MOAB: Mesh Oriented datABase
(version 5.4.1)
#include <ReadRTT.hpp>
Inheritance diagram for moab::ReadRTT:
Collaboration diagram for moab::ReadRTT:Classes | |
| struct | boundary |
| struct | cell |
| struct | facet |
| struct | headerData |
| struct | node |
| struct | side |
| struct | tet |
Public Member Functions | |
| ErrorCode | load_file (const char *file_name, const EntityHandle *file_set, const FileOptions &opts, const SubsetList *subset_list=0, const Tag *file_id_tag=0) |
| Load mesh from a file. | |
| ReadRTT (Interface *impl=NULL) | |
| virtual | ~ReadRTT () |
| ErrorCode | read_tag_values (const char *file_name, const char *tag_name, const FileOptions &opts, std::vector< int > &tag_values_out, const SubsetList *subset_list=0) |
| Read tag values from a file. | |
Static Public Member Functions | |
| static ReaderIface * | factory (Interface *) |
Private Member Functions | |
| ErrorCode | generate_topology (std::vector< side > side_data, std::vector< cell > cell_data, std::map< int, EntityHandle > &surface_map) |
| void | generate_parent_child_links (int num_ents[4], std::vector< EntityHandle > entity_map[4], std::vector< side > side_data, std::vector< cell > cell_data) |
| void | set_surface_senses (int num_ents[4], std::vector< EntityHandle > entity_map[4], std::vector< side > side_data, std::vector< cell > cell_data) |
| ErrorCode | setup_group_data (std::vector< EntityHandle > entity_map[4]) |
| EntityHandle | create_group (std::string group_name, int id) |
| ErrorCode | build_moab (std::vector< node > node_data, std::vector< facet > facet_data, std::vector< tet > tet_data, std::map< int, EntityHandle > surface_map) |
| ErrorCode | read_header (const char *filename) |
| ErrorCode | read_sides (const char *filename, std::vector< side > &side_data) |
| ErrorCode | read_cells (const char *filename, std::vector< cell > &cell_data) |
| ErrorCode | read_nodes (const char *filename, std::vector< node > &node_data) |
| ErrorCode | read_facets (const char *filename, std::vector< facet > &facet_data) |
| ErrorCode | read_tets (const char *filename, std::vector< tet > &tet_data) |
| ErrorCode | get_header_data (std::ifstream &input_file) |
| cell | get_cell_data (std::string celldata) |
| side | get_side_data (std::string sidedata) |
| node | get_node_data (std::string nodedata) |
| facet | get_facet_data (std::string facetdata) |
| tet | get_tet_data (std::string tetdata) |
| std::vector< std::string > | split_string (std::string string_to_split, char split_char) |
| boundary | split_name (std::string atilla_cellname) |
| int | count_sides (std::vector< side > side_data, std::vector< int > &surface_numbers) |
Private Attributes | |
| headerData | header_data |
| ReadUtilIface * | readMeshIface |
| Interface * | MBI |
| GeomTopoTool * | myGeomTool |
| Tag | geom_tag |
| Tag | id_tag |
| Tag | name_tag |
| Tag | category_tag |
| Tag | faceting_tol_tag |
Definition at line 112 of file ReadRTT.hpp.
| ReadRTT::ReadRTT | ( | Interface * | impl = NULL | ) |
Definition at line 56 of file ReadRTT.cpp.
References category_tag, CATEGORY_TAG_NAME, CATEGORY_TAG_SIZE, ErrorCode, faceting_tol_tag, GEOM_DIMENSION_TAG_NAME, geom_tag, moab::Interface::globalId_tag(), id_tag, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_DOUBLE, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, MBI, myGeomTool, name_tag, NAME_TAG_NAME, NAME_TAG_SIZE, moab::Interface::query_interface(), readMeshIface, and moab::Interface::tag_get_handle().
Referenced by factory().
: MBI( impl ), geom_tag( 0 ), id_tag( 0 ), name_tag( 0 ), category_tag( 0 ), faceting_tol_tag( 0 ) { assert( NULL != impl ); myGeomTool = new GeomTopoTool( impl ); MBI->query_interface( readMeshIface ); assert( NULL != readMeshIface ); // this section copied from ReadCGM initalisation int negone = -1; double zero = 0.; ErrorCode rval; rval = MBI->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, geom_tag, MB_TAG_SPARSE | MB_TAG_CREAT, &negone ); assert( !rval ); id_tag = MBI->globalId_tag(); rval = MBI->tag_get_handle( NAME_TAG_NAME, NAME_TAG_SIZE, MB_TYPE_OPAQUE, name_tag, MB_TAG_SPARSE | MB_TAG_CREAT ); assert( !rval ); rval = MBI->tag_get_handle( CATEGORY_TAG_NAME, CATEGORY_TAG_SIZE, MB_TYPE_OPAQUE, category_tag, MB_TAG_SPARSE | MB_TAG_CREAT ); assert( !rval ); rval = MBI->tag_get_handle( "FACETING_TOL", 1, MB_TYPE_DOUBLE, faceting_tol_tag, MB_TAG_SPARSE | MB_TAG_CREAT, &zero ); assert( !rval ); #ifdef NDEBUG if( !rval ) { }; // Line to avoid compiler warning about variable set but not used #endif }
| ReadRTT::~ReadRTT | ( | ) | [virtual] |
Definition at line 88 of file ReadRTT.cpp.
