MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** \file ScdInterface.hpp 00002 */ 00003 #ifndef SCD_INTERFACE 00004 #define SCD_INTERFACE 00005 00006 #include "moab/Interface.hpp" 00007 #include "moab/HomXform.hpp" 00008 00009 #include <iostream> 00010 #include <vector> 00011 #include <cassert> 00012 00013 #include "moab/win32_config.h" 00014 00015 namespace moab 00016 { 00017 00018 class StructuredElementSeq; 00019 class EntitySequence; 00020 class ScdVertexData; 00021 class EntitySequence; 00022 class ScdBox; 00023 class ParallelComm; 00024 00025 /** \class ScdInterface ScdInterface.hpp "moab/ScdInterface.hpp" 00026 * \brief A structured mesh interface for MOAB-based data 00027 * 00028 * Structured mesh in MOAB is created and accessed through the ScdInterface and ScdBox classes. 00029 * 00030 * \section Construction Construction and Representation 00031 * Structured mesh can be constructed in one of two ways. First, a rectangular block of mesh, 00032 * both vertices and edges/quads/hexes, can be created in one shot, using the construct_box method. 00033 * In this case, there are single sequences of vertices/entities. The second method for creating 00034 * structured mesh is to create the structured blocks of vertices and elements separately. In 00035 * this case, different blocks of elements can share blocks of vertices, and each block of 00036 * elements has its own independent parametric space. The algorithms behind this representation 00037 * are described in T. Tautges, "MOAB-SD: Integrated structured and unstructured mesh 00038 * representation", Eng. w Comp, vol 20 no. 3. 00039 * 00040 * Structured mesh is represented in MOAB down at the element sequence level, which is something 00041 * applications don't see. In addition, when structured mesh is created, entity sets are also 00042 * created and tagged with information about the parametric space. In particular, the BOX_DIMS 00043 * tag is used to indicate the lower and upper corners in parametric space (this 00044 * tag is integer size 6). Structured mesh blocks are also available through ScdBox class objects 00045 * returned by ScdInterface. These class objects should be treated only as references to the 00046 * structured mesh blocks; that is, the structured mesh referenced by these objects is not deleted 00047 * when the ScdBox instance is destroyed. Functions for destroying the actual mesh are available 00048 * on this class, though. 00049 * 00050 * Structured mesh blocks are returned in the form of ScdBox class objects. Each ScdBox instance 00051 * represents a rectangular block of vertices and possibly elements (edges, quads, or hexes). The 00052 * edge/quad/hex entity handles for a ScdBox are guaranteed to be contiguous, starting at a starting 00053 * value which is also available through the ScdBox class. However, vertex handles may or may not 00054 * be contiguous, depending on the construction method. The start vertex handle is also available 00055 * from the ScdBox class. 00056 * 00057 * \section Parameters Parametric Space 00058 * 00059 * Each structured box has a parametric (ijk) space, which can be queried through the ScdBox 00060 * interface. For non-periodic boxes, the edge/quad/hex parameter bounds are one less in each 00061 * dimension than that of the vertices, otherwise they are the same as the vertex parameter bounds. 00062 * In a parallel representation, boxes are locally non-periodic by default, but global ids are 00063 * assigned such that the last set of vertices in a periodic direction match those of the first set 00064 * of vertices in that direction. 00065 * 00066 * Entity handles are allocated with the i parameter varying fastest, then j, then k. 00067 * 00068 * \section Per Periodic Meshes 00069 * Boxes can be periodic in i, or j, or both i and j. If only i or j is periodic, the corresponding 00070 * mesh is a strip or an annular cylinder; if both i and j are periodic, the corresponding mesh is 00071 * an annular torus. A box cannot be periodic in all three parameters. If i and/or j is periodic, 00072 * and assuming IMIN/JMIN is zero, the parameter extents in the/each periodic direction (IMAX/JMAX) 00073 * for vertices and edges/faces/hexes are the same, and the vertices on the "top" end in the 00074 * periodic direction are at parameter value IMIN/JMIN. 00075 * 00076 * \section Par Parallel Representation 00077 * 00078 * For parallel structured meshes, each local mesh (the mesh on a given process) looks like a 00079 * non-periodic structured mesh, and there are both local and global parameters of the structured 00080 * mesh. If the mesh is periodic in a given direction, the last process in the periodic direction 00081 * has local IMAX/JMAX that is one greater than the global IMAX/JMAX. 00082 * 00083 * 00084 * In parallel, the periodicity described in the previous paragraph is "local periodicity"; there is 00085 * also the notion of global periodicity. For serial meshes, those concepts are the same. In 00086 * parallel, a mesh can be locally non-periodic but globally periodic in a given direction. In that 00087 * case, the local mesh is still non-periodic, i.e. the parametric extents for edges is one fewer 00088 * than that of vertices in that direction. However, vertices are given global ids such that they 00089 * match those of the parametric minimum in that direction. Geometric positions of the vertices at 00090 * the high end should still be greater than the ones just below. 00091 * 00092 * \section Adjs Adjacent Entities 00093 * This interface supports parametric access to intermediate-dimension entities, e.g. adjacent faces 00094 * and edges in a 3d mesh. In this case, a direction parameter is added, to identify the parametric 00095 * direction of the entities being requested. For example, to retrieve the faces adjacent to a hex 00096 * with parameters ijk, in the i parametric direction, you would use the parameters ijk0. These 00097 * intermediate entities are not stored in a structured representation, but their parametric 00098 * positions can be evaluated based on their adjacencies to higher-dimensional entities. Thanks to 00099 * Milad Fatenejad for the thinking behind this. 00100 * 00101 * \section Evaluation Evaluation 00102 * The ScdBox class provides functions for evaluating the mesh based on the ijk parameter space. 00103 * These functions are inlined where possible, for efficiency. 