MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 #ifndef WRITE_HDF5_HPP 00017 #define WRITE_HDF5_HPP 00018 00019 #include <list> 00020 #include "moab/MOABConfig.h" 00021 #ifdef MOAB_HAVE_MPI // include this before HDF5 headers to avoid conflicts 00022 #include "moab_mpi.h" 00023 #endif 00024 #include "moab_mpe.h" 00025 #include "mhdf.h" 00026 #include "moab/Forward.hpp" 00027 #include "moab/Range.hpp" 00028 #include "moab/WriterIface.hpp" 00029 #include "moab/RangeMap.hpp" 00030 #include "moab/WriteUtilIface.hpp" 00031 #include "DebugOutput.hpp" 00032 #include "HDF5Common.hpp" 00033 00034 namespace moab 00035 { 00036 00037 class IODebugTrack; 00038 00039 /* If this define is not set, node->entity adjacencies will not be written */ 00040 #undef MB_H5M_WRITE_NODE_ADJACENCIES 00041 00042 /** 00043 * \brief Write mesh database to MOAB's native HDF5-based file format. 00044 * \author Jason Kraftcheck 00045 * \date 01 April 2004 00046 */ 00047 class WriteHDF5 : public WriterIface 00048 { 00049 00050 public: 00051 static WriterIface* factory( Interface* ); 00052 00053 WriteHDF5( Interface* iface ); 00054 00055 virtual ~WriteHDF5(); 00056 00057 /** Export specified meshsets to file 00058 * \param filename The filename to export. 00059 * \param export_sets Array of handles to sets to export, or NULL to export all. 00060 * \param export_set_count Length of <code>export_sets</code> array. 00061 */ 00062 ErrorCode write_file( const char* filename, 00063 const bool overwrite, 00064 const FileOptions& opts, 00065 const EntityHandle* export_sets, 00066 const int export_set_count, 00067 const std::vector< std::string >& qa_records, 00068 const Tag* tag_list = NULL, 00069 int num_tags = 0, 00070 int user_dimension = 3 ); 00071 00072 /** The type to use for entity IDs w/in the file. 00073 * 00074 * NOTE: If this is changed, the value of id_type 00075 * MUST be changed accordingly. 00076 */ 00077 typedef EntityHandle wid_t; // change the name, 00078 // to avoid conflicts to /usr/include/x86_64-linux-gnu/bits/types.h : id_t , which is unsigned 00079 // int 00080 00081 /** HDF5 type corresponding to type of wid_t */ 00082 static const hid_t id_type; 00083 00084 struct ExportType 00085 { 00086 //! The type of the entities in the range 00087 EntityType type; 00088 //! The number of nodes per entity - not used for nodes and sets 00089 int num_nodes; 00090 00091 virtual ~ExportType() {} 00092 00093 bool operator==( const ExportType& t ) const 00094 { 00095 return t.type == type && t.num_nodes == num_nodes; 00096 } 00097 bool operator!=( const ExportType& t ) const 00098 { 00099 return t.type != type || t.num_nodes != num_nodes; 00100 } 00101 bool operator<( const ExportType& t ) const 00102 { 00103 return type < t.type || ( type == t.type && num_nodes < t.num_nodes ); 00104 } 00105 }; 00106 00107 //! Range of entities, grouped by type, to export 00108 struct ExportSet : public ExportType 00109 { 00110 //! The range of entities. 00111 Range range; 00112 //! The first Id allocated by the mhdf library. Entities in range have sequential IDs. 00113 wid_t first_id; 00114 //! The offset at which to begin writing this processor's data. 00115 //! Always zero except for parallel IO. 00116 long offset; 00117 //! Offset for adjacency data. Always zero except for parallel IO 00118 long adj_offset; 00119 //! If doing parallel IO, largest number of entities to write 00120 //! for any processor (needed to do collective IO). Zero if unused. 00121 long max_num_ents, max_num_adjs; 00122 //! The total number of entities that will be written to the file 00123 //! for this group. For serial IO, this should always be range.size(). 