MOAB: Mesh Oriented datABase
(version 5.4.1)
Perform Lloyd relaxation on a mesh and its dual
To run: mpiexec -np <np> LloydRelaxation [filename]
Briefly, Lloyd relaxation is a technique to smooth out a mesh. The centroid of each cell is computed from its vertex positions, then vertices are placed at the average of their connected cells' centroids.
In the parallel algorithm, an extra ghost layer of cells is exchanged. This allows us to compute the centroids for boundary cells on each processor where they appear; this eliminates the need for one round of data exchange (for those centroids) between processors. New vertex positions must be sent from owning processors to processors sharing those vertices. Convergence is measured as the maximum distance moved by any vertex.
In this implementation, a fixed number of iterations is performed. The final mesh is output to 'lloydfinal.h5m' in the current directory (H5M format must be used since the file is written in parallel).
/** @example LloydRelaxation.cpp \n * \brief Perform Lloyd relaxation on a mesh and its dual \n * <b>To run</b>: mpiexec -np <np> LloydRelaxation [filename]\n * * Briefly, Lloyd relaxation is a technique to smooth out a mesh. The centroid of each cell is * computed from its vertex positions, then vertices are placed at the average of their connected * cells' centroids. * * In the parallel algorithm, an extra ghost layer of cells is exchanged. This allows us to compute * the centroids for boundary cells on each processor where they appear; this eliminates the need * for one round of data exchange (for those centroids) between processors. New vertex positions * must be sent from owning processors to processors sharing those vertices. Convergence is * measured as the maximum distance moved by any vertex. * * In this implementation, a fixed number of iterations is performed. The final mesh is output to * 'lloydfinal.h5m' in the current directory (H5M format must be used since the file is written in * parallel). */ #include "moab/Core.hpp" #ifdef MOAB_HAVE_MPI #include "moab/ParallelComm.hpp" #include "MBParallelConventions.h" #endif #include "moab/Skinner.hpp" #include "moab/CN.hpp" #include "moab/CartVect.hpp" #include <iostream> #include <sstream> using namespace moab; using namespace std; string test_file_name = string( MESH_DIR ) + string( "/surfrandomtris-4part.h5m" ); ErrorCode perform_lloyd_relaxation( Interface* mb, Range& verts, Range& cells, Tag fixed, int num_its, int report_its ); int main( int argc, char** argv ) { int num_its = 10; int report_its = 1; #ifdef MOAB_HAVE_MPI MPI_Init( &argc, &argv ); #endif // Need option handling here for input filename if( argc > 1 ) { // User has input a mesh file test_file_name = argv[1]; } // Get MOAB instance Interface* mb = new( std::nothrow ) Core; if( NULL == mb ) return 1; #ifdef MOAB_HAVE_MPI // Get the ParallelComm instance ParallelComm* pcomm = new ParallelComm( mb, MPI_COMM_WORLD ); int nprocs = pcomm->size(); #else int nprocs = 1; #endif string options; if( nprocs > 1 ) // If reading in parallel, need to tell it how options = "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;" "PARALLEL_GHOSTS=2.0.1;DEBUG_IO=0;DEBUG_PIO=0"; // Load the test file with specified options ErrorCode rval = mb->load_file( test_file_name.c_str(), 0, options.c_str() );MB_CHK_ERR( rval ); // Make