00104 */ 00105 00106 //! struct for keeping parallel data in one place 00107 class ScdParData 00108 { 00109 public: 00110 ScdParData() : partMethod( NOPART ), pComm( NULL ) 00111 { 00112 gDims[0] = gDims[1] = gDims[2] = gDims[3] = gDims[4] = gDims[5] = 0; 00113 gPeriodic[0] = gPeriodic[1] = gPeriodic[2] = 0; 00114 pDims[0] = pDims[1] = pDims[2] = 0; 00115 } 00116 00117 //! Partition method enumeration; these strategies are described in comments for 00118 //! compute_partition_alljorkori, compute_partition_alljkbal, compute_partition_sqij, 00119 //! compute_partition_sqjk, and compute_partition_sqijk 00120 enum PartitionMethod 00121 { 00122 ALLJORKORI = 0, 00123 ALLJKBAL, 00124 SQIJ, 00125 SQJK, 00126 SQIJK, 00127 TRIVIAL, 00128 RCBZOLTAN, 00129 NOPART 00130 }; 00131 00132 //! Partition method names 00133 static MOAB_EXPORT const char* PartitionMethodNames[NOPART + 1]; 00134 00135 //! partition method used to partition global parametric space 00136 int partMethod; 00137 00138 //! lower and upper corners of global box 00139 int gDims[6]; 00140 00141 //! is globally periodic in i or j or k 00142 int gPeriodic[3]; 00143 00144 //! number of procs in each direction 00145 int pDims[3]; 00146 00147 //! parallel communicator object for this par scd mesh 00148 ParallelComm* pComm; 00149 }; 00150 00151 class MOAB_EXPORT ScdInterface 00152 { 00153 public: 00154 friend class ScdBox; 00155 00156 //! Constructor 00157 /** Constructor; if find_boxes is true, this will search for entity sets marked as 00158 * structured blocks, based on the BOX_DIMS tag. Structured mesh blocks will be stored 00159 * in this interface class for future retrieval. Structured mesh blocks created through 00160 * this interface will also be stored here. 00161 * \param impl MOAB instance 00162 * \param find_boxes If true, search all the entity sets, caching the structured mesh blocks 00163 */ 00164 ScdInterface( Interface* impl, bool find_boxes = false ); 00165 00166 // Destructor 00167 ~ScdInterface(); 00168 00169 //! Return the MOAB Interface instance * 00170 Interface* impl() const; 00171 00172 //! Construct new structured mesh box, including both vertices and elements 00173 /** Parameter range 00174 * for vertex box is [low-high], for elements is [low-high). Construct quads by passing 00175 * in low[2] == high[2], and edges by passing in low[1] == high[1] and low[2] == high[2]. 00176 * The result is passed back in a ScdBox*, which is a *reference* to the box of structured mesh. 00177 * That is, the actual mesh is retained in MOAB when the ScdBox is destroyed. To actually 00178 * destroy the mesh, call the destroy_mesh function on the ScdBox object first, before 00179 * destroying it. \param low Lower corner in parameter space \param high Higher corner in 00180 * parameter space \param coords Coordinates of vertices, interleaved (xyzxyz...); if NULL, 00181 * coords are set to parametric values \param num_coords Number of coordinate values \param 00182 * new_box Reference to box of structured mesh \param lperiodic[3] If lperiodic[s] != 0, 00183 * direction s is locally periodic \param par_data If non-NULL, this will get stored on the 00184 * ScdBox once created, contains info about global parallel nature of ScdBox across procs \param 00185 * assign_global_ids If true, assigns 1-based global ids to vertices using GLOBAL_ID_TAG_NAME 00186 * \param resolve_shared_ents If != -1, resolves shared entities up to and including dimension 00187 * equal to value 00188 */ 00189 ErrorCode construct_box( HomCoord low, 00190 HomCoord high, 00191 const double* const coords, 00192 unsigned int num_coords, 00193 ScdBox*& new_box, 00194 int* const lperiodic = NULL, 00195 ScdParData* const par_data = NULL, 00196 bool assign_global_ids = false, 00197 int resolve_shared_ents = -1 ); 00198 00199 //! Create a structured sequence of vertices, quads, or hexes 00200 /** Starting handle for the sequence is available from the returned ScdBox. 00201 * If creating a structured quad or hex box, subsequent calls must be made to ScdBox::add_vbox, 00202 * until all the vertices have been filled in for the box. 00203 * \param low Lower corner of structured box 00204 * \param high Higher corner of structured box 00205 * \param type EntityType, one of MBVERTEX, MBEDGE, MBQUAD, MBHEX 00206 * \param starting_id Requested start id of entities 00207 * \param new_box Reference to the newly created box of entities 00208 * \param is_periodic[3] If is_periodic[s] is non-zero, mesh should be periodic in direction s 00209 * (s=[0,1,2]) 00210 */ 00211 ErrorCode create_scd_sequence( const HomCoord& low, 00212 const HomCoord& high, 00213 EntityType type, 00214 int starting_id, 00215 ScdBox*& new_box, 00216 int* is_periodic = NULL ); 00217 00218 //! Return all the structured mesh blocks in this MOAB instance, as ScdBox objects 00219 /** Return the structured blocks in this MOAB instance. If these were not searched for 00220 * at instantiation time, then the search is done now. 00221 * \param boxes Vector of ScdBox objects representing structured mesh blocks 00222 */ 00223 ErrorCode find_boxes( std::vector< ScdBox* >& boxes ); 00224 00225 //! Return all the structured mesh blocks in this MOAB instance, as entity set handles 00226 /** Return the structured blocks in this MOAB instance. If these were not searched for 00227 * at instantiation time, then the search is done now. 00228 * \param boxes Range of entity set objects representing structured mesh blocks 00229 */ 00230 ErrorCode find_boxes( Range& boxes ); 00231 00232 //! Return all the structured mesh blocks known by ScdInterface (does not search) 00233 /** Return the structured blocks in this ScdInterface instance. Does not search for new boxes, 00234 * just returns the contents of the list. 00235 * \param boxes Structured boxes 00236 */ 00237 ErrorCode get_boxes( std::vector< ScdBox* >& boxes ); 00238 00239 //! Return the tag marking the lower and upper corners of boxes 00240 /** 00241 * \param create_if_missing If the tag does not yet exist, create it 00242 */ 00243 Tag box_dims_tag( bool create_if_missing = true ); 00244 00245 //! Return the tag marking the global lower and upper corners of boxes 00246 /** 00247 * \param create_if_missing If the tag does not yet exist, create it 00248 */ 00249 Tag global_box_dims_tag( bool create_if_missing = true ); 00250 00251 //! Return the tag marking the partitioning method used to partition the box in parallel 00252 /** 00253 * \param create_if_missing If the tag does not yet exist, create it 00254 */ 00255 Tag part_method_tag( bool create_if_missing = true ); 00256 00257 //! Return the tag marking whether box is periodic in i and j 00258 /** 00259 * \param create_if_missing If the tag does not yet exist, create it 00260 */ 00261 Tag box_periodic_tag( bool create_if_missing = true ); 00262 00263 //! Return the tag marking the ScdBox for a set 00264 /** 00265 * \param create_if_missing If the tag does not yet exist, create it 00266 */ 00267 Tag box_set_tag( bool create_if_missing = true ); 00268 00269 //! Return the ScdBox corresponding to the entity set passed in 00270 /** If the entity isn't a structured box set, NULL is returned. 00271 * \param eh Entity whose box is being queried 00272 */ 00273 ScdBox* get_scd_box( EntityHandle eh ); 00274 00275 //! Compute a partition of structured parameter space 00276 /** Compute a partition of structured parameter space, based on data in the ScdParData 00277 * passed in. Results are passed back in arguments, which application can set back into 00278 * par_data argument if they so desire. 00279 * \param np Number of processors 00280 * \param nr Rank of this processor 00281 * \param par_data ScdParData object that contains input global parameter space, desired 00282 * partitioning method, and information about global periodicity. 