MOAB: Mesh Oriented datABase
(version 5.4.1)
Description: This example tests MOAB's trace back error handler in serial.
To run: ./TestErrorHandling <test_case_num(1 to 4)>
/** @example TestErrorHandling.cpp \n * Description: This example tests MOAB's trace back error handler in serial. \n * * <b>To run</b>: ./TestErrorHandling <test_case_num(1 to 4)> \n */ #include "moab/Core.hpp" #ifdef MOAB_HAVE_MPI #include "moab_mpi.h" #endif #include <iostream> using namespace moab; using namespace std; // In this test case, an error MB_NOT_IMPLEMENTED is returned by MOAB ErrorCode TestErrorHandling_1() { Core moab; Interface& mb = moab; // Load a CAM-FV file and read a variable on edges (not supported yet) string test_file = string( MESH_DIR ) + string( "/io/fv3x46x72.t.3.nc" ); ErrorCode rval = mb.load_file( test_file.c_str(), NULL, "VARIABLE=US" );MB_CHK_ERR( rval ); return MB_SUCCESS; } // In this test case, an error MB_TYPE_OUT_OF_RANGE is returned by MOAB ErrorCode TestErrorHandling_2() { Core moab; Interface& mb = moab; // Load a HOMME file with an invalid GATHER_SET option string test_file = string( MESH_DIR ) + string( "/io/homme3x3458.t.3.nc" ); ErrorCode rval = mb.load_file( test_file.c_str(), NULL, "VARIABLE=T;GATHER_SET=0.1" );MB_CHK_ERR( rval ); return MB_SUCCESS; } // In this test case, an error MB_FAILURE is returned by MOAB ErrorCode TestErrorHandling_3() { Core moab; Interface& mb = moab; // Load a CAM-FV file with NOMESH option and a NULL file set string test_file = string( MESH_DIR ) + string( "/io/fv3x46x72.t.3.nc" ); ErrorCode rval = mb.load_file( test_file.c_str(), NULL, "NOMESH;VARIABLE=" );MB_CHK_ERR( rval ); return MB_SUCCESS; } // In this test case, an error MB_VARIABLE_DATA_LENGTH is returned by MOAB ErrorCode TestErrorHandling_4() { Core moab; Interface& mb = moab; // Create 100 vertices const int NUM_VTX = 100; vector< double > coords( 3 * NUM_VTX ); Range verts; ErrorCode rval = mb.create_vertices( &coords[0], NUM_VTX, verts );MB_CHK_SET_ERR( rval, "Failed to create vertices" ); // Create a variable-length dense tag Tag tag; rval = mb.tag_get_handle( "var_len_den", 1, MB_TYPE_INTEGER, tag, MB_TAG_VARLEN | MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_SET_ERR( rval, "Failed to create a tag" ); // Attempt to iterate over a variable-length tag, which will never be possible void* ptr = NULL; int count = 0; rval = mb.tag_iterate( tag, verts.begin(), verts.end(), count, ptr );MB_CHK_SET_ERR( rval, "Failed to iterate over tag on " << NUM_VTX << " vertices" ); return MB_SUCCESS; } int main( int argc, char** argv ) { if( argc < 2 ) { cout << "Usage: " << argv[0] << " <test_case_num(1 to 4)>" << endl; return 0; } #ifdef MOAB_HAVE_MPI MPI_Init( &argc, &argv ); #endif // Initialize error handler, optional for this example (using moab instances) MBErrorHandler_Init(); ErrorCode rval = MB_SUCCESS; int test_case_num = atoi( argv[1] ); switch( test_case_num ) { case 1: rval = TestErrorHandling_1();MB_CHK_ERR( rval ); break; case 2: rval = TestErrorHandling_2();MB_CHK_ERR( rval ); break; case 3: rval = TestErrorHandling_3();MB_CHK_ERR( rval ); break; case 4: rval = TestErrorHandling_4();MB_CHK_ERR( rval ); break; default: break; } // Finalize error handler, optional for this example (using moab instances) MBErrorHandler_Finalize(); #ifdef MOAB_HAVE_MPI MPI_Finalize(); #endif return 0; }