00124 //! For parallel IO, it will be the sum of range size over all processors. 00125 //! For parallel IO, this value is undefined except for on the root 00126 //! processor. 00127 long total_num_ents; 00128 00129 bool operator<( const ExportType& other ) const 00130 { 00131 return type < other.type || ( type == other.type && num_nodes < other.num_nodes ); 00132 } 00133 00134 bool operator<( std::pair< int, int > other ) const 00135 { 00136 return type < other.first || ( type == other.first && num_nodes < other.second ); 00137 } 00138 00139 bool operator==( const ExportType& other ) const 00140 { 00141 return ( type == other.type && num_nodes == other.num_nodes ); 00142 } 00143 00144 bool operator==( std::pair< int, int > other ) const 00145 { 00146 return ( type == other.first && num_nodes == other.second ); 00147 } 00148 00149 const char* name() const; 00150 }; 00151 00152 //! Tag to write to file. 00153 struct TagDesc 00154 { 00155 //! The tag handle 00156 Tag tag_id; 00157 //! The offset at which to begin writting this processor's data. 00158 //! Always zero except for parallel IO. 00159 wid_t sparse_offset; 00160 //! For variable-length tags, a second offset for the tag data table, 00161 //! separate from the offset used for the ID and Index tables. 00162 //! Always zero except for parallel IO. 00163 wid_t var_data_offset; 00164 //! Write sparse tag data (for serial, is always equal to !range.empty()) 00165 bool write_sparse; 00166 //! If doing parallel IO, largest number, over all processes, of entities 00167 //! for which to write tag data. Zero if unused. 00168 unsigned long max_num_ents; 00169 //! For variable-length tags during parallel IO: the largest number 00170 //! of tag values to be written on by any process, used to calculate 00171 //! the total number of collective writes that all processes must do. 00172 //! Zero for fixed-length tags or if not doing parallel IO. 00173 unsigned long max_num_vals; 00174 00175 //! List of entity groups for which to write tag data in 00176 //! dense format 00177 std::vector< ExportType > dense_list; 00178 00179 bool have_dense( const ExportType& type ) const 00180 { 00181 return std::find( dense_list.begin(), dense_list.end(), type ) != dense_list.end(); 00182 } 00183 00184 bool operator<( const TagDesc& ) const; 00185 }; 00186 00187 /** Create attributes holding the HDF5 type handle for the 00188 * type of a bunch of the default tags. 00189 */ 00190 // static ErrorCode register_known_tag_types( Interface* ); 00191 00192 //! Store old HDF5 error handling function 00193 struct HDF5ErrorHandler 00194 { 00195 HDF5_Error_Func_Type func; 00196 void* data; 00197 }; 00198 00199 mhdf_FileHandle file_ptr() 00200 { 00201 return filePtr; 00202 } 00203 00204 WriteUtilIface* write_util() 00205 { 00206 return writeUtil; 00207 } 00208 00209 protected: 00210 //! Store old HDF5 error handling function 00211 HDF5ErrorHandler errorHandler; 00212 00213 /** Function to create the file. Virtual to allow override 00214 * for parallel version. 00215 */ 00216 virtual ErrorCode parallel_create_file( const char* filename, 00217 bool overwrite, 00218 const std::vector< std::string >& qa_records, 00219 const FileOptions& opts, 00220 const Tag* tag_list, 00221 int num_tags, 00222 int dimension = 3, 00223 double* times = 0 ); 00224 virtual ErrorCode write_finished(); 00225 virtual void debug_barrier_line( int lineno ); 00226 00227 //! Gather tags 00228 ErrorCode gather_tags( const Tag* user_tag_list, int user_tag_list_length ); 00229 00230 /** Check if tag values for a given ExportSet should be written in dense format 00231 * 00232 *\param ents ExportSet to consider 00233 *\param all_tagged Range containing all the entities in ents.range for 00234 * which an explicit tag value is stored. Range may 00235 * also contain entities not in ents.range, but may 00236 * not contain entities in ents.range for which no tag 00237 * value is stored. 