MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 // Contributed by Lorenzo Alessio Botti (SpaFEDTe) 00017 // This implementation is mostly borrowed from the mbzoltan MOAB partitioning tool 00018 00019 #include <iostream> 00020 #include <cassert> 00021 #include <sstream> 00022 #include <map> 00023 #include <ctime> 00024 00025 #include "moab/MetisPartitioner.hpp" 00026 #include "moab/Interface.hpp" 00027 #include "Internals.hpp" 00028 #include "moab/Range.hpp" 00029 #include "moab/WriteUtilIface.hpp" 00030 #include "moab/MeshTopoUtil.hpp" 00031 #include "moab/Skinner.hpp" 00032 #include "MBTagConventions.hpp" 00033 #include "moab/CN.hpp" 00034 00035 using namespace moab; 00036 00037 const bool debug = false; 00038 00039 MetisPartitioner::MetisPartitioner( Interface* impl, const bool use_coords ) 00040 : PartitionerBase< idx_t >( impl, use_coords ) 00041 00042 { 00043 } 00044 00045 MetisPartitioner::~MetisPartitioner() {} 00046 00047 ErrorCode MetisPartitioner::partition_mesh( const idx_t nparts, 00048 const char* method, 00049 const int part_dim, 00050 const bool write_as_sets, 00051 const bool write_as_tags, 00052 const bool partition_tagged_sets, 00053 const bool partition_tagged_ents, 00054 const char* aggregating_tag, 00055 const bool print_time ) 00056 { 00057 #ifdef MOAB_HAVE_MPI 00058 // should only be called in serial 00059 if( mbpc->proc_config().proc_size() != 1 ) 00060 { 00061 std::cout << "MetisPartitioner::partition_mesh_and_geometry must be called in serial." << std::endl; 00062 return MB_FAILURE; 00063 } 00064 #endif 00065 00066 if( NULL != method && strcmp( method, "ML_RB" ) != 0 && strcmp( method, "ML_KWAY" ) != 0 ) 00067 { 00068 std::cout << "ERROR: Method must be " 00069 << "ML_RB or ML_KWAY" << std::endl; 00070 return MB_FAILURE; 00071 } 00072 00073 std::vector< double > pts; // x[0], y[0], z[0], ... from MOAB 00074 std::vector< idx_t > ids; // poidx_t ids from MOAB 00075 std::vector< idx_t > adjs, parts; 00076 std::vector< idx_t > length; 00077 Range elems; 00078 // Get a mesh from MOAB and diide it across processors. 00079 00080 clock_t t = clock(); 00081 00082 ErrorCode result; 00083 if( !partition_tagged_sets && !partition_tagged_ents ) 00084 { 00085 result = assemble_graph( part_dim, pts, ids, adjs, length, elems );MB_CHK_ERR( result ); 00086 } 00087 else if( partition_tagged_sets ) 00088 { 00089 result = assemble_taggedsets_graph( part_dim, pts, ids, adjs, length, elems, &( *aggregating_tag ) );MB_CHK_ERR( result ); 00090 } 00091 else if( partition_tagged_ents ) 00092 { 00093 result = assemble_taggedents_graph( part_dim, pts, ids, adjs, length, elems, &( *aggregating_tag ) );MB_CHK_ERR( result ); 00094 } 00095 else 00096 { 00097 MB_SET_ERR( MB_FAILURE, "Either partition tags or sets for Metis partitoner" ); 00098 } 00099 00100 if( print_time ) 00101 { 00102 std::cout << " time to assemble graph: " << ( clock() - t ) / (double)CLOCKS_PER_SEC << "s. \n"; 00103 t = clock(); 00104 } 00105 00106 std::cout << "Computing partition using " << method << " method for " << nparts << " processors..." << std::endl; 00107 00108 idx_t nelems = length.size() - 1; 00109 idx_t* assign_parts; 00110 assign_parts = (idx_t*)malloc( sizeof( idx_t ) * nelems ); 00111 idx_t nconstraidx_ts = 1; 00112 idx_t edgeCut = 0; 00113 idx_t nOfPartitions = static_cast< idx_t >( nparts ); 00114 idx_t metis_RESULT; 00115 00116 if( strcmp( method, "ML_KWAY" ) == 0 ) 00117 { 00118 idx_t options[METIS_NOPTIONS]; 00119 METIS_SetDefaultOptions( options ); 00120 options[METIS_OPTION_CONTIG] = 1; 00121 metis_RESULT = METIS_PartGraphKway( &nelems, &nconstraidx_ts, &length[0], &adjs[0], NULL, NULL, NULL, 00122 &nOfPartitions, NULL, NULL, options, &edgeCut, assign_parts ); 00123 } 00124 else if( strcmp( method, "ML_RB" ) == 0 ) 00125 { 00126 idx_t options[METIS_NOPTIONS]; 00127 METIS_SetDefaultOptions( options ); 00128 options[METIS_OPTION_OBJTYPE] = METIS_OBJTYPE_CUT; // CUT 00129 options[METIS_OPTION_IPTYPE] = METIS_IPTYPE_GROW; // GROW or RANDOM 00130 options[METIS_OPTION_CTYPE] = METIS_CTYPE_RM; // RM or SHEM 00131 options[METIS_OPTION_RTYPE] = METIS_RTYPE_FM; // FM 00132 options[METIS_OPTION_NCUTS] = 10; // Number of different partitionings to compute, then 00133 // chooses the best one, default = 1 00134 options[METIS_OPTION_NITER] = 10; // Number of refinements steps, default = 10 00135 options[METIS_OPTION_UFACTOR] = 30; // Imabalance, default = 1 00136 options[METIS_OPTION_DBGLVL] = METIS_DBG_INFO; 00137 metis_RESULT = METIS_PartGraphRecursive( &nelems, &nconstraidx_ts, &length[0], &adjs[0], NULL, NULL, NULL, 00138 &nOfPartitions, NULL, NULL, options, &edgeCut, assign_parts ); 00139 } 00140 else 00141 MB_SET_ERR( MB_FAILURE, "Either ML_KWAY or ML_RB needs to be specified for Metis partitioner" ); 00142 00143 if( print_time ) 00144 { 00145 std::cout << " time to partition: " << ( clock() - t ) / (double)CLOCKS_PER_SEC << "s. \n"; 00146 t = clock(); 00147 } 00148 00149 #ifdef MOAB_HAVE_MPI 00150 // assign global node ids, starting from one! TODO 00151 if( assign_global_ids ) 00152 { 00153 EntityHandle rootset = 0; 00154 result = mbpc->assign_global_ids( rootset, part_dim, 1, true, false );MB_CHK_ERR( result ); 00155 } 00156 #endif 00157 00158 if( metis_RESULT != METIS_OK ) return MB_FAILURE; 00159 00160 // take results & write onto MOAB partition sets 00161 std::cout << "Saving partition information to MOAB..." << std::endl; 00162 { 00163 if( partition_tagged_sets || partition_tagged_ents ) 00164 { 00165 result = write_aggregationtag_partition( nparts, elems, assign_parts, write_as_sets, write_as_tags );MB_CHK_ERR( result ); 00166 } 00167 else 00168 { 00169 result = write_partition( nparts, elems, assign_parts, write_as_sets, write_as_tags );MB_CHK_ERR( result ); 00170 } 00171 } 00172 00173 if( print_time ) 00174 { 00175 std::cout << " time to write partition in memory " << ( clock() - t ) / (double)CLOCKS_PER_SEC << "s. \n"; 00176 t = clock(); 00177 } 00178 free( assign_parts ); 00179 00180 return MB_SUCCESS; 00181 } 00182 00183 ErrorCode MetisPartitioner::assemble_taggedents_graph( const int dimension, 00184 std::vector< double >& coords, 00185 std::vector< idx_t >& moab_ids, 00186 std::vector< idx_t >& adjacencies, 00187 std::vector< idx_t >& length, 00188 Range& elems, 00189 const char* aggregating_tag ) 00190 { 00191 Tag partSetTag; 00192 ErrorCode result = mbImpl->tag_get_handle( aggregating_tag, 1, MB_TYPE_INTEGER, partSetTag ); 00193 if( MB_SUCCESS != result ) return result; 00194 00195 Range allSubElems; 00196 result = mbImpl->get_entities_by_dimension( 0, dimension, allSubElems ); 00197 if( MB_SUCCESS != result || allSubElems.empty() ) return result; 00198 idx_t partSet; 00199 std::map< idx_t, Range > aggloElems; 00200 for( Range::iterator rit = allSubElems.begin(); rit != allSubElems.end(); rit++ ) 00201 { 00202 EntityHandle entity = *rit; 00203 result = mbImpl->tag_get_data( partSetTag, &entity, 1, &partSet ); 00204 if( MB_SUCCESS != result ) return result; 00205 if( partSet >= 0 ) aggloElems[partSet].insert( entity ); 00206 } 00207 // clear aggregating tag data 00208 TagType type; 00209 result = mbImpl->tag_get_type( partSetTag, type ); 00210 if( type == MB_TAG_DENSE ) 00211 { 00212 // clear tag on ents and sets 00213 result = mbImpl->tag_delete( partSetTag ); 00214 if( MB_SUCCESS != result ) return result; 00215 } 00216 if( type == MB_TAG_SPARSE ) 00217 { 00218 // clear tag on ents 00219 result = mbImpl->tag_delete_data( partSetTag, allSubElems ); 00220 if( MB_SUCCESS != result ) return result; 00221 // clear tag on sets 00222 result = mbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET, &partSetTag, 0, 1, elems ); 00223 if( MB_SUCCESS != result ) return result; 00224 result = mbImpl->tag_delete_data( partSetTag, elems ); 00225 if( MB_SUCCESS != result ) return result; 00226 elems.clear(); 00227 } 00228 result = 00229 mbImpl->tag_get_handle( "PARALLEL_PARTITION", 1, MB_TYPE_INTEGER, partSetTag, MB_TAG_SPARSE | MB_TAG_CREAT ); 00230 if( MB_SUCCESS != result ) return result; 00231 00232 for( std::map< idx_t, Range >::iterator mit = aggloElems.begin(); mit != aggloElems.end(); mit++ ) 00233 { 00234 EntityHandle new_set; 00235 result = mbImpl->create_meshset( MESHSET_SET, new_set ); 00236 if( MB_SUCCESS != result ) return result; 00237 result = mbImpl->add_entities( new_set, mit->second ); 00238 if( MB_SUCCESS != result ) return result; 00239 result = mbImpl->tag_set_data( partSetTag, &new_set, 1, &mit->first ); 00240 if( MB_SUCCESS != result ) return result; 00241 } 00242 00243 result = 00244 assemble_taggedsets_graph( dimension, coords, moab_ids, adjacencies, length, elems, &( *aggregating_tag ) ); 00245 return MB_SUCCESS; 00246 } 00247 00248 ErrorCode MetisPartitioner::assemble_taggedsets_graph( const int dimension, 00249 std::vector< double >& coords, 00250 std::vector< idx_t >& moab_ids, 00251 std::vector< idx_t >& adjacencies, 00252 std::vector< idx_t >& length, 00253 Range& elems, 00254 const char* aggregating_tag ) 00255 { 00256 length.push_back( 0 ); 00257 // assemble a graph with vertices equal to elements of specified dimension, edges 00258 // signified by list of other elements to which an element is connected 00259 00260 // get the tagged elements 00261 Tag partSetTag; 00262 ErrorCode result = mbImpl->tag_get_handle( aggregating_tag, 1, MB_TYPE_INTEGER, partSetTag );MB_CHK_ERR( result ); 00263 // ErrorCode result = mbImpl->tag_get_handle("PARALLEL_PARTITION_SET", 1, MB_TYPE_INTEGER, 00264 // partSetTag);MB_CHK_ERR(result); 00265 00266 result = mbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET, &partSetTag, 