00283 * \param ldims Local parameters for grid 00284 * \param lperiodic Whether or not a given dimension is locally periodic 00285 * \param pdims Number of procs in i, j, k directions 00286 */ 00287 static ErrorCode compute_partition( int np, 00288 int nr, 00289 const ScdParData& par_data, 00290 int* ldims, 00291 int* lperiodic = NULL, 00292 int* pdims = NULL ); 00293 00294 //! Get information about the neighbor in the dijk[] direction, where dijk can be -1 or 1 for 00295 //! all 3 params 00296 /** Get information about the neighbor in the dijk[] direction, where dijk can be -1 or 1 for 00297 * all 3 params \param np (in) Total # procs \param nr Processor from which neighbor is 00298 * requested \param spd (in) ScdParData containing part method, gdims, gperiodic data \param 00299 * dijk(*) (in) Direction being queried, = +/-1 or 0 \param pto (out) Processor holding the 00300 * destination part \param rdims(6) (out) Parametric min/max of destination part \param 00301 * facedims(6) (out) Parametric min/max of interface between pfrom and pto; if at the max in a 00302 * periodic direction, set to global min of that direction \param across_bdy(3) (out) If 00303 * across_bdy[i] is -1(1), interface with pto is across periodic lower(upper) bdy in parameter 00304 * i, 0 otherwise 00305 */ 00306 static ErrorCode get_neighbor( int np, 00307 int nr, 00308 const ScdParData& spd, 00309 const int* const dijk, 00310 int& pto, 00311 int* rdims, 00312 int* facedims, 00313 int* across_bdy ); 00314 00315 //! Tag vertices with sharing data for parallel representations 00316 /** Given the ParallelComm object to use, tag the vertices shared with other processors 00317 */ 00318 ErrorCode tag_shared_vertices( ParallelComm* pcomm, EntityHandle seth ); 00319 00320 //! Tag vertices with sharing data for parallel representations 00321 /** Given the ParallelComm object to use, tag the vertices shared with other processors 00322 */ 00323 ErrorCode tag_shared_vertices( ParallelComm* pcomm, ScdBox* box ); 00324 00325 protected: 00326 //! Remove the box from the list on ScdInterface 00327 ErrorCode remove_box( ScdBox* box ); 00328 00329 //! Add the box to the list on ScdInterface 00330 ErrorCode add_box( ScdBox* box ); 00331 00332 private: 00333 //! Create an entity set for a box, and tag with the parameters 00334 /** \param low Lower corner parameters for this box 00335 * \param high Upper corner parameters for this box 00336 * \param scd_set Entity set created 00337 * \param is_periodic[3] If is_periodic[s] is non-zero, mesh should be periodic in direction s 00338 * (s=[0,1,2]) 00339 */ 00340 ErrorCode create_box_set( const HomCoord& low, 00341 const HomCoord& high, 00342 EntityHandle& scd_set, 00343 int* is_periodic = NULL ); 00344 00345 //! Compute a partition of structured parameter space 00346 /** Partitions the structured parametric space by partitioning j, k, or i only. 00347 * If j is greater than #procs, partition that, else k, else i. 00348 * For description of arguments, see ScdInterface::compute_partition. 00349 */ 00350 inline static ErrorCode compute_partition_alljorkori( int np, 00351 int nr, 00352 const int gijk[6], 00353 const int* const gperiodic, 00354 int* lijk, 00355 int* lperiodic, 00356 int* pijk ); 00357 00358 //! Compute a partition of structured parameter space 00359 /** Partitions the structured parametric space by partitioning j, and possibly k, 00360 * seeking square regions of jk space 00361 * For description of arguments, see ScdInterface::compute_partition. 00362 */ 00363 inline static ErrorCode compute_partition_alljkbal( int np, 00364 int nr, 00365 const int gijk[6], 00366 const int* const gperiodic, 00367 int* lijk, 00368 int* lperiodic, 00369 int* pijk ); 00370 00371 //! Compute a partition of structured parameter space 00372 /** Partitions the structured parametric space by seeking square ij partitions 00373 * For description of arguments, see ScdInterface::compute_partition. 00374 */ 00375 inline static ErrorCode compute_partition_sqij( int np, 00376 int nr, 00377 const int gijk[6], 00378 const int* const gperiodic, 00379 int* lijk, 00380 int* lperiodic, 00381 int* pijk ); 00382 00383 //! Compute a partition of structured parameter space 00384 /** Partitions the structured parametric space by seeking square jk partitions 00385 * For description of arguments, see ScdInterface::compute_partition. 00386 */ 00387 inline static ErrorCode compute_partition_sqjk( int np, 00388 int nr, 00389 const int gijk[6], 00390 const int* const gperiodic, 00391 int* lijk, 00392 int* lperiodic, 00393 int* pijk ); 00394 00395 //! Compute a partition of structured parameter space 00396 /** Partitions the structured parametric space by seeking square ijk partitions 00397 * For description of arguments, see ScdInterface::compute_partition. 00398 */ 00399 inline static ErrorCode compute_partition_sqijk( int np, 00400 int nr, 00401 const int gijk[6], 00402 const int* const gperiodic, 00403 int* lijk, 00404 int* lperiodic, 00405 int* pijk ); 00406 00407 //! Get vertices shared with other processors 00408 /** Shared vertices returned as indices into each proc's handle space 00409 * \param box Box used to get parametric space info 00410 * \param procs Procs this proc shares vertices with 00411 * \param offsets Offsets into indices list for each proc 00412 * \param shared_indices local/remote indices of shared vertices 00413 */ 00414 static ErrorCode get_shared_vertices( ParallelComm* pcomm, 00415 ScdBox* box, 00416 std::vector< int >& procs, 00417 std::vector< int >& offsets, 00418 std::vector< int >& shared_indices ); 00419 00420 static ErrorCode get_indices( const int* const ldims, 00421 const int* const rdims, 00422 const int* const across_bdy, 00423 int* face_dims, 00424 std::vector< int >& shared_indices ); 00425 00426 static ErrorCode get_neighbor_alljorkori( int np, 00427 int pfrom, 00428 const int* const gdims, 00429 const int* const gperiodic, 00430 const int* const dijk, 00431 int& pto, 00432 int* rdims, 00433 int* facedims, 00434 int* across_bdy ); 00435 00436 static ErrorCode get_neighbor_alljkbal( int np, 00437 int pfrom, 00438 const int* const gdims, 00439 const int* const gperiodic, 00440 const int* const dijk, 00441 int& pto, 00442 int* rdims, 00443 int* facedims, 00444 int* across_bdy ); 00445 00446 static ErrorCode get_neighbor_sqij( int np, 00447 int pfrom, 00448 const int* const gdims, 00449 const int* const gperiodic, 00450 const int* const dijk, 00451 int& pto, 00452 int* rdims, 00453 int* facedims, 00454 int* across_bdy ); 00455 00456 static ErrorCode get_neighbor_sqjk( int np, 00457 int pfrom, 00458 const int* const gdims, 00459 const int* const gperiodic, 00460 const int* const dijk, 00461 int& pto, 00462 int* rdims, 00463 int* facedims, 00464 int* across_bdy ); 00465 00466 static ErrorCode get_neighbor_sqijk( int np, 00467 int pfrom, 00468 const int* const gdims, 00469 const int* const gperiodic, 00470 const int* const dijk, 00471 int& pto, 00472 int* rdims, 00473 int* facedims, 00474 int* across_bdy ); 00475 00476 static int gtol( const int* gijk, int i, int j, int k ); 00477 00478 //! assign global ids to vertices in this box 00479 ErrorCode assign_global_ids( ScdBox* box ); 00480 00481 //! interface instance 00482 Interface* mbImpl; 00483 00484 //! whether we've searched the database for boxes yet 00485 bool searchedBoxes; 00486 00487 //! structured mesh blocks; stored as ScdBox objects, can get sets from those 00488 std::vector< ScdBox* > scdBoxes; 00489 00490 //! tag representing whether box is periodic in i and j 00491 Tag boxPeriodicTag; 00492 00493 //! tag representing box lower and upper corners 00494 Tag boxDimsTag; 00495 00496 //! tag representing global lower and upper corners 00497 Tag globalBoxDimsTag; 00498 00499 //! tag representing partition method 00500 Tag partMethodTag; 00501 00502 //! tag pointing from set to ScdBox 00503 Tag boxSetTag; 00504 }; 00505 00506 class MOAB_EXPORT ScdBox 