00238 *\param prefer_dense If true, will return true if at least 2/3 of the 00239 * entities are tagged. This should not be passed as 00240 * true if the tag does not have a default value, as 00241 * tag values must be stored for all entities in the 00242 * ExportSet for dense-formatted data. 00243 */ 00244 bool check_dense_format_tag( const ExportSet& ents, const Range& all_tagged, bool prefer_dense ); 00245 00246 /** Helper function for create-file 00247 * 00248 * Calculate the sum of the number of non-set adjacencies 00249 * of all entities in the passed range. 00250 */ 00251 ErrorCode count_adjacencies( const Range& elements, wid_t& result ); 00252 00253 public: // make these public so helper classes in WriteHDF5Parallel can use them 00254 /** Helper function for create-file 00255 * 00256 * Create zero-ed tables where element connectivity and 00257 * adjacency data will be stored. 00258 */ 00259 ErrorCode create_elem_table( const ExportSet& block, long num_ents, long& first_id_out ); 00260 00261 /** Helper function for create-file 00262 * 00263 * Create zero-ed table where set descriptions will be written 00264 */ 00265 ErrorCode create_set_meta( long num_sets, long& first_id_out ); 00266 00267 protected: 00268 /** Helper function for create-file 00269 * 00270 * Calculate total length of set contents and child tables. 00271 */ 00272 ErrorCode count_set_size( const Range& sets, 00273 long& contents_length_out, 00274 long& children_length_out, 00275 long& parents_length_out ); 00276 00277 //! Get information about a meshset 00278 ErrorCode get_set_info( EntityHandle set, 00279 long& num_entities, 00280 long& num_children, 00281 long& num_parents, 00282 unsigned long& flags ); 00283 00284 /** Helper function for create-file 00285 * 00286 * Create zero-ed tables where set data will be written. 00287 */ 00288 ErrorCode create_set_tables( long contents_length, long children_length, long parents_length ); 00289 00290 //! Write exodus-type QA info 00291 ErrorCode write_qa( const std::vector< std::string >& list ); 00292 00293 //!\brief Get tagged entities for which to write tag values 00294 ErrorCode get_num_sparse_tagged_entities( const TagDesc& tag, size_t& count ); 00295 //!\brief Get tagged entities for which to write tag values 00296 ErrorCode get_sparse_tagged_entities( const TagDesc& tag, Range& range ); 00297 //!\brief Get entities that will be written to file 00298 void get_write_entities( Range& range ); 00299 00300 //! The size of the data buffer (<code>dataBuffer</code>). 00301 size_t bufferSize; 00302 //! A memory buffer to use for all I/O operations. 00303 char* dataBuffer; 00304 00305 //! Interface pointer passed to constructor 00306 Interface* iFace; 00307 //! Cached pointer to writeUtil interface. 00308 WriteUtilIface* writeUtil; 00309 00310 //! The file handle from the mhdf library 00311 mhdf_FileHandle filePtr; 00312 00313 //! Map from entity handles to file IDs 00314 RangeMap< EntityHandle, wid_t > idMap; 00315 00316 //! The list elements to export. 