MOAB: Mesh Oriented datABase
(version 5.4.1)
#include <VtkUtil.hpp>
Collaboration diagram for moab::VtkElemType:Public Attributes | |
| const char * | name |
| String name for use in error messages. | |
| unsigned | vtk_type |
| VTK integer type. | |
| EntityType | mb_type |
| MOAB type. | |
| unsigned | num_nodes |
| Number of nodes (0 for polygon) | |
| const unsigned * | node_order |
Structure defining relation between MOAB and VTK element types. VTK had different types for quadratic than linear elements, so a tuple of the MOAB type and number of elements maps to a VTK type.
Definition at line 28 of file VtkUtil.hpp.
| EntityType moab::VtkElemType::mb_type |
MOAB type.
Definition at line 32 of file VtkUtil.hpp.
Referenced by moab::ReadVtk::vtk_read_unstructured_grid().
| const char* moab::VtkElemType::name |
Definition at line 30 of file VtkUtil.hpp.
| const unsigned* moab::VtkElemType::node_order |
VTK element node ordering, indexed by the VTK node position and containing the corresponding MOAB node position. NOTE: This field is NULL if MOAB and VTK ordering is the same!
Definition at line 34 of file VtkUtil.hpp.
Referenced by moab::ReadVtk::vtk_read_unstructured_grid(), and moab::WriteVtk::write_elems().
| unsigned moab::VtkElemType::num_nodes |
Definition at line 33 of file VtkUtil.hpp.
| unsigned moab::VtkElemType::vtk_type |
VTK integer type.
Definition at line 31 of file VtkUtil.hpp.
Referenced by moab::WriteVtk::write_elems().
