MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "moab/Range.hpp" 00002 #include "TestUtil.hpp" 00003 00004 #include "moab/Core.hpp" 00005 #include "moab/ParallelComm.hpp" 00006 #include "moab/Skinner.hpp" 00007 #include "MBTagConventions.hpp" 00008 #include "moab/CN.hpp" 00009 #include "MBParallelConventions.h" 00010 00011 #include <iostream> 00012 #include <sstream> 00013 #include <algorithm> 00014 #include "moab_mpi.h" 00015 #include <unistd.h> 00016 #include <cfloat> 00017 #include <cstdio> 00018 #include <ctime> 00019 00020 using namespace moab; 00021 00022 #ifdef MESHDIR 00023 const char* InputFile = STRINGIFY( MESHDIR ) "/ptest.cub"; 00024 const char* InputMix = STRINGIFY( MESHDIR ) "/io/mix.h5m"; 00025 const char* InputOneSide = STRINGIFY( MESHDIR ) "/io/oneside.h5m"; 00026 #else 00027 #error Specify MESHDIR to compile test 00028 #endif 00029 00030 void load_and_partition( Interface& moab, const char* filename, bool print_debug = false ); 00031 00032 void save_and_load_on_root( Interface& moab, const char* tmp_filename ); 00033 00034 void check_identical_mesh( Interface& moab1, Interface& moab2 ); 00035 00036 void test_write_elements(); 00037 void test_write_shared_sets(); 00038 void test_var_length_parallel(); 00039 00040 void test_read_elements_common( bool by_rank, int intervals, bool print_time, const char* extra_opts = 0 ); 00041 00042 int ReadIntervals = 0; 00043 void test_read_elements() 00044 { 00045 test_read_elements_common( false, ReadIntervals, false ); 00046 } 00047 void test_read_elements_by_rank() 00048 { 00049 test_read_elements_common( true, ReadIntervals, false ); 00050 } 00051 void test_bcast_summary() 00052 { 00053 test_read_elements_common( false, ReadIntervals, false, "BCAST_SUMMARY=yes" ); 00054 } 00055 void test_read_summary() 00056 { 00057 test_read_elements_common( false, ReadIntervals, false, "BCAST_SUMMARY=no" ); 00058 } 00059 void test_read_time(); 00060 00061 void test_read_tags(); 00062 void test_read_global_tags(); 00063 void test_read_sets_common( const char* extra_opts = 0 ); 00064 void test_read_sets() 00065 { 00066 test_read_sets_common(); 00067 } 00068 void test_read_sets_bcast_dups() 00069 { 00070 test_read_sets_common( "BCAST_DUPLICATE_READS=yes" ); 00071 } 00072 void test_read_sets_read_dups() 00073 { 00074 test_read_sets_common( "BCAST_DUPLICATE_READS=no" ); 00075 } 00076 void test_read_bc_sets(); 00077 00078 void test_write_different_element_types(); 00079 void test_write_different_tags(); 00080 void test_write_polygons(); 00081 void test_write_unbalanced(); 00082 void test_write_dense_tags(); 00083 void test_read_non_adjs_side(); 00084 00085 const char PARTITION_TAG[] = "PARTITION"; 00086 00087 bool KeepTmpFiles = false; 00088 bool PauseOnStart = false; 00089 bool HyperslabAppend = false; 00090 const int DefaultReadIntervals = 2; 00091 int ReadDebugLevel = 0; 00092 int WriteDebugLevel = 0; 00093 int ReadBlocks = 1; 00094 00095 enum Mode 00096 { 00097 READ_PART, 00098 READ_DELETE, 00099 BCAST_DELETE 00100 }; 00101 const Mode DEFAULT_MODE = READ_PART; 00102 const bool DEFAULT_BY_RANK = false; 00103 00104 std::string get_read_options( bool by_rank = DEFAULT_BY_RANK, Mode mode = DEFAULT_MODE, const char* extra_opts = 0 ); 00105 std::string get_read_options( const char* extra_opts ) 00106 { 00107 return get_read_options( DEFAULT_BY_RANK, DEFAULT_MODE, extra_opts ); 00108 } 00109 std::string get_read_options( bool by_rank, const char* extra_opts ) 00110 { 00111 return get_read_options( by_rank, DEFAULT_MODE, extra_opts ); 00112 } 00113 00114 std::string get_read_options( bool by_rank, Mode mode, const char* extra_opts ) 00115 { 00116 int numproc; 00117 MPI_Comm_size( MPI_COMM_WORLD, &numproc ); 00118 00119 // do parallel read unless only one processor 00120 std::ostringstream str; 00121 if( numproc > 1 ) 00122 { 00123 str << "PARALLEL="; 00124 switch( mode ) 00125 { 00126 case READ_PART: 00127 str << "READ_PART"; 00128 break; 00129 case READ_DELETE: 00130 str << "READ_DELETE"; 00131 break; 00132 case BCAST_DELETE: 00133 str << "BCAST_DELETE"; 00134 break; 00135 } 00136 str << ";PARTITION=" << PARTITION_TAG << ";"; 00137 if( by_rank ) str << "PARTITION_BY_RANK;"; 00138 } 00139 00140 if( extra_opts ) str << extra_opts << ";"; 00141 00142 if( ReadDebugLevel ) str << "DEBUG_IO=" << ReadDebugLevel << ";"; 00143 00144 if( HyperslabAppend ) str << "HYPERSLAB_APPEND;HYPERSLAB_SELECT_LIMIT=2147483647"; 00145 00146 return str.str(); 00147 } 00148 00149 int main( int argc, char* argv[] ) 00150 { 00151 int err = MPI_Init( &argc, &argv ); 00152 CHECK( !err ); 00153 00154 for( int i = 1; i < argc; ++i ) 00155 { 00156 if( !strcmp( argv[i], "-k" ) ) 00157 KeepTmpFiles = true; 00158 else if( !strcmp( argv[i], "-p" ) ) 00159 PauseOnStart = true; 00160 else if( !strcmp( argv[i], "-R" ) ) 00161 { 00162 ++i; 00163 CHECK( i < argc ); 00164 ReadIntervals = atoi( argv[i] ); 00165 CHECK( ReadIntervals > 0 ); 00166 } 00167 else if( !strcmp( argv[i], "-b" ) ) 00168 { 00169 ++i; 00170 CHECK( i < argc ); 00171 ReadBlocks = atoi( argv[i] ); 00172 CHECK( ReadBlocks > 0 ); 00173 } 00174 else if( !strcmp( argv[i], "-r" ) ) 00175 { 00176 ++i; 00177 CHECK( i < argc ); 00178 ReadDebugLevel = atoi( argv[i] ); 00179 CHECK( ReadDebugLevel > 0 ); 00180 } 00181 else if( !strcmp( argv[i], "-w" ) ) 00182 { 00183 ++i; 00184 CHECK( i < argc ); 00185 WriteDebugLevel = atoi( argv[i] ); 00186 CHECK( WriteDebugLevel > 0 ); 00187 } 00188 else if( !strcmp( argv[i], "-A" ) ) 00189 HyperslabAppend = true; 00190 else 00191 { 00192 std::cerr << "Usage: " << argv[0] 00193 << " [-k] [-p] [-R <intervals>] [-r <level>] [-w <level>] [-b <blocks>] [-A]" << std::endl; 00194 return 1; 00195 } 00196 } 00197 00198 if( PauseOnStart ) 00199 { 00200 int rank; 00201 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 00202 printf( "Rank %2d PID %lu\n", rank, (unsigned long)getpid() ); 00203 sleep( 30 ); 00204 } 00205 00206 int result = 0; 00207 if( ReadIntervals ) 00208 { 00209 result = RUN_TEST( test_read_time ); 00210 } 00211 else 00212 { 00213 ReadIntervals = DefaultReadIntervals; 00214 result += RUN_TEST( test_write_elements ); 00215 MPI_Barrier( MPI_COMM_WORLD ); 00216 result += RUN_TEST( test_write_shared_sets ); 00217 MPI_Barrier( MPI_COMM_WORLD ); 00218 result += RUN_TEST( test_var_length_parallel ); 00219 MPI_Barrier( MPI_COMM_WORLD ); 00220 result += RUN_TEST( test_read_elements ); 00221 MPI_Barrier( MPI_COMM_WORLD ); 00222 result += RUN_TEST( test_read_elements_by_rank ); 00223 MPI_Barrier( MPI_COMM_WORLD ); 00224 result += RUN_TEST( test_read_tags ); 00225 MPI_Barrier( MPI_COMM_WORLD ); 00226 result += RUN_TEST( test_read_global_tags ); 00227 MPI_Barrier( MPI_COMM_WORLD ); 00228 result += RUN_TEST( test_read_sets ); 00229 MPI_Barrier( MPI_COMM_WORLD ); 00230 result += RUN_TEST( test_read_sets_bcast_dups ); 00231 MPI_Barrier( MPI_COMM_WORLD ); 00232 result += RUN_TEST( test_read_sets_read_dups ); 00233 MPI_Barrier( MPI_COMM_WORLD ); 00234 result += RUN_TEST( test_read_bc_sets ); 00235 MPI_Barrier( MPI_COMM_WORLD ); 00236 result += RUN_TEST( test_write_different_element_types ); 00237 MPI_Barrier( MPI_COMM_WORLD ); 00238 result += RUN_TEST( test_write_different_tags ); 00239 MPI_Barrier( MPI_COMM_WORLD ); 00240 result += RUN_TEST( test_write_polygons ); 00241 MPI_Barrier( MPI_COMM_WORLD ); 00242 result += RUN_TEST( test_write_unbalanced ); 00243 MPI_Barrier( MPI_COMM_WORLD ); 00244 result += RUN_TEST( test_write_dense_tags ); 00245 MPI_Barrier( MPI_COMM_WORLD ); 00246 result += RUN_TEST( test_read_non_adjs_side ); 00247 MPI_Barrier( MPI_COMM_WORLD ); 00248 } 00249 00250 MPI_Finalize(); 00251 return result; 00252 } 00253 00254 /* Assume geometric topology sets correspond to interface sets 00255 * in that the entities contained inclusively in a geometric 00256 * topology set must be shared by the same set of processors. 