00317 std::list< ExportSet > exportList; 00318 //! The list of nodes to export 00319 ExportSet nodeSet; 00320 //! The list of sets to export 00321 ExportSet setSet; 00322 00323 const ExportSet* find( const ExportType& type ) const 00324 { 00325 if( type.type == MBVERTEX ) 00326 return &nodeSet; 00327 else if( type.type == MBENTITYSET ) 00328 return &setSet; 00329 else 00330 { 00331 std::list< ExportSet >::const_iterator it; 00332 it = std::find( exportList.begin(), exportList.end(), type ); 00333 return it == exportList.end() ? 0 : &*it; 00334 } 00335 } 00336 00337 //! Offset into set contents table (zero except for parallel) 00338 unsigned long setContentsOffset; 00339 //! Offset into set children table (zero except for parallel) 00340 unsigned long setChildrenOffset, setParentsOffset; 00341 //! The largest number of values to write 00342 //! for any processor (needed to do collective IO). 00343 long maxNumSetContents, maxNumSetChildren, maxNumSetParents; 00344 //! Flags idicating if set data should be written. 00345 //! For the normal (non-parallel) case, these values 00346 //! will depend only on whether or not there is any 00347 //! data to be written. For parallel-meshes, opening 00348 //! the data table is collective so the values must 00349 //! depend on whether or not any processor has meshsets 00350 //! to be written. 00351 bool writeSets, writeSetContents, writeSetChildren, writeSetParents; 00352 00353 //! Struct describing a set for which the contained and linked entity 00354 //! lists are something other than the local values. Used to store 00355 //! data for shared sets owned by this process when writing in parallel. 00356 struct SpecialSetData 00357 { 00358 EntityHandle setHandle; 00359 unsigned setFlags; 00360 std::vector< wid_t > contentIds; 00361 std::vector< wid_t > childIds; 00362 std::vector< wid_t > parentIds; 00363 }; 00364 struct SpecSetLess 00365 { 00366 bool operator()( const SpecialSetData& a, SpecialSetData b ) const 00367 { 00368 return a.setHandle < b.setHandle; 00369 } 00370 }; 00371 00372 //! Array of special/shared sets, in order of handle value. 00373 std::vector< SpecialSetData > specialSets; 00374 const SpecialSetData* find_set_data( EntityHandle h ) const 00375 { 00376 return const_cast< WriteHDF5* >( this )->find_set_data( h ); 00377 } 00378 SpecialSetData* find_set_data( EntityHandle h ); 00379 00380 //! The list of tags to export 00381 std::list< TagDesc > tagList; 00382 00383 //! True if doing parallel write 00384 bool parallelWrite; 00385 //! True if using collective IO calls for parallel write 00386 bool collectiveIO; 00387 //! True if writing dense-formatted tag data 00388 bool writeTagDense; 00389 00390 //! Property set to pass to H5Dwrite calls. 00391 //! For serial, should be H5P_DEFAULTS. 00392 //! For parallel, may request collective IO. 00393 hid_t writeProp; 00394 00395 //! Utility to log debug output 00396 DebugOutput dbgOut; 00397 00398 static MPEState topState; 00399 static MPEState subState; 00400 00401 //! Look for overlapping and/or missing writes 00402 bool debugTrack; 00403 00404 void print_id_map() const; 00405 void print_id_map( std::ostream& str, const char* prefix = "" ) const; 00406 00407 /** Helper function for create-file 00408 * 00409 * Write tag meta-info and create zero-ed table where 00410 * tag values will be written. 00411 *\param num_entities Number of entities for which to write tag data. 00412 *\param var_len_total For variable-length tags, the total number of values 00413 * in the data table. 