0, 1, elems ); 00267 if( MB_SUCCESS != result || elems.empty() ) return result; 00268 00269 // assign globla ids to elem sets based on aggregating_tag data 00270 Tag gid_tag; 00271 idx_t zero1 = -1; 00272 result = 00273 mbImpl->tag_get_handle( "GLOBAL_ID_AGGLO", 1, MB_TYPE_INTEGER, gid_tag, MB_TAG_SPARSE | MB_TAG_CREAT, &zero1 );MB_CHK_ERR( result ); 00274 for( Range::iterator rit = elems.begin(); rit != elems.end(); rit++ ) 00275 { 00276 idx_t partSet; 00277 result = mbImpl->tag_get_data( partSetTag, &( *rit ), 1, &partSet );MB_CHK_ERR( result ); 00278 result = mbImpl->tag_set_data( gid_tag, &( *rit ), 1, &partSet );MB_CHK_ERR( result ); 00279 } 00280 // clear aggregating tag data 00281 TagType type; 00282 result = mbImpl->tag_get_type( partSetTag, type );MB_CHK_ERR( result ); 00283 if( type == MB_TAG_DENSE ) 00284 { 00285 result = mbImpl->tag_delete( partSetTag );MB_CHK_ERR( result ); 00286 } 00287 if( type == MB_TAG_SPARSE ) 00288 { 00289 result = mbImpl->tag_delete_data( partSetTag, elems );MB_CHK_ERR( result ); 00290 } 00291 00292 // assemble the graph, using Skinner to get d-1 dimensional neighbors and then idx_tersecting to 00293 // get adjacencies 00294 std::vector< Range > skin_subFaces( elems.size() ); 00295 unsigned int i = 0; 00296 for( Range::iterator rit = elems.begin(); rit != elems.end(); rit++ ) 00297 { 00298 Range part_ents; 00299 result = mbImpl->get_entities_by_handle( *rit, part_ents, false ); 00300 if( mbImpl->dimension_from_handle( *part_ents.rbegin() ) != 00301 mbImpl->dimension_from_handle( *part_ents.begin() ) ) 00302 { 00303 Range::iterator lower = part_ents.lower_bound( CN::TypeDimensionMap[0].first ), 00304 upper = part_ents.upper_bound( CN::TypeDimensionMap[dimension - 1].second ); 00305 part_ents.erase( lower, upper ); 00306 } 00307 Skinner skinner( mbImpl ); 00308 result = skinner.find_skin( 0, part_ents, false, skin_subFaces[i], NULL, false, true, false );MB_CHK_ERR( result ); 00309 i++; 00310 } 00311 std::vector< EntityHandle > adjs; 00312 std::vector< idx_t > neighbors; 00313 double avg_position[3]; 00314 idx_t moab_id; 00315 MeshTopoUtil mtu( mbImpl ); 00316 for( unsigned int k = 0; k < i; k++ ) 00317 { 00318 // get bridge adjacencies for element k 00319 adjs.clear(); 00320 for( unsigned int t = 0; t < i; t++ ) 00321 { 00322 if( t != k ) 00323 { 00324 Range subFaces = intersect( skin_subFaces[k], skin_subFaces[t] ); 00325 if( subFaces.size() > 0 ) adjs.push_back( elems[t] ); 00326 } 00327 } 00328 if( !adjs.empty() ) 00329 { 00330 neighbors.resize( adjs.size() ); 00331 result = mbImpl->tag_get_data( gid_tag, &adjs[0], adjs.size(), &neighbors[0] );MB_CHK_ERR( result ); 00332 } 00333 // copy those idx_to adjacencies vector 00334 length.push_back( length.back() + (idx_t)adjs.size() ); 00335 std::copy( neighbors.begin(), neighbors.end(), std::back_inserter( adjacencies ) ); 00336 // get the graph vertex id for this element 00337 const EntityHandle& setk = elems[k]; 00338 result = mbImpl->tag_get_data( gid_tag, &setk, 1, &moab_id ); 00339 moab_ids.push_back( moab_id ); 00340 // get average position of vertices 00341 Range part_ents; 00342 result = mbImpl->get_entities_by_handle( elems[k], part_ents, false );MB_CHK_ERR( result ); 00343 result = mtu.get_average_position( part_ents, avg_position );MB_CHK_ERR( result ); 00344 std::copy( avg_position, avg_position + 3, std::back_inserter( coords ) ); 00345 } 00346 for( unsigned int k = 0; k < i; k++ ) 00347 { 00348 for( unsigned int t = 0; t < k; t++ ) 00349 { 00350 Range subFaces = intersect( skin_subFaces[k], skin_subFaces[t] ); 00351 if( subFaces.size() > 0 ) mbImpl->delete_entities( subFaces ); 00352 } 00353 } 00354 00355 if( debug ) 00356 { 00357 std::cout << "Length vector: " << std::endl; 00358 std::copy( length.begin(), length.end(), std::ostream_iterator< idx_t >( std::cout, ", " ) ); 00359 std::cout << std::endl; 00360 std::cout << "Adjacencies vector: " << std::endl; 00361 std::copy( adjacencies.begin(), adjacencies.end(), std::ostream_iterator< idx_t >( std::cout, ", " ) ); 00362 std::cout << std::endl; 00363 std::cout << "Moab_ids vector: " << std::endl; 00364 std::copy( moab_ids.begin(), moab_ids.end(), std::ostream_iterator< idx_t >( std::cout, ", " ) ); 00365 std::cout << std::endl; 00366 std::cout << "Coords vector: " << std::endl; 00367 std::copy( coords.begin(), coords.end(), std::ostream_iterator< double >( std::cout, ", " ) ); 00368 std::cout << std::endl; 00369 } 00370 return MB_SUCCESS; 00371 } 00372 00373 ErrorCode MetisPartitioner::assemble_graph( const int dimension, 00374 std::vector< double >& coords, 00375 std::vector< idx_t >& moab_ids, 00376 std::vector< idx_t >& adjacencies, 00377 std::vector< idx_t >& length, 00378 Range& elems ) 00379 { 00380 length.push_back( 0 ); 00381 // assemble a graph with vertices equal to elements of specified dimension, edges 00382 // signified by list of other elements to which an element is connected 00383 00384 // get the elements of that dimension 00385 ErrorCode result = mbImpl->get_entities_by_dimension( 0, dimension, elems ); 00386 if( MB_SUCCESS != result || elems.empty() ) return result; 00387 00388 #ifdef MOAB_HAVE_MPI 00389 // assign global ids 00390 if( assign_global_ids ) 00391 { 00392 result = mbpc->assign_global_ids( 0, dimension, 0 );MB_CHK_ERR( result ); 00393 } 00394 #endif 00395 00396 // now assemble the graph, calling MeshTopoUtil to get bridge adjacencies through d-1 00397 // dimensional neighbors 00398 MeshTopoUtil mtu( mbImpl ); 00399 Range adjs; 00400 // can use a fixed-size array 'cuz the number of lower-dimensional neighbors is limited 00401 // by MBCN 00402 int neighbors[5 * MAX_SUB_ENTITIES]; // these will be now indices in the elems range 00403 00404 double avg_position[3]; 00405 int index_in_elems = 0; 00406 00407 for( Range::iterator rit = elems.begin(); rit != elems.end(); rit++, index_in_elems++ ) 00408 { 00409 00410 // get bridge adjacencies 00411 adjs.clear(); 00412 result = mtu.get_bridge_adjacencies( *rit, ( dimension > 0 ? dimension - 1 : 3 ), dimension, adjs );MB_CHK_ERR( result ); 00413 00414 // get the indices in elems range of those 00415 if( !adjs.empty() ) 00416 { 00417 int i = 0; 00418 assert( adjs.size() < 5 * MAX_SUB_ENTITIES ); 00419 for( Range::iterator ait = adjs.begin(); ait != adjs.end(); ait++, i++ ) 00420 { 00421 EntityHandle adjEnt = *ait; 00422 neighbors[i] = elems.index( adjEnt ); 00423 } 00424 } 00425 00426 // copy those idx_to adjacencies vector 00427 length.push_back( length.back() + (idx_t)adjs.size() ); 00428 // conversion made to idx_t 00429 std::copy( neighbors, neighbors + adjs.size(), std::back_inserter( adjacencies ) ); 00430 00431 // get average position of vertices 00432 result = mtu.get_average_position( *rit, avg_position );MB_CHK_ERR( result ); 00433 00434 // get the graph vertex id for this element; it is now index in elems 00435 moab_ids.push_back( index_in_elems ); // conversion made to idx_t 00436 00437 // copy_to coords vector 00438 std::copy( avg_position, avg_position + 3, std::back_inserter( coords ) ); 00439 } 00440 00441 if( debug ) 00442 { 00443 std::cout << "Length vector: " << std::endl; 00444 std::copy( length.begin(), length.end(), std::ostream_iterator< idx_t >( std::cout, ", " ) ); 00445 std::cout << std::endl; 00446 std::cout << "Adjacencies vector: " << std::endl; 00447 std::copy( adjacencies.begin(), adjacencies.end(), std::ostream_iterator< idx_t >( std::cout, ", " ) ); 00448 std::cout << std::endl; 00449 std::cout << "Moab_ids vector: " << std::endl; 00450 std::copy( moab_ids.begin(), moab_ids.end(), std::ostream_iterator< idx_t >( std::cout, ", " ) ); 00451 std::cout << std::endl; 00452 std::cout << "Coords vector: " << std::endl; 00453 std::copy( coords.begin(), coords.end(), std::ostream_iterator< double >( std::cout, ", " ) ); 00454 std::cout << std::endl; 00455 } 00456 00457 return MB_SUCCESS; 00458 } 00459 00460 ErrorCode MetisPartitioner::write_aggregationtag_partition( const idx_t nparts, 00461 Range& elems, 00462 const idx_t* assignment, 00463 const bool write_as_sets, 00464 const bool write_as_tags ) 00465 { 00466 ErrorCode result; 00467 00468 // get the partition set tag 00469 Tag part_set_tag; 00470 result = 00471 mbImpl->tag_get_handle( "PARALLEL_PARTITION", 1, MB_TYPE_INTEGER, part_set_tag, MB_TAG_SPARSE | MB_TAG_CREAT );MB_CHK_ERR( result ); 00472 00473 // get any sets already with this tag, and clear them 00474 Range tagged_sets; 00475 result = 00476 mbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET, &part_set_tag, NULL, 1, tagged_sets, Interface::UNION );MB_CHK_ERR( result ); 00477 if( !tagged_sets.empty() ) 00478 { 00479 result = mbImpl->clear_meshset( tagged_sets ); 00480 if( !write_as_sets ) 00481 { 00482 result = mbImpl->tag_delete_data( part_set_tag, tagged_sets );MB_CHK_ERR( result ); 00483 } 00484 } 00485 00486 if( write_as_sets ) 00487 { 00488 // first, create partition sets and store in vector 00489 partSets.clear(); 00490 00491 if( nparts > (idx_t)tagged_sets.size() ) 00492 { 00493 // too few partition sets - create missing ones 00494 idx_t num_new = nparts - tagged_sets.size(); 00495 for( idx_t i = 0; i < num_new; i++ ) 00496 { 00497 EntityHandle new_set; 00498 result = mbImpl->create_meshset( MESHSET_SET, new_set );MB_CHK_ERR( result ); 00499 tagged_sets.insert( new_set ); 00500 } 00501 } 00502 else if( nparts < (idx_t)tagged_sets.size() ) 00503 { 00504 // too many partition sets - delete extras 00505 idx_t num_del = tagged_sets.size() - nparts; 00506 for( idx_t i = 0; i < num_del; i++ ) 00507 { 00508 