References MBI, myGeomTool, readMeshIface, and moab::Interface::release_interface().
if( readMeshIface )
MBI->release_interface( readMeshIface );
readMeshIface = 0;
delete myGeomTool;
| ErrorCode ReadRTT::build_moab | ( | std::vector< node > | node_data, |
| std::vector< facet > | facet_data, | ||
| std::vector< tet > | tet_data, | ||
| std::map< int, EntityHandle > | surface_map | ||
| ) | [private] |
Builds the full MOAB representation of the data, making vertices from coordinates, triangles from vertices and tets from the same vertices. Tags appropriate to each dataset collection are applied, triangles are tagged with the surface id and side id they belong to, as well as tagging the surface with the same data. Tets are similarly tagged only with the Material number
| node_data | the node data |
| facet_data,the | triangles in the problem |
| tet_data,the | tets in the problem |
| surface_map,the | map of surface meshset and id numbers |
Definition at line 248 of file ReadRTT.cpp.
References moab::Interface::add_entities(), moab::ReadRTT::facet::connectivity, moab::ReadRTT::tet::connectivity, moab::Interface::create_element(), moab::Interface::create_meshset(), moab::Interface::create_vertex(), ErrorCode, moab::Range::insert(), moab::ReadRTT::tet::material_number, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBI, MBTET, MBTRI, MESHSET_SET, moab::ReadRTT::facet::side_id, moab::ReadRTT::facet::surface_number, moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), moab::ReadRTT::node::x, moab::ReadRTT::node::y, and moab::ReadRTT::node::z.
Referenced by load_file().
ErrorCode rval; // reusable return value
EntityHandle file_set; // the file handle
// create the file set
rval = MBI->create_meshset( MESHSET_SET, file_set );
if( MB_SUCCESS != rval ) return rval;
// create the vertices
EntityHandle handle;
std::vector< node >::iterator it; // iterate over the nodes
Range mb_coords; // range of coordinates
for( it = node_data.begin(); it != node_data.end(); ++it )
node tmp = *it;
double coords[3] = { tmp.x, tmp.y, tmp.z };
rval = MBI->create_vertex( coords, handle );
mb_coords.insert( handle ); // inesert handle into the coordinate range
// add verts to set
rval = MBI->add_entities( file_set, mb_coords );
// create sense tag
Tag side_id_tag, surface_number_tag;
// int zero = 0;
rval = MBI->tag_get_handle( "SIDEID_TAG", 1, MB_TYPE_INTEGER, side_id_tag, MB_TAG_SPARSE | MB_TAG_CREAT );
rval =
MBI->tag_get_handle( "SURFACE_NUMBER", 1, MB_TYPE_INTEGER, surface_number_tag, MB_TAG_SPARSE | MB_TAG_CREAT );
// create the facets
EntityHandle triangle;
std::vector< facet >::iterator it_f;
// range of triangles
Range mb_tris;
// loop over the facet data
for( it_f = facet_data.begin(); it_f != facet_data.end(); ++it_f )
facet tmp = *it_f;
// get the nodes for the triangle
EntityHandle tri_nodes[3] = { mb_coords[tmp.connectivity[0] - 1], mb_coords[tmp.connectivity[1] - 1],
mb_coords[tmp.connectivity[2] - 1] };
// create a triangle element
rval = MBI->create_element( MBTRI, tri_nodes, 3, triangle );
// tag in side id on the triangle
rval = MBI->tag_set_data( side_id_tag, &triangle, 1, &tmp.side_id );
// tag the surface number on the triangle
rval = MBI->tag_set_data( surface_number_tag, &triangle, 1, &tmp.surface_number );
// insert vertices and triangles into the appropriate surface meshset
EntityHandle meshset_handle = surface_map[tmp.surface_number];
// also set surface tag
rval = MBI->tag_set_data( side_id_tag, &meshset_handle, 1, &tmp.side_id );
rval = MBI->tag_set_data( surface_number_tag, &meshset_handle, 1, &tmp.surface_number );
// add vertices to the mesh
rval = MBI->add_entities( meshset_handle, &( *tri_nodes ), 3 );