00257 * As we partition based on geometric volumes, this assumption 00258 * should aways be true. Print for each geometric topology set 00259 * the list of processors it is shared with. 00260 */ 00261 void print_partitioned_entities( Interface& moab, bool list_non_shared = false ) 00262 { 00263 ErrorCode rval; 00264 int size, rank; 00265 std::vector< int > ent_procs( MAX_SHARING_PROCS ), tmp_ent_procs( MAX_SHARING_PROCS ); 00266 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 00267 MPI_Comm_size( MPI_COMM_WORLD, &size ); 00268 00269 // expect shared entities to correspond to geometric sets 00270 00271 // get tags for parallel data 00272 Tag sharedp_tag, sharedps_tag, sharedh_tag, sharedhs_tag, pstatus_tag; 00273 rval = moab.tag_get_handle( PARALLEL_SHARED_PROC_TAG_NAME, 1, MB_TYPE_INTEGER, sharedp_tag );CHECK_ERR( rval ); 00274 rval = moab.tag_get_handle( PARALLEL_SHARED_PROCS_TAG_NAME, MAX_SHARING_PROCS, MB_TYPE_INTEGER, sharedps_tag );CHECK_ERR( rval ); 00275 rval = moab.tag_get_handle( PARALLEL_SHARED_HANDLE_TAG_NAME, 1, MB_TYPE_HANDLE, sharedh_tag );CHECK_ERR( rval ); 00276 rval = moab.tag_get_handle( PARALLEL_SHARED_HANDLES_TAG_NAME, MAX_SHARING_PROCS, MB_TYPE_HANDLE, sharedhs_tag );CHECK_ERR( rval ); 00277 rval = moab.tag_get_handle( PARALLEL_STATUS_TAG_NAME, 1, MB_TYPE_OPAQUE, pstatus_tag );CHECK_ERR( rval ); 00278 00279 // for each geometric entity, check which processor we are sharing 00280 // entities with 00281 Tag geom_tag, id_tag; 00282 rval = moab.tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, geom_tag );CHECK_ERR( rval ); 00283 id_tag = moab.globalId_tag(); 00284 const char* topo_names_s[] = { "Vertex", "Curve", "Surface", "Volume" }; 00285 // const char* topo_names_p[] = { "Vertices", "Curves", "Surfaces", "Volumes" }; 00286 std::ostringstream buffer; // buffer output in an attempt to prevent lines from different 00287 // processsors being mixed up. 00288 for( int t = 0; t < 4; ++t ) 00289 { 00290 Range geom; 00291 int dim = t; 00292 const void* ptr = &dim; 00293 rval = moab.get_entities_by_type_and_tag( 0, MBENTITYSET, &geom_tag, &ptr, 1, geom );CHECK_ERR( rval ); 00294 00295 // for each geometric entity of dimension 't' 00296 for( Range::const_iterator i = geom.begin(); i != geom.end(); ++i ) 00297 { 00298 EntityHandle set = *i; 00299 int id; 00300 rval = moab.tag_get_data( id_tag, &set, 1, &id );CHECK_ERR( rval ); 00301 00302 buffer.clear(); 00303 00304 // get entities contained in this set but not its children 00305 Range entities, tmp_entities, children, diff; 00306 rval = moab.get_entities_by_handle( set, entities );CHECK_ERR( rval ); 00307 rval = moab.get_child_meshsets( set, children );CHECK_ERR( rval ); 00308 for( Range::const_iterator j = children.begin(); j != children.end(); ++j ) 00309 { 00310 tmp_entities.clear(); 00311 rval = moab.get_entities_by_handle( *j, tmp_entities );CHECK_ERR( rval ); 00312 diff = subtract( entities, tmp_entities ); 00313 entities.swap( diff ); 00314 } 00315 00316 // for each entity, check owning processors 00317 std::vector< char > status_flags( entities.size(), 0 ); 00318 std::vector< int > shared_procs( entities.size(), 0 ); 00319 rval = moab.tag_get_data( pstatus_tag, entities, &status_flags[0] ); 00320 if( MB_TAG_NOT_FOUND == rval ) 00321 { 00322 // keep default values of zero (not shared) 00323 } 00324 CHECK_ERR( rval ); 00325 unsigned num_shared = 0, num_owned = 0; 00326 for( size_t j = 0; j < status_flags.size(); ++j ) 00327 { 00328 num_shared += !!( status_flags[j] & PSTATUS_SHARED ); 00329 num_owned += !( status_flags[j] & PSTATUS_NOT_OWNED ); 00330 } 00331 00332 if( !num_shared ) 00333 { 00334 if( list_non_shared ) 00335 buffer << rank << ":\t" << topo_names_s[t] << " " << id << ":\t" 00336 << "not shared" << std::endl; 00337 } 00338 else if( num_shared != entities.size() ) 00339 { 00340 buffer << rank << ":\t" << topo_names_s[t] << " " << id << ":\t" 00341 << "ERROR: " << num_shared << " of " << entities.size() << " entities marked as 'shared'" 00342 << std::endl; 00343 } 00344 else if( num_owned && num_owned != entities.size() ) 00345 { 00346 buffer << rank << ":\t" << topo_names_s[t] << " " << id << ":\t" 00347 << "ERROR: " << num_owned << " of " << entities.size() << " entities owned by this processor" 00348 << std::endl; 00349 } 00350 else 00351 { 00352 rval = moab.tag_get_data( sharedp_tag, entities, &shared_procs[0] );CHECK_ERR( rval ); 00353 int proc = shared_procs[0]; 00354 bool all_match = true; 00355 for( size_t j = 1; j < shared_procs.size(); ++j ) 00356 if( shared_procs[j] != proc ) all_match = false; 00357 if( !all_match ) 00358 { 00359 buffer << rank << ":\t" << topo_names_s[t] << " " << id << ":\t" 00360 << "ERROR: processsor IDs do not match!" << std::endl; 00361 } 00362 else if( proc != -1 ) 00363 { 00364 buffer << rank << ":\t" << topo_names_s[t] << " " << id << ":\t" 00365 << "shared with processor " << proc; 00366 if( num_owned ) buffer << " (owned by this processor)"; 00367 buffer << std::endl; 00368 } 00369 else if( entities.empty() ) 00370 { 00371 buffer << rank << ":\t" << topo_names_s[t] << " " << id << ":\t" 00372 << "ERROR: no entities!" << std::endl; 00373 } 00374 else 00375 { 00376 Range::const_iterator j = entities.begin(); 00377 rval = moab.tag_get_data( sharedps_tag, &*j, 1, &ent_procs[0] );CHECK_ERR( rval ); 00378 for( ++j; j != entities.end(); ++j ) 00379 { 00380 rval = moab.tag_get_data( sharedps_tag, &*j, 1, &tmp_ent_procs[0] );CHECK_ERR( rval ); 00381 if( ent_procs != tmp_ent_procs ) all_match = false; 00382 } 00383 if( !all_match ) 00384 { 00385 buffer << rank << ":\t" << topo_names_s[t] << " " << id << ":\t" 00386 << "ERROR: processsor IDs do not match!" << std::endl; 00387 } 00388 else 00389 { 00390 buffer << rank << ":\t" << topo_names_s[t] << " " << id << ":\t" 00391 << "processors "; 00392 for( int k = 0; k < MAX_SHARING_PROCS; ++k ) 00393 if( ent_procs[k] != -1 ) buffer << ent_procs[k] << ", "; 00394 if( num_owned ) buffer << " (owned by this processor)"; 00395 buffer << std::endl; 00396 } 00397 } 00398 } 00399 } 00400 } 00401 for( int i = 0; i < size; ++i ) 00402 { 00403 MPI_Barrier( MPI_COMM_WORLD ); 00404 if( i == rank ) 00405 { 00406 std::cout << buffer.str(); 00407 std::cout.flush(); 00408 } 00409 } 00410 } 00411 00412 void load_and_partition( Interface& moab, const char* filename, bool print ) 00413 { 00414 ErrorCode rval; 00415 00416 rval = moab.load_file( filename, 0, 00417 "PARALLEL=READ_DELETE;" 00418 "PARTITION=GEOM_DIMENSION;PARTITION_VAL=3;" 00419 "PARTITION_DISTRIBUTE;" 00420 "PARALLEL_RESOLVE_SHARED_ENTS" ); 00421 00422 if( print ) print_partitioned_entities( moab ); 00423 00424 CHECK_ERR( rval ); 00425 } 00426 00427 void save_and_load_on_root( Interface& moab, const char* tmp_filename ) 00428 { 00429 ErrorCode rval; 00430 int procnum; 00431 MPI_Comm_rank( MPI_COMM_WORLD, &procnum ); 00432 00433 const char* opt = "PARALLEL=WRITE_PART"; 00434 std::string str; 00435 if( WriteDebugLevel ) 00436 { 00437 std::ostringstream s; 00438 s << opt << ";DEBUG_IO=" << WriteDebugLevel; 00439 str = s.str(); 00440 opt = str.c_str(); 00441 } 00442 rval = moab.write_file( tmp_filename, 0, opt ); 00443 if( MB_SUCCESS != rval ) 00444 { 00445 std::cerr << "Parallel write failed on processor " << procnum << std::endl; 00446 if( procnum == 0 && !KeepTmpFiles ) remove( tmp_filename );CHECK_ERR( rval ); 00447 } 00448 00449 if( procnum == 0 && KeepTmpFiles ) std::cout << "Wrote file: \"" << tmp_filename << "\"\n"; 00450 00451 // All created pcomm objects should be retrieved (with the pcomm tag) and 00452 // deleted at this time. Otherwise, the memory used by them will be leaked 00453 // as the pcomm tag will be deleted by moab.delete_mesh() below. 