EntityHandle old_set = tagged_sets.pop_back(); 00509 result = mbImpl->delete_entities( &old_set, 1 );MB_CHK_ERR( result ); 00510 } 00511 } 00512 00513 // assign partition sets to vector 00514 partSets.swap( tagged_sets ); 00515 00516 // write a tag to those sets denoting they're partition sets, with a value of the 00517 // proc number 00518 idx_t* dum_ids = new idx_t[nparts]; 00519 for( idx_t i = 0; i < nparts; i++ ) 00520 dum_ids[i] = i; 00521 00522 result = mbImpl->tag_set_data( part_set_tag, partSets, dum_ids );MB_CHK_ERR( result ); 00523 00524 // assign entities to the relevant sets 00525 std::vector< EntityHandle > tmp_part_sets; 00526 std::copy( partSets.begin(), partSets.end(), std::back_inserter( tmp_part_sets ) ); 00527 Range::iterator rit; 00528 unsigned j = 0; 00529 for( rit = elems.begin(); rit != elems.end(); rit++, j++ ) 00530 { 00531 result = mbImpl->add_entities( tmp_part_sets[assignment[j]], &( *rit ), 1 );MB_CHK_ERR( result ); 00532 } 00533 00534 // check for empty sets, warn if there are any 00535 Range empty_sets; 00536 for( rit = partSets.begin(); rit != partSets.end(); rit++ ) 00537 { 00538 int num_ents = 0; 00539 result = mbImpl->get_number_entities_by_handle( *rit, num_ents ); 00540 if( MB_SUCCESS != result || !num_ents ) empty_sets.insert( *rit ); 00541 } 00542 if( !empty_sets.empty() ) 00543 { 00544 std::cout << "WARNING: " << empty_sets.size() << " empty sets in partition: "; 00545 for( rit = empty_sets.begin(); rit != empty_sets.end(); rit++ ) 00546 std::cout << *rit << " "; 00547 std::cout << std::endl; 00548 } 00549 } 00550 00551 if( write_as_tags ) 00552 { 00553 Tag gid_tag; 00554 result = mbImpl->tag_get_handle( "GLOBAL_ID_AGGLO", 1, MB_TYPE_INTEGER, gid_tag, MB_TAG_SPARSE );MB_CHK_ERR( result ); 00555 00556 // allocate idx_teger-size partitions 00557 unsigned int i = 0; 00558 idx_t gid; 00559 for( Range::iterator rit = elems.begin(); rit != elems.end(); rit++ ) 00560 { 00561 result = mbImpl->tag_get_data( gid_tag, &( *rit ), 1, &gid ); 00562 Range part_ents; 00563 // std::cout<<"part ents "<<part_ents.size()<<std::endl; 00564 result = mbImpl->get_entities_by_handle( *rit, part_ents, false );MB_CHK_ERR( result ); 00565 00566 for( Range::iterator eit = part_ents.begin(); eit != part_ents.end(); eit++ ) 00567 { 00568 result = mbImpl->tag_set_data( part_set_tag, &( *eit ), 1, &assignment[i] );MB_CHK_ERR( result ); 00569 00570 result = mbImpl->tag_set_data( gid_tag, &( *eit ), 1, &gid );MB_CHK_ERR( result ); 00571 } 00572 i++; 00573 } 00574 } 00575 return MB_SUCCESS; 00576 } 00577 00578 ErrorCode MetisPartitioner::write_partition( const idx_t nparts, 00579 Range& elems, 00580 const idx_t* assignment, 00581 const bool write_as_sets, 00582 const bool write_as_tags ) 00583 { 00584 ErrorCode result; 00585 00586 // get the partition set tag 00587 Tag part_set_tag; 00588 idx_t dum_id = -1, i; 00589 result = mbImpl->tag_get_handle( "PARALLEL_PARTITION", 1, MB_TYPE_INTEGER, part_set_tag, 00590 MB_TAG_SPARSE | MB_TAG_CREAT, &dum_id );MB_CHK_ERR( result ); 00591 00592 // get any sets already with this tag, and clear them 00593 Range tagged_sets; 00594 result = 00595 mbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET, &part_set_tag, NULL, 