00507 { 00508 friend class ScdInterface; 00509 00510 public: 00511 //! Destructor 00512 ~ScdBox(); 00513 00514 //! Return the ScdInterface responsible for this box 00515 inline ScdInterface* sc_impl() const; 00516 00517 //! Add a vertex box to this box 00518 /* Add a vertex box to the element sequence referenced by this box. The passed in vbox must 00519 * be a vertex box, with parametric extents no larger than that of this box. This vbox is 00520 * oriented to this box by matching parameters from1-from3 in vbox to to1-to3 in this box. 00521 * If bb_input is true, only the part of the vertex sequence between bb_min and bb_max is 00522 * referenced \param vbox The vertex box being added to this box \param from1 1st reference 00523 * point on vbox \param to1 1st reference point on this box \param from2 2nd reference point on 00524 * vbox \param to2 2nd reference point on this box \param from3 3rd reference point on vbox 00525 * \param to3 3rd reference point on this box 00526 * \param bb_input If true, subsequent parameters list extents of vbox referenced 00527 * \param bb_min Lower corner of rectangle referenced 00528 * \param bb_max Upper corner of rectangle referenced 00529 */ 00530 ErrorCode add_vbox( ScdBox* vbox, 00531 HomCoord from1, 00532 HomCoord to1, 00533 HomCoord from2, 00534 HomCoord to2, 00535 HomCoord from3, 00536 HomCoord to3, 00537 bool bb_input = false, 00538 const HomCoord& bb_min = HomCoord::getUnitv( 0 ), 00539 const HomCoord& bb_max = HomCoord::getUnitv( 0 ) ); 00540 // const HomCoord &bb_min = HomCoord::unitv[0], 00541 // const HomCoord &bb_max = HomCoord::unitv[0]); 00542 00543 //! Return whether this box has all its vertices defined 00544 /** Tests whether vertex boxs added with add_vbox have completely defined the vertex parametric 00545 * space for this box. 00546 * 00547 */ 00548 bool boundary_complete() const; 00549 00550 //! Return highest topological dimension of box 00551 inline int box_dimension() const; 00552 00553 //! Starting vertex handle for this box 00554 inline EntityHandle start_vertex() const; 00555 00556 //! Starting entity handle for this box 00557 /** If this is a vertex box, the start vertex handle is returned. 00558 */ 00559 inline EntityHandle start_element() const; 00560 00561 //! Return the number of elements in the box 00562 /* Number of elements is (boxSize[0]-1)(boxSize[1]-1)(boxSize[2]-1) 00563 */ 00564 inline int num_elements() const; 00565 00566 //! Return the number of vertices in the box 00567 /* Number of vertices is boxSize[0] * boxSize[1] * boxSize[2] 00568 */ 00569 inline int num_vertices() const; 00570 00571 //! Return the parametric coordinates for this box 00572 /** 00573 * \return IJK parameters of lower and upper corners 00574 */ 00575 inline const int* box_dims() const; 00576 00577 //! Return the lower corner parametric coordinates for this box 00578 inline HomCoord box_min() const; 00579 00580 //! Return the upper corner parametric coordinates for this box 00581 inline HomCoord box_max() const; 00582 00583 //! Return the parameter extents for this box 00584 inline HomCoord box_size() const; 00585 00586 //! Return the parametric extents for this box 00587 /** 00588 * \param ijk IJK extents of this box 00589 */ 00590 inline void box_size( int* ijk ) const; 00591 00592 //! Return the parametric extents for this box 00593 /** 00594 * \param i I extent of this box 00595 * \param j J extent of this box 00596 * \param k K extent of this box 00597 */ 00598 void box_size( int& i, int& j, int& k ) const; 00599 00600 //! Get the element at the specified coordinates 00601 /** 00602 * \param ijk Parametric coordinates being evaluated 00603 */ 00604 EntityHandle get_element( const HomCoord& ijk ) const; 00605 00606 //! Get the element at the specified coordinates 00607 /** 00608 * \param i Parametric coordinates being evaluated 00609 * \param j Parametric coordinates being evaluated 00610 * \param k Parametric coordinates being evaluated 00611 */ 00612 EntityHandle get_element( int i, int j = 0, int k = 0 ) const; 00613 00614 //! Get the vertex at the specified coordinates 00615 /** 00616 * \param ijk Parametric coordinates being evaluated 00617 */ 00618 EntityHandle get_vertex( const HomCoord& ijk ) const; 00619 00620 //! Get the vertex at the specified coordinates 00621 /** 00622 * \param i Parametric coordinates being evaluated 00623 * \param j Parametric coordinates being evaluated 00624 * \param k Parametric coordinates being evaluated 00625 */ 00626 EntityHandle get_vertex( int i, int j = 0, int k = 0 ) const; 00627 00628 //! Get parametric coordinates of the specified entity 00629 /** This function returns MB_ENTITY_NOT_FOUND if the entity is not 00630 * in this ScdBox. 00631 * \param ent Entity being queried 00632 * \param i Parametric coordinates returned 00633 * \param j Parametric coordinates returned 00634 * \param k Parametric coordinates returned 00635 * \param dir Parametric coordinate direction returned (in case of getting adjacent 00636 * edges (2d, 3d) or faces (3d); not modified otherwise 00637 */ 00638 ErrorCode get_params( EntityHandle ent, int& i, int& j, int& k, int& dir ) const; 00639 00640 //! Get parametric coordinates of the specified entity, intermediate entities not allowed (no 00641 //! dir parameter) 00642 /** This function returns MB_ENTITY_NOT_FOUND if the entity is not 00643 * in this ScdBox, or MB_FAILURE if the entity is an intermediate-dimension entity. 00644 * \param ent Entity being queried 00645 * \param i Parametric coordinates returned 00646 * \param j Parametric coordinates returned 00647 * \param k Parametric coordinates returned 00648 */ 00649 ErrorCode get_params( EntityHandle ent, int& i, int& j, int& k ) const; 00650 00651 //! Get parametric coordinates of the specified entity 00652 /** This function returns MB_ENTITY_NOT_FOUND if the entity is not 00653 * in this ScdBox. 00654 * \param ent Entity being queried 00655 * \param ijkd Parametric coordinates returned (including direction, in case of 00656 * getting adjacent edges (2d, 3d) or faces (3d)) 00657 */ 00658 ErrorCode get_params( EntityHandle ent, HomCoord& ijkd ) const; 00659 00660 /** \brief Get the adjacent edge or face at a parametric location 00661 * This function gets the left (i=0), front (j=0), or bottom (k=0) edge or face for a parametric 00662 * element. Left, front, or bottom is indicated by dir = 0, 1, or 2, resp. All edges and faces 00663 * in a structured mesh block can be accessed using these parameters. \param dim Dimension of 00664 * adjacent entity being requested \param i Parametric coordinates of cell being evaluated 00665 * \param j Parametric coordinates of cell being evaluated 00666 * \param k Parametric coordinates of cell being evaluated 00667 * \param dir Direction (0, 1, or 2), for getting adjacent edges (2d, 3d) or faces (3d) 00668 * \param ent Entity returned from this function 00669 * \param create_if_missing If true, creates the entity if it doesn't already exist 00670 */ 00671 ErrorCode get_adj_edge_or_face( int dim, 00672 int i, 00673 int j, 00674 int k, 00675 int dir, 00676 EntityHandle& ent, 00677 bool create_if_missing = true ) const; 00678 00679 //! Return whether the box contains the parameters passed in 00680 /** 00681 * \param i Parametric coordinates being evaluated 00682 * \param j Parametric coordinates being evaluated 00683 * \param k Parametric coordinates