MOAB: Mesh Oriented datABase
(version 5.4.1)
Utility used for reading portions of an HDF5 dataset. More...
#include <ReadHDF5Dataset.hpp>
Collaboration diagram for moab::ReadHDF5Dataset:Classes | |
| class | Exception |
Public Types | |
| typedef int | Comm |
Public Member Functions | |
| ReadHDF5Dataset (const char *debug_desc, hid_t data_set_handle, bool parallel, const Comm *communicator=0, bool close_data_set_on_destruct=true) | |
| Setup to read entire table. | |
| ReadHDF5Dataset (const char *debug_desc, bool parallel, const Comm *communicator=0) | |
| void | init (hid_t data_set_handle, bool close_data_set_on_destruct=true) |
| bool | will_close_data_set () const |
| void | close_data_set_on_destruct (bool val) |
| ~ReadHDF5Dataset () | |
| void | set_file_ids (const Range &file_ids, EntityHandle start_id, hsize_t row_cout, hid_t data_type) |
| Change file ids to read from. | |
| void | set_all_file_ids (hsize_t row_count, hid_t data_type) |
| Read all values in dataset (undo set_file_ids) | |
| bool | done () const |
| Return false if more data to read, true otherwise. | |
| void | read (void *buffer, size_t &rows_read) |
| Read rows of table. | |
| Range::const_iterator | next_file_id () const |
Return position in Range of file IDs at which next read will start. | |
| void | null_read () |
| Do null read operation. | |
| unsigned | columns () const |
| void | set_column (unsigned c) |
| unsigned long | get_read_count () const |
| const char * | get_debug_desc () const |
Static Public Member Functions | |
| static void | set_hyperslab_selection_limit (size_t val) |
| static void | default_hyperslab_selection_limit () |
| static void | append_hyperslabs () |
| static void | or_hyperslabs () |
Private Member Functions | |
| Range::const_iterator | next_end (Range::const_iterator iter) |
Private Attributes | |
| Range | internalRange |
| used when reading entire dataset | |
| bool | closeDataSet |
| close dataset in destructor | |
| hsize_t | dataSetOffset [64] |
| hsize_t | dataSetCount [64] |
| hid_t | dataSet |
| Handle for HDF5 data set. | |
| hid_t | dataSpace |
| Data space for data set. | |
| hid_t | dataType |
| Data type client code wants for data. | |
| hid_t | fileType |
| Data type as stored in data set. | |
| hid_t | ioProp |
| Used to specify collective IO. | |
| int | dataSpaceRank |
| Rank of data set. | |
| hsize_t | rowsInTable |
| Total number of rows in dataset. | |
| bool | doConversion |
| True if dataType != fileType. | |
| bool | nativeParallel |
| If true then reading different data on different procs. | |
| hsize_t | readCount |
| Number of actual reads to do. | |
| hsize_t | bufferSize |
size of buffer passed to read, in number of rows | |
| const Comm * | mpiComm |
| Range::const_iterator | currOffset |
| Range::const_iterator | rangeEnd |
| EntityHandle | startID |
| std::string | mpeDesc |
Static Private Attributes | |
| static bool | haveMPEEvents = false |
| static std::pair< int, int > | mpeReadEvent |
| static std::pair< int, int > | mpeReduceEvent |
| static size_t | hyperslabSelectionLimit = DEFAULT_HYPERSLAB_SELECTION_LIMIT |
| static H5S_seloper_t | hyperslabSelectOp = H5S_SELECT_OR |
Implement iterative read of table where:
NOTE: This class also implements an RAII pattern for the data set handle: It will close the data set in its destructor unless it is specified to the constructor that only a single column should be read.
NOTE: This class will always do collective IO for parallel reads.
Definition at line 38 of file ReadHDF5Dataset.hpp.
| typedef int moab::ReadHDF5Dataset::Comm |
Definition at line 44 of file ReadHDF5Dataset.hpp.
| moab::ReadHDF5Dataset::ReadHDF5Dataset | ( | const char * | debug_desc, |
| hid_t | data_set_handle, | ||
| bool | parallel, | ||
| const Comm * | communicator = 0, |
| bool | close_data_set_on_destruct = true |
| data_set_handle | The HDF5 DataSet to read. |
| parallel | Doing true partial-read parallel read (as opposed to read and delete where collective IO is done for everything because all procs read the same stuff.) |
| communictor | If parallel is true and io_prop is H5FD_MPIO_COLLECTIVE, then this must be a pointer to the MPI_Communicator value. |
| close_data_set_on_destruct | Call H5Dclose on passed data_set_handle in desturctor. |
If parallel is true and io_prop is H5FD_MPIO_COLLECTIVE, then not only must communicator be non-null, but this call must be made collectively!
