MOAB: Mesh Oriented datABase
(version 5.4.1)
generalized gather scatter using tuples
To run: mpiexec -np <n> CrystalRouterExample -r [reportrank] -t [num_tuples] -n [num_comms]
/* * This example will show one of the building blocks of parallel infrastructure in MOAB * More exactly, if we have some homogeneous data to communicate from each processor to a list of * other processors, how do we do it? * * introduce the TupleList and crystal router to MOAB users. * * This technology is used in resolving shared vertices / sets between partitions * It is used in the mbcoupler for sending data (target points) to the proper processor, and * communicate back the results. Also, it is used to communicate departure mesh for intersection in * parallel * * It is a way of doing MPI_gatheralltoallv(), when the communication matrix is sparse * * It is assumed that every proc needs to communicate only with a few of the other processors. * If every processor needs to communicate with all other, then we will have to use paired isend * and irecv, the communication matrix is full * * the example needs to be launched in parallel. * Every proc will build a list of tuples, that will be send to a few procs; * In general, we will send to num_comms tasks, and about num_tuples to each task * We vary num_comms and num_tuples for processor * * we will send long ints of the form * 100000 * send + 1000* rank +j, where j is the index of tuple * * after routing, we verify we received * 100000 * rank + 1000 * from * * For some reportrank we also print the tuples. * * after routing, we will see if we received, as expected. Should run on at least 2 processors. * * Note: We do not need a moab instance for this example * */ /** @example CrystalRouterExample.cpp \n * \brief generalized gather scatter using tuples \n * <b>To run</b>: mpiexec -np <n> CrystalRouterExample -r [reportrank] -t [num_tuples] -n * [num_comms] \n * */ // #include "moab/MOABConfig.h" #ifdef MOAB_HAVE_MPI #include "moab/ProcConfig.hpp" #endif #include "moab/TupleList.hpp" #include "moab/ProgOptions.hpp" #include "moab/ErrorHandler.hpp" #include <ctime> #include <iostream> #include <sstream> const char BRIEF_DESC[] = "Example of gather scatter with tuple lists \n"; std::ostringstream LONG_DESC; using namespace moab; using namespace std; int main( int argc, char** argv ) { #ifdef MOAB_HAVE_MPI MPI_Init( &argc, &argv ); // Initialize error handler, required for this example (not using a moab instance) MBErrorHandler_Init(); ProcConfig pc( MPI_COMM_WORLD ); int size = pc.proc_size(); int rank = pc.proc_rank(); // Start copy LONG_DESC << "This program does a gather scatter with a list of tuples. \n" " It tries to see how much communication costs in terms of time and memory. \n" << "It starts with creating a list of tuples to be sent from each processor, \n to a " "list of other processors.\n" << "The number of tuples and how many tasks to communicate to are controlled by " "input parameters.\n" << "After communication, we verify locally if we received what we expected. \n"; ProgOptions opts( LONG_DESC.str(), BRIEF_DESC ); // How many procs communicate to current proc, on average (we will vary that too) int num_comms = 2; opts.addOpt< int >( "num_comms,n", "each task will send to about num_comms other tasks some tuples (default 2)", &num_comms ); int num_tuples = 4; opts.addOpt< int >( "num_tuples,t", "each task will send to some task about num_tuples tuples (default 4)", &num_tuples ); int reportrank = size + 1; opts.addOpt< int >( "reporting_rank,r", "this rank will report the tuples sent and the tuples received; it could " "be higher than num_procs, then no reporting", &reportrank ); opts.parseCommandLine( argc, argv ); if( rank == reportrank || ( reportrank >= size && 0 == rank ) ) { cout << " There are " << size << " tasks in example.\n"; cout << " We will send groups of " << num_tuples << " from each task towards " << num_comms << " other tasks.\n"; } // Send some data from proc i to i + n/2, also to i + n/2 + 1 modulo n, where n is num procs gs_data::crystal_data* cd = pc.crystal_router(); long total_n_tuples = num_comms * num_tuples; // Vary the number of tasks to send to, and the number of tuples to send if( rank < size / 2 ) num_comms--; else num_comms++; if( rank < size / 3 ) num_tuples *= 2; else if( rank > size - size / 3 ) num_tuples /= 2; TupleList tl; // At most num_tuples* num_comms to send // We do a preallocate with this; some tuples on some processors might need more memory, to be // able to grow locally; Some tasks might receive more tuples though, and in the process, some // might grow more than others. By doing these logP sends/receives, we do not grow local memory // too much. tl.initialize( 1, 1, 0, 1, num_tuples * num_comms ); tl.enableWriteAccess(); // Form num_tuples*num_comms tuples, send to various ranks unsigned int n = tl.get_n(); for( int i = 0; i < num_comms; i++ ) { int sendTo = rank + i * size / 2 + 1; // Spread out the send to, for a stress-like test sendTo = sendTo % size; // long intToSend = 1000 * rank + 100000 * sendTo; for( int j = 0; j < num_tuples; j++ ) { n = tl.get_n(); tl.vi_wr[n] = sendTo; tl.vl_wr[n] = intToSend + j; tl.vr_wr[n] = 10000. * rank + j; tl.inc_n(); } } if( rank == reportrank ) { cout << "rank " << rank << "\n"; tl.print( " before sending" ); } clock_t tt = clock(); // All communication happens here; no mpi calls for the user ErrorCode rval = cd->gs_transfer( 1, tl, 0 );MB_CHK_SET_ERR( rval, "Error in tuple transfer" ); double secs = 0; if( rank == reportrank || ( reportrank >= size && 0 == rank ) ) { secs = ( clock() - tt ) / (double)CLOCKS_PER_SEC; } if( rank == reportrank ) { cout << "rank " << rank << "\n"; tl.print( " after transfer" ); } // Check that all tuples received have the form 10000*rank + 100*from unsigned int received = tl.get_n(); for( int i = 0; i < (int)received; i++ ) { int from = tl.vi_rd[i]; long valrec = tl.vl_rd[i]; int remainder = valrec - 100000 * rank - 1000 * from; if( remainder < 0 || remainder >= num_tuples * 4 ) cout << " error: tuple " << i << " received at proc rank " << rank << " from proc " << from << " has value " << valrec << " remainder " << remainder << "\n"; } if( rank == reportrank || ( reportrank >= size && 0 == rank ) ) { cout << "communication of about " << total_n_tuples << " tuples/per proc took " << secs << " seconds" << "\n"; tt = clock(); } // Finalize error handler, required for this example (not using a moab instance) MBErrorHandler_Finalize(); MPI_Finalize(); #else std::cout << " Build with MPI for this example to work\n"; #endif return 0; }