00454 std::vector< ParallelComm* > pc_list; 00455 ParallelComm::get_all_pcomm( &moab, pc_list ); 00456 for( std::vector< ParallelComm* >::iterator vit = pc_list.begin(); vit != pc_list.end(); ++vit ) 00457 delete *vit; 00458 00459 moab.delete_mesh(); 00460 std::vector< Tag > tags; 00461 rval = moab.tag_get_tags( tags );CHECK_ERR( rval ); 00462 for( size_t i = 0; i < tags.size(); ++i ) 00463 { 00464 rval = moab.tag_delete( tags[i] );CHECK_ERR( rval ); 00465 } 00466 00467 if( procnum == 0 ) 00468 { 00469 rval = moab.load_file( tmp_filename ); 00470 if( !KeepTmpFiles ) remove( tmp_filename );CHECK_ERR( rval ); 00471 } 00472 } 00473 00474 void count_owned_entities( Interface& moab, int counts[MBENTITYSET] ) 00475 { 00476 ErrorCode rval; 00477 ParallelComm* pcomm = ParallelComm::get_pcomm( &moab, 0 ); 00478 CHECK( 0 != pcomm ); 00479 std::fill( counts, counts + MBENTITYSET, 0u ); 00480 00481 for( EntityType t = MBVERTEX; t < MBENTITYSET; ++t ) 00482 { 00483 Range range; 00484 rval = moab.get_entities_by_type( 0, t, range );CHECK_ERR( rval ); 00485 if( !range.empty() ) rval = pcomm->filter_pstatus( range, PSTATUS_NOT_OWNED, PSTATUS_NOT );CHECK_ERR( rval ); 00486 counts[t] = range.size(); 00487 } 00488 } 00489 00490 void check_identical_mesh( Interface& mb1, Interface& mb2 ) 00491 { 00492 ErrorCode rval; 00493 std::map< EntityHandle, EntityHandle > entmap; 00494 00495 // match vertices by coordinate 00496 Range r1, r2; 00497 Range::iterator i1, i2; 00498 rval = mb1.get_entities_by_type( 0, MBVERTEX, r1 );CHECK_ERR( rval ); 00499 rval = mb2.get_entities_by_type( 0, MBVERTEX, r2 );CHECK_ERR( rval ); 00500 CHECK_EQUAL( r1.size(), r2.size() ); 00501 for( i1 = r1.begin(); i1 != r1.end(); ++i1 ) 00502 { 00503 double coords1[3]; 00504 rval = mb1.get_coords( &*i1, 1, coords1 );CHECK_ERR( rval ); 00505 for( i2 = r2.begin(); i2 != r2.end(); ++i2 ) 00506 { 00507 double coords2[3]; 00508 rval = mb2.get_coords( &*i2, 1, coords2 );CHECK_ERR( rval ); 00509 coords2[0] -= coords1[0]; 00510 coords2[1] -= coords1[1]; 00511 coords2[2] -= coords1[2]; 00512 double lensqr = coords2[0] * coords2[0] + coords2[1] * coords2[1] + coords2[2] * coords2[2]; 00513 if( lensqr < 1e-12 ) break; 00514 } 00515 CHECK( i2 != r2.end() ); 00516 entmap[*i2] = *i1; 00517 r2.erase( i2 ); 00518 } 00519 00520 // match element connectivity 00521 std::vector< EntityHandle > conn1, conn2; 00522 for( EntityType t = MBEDGE; t < MBENTITYSET; ++t ) 00523 { 00524 r1.clear(); 00525 rval = mb1.get_entities_by_type( 0, t, r1 );CHECK_ERR( rval ); 00526 r2.clear(); 00527 rval = mb2.get_entities_by_type( 0, t, r2 );CHECK_ERR( rval ); 00528 CHECK_EQUAL( r1.size(), r2.size() ); 00529 00530 for( i1 = r1.begin(); i1 != r1.end(); ++i1 ) 00531 { 00532 conn1.clear(); 00533 rval = mb1.get_connectivity( &*i1, 1, conn1 );CHECK_ERR( rval ); 00534 for( i2 = r2.begin(); i2 != r2.end(); ++i2 ) 00535 { 00536 conn2.clear(); 00537 rval = mb2.get_connectivity( &*i2, 1, conn2 );CHECK_ERR( rval ); 00538 if( conn1.size() != conn2.size() ) continue; 00539 for( std::vector< EntityHandle >::iterator j = conn2.begin(); j != conn2.end(); ++j ) 00540 *j = entmap[*j]; 00541 if( conn1 == conn2 ) break; 00542 } 00543 00544 CHECK( i2 != r2.end() ); 00545 entmap[*i2] = *i1; 00546 r2.erase( i2 ); 00547 } 00548 } 00549 } 00550 00551 void test_write_elements() 00552 { 00553 int proc_counts[MBENTITYSET], all_counts[MBENTITYSET], file_counts[MBENTITYSET]; 00554 int err, rank; 00555 ErrorCode rval; 00556 err = MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 00557 CHECK( !err ); 00558 00559 // load and partition a .cub file 00560 Core moab_instance; 00561 Interface& moab = moab_instance; 00562 load_and_partition( moab, InputFile, false ); 00563 00564 // count number of owned entities of each type and sum over all procs 00565 count_owned_entities( moab, proc_counts ); 00566 std::fill( all_counts, all_counts + MBENTITYSET, 0u ); 00567 err = MPI_Allreduce( proc_counts, all_counts, MBENTITYSET, MPI_INT, MPI_SUM, MPI_COMM_WORLD ); 00568 CHECK( !err ); 00569 00570 // do parallel write and on root proc do serial read of written file 00571 save_and_load_on_root( moab, "test_write_elements.h5m" ); 00572 if( rank == 0 ) 00573 { 00574 for( EntityType t = MBVERTEX; t < MBENTITYSET; ++t ) 00575 { 00576 rval = moab.get_number_entities_by_type( 0, t, file_counts[t] );CHECK_ERR( rval ); 00577 } 00578 } 00579 00580 // check that sum of owned entities equals number of entities from serial read 00581 00582 err = MPI_Bcast( file_counts, MBENTITYSET, MPI_INT, 0, MPI_COMM_WORLD ); 00583 CHECK( !err ); 00584 00585 bool all_equal = true; 00586 for( EntityType t = MBVERTEX; t < MBENTITYSET; ++t ) 00587 if( file_counts[t] != all_counts[t] ) all_equal = false; 00588 00589 if( rank == 0 && !all_equal ) 00590 { 00591 std::cerr << "Type\tPartnd\tWritten" << std::endl; 00592 for( EntityType t = MBVERTEX; t < MBENTITYSET; ++t ) 00593 std::cerr << CN::EntityTypeName( t ) << '\t' << all_counts[t] << '\t' << file_counts[t] << std::endl; 00594 } 00595 00596 CHECK( all_equal ); 00597 00598 // on root processor, do serial read of original .cub file and compare 00599 00600 if( rank == 0 ) 00601 { 00602 Core moab2; 00603 rval = moab2.load_file( InputFile );CHECK_ERR( rval ); 00604 check_identical_mesh( moab, moab2 ); 00605 } 00606 } 00607 00608 bool check_sets_sizes( Interface& mb1, EntityHandle set1, Interface& mb2, EntityHandle set2 ) 00609 { 00610 ErrorCode rval; 00611 bool result = true; 00612 for( EntityType t = MBVERTEX; t < MBMAXTYPE; ++t ) 00613 { 00614 int count1, count2; 00615 rval = mb1.get_number_entities_by_type( set1, t, count1 );CHECK_ERR( rval ); 00616 rval = mb2.get_number_entities_by_type( set2, t, count2 );CHECK_ERR( rval ); 00617 if( count1 != count2 ) 00618 { 00619 std::cerr << "Sets differ in number of " << CN::EntityTypeName( t ) << " : " << count1 << " vs. " << count2 00620 << std::endl; 00621 result = false; 00622 } 00623 } 00624 return result; 00625 } 00626 00627 void test_write_shared_sets() 00628 { 00629 int err, rank, size; 00630 ErrorCode rval; 00631 err = MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 00632 CHECK( !err ); 00633 err = MPI_Comm_size( MPI_COMM_WORLD, &size ); 00634 CHECK( !err ); 00635 00636 Core moab_instance; 00637 Interface& moab = moab_instance; 00638 load_and_partition( moab, InputFile ); 00639 save_and_load_on_root( moab, "test_write_shared_sets.h5m" ); 00640 00641 