// add triangles to the meshset
rval = MBI->add_entities( meshset_handle, &triangle, 1 );
// ineter triangles into large run
mb_tris.insert( triangle );
// add tris to set to fileset
rval = MBI->add_entities( file_set, mb_tris );
// create material number tag
Tag mat_num_tag;
// int zero = 0;
rval = MBI->tag_get_handle( "MATERIAL_NUMBER", 1, MB_TYPE_INTEGER, mat_num_tag, MB_TAG_SPARSE | MB_TAG_CREAT );
// create the tets
EntityHandle tetra; // handle for a specific tet
std::vector< tet >::iterator it_t;
Range mb_tets;
// loop over all tets
for( it_t = tet_data.begin(); it_t != tet_data.end(); ++it_t )
tet tmp = *it_t;
// get the handles for the tet
EntityHandle tet_nodes[4] = { mb_coords[tmp.connectivity[0] - 1], mb_coords[tmp.connectivity[1] - 1],
mb_coords[tmp.connectivity[2] - 1], mb_coords[tmp.connectivity[3] - 1] };
// create the tet
rval = MBI->create_element( MBTET, tet_nodes, 4, tetra );
int mat_number = tmp.material_number;
// tag the tet with the material number
rval = MBI->tag_set_data( mat_num_tag, &tetra, 1, &mat_number );
// set the tag data
mb_tets.insert( tetra );
// add tris to set
rval = MBI->add_entities( file_set, mb_tets );
return MB_SUCCESS;
| int moab::ReadRTT::count_sides | ( | std::vector< side > | side_data, |
| std::vector< int > & | surface_numbers | ||
| ) | [private] |
Count the number of unique surface numbers in the dataset, also get list of surface numbers
| side_data,collection | of all the side data in the mesh |
| surface_numbers,collection | of surface numbers |
returns the number of surface numbers
| EntityHandle ReadRTT::create_group | ( | std::string | group_name, |
| int | id | ||
| ) | [private] |
create a group of a given name, mustkeep track of id
| group_name,name | of the group |
| id,integer | id number |
returns the entity handle of the group
Definition at line 926 of file ReadRTT.cpp.
References category_tag, CATEGORY_TAG_SIZE, moab::Interface::create_meshset(), ErrorCode, id_tag, MB_SUCCESS, MBI, MESHSET_SET, name_tag, and moab::Interface::tag_set_data().
Referenced by setup_group_data().
ErrorCode rval;
// category tags
const char geom_categories[][CATEGORY_TAG_SIZE] = { "Vertex\0", "Curve\0", "Surface\0", "Volume\0", "Group\0" };
rval = MBI->create_meshset( MESHSET_SET, handle );
rval = MBI->tag_set_data( name_tag, &handle, 1, group_name.c_str() );
if( MB_SUCCESS != rval ) return MB_FAILURE;
rval = MBI->tag_set_data( id_tag, &handle, 1, &id );
rval = MBI->tag_set_data( category_tag, &handle, 1, &geom_categories[4] );
return handle;
| ReaderIface * ReadRTT::factory | ( | Interface * | iface | ) | [static] |
Definition at line 50 of file ReadRTT.cpp.
References ReadRTT().
Referenced by moab::ReaderWriterSet::ReaderWriterSet().
| void ReadRTT::generate_parent_child_links | ( | int | num_ents[4], |
| std::vector< EntityHandle > | entity_map[4], | ||
| std::vector< side > | side_data, | ||
| std::vector< cell > | cell_data | ||
| ) | [private] |
Generate parent child links to create DAGMC like structure of surface meshsets being children of parent cell meshsets. By looping over the surfaces (1->N), look in the description of the cells that are shared by that surface, and then make the surface the child of the parent volume. The appropriate sense data will be set later
| num_ents[4],array | containing the number of surfaces, cells, groups etc |
| entity_map[4],vector | of maps containing data by dimension |
| side_data,vector | of all the side data in the problem |
| cell_data,vector | of the cell data in the problem |
Definition at line 822 of file ReadRTT.cpp.
References moab::Interface::add_parent_child(), ErrorCode, MB_SUCCESS, and MBI.
Referenced by generate_topology().