being evaluated 00684 */ 00685 bool contains( int i, int j, int k ) const; 00686 00687 //! Return whether the box contains the parameters passed in 00688 /** 00689 * \param i Parametric coordinates being evaluated 00690 * \param j Parametric coordinates being evaluated 00691 * \param k Parametric coordinates being evaluated 00692 */ 00693 bool contains( const HomCoord& ijk ) const; 00694 00695 //! Set/Get the entity set representing the box 00696 void box_set( EntityHandle this_set ); 00697 EntityHandle box_set(); 00698 00699 //! Get coordinate arrays for vertex coordinates for a structured block 00700 /** Returns error if there isn't a single vertex sequence associated with this structured block 00701 * \param xc X coordinate array pointer returned 00702 * \param yc Y coordinate array pointer returned 00703 * \param zc Z coordinate array pointer returned 00704 */ 00705 ErrorCode get_coordinate_arrays( double*& xc, double*& yc, double*& zc ); 00706 00707 //! Get read-only coordinate arrays for vertex coordinates for a structured block 00708 /** Returns error if there isn't a single vertex sequence associated with this structured block 00709 * \param xc X coordinate array pointer returned 00710 * \param yc Y coordinate array pointer returned 00711 * \param zc Z coordinate array pointer returned 00712 */ 00713 ErrorCode get_coordinate_arrays( const double*& xc, const double*& yc, const double*& zc ) const; 00714 00715 //! Return whether box is locally periodic in i 00716 /** Return whether box is locally periodic in i 00717 * \return True if box is locally periodic in i direction 00718 */ 00719 bool locally_periodic_i() const; 00720 00721 //! Return whether box is locally periodic in j 00722 /** Return whether box is locally periodic in j 00723 * \return True if box is locally periodic in j direction 00724 */ 00725 bool locally_periodic_j() const; 00726 00727 //! Return whether box is locally periodic in k 00728 /** Return whether box is locally periodic in k 00729 * \return True if box is locally periodic in k direction 00730 */ 00731 bool locally_periodic_k() const; 00732 00733 //! Set local periodicity 00734 /** 00735 * \param lperiodic Vector of ijk periodicities to set this box to 00736 */ 00737 void locally_periodic( bool lperiodic[3] ); 00738 00739 //! Get local periodicity 00740 /** 00741 * \return Vector of ijk periodicities for this box 00742 */ 00743 const int* locally_periodic() const; 00744 00745 //! Return parallel data 00746 /** Return parallel data, if there is any 00747 * \return par_data Parallel data set on this box 00748 */ 00749 ScdParData& par_data() 00750 { 00751 return parData; 00752 } 00753 00754 //! Return parallel data 00755 /** Return parallel data, if there is any 00756 * \return par_data Parallel data set on this box 00757 */ 00758 const ScdParData& par_data() const 00759 { 00760 return parData; 00761 } 00762 00763 //! set parallel data 00764 /** Set parallel data for this box 00765 * \param par_data Parallel data to be set on this box 00766 */ 00767 void par_data( const ScdParData& par_datap ) 00768 { 00769 parData = par_datap; 00770 } 00771 00772 private: 00773 //! Constructor 00774 /** Create a structured box instance; this constructor is private because it should only be 00775 * called from ScdInterface, a friend class. This constructor takes two sequences, one of which 00776 * can be NULL. If both sequences come in non-NULL, the first should be a VertexSequence* 00777 * corresponding to a structured vertex sequence and the second should be a 00778 * StructuredElementSeq*. If the 2nd is NULL, the first can be either of those types. The 00779 * other members of this class are taken from the sequences (e.g. parametric space) or the box 00780 * set argument. Tags on the box set should be set from the caller. \param sc_impl A 00781 * ScdInterface instance \param box_set Entity set representing this rectangle \param seq1 An 00782 * EntitySequence (see ScdBox description) \param seq2 An EntitySequence (see ScdBox 00783 * description), or NULL 00784 */ 00785 ScdBox( ScdInterface* sc_impl, EntityHandle box_set, EntitySequence* seq1, EntitySequence* seq2 = NULL ); 00786 00787 //! function to get vertex handle directly from sequence 00788 /** \param i Parameter being queried 00789 * \param j Parameter being queried 00790 * \param k Parameter being queried 00791 */ 00792 EntityHandle get_vertex_from_seq( int i, int j, int k ) const; 00793 00794 //! set the vertex sequence 00795 ErrorCode vert_dat( ScdVertexData* vert_dat ); 00796 00797 //! get the vertex sequence 00798 ScdVertexData* vert_dat() const; 00799 00800 //! set the element sequence 00801 ErrorCode elem_seq( EntitySequence* elem_seq ); 00802 00803 //! get the element sequence 00804 StructuredElementSeq* elem_seq() const; 00805 00806 //! Set the starting vertex handle for this box 00807 void start_vertex( EntityHandle startv ); 00808 00809 //! Set the starting entity handle for this box 00810 void start_element( EntityHandle starte ); 00811 00812 //! interface instance 00813 ScdInterface* scImpl; 00814 00815 //! entity set representing this box 00816 EntityHandle boxSet; 00817 00818 //! vertex sequence this box represents, if there's only one, otherwise they're 00819 //! retrieved from the element sequence 00820 ScdVertexData* vertDat; 00821 00822 //! element sequence this box represents 00823 StructuredElementSeq* elemSeq; 00824 00825 //! starting vertex handle for this box 00826 EntityHandle startVertex; 00827 00828 //! starting element handle for this box 00829 EntityHandle startElem; 00830 00831 //! lower and upper corners 00832 int boxDims[6]; 00833 00834 //! is locally periodic in i or j or k 00835 int locallyPeriodic[3]; 00836 00837 //! parallel data associated with this box, if any 00838 ScdParData parData; 00839 00840 //! parameter extents 00841 HomCoord boxSize; 00842 00843 //! convenience parameters, (boxSize[1]-1)*(boxSize[0]-1) and boxSize[0]-1 00844 int boxSizeIJ; 00845 int boxSizeIJM1; 00846 int boxSizeIM1; 00847 }; 00848 00849 inline ErrorCode ScdInterface::compute_partition( int np, 00850 int nr, 00851 const ScdParData& par_data, 00852 int* ldims, 00853 int* lperiodic, 00854 int* pdims ) 00855 { 00856 ErrorCode rval = MB_SUCCESS; 00857 switch( par_data.partMethod ) 00858 { 00859 case ScdParData::ALLJORKORI: 00860 case -1: 00861 rval = compute_partition_alljorkori( np, nr, par_data.gDims, par_data.gPeriodic, ldims, lperiodic, pdims ); 00862 break; 00863 case ScdParData::ALLJKBAL: 00864 rval = compute_partition_alljkbal( np, nr, par_data.gDims, par_data.gPeriodic, ldims, lperiodic, pdims ); 00865 break; 00866 case ScdParData::SQIJ: 00867 rval = compute_partition_sqij( np, nr, par_data.gDims, par_data.gPeriodic, ldims, lperiodic, pdims ); 00868 break; 00869 case ScdParData::SQJK: 00870 rval = compute_partition_sqjk( np, nr, par_data.gDims, par_data.gPeriodic, ldims, lperiodic, pdims ); 00871 break; 00872 case ScdParData::SQIJK: 00873 rval = compute_partition_sqijk( np, nr, par_data.gDims, par_data.gPeriodic, ldims, lperiodic, pdims ); 00874 break; 00875 default: 00876 rval = MB_FAILURE; 00877 break; 00878 } 00879 00880 return rval; 00881 } 00882 00883 inline ErrorCode ScdInterface::compute_partition_alljorkori( int np, 00884 int nr, 00885 const int gijk[6], 00886 const int* const gperiodic, 00887 int* ldims, 00888 int* lperiodic, 00889 int* pijk ) 00890 { 00891 // partition *the elements* over the parametric space; 1d partition for now, in the j, k, or i 00892 // parameters 00893 int tmp_lp[3], tmp_pijk[3]; 00894 if( !lperiodic ) lperiodic = tmp_lp; 00895 if( !pijk ) pijk = tmp_pijk; 00896 00897 for( int i = 0; i < 3; i++ ) 00898 lperiodic[i] = gperiodic[i]; 00899 00900 if( np == 1 ) 00901 { 00902 if( ldims ) 00903 { 00904 ldims[0] = gijk[0]; 00905 ldims[3] = gijk[3]; 00906 ldims[1] = gijk[1]; 00907 ldims[4] = gijk[4]; 00908 ldims[2] = gijk[2]; 00909 ldims[5] = gijk[5]; 00910 } 00911 pijk[0] = pijk[1] = pijk[2] = 1; 00912 } 00913 else 00914 { 00915 if( gijk[4] - gijk[1] > np ) 00916 { 00917 // partition j over procs 00918 int dj = ( gijk[4] - gijk[1] ) / np; 00919 int extra = ( gijk[4] - gijk[1] ) % np; 00920 ldims[1] = gijk[1] + nr * dj + std::min( nr, extra ); 00921 ldims[4] = ldims[1] + dj + ( nr < extra ? 