if( rank != 0 ) return; 00642 00643 Core moab2_instance; 00644 Interface& moab2 = moab2_instance; 00645 rval = moab2.load_file( InputFile );CHECK_ERR( rval ); 00646 00647 Tag mattag1, mattag2; 00648 rval = moab.tag_get_handle( MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mattag1 );CHECK_ERR( rval ); 00649 rval = moab2.tag_get_handle( MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mattag2 );CHECK_ERR( rval ); 00650 00651 Range matsets; 00652 rval = moab2.get_entities_by_type_and_tag( 0, MBENTITYSET, &mattag2, 0, 1, matsets );CHECK_ERR( rval ); 00653 for( Range::iterator i = matsets.begin(); i != matsets.end(); ++i ) 00654 { 00655 int block_id; 00656 rval = moab2.tag_get_data( mattag2, &*i, 1, &block_id );CHECK_ERR( rval ); 00657 00658 Range tmpents; 00659 void* tagdata[] = { &block_id }; 00660 rval = moab.get_entities_by_type_and_tag( 0, MBENTITYSET, &mattag1, tagdata, 1, tmpents ); 00661 if( tmpents.size() != 1 ) std::cerr << tmpents.size() << " sets with material set id " << block_id << std::endl; 00662 CHECK_EQUAL( (int)tmpents.size(), 1 ); 00663 00664 CHECK( check_sets_sizes( moab2, *i, moab, tmpents.front() ) ); 00665 } 00666 } 00667 00668 void test_var_length_parallel() 00669 { 00670 Range::const_iterator i; 00671 ErrorCode rval; 00672 Core moab; 00673 Interface& mb = moab; 00674 Range verts; 00675 Tag vartag; 00676 const char* filename = "var-len-para.h5m"; 00677 const char* tagname = "ParVar"; 00678 00679 // If this tag doesn't exist, writer will fail 00680 Tag junk_tag; 00681 mb.tag_get_handle( PARALLEL_GID_TAG_NAME, 1, MB_TYPE_INTEGER, junk_tag, MB_TAG_DENSE | MB_TAG_EXCL ); 00682 00683 int numproc, rank; 00684 MPI_Comm_size( MPI_COMM_WORLD, &numproc ); 00685 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 00686 00687 // Create N+1 vertices on each processor, where N is the rank 00688 std::vector< double > coords( 3 * rank + 3, (double)rank ); 00689 rval = mb.create_vertices( &coords[0], rank + 1, verts );CHECK_ERR( rval ); 00690 00691 // Create a var-len tag 00692 rval = mb.tag_get_handle( tagname, 0, MB_TYPE_INTEGER, vartag, MB_TAG_DENSE | MB_TAG_VARLEN | MB_TAG_EXCL );CHECK_ERR( rval ); 00693 00694 // Write data on each vertex: 00695 // { n, rank, rank+1, ..., rank+n-1 } where n >= 1 00696 std::vector< int > data; 00697 rval = MB_SUCCESS; 00698 for( i = verts.begin(); i != verts.end(); ++i ) 00699 { 00700 EntityHandle h = *i; 00701 const int n = h % 7 + 1; 00702 data.resize( n + 1 ); 00703 data[0] = n; 00704 for( int j = 0; j < n; ++j ) 00705 data[j + 1] = rank + j; 00706 const int s = ( n + 1 ); 00707 const void* ptrarr[] = { &data[0] }; 00708 ErrorCode tmperr = mb.tag_set_by_ptr( vartag, &h, 1, ptrarr, &s ); 00709 if( MB_SUCCESS != tmperr ) rval = tmperr; 00710 } 00711 CHECK_ERR( rval ); 00712 00713 // Write file 00714 const char* opt = "PARALLEL=WRITE_PART"; 00715 std::string str; 00716 if( WriteDebugLevel ) 00717 { 00718 std::ostringstream s; 00719 s << opt << ";DEBUG_IO=" << WriteDebugLevel; 00720 str = s.str(); 00721 opt = str.c_str(); 00722 } 00723 rval = mb.write_file( filename, "MOAB", opt );CHECK_ERR( rval ); 00724 00725 // Read file. We only reset and re-read the file on the 00726 // root processor. All other processors keep the pre-write 00727 // mesh. This allows many of the tests to be run on all 00728 // processors. Running the tests on the pre-write mesh on 00729 // non-root processors allows us to verify that any problems 00730 // are due to the file API rather than some other bug. 00731 ErrorCode rval2 = rval = MB_SUCCESS; 00732 if( !rank ) 00733 { 00734 moab.~Core(); 00735 new( &moab ) Core; 00736 rval = mb.load_mesh( filename ); 00737 if( !KeepTmpFiles ) remove( filename ); 00738 rval2 = mb.tag_get_handle( tagname, 0, MB_TYPE_INTEGER, vartag ); 00739 } 00740 CHECK_ERR( rval );CHECK_ERR( rval2 ); 00741 00742 // Check that tag is correct 00743 int tag_size; 00744 rval = mb.tag_get_length( vartag, tag_size ); 00745 CHECK_EQUAL( MB_VARIABLE_DATA_LENGTH, rval ); 00746 TagType storage; 00747 rval = mb.tag_get_type( vartag, storage );CHECK_ERR( rval ); 00748 CHECK_EQUAL( MB_TAG_DENSE, storage ); 00749 DataType type; 00750 rval = mb.tag_get_data_type( vartag, type );CHECK_ERR( rval ); 00751 CHECK_EQUAL( MB_TYPE_INTEGER, type ); 00752 00753 // get vertices 00754 verts.clear(); 00755 rval = mb.get_entities_by_type( 0, MBVERTEX, verts );CHECK_ERR( rval ); 00756 00757 // Check consistency of tag data on each vertex 00758 // and count the number of vertices for each rank. 00759 std::vector< int > vtx_counts( numproc, 0 ); 00760 for( i = verts.begin(); i != verts.end(); ++i ) 00761 { 00762 EntityHandle h = *i; 00763 int size = -1; 00764 const void* ptrarr[1] = { 0 }; 00765 rval = mb.tag_get_by_ptr( vartag, &h, 1, ptrarr, &size );CHECK_ERR( rval ); 00766 const int* tag_data = reinterpret_cast< const int* >( ptrarr[0] ); 00767 CHECK( size >= 2 ); 00768 CHECK( NULL != tag_data ); 00769 CHECK_EQUAL( size - 1, tag_data[0] ); 00770 CHECK( tag_data[1] >= 0 && tag_data[1] < numproc ); 00771 ++vtx_counts[tag_data[1]]; 00772 for( int j = 1; j < size - 1; ++j ) 00773 CHECK_EQUAL( tag_data[1] + j, tag_data[1 + j] ); 00774 } 00775 00776 // Check number of vertices for each rank 00777 for( int j = 0; j < numproc; ++j ) 00778 { 00779 // Only root should have data for other processors. 00780 if( rank == 0 || rank == j ) 00781 CHECK_EQUAL( j + 1, vtx_counts[j] ); 00782 else 00783 CHECK_EQUAL( 0, vtx_counts[j] ); 00784 } 00785 } 00786 00787 // create row of cubes of mesh 00788 void create_input_file( const char* file_name, 00789 int intervals, 00790 int num_cpu, 00791 int blocks_per_cpu = 1, 00792 const char* ijk_vert_tag_name = 0, 00793 const char* ij_set_tag_name = 0, 00794 const char* global_tag_name = 0, 00795 const int* global_mesh_value = 0, 00796 const int* global_default_value = 0, 00797 bool create_bcsets = false ) 00798 { 00799 Core moab; 00800 Interface& mb = moab; 00801 ErrorCode rval; 00802 00803 Tag ijk_vert_tag = 0, ij_set_tag = 0, global_tag = 0; 00804 if( ijk_vert_tag_name ) 00805 { 00806 rval = mb.tag_get_handle( ijk_vert_tag_name, 3, MB_TYPE_INTEGER, ijk_vert_tag, MB_TAG_EXCL | MB_TAG_DENSE );CHECK_ERR( rval ); 00807 } 00808 if( ij_set_tag_name ) 00809 { 00810 rval = mb.tag_get_handle( ij_set_tag_name, 2, MB_TYPE_INTEGER, ij_set_tag, MB_TAG_SPARSE | MB_TAG_EXCL );CHECK_ERR( rval ); 00811 } 00812 if( global_tag_name ) 00813 { 00814 rval = mb.tag_get_handle( global_tag_name, 1, MB_TYPE_INTEGER, global_tag, MB_TAG_DENSE | MB_TAG_EXCL, 00815 global_default_value );CHECK_ERR( rval ); 00816 if( global_mesh_value ) 00817 { 00818 EntityHandle root = 0; 00819 rval = mb.tag_set_data( global_tag, &root, 1, global_mesh_value );CHECK_ERR( rval ); 00820 } 00821 } 00822 00823 const int num_blk = num_cpu * blocks_per_cpu; 00824 int iv = intervals + 1, ii = num_blk * intervals + 1; 00825 std::vector< EntityHandle > verts( iv * iv * ii ); 00826 int idx = 0; 00827 for( int i = 0; i < ii; ++i ) 00828 { 00829 for( int j = 0; j < iv; ++j ) 00830 { 00831 int start = idx; 00832 for( int k = 0; k < iv; ++k ) 00833 { 00834 const double coords[3] = { static_cast< double >( i ), static_cast< double >( j ), 00835 static_cast< double >( k ) }; 00836 rval = mb.create_vertex( coords, verts[idx] );CHECK_ERR( rval ); 00837 if( ijk_vert_tag ) 00838 { 00839 int vals[] = { i, j, k }; 00840 rval = mb.tag_set_data( ijk_vert_tag, &verts[idx], 1, vals );CHECK_ERR( rval ); 00841 } 00842 ++idx; 00843 } 00844 00845 if( ij_set_tag ) 00846 { 00847 EntityHandle set; 00848 rval = mb.create_meshset( MESHSET_SET, set );CHECK_ERR( rval ); 00849 rval = mb.add_entities( set, &verts[start], idx - start );CHECK_ERR( rval ); 00850 int vals[] = { i, j }; 00851 rval = mb.tag_set_data( ij_set_tag, &set, 1, vals );CHECK_ERR( rval ); 00852 } 00853 } 00854 } 00855 00856 const int eb = intervals * intervals * intervals; 00857 std::vector< EntityHandle > elems( num_blk * eb ); 00858 idx = 0; 00859 for( int c = 0; c < num_blk; ++c ) 00860 { 00861 for( int i = c * intervals; i < ( c + 1 ) * intervals; ++i ) 00862 { 00863 for( int j = 0; j < intervals; ++j ) 00864 { 00865 for( int k = 0; k < intervals; ++k ) 00866 { 00867 EntityHandle conn[8] = { verts[iv * ( iv * i + j ) + k], 00868 verts[iv * ( iv * ( i + 1 ) + j ) + k], 00869 verts[iv * ( iv * ( i + 1 ) + j + 1 ) + k], 00870 verts[iv * ( iv * i + j + 1 ) + k], 00871 verts[iv * ( iv * i + j ) + k + 1], 00872 verts[iv * ( iv * ( i + 1 ) + j ) + k + 1], 00873 verts[iv * ( iv * ( i + 1 ) + j + 1 ) + k + 1], 00874 verts[iv * ( iv * i + j + 1 ) + k + 1] }; 00875 00876 rval = mb.create_element( MBHEX, conn, 8, elems[idx++] );CHECK_ERR( rval ); 00877 } 00878 } 00879 } 00880 } 00881 00882 Tag part_tag; 00883 rval = mb.tag_get_handle( PARTITION_TAG, 1, MB_TYPE_INTEGER, part_tag, MB_TAG_SPARSE | MB_TAG_EXCL );CHECK_ERR( rval ); 00884 00885 std::vector< EntityHandle > parts( num_cpu ); 00886 for( int i = 0; i < num_cpu; ++i ) 00887 { 00888 rval = mb.create_meshset( MESHSET_SET, parts[i] );CHECK_ERR( rval ); 00889 for( int j = 0; j < blocks_per_cpu; ++j ) 00890 { 00891 rval = mb.add_entities( parts[i], &elems[( num_cpu * j + i ) * eb], eb );CHECK_ERR( rval ); 00892 } 00893 rval = mb.tag_set_data( part_tag, &parts[i], 1, &i );CHECK_ERR( rval ); 00894 } 00895 00896 if( create_bcsets ) 00897 { 00898 // neumann set 00899 Range skin_ents; 00900 rval = Skinner( &mb ).find_skin( 0, &elems[0], elems.size(), false, skin_ents );CHECK_ERR( rval ); 00901 EntityHandle bcset; 00902 rval = mb.create_meshset( MESHSET_SET, bcset );CHECK_ERR( rval ); 00903 Tag bcset_tag; 00904 rval = mb.tag_get_handle( NEUMANN_SET_TAG_NAME, 1, MB_TYPE_INTEGER, bcset_tag, MB_TAG_SPARSE | MB_TAG_CREAT );CHECK_ERR( rval ); 00905 int dum = 100; 00906 rval = mb.tag_set_data( bcset_tag, &bcset, 1, &dum );CHECK_ERR( rval ); 00907 rval = mb.add_entities( bcset, skin_ents );CHECK_ERR( rval ); 00908 00909 // dirichlet set 00910 rval = mb.create_meshset( MESHSET_SET, bcset );CHECK_ERR( rval ); 00911 rval = mb.tag_get_handle( DIRICHLET_SET_TAG_NAME, 1, MB_TYPE_INTEGER, bcset_tag, MB_TAG_SPARSE | MB_TAG_CREAT );CHECK_ERR( rval ); 00912 dum = 200; 00913 rval = mb.tag_set_data( bcset_tag, &bcset, 1, &dum );CHECK_ERR( rval ); 00914 Range nodes; 00915 rval = mb.get_adjacencies( skin_ents, 0, false, nodes, Interface::UNION );CHECK_ERR( rval ); 00916 rval = mb.add_entities( bcset, nodes );CHECK_ERR( rval ); 00917 00918 // material set 00919 rval = mb.create_meshset( MESHSET_SET, bcset );CHECK_ERR( rval ); 00920 rval = mb.tag_get_handle( MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, bcset_tag, MB_TAG_SPARSE | MB_TAG_CREAT );CHECK_ERR( rval ); 00921 dum = 300; 00922 rval = mb.tag_set_data( bcset_tag, &bcset, 1, &dum );CHECK_ERR( rval ); 00923 rval = mb.add_entities( bcset, &elems[0], elems.size() );CHECK_ERR( rval ); 00924 } 00925 00926 rval = mb.write_file( file_name, "MOAB" );CHECK_ERR( rval ); 00927 } 00928 00929 void test_read_elements_common( bool by_rank, int intervals, bool /* print_time */, const char* extra_opts ) 00930 { 00931 const char* file_name = by_rank ? "test_read_rank.h5m" : "test_read.h5m"; 00932 int numproc, rank; 00933 MPI_Comm_size( MPI_COMM_WORLD, &numproc ); 00934 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 00935 Core moab; 00936 Interface& mb = moab; 00937 ErrorCode rval; 00938 00939 // if root processor, create hdf5 file for use in testing 00940 if( 0 == rank ) create_input_file( file_name, intervals, numproc ); 00941 MPI_Barrier( MPI_COMM_WORLD ); // make sure root has completed writing the file 00942 00943 // do parallel read unless only one processor 00944 std::string opt = get_read_options( by_rank, extra_opts ); 00945 rval = mb.load_file( file_name, 0, opt.c_str() ); 00946 00947 MPI_Barrier( MPI_COMM_WORLD ); // make sure all procs complete before removing file 00948 if( 0 == rank && !KeepTmpFiles ) remove( file_name );CHECK_ERR( rval ); 00949 00950 Tag part_tag; 00951 rval = mb.tag_get_handle( PARTITION_TAG, 1, MB_TYPE_INTEGER, part_tag );CHECK_ERR( rval ); 00952 00953 Range parts; 00954 rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &part_tag, 0, 1, parts );CHECK_ERR( rval ); 00955 CHECK_EQUAL( 1, (int)parts.size() ); 00956 EntityHandle part = parts.front(); 00957 int id; 00958 rval = mb.tag_get_data( part_tag, &part, 1, &id );CHECK_ERR( rval ); 00959 if( by_rank ) 00960 { 00961 CHECK_EQUAL( rank, id ); 00962 } 00963 00964 // check that all of the elements in the mesh are in the part 00965 int npart, nall; 00966 rval = mb.get_number_entities_by_dimension( part, 3, npart );CHECK_ERR( rval ); 00967 rval = mb.get_number_entities_by_dimension( 0, 3, nall );CHECK_ERR( rval ); 00968 CHECK_EQUAL( npart, nall ); 00969 00970 // check that we have the correct vertices 00971 const double x_min = intervals * rank; 00972 const double x_max = intervals * ( rank + 1 ); 00973 Range verts; 00974 rval = mb.get_entities_by_type( 0, MBVERTEX, verts );CHECK_ERR( rval ); 00975 std::vector< double > coords( verts.size() ); 00976 rval = mb.get_coords( verts, &coords[0], 0, 0 );CHECK_ERR( rval ); 00977 const double act_x_min = *std::min_element( coords.begin(), coords.end() ); 00978 const double act_x_max = *std::max_element( coords.begin(), coords.end() ); 00979 CHECK_REAL_EQUAL( x_min, act_x_min, DBL_EPSILON ); 00980 CHECK_REAL_EQUAL( x_max, act_x_max, DBL_EPSILON ); 00981 } 00982 00983 void test_read_time() 00984 { 00985 const char file_name[] = "read_time.h5m"; 00986 int numproc, rank; 00987 MPI_Comm_size( MPI_COMM_WORLD, &numproc ); 00988 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 00989 ErrorCode rval; 00990 00991 // if root processor, create hdf5 file for use in testing 00992 if( 0 == rank ) create_input_file( file_name, ReadIntervals, numproc, ReadBlocks ); 00993 MPI_Barrier( MPI_COMM_WORLD ); 00994 00995 // CPU Time for true paralle, wall time for true paralle, 00996 // CPU time for read and delete, wall time for read and delete 00997 double times[6]; 00998 clock_t tmp_t; 00999 01000 // Time true parallel read 01001 Core moab; 01002 Interface& mb = moab; 01003 times[0] = MPI_Wtime(); 01004 tmp_t = clock(); 01005 std::string opt = get_read_options( true, READ_PART ); 01006 rval = mb.load_file( file_name, 0, opt.c_str() );CHECK_ERR( rval ); 01007 times[0] = MPI_Wtime() - times[0]; 01008 times[1] = double( clock() - tmp_t ) / CLOCKS_PER_SEC; 01009 mb.delete_mesh(); 01010 01011 // Time read and delete 01012 Core moab2; 01013 Interface& mb2 = moab2; 01014 std::string opt2 = get_read_options( true, READ_DELETE ); 01015 times[2] = MPI_Wtime(); 01016 tmp_t = clock(); 01017 rval = mb2.load_file( file_name, 0, opt2.c_str() );CHECK_ERR( rval ); 01018 