Class instance will not be usable until one of either set_file_ids or set_all_file_ids is called.
Definition at line 85 of file ReadHDF5Dataset.cpp.
References moab::allocate_mpe_state(), haveMPEEvents, init(), ioProp, mpeReadEvent, mpeReduceEvent, mpiComm, and nativeParallel.
: closeDataSet( close_data_set ), dataSet( data_set_handle ), dataSpace( -1 ), dataType( -1 ), fileType( -1 ), ioProp( H5P_DEFAULT ), dataSpaceRank( 0 ), rowsInTable( 0 ), doConversion( false ), nativeParallel( parallel ), readCount( 0 ), bufferSize( 0 ), mpiComm( communicator ), mpeDesc( debug_desc ) { if( !haveMPEEvents ) { haveMPEEvents = true; mpeReadEvent = allocate_mpe_state( "ReadHDF5Dataset::read", "yellow" ); mpeReduceEvent = allocate_mpe_state( "ReadHDF5Dataset::all_reduce", "yellow" ); } init( data_set_handle, close_data_set ); #ifndef MOAB_HAVE_HDF5_PARALLEL if( nativeParallel ) throw Exception( __LINE__ ); #else if( nativeParallel && !mpiComm ) throw Exception( __LINE__ ); if( mpiComm ) { ioProp = H5Pcreate( H5P_DATASET_XFER ); H5Pset_dxpl_mpio( ioProp, H5FD_MPIO_COLLECTIVE ); } #endif }
| const Comm * | communicator = 0 |
Definition at line 60 of file ReadHDF5Dataset.cpp.
References moab::allocate_mpe_state(), haveMPEEvents, ioProp, mpeReadEvent, mpeReduceEvent, mpiComm, and nativeParallel.
: closeDataSet( false ), dataSet( -1 ), dataSpace( -1 ), dataType( -1 ), fileType( -1 ), ioProp( H5P_DEFAULT ), dataSpaceRank( 0 ), rowsInTable( 0 ), doConversion( false ), nativeParallel( parallel ), readCount( 0 ), bufferSize( 0 ), mpiComm( communicator ), mpeDesc( debug_desc ) { if( !haveMPEEvents ) { haveMPEEvents = true; mpeReadEvent = allocate_mpe_state( "ReadHDF5Dataset::read", "yellow" ); mpeReduceEvent = allocate_mpe_state( "ReadHDF5Dataset::all_reduce", "yellow" ); } #ifndef MOAB_HAVE_HDF5_PARALLEL if( nativeParallel ) throw Exception( __LINE__ ); #else if( nativeParallel && !mpiComm ) throw Exception( __LINE__ ); if( mpiComm ) { ioProp = H5Pcreate( H5P_DATASET_XFER ); H5Pset_dxpl_mpio( ioProp, H5FD_MPIO_COLLECTIVE ); } #endif }
Definition at line 231 of file ReadHDF5Dataset.cpp.
References closeDataSet, dataSet, dataSpace, fileType, and ioProp.
| static void moab::ReadHDF5Dataset::append_hyperslabs | ( | ) | [inline, static] |
Use non-standard 'APPEND' operation for hyperslab selection
Definition at line 166 of file ReadHDF5Dataset.hpp.
References hyperslabSelectOp.
Referenced by moab::ReadHDF5::set_up_read().
hyperslabSelectOp = H5S_SELECT_APPEND;
| void moab::ReadHDF5Dataset::close_data_set_on_destruct | ( | bool | val | ) | [inline] |
| unsigned moab::ReadHDF5Dataset::columns | ( | ) | const |
Definition at line 137 of file ReadHDF5Dataset.cpp.
References dataSetCount, and dataSpaceRank.
Referenced by read().
if( dataSpaceRank == 1 )
return 1;
else if( dataSpaceRank == 2 )
return dataSetCount[1];
| void moab::ReadHDF5Dataset::default_hyperslab_selection_limit | ( | ) | [static] |
Definition at line 33 of file ReadHDF5Dataset.cpp.
References moab::DEFAULT_HYPERSLAB_SELECTION_LIMIT, and hyperslabSelectionLimit.
| bool moab::ReadHDF5Dataset::done | ( | ) | const [inline] |
Test if the iterative read has reached the end.
Definition at line 116 of file ReadHDF5Dataset.hpp.
