MOAB: Mesh Oriented datABase
(version 5.4.1)
Load a part of a file
To run: LoadPartial <file> <tag_name> <val1> <val2> ...
In this example, it is shown how to load only a part of one file; the file must be organized in sets. (cherry-picking only the sets we want) The sets to load are identified by a tag name and the tag values for the sets of interest. This procedure is used when reading in parallel, as each processor will load only its part of the file, identified either by partition or by material/block sets by default, this example will load parallel partition sets with values 1, 2, and 5 from ../MeshFiles/unittest/64bricks_1khex.h5m The example will always write the output to a file name part.h5m
/** @example LoadPartial.cpp \n * \brief Load a part of a file \n * <b>To run</b>: LoadPartial <file> <tag_name> <val1> <val2> ...\n * * In this example, it is shown how to load only a part of one file; the file must be organized in * sets. (cherry-picking only the sets we want) The sets to load are identified by a tag name and * the tag values for the sets of interest. This procedure is used when reading in parallel, as * each processor will load only its part of the file, identified either by partition or by * material/block sets by default, this example will load parallel partition sets with values 1, 2, * and 5 from ../MeshFiles/unittest/64bricks_1khex.h5m The example will always write the output to a * file name part.h5m */ #include <iostream> #include <vector> // Include header for MOAB instance and tag conventions for #include "moab/Core.hpp" #include "MBTagConventions.hpp" #define NTAGVALS 3 using namespace moab; using namespace std; // Function to parse input parameters ErrorCode get_file_options( int argc, char** argv, string& filename, string& tagName, vector< int >& tagValues ) { // Get mesh filename if( argc > 1 ) filename = string( argv[1] ); else filename = string( MESH_DIR ) + string( "/64bricks_512hex_256part.h5m" ); // Get tag selection options if( argc > 2 ) tagName = string( argv[2] ); else tagName = "USERTAG"; if( argc > 3 ) { tagValues.resize( argc - 3, 0 ); for( int i = 3; i < argc; ++i ) tagValues[i - 3] = atoi( argv[i] ); } else { for( unsigned i = 0; i < tagValues.size(); ++i ) tagValues[i] = 2 * i + 1; } if( argc > 1 && argc < 4 ) // print usage cout << " usage is " << argv[0] << " <file> <tag_name> <value1> <value2> .. \n"; return MB_SUCCESS; } int main( int argc, char** argv ) { // Get MOAB instance Interface* mb = new( std::nothrow ) Core; if( NULL == mb ) return 1; std::string filename, tagname; vector< int > tagvals( NTAGVALS ); // Allocate for a maximum of 5 tag values ErrorCode rval = get_file_options( argc, argv, filename, tagname, tagvals );MB_CHK_ERR( rval ); #ifdef MOAB_HAVE_HDF5 // This file is in the mesh files directory rval = mb->load_file( filename.c_str(), 0, 0, PARALLEL_PARTITION_TAG_NAME, tagvals.data(), (int)tagvals.size() );MB_CHK_SET_ERR( rval, "Failed to read" ); // If HANDLEID tag present, convert to long, and see what we read from file Tag handleid_tag; rval = mb->tag_get_handle( "HANDLEID", handleid_tag ); if( MB_SUCCESS == rval ) { // Convert a few values for a few vertices Range verts; rval = mb->get_entities_by_type( 0, MBVERTEX, verts );MB_CHK_SET_ERR( rval, "Failed to get vertices" ); vector< long > valsTag( verts.size() ); rval = mb->tag_get_data( handleid_tag, verts, &valsTag[0] ); if( MB_SUCCESS == rval ) cout << "First 2 long values recovered: " << valsTag[0] << " " << valsTag[1] << "\n"; } rval = mb->write_file( "part.h5m" );MB_CHK_SET_ERR( rval, "Failed to write partial file" ); cout << "Wrote successfully part.h5m.\n"; #else std::cout << "Configure MOAB with HDF5 to build and use this example correctly.\n"; #endif delete mb; return 0; }