ErrorCode rval; // return value
// loop over the number of surfaces
for( int i = 0; i < num_ents[2]; i++ )
// get the surface handle
EntityHandle surf_handle = entity_map[2][i];
// there are volumes that share this face
for( unsigned int shared = 0; shared <= 1; shared++ )
std::string parent_name = side_data[i].names[shared];
// find the @ sign
unsigned pos = parent_name.find( "@" );
parent_name = parent_name.substr( 0, pos );
// loop over tets looking for matching name
for( int j = 0; j < num_ents[3]; j++ )
// if match found
if( cell_data[j].name.compare( parent_name ) == 0 )
EntityHandle cell_handle = entity_map[3][j];
// parent
rval = MBI->add_parent_child( cell_handle, surf_handle );
if( rval != MB_SUCCESS )
std::cerr << "Failed to add parent child relationship" << std::endl;
return;
| ErrorCode ReadRTT::generate_topology | ( | std::vector< side > | side_data, |
| std::vector< cell > | cell_data, | ||
| std::map< int, EntityHandle > & | surface_map | ||
| ) | [private] |
generates the topology of the problem from the already read input data, loops over the 2 and 3 dimension macrodata that exist from the rtt file, sides = dagmc surfaces, cells = dagmc cells, creates a meshset for each surface and tags with the id number, and similarly makes a meshset for dagmc cells and tags with the id number. The surfaces are added to the s surface map, where the key is the surface ID number (1->N) and (cells and surfaces are added to an dimesional entity map stored in the class
| side_data,vector | of side data |
| cell_data,vector | of vector of cell data |
| surface_map,reference | to the surface map of data |
Definition at line 175 of file ReadRTT.cpp.
References category_tag, CATEGORY_TAG_SIZE, moab::Interface::create_meshset(), dim, ErrorCode, generate_parent_child_links(), geom_tag, id_tag, MB_SUCCESS, MBI, MESHSET_SET, set_surface_senses(), setup_group_data(), and moab::Interface::tag_set_data().
ErrorCode rval;
std::vector< EntityHandle > entmap[4];
int num_ents[4]; // number of entities in each dimension
std::vector< int > surface_numbers; // the surface numbers in the problem
// corresponds to number of cad like surfaces and cad like volumes
num_ents[2] = side_data.size();
num_ents[3] = cell_data.size();
// loop over surfaces & volumes
for( int dim = 2; dim <= 3; dim++ )
for( int i = 0; i != num_ents[dim]; i++ )
// create a meshset for each entity surface/volume
rval = MBI->create_meshset( dim == 1 ? MESHSET_ORDERED : MESHSET_SET, handle );
// if failure
if( rval != MB_SUCCESS ) return rval;
// collect the entity handles into an
entmap[dim].push_back( handle );
// set the dimension tag
rval = MBI->tag_set_data( geom_tag, &handle, 1, &dim );
// if fail
// if we are a surface
if( dim == 2 )
// tag the id onto the surface meshset
rval = MBI->tag_set_data( id_tag, &handle, 1, &side_data[i].id );
// inesert entity into the map
surface_map[side_data[i].id] = handle;
else
// otherwise we set the volume tag data, loop is only 2 & 3 dim
rval = MBI->tag_set_data( id_tag, &handle, 1, &cell_data[i].id );
// if fail
// set the category tag
rval = MBI->tag_set_data( category_tag, &handle, 1, &geom_categories[dim] );
// generate parent child links
// best to loop over the surfaces and assign them to volumes, we can then assign facets to
// to each surface
generate_parent_child_links( num_ents, entmap, side_data, cell_data );
// set the surface senses
set_surface_senses( num_ents, entmap, side_data, cell_data );
// set the group data
rval = setup_group_data( entmap );
return MB_SUCCESS;
| ReadRTT::cell ReadRTT::get_cell_data | ( | std::string | celldata | ) | [private] |
Reads a single atomic cell data string and populates a cell struct
| celldata,a | string of read data and |
Definition at line 642 of file ReadRTT.cpp.
References moab::ReadRTT::cell::id, MB_SET_ERR_RET_VAL, moab::ReadRTT::cell::name, and split_string().
Referenced by read_cells().
cell new_cell;
std::vector< std::string > tokens;
tokens = ReadRTT::split_string( celldata, ' ' );
// set the side id
if( tokens.size() != 2 )
MB_SET_ERR_RET_VAL( "Error, too many tokens found from cell_data", new_cell );
// create the new side
new_cell.id = std::atoi( tokens[0].c_str() );
new_cell.name = tokens[1];
return new_cell;
| ReadRTT::facet ReadRTT::get_facet_data | ( | std::string | facetdata | ) | [private] |
Reads a single atomic facet data string and populates a facet struct
| facetdata,a | string of facet data and |
Definition at line 684 of file ReadRTT.cpp.
References moab::ReadRTT::facet::connectivity, header_data, moab::ReadRTT::facet::id, MB_SET_ERR_RET_VAL, moab::ReadRTT::facet::side_id, split_string(), moab::ReadRTT::facet::surface_number, and moab::ReadRTT::headerData::version.
