MOAB: Mesh Oriented datABase
(version 5.4.1)
Description: Get entities and report non-vertex entity connectivity and vertex adjacencies.
then delete edges, and write result To run: ./DeleteEdges [meshfile] [outfile]
/** @example GetEntities.cpp * Description: Get entities and report non-vertex entity connectivity and vertex adjacencies.\n * This example shows how to get connectivity and adjacencies.\n * * To run: ./GetEntities [meshfile]\n * (default values can run if users don't specify a mesh file) */ #include "moab/Core.hpp" #include "moab/Range.hpp" #include "moab/CN.hpp" #include <iostream> using namespace moab; using namespace std; #ifndef MESH_DIR #define MESH_DIR "." #endif string test_file_name = string( MESH_DIR ) + string( "/hex01.vtk" ); int main( int argc, char** argv ) { if( argc > 1 ) { // User has input a mesh file test_file_name = argv[1]; } // Instantiate & load a mesh from a file Core* mb = new( std::nothrow ) Core; if( NULL == mb ) return 1; ErrorCode rval = mb->load_mesh( test_file_name.c_str() );MB_CHK_ERR( rval ); Range ents; // Get all entities in the database rval = mb->get_entities_by_handle( 0, ents );MB_CHK_ERR( rval ); for( Range::iterator it = ents.begin(); it != ents.end(); ++it ) { if( MBVERTEX == mb->type_from_handle( *it ) ) { Range adjs; rval = mb->get_adjacencies( &( *it ), 1, 3, false, adjs );MB_CHK_ERR( rval ); cout << "Vertex " << mb->id_from_handle( *it ) << " adjacencies:" << endl; adjs.print(); } else if( mb->type_from_handle( *it ) < MBENTITYSET ) { const EntityHandle* connect; int num_connect; rval = mb->get_connectivity( *it, connect, num_connect );MB_CHK_ERR( rval ); cout << CN::EntityTypeName( mb->type_from_handle( *it ) ) << " " << mb->id_from_handle( *it ) << " vertex connectivity is: "; for( int i = 0; i < num_connect; i++ ) cout << mb->id_from_handle( connect[i] ) << " "; cout << endl; } } delete mb; return 0; }
