MOAB: Mesh Oriented datABase
(version 5.4.1)
Description: Get the sets representing materials and Dirichlet/Neumann boundary conditions and list their contents.
This example shows how to get entity sets, and tags on those sets.
To run: ./SetsNTags [meshfile]
(default values can run if users don't specify a mesh file)
/** @example SetsNTags.cpp * Description: Get the sets representing materials and Dirichlet/Neumann boundary conditions and * list their contents.\n This example shows how to get entity sets, and tags on those sets. * * To run: ./SetsNTags [meshfile]\n * (default values can run if users don't specify a mesh file) */ #include "moab/Core.hpp" #include "moab/Interface.hpp" #include "moab/Range.hpp" #include "MBTagConventions.hpp" #include <iostream> using namespace moab; using namespace std; #ifndef MESH_DIR #define MESH_DIR "." #endif string test_file_name = string( MESH_DIR ) + string( "/hex01.vtk" ); // Tag names for these conventional tags come from MBTagConventions.hpp const char* tag_nms[] = { MATERIAL_SET_TAG_NAME, DIRICHLET_SET_TAG_NAME, NEUMANN_SET_TAG_NAME }; int main( int argc, char** argv ) { // Get the material set tag handle Tag mtag; ErrorCode rval; Range sets, set_ents; // Get MOAB instance Interface* mb = new( std::nothrow ) Core; if( NULL == mb ) return 1; // Need option handling here for input filename if( argc > 1 ) { // User has input a mesh file test_file_name = argv[1]; } // Load a file rval = mb->load_file( test_file_name.c_str() );MB_CHK_ERR( rval ); // Loop over set types for( int i = 0; i < 3; i++ ) { // Get the tag handle for this tag name; tag should already exist (it was created during // file read) rval = mb->tag_get_handle( tag_nms[i], 1, MB_TYPE_INTEGER, mtag );MB_CHK_ERR( rval ); // Get all the sets having that tag (with any value for that tag) sets.clear(); rval = mb->get_entities_by_type_and_tag( 0, MBENTITYSET, &mtag, NULL, 1, sets );MB_CHK_ERR( rval ); // Iterate over each set, getting the entities and printing them Range::iterator set_it; for( set_it = sets.begin(); set_it != sets.end(); ++set_it ) { // Get the id for this set int set_id; rval = mb->tag_get_data( mtag, &( *set_it ), 1, &set_id );MB_CHK_ERR( rval ); // Get the entities in the set, recursively rval = mb->get_entities_by_handle( *set_it, set_ents, true );MB_CHK_ERR( rval ); cout << tag_nms[i] << " " << set_id << " has " << set_ents.size() << " entities:" << endl; set_ents.print( " " ); set_ents.clear(); } } delete mb; return 0; }
