MOAB: Mesh Oriented datABase
(version 5.4.1)
Read mesh into MOAB and write some back
To run: mpiexec -np 4 ReadWriteTest [input] [output] -O <read_opts> -o <write_opts>
used for stress test of reader/writer report times to read and write
example ReadWriteTest ../MeshFiles/io/fv3x46x72.t.3.nc out.nc \ -O PARALLEL=READ_PART;PARTITION_METHOD=SQIJ;PARALLEL_RESOLVE_SHARED_ENTS;VARIABLE=T,U; \ -o PARALLEL=WRITE_PART;VARIABLE=T,U
/** @example ReadWriteTest.cpp \n * \brief Read mesh into MOAB and write some back \n * * <b>To run</b>: mpiexec -np 4 ReadWriteTest [input] [output] -O <read_opts> -o <write_opts>\n * * used for stress test of reader/writer * report times to read and write * * example ReadWriteTest ../MeshFiles/io/fv3x46x72.t.3.nc out.nc \ * -O PARALLEL=READ_PART;PARTITION_METHOD=SQIJ;PARALLEL_RESOLVE_SHARED_ENTS;VARIABLE=T,U; \ * -o PARALLEL=WRITE_PART;VARIABLE=T,U */ #include "moab/Core.hpp" #ifdef MOAB_HAVE_MPI #include "moab/ParallelComm.hpp" #include "MBParallelConventions.h" #endif #include <iostream> #include <ctime> using namespace moab; using namespace std; int main( int argc, char** argv ) { #ifdef MOAB_HAVE_MPI string input_file, output_file, read_opts, write_opts; MPI_Init( &argc, &argv ); // Need option handling here for input filename if( argc < 3 ) { #ifdef MOAB_HAVE_NETCDF input_file = string( MESH_DIR ) + string( "/io/fv3x46x72.t.3.nc" ); output_file = "ReadWriteTestOut.h5m"; read_opts = "PARALLEL=READ_PART;PARTITION_METHOD=SQIJ;PARALLEL_RESOLVE_SHARED_ENTS;VARIABLE=T,U"; write_opts = "PARALLEL=WRITE_PART"; #else cout << "Usage: mpiexec -n $NP ReadWriteTest [input] [output] -O <read_opts> -o " "<write_opts>\n"; return 0; #endif } else { input_file = argv[1]; output_file = argv[2]; } if( argc > 3 ) { int index = 3; while( index < argc ) { if( !strcmp( argv[index], "-O" ) ) // This is for reading options, optional read_opts = argv[++index]; if( !strcmp( argv[index], "-o" ) ) write_opts = argv[++index]; index++; } } // Get MOAB instance Interface* mb = new( std::nothrow ) Core; if( NULL == mb ) return 1; // Get the ParallelComm instance ParallelComm* pcomm = new ParallelComm( mb, MPI_COMM_WORLD ); int nprocs = pcomm->proc_config().proc_size(); int rank = pcomm->proc_config().proc_rank(); EntityHandle set; ErrorCode rval = mb->create_meshset( MESHSET_SET, set );MB_CHK_ERR( rval ); clock_t tt = clock(); if( 0 == rank ) cout << "Reading file " << input_file << "\n with options: " << read_opts << "\n on " << nprocs << " processors\n"; // Read the file with the specified options rval = mb->load_file( input_file.c_str(), &set, read_opts.c_str() );MB_CHK_ERR( rval ); if( 0 == rank ) { cout << "Time: " << ( clock() - tt ) / (double)CLOCKS_PER_SEC << " seconds" << endl; tt = clock(); } // Write back the file with the specified options rval = mb->write_file( output_file.c_str(), 0, write_opts.c_str(), &set, 1 );MB_CHK_ERR( rval ); if( 0 == rank ) { cout << "Writing file " << output_file << "\n with options: " << write_opts << endl; cout << "Time: " << ( clock() - tt ) / (double)CLOCKS_PER_SEC << " seconds" << endl; tt = clock(); } delete mb; MPI_Finalize(); #else std::cout << " compile MOAB with mpi for this example to work\n"; #endif return 0; }
