MOAB: Mesh Oriented datABase
(version 5.4.1)
copy partition info on a mesh file from a point cloud this tool will take an existing h5m phys grid partition file (point cloud) and copy the partition information on a pg2 mesh file, for better viewing with VisIt
example of usage: ./copyPartition -p AtmPhys.h5m -g wholeATM_PG2.h5m -o atm_PG2_part.h5m
the *PG2" style atm mesh is available in E3SM only for pg2 runs, something like --res ne30pg2_r05_oECv3_ICG --compset A_WCYCL1850S_CMIP6 or --res ne4pg2_ne4pg2 --compset FC5AV1C-L
/** @example copyPartition.cpp copy partition info on a mesh file from a point cloud * this tool will take an existing h5m phys grid partition file (point cloud) and copy the * partition information on a pg2 mesh file, for better viewing with VisIt * * example of usage: * ./copyPartition -p AtmPhys.h5m -g wholeATM_PG2.h5m -o atm_PG2_part.h5m * * the *PG2" style atm mesh is available in E3SM only for pg2 runs, something like * --res ne30pg2_r05_oECv3_ICG --compset A_WCYCL1850S_CMIP6 * or * --res ne4pg2_ne4pg2 --compset FC5AV1C-L */ #include "moab/ProgOptions.hpp" #include "moab/Core.hpp" #include <cmath> #include <sstream> using namespace moab; int main( int argc, char* argv[] ) { ProgOptions opts; std::string physfile, pg2file, outfile; opts.addOpt< std::string >( "physgridfile,p", "phys grid filename", &physfile ); opts.addOpt< std::string >( "pg2file,g", "pg2 mesh file", &pg2file ); opts.addOpt< std::string >( "output,o", "output mesh filename", &outfile ); opts.parseCommandLine( argc, argv ); std::cout << "phys grid cloud file: " << physfile << "\n"; std::cout << "pg2 mesh file: " << pg2file << "\n"; std::cout << "output file: " << outfile << "\n"; if( physfile.empty() ) { opts.printHelp(); return 0; } ErrorCode rval; Core* mb = new Core(); rval = mb->load_file( physfile.c_str() );MB_CHK_SET_ERR( rval, "can't load phys grid file" ); Core* mb2 = new Core(); rval = mb2->load_file( pg2file.c_str() );MB_CHK_SET_ERR( rval, "can't load pg2 mesh file" ); Tag globalIDTag1 = mb->globalId_tag(); Tag parti; rval = mb->tag_get_handle( "partition", parti );MB_CHK_SET_ERR( rval, "can't get partition tag phys grid mesh " ); Tag globalIDTag2 = mb2->globalId_tag(); Range verts1; rval = mb->get_entities_by_dimension( 0, 0, verts1 );MB_CHK_SET_ERR( rval, "can't get vertices " ); std::vector< int > partValues; partValues.resize( verts1.size() ); rval = mb->tag_get_data( parti, verts1, &partValues[0] );MB_CHK_SET_ERR( rval, "can't get parts values on vertices " ); Range cells; rval = mb2->get_entities_by_dimension( 0, 2, cells );MB_CHK_SET_ERR( rval, "can't get 2d cells " ); std::vector< int > globalIdsCells; globalIdsCells.resize( cells.size() ); rval = mb2->tag_get_data( globalIDTag2, cells, &globalIdsCells[0] );MB_CHK_SET_ERR( rval, "can't get global ids cells " ); std::vector< int > globalIdsVerts; globalIdsVerts.resize( verts1.size() ); rval = mb->tag_get_data( globalIDTag1, verts1, &globalIdsVerts[0] );MB_CHK_SET_ERR( rval, "can't get global ids cells " ); Tag partTag; rval = mb2->tag_get_handle( "PARALLEL_PARTITION", partTag );MB_CHK_SET_ERR( rval, "can't partition tag " ); Range sets; rval = mb2->get_entities_by_type_and_tag( 0, MBENTITYSET, &partTag, NULL, 1, sets );MB_CHK_ERR( rval ); std::vector< int > setValues; setValues.resize( sets.size() ); rval = mb2->tag_get_data( partTag, sets, &setValues[0] );MB_CHK_ERR( rval ); std::map< int, EntityHandle > valToSet; int i = 0; for( Range::iterator st = sets.begin(); st != sets.end(); ++st, i++ ) { valToSet[setValues[i]] = *st; } // now, every cell will be put into one set, by looking at the global id of cell std::map< int, EntityHandle > gidToCell; i = 0; for( Range::iterator it = cells.begin(); it != cells.end(); ++it, i++ ) { gidToCell[globalIdsCells[i]] = *it; } // empty all sets rval = mb2->clear_meshset( sets );MB_CHK_ERR( rval ); // look now at parti values for vertices, and their global ids for( i = 0; i < (int)verts1.size(); i++ ) { int part = partValues[i]; int gid = globalIdsVerts[i]; EntityHandle set1 = valToSet[part]; EntityHandle cell = gidToCell[gid]; rval = mb2->add_entities( set1, &cell, 1 );MB_CHK_ERR( rval ); } rval = mb2->write_file( outfile.c_str() );MB_CHK_SET_ERR( rval, "can't write file" ); delete mb; delete mb2; return 0; }