1, tagged_sets, Interface::UNION );MB_CHK_ERR( result ); 00596 if( !tagged_sets.empty() ) 00597 { 00598 result = mbImpl->clear_meshset( tagged_sets ); 00599 if( !write_as_sets ) 00600 { 00601 result = mbImpl->tag_delete_data( part_set_tag, tagged_sets );MB_CHK_ERR( result ); 00602 } 00603 } 00604 00605 if( write_as_sets ) 00606 { 00607 // first, create partition sets and store in vector 00608 partSets.clear(); 00609 00610 if( nparts > (int)tagged_sets.size() ) 00611 { 00612 // too few partition sets - create missing ones 00613 idx_t num_new = nparts - tagged_sets.size(); 00614 for( i = 0; i < num_new; i++ ) 00615 { 00616 EntityHandle new_set; 00617 result = mbImpl->create_meshset( MESHSET_SET, new_set );MB_CHK_ERR( result ); 00618 tagged_sets.insert( new_set ); 00619 } 00620 } 00621 else if( nparts < (idx_t)tagged_sets.size() ) 00622 { 00623 // too many partition sets - delete extras 00624 idx_t num_del = tagged_sets.size() - nparts; 00625 for( i = 0; i < num_del; i++ ) 00626 { 00627 EntityHandle old_set = tagged_sets.pop_back(); 00628 result = mbImpl->delete_entities( &old_set, 1 );MB_CHK_ERR( result ); 00629 } 00630 } 00631 00632 // assign partition sets to vector 00633 partSets.swap( tagged_sets ); 00634 00635 // write a tag to those sets denoting they're partition sets, with a value of the 00636 // proc number 00637 int* dum_ids = new int[nparts]; // this remains integer 00638 for( i = 0; i < nparts; i++ ) 00639 dum_ids[i] = i; 00640 00641 result = mbImpl->tag_set_data( part_set_tag, partSets, dum_ids ); 00642 delete[] dum_ids; 00643 00644 // assign entities to the relevant sets 00645 std::vector< EntityHandle > tmp_part_sets; 00646 std::copy( partSets.begin(), partSets.end(), std::back_inserter( tmp_part_sets ) ); 00647 Range::iterator rit; 00648 for( i = 0, rit = elems.begin(); rit != elems.end(); rit++, i++ ) 00649 { 00650 result = mbImpl->add_entities( tmp_part_sets[assignment[i]], &( *rit ), 1 );MB_CHK_ERR( result ); 00651 } 00652 00653 // check for empty sets, warn if there are any 00654 Range empty_sets; 00655 for( rit = partSets.begin(); rit != partSets.end(); rit++ ) 00656 { 00657 int num_ents = 0; 00658 result = mbImpl->get_number_entities_by_handle( *rit, num_ents ); 00659 if( MB_SUCCESS != result || !num_ents ) empty_sets.insert( *rit ); 00660 } 00661 if( !empty_sets.empty() ) 00662 { 00663 std::cout << "WARNING: " << empty_sets.size() << " empty sets in partition: "; 00664 for( rit = empty_sets.begin(); rit != empty_sets.end(); rit++ ) 00665 std::cout << *rit << " "; 00666 std::cout << std::endl; 00667 } 00668 } 00669 00670 if( write_as_tags ) 00671 { 00672 if( sizeof( int ) != sizeof( idx_t ) ) 00673 { 00674 // allocate idx_teger-size partitions 00675 // first we have to copy to int, then assign 00676 int* assg_int = new int[elems.size()]; 00677 for( int k = 0; k < (int)elems.size(); k++ ) 00678 assg_int[k] = assignment[k]; 00679 result = mbImpl->tag_set_data( part_set_tag, elems, assg_int );MB_CHK_ERR( result ); 00680 delete[] assg_int; 00681 } 00682 else 00683 result = mbImpl->tag_set_data( part_set_tag, elems, assignment );MB_CHK_ERR( result ); 00684 } 00685 00686 return MB_SUCCESS; 00687 }