00414 */ 00415 ErrorCode create_tag( const TagDesc& tag_data, unsigned long num_entities, unsigned long var_len_total ); 00416 00417 /**\brief add entities to idMap */ 00418 ErrorCode assign_ids( const Range& entities, wid_t first_id ); 00419 00420 /** Get possibly compacted list of IDs for passed entities 00421 * 00422 * For the passed range of entities, determine if IDs 00423 * can be compacted and write IDs to passed list. 00424 * 00425 * If the IDs are not compacted, the output list will contain 00426 * a simple ordered list of IDs. 00427 * 00428 * If IDs are compacted, the output list will contain 00429 * {start,count} pairs. 00430 * 00431 * If the ID list is compacted, ranged_list will be 'true'. 00432 * Otherwise it will be 'false'. 00433 */ 00434 ErrorCode range_to_blocked_list( const Range& input_range, 00435 std::vector< wid_t >& output_id_list, 00436 bool& ranged_list ); 00437 00438 /** Get possibly compacted list of IDs for passed entities 00439 * 00440 * For the passed range of entities, determine if IDs 00441 * can be compacted and write IDs to passed list. 00442 * 00443 * If the IDs are not compacted, the output list will contain 00444 * a simple ordered list of IDs. 00445 * 00446 * If IDs are compacted, the output list will contain 00447 * {start,count} pairs. 00448 * 00449 * If the ID list is compacted, ranged_list will be 'true'. 00450 * Otherwise it will be 'false'. 00451 */ 00452 ErrorCode range_to_blocked_list( const EntityHandle* input_ranges, 00453 size_t num_input_ranges, 00454 std::vector< wid_t >& output_id_list, 00455 bool& ranged_list ); 00456 00457 ErrorCode range_to_id_list( const Range& input_range, wid_t* array ); 00458 //! Get IDs for entities 00459 ErrorCode vector_to_id_list( const std::vector< EntityHandle >& input, 00460 std::vector< wid_t >& output, 00461 bool remove_non_written = false ); 00462 //! Get IDs for entities 00463 ErrorCode vector_to_id_list( const EntityHandle* input, wid_t* output, size_t num_entities ); 00464 //! Get IDs for entities 00465 ErrorCode vector_to_id_list( const EntityHandle* input, 00466 size_t input_len, 00467 wid_t* output, 00468 size_t& output_len, 00469 bool remove_non_written ); 00470 00471 /** When writing tags containing EntityHandles to file, need to convert tag 00472 * data from EntityHandles to file IDs. This function does that. 00473 * 00474 * If the handle is not valid or does not correspond to an entity that will 00475 * be written to the file, the file ID is set to zero. 00476 *\param data The data buffer. As input, an array of EntityHandles. As 00477 * output an array of file IDS, where the size of each integral 00478 * file ID is the same as the size of EntityHandle. 00479 *\param count The number of handles in the buffer. 00480 *\return true if at least one of the handles is valid and will be written to 00481 * the file or at least one of the handles is NULL (zero). false 00482 * otherwise 00483 */ 00484 bool convert_handle_tag( EntityHandle* data, size_t count ) const; 00485 bool convert_handle_tag( const EntityHandle* source, EntityHandle* dest, size_t count ) const; 00486 00487 /** Get IDs of adjacent entities. 00488 * 00489 * For all entities adjacent to the passed entity, if the 00490 * adjacent entity is to be exported (ID is not zero), append 00491 * the ID to the passed list. 00492 */ 00493 ErrorCode get_adjacencies( EntityHandle entity, std::vector< wid_t >& adj ); 00494 00495 //! get sum of lengths of tag values (as number of type) for 00496 //! variable length tag data. 00497 ErrorCode get_tag_data_length( const TagDesc& tag_info, const Range& range, unsigned long& result ); 00498 00499 private: 00500 //! Do the actual work of write_file. Separated from write_file 00501 //! for easier resource cleanup. 