, including all inherited members.
| add_adjacency(EntityHandle entity) | moab::Skinner | [protected] |
| add_adjacency(EntityHandle entity, const EntityHandle *conn, const int num_nodes) | moab::Skinner | [protected] |
| classify_2d_boundary(const Range &boundary, const Range &bar_elements, EntityHandle boundary_edges, EntityHandle inferred_edges, EntityHandle non_manifold_edges, EntityHandle other_edges, int &number_boundary_nodes) | moab::Skinner | |
| classify_2d_boundary(const Range &boundary, const Range &mesh_1d_elements, Range &boundary_edges, Range &inferred_edges, Range &non_manifold_edges, Range &other_edges, int &number_boundary_nodes) | moab::Skinner | |
| connectivity_match(const EntityHandle *conn1, const EntityHandle *conn2, const int num_verts, Skinner::direction &direct) | moab::Skinner | [protected] |
| create_side(const EntityHandle this_set, EntityHandle element, EntityType side_type, const EntityHandle *side_corners, EntityHandle &side_elem_handle_out) | moab::Skinner | [protected] |
| deinitialize() | moab::Skinner | [protected] |
| direction enum name | moab::Skinner | [private] |
| edge_reversed(EntityHandle face, const EntityHandle edge_ends[2]) | moab::Skinner | [protected] |
| entity_deletable(EntityHandle entity) | moab::Skinner | [protected] |
| face_reversed(EntityHandle region, const EntityHandle *face_conn, EntityType face_type) | moab::Skinner | [protected] |
| find_geometric_skin(const EntityHandle meshset, Range &forward_target_entities) | moab::Skinner | |
| find_inferred_edges(Range &skin_boundary, Range &candidate_edges, Range &inferred_edges, double reference_angle_degrees) | moab::Skinner | [protected] |
| find_match(EntityType type, const EntityHandle *conn, const int num_nodes, EntityHandle &match, Skinner::direction &direct) | moab::Skinner | [protected] |
| find_skin(const EntityHandle meshset, const Range &entities, bool get_vertices, Range &output_handles, Range *output_reverse_handles=0, bool create_vert_elem_adjs=false, bool create_skin_elements=true, bool look_for_scd=false) | moab::Skinner | |
| find_skin(const EntityHandle this_set, const EntityHandle *entities, int num_entities, bool get_vertices, Range &output_handles, Range *output_reverse_handles=0, bool create_vert_elem_adjs=false, bool create_skin_elements=true, bool look_for_scd=false) | moab::Skinner | [inline] |
| find_skin(const EntityHandle this_set, const Range &entities, int dim, Range &skin_entities, bool create_vert_elem_adjs=false, bool create_skin_elements=true) | moab::Skinner | |
| find_skin_noadj(const Range &source_entities, Range &forward_target_entities, Range &reverse_target_entities) | moab::Skinner | [protected] |
| find_skin_scd(const Range &source_entities, bool get_vertices, Range &output_handles, bool create_skin_elements) | moab::Skinner | [protected] |
| find_skin_vertices(const EntityHandle this_set, const Range &entities, Range *skin_verts=0, Range *skin_elems=0, Range *rev_elems=0, bool create_if_missing=true, bool corners_only=false) | moab::Skinner | [protected] |
| find_skin_vertices_1D(Tag tag, const Range &edges, Range &skin_verts) | moab::Skinner | [protected] |
| find_skin_vertices_2D(const EntityHandle this_set, Tag tag, const Range &faces, Range *skin_verts=0, Range *skin_edges=0, Range *reverse_edges=0, bool create_edges=false, bool corners_only=false) | moab::Skinner | [protected] |
| find_skin_vertices_3D(const EntityHandle this_set, Tag tag, const Range &entities, Range *skin_verts=0, Range *skin_faces=0, Range *reverse_faces=0, bool create_faces=false, bool corners_only=false) | moab::Skinner | [protected] |
| FORWARD enum value | moab::Skinner | [private] |
| has_larger_angle(EntityHandle &entity1, EntityHandle &entity2, double reference_angle_cosine) | moab::Skinner | [protected] |
| mAdjTag | moab::Skinner | [protected] |
| mDeletableMBTag | moab::Skinner | [protected] |
| mTargetDim | moab::Skinner | [protected] |
| remove_adjacency(EntityHandle entity) | moab::Skinner | [protected] |
| REVERSE enum value | moab::Skinner | [private] |
| skin_box(ScdBox *box, bool get_vertices, Range &output_handles, bool create_skin_elements) | moab::Skinner | [protected] |
| Skinner(Interface *mdb) | moab::Skinner | [inline] |
| thisMB | moab::Skinner | [protected] |
| ~Skinner() | moab::Skinner | |