Referenced by read_facets().
facet new_facet;
tokens = ReadRTT::split_string( facetdata, ' ' );
// set the side id
if( tokens.size() != 7 )
MB_SET_ERR_RET_VAL( "Error, too many tokens found from get_facet_data", new_facet );
new_facet.id = std::atoi( tokens[0].c_str() );
// branch on the rtt version number
if( header_data.version == "v1.0.0" )
new_facet.connectivity[0] = std::atoi( tokens[1].c_str() );
new_facet.connectivity[1] = std::atoi( tokens[2].c_str() );
new_facet.connectivity[2] = std::atoi( tokens[3].c_str() );
new_facet.side_id = std::atoi( tokens[4].c_str() );
new_facet.surface_number = std::atoi( tokens[5].c_str() );
else if( header_data.version == "v1.0.1" )
new_facet.connectivity[0] = std::atoi( tokens[2].c_str() );
new_facet.connectivity[1] = std::atoi( tokens[3].c_str() );
new_facet.connectivity[2] = std::atoi( tokens[4].c_str() );
new_facet.side_id = std::atoi( tokens[5].c_str() );
new_facet.surface_number = std::atoi( tokens[6].c_str() );
else
MB_SET_ERR_RET_VAL( "Error, version number not understood", new_facet );
return new_facet;
| ErrorCode ReadRTT::get_header_data | ( | std::ifstream & | input_file | ) | [private] |
Reads the header data into a class member structure
| input_file,an | open filestream |
Definition at line 556 of file ReadRTT.cpp.
References moab::ReadRTT::headerData::date, header_data, MB_SUCCESS, split_string(), moab::ReadRTT::headerData::title, and moab::ReadRTT::headerData::version.
Referenced by read_header().
std::string line;
while( std::getline( input_file, line ) )
// tokenize the line
std::istringstream iss( line );
std::vector< std::string > split_string;
do
std::string sub_string;
iss >> sub_string;
split_string.push_back( sub_string );
} while( iss );
// if we find version
if( line.find( "version" ) != std::string::npos )
if( split_string[1].find( "v" ) != std::string::npos &&
split_string[0].find( "version" ) != std::string::npos )
header_data.version = split_string[1];
if( line.find( "title" ) != std::string::npos )
header_data.title = split_string[1];
if( line.find( "date" ) != std::string::npos )
header_data.date = split_string[1];
if( line.find( "end_header" ) != std::string::npos )
return MB_SUCCESS;
// otherwise we never found the end_header keyword
return MB_FAILURE;
| ReadRTT::node ReadRTT::get_node_data | ( | std::string | nodedata | ) | [private] |
Reads a single atomic node data string and populates a node struct
| sidedata,a | string of read data and |
Definition at line 663 of file ReadRTT.cpp.
References moab::ReadRTT::node::id, MB_SET_ERR_RET_VAL, split_string(), moab::ReadRTT::node::x, moab::ReadRTT::node::y, and moab::ReadRTT::node::z.
Referenced by read_nodes().
node new_node;
tokens = ReadRTT::split_string( nodedata, ' ' );
// set the side id
if( tokens.size() != 5 )
MB_SET_ERR_RET_VAL( "Error, too many tokens found from get_node_data", new_node );
new_node.id = std::atoi( tokens[0].c_str() );
new_node.x = std::atof( tokens[1].c_str() );
new_node.y = std::atof( tokens[2].c_str() );
new_node.z = std::atof( tokens[3].c_str() );
return new_node;
| ReadRTT::side ReadRTT::get_side_data | ( | std::string | sidedata | ) | [private] |
Reads a single atomic side data string and populates a side struct
Definition at line 603 of file ReadRTT.cpp.
References moab::ReadRTT::side::id, MB_SET_ERR_RET_VAL, moab::ReadRTT::boundary::name, moab::ReadRTT::side::names, moab::ReadRTT::boundary::sense, moab::ReadRTT::side::senses, split_name(), and split_string().
Referenced by read_sides().
side new_side;
tokens = ReadRTT::split_string( sidedata, ' ' );
// set the side id
MB_SET_ERR_RET_VAL( "Error, too many tokens found from side_data", new_side );
new_side.id = std::atoi( tokens[0].c_str() );
std::vector< std::string > cell_names = ReadRTT::split_string( tokens[1], '/' );
// get the boundary
boundary new_bnd = ReadRTT::split_name( cell_names[0] );
// set the surface sense and name
new_side.senses[0] = new_bnd.sense;
new_side.names[0] = new_bnd.name;
if( cell_names.size() > 1 )
boundary bnd = ReadRTT::split_name( cell_names[1] );
new_side.senses[1] = bnd.sense;
new_side.names[1] = bnd.name;
else
new_side.senses[1] = 0;
new_side.names[1] = "\0";
return new_side;
| ReadRTT::tet ReadRTT::get_tet_data | ( | std::string | tetdata | ) | [private] |
Reads a single atomic tet data string and populates a tet struct
| tetdata,a | string of tet data and |
Definition at line 725 of file ReadRTT.cpp.