00502 ErrorCode write_file_impl( const char* filename, 00503 const bool overwrite, 00504 const FileOptions& opts, 00505 const EntityHandle* export_sets, 00506 const int export_set_count, 00507 const std::vector< std::string >& qa_records, 00508 const Tag* tag_list, 00509 int num_tags, 00510 int user_dimension = 3 ); 00511 00512 ErrorCode init(); 00513 00514 ErrorCode serial_create_file( const char* filename, 00515 bool overwrite, 00516 const std::vector< std::string >& qa_records, 00517 const Tag* tag_list, 00518 int num_tags, 00519 int dimension = 3 ); 00520 00521 /** Get all mesh to export from given list of sets. 00522 * 00523 * Populate exportSets, nodeSet and setSet with lists of 00524 * entities to write. 00525 * 00526 * \param export_sets The list of meshsets to export 00527 */ 00528 ErrorCode gather_mesh_info( const std::vector< EntityHandle >& export_sets ); 00529 00530 //! Same as gather_mesh_info, except for entire mesh 00531 ErrorCode gather_all_mesh(); 00532 00533 //! Initialize internal data structures from gathered mesh 00534 ErrorCode initialize_mesh( const Range entities_by_dim[5] ); 00535 00536 /** Write out the nodes. 00537 * 00538 * Note: Assigns IDs to nodes. 00539 */ 00540 ErrorCode write_nodes(); 00541 00542 /** Write out element connectivity. 00543 * 00544 * Write connectivity for passed set of elements. 00545 * 00546 * Note: Assigns element IDs. 00547 * Note: Must do write_nodes first so node IDs get assigned. 00548 */ 00549 ErrorCode write_elems( ExportSet& elemset ); 00550 00551 /** Write out meshsets 00552 * 00553 * Write passed set of meshsets, including parent/child relations. 00554 * 00555 * Note: Must have written nodes and element connectivity 00556 * so entities have assigned IDs. 00557 */ 00558 ErrorCode write_sets( double* times ); 00559 00560 /** Write set contents/parents/children lists 00561 * 00562 *\param which_data Which set data to write (contents, parents, or children) 00563 *\param handle HDF5 handle for data set in which to write data 00564 *\param track Debugging tool 00565 *\param ranged Will be populated with handles of sets for which 00566 * contents were written in a range-compacted format. 00567 * (mhdf_SET_RANGE_BIT). Should be null for parents/children. 00568 *\param null_stripped Will be populated with handles of sets for which 00569 * invalid or null handles were stripped from the contents 00570 * list. This is only done for unordered sets. This argument 00571 * should be null if writing parents/children because those 00572 * lists are always ordered. 00573 *\param set_sizes Will be populated with the length of the data written 00574 * for those sets for which the handles were added to 00575 * either \c ranged or \c null_stripped. Values are 00576 * in handle order. 00577 */ 00578 ErrorCode write_set_data( const WriteUtilIface::EntityListType which_data, 00579 const hid_t handle, 00580 IODebugTrack& track, 00581 Range* ranged = 0, 00582 Range* null_stripped = 0, 00583 std::vector< long >* set_sizes = 0 ); 00584 00585 /** Write adjacency info for passed set of elements 00586 * 00587 * Note: Must have written element connectivity so elements 00588 * have IDs assigned. 00589 */ 00590 ErrorCode write_adjacencies( const ExportSet& export_set ); 00591 00592 /** Write tag information and data. 00593 * 00594 * Note: Must have already written nodes, elem connectivity and 00595 * sets so that entities have IDs assigned. 00596 */ 00597 00598 //! Write tag for all entities. 00599 ErrorCode write_tag( const TagDesc& tag_data, double* times ); 00600 00601 //! Get element connectivity 00602 ErrorCode get_connectivity( Range::const_iterator begin, 00603 Range::const_iterator end, 00604 int nodes_per_element, 00605 wid_t* id_data_out ); 00606 00607 //! Get size data for tag 00608 //!