1 : 0 ); 00922 00923 if( gperiodic[1] && np > 1 ) 00924 { 00925 lperiodic[1] = 0; 00926 ldims[4]++; 00927 } 00928 00929 ldims[2] = gijk[2]; 00930 ldims[5] = gijk[5]; 00931 ldims[0] = gijk[0]; 00932 ldims[3] = gijk[3]; 00933 pijk[0] = pijk[2] = 1; 00934 pijk[1] = np; 00935 } 00936 else if( gijk[5] - gijk[2] > np ) 00937 { 00938 // partition k over procs 00939 int dk = ( gijk[5] - gijk[2] ) / np; 00940 int extra = ( gijk[5] - gijk[2] ) % np; 00941 ldims[2] = gijk[2] + nr * dk + std::min( nr, extra ); 00942 ldims[5] = ldims[2] + dk + ( nr < extra ? 1 : 0 ); 00943 00944 ldims[1] = gijk[1]; 00945 ldims[4] = gijk[4]; 00946 ldims[0] = gijk[0]; 00947 ldims[3] = gijk[3]; 00948 pijk[0] = pijk[1] = 1; 00949 pijk[2] = np; 00950 } 00951 else if( gijk[3] - gijk[0] > np ) 00952 { 00953 // partition i over procs 00954 int di = ( gijk[3] - gijk[0] ) / np; 00955 int extra = ( gijk[3] - gijk[0] ) % np; 00956 ldims[0] = gijk[0] + nr * di + std::min( nr, extra ); 00957 ldims[3] = ldims[0] + di + ( nr < extra ? 1 : 0 ); 00958 00959 if( gperiodic[0] && np > 1 ) 00960 { 00961 lperiodic[0] = 0; 00962 ldims[3]++; 00963 } 00964 00965 ldims[2] = gijk[2]; 00966 ldims[5] = gijk[5]; 00967 ldims[1] = gijk[1]; 00968 ldims[4] = gijk[4]; 00969 00970 pijk[1] = pijk[2] = 1; 00971 pijk[0] = np; 00972 } 00973 else 00974 { 00975 // Couldn't find a suitable partition... 00976 return MB_FAILURE; 00977 } 00978 } 00979 00980 return MB_SUCCESS; 00981 } 00982 00983 inline ErrorCode ScdInterface::compute_partition_alljkbal( int np, 00984 int nr, 00985 const int gijk[6], 00986 const int* const gperiodic, 00987 int* ldims, 00988 int* lperiodic, 00989 int* pijk ) 00990 { 00991 int tmp_lp[3], tmp_pijk[3]; 00992 if( !lperiodic ) lperiodic = tmp_lp; 00993 if( !pijk ) pijk = tmp_pijk; 00994 00995 for( int i = 0; i < 3; i++ ) 00996 lperiodic[i] = gperiodic[i]; 00997 00998 if( np == 1 ) 00999 { 01000 if( ldims ) 01001 { 01002 ldims[0] = gijk[0]; 01003 ldims[3] = gijk[3]; 01004 ldims[1] = gijk[1]; 01005 ldims[4] = gijk[4]; 01006 ldims[2] = gijk[2]; 01007 ldims[5] = gijk[5]; 01008 } 01009 pijk[0] = pijk[1] = pijk[2] = 1; 01010 } 01011 else 01012 { 01013 // improved, possibly 2-d partition 01014 std::vector< double > kfactors; 01015 kfactors.push_back( 1 ); 01016 int K = gijk[5] - gijk[2]; 01017 for( int i = 2; i < K; i++ ) 01018 if( !( K % i ) && !( np % i ) ) kfactors.push_back( i ); 01019 kfactors.push_back( K ); 01020 01021 // compute the ideal nj and nk 01022 int J = gijk[4] - gijk[1]; 01023 double njideal = sqrt( ( (double)( np * J ) ) / ( (double)K ) ); 01024 double nkideal = ( njideal * K ) / J; 01025 01026 int nk, nj; 01027 if( nkideal < 1.0 ) 01028 { 01029 nk = 1; 01030 nj = np; 01031 } 01032 else 01033 { 01034 std::vector< double >::iterator vit = std::lower_bound( kfactors.begin(), kfactors.end(), nkideal ); 01035 if( vit == kfactors.begin() ) 01036 nk = 1; 01037 else 01038 nk = (int)*( --vit ); 01039 nj = np / nk; 01040 } 01041 01042 int dk = K / nk; 01043 int dj = J / nj; 01044 01045 ldims[2] = gijk[2] + ( nr % nk ) * dk; 01046 ldims[5] = ldims[2] + dk; 01047 01048 int extra = J % nj; 01049 01050 ldims[1] = gijk[1] + ( nr / nk ) * dj + std::min( nr / nk, extra ); 01051 ldims[4] = ldims[1] + dj + ( nr / nk < extra ? 1 : 0 ); 01052 01053 ldims[0] = gijk[0]; 01054 ldims[3] = gijk[3]; 01055 01056 if( gperiodic[1] && np > 1 ) 01057 { 01058 lperiodic[1] = 0; 01059 if( nr / nk == nj - 1 ) 01060 { 01061 ldims[1]++; 01062 } 01063 } 01064 01065 pijk[0] = 1; 01066 pijk[1] = nj; 01067 pijk[2] = nk; 01068 } 01069 01070 return MB_SUCCESS; 01071 } 01072 01073 inline ErrorCode ScdInterface::compute_partition_sqij( int np, 01074 int nr, 01075 const int gijk[6], 01076 const int* const gperiodic, 01077 int* ldims, 01078 int* lperiodic, 01079 int* pijk ) 01080 { 01081 int tmp_lp[3], tmp_pijk[3]; 01082 if( !lperiodic ) lperiodic = tmp_lp; 01083 if( !pijk ) pijk = tmp_pijk; 01084 01085 // square IxJ partition 01086 01087 for( int i = 0; i < 3; i++ ) 01088 lperiodic[i] = gperiodic[i]; 01089 01090 if( np == 1 ) 01091 { 01092 if( ldims ) 01093 { 01094 ldims[0] = gijk[0]; 01095 ldims[3] = gijk[3]; 01096 ldims[1] = gijk[1]; 01097 ldims[4] = gijk[4]; 01098 ldims[2] = gijk[2]; 01099 ldims[5] = gijk[5]; 01100 } 01101 pijk[0] = pijk[1] = pijk[2] = 1; 01102 } 01103 else 01104 { 01105 std::vector< double > pfactors, ppfactors; 01106 for( int i = 2; i <= np / 2; i++ ) 01107 if( !( np % i ) ) 01108 { 01109 pfactors.push_back( i ); 01110 ppfactors.push_back( ( (double)( i * i ) ) / np ); 01111 } 01112 pfactors.push_back( np ); 01113 ppfactors.push_back( (double)np ); 01114 01115 // ideally, Px/Py = I/J 01116 double ijratio = ( (double)( gijk[3] - gijk[0] ) ) / ( (double)( gijk[4] - gijk[1] ) ); 01117 01118 unsigned int ind = 0; 01119 std::vector< double >::iterator optimal = std::lower_bound( ppfactors.begin(), ppfactors.end(), ijratio ); 01120 if( optimal == ppfactors.end() ) 01121 { 01122 ind = ppfactors.size() - 1; 01123 } 01124 else 01125 { 01126 ind = optimal - ppfactors.begin(); 01127 if( ind && fabs( ppfactors[ind - 1] - ijratio ) < fabs( ppfactors[ind] - ijratio ) ) ind--; 01128 } 01129 01130 // VARIABLES DESCRIBING THE MESH: 01131 // pi, pj = # procs in i and j directions 01132 // nri, nrj = my proc's position in i, j directions 01133 // I, J = # edges/elements in i, j directions 01134 // iextra, jextra = # procs having extra edge in i/j direction 01135 // top_i, top_j = if true, I'm the last proc in the i/j direction 01136 // i, j = # edges locally in i/j direction, *not* including one for iextra/jextra 01137 int pi = pfactors[ind]; 01138 int pj = np / pi; 01139 01140 int I = ( gijk[3] - gijk[0] ), J = ( gijk[4] - gijk[1] ); 01141 int iextra = I % pi, jextra = J % pj, i = I / pi, j = J / pj; 01142 int nri = nr % pi, nrj = nr / pi; 01143 01144 if( ldims ) 01145 { 01146 ldims[0] = gijk[0] + i * nri + std::min( iextra, nri ); 01147 ldims[3] = ldims[0] + i + ( nri < iextra ? 1 : 0 ); 01148 ldims[1] = gijk[1] + j * nrj + std::min( jextra, nrj ); 01149 ldims[4] = ldims[1] + j + ( nrj < jextra ? 