note that the order of the terms in the if statements below
                // is important.  We want to unmark any existing skin faces even
                // if we aren't returning them.  Otherwise we'll end up creating
                // duplicates if create_faces is true.
                if( 3 == len )
                    if( adj_tris.find_and_unmark( conn, idx2, elem ) && skin_faces )
                        if( reversed_faces && face_reversed( elem, conn, MBTRI ) )
                            reversed_faces->insert( *i );
                        else
                            skin_faces->insert( *i );
                else if( 4 == len )
                    if( adj_quads.find_and_unmark( conn, idx2, elem ) && skin_faces )
                        if( reversed_faces && face_reversed( elem, conn, MBQUAD ) )
                        else
                else
                    if( adj_poly.find_and_unmark( &*i, 1, elem ) && skin_faces ) skin_faces->insert( *i );
        // If user does not want use to create new faces representing
        // sides for which there is currently no explicit element,
        // skip the remaining code and advance the outer loop to the
        // next vertex.
        if( !create_faces ) continue;
        // Polyhedra always have explicitly defined faces, so
        // there is no way we could need to create such a face.
        assert( 0 == adj_poly.num_skin() );
        // Create any skin tris that don't exist
        if( adj_tris.num_skin() )
                if( t->skin() )
                    EntityHandle tri, c[3] = { *it, t->handles[0], t->handles[1] };
                    rval = create_side( this_set, t->adj_elem, MBTRI, c, tri );
                    if( skin_faces ) skin_faces->insert( tri );
        // Create any skin quads that don't exist
        if( adj_quads.num_skin() )
                if( q->skin() )
                    EntityHandle quad, c[4] = { *it, q->handles[0], q->handles[1], q->handles[2] };
                    rval = create_side( this_set, q->adj_elem, MBQUAD, c, quad );
                    if( skin_faces ) skin_faces->insert( quad );
    return MB_SUCCESS;
bool moab::Skinner::has_larger_angle ( EntityHandle &  entity1,
EntityHandle &  entity2,
) [protected]
Definition at line 965 of file Skinner.cpp.
References moab::Util::normal(), and thisMB.
Referenced by find_inferred_edges().
    // compare normals to get angle.  We assume that the surface quads
    // which we test here will be approximately planar
    double norm[2][3];
    Util::normal( thisMB, entity1, norm[0][0], norm[0][1], norm[0][2] );
    Util::normal( thisMB, entity2, norm[1][0], norm[1][1], norm[1][2] );
    double cosine = norm[0][0] * norm[1][0] + norm[0][1] * norm[1][1] + norm[0][2] * norm[1][2];
    if( cosine < reference_angle_cosine )
        return true;
    return false;
Definition at line 53 of file Skinner.cpp.
References add_adjacency(), moab::Range::begin(), moab::Range::end(), entities, ErrorCode, moab::Interface::get_entities_by_type(), mAdjTag, MB_CHK_ERR, MB_SUCCESS, MB_TAG_BIT, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_BIT, MB_TYPE_OPAQUE, MBVERTEX, mDeletableMBTag, mTargetDim, moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), thisMB, moab::TYPE_FROM_HANDLE(), and moab::CN::TypeDimensionMap.
    // go through and mark all the target dimension entities
    // that already exist as not deleteable
    // also get the connectivity tags for each type
    // also populate adjacency information
    EntityType type;
    DimensionPair target_ent_types = CN::TypeDimensionMap[mTargetDim];
    void* null_ptr = NULL;
    ErrorCode result = thisMB->tag_get_handle( "skinner adj", sizeof( void* ), MB_TYPE_OPAQUE, mAdjTag,
                                               MB_TAG_DENSE | MB_TAG_CREAT, &null_ptr );MB_CHK_ERR( result );
    if( mDeletableMBTag == 0 )
        result =
            thisMB->tag_get_handle( "skinner deletable", 1, MB_TYPE_BIT, mDeletableMBTag, MB_TAG_BIT | MB_TAG_CREAT );MB_CHK_ERR( result );
    Range entities;
    // go through each type at this dimension
    for( type = target_ent_types.first; type <= target_ent_types.second; ++type )
        // get the entities of this type in the MB
        thisMB->get_entities_by_type( 0, type, entities );
        // go through each entity of this type in the MB
        // and set its deletable tag to NO
        Range::iterator iter, end_iter;
        end_iter = entities.end();
        for( iter = entities.begin(); iter != end_iter; ++iter )
            unsigned char bit = 0x1;
            result            = thisMB->tag_set_data( mDeletableMBTag, &( *iter ), 1, &bit );
            // add adjacency information too
            if( TYPE_FROM_HANDLE( *iter ) != MBVERTEX ) add_adjacency( *iter );
    return MB_SUCCESS;
Definition at line 632 of file Skinner.cpp.