\param tag MOAB tag ID 00609 //!\param moab_type Output: DataType for tag 00610 //!\param num_bytes Output: MOAB tag size (bits for bit tags). 00611 //! MB_VARIABLE_LENGTH for variable-length tags. 00612 //!\param elem_size Output: Size of of the base data type of the 00613 //! tag data (e.g. sizeof(double) if 00614 //! moab_type == MB_TYPE_DOUBLE). 00615 //! One for bit and opaque tags. 00616 //!\param array_size Output: The number of valeus of size elem_size 00617 //! for each tag. Always 1 for opaque data. 00618 //! Nubmer of bits for bit tags. 00619 //!\param file_type Output: mhdf type enumeration 00620 //!\param hdf_type Output: Handle to HDF5 type object. Caller is 00621 //! responsible for releasing this object 00622 //! (calling H5Tclose). 00623 ErrorCode get_tag_size( Tag tag, 00624 DataType& moab_type, 00625 int& num_bytes, 00626 int& elem_size, 00627 int& file_size, 00628 mhdf_TagDataType& file_type, 00629 hid_t& hdf_type ); 00630 00631 //! Write ID table for sparse tag 00632 ErrorCode write_sparse_ids( const TagDesc& tag_data, 00633 const Range& range, 00634 hid_t table_handle, 00635 size_t table_size, 00636 const char* name = 0 ); 00637 00638 //! Write fixed-length tag data in sparse format 00639 ErrorCode write_sparse_tag( const TagDesc& tag_data, 00640 const std::string& tag_name, 00641 DataType tag_data_type, 00642 hid_t hdf5_data_type, 00643 int hdf5_type_size ); 00644 00645 //! Write end index data_set for a variable-length tag 00646 ErrorCode write_var_len_indices( const TagDesc& tag_data, 00647 const Range& range, 00648 hid_t idx_table, 00649 size_t table_size, 00650 int type_size, 00651 const char* name = 0 ); 00652 00653 //! Write tag value data_set for a variable-length tag 00654 ErrorCode write_var_len_data( const TagDesc& tag_data, 00655 const Range& range, 00656 hid_t table, 00657 size_t table_size, 00658 bool handle_tag, 00659 hid_t hdf_type, 00660 int type_size, 00661 const char* name = 0 ); 00662 00663 //! Write varialbe-length tag data 00664 ErrorCode write_var_len_tag( const TagDesc& tag_info, 00665 const std::string& tag_name, 00666 DataType tag_data_type, 00667 hid_t hdf5_type, 00668 int hdf5_type_size ); 00669 00670 //! Write dense-formatted tag data 00671 ErrorCode write_dense_tag( const TagDesc& tag_data, 00672 const ExportSet& elem_data, 00673 const std::string& tag_name, 00674 DataType tag_data_type, 00675 hid_t hdf5_data_type, 00676 int hdf5_type_size ); 00677 00678 //! Write data for fixed-size tag 00679 ErrorCode write_tag_values( Tag tag_id, 00680 hid_t data_table, 00681 unsigned long data_offset, 00682 const Range& range, 00683 DataType tag_data_type, 00684 hid_t hdf5_data_type, 00685 int hdf5_type_size, 00686 unsigned long max_num_ents, 00687 IODebugTrack& debug_track ); 00688 00689 protected: 00690 enum TimingValues 00691 { 00692 TOTAL_TIME = 0, 00693 GATHER_TIME, 00694 CREATE_TIME, 00695 CREATE_NODE_TIME, 00696 NEGOTIATE_TYPES_TIME, 00697 CREATE_ELEM_TIME, 00698 FILEID_EXCHANGE_TIME, 00699 CREATE_ADJ_TIME, 00700 CREATE_SET_TIME, 00701 SHARED_SET_IDS, 00702 SHARED_SET_CONTENTS, 00703 SET_OFFSET_TIME, 00704 CREATE_TAG_TIME, 00705 COORD_TIME, 00706 CONN_TIME, 00707 SET_TIME, 00708 SET_META, 00709 SET_CONTENT, 00710 SET_PARENT, 00711 SET_CHILD, 00712 ADJ_TIME, 00713 TAG_TIME, 00714 DENSE_TAG_TIME, 00715 SPARSE_TAG_TIME, 00716 VARLEN_TAG_TIME, 00717 NUM_TIMES 00718 }; 00719 00720 virtual void print_times( const double times[NUM_TIMES] ) const; 00721 }; 00722 00723 } // namespace moab 00724 00725 #endif