times[2] = MPI_Wtime() - times[2]; 01019 times[3] = double( clock() - tmp_t ) / CLOCKS_PER_SEC; 01020 mb2.delete_mesh(); 01021 01022 // Time broadcast and delete 01023 Core moab3; 01024 Interface& mb3 = moab3; 01025 std::string opt3 = get_read_options( true, BCAST_DELETE ); 01026 times[4] = MPI_Wtime(); 01027 tmp_t = clock(); 01028 rval = mb3.load_file( file_name, 0, opt3.c_str() );CHECK_ERR( rval ); 01029 times[4] = MPI_Wtime() - times[4]; 01030 times[5] = double( clock() - tmp_t ) / CLOCKS_PER_SEC; 01031 mb3.delete_mesh(); 01032 01033 double max_times[6] = { 0, 0, 0, 0, 0, 0 }, sum_times[6] = { 0, 0, 0, 0, 0, 0 }; 01034 MPI_Reduce( times, max_times, 6, MPI_DOUBLE, MPI_MAX, 0, MPI_COMM_WORLD ); 01035 MPI_Reduce( times, sum_times, 6, MPI_DOUBLE, MPI_SUM, 0, MPI_COMM_WORLD ); 01036 MPI_Barrier( MPI_COMM_WORLD ); 01037 if( 0 == rank ) 01038 { 01039 printf( "%12s %12s %12s %12s\n", "", "READ_PART", "READ_DELETE", "BCAST_DELETE" ); 01040 printf( "%12s %12g %12g %12g\n", "Max Wall", max_times[0], max_times[2], max_times[4] ); 01041 printf( "%12s %12g %12g %12g\n", "Total Wall", sum_times[0], sum_times[2], sum_times[4] ); 01042 printf( "%12s %12g %12g %12g\n", "Max CPU", max_times[1], max_times[3], max_times[5] ); 01043 printf( "%12s %12g %12g %12g\n", "Total CPU", sum_times[1], sum_times[3], sum_times[5] ); 01044 } 01045 01046 MPI_Barrier( MPI_COMM_WORLD ); 01047 if( 0 == rank && !KeepTmpFiles ) remove( file_name ); 01048 } 01049 01050 void test_read_tags() 01051 { 01052 const char tag_name[] = "test_tag_xx"; 01053 const char file_name[] = "test_read_tags.h5m"; 01054 int numproc, rank; 01055 MPI_Comm_size( MPI_COMM_WORLD, &numproc ); 01056 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 01057 Core moab; 01058 Interface& mb = moab; 01059 ErrorCode rval; 01060 01061 // if root processor, create hdf5 file for use in testing 01062 if( 0 == rank ) create_input_file( file_name, DefaultReadIntervals, numproc, 1, tag_name ); 01063 MPI_Barrier( MPI_COMM_WORLD ); // make sure root has completed writing the file 01064 01065 // do parallel read unless only one processor 01066 std::string opt = get_read_options(); 01067 rval = mb.load_file( file_name, 0, opt.c_str() ); 01068 MPI_Barrier( MPI_COMM_WORLD ); // make sure all procs complete before removing file 01069 if( 0 == rank && !KeepTmpFiles ) remove( file_name );CHECK_ERR( rval ); 01070 01071 Tag tag; 01072 rval = mb.tag_get_handle( tag_name, 3, MB_TYPE_INTEGER, tag );CHECK_ERR( rval ); 01073 01074 TagType storage; 01075 rval = mb.tag_get_type( tag, storage );CHECK_ERR( rval ); 01076 CHECK_EQUAL( MB_TAG_DENSE, storage ); 01077 01078 Range verts, tagged; 01079 rval = mb.get_entities_by_type( 0, MBVERTEX, verts );CHECK_ERR( rval ); 01080 rval = mb.get_entities_by_type_and_tag( 0, MBVERTEX, &tag, 0, 1, tagged );CHECK_ERR( rval ); 01081 CHECK_EQUAL( verts, tagged ); 01082 01083 for( Range::iterator i = verts.begin(); i != verts.end(); ++i ) 01084 { 01085 double coords[3]; 01086 rval = mb.get_coords( &*i, 1, coords );CHECK_ERR( rval ); 01087 int ijk[3]; 01088 rval = mb.tag_get_data( tag, &*i, 1, ijk );CHECK_ERR( rval ); 01089 01090 CHECK( ijk[0] >= DefaultReadIntervals * rank ); 01091 CHECK( ijk[0] <= DefaultReadIntervals * ( rank + 1 ) ); 01092 CHECK( ijk[1] >= 0 ); 01093 CHECK( ijk[1] <= DefaultReadIntervals ); 01094 CHECK( ijk[2] >= 0 ); 01095 CHECK( ijk[2] <= DefaultReadIntervals ); 01096 01097 CHECK_REAL_EQUAL( coords[0], (double)ijk[0], 1e-100 ); 01098 CHECK_REAL_EQUAL( coords[1], (double)ijk[1], 1e-100 ); 01099 CHECK_REAL_EQUAL( coords[2], (double)ijk[2], 1e-100 ); 01100 } 01101 } 01102 01103 void test_read_global_tags() 01104 { 01105 const char tag_name[] = "test_tag_g"; 01106 const char file_name[] = "test_read_global_tags.h5m"; 01107 int numproc, rank; 01108 MPI_Comm_size( MPI_COMM_WORLD, &numproc ); 01109 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 01110 Core moab; 01111 Interface& mb = moab; 01112 ErrorCode rval; 01113 const int def_val = 0xdeadcad; 01114 const int global_val = -11; 01115 01116 // if root processor, create hdf5 file for use in testing 01117 if( 0 == rank ) create_input_file( file_name, 1, numproc, 1, 0, 0, tag_name, &global_val, &def_val ); 01118 MPI_Barrier( MPI_COMM_WORLD ); // make sure root has completed writing the file 01119 01120 // do parallel read unless only one processor 01121 std::string opt = get_read_options(); 01122 rval = mb.load_file( file_name, 0, opt.c_str() ); 01123 MPI_Barrier( MPI_COMM_WORLD ); // make sure all procs complete before removing file 01124 if( 0 == rank && !KeepTmpFiles ) remove( file_name );CHECK_ERR( rval ); 01125 01126 Tag tag; 01127 rval = mb.tag_get_handle( tag_name, 1, MB_TYPE_INTEGER, tag );CHECK_ERR( rval ); 01128 01129 TagType storage; 01130 rval = mb.tag_get_type( tag, storage );CHECK_ERR( rval ); 01131 CHECK_EQUAL( MB_TAG_DENSE, storage ); 01132 01133 int mesh_def_val, mesh_gbl_val; 01134 rval = mb.tag_get_default_value( tag, &mesh_def_val );CHECK_ERR( rval ); 01135 CHECK_EQUAL( def_val, mesh_def_val ); 01136 EntityHandle root = 0; 01137 rval = mb.tag_get_data( tag, &root, 1, &mesh_gbl_val );CHECK_ERR( rval ); 01138 CHECK_EQUAL( global_val, mesh_gbl_val ); 01139 } 01140 01141 void test_read_sets_common( const char* extra_opts ) 01142 { 01143 const char tag_name[] = "test_tag_s"; 01144 const char file_name[] = "test_read_sets.h5m"; 01145 int numproc, rank; 01146 MPI_Comm_size( MPI_COMM_WORLD, &numproc ); 01147 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 01148 Core moab; 01149 Interface& mb = moab; 01150 ErrorCode rval; 01151 01152 // if root processor, create hdf5 file for use in testing 01153 if( 0 == rank ) create_input_file( file_name, DefaultReadIntervals, numproc, 1, 0, tag_name ); 01154 MPI_Barrier( MPI_COMM_WORLD ); // make sure root has completed writing the file 01155 01156 // do parallel read unless only one processor 01157 std::string opt = get_read_options( extra_opts ); 01158 rval = mb.load_file( file_name, 0, opt.c_str() ); 01159 MPI_Barrier( MPI_COMM_WORLD ); // make sure all procs complete before removing file 01160 if( 0 == rank && !KeepTmpFiles ) remove( file_name );CHECK_ERR( rval ); 01161 01162 Tag tag; 01163 rval = mb.tag_get_handle( tag_name, 2, MB_TYPE_INTEGER, tag );CHECK_ERR( rval ); 01164 01165 TagType storage; 01166 rval = mb.tag_get_type( tag, storage );CHECK_ERR( rval ); 01167 CHECK_EQUAL( MB_TAG_SPARSE, storage ); 01168 01169 const int iv = DefaultReadIntervals + 1; 01170 Range sets; 01171 rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &tag, 0, 1, sets );CHECK_ERR( rval ); 01172 CHECK_EQUAL( ( iv * iv ), (int)sets.size() ); 01173 01174 for( Range::iterator i = sets.begin(); i != sets.end(); ++i ) 01175 { 01176 int ij[2]; 01177 rval = mb.tag_get_data( tag, &*i, 1, &ij );CHECK_ERR( rval ); 01178 01179 CHECK( ij[0] >= DefaultReadIntervals * rank ); 01180 CHECK( ij[0] <= DefaultReadIntervals * ( rank + 1 ) ); 01181 CHECK( ij[1] >= 0 ); 01182 CHECK( ij[1] <= DefaultReadIntervals ); 01183 01184 Range contents; 01185 rval = mb.get_entities_by_handle( *i, contents );CHECK_ERR( rval ); 01186 CHECK( contents.all_of_type( MBVERTEX ) ); 01187 CHECK_EQUAL( iv, (int)contents.size() ); 01188 01189 for( Range::iterator v = contents.begin(); v != contents.end(); ++v ) 01190 { 01191 double coords[3]; 01192 rval = mb.get_coords( &*v, 1, coords );CHECK_ERR( rval ); 01193 CHECK_REAL_EQUAL( coords[0], (double)ij[0], 1e-100 ); 01194 CHECK_REAL_EQUAL( coords[1], (double)ij[1], 1e-100 ); 01195 } 01196 } 01197 } 01198 01199 void test_read_bc_sets() 01200 { 01201 // const char tag_name[] = "test_tag_s"; 01202 const char file_name[] = "test_read_sets.h5m"; 01203 int numproc, rank; 01204 MPI_Comm_size( MPI_COMM_WORLD, &numproc ); 01205 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 01206 Core moab; 01207 Interface& mb = moab; 01208 ErrorCode rval; 01209 01210 // if root processor, create hdf5 file for use in testing 01211 if( 0 == rank ) 01212 create_input_file( file_name, DefaultReadIntervals, numproc, 1, NULL, NULL, NULL, NULL, NULL, true ); 01213 MPI_Barrier( MPI_COMM_WORLD ); // make sure root has completed writing the file 01214 01215 // do parallel read unless only one processor 01216 std::string opt = get_read_options(); 01217 rval = mb.load_file( file_name, 0, opt.c_str() ); 01218 MPI_Barrier( MPI_COMM_WORLD ); // make sure all procs complete before removing file 01219 if( 0 == rank && !KeepTmpFiles ) remove( file_name );CHECK_ERR( rval ); 01220 01221 Tag tag; 01222 int num_ents[3], global_num_ents[3] = { 0, 0, 0 }; 01223 Range sets, contents; 01224 const char* names[] = { NEUMANN_SET_TAG_NAME, DIRICHLET_SET_TAG_NAME, MATERIAL_SET_TAG_NAME }; 01225 int vints = DefaultReadIntervals + 1; 01226 int expected_num_ents[] = { ( numproc * 4 + 2 ) * DefaultReadIntervals * DefaultReadIntervals, 01227 ( ( numproc * 4 + 2 ) * ( vints - 2 ) * ( vints - 2 ) + 12 * numproc * ( vints - 2 ) + 01228 8 * numproc ), 01229 numproc * DefaultReadIntervals * DefaultReadIntervals * DefaultReadIntervals }; 01230 01231 for( int i = 0; i < 3; i++ ) 01232 { 01233 rval = mb.tag_get_handle( names[i], 1, MB_TYPE_INTEGER, tag );CHECK_ERR( rval ); 01234 rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &tag, 0, 1, sets );CHECK_ERR( rval ); 01235 CHECK_EQUAL( 1, (int)sets.size() ); 01236 rval = mb.get_entities_by_handle( *sets.begin(), contents, true );CHECK_ERR( rval ); 01237 num_ents[i] = contents.size(); 01238 sets.clear(); 01239 contents.clear(); 01240 } 01241 01242 MPI_Reduce( num_ents, global_num_ents, 3, MPI_INT, MPI_SUM, 0, MPI_COMM_WORLD ); 01243 if( 0 == rank ) 01244 { 01245 // std::cout << "Global:" << global_num_ents[0] << " " << global_num_ents[1] << " " << 01246 // global_num_ents[2] << " " << std::endl; std::cout << "Expected:" << 01247 // expected_num_ents[0] << " " << expected_num_ents[1] << " " << expected_num_ents[2] << 01248 // " " << std::endl; 01249 01250 for( int i = 0; i < 3; i++ ) 01251 { 01252 CHECK_EQUAL( global_num_ents[i], expected_num_ents[i] ); 01253 } 01254 } 01255 } 01256 01257 void test_write_different_element_types() 01258 { 01259 const char file_name[] = "test_write_different_element_types.h5m"; 01260 int numproc, rank; 01261 MPI_Comm_size( MPI_COMM_WORLD, &numproc ); 01262 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 01263 Core moab; 01264 Interface& mb = moab; 01265 ErrorCode rval; 01266 01267 const EntityType topos[] = { MBEDGE, MBEDGE, MBQUAD, MBTRI, MBQUAD, MBTRI, 01268 MBTET, MBHEX, MBPRISM, MBPYRAMID, MBHEX, MBHEX }; 01269 const int verts[] = { 2, 3, 4, 3, 9, 6, 4, 8, 6, 5, 20, 27 }; 01270 const int ntypes = sizeof( topos ) / sizeof( topos[0] ); 01271 01272 const EntityType mtype = topos[rank % ntypes]; 01273 const int nvert = verts[rank % ntypes]; 01274 std::vector< EntityHandle > conn( nvert ); 01275 for( int i = 0; i < nvert; ++i ) 01276 { 01277 const double coords[] = { static_cast< double >( rank ), static_cast< double >( i ), 0 }; 01278 rval = mb.create_vertex( coords, conn[i] );CHECK_ERR( rval ); 01279 } 01280 EntityHandle handle; 01281 rval = mb.create_element( mtype, &conn[0], nvert, handle );CHECK_ERR( rval ); 01282 01283 save_and_load_on_root( mb, file_name ); 01284 01285 if( rank ) return; 01286 01287 for( int i = 0; i < ntypes; ++i ) 01288 { 01289 const int num_exp = numproc / ntypes + ( i < ( numproc % ntypes ) ? 1 : 0 ); 01290 Range ents; 01291 rval = mb.get_entities_by_type( 0, topos[i], ents );CHECK_ERR( rval ); 01292 int num = 0; 01293 for( Range::iterator e = ents.begin(); e != ents.end(); ++e ) 01294 { 01295 const EntityHandle* junk; 01296 int len; 01297 rval = mb.get_connectivity( *e, junk, len, false ); 01298 if( len == verts[i] ) ++num; 01299 } 01300 01301 CHECK_EQUAL( num_exp, num ); 01302 } 01303 } 01304 01305 Tag get_tag( Interface& mb, int rank, bool create ) 01306 { 01307 DataType type = (DataType)( rank % ( MB_MAX_DATA_TYPE + 1 ) ); 01308 TagType storage = ( type == MB_TYPE_BIT ) ? MB_TAG_BIT : ( rank % 2 ) ? MB_TAG_DENSE : MB_TAG_SPARSE; 01309 int len = rank % 3 + 1; 01310 TagType cbit = create ? MB_TAG_EXCL : (TagType)0; 01311 TagType vbit = rank % 4 == 1 && storage != MB_TAG_BIT ? MB_TAG_VARLEN : (TagType)0; 01312 std::ostringstream name; 01313 name << "TestTag" << rank; 01314 const void* defval = 0; 01315 const int defint[] = { static_cast< int >( rank ), static_cast< int >( rank / 2 ), static_cast< int >( rank + 1 ), 01316 static_cast< int >( rank - 1 ) }; 01317 const double defreal[] = { 0.1 * rank, 1.0 / rank, static_cast< double >( -rank ), static_cast< double >( rank ) }; 01318 const int defhandle[] = { 0, 0, 0, 0 }; 01319 const unsigned char defbit = 0x1; 01320 const char defopq[] = "Jason"; 01321 if( rank % 4 < 2 ) 01322 { 01323 switch( type ) 01324 { 01325 case MB_TYPE_BIT: 01326 defval = &defbit; 01327 break; 01328 case MB_TYPE_INTEGER: 01329 defval = defint; 01330 break; 01331 case MB_TYPE_DOUBLE: 01332 defval = defreal; 01333 break; 01334 case MB_TYPE_HANDLE: 01335 defval = defhandle; 01336 break; 01337 case MB_TYPE_OPAQUE: 01338 defval = defopq; 01339 break; 01340 } 01341 } 01342 01343 Tag result; 01344 ErrorCode rval = mb.tag_get_handle( name.str().c_str(), len, type, result, storage | cbit | vbit, defval );CHECK_ERR( rval ); 01345 return result; 01346 } 01347 01348 void test_write_different_tags() 01349 { 01350 const char file_name[] = "test_write_different_tags.h5m"; 01351 int numproc, rank; 01352 MPI_Comm_size( MPI_COMM_WORLD, &numproc ); 01353 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 01354 Core moab; 01355 Interface& mb = moab; 01356 01357 const int min_tags = 8; 01358 get_tag( mb, rank, true ); 01359 for( int idx = rank + numproc; idx < min_tags; idx += numproc ) 01360 get_tag( mb, idx, true ); 01361 01362 save_and_load_on_root( mb, file_name ); 01363 01364 if( 0 == rank ) 01365 { 01366 for( int i = 0; i < std::max( min_tags, numproc ); ++i ) 01367 get_tag( mb, i, false ); 01368 } 01369 } 01370 01371 void test_write_polygons() 01372 { 01373 const char file_name[] = "test_write_polygons.h5m"; 01374 int numproc, rank; 01375 MPI_Comm_size( MPI_COMM_WORLD, &numproc ); 01376 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 01377 Core moab; 01378 Interface& mb = moab; 01379 ErrorCode rval; 01380 01381 // create a polygon on each process 01382 const double r = 0.70710678118654757; 01383 const double points[8][3] = { 01384 { 1, 0, static_cast< double >( rank ) }, 01385 { static_cast< double >( r ), static_cast< double >( r ), static_cast< double >( rank ) }, 01386 { 0, 1, static_cast< double >( rank ) }, 01387 { static_cast< double >( -r ), static_cast< double >( r ), static_cast< double >( rank ) }, 01388 { -1, 0, static_cast< double >( rank ) }, 