References ErrorCode, moab::Interface::get_connectivity(), mAdjTag, MB_CHK_ERR, MB_SUCCESS, moab::Interface::tag_get_data(), and thisMB.
Referenced by find_skin_noadj().
    std::vector< EntityHandle > nodes, *adj = NULL;
    ErrorCode result = thisMB->get_connectivity( &entity, 1, nodes );MB_CHK_ERR( result );
    std::vector< EntityHandle >::iterator iter = std::min_element( nodes.begin(), nodes.end() );
    if( iter == nodes.end() ) return MB_FAILURE;
    // remove this entity from the node
    if( thisMB->tag_get_data( mAdjTag, &( *iter ), 1, &adj ) == MB_SUCCESS && adj != NULL )
        iter = std::find( adj->begin(), adj->end(), entity );
        if( iter != adj->end() ) adj->erase( iter );
    return result;
ErrorCode moab::Skinner::skin_box ( ScdBox *  box,
bool  get_vertices,
) [protected]
Definition at line 296 of file Skinner.cpp.
References moab::ScdBox::box_max(), moab::ScdBox::box_min(), dim, ErrorCode, moab::ScdBox::get_adj_edge_or_face(), moab::Interface::get_adjacencies(), moab::HomCoord::i(), moab::Range::insert(), moab::HomCoord::j(), moab::HomCoord::k(), MB_SUCCESS, moab::Range::merge(), thisMB, and moab::Interface::UNION.
Referenced by find_skin_scd().
    HomCoord bmin = box->box_min(), bmax = box->box_max();
    // don't support 1d boxes
    if( bmin.j() == bmax.j() && bmin.k() == bmax.k() ) return MB_FAILURE;
    int dim = ( bmin.k() == bmax.k() ? 1 : 2 );
    ErrorCode rval;
    EntityHandle ent;
    // i=min
    for( int k = bmin.k(); k < bmax.k(); k++ )
        for( int j = bmin.j(); j < bmax.j(); j++ )
            ent  = 0;
            rval = box->get_adj_edge_or_face( dim, bmin.i(), j, k, 0, ent, create_skin_elements );
            if( ent ) output_handles.insert( ent );
    // i=max
            ent  = 0;
            rval = box->get_adj_edge_or_face( dim, bmax.i(), j, k, 0, ent, create_skin_elements );
    // j=min
        for( int i = bmin.i(); i < bmax.i(); i++ )
            ent  = 0;
            rval = box->get_adj_edge_or_face( dim, i, bmin.j(), k, 1, ent, create_skin_elements );
    // j=max
            ent  = 0;
            rval = box->get_adj_edge_or_face( dim, i, bmax.j(), k, 1, ent, create_skin_elements );
    // k=min
            ent  = 0;
            rval = box->get_adj_edge_or_face( dim, i, j, bmin.k(), 2, ent, create_skin_elements );
    // k=max
            ent  = 0;
            rval = box->get_adj_edge_or_face( dim, i, j, bmax.k(), 2, ent, create_skin_elements );
    if( get_vertices )
        Range verts;
        rval = thisMB->get_adjacencies( output_handles, 0, true, verts, Interface::UNION );
        output_handles.merge( verts );
    return MB_SUCCESS;
Member Data Documentation
Definition at line 50 of file Skinner.hpp.
Referenced by add_adjacency(), deinitialize(), find_match(), initialize(), and remove_adjacency().
Definition at line 49 of file Skinner.hpp.
Referenced by deinitialize(), entity_deletable(), and initialize().
int moab::Skinner::mTargetDim [protected]
Definition at line 51 of file Skinner.hpp.
List of all members.