1 : 0 ); 01150 01151 ldims[2] = gijk[2]; 01152 ldims[5] = gijk[5]; 01153 01154 if( gperiodic[0] && pi > 1 ) 01155 { 01156 lperiodic[0] = 0; 01157 if( nri == pi - 1 ) ldims[3]++; 01158 } 01159 if( gperiodic[1] && pj > 1 ) 01160 { 01161 lperiodic[1] = 0; 01162 if( nrj == pj - 1 ) ldims[4]++; 01163 } 01164 } 01165 01166 pijk[0] = pi; 01167 pijk[1] = pj; 01168 pijk[2] = 1; 01169 } 01170 01171 return MB_SUCCESS; 01172 } 01173 01174 inline ErrorCode ScdInterface::compute_partition_sqjk( int np, 01175 int nr, 01176 const int gijk[6], 01177 const int* const gperiodic, 01178 int* ldims, 01179 int* lperiodic, 01180 int* pijk ) 01181 { 01182 int tmp_lp[3], tmp_pijk[3]; 01183 if( !lperiodic ) lperiodic = tmp_lp; 01184 if( !pijk ) pijk = tmp_pijk; 01185 01186 // square JxK partition 01187 for( int i = 0; i < 3; i++ ) 01188 lperiodic[i] = gperiodic[i]; 01189 01190 if( np == 1 ) 01191 { 01192 if( ldims ) 01193 { 01194 ldims[0] = gijk[0]; 01195 ldims[3] = gijk[3]; 01196 ldims[1] = gijk[1]; 01197 ldims[4] = gijk[4]; 01198 ldims[2] = gijk[2]; 01199 ldims[5] = gijk[5]; 01200 } 01201 pijk[0] = pijk[1] = pijk[2] = 1; 01202 } 01203 else 01204 { 01205 std::vector< double > pfactors, ppfactors; 01206 for( int p = 2; p <= np; p++ ) 01207 if( !( np % p ) ) 01208 { 01209 pfactors.push_back( p ); 01210 ppfactors.push_back( ( (double)( p * p ) ) / np ); 01211 } 01212 01213 // ideally, Pj/Pk = J/K 01214 int pj, pk; 01215 if( gijk[5] == gijk[2] ) 01216 { 01217 pk = 1; 01218 pj = np; 01219 } 01220 else 01221 { 01222 double jkratio = ( (double)( gijk[4] - gijk[1] ) ) / ( (double)( gijk[5] - gijk[2] ) ); 01223 01224 std::vector< double >::iterator vit = std::lower_bound( ppfactors.begin(), ppfactors.end(), jkratio ); 01225 if( vit == ppfactors.end() ) 01226 --vit; 01227 else if( vit != ppfactors.begin() && fabs( *( vit - 1 ) - jkratio ) < fabs( ( *vit ) - jkratio ) ) 01228 --vit; 01229 int ind = vit - ppfactors.begin(); 01230 01231 pj = 1; 01232 if( ind >= 0 && !pfactors.empty() ) pfactors[ind]; 01233 pk = np / pj; 01234 } 01235 01236 int K = ( gijk[5] - gijk[2] ), J = ( gijk[4] - gijk[1] ); 01237 int jextra = J % pj, kextra = K % pk, j = J / pj, k = K / pk; 01238 int nrj = nr % pj, nrk = nr / pj; 01239 ldims[1] = gijk[1] + j * nrj + std::min( jextra, nrj ); 01240 ldims[4] = ldims[1] + j + ( nrj < jextra ? 1 : 0 ); 01241 ldims[2] = gijk[2] + k * nrk + std::min( kextra, nrk ); 01242 ldims[5] = ldims[2] + k + ( nrk < kextra ? 1 : 0 ); 01243 01244 ldims[0] = gijk[0]; 01245 ldims[3] = gijk[3]; 01246 01247 if( gperiodic[1] && pj > 1 ) 01248 { 01249 lperiodic[1] = 0; 01250 if( nrj == pj - 1 ) ldims[4]++; 01251 } 01252 01253 pijk[0] = 1; 01254 pijk[1] = pj; 01255 pijk[2] = pk; 01256 } 01257 01258 return MB_SUCCESS; 01259 } 01260 01261 inline ErrorCode ScdInterface::compute_partition_sqijk( int np, 01262 int nr, 01263 const int* const gijk, 01264 const int* const gperiodic, 01265 int* ldims, 01266 int* lperiodic, 01267 int* pijk ) 01268 { 01269 if( gperiodic[0] || gperiodic[1] || gperiodic[2] ) return MB_FAILURE; 01270 01271 int tmp_lp[3], tmp_pijk[3]; 01272 if( !lperiodic ) lperiodic = tmp_lp; 01273 if( !pijk ) pijk = tmp_pijk; 01274 01275 // square IxJxK partition 01276 01277 for( int i = 0; i < 3; i++ ) 01278 lperiodic[i] = gperiodic[i]; 01279 01280 if( np == 1 ) 01281 { 01282 if( ldims ) 01283 for( int i = 0; i < 6; i++ ) 01284 ldims[i] = gijk[i]; 01285 pijk[0] = pijk[1] = pijk[2] = 1; 01286 return MB_SUCCESS; 01287 } 01288 01289 std::vector< int > pfactors; 01290 pfactors.push_back( 1 ); 01291 for( int i = 2; i <= np / 2; i++ ) 01292 if( !( np % i ) ) pfactors.push_back( i ); 01293 pfactors.push_back( np ); 01294 01295 // test for IJ, JK, IK 01296 int IJK[3], dIJK[3]; 01297 for( int i = 0; i < 3; i++ ) 01298 IJK[i] = std::max( gijk[3 + i] - gijk[i], 1 ); 01299 // order IJK from lo to hi 01300 int lo = 0, hi = 0; 01301 for( int i = 1; i < 3; i++ ) 01302 { 01303 if( IJK[i] < IJK[lo] ) lo = i; 01304 if( IJK[i] > IJK[hi] ) hi = i; 01305 } 01306 if( lo == hi ) hi = ( lo + 1 ) % 3; 01307 int mid = 3 - lo - hi; 01308 // search for perfect subdivision of np that balances #cells 01309 int perfa_best = -1, perfb_best = -1; 01310 double ratio = 0.0; 01311 for( int po = 0; po < (int)pfactors.size(); po++ ) 01312 { 01313 for( int pi = po; pi < (int)pfactors.size() && np / ( pfactors[po] * pfactors[pi] ) >= pfactors[pi]; pi++ ) 01314 { 01315 int p3 = 01316 std::find( pfactors.begin(), pfactors.end(), np / ( pfactors[po] * pfactors[pi] ) ) - pfactors.begin(); 01317 if( p3 == (int)pfactors.size() || pfactors[po] * pfactors[pi] * pfactors[p3] != np ) 01318 continue; // po*pi should exactly factor np 01319 assert( po <= pi && pi <= p3 ); 01320 // by definition, po <= pi <= p3 01321 double minl = 01322 std::min( std::min( IJK[lo] / pfactors[po], IJK[mid] / pfactors[pi] ), IJK[hi] / pfactors[p3] ), 01323 maxl = 01324 std::max( std::max( IJK[lo] / pfactors[po], IJK[mid] / pfactors[pi] ), IJK[hi] / pfactors[p3] ); 01325 if( minl / maxl > ratio ) 01326 { 01327 ratio = minl / maxl; 01328 perfa_best = po; 01329 perfb_best = pi; 01330 } 01331 } 01332 } 01333 if( perfa_best == -1 || perfb_best == -1 ) return MB_FAILURE; 01334 01335 // VARIABLES DESCRIBING THE MESH: 01336 // pijk[i] = # procs in direction i 01337 // numr[i] = my proc's position in direction i 01338 // dIJK[i] = # edges/elements in direction i 01339 // extra[i]= # procs having extra edge in direction i 01340 // top[i] = if true, I'm the last proc in direction i 01341 01342 pijk[lo] = pfactors[perfa_best]; 01343 pijk[mid] = pfactors[perfb_best]; 01344 pijk[hi] = ( np / ( pfactors[perfa_best] * pfactors[perfb_best] ) ); 01345 int extra[3] = { 0, 0, 0 }, numr[3]; 01346 for( int i = 0; i < 3; i++ ) 01347 { 01348 dIJK[i] = IJK[i] / pijk[i]; 01349 extra[i] = IJK[i] % pijk[i]; 01350 } 01351 numr[2] = nr / ( pijk[0] * pijk[1] ); 01352 int rem = nr % ( pijk[0] * pijk[1] ); 01353 numr[1] = rem / pijk[0]; 01354 numr[0] = rem % pijk[0]; 01355 for( int i = 0; i < 3; i++ ) 01356 { 01357 extra[i] = IJK[i] % dIJK[i]; 01358 ldims[i] = gijk[i] + numr[i] * dIJK[i] + std::min( extra[i], numr[i] ); 01359 ldims[3 + i] = ldims[i] + dIJK[i] + ( numr[i] < extra[i] ? 1 : 0 ); 01360 } 01361 01362 return MB_SUCCESS; 01363 } 01364 01365 inline int ScdInterface::gtol( const int* gijk, int i, int j, int k ) 01366 { 01367 return ( ( k - gijk[2] ) * ( gijk[3] - gijk[0] + 1 ) * ( gijk[4] - gijk[1] + 1 ) + 01368 ( j - gijk[1] ) * ( gijk[3] - gijk[0] + 1 ) + i - gijk[0] ); 01369 } 01370 01371 inline ErrorCode ScdInterface::get_indices( const int* const ldims, 01372 const int* const rdims, 01373 const int* const across_bdy, 01374 int* face_dims, 01375 std::vector< int >& shared_indices ) 01376 { 01377 // check for going across periodic bdy and face_dims not in my ldims (I'll always be on top in 01378 // that case)... 