tag to specify fixed vertices, since it's input to the algorithm; use a default value of // non-fixed so we only need to set the fixed tag for skin vertices Tag fixed; int def_val = 0; rval = mb->tag_get_handle( "fixed", 1, MB_TYPE_INTEGER, fixed, MB_TAG_CREAT | MB_TAG_DENSE, &def_val );MB_CHK_ERR( rval ); // Get all vertices and faces Range verts, faces, skin_verts; rval = mb->get_entities_by_type( 0, MBVERTEX, verts );MB_CHK_ERR( rval ); rval = mb->get_entities_by_dimension( 0, 2, faces );MB_CHK_ERR( rval ); // Get the skin vertices of those faces and mark them as fixed; we don't want to fix the // vertices on a part boundary, but since we exchanged a layer of ghost faces, those vertices // aren't on the skin locally ok to mark non-owned skin vertices too, I won't move those anyway // use MOAB's skinner class to find the skin Skinner skinner( mb ); rval = skinner.find_skin( 0, faces, true, skin_verts );MB_CHK_ERR( rval ); // 'true' param indicates we want vertices back, not faces vector< int > fix_tag( skin_verts.size(), 1 ); // Initialized to 1 to indicate fixed rval = mb->tag_set_data( fixed, skin_verts, &fix_tag[0] );MB_CHK_ERR( rval ); // Now perform the Lloyd relaxation rval = perform_lloyd_relaxation( mb, verts, faces, fixed, num_its, report_its );MB_CHK_ERR( rval ); // Delete fixed tag, since we created it here rval = mb->tag_delete( fixed );MB_CHK_ERR( rval ); // Output file, using parallel write #ifdef MOAB_HAVE_MPI options = "PARALLEL=WRITE_PART"; #endif rval = mb->write_file( "lloydfinal.h5m", NULL, options.c_str() );MB_CHK_ERR( rval ); // Delete MOAB instance delete mb; #ifdef MOAB_HAVE_MPI MPI_Finalize(); #endif return 0; } ErrorCode perform_lloyd_relaxation( Interface* mb, Range& verts, Range& faces, Tag fixed, int num_its, int report_its ) { ErrorCode rval; #ifdef MOAB_HAVE_MPI ParallelComm* pcomm = ParallelComm::get_pcomm( mb, 0 ); int nprocs = pcomm->size(); #else int nprocs = 1; #endif // Perform Lloyd relaxation: // 1. Setup: set vertex centroids from vertex coords; filter to owned verts; get fixed tags // Get all verts coords into tag; don't need to worry about filtering out fixed verts, // we'll just be setting to their fixed coords vector< double > vcentroids( 3 * verts.size() ); rval = mb->get_coords( verts, &vcentroids[0] );MB_CHK_ERR( rval ); Tag centroid; rval = mb->tag_get_handle( "centroid", 3, MB_TYPE_DOUBLE, centroid, MB_TAG_CREAT | MB_TAG_DENSE );MB_CHK_ERR( rval ); rval = mb->tag_set_data( centroid, verts, &vcentroids[0] );MB_CHK_ERR( rval ); // Filter verts down to owned ones and get fixed tag for them Range owned_verts, shared_owned_verts; if( nprocs > 1 ) { #ifdef MOAB_HAVE_MPI rval = pcomm->filter_pstatus( verts, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &owned_verts );MB_CHK_ERR( rval ); #endif } else owned_verts = verts; vector< int > fix_tag( owned_verts.size() ); rval = mb->tag_get_data( fixed, owned_verts, &fix_tag[0] );MB_CHK_ERR( rval ); // Now fill vcentroids array with positions of just owned vertices, since those are the ones // we're actually computing vcentroids.resize( 3 * owned_verts.size() ); rval = mb->tag_get_data( centroid, owned_verts, &vcentroids[0] );MB_CHK_ERR( rval ); #ifdef MOAB_HAVE_MPI // Get shared owned verts, for exchanging tags rval = pcomm->get_shared_entities( -1, shared_owned_verts, 0, false, true );MB_CHK_ERR( rval ); // Workaround: if no shared owned verts, put a non-shared one in the list, to prevent exchanging // tags for all shared entities if( shared_owned_verts.empty() ) shared_owned_verts.insert( *verts.begin() ); #endif // Some declarations for later iterations vector< double > fcentroids( 3 * faces.size() ); // fcentroids for face centroids vector< double > ctag( 3 * CN::MAX_NODES_PER_ELEMENT ); // Temporary coordinate storage for verts bounding a face const EntityHandle* conn; // const ptr & size to face connectivity int nconn; Range::iterator fit, vit; // For iterating over faces, verts int f, v; // For indexing into centroid vectors vector< EntityHandle > adj_faces; // Used in vertex iteration // 2. For num_its iterations: for( int nit = 0; nit < num_its; nit++ ) { double mxdelta = 0.0; // 2a. For each face: centroid = sum(vertex centroids)/num_verts_in_cell for( fit = faces.begin(), f = 0; fit != faces.end(); ++fit, f++ ) { // Get verts for this face rval = mb->get_connectivity( *fit, conn, nconn );MB_CHK_ERR( rval ); // Get centroid tags for those verts rval = mb->tag_get_data( centroid, conn, nconn, &ctag[0] );MB_CHK_ERR( rval ); fcentroids[3 * f + 0] = fcentroids[3 * f + 1] = fcentroids[3 * f + 2] = 0.0; for( v = 0; v < nconn; v++ ) { fcentroids[3 * f + 0] += ctag[3 * v + 0]; fcentroids[3 * f + 1] += ctag[3 * v + 1]; fcentroids[3 * f + 2] += ctag[3 * v + 2]; } for( v = 0; v < 3; v++ ) fcentroids[3 * f + v] /= nconn; } rval = mb->tag_set_data( centroid, faces, &fcentroids[0] );MB_CHK_ERR( rval ); // 2b. For each owned vertex: for( vit = owned_verts.begin(), v = 0; vit != owned_verts.end(); ++vit, v++ ) { // if !fixed if( fix_tag[v] ) continue; // vertex centroid = sum(cell centroids)/ncells adj_faces.clear(); rval = mb->get_adjacencies( &( *vit ), 1, 2, false, adj_faces );MB_CHK_ERR( rval ); rval = mb->tag_get_data( centroid, &adj_faces[0], adj_faces.size(), &fcentroids[0] );MB_CHK_ERR( rval ); double vnew[] = { 0.0, 0.0, 0.0 }; for( f = 0; f < (int)adj_faces.size(); f++ ) { vnew[0] += fcentroids[3 * f + 0]; vnew[1] += fcentroids[3 * f + 1]; vnew[2] += fcentroids[3 * f + 2]; } for( f = 0; f < 3; f++ ) vnew[f] /= adj_faces.size(); double delta = ( CartVect( vnew ) - CartVect( &vcentroids[3 * v] ) ).length(); mxdelta = std::max( delta, mxdelta ); for( f = 0; f < 3; f++ ) vcentroids[3 * v + f] = vnew[f]; } // Set the centroid tag; having them only in vcentroids array isn't enough, as vertex // centroids are accessed randomly in loop over faces rval = mb->tag_set_data( centroid, owned_verts, &vcentroids[0] );MB_CHK_ERR( rval ); // 2c. Exchange tags on owned verts if( nprocs > 1 ) { #ifdef MOAB_HAVE_MPI rval = pcomm->exchange_tags( centroid, shared_owned_verts );MB_CHK_ERR( rval ); #endif } if( !( nit % report_its ) ) { // Global reduce for maximum delta, then report it double global_max = mxdelta; int myrank = 0; #ifdef MOAB_HAVE_MPI if( nprocs > 1 ) MPI_Reduce( &mxdelta, &global_max, 1, MPI_DOUBLE, MPI_MAX, 0, pcomm->comm() ); myrank = pcomm->rank(); #endif if( 1 == nprocs || 0 == myrank ) cout << "Max delta = " << global_max << endl; } } // Write the tag back onto vertex coordinates rval = mb->set_coords( owned_verts, &vcentroids[0] );MB_CHK_ERR( rval ); // Delete the centroid tag, since we don't need it anymore rval = mb->tag_delete( centroid );MB_CHK_ERR( rval ); return MB_SUCCESS; }
