MOAB: Mesh Oriented datABase
(version 5.4.1)
this tool will take an existing h5m pg2 mesh (fv) file and a land point cloud mesh
will extract the corresponding land mesh
example of usage: ./ExtractLand -p wholeATM_PG2.h5m -l wholeLnd.h5m -o LandMesh.h5m
the *PG2" style atm mesh is available in E3SM only for pg2 runs, something like --res ne30pg2_r05_oECv3_ICG --compset A_WCYCL1850S_CMIP6 or --res ne4pg2_ne4pg2 --compset FC5AV1C-L
/** @example ExtractLand.cpp * this tool will take an existing h5m pg2 mesh (fv) file and a land point cloud mesh * * will extract the corresponding land mesh * * example of usage: * ./ExtractLand -p wholeATM_PG2.h5m -l wholeLnd.h5m -o LandMesh.h5m * * the *PG2" style atm mesh is available in E3SM only for pg2 runs, something like * --res ne30pg2_r05_oECv3_ICG --compset A_WCYCL1850S_CMIP6 * or * --res ne4pg2_ne4pg2 --compset FC5AV1C-L */ #include "moab/ProgOptions.hpp" #include "moab/Core.hpp" #include <cmath> #include <sstream> using namespace moab; int main( int argc, char* argv[] ) { ProgOptions opts; std::string pg2file, lndfile, outfile; opts.addOpt< std::string >( "land,l", "phys grid filename", &lndfile ); opts.addOpt< std::string >( "pg2file,p", "pg2 mesh file", &pg2file ); opts.addOpt< std::string >( "output,o", "output mesh filename", &outfile ); opts.parseCommandLine( argc, argv ); std::cout << " land file " << lndfile << "\n"; std::cout << "pg2 mesh file: " << pg2file << "\n"; std::cout << "output file: " << outfile << "\n"; if( lndfile.empty() || pg2file.empty() || outfile.empty() ) { opts.printHelp(); return 0; } ErrorCode rval; Core* mb = new Core(); rval = mb->load_file( lndfile.c_str() );MB_CHK_SET_ERR( rval, "can't load land pc file" ); Core* mb2 = new Core(); rval = mb2->load_file( pg2file.c_str() );MB_CHK_SET_ERR( rval, "can't load pg2 mesh file" ); Tag globalIDTag1 = mb->globalId_tag(); Tag globalIDTag2 = mb2->globalId_tag(); Range verts1; rval = mb->get_entities_by_dimension( 0, 0, verts1 );MB_CHK_SET_ERR( rval, "can't get vertices " ); Range cells; rval = mb2->get_entities_by_dimension( 0, 2, cells );MB_CHK_SET_ERR( rval, "can't get 2d cells " ); std::vector< int > globalIdsCells; globalIdsCells.resize( cells.size() ); rval = mb2->tag_get_data( globalIDTag2, cells, &globalIdsCells[0] );MB_CHK_SET_ERR( rval, "can't get global ids cells " ); std::vector< int > globalIdsVerts; globalIdsVerts.resize( verts1.size() ); rval = mb->tag_get_data( globalIDTag1, verts1, &globalIdsVerts[0] );MB_CHK_SET_ERR( rval, "can't get global ids cells " ); // now, every cell will be put into one set, by looking at the global id of cell std::map< int, EntityHandle > gidToCell; int i = 0; for( Range::iterator it = cells.begin(); it != cells.end(); ++it, i++ ) { gidToCell[globalIdsCells[i]] = *it; } // create a new file set with land cells EntityHandle fileSet; rval = mb2->create_meshset( MESHSET_SET, fileSet );MB_CHK_SET_ERR( rval, "Error creating file set" ); // empty all sets Range landCells; // look now at gid values for vertices for( i = 0; i < (int)verts1.size(); i++ ) { int gid = globalIdsVerts[i]; landCells.insert(gidToCell[gid]); } rval = mb2->add_entities(fileSet, landCells);;MB_CHK_SET_ERR( rval, "can't add land cells" ); rval = mb2->write_file( outfile.c_str(), 0, 0, &fileSet, 1 );MB_CHK_SET_ERR( rval, "can't write file" ); // write the original with mask 0/1, default -1 Tag mask; double def_val=-1.; rval = mb2->tag_get_handle( "mask", 1, MB_TYPE_DOUBLE, mask, MB_TAG_CREAT | MB_TAG_DENSE, &def_val );MB_CHK_SET_ERR( rval, "can't create mask tag" ); for( Range::iterator it = cells.begin(); it != cells.end(); ++it, i++ ) { EntityHandle cell = *it; // set to 0 double val = 0.; rval = mb2->tag_set_data(mask, &cell, 1, &val); MB_CHK_SET_ERR( rval, "can't set mask tag" ); } for( Range::iterator it = landCells.begin(); it != landCells.end(); ++it, i++ ) { EntityHandle cell = *it; // set to 0 double val = 1.; rval = mb2->tag_set_data(mask, &cell, 1, &val); MB_CHK_SET_ERR( rval, "can't set mask tag" ); } rval = mb2->delete_entities(&fileSet, 1); MB_CHK_SET_ERR( rval, "can't delete set" ); rval = mb2->write_file( "AtmWithLandMask.h5m" );MB_CHK_SET_ERR( rval, "can't write file" ); delete mb; delete mb2; return 0; }