References moab::ReadRTT::tet::connectivity, header_data, moab::ReadRTT::tet::id, moab::ReadRTT::tet::material_number, MB_SET_ERR_RET_VAL, split_string(), and moab::ReadRTT::headerData::version.
Referenced by read_tets().
tet new_tet;
tokens = ReadRTT::split_string( tetdata, ' ' );
// set the side id
MB_SET_ERR_RET_VAL( "Error, too many tokens found from get_tet_data", new_tet );
new_tet.id = std::atoi( tokens[0].c_str() );
// branch on the version number
new_tet.connectivity[0] = std::atoi( tokens[1].c_str() );
new_tet.connectivity[1] = std::atoi( tokens[2].c_str() );
new_tet.connectivity[2] = std::atoi( tokens[3].c_str() );
new_tet.connectivity[3] = std::atoi( tokens[4].c_str() );
new_tet.material_number = std::atoi( tokens[5].c_str() );
new_tet.connectivity[0] = std::atoi( tokens[2].c_str() );
new_tet.connectivity[1] = std::atoi( tokens[3].c_str() );
new_tet.connectivity[2] = std::atoi( tokens[4].c_str() );
new_tet.connectivity[3] = std::atoi( tokens[5].c_str() );
new_tet.material_number = std::atoi( tokens[6].c_str() );
else
MB_SET_ERR_RET_VAL( "Error, version number not supported", new_tet );
return new_tet;
| ErrorCode ReadRTT::load_file | ( | const char * | file_name, |
| const EntityHandle * | file_set, | ||
| const FileOptions & | opts, | ||
| const SubsetList * | subset_list = 0, |
| const Tag * | file_id_tag = 0 |
| ) | [virtual] |
Method all readers must provide to import a mesh.
| file_name | The file to read. |
| file_set | Optional pointer to entity set representing file. If this is not NULL, reader may optionally tag the pointed-to set with format-specific meta-data. |
| subset_list | An optional struct pointer specifying the tags identifying entity sets to be read. |
| file_id_tag | If specified, reader should store for each entity it reads, a unique integer ID for this tag. |
Implements moab::ReaderIface.
Definition at line 109 of file ReadRTT.cpp.
References build_moab(), ErrorCode, generate_topology(), MB_FILE_DOES_NOT_EXIST, MB_SUCCESS, MB_UNSUPPORTED_OPERATION, read_cells(), read_facets(), read_header(), read_nodes(), read_sides(), and read_tets().
ErrorCode rval;
// at this time there is no support for reading a subset of the file
if( subset_list )
std::cout << "Subset reading not supported for RTT meshes" << std::endl;
return MB_UNSUPPORTED_OPERATION;
// test to see if file exists
FILE* file = NULL;
file = fopen( filename, "r" );
if( file == NULL ) return MB_FILE_DOES_NOT_EXIST;
// otherwise close the file
fclose( file );
// read the header
rval = ReadRTT::read_header( filename );
// read the side_flag data
std::vector< side > side_data;
rval = ReadRTT::read_sides( filename, side_data );
// read the cell data
std::vector< cell > cell_data;
rval = ReadRTT::read_cells( filename, cell_data );
// read the node data
std::vector< node > node_data;
rval = ReadRTT::read_nodes( filename, node_data );
// read the facet data
std::vector< facet > facet_data;
rval = ReadRTT::read_facets( filename, facet_data );
// read the tetrahedra data
std::vector< tet > tet_data;
rval = ReadRTT::read_tets( filename, tet_data );
// make the map of surface number in the rttmesh to the surface meshset
std::map< int, EntityHandle > surface_map; // corrsespondance of surface number to entity handle
rval = ReadRTT::generate_topology( side_data, cell_data, surface_map );
// generate the rest of the database, triangles to surface meshsets etc
rval = ReadRTT::build_moab( node_data, facet_data, tet_data, surface_map );
return MB_SUCCESS;
| ErrorCode ReadRTT::read_cells | ( | const char * | filename, |
| std::vector< cell > & | cell_data | ||
| ) | [private] |
Reads the full set of cell data from the file
| filename,the | file to read all the side data from |
| cell | data, a vector containing all the read cell data |
Definition at line 414 of file ReadRTT.cpp.
References get_cell_data(), input_file, and MB_SUCCESS.
std::string line; // the current line being read
std::ifstream input_file( filename ); // filestream for rttfile
// file ok?
if( !input_file.good() )
std::cout << "Problems reading file = " << filename << std::endl;
return MB_FAILURE;
// if it works
if( input_file.is_open() )
if( line.compare( " 1 REGIONS\0" ) == 0 )
// read lines until find end nodes
if( line.compare( "end_cell_flags\0" ) == 0 ) break;
cell data = ReadRTT::get_cell_data( line );
cell_data.push_back( data );
input_file.close();
if( cell_data.size() == 0 ) return MB_FAILURE;
return MB_SUCCESS;
| ErrorCode ReadRTT::read_facets | ( | const char * | filename, |
| std::vector< facet > & | facet_data | ||
| ) | [private] |
Reads the full set of facet data from the file
| facet | data, a vector containing all the read facet data |
Definition at line 485 of file ReadRTT.cpp.