01389 { static_cast< double >( -r ), static_cast< double >( -r ), static_cast< double >( rank ) }, 01390 { 0, -1, static_cast< double >( rank ) }, 01391 { static_cast< double >( r ), static_cast< double >( -r ), static_cast< double >( rank ) } }; 01392 const int nvtx = rank % 4 + 5; 01393 std::vector< EntityHandle > conn( nvtx ); 01394 for( int i = 0; i < nvtx; ++i ) 01395 { 01396 rval = mb.create_vertex( points[i], conn[i] );CHECK_ERR( rval ); 01397 } 01398 01399 EntityHandle h; 01400 rval = mb.create_element( MBPOLYGON, &conn[0], nvtx, h );CHECK_ERR( rval ); 01401 01402 save_and_load_on_root( mb, file_name ); 01403 01404 if( rank != 0 ) return; 01405 01406 // check results on root process 01407 01408 // determine which polygon was created by which proc by 01409 // looking at the z-coordinate of the vertices 01410 Range range; 01411 rval = mb.get_entities_by_type( 0, MBPOLYGON, range ); 01412 std::vector< EntityHandle > poly( numproc, 0 ); 01413 CHECK_EQUAL( numproc, (int)range.size() ); 01414 for( Range::iterator it = range.begin(); it != range.end(); ++it ) 01415 { 01416 const EntityHandle* conn_arr; 01417 int len; 01418 rval = mb.get_connectivity( *it, conn_arr, len );CHECK_ERR( rval ); 01419 double coords[3]; 01420 rval = mb.get_coords( conn_arr, 1, coords );CHECK_ERR( rval ); 01421 int proc = (int)( coords[2] ); 01422 CHECK_EQUAL( (EntityHandle)0, poly[proc] ); 01423 poly[proc] = *it; 01424 } 01425 01426 // check that each poly has the expected number of vertices 01427 for( int i = 0; i < numproc; ++i ) 01428 { 01429 const EntityHandle* conn_arr; 01430 int len; 01431 rval = mb.get_connectivity( poly[i], conn_arr, len );CHECK_ERR( rval ); 01432 CHECK_EQUAL( i % 4 + 5, len ); 01433 } 01434 } 01435 01436 // Some processes have no mesh to write 01437 void test_write_unbalanced() 01438 { 01439 const char file_name[] = "test_write_unbalanced.h5m"; 01440 int numproc, rank; 01441 MPI_Comm_size( MPI_COMM_WORLD, &numproc ); 01442 MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 01443 Core moab; 01444 Interface& mb = moab; 01445 ErrorCode rval; 01446 Tag idtag = mb.globalId_tag(); 01447 01448 // create a shared set 01449 const int two = 2; 01450 Range entities, sets; 01451 01452 EntityHandle set; 01453 rval = mb.create_meshset( MESHSET_SET, set );CHECK_ERR( rval ); 01454 rval = mb.tag_set_data( idtag, &set, 1, &two );CHECK_ERR( rval ); 01455 sets.insert( set ); 01456 01457 // create a quad on every odd processor 01458 if( rank % 2 ) 01459 { 01460 const double coords[4][3] = { { static_cast< double >( rank ), 0, 0 }, 01461 { static_cast< double >( rank + 2 ), 0, 0 }, 01462 { static_cast< double >( rank + 2 ), 2, 0 }, 01463 { static_cast< double >( rank ), 2, 0 } }; 01464 EntityHandle conn[4], quad; 01465 for( int i = 0; i < 4; ++i ) 01466 mb.create_vertex( coords[i], conn[i] ); 01467 mb.create_element( MBQUAD, conn, 4, quad ); 01468 01469 const int ids[4] = { rank, rank + 2, rank + 3, rank + 1 }; 01470 rval = mb.tag_set_data( idtag, conn, 4, ids );CHECK_ERR( rval ); 01471 01472 rval = mb.add_entities( set, &quad, 1 );CHECK_ERR( rval ); 01473 01474 entities.insert( quad ); 01475 } 01476 01477 // set up sharing data 01478 ParallelComm* pcomm = ParallelComm::get_pcomm( &mb, 0 ); 01479 if( 0 == pcomm ) pcomm = new ParallelComm( &mb, MPI_COMM_WORLD ); 01480 rval = pcomm->resolve_shared_ents( 0, entities, 2, 0, NULL, &idtag );CHECK_ERR( rval ); 01481 rval = pcomm->resolve_shared_sets( sets, idtag );CHECK_ERR( rval ); 01482 01483 // do parallel write and serial load 01484 save_and_load_on_root( mb, file_name ); 01485 01486 if( rank != 0 ) return; 01487 01488 // check that we got what we expected 01489 Range quads, verts; 01490 rval = mb.get_entities_by_type( 0, MBQUAD, quads );CHECK_ERR( rval ); 01491 rval = mb.get_entities_by_type( 0, MBVERTEX, verts );CHECK_ERR( rval ); 01492 01493 const size_t nquads = numproc / 2; 01494 const size_t nverts = nquads ? 2 + 2 * nquads : 0; 01495 CHECK_EQUAL( nquads, quads.size() ); 01496 CHECK_EQUAL( nverts, verts.size() ); 01497 01498 rval = mb.tag_get_handle( GLOBAL_ID_TAG_NAME, 1, MB_TYPE_INTEGER, idtag );CHECK_ERR( rval ); 01499 sets.clear(); 01500 const void* vals[] = { &two }; 01501 rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &idtag, vals, 1, sets );CHECK_ERR( rval ); 01502 CHECK_EQUAL( (size_t)1, sets.size() ); 01503 01504 entities.clear(); 01505 rval = mb.get_entities_by_handle( sets.front(), entities );CHECK_ERR( rval ); 01506 CHECK_EQUAL( nquads, entities.size() ); 01507 CHECK_EQUAL( quads, entities ); 01508 } 01509 01510 // this test will load a file that has 2 partitions (mix.h5m) 01511 // one partition with triangles, and one with triangles and quads 01512 // a dense tag created on this should be dense in the file 01513 // 01514 void test_write_dense_tags() 01515 { 01516 int err, rank, size; 01517 ErrorCode rval; 01518 err = MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 01519 CHECK( !err ); 01520 err = MPI_Comm_size( MPI_COMM_WORLD, &size ); 01521 CHECK( !err ); 01522 01523 Core moab; 01524 rval = moab.load_file( InputMix, 0, 01525 "PARALLEL=READ_PART;" 01526 "PARTITION=PARALLEL_PARTITION;" 01527 "PARALLEL_RESOLVE_SHARED_ENTS" );CHECK_ERR( rval ); 01528 01529 // create an dense tag, on all elements, then write the output in parallel 01530 // load the file again, and test the type of the tag 01531 Range elems; 01532 moab.get_entities_by_dimension( 0, 2, elems ); 01533 01534 const char* tagname = "element_tag"; 01535 const double defVal = 0.; 01536 Tag fieldTag; 01537 rval = moab.tag_get_handle( tagname, 1, MB_TYPE_DOUBLE, fieldTag, MB_TAG_DENSE | MB_TAG_CREAT, &defVal );CHECK_ERR( rval ); 01538 01539 int numElems = (int)elems.size(); 01540 01541 for( int i = 0; i < numElems; i++ ) 01542 { 01543 EntityHandle elem = elems[i]; 01544 double xyz[3]; 01545 moab.get_coords( &elem, 1, xyz ); 01546 // some value 01547 double fieldValue = sqrt( xyz[0] * xyz[0] + xyz[1] * xyz[1] + xyz[2] * xyz[2] ); 01548 moab.tag_set_data( fieldTag, &elem, 1, &fieldValue ); 01549 } 01550 01551 // write the file in parallel 01552 rval = moab.write_file( "newfile.h5m", 0, "PARALLEL=WRITE_PART" );CHECK_ERR( rval ); 01553 01554 // now read the new file, in a new instance, and test the tag type 01555 01556 Core moab2; 01557 rval = moab2.load_file( "newfile.h5m", 0, 01558 "PARALLEL=READ_PART;" 01559 "PARTITION=PARALLEL_PARTITION;" 01560 "PARALLEL_RESOLVE_SHARED_ENTS" );CHECK_ERR( rval ); 01561 01562 // find the element tag 01563 Tag found_tag; 01564 rval = moab2.tag_get_handle( tagname, 1, MB_TYPE_DOUBLE, found_tag );CHECK_ERR( rval ); 01565 TagType tagt; 01566 rval = moab2.tag_get_type( found_tag, tagt );CHECK_ERR( rval ); 01567 CHECK( tagt == MB_TAG_DENSE ); 01568 } 01569 // this test will load a file that has 2 partitions (oneside.h5m) 01570 // and one side set, that is adjacent to one part only 01571 // 01572 void test_read_non_adjs_side() 01573 { 01574 int err, rank, size; 01575 ErrorCode rval; 01576 err = MPI_Comm_rank( MPI_COMM_WORLD, &rank ); 01577 CHECK( !err ); 01578 err = MPI_Comm_size( MPI_COMM_WORLD, &size ); 01579 CHECK( !err ); 01580 01581 Core moab; 01582 rval = moab.load_file( InputOneSide, 0, 01583 "PARALLEL=READ_PART;" 01584 "PARTITION=PARALLEL_PARTITION;" 01585 "PARALLEL_RESOLVE_SHARED_ENTS" );CHECK_ERR( rval ); 01586 01587 return; 01588 }