01379 if( across_bdy[0] > 0 && face_dims[0] != ldims[3] ) 01380 face_dims[0] = face_dims[3] = ldims[3]; 01381 else if( across_bdy[0] < 0 && face_dims[0] != ldims[0] ) 01382 face_dims[0] = face_dims[3] = ldims[0]; 01383 if( across_bdy[1] > 0 && face_dims[1] != ldims[4] ) 01384 face_dims[1] = face_dims[4] = ldims[4]; 01385 else if( across_bdy[1] < 0 && face_dims[1] != ldims[1] ) 01386 face_dims[0] = face_dims[3] = ldims[1]; 01387 01388 for( int k = face_dims[2]; k <= face_dims[5]; k++ ) 01389 for( int j = face_dims[1]; j <= face_dims[4]; j++ ) 01390 for( int i = face_dims[0]; i <= face_dims[3]; i++ ) 01391 shared_indices.push_back( gtol( ldims, i, j, k ) ); 01392 01393 if( across_bdy[0] > 0 && face_dims[0] != rdims[0] ) 01394 face_dims[0] = face_dims[3] = rdims[0]; 01395 else if( across_bdy[0] < 0 && face_dims[0] != rdims[3] ) 01396 face_dims[0] = face_dims[3] = rdims[3]; 01397 if( across_bdy[1] > 0 && face_dims[1] != rdims[1] ) 01398 face_dims[1] = face_dims[4] = rdims[1]; 01399 else if( across_bdy[1] < 0 && face_dims[1] != rdims[4] ) 01400 face_dims[0] = face_dims[3] = rdims[4]; 01401 01402 for( int k = face_dims[2]; k <= face_dims[5]; k++ ) 01403 for( int j = face_dims[1]; j <= face_dims[4]; j++ ) 01404 for( int i = face_dims[0]; i <= face_dims[3]; i++ ) 01405 shared_indices.push_back( gtol( rdims, i, j, k ) ); 01406 01407 return MB_SUCCESS; 01408 } 01409 01410 inline ErrorCode ScdInterface::get_neighbor( int np, 01411 int pfrom, 01412 const ScdParData& spd, 01413 const int* const dijk, 01414 int& pto, 01415 int* rdims, 01416 int* facedims, 01417 int* across_bdy ) 01418 { 01419 if( !dijk[0] && !dijk[1] && !dijk[2] ) 01420 { 01421 // not going anywhere, return 01422 pto = -1; 01423 return MB_SUCCESS; 01424 } 01425 01426 switch( spd.partMethod ) 01427 { 01428 case ScdParData::ALLJORKORI: 01429 case -1: 01430 return get_neighbor_alljorkori( np, pfrom, spd.gDims, spd.gPeriodic, dijk, pto, rdims, facedims, 01431 across_bdy ); 01432 case ScdParData::ALLJKBAL: 01433 return get_neighbor_alljkbal( np, pfrom, spd.gDims, spd.gPeriodic, dijk, pto, rdims, facedims, across_bdy ); 01434 case ScdParData::SQIJ: 01435 return get_neighbor_sqij( np, pfrom, spd.gDims, spd.gPeriodic, dijk, pto, rdims, facedims, across_bdy ); 01436 case ScdParData::SQJK: 01437 return get_neighbor_sqjk( np, pfrom, spd.gDims, spd.gPeriodic, dijk, pto, rdims, facedims, across_bdy ); 01438 case ScdParData::SQIJK: 01439 return get_neighbor_sqijk( np, pfrom, spd.gDims, spd.gPeriodic, dijk, pto, rdims, facedims, across_bdy ); 01440 default: 01441 break; 01442 } 01443 01444 return MB_FAILURE; 01445 } 01446 01447 inline ErrorCode ScdInterface::tag_shared_vertices( ParallelComm* pcomm, EntityHandle seth ) 01448 { 01449 ScdBox* box = get_scd_box( seth ); 01450 if( !box ) 01451 { 01452 // look for contained boxes 01453 Range tmp_range; 01454 ErrorCode rval = mbImpl->get_entities_by_type( seth, MBENTITYSET, tmp_range ); 01455 if( MB_SUCCESS != rval ) return rval; 01456 for( Range::iterator rit = tmp_range.begin(); rit != tmp_range.end(); ++rit ) 01457 { 01458 box = get_scd_box( *rit ); 01459 if( box ) break; 01460 } 01461 } 01462 01463 if( !box ) return MB_FAILURE; 01464 01465 return tag_shared_vertices( pcomm, box ); 01466 } 01467 01468 inline ScdInterface* ScdBox::sc_impl() const 01469 { 01470 return scImpl; 01471 } 01472 01473 inline EntityHandle ScdBox::start_vertex() const 01474 { 01475 return startVertex; 01476 } 01477 01478 inline void ScdBox::start_vertex( EntityHandle startv ) 01479 { 01480 startVertex = startv; 01481 } 01482 01483 inline EntityHandle ScdBox::start_element() const 01484 { 01485 return startElem; 01486 } 01487 01488 inline void ScdBox::start_element( EntityHandle starte ) 01489 { 01490 startElem = starte; 01491 } 01492 01493 inline int ScdBox::num_elements() const 01494 { 01495 if( !startElem ) return 0; // not initialized yet 01496 01497 /* for a structured mesh, total number of elements is obtained by multiplying 01498 number of elements in each direction 01499 number of elements in each direction is given by number of vertices in that direction minus 1 01500 if periodic in that direction, the last vertex is the same as first one, count one more 01501 element 01502 */ 01503 int num_e_i = ( -1 == boxSize[0] || 1 == boxSize[0] ) ? 1 : boxSize[0] - 1; 01504 if( locallyPeriodic[0] ) ++num_e_i; 01505 01506 int num_e_j = ( -1 == boxSize[1] || 1 == boxSize[1] ) ? 1 : boxSize[1] - 1; 01507 if( locallyPeriodic[1] ) ++num_e_j; 01508 01509 int num_e_k = ( -1 == boxSize[2] || 1 == boxSize[2] ) ? 1 : boxSize[2] - 1; 01510 if( locallyPeriodic[2] ) ++num_e_k; 01511 01512 return num_e_i * num_e_j * num_e_k; 01513 } 01514 01515 inline int ScdBox::num_vertices() const 01516 { 01517 return boxSize[0] * ( !boxSize[1] ? 1 : boxSize[1] ) * ( !boxSize[2] ? 1 : boxSize[2] ); 01518 } 01519 01520 inline const int* ScdBox::box_dims() const 01521 { 01522 return boxDims; 01523 } 01524 01525 inline HomCoord ScdBox::box_min() const 01526 { 01527 return HomCoord( boxDims, 3 ); 01528 } 01529 01530 inline HomCoord ScdBox::box_max() const 01531 { 01532 return HomCoord( boxDims + 3, 3 ); 01533 } 01534 01535 inline HomCoord ScdBox::box_size() const 01536 { 01537 return boxSize; 01538 } 01539 01540 inline void ScdBox::box_size( int* ijk ) const 01541 { 01542 ijk[0] = boxSize[0]; 01543 ijk[1] = boxSize[1]; 01544 ijk[2] = boxSize[2]; 01545 } 01546 01547 inline void ScdBox::box_size( int& i, int& j, int& k ) const 01548 { 01549 i = boxSize[0]; 01550 j = boxSize[1]; 01551 k = boxSize[2]; 01552 } 01553 01554 inline EntityHandle ScdBox::get_element( int i, int j, int k ) const 01555 { 01556 return ( !startElem 01557 ? 0 01558 : startElem + ( k - boxDims[2] ) * boxSizeIJM1 + ( j - boxDims[1] ) * boxSizeIM1 + i - boxDims[0] ); 01559 } 01560 01561 inline EntityHandle ScdBox::get_element( const HomCoord& ijk ) const 01562 { 01563 return get_element( ijk[0], ijk[1], ijk[2] ); 01564 } 01565 01566 inline EntityHandle ScdBox::get_vertex( int i, int j, int k ) const 01567 { 01568 return ( vertDat 01569 ? startVertex + ( boxDims[2] == -1 && boxDims[5] == -1 ? 0 : ( k - boxDims[2] ) ) * boxSizeIJ + 01570 ( boxDims[1] == -1 && boxDims[4] == -1 ? 0 : ( j - boxDims[1] ) ) * boxSize[0] + i - boxDims[0] 01571 : get_vertex_from_seq( i, j, k ) ); 01572 } 01573 01574 inline EntityHandle ScdBox::get_vertex( const HomCoord& ijk ) const 01575 { 01576 return get_vertex( ijk[0], ijk[1], ijk[2] ); 01577 } 01578 01579 inline bool ScdBox::contains( const HomCoord& ijk ) const 01580 { 01581 return ( ijk >= HomCoord( boxDims, 3 ) && ijk <= HomCoord( boxDims + 3, 3 ) ); 01582 } 01583 01584 inline bool ScdBox::contains( int i, int j, int k ) const 01585 { 01586 return contains( HomCoord( i, j, k ) ); 01587 } 01588 01589 inline void ScdBox::box_set( EntityHandle this_set ) 01590 { 01591 boxSet = this_set; 01592 } 01593 01594 inline EntityHandle ScdBox::box_set() 01595 { 01596 return boxSet; 01597 } 01598 01599 inline ScdVertexData* ScdBox::vert_dat() const 01600 { 01601 return vertDat; 01602 } 01603 01604 inline StructuredElementSeq* ScdBox::elem_seq() const 01605 { 01606 return elemSeq; 01607 } 01608 01609 inline ErrorCode ScdBox::get_params( EntityHandle ent, int& i, int& j, int& k, int& dir ) const 01610 { 01611 HomCoord hc; 01612 ErrorCode rval = get_params( ent, hc ); 01613 if( MB_SUCCESS == rval ) 01614 { 01615 i = hc[0]; 01616 j = hc[1]; 01617 k = hc[2]; 01618 dir = hc[3]; 01619 } 01620 01621 return rval; 01622 } 01623 01624 inline ErrorCode ScdBox::get_params( EntityHandle ent, int& i, int& j, int& k ) const 01625 { 01626 HomCoord hc; 01627 ErrorCode rval = get_params( ent, hc ); 01628 if( MB_SUCCESS == rval ) 01629 { 01630 i = hc[0]; 01631 j = hc[1]; 01632 k = hc[2]; 01633 } 01634 01635 return rval; 01636 } 01637 01638 inline bool ScdBox::locally_periodic_i() const 01639 { 01640 return locallyPeriodic[0]; 01641 } 01642 01643 inline bool ScdBox::locally_periodic_j() const 01644 { 01645 return locallyPeriodic[1]; 01646 } 01647 01648 inline bool ScdBox::locally_periodic_k() const 01649 { 01650 return locallyPeriodic[2]; 01651 } 01652 01653 inline void ScdBox::locally_periodic( bool lperiodic[3] ) 01654 { 01655 for( int i = 0; i < 3; i++ ) 01656 locallyPeriodic[i] = lperiodic[i]; 01657 } 01658 01659 inline const int* ScdBox::locally_periodic() const 01660 { 01661 return locallyPeriodic; 01662 } 01663 01664 std::ostream& operator<<( std::ostream& str, const ScdParData& pd ); 01665 01666 } // namespace moab 01667 #endif
