MOAB: Mesh Oriented datABase
(version 5.4.1)
Description: This example simulates MOAB's enhanced error handling in parallel.
All of the errors are contrived, used for simulation purpose only.
Note: We do not need a moab instance for this example
To run: mpiexec -np 4 ./ErrorHandlingSimulation <test_case_num(1 to 4)>
/** @example ErrorHandlingSimulation.cpp * Description: This example simulates MOAB's enhanced error handling in parallel. \n * All of the errors are contrived, used for simulation purpose only. \n * * Note: We do not need a moab instance for this example * * <b>To run</b>: mpiexec -np 4 ./ErrorHandlingSimulation <test_case_num(1 to 4)> \n */ #include "moab/MOABConfig.h" #include "moab/ErrorHandler.hpp" #ifdef MOAB_HAVE_MPI #include "moab_mpi.h" #endif #include <iostream> #include <cstdlib> using namespace moab; using namespace std; // Functions that create and handle contrived errors // Call hierarchy: A calls B, and B calls C ErrorCode FunctionC( int test_case_num, int rank ) { switch( test_case_num ) { case 1: // Simulate a global fatal error MB_NOT_IMPLEMENTED on all processors // Note, it is printed by root processor 0 only MB_SET_GLB_ERR( MB_NOT_IMPLEMENTED, "A contrived global error MB_NOT_IMPLEMENTED" ); break; case 2: // Simulate a per-processor relevant error MB_INDEX_OUT_OF_RANGE on all processors // Note, it is printed by all processors MB_SET_ERR( MB_INDEX_OUT_OF_RANGE, "A contrived error MB_INDEX_OUT_OF_RANGE on processor " << rank ); break; case 3: // Simulate a per-processor relevant error MB_TYPE_OUT_OF_RANGE on all processors except // root Note, it is printed by all non-root processors if( 0 != rank ) MB_SET_ERR( MB_TYPE_OUT_OF_RANGE, "A contrived error MB_TYPE_OUT_OF_RANGE on processor " << rank ); break; case 4: // Simulate a per-processor relevant error MB_INDEX_OUT_OF_RANGE on processor 1 // Note, it is printed by processor 1 only if( 1 == rank ) MB_SET_ERR( MB_INDEX_OUT_OF_RANGE, "A contrived error MB_INDEX_OUT_OF_RANGE on processor 1" ); // Simulate a per-processor relevant error MB_TYPE_OUT_OF_RANGE on processor 3 // Note, it is printed by processor 3 only if( 3 == rank ) MB_SET_ERR( MB_TYPE_OUT_OF_RANGE, "A contrived error MB_TYPE_OUT_OF_RANGE on processor 3" ); break; default: break; } return MB_SUCCESS; } ErrorCode FunctionB( int test_case_num, int rank ) { ErrorCode err_code = FunctionC( test_case_num, rank );MB_CHK_ERR( err_code ); return MB_SUCCESS; } ErrorCode FunctionA( int test_case_num, int rank ) { ErrorCode err_code = FunctionB( test_case_num, rank );MB_CHK_ERR( err_code ); return MB_SUCCESS; } int main( int argc, char** argv ) { if( argc < 2 ) { cout << "Usage: " << argv[0] << " <test_case_num(1 to 4)>" << endl; return 0; } #ifdef MOAB_HAVE_MPI MPI_Init( &argc, &argv ); #endif // Initialize error handler, required for this example (not using a moab instance) MBErrorHandler_Init(); int test_case_num = atoi( argv[1] ); int rank = 0; #ifdef MOAB_HAVE_MPI MPI_Comm_rank( MPI_COMM_WORLD, &rank ); #endif ErrorCode rval = FunctionA( test_case_num, rank );MB_CHK_ERR( rval ); // Finalize error handler, required for this example (not using a moab instance) MBErrorHandler_Finalize(); #ifdef MOAB_HAVE_MPI MPI_Finalize(); #endif return 0; }