References get_facet_data(), input_file, and MB_SUCCESS.
// file ok?
return MB_FAILURE;
// if it works
if( line.compare( "sides\0" ) == 0 )
if( line.compare( "end_sides\0" ) == 0 ) break;
facet data = ReadRTT::get_facet_data( line );
facet_data.push_back( data );
input_file.close();
if( facet_data.size() == 0 ) return MB_FAILURE;
return MB_SUCCESS;
| ErrorCode ReadRTT::read_header | ( | const char * | filename | ) | [private] |
reads the full set of header data
| filename,the | file to read the data from |
Definition at line 349 of file ReadRTT.cpp.
References ErrorCode, get_header_data(), and input_file.
std::ifstream input_file( filename ); // filename for rtt file
// file ok?
return MB_FAILURE;
// if it works
std::string line;
moab::ErrorCode rval = MB_FAILURE;
if( line.compare( "header" ) == 0 )
rval = get_header_data( input_file );
input_file.close();
return rval;
| ErrorCode ReadRTT::read_nodes | ( | const char * | filename, |
| std::vector< node > & | node_data | ||
| ) | [private] |
Reads the full set of node data from the file
| node | data, a vector containing all the read node data |
Definition at line 449 of file ReadRTT.cpp.
References get_node_data(), input_file, and MB_SUCCESS.
// file ok?
return MB_FAILURE;
// if it works
if( line.compare( "nodes\0" ) == 0 )
if( line.compare( "end_nodes\0" ) == 0 ) break;
node data = ReadRTT::get_node_data( line );
node_data.push_back( data );
input_file.close();
if( node_data.size() == 0 ) return MB_FAILURE;
return MB_SUCCESS;
| ErrorCode ReadRTT::read_sides | ( | const char * | filename, |
| std::vector< side > & | side_data | ||
| ) | [private] |
Reads the full set of side data from the file
| side | data, a vector containing all the read side data |
Definition at line 379 of file ReadRTT.cpp.
References get_side_data(), input_file, and MB_SUCCESS.
// file ok?
return MB_FAILURE;
// if it works
if( line.compare( " 2 FACES\0" ) == 0 )
if( line.compare( "end_side_flags\0" ) == 0 ) break;
side data = ReadRTT::get_side_data( line );
side_data.push_back( data );
input_file.close();
if( side_data.size() == 0 ) return MB_FAILURE;
return MB_SUCCESS;
| ErrorCode ReadRTT::read_tag_values | ( | const char * | file_name, |
| const char * | tag_name, | ||
| std::vector< int > & | tag_values_out, | ||
| const SubsetList * | subset_list = 0 |
| ) | [virtual] |
Read the list if all integer tag values from the file for a tag that is a single integer value per entity.
| tag_name | The tag for which to read values |
| tag_values_out | Output: The list of tag values. |
| subset_list | An array of tag name and value sets specifying the subset of the file to read. If multiple tags are specified, the sets that match all tags (intersection) should be read. |
| subset_list_length | The length of the 'subset_list' array. |
Definition at line 99 of file ReadRTT.cpp.
References MB_NOT_IMPLEMENTED.
return MB_NOT_IMPLEMENTED;
| ErrorCode ReadRTT::read_tets | ( | const char * | filename, |
| std::vector< tet > & | tet_data | ||
| ) | [private] |
Reads the full set of tet data from the file
| tet | data, a vector containing all the read tet data |
Definition at line 521 of file ReadRTT.cpp.
References get_tet_data(), input_file, and MB_SUCCESS.
// file ok?
return MB_FAILURE;
// if it works
if( line.compare( "cells\0" ) == 0 )
if( line.compare( "end_cells\0" ) == 0 ) break;
tet data = ReadRTT::get_tet_data( line );
tet_data.push_back( data );
input_file.close();
if( tet_data.size() == 0 ) return MB_FAILURE;
return MB_SUCCESS;
| void ReadRTT::set_surface_senses | ( | int | num_ents[4], |
| ) | [private] |
Sets the appropriate surface senses for each surface in the problem. By looping through all the surfaces, we determine from the side_data vector, the volume id's that are shared, then using 1 to mean +ve sense and -1 to mean -ve sense wrt the volume.
Definition at line 864 of file ReadRTT.cpp.
