moab::WriteHDF5::TagDesc Struct Reference
Tag to write to file. More...
#include <WriteHDF5.hpp>
+ Collaboration diagram for moab::WriteHDF5::TagDesc:
Public Member Functions
bool have_dense (const ExportType &type) const
bool operator< (const TagDesc &) const
Public Attributes
Tag tag_id
 The tag handle.
wid_t sparse_offset
wid_t var_data_offset
bool write_sparse
 Write sparse tag data (for serial, is always equal to !range.empty())
unsigned long max_num_ents
unsigned long max_num_vals
std::vector< ExportType > dense_list
Detailed Description
Definition at line 153 of file WriteHDF5.hpp.
Member Function Documentation
bool moab::WriteHDF5::TagDesc::have_dense ( const ExportType &  type) const [inline]
Definition at line 179 of file WriteHDF5.hpp.
References dense_list, and moab::WriteHDF5::find().
Referenced by moab::WriteHDF5::get_sparse_tagged_entities().
            return std::find( dense_list.begin(), dense_list.end(), type ) != dense_list.end();
bool moab::WriteHDF5::TagDesc::operator< ( const TagDesc &  ) const
Member Data Documentation
List of entity groups for which to write tag data in dense format
Definition at line 177 of file WriteHDF5.hpp.
Referenced by moab::WriteHDF5::create_tag(), have_dense(), and moab::WriteHDF5::write_tag().
If doing parallel IO, largest number, over all processes, of entities for which to write tag data. Zero if unused.
Definition at line 168 of file WriteHDF5.hpp.
Referenced by moab::WriteHDF5Parallel::check_serial_tag_data(), moab::WriteHDF5::gather_tags(), moab::WriteHDF5::write_sparse_ids(), moab::WriteHDF5::write_sparse_tag(), and moab::WriteHDF5::write_var_len_indices().
For variable-length tags during parallel IO: the largest number of tag values to be written on by any process, used to calculate the total number of collective writes that all processes must do. Zero for fixed-length tags or if not doing parallel IO.
Definition at line 173 of file WriteHDF5.hpp.
Referenced by moab::WriteHDF5Parallel::check_serial_tag_data(), moab::WriteHDF5::gather_tags(), and moab::WriteHDF5::write_var_len_data().
For variable-length tags, a second offset for the tag data table, separate from the offset used for the ID and Index tables. Always zero except for parallel IO.
Definition at line 163 of file WriteHDF5.hpp.
Referenced by moab::WriteHDF5Parallel::check_serial_tag_data(), moab::WriteHDF5::gather_tags(), moab::WriteHDF5::write_var_len_data(), and moab::WriteHDF5::write_var_len_indices().
Definition at line 165 of file WriteHDF5.hpp.
Referenced by moab::WriteHDF5Parallel::check_serial_tag_data(), moab::WriteHDF5::gather_tags(), and moab::WriteHDF5::write_tag().
List of all members.
The documentation for this struct was generated from the following file:
