MOAB: Mesh Oriented datABase
(version 5.4.1)
This example demonstrates how to retrieve material, dirichlet and neumann sets from an ExodusII file.
Sets in MOAB contain entities and have a tag on them to give meaning to the entities. Tag names: MATERIAL_SET", "DIRICHLET_SET" and "NEUMANN_SET" are reserved and are associated with their corresponding entity sets. Sets are traversed to find out the type number of entities contained in each set.
Steps in this example :
To compile: make TestExodusII MOAB_DIR=<installdir>
To run:
/** @example TestExodusII.cpp * This example demonstrates how to retrieve material, dirichlet and neumann sets * from an ExodusII file. \n * Sets in MOAB contain entities and have a tag on them to give meaning to the entities. * Tag names: MATERIAL_SET", "DIRICHLET_SET" and "NEUMANN_SET" are reserved and * are associated with their corresponding entity sets. * Sets are traversed to find out the type number of entities contained in each set. \n * * <b>Steps in this example </b>: * -# Instantiate MOAB * -# Get input mesh file name and load it. * -# Loop over the three sets: material, dirichlet and neumann * -# Get TagHandle and EntitySet(corresponding to the TagHandle) * -# Loop thru all the EntitySet's * -# Get the set id and entities in this set * -# Destroy the MOAB instance * * * <b> To compile: </b> * make TestExodusII MOAB_DIR=<installdir> \n * * <b> To run: </b> * -# TestExodusII <mesh-file> \n * -# TestExodusII (This uses the default <mesh-file>: * <MOAB_SRC_DIR>/MeshFiles/unittest/mbtest2.g) */ #include <iostream> // Include header for MOAB instance and range #include "moab/Core.hpp" using namespace moab; using namespace std; string test_file_name = string( MESH_DIR ) + string( "/mbtest2.g" ); int main( int argc, char** argv ) { #ifdef MOAB_HAVE_NETCDF // Get MOAB instance Interface* mb = new( std::nothrow ) Core; if( NULL == mb ) return 1; // Get the material set tag handle Tag mtag; ErrorCode rval; const char* tag_nms[] = { "MATERIAL_SET", "DIRICHLET_SET", "NEUMANN_SET" }; Range sets, set_ents; // Load a file if( argc == 1 ) { cout << "Running default case, loading " << test_file_name << endl; cout << "Usage: " << argv[0] << " <filename>\n" << endl; rval = mb->load_file( test_file_name.c_str() );MB_CHK_ERR( rval ); } else { rval = mb->load_file( argv[argc - 1] );MB_CHK_ERR( rval ); cout << "Loaded mesh file: " << argv[argc - 1] << endl; } // Loop over set types for( int i = 0; i < 3; i++ ) { rval = mb->tag_get_handle( tag_nms[i], 1, MB_TYPE_INTEGER, mtag );MB_CHK_ERR( rval ); // Get all the sets of that type in the mesh sets.clear(); rval = mb->get_entities_by_type_and_tag( 0, MBENTITYSET, &mtag, NULL, 1, sets );MB_CHK_ERR( rval ); // Iterate over each set, getting entities Range::iterator set_it; for( set_it = sets.begin(); set_it != sets.end(); ++set_it ) { EntityHandle this_set = *set_it; // Get the id for this set int set_id; rval = mb->tag_get_data( mtag, &this_set, 1, &set_id );MB_CHK_ERR( rval ); // Get the entities in the set, recursively rval = mb->get_entities_by_handle( this_set, set_ents, true );MB_CHK_ERR( rval ); cout << tag_nms[i] << " " << set_id << " has " << set_ents.size() << " entities:" << endl; // Print the entities contained in this set set_ents.print( " " ); set_ents.clear(); } } delete mb; #else cout << " This test needs moab configured with netcdf \n"; #endif return 0; }