References ErrorCode, MB_SUCCESS, myGeomTool, SENSE_FORWARD, SENSE_REVERSE, and moab::GeomTopoTool::set_sense().
// there are 2 volumes that share this face
// if match found
// in rtt mesh +represents the inside and -represents outside
// in moab reverse is outside and forward is inside
if( side_data[i].senses[shared] == 1 )
rval = myGeomTool->set_sense( surf_handle, cell_handle, SENSE_FORWARD );
else if( side_data[i].senses[shared] == -1 )
rval = myGeomTool->set_sense( surf_handle, cell_handle, SENSE_REVERSE );
else
rval = myGeomTool->set_sense( surf_handle, 0, SENSE_REVERSE );
std::cerr << "Failed to set sense appropriately" << std::endl;
return;
| ErrorCode ReadRTT::setup_group_data | ( | std::vector< EntityHandle > | entity_map[4] | ) | [private] |
creates the group data requried for dagmc, reflecting planes, material assignments etc
| entity_map,vector | of vector of entitiy handles for each dimension |
Definition at line 911 of file ReadRTT.cpp.
References moab::Interface::add_entities(), create_group(), ErrorCode, and MBI.
ErrorCode rval; // error codes
handle = create_group( "graveyard_comp", 1 );
// add any volume to group graveyard, it is ignored by dag
EntityHandle vol_handle = entity_map[3][0];
rval = MBI->add_entities( handle, &vol_handle, 1 );
return rval;
| ReadRTT::boundary ReadRTT::split_name | ( | std::string | atilla_cellname | ) | [private] |
Splits an Attila cellname and populates a boundary structure
| attila_cellname,string | containing the boundary information |
Definition at line 766 of file ReadRTT.cpp.
References moab::ReadRTT::boundary::name, and moab::ReadRTT::boundary::sense.
Referenced by get_side_data().
boundary new_boundary;
// default initialisation
new_boundary.sense = 0;
new_boundary.name = "\0";
// +ve sense
if( atilla_cellname.find( "+" ) != std::string::npos )
new_boundary.sense = 1;
// look for the @# we do not want it
std::size_t found = atilla_cellname.find( "@" );
if( found != std::string::npos )
new_boundary.name = atilla_cellname.substr( 3, found );
else
new_boundary.name = atilla_cellname.substr( 3, atilla_cellname.length() );
else if( atilla_cellname.find( "-" ) != std::string::npos )
// negative sense
new_boundary.sense = -1;
return new_boundary;
| std::vector< std::string > ReadRTT::split_string | ( | std::string | string_to_split, |
| char | split_char | ||
| ) | [private] |
Splits a string into a vector of substrings delimited by split_char
| string_to_split,the | string that needs splitting into chunks |
| split_char,the | character to split the string with |
Definition at line 795 of file ReadRTT.cpp.
References compare().
Referenced by get_cell_data(), get_facet_data(), get_header_data(), get_node_data(), get_side_data(), and get_tet_data().
std::istringstream ss( string_to_split );
while( !ss.eof() )
std::string x; // here's a nice, empty string
std::getline( ss, x, split_char ); // try to read the next field into it
tokens.push_back( x );
// remove empty tokens
std::vector< std::string >::iterator it;
for( it = tokens.begin(); it != tokens.end(); )
std::string string = *it;
if( string.compare( "\0" ) == 0 )
it = tokens.erase( it );
else
++it;
return tokens;
Tag moab::ReadRTT::category_tag [private] |
Definition at line 448 of file ReadRTT.hpp.
Referenced by create_group(), generate_topology(), and ReadRTT().
Tag moab::ReadRTT::faceting_tol_tag [private] |
Referenced by ReadRTT().
Tag moab::ReadRTT::geom_tag [private] |
Referenced by generate_topology(), and ReadRTT().
headerData moab::ReadRTT::header_data [private] |
Definition at line 440 of file ReadRTT.hpp.
Referenced by get_facet_data(), get_header_data(), and get_tet_data().
Tag moab::ReadRTT::id_tag [private] |
Interface* moab::ReadRTT::MBI [private] |
Definition at line 444 of file ReadRTT.hpp.
Referenced by build_moab(), create_group(), generate_parent_child_links(), generate_topology(), ReadRTT(), setup_group_data(), and ~ReadRTT().
GeomTopoTool* moab::ReadRTT::myGeomTool [private] |
Definition at line 446 of file ReadRTT.hpp.
Referenced by ReadRTT(), set_surface_senses(), and ~ReadRTT().
Tag moab::ReadRTT::name_tag [private] |
Referenced by create_group(), and ReadRTT().
ReadUtilIface* moab::ReadRTT::readMeshIface [private] |
Definition at line 442 of file ReadRTT.hpp.
Referenced by ReadRTT(), and ~ReadRTT().