References currOffset, rangeEnd, and readCount.
Referenced by moab::ReadHDF5VarLen::read_data(), moab::ReadHDF5::read_elems(), moab::ReadHDF5::read_nodes(), moab::ReadHDF5VarLen::read_offsets(), moab::ReadHDF5::read_set_data(), moab::ReadHDF5::read_sparse_tag(), and moab::ReadHDF5::read_tag_values_partial().
return ( currOffset == rangeEnd ) && ( readCount == 0 );
| const char* moab::ReadHDF5Dataset::get_debug_desc | ( | ) | const [inline] |
Definition at line 154 of file ReadHDF5Dataset.hpp.
References mpeDesc.
Referenced by moab::ReadHDF5VarLen::read_data(), moab::ReadHDF5VarLen::read_offsets(), and moab::ReadHDF5::read_set_data().
return mpeDesc.c_str();
| unsigned long moab::ReadHDF5Dataset::get_read_count | ( | ) | const [inline] |
Definition at line 150 of file ReadHDF5Dataset.hpp.
References readCount.
Referenced by moab::ReadHDF5VarLen::read_data(), moab::ReadHDF5::read_elems(), moab::ReadHDF5::read_nodes(), moab::ReadHDF5VarLen::read_offsets(), moab::ReadHDF5::read_sparse_tag(), and moab::ReadHDF5::read_tag_values_partial().
return readCount;
| void moab::ReadHDF5Dataset::init | ( | hid_t | data_set_handle, |
Definition at line 116 of file ReadHDF5Dataset.cpp.
References closeDataSet, currOffset, dataSet, dataSetCount, dataSetOffset, dataSpace, dataSpaceRank, moab::Range::end(), fileType, internalRange, rangeEnd, and rowsInTable.
Referenced by moab::ReadHDF5::read_set_ids_recursive(), and ReadHDF5Dataset().
closeDataSet = close_data_set;
dataSet = data_set_handle;
fileType = H5Dget_type( data_set_handle );
if( fileType < 0 ) throw Exception( __LINE__ );
dataSpace = H5Dget_space( dataSet );
if( dataSpace < 0 ) throw Exception( __LINE__ );
dataSpaceRank = H5Sget_simple_extent_dims( dataSpace, dataSetCount, dataSetOffset );
if( dataSpaceRank < 0 ) throw Exception( __LINE__ );
rowsInTable = dataSetCount[0];
for( int i = 0; i < dataSpaceRank; ++i )
dataSetOffset[i] = 0;
currOffset = rangeEnd = internalRange.end();
| Range::const_iterator moab::ReadHDF5Dataset::next_end | ( | Range::const_iterator | iter | ) | [private] |
Definition at line 154 of file ReadHDF5Dataset.cpp.
References bufferSize, moab::Range::const_iterator::end_of_block(), hyperslabSelectionLimit, and rangeEnd.
Referenced by read(), and set_file_ids().
size_t slabs_remaining = hyperslabSelectionLimit;
size_t avail = bufferSize;
while( iter != rangeEnd && slabs_remaining )
size_t count = *( iter.end_of_block() ) - *iter + 1;
if( count >= avail )
iter += avail;
break;
avail -= count;
iter += count;
--slabs_remaining;
return iter;
| Range::const_iterator moab::ReadHDF5Dataset::next_file_id | ( | ) | const [inline] |
Definition at line 132 of file ReadHDF5Dataset.hpp.
References currOffset.
return currOffset;
| void moab::ReadHDF5Dataset::null_read | ( | ) |
Do a read call requesting no data. This functionality is provided so as to allow collective IO when not all processes need to make the same number of read calls. To prevent deadlock in this case, processes that have finished their necessary read calls can call this function so that all processes are calling the read method collectively.
Definition at line 297 of file ReadHDF5Dataset.cpp.
References dataSet, dataSpace, fileType, and ioProp.
Referenced by read(), and moab::ReadHDF5::read_set_data().
herr_t err;
err = H5Sselect_none( dataSpace );
if( err < 0 ) throw Exception( __LINE__ );
//#if HDF5_16API
hsize_t one = 1;
hid_t mem_id = H5Screate_simple( 1, &one, NULL );
if( mem_id < 0 ) throw Exception( __LINE__ );
err = H5Sselect_none( mem_id );
if( err < 0 )
H5Sclose( mem_id );
//#else
// hid_t mem_id = H5Screate(H5S_NULL);
// if (mem_id < 0)
// throw Exception(__LINE__);
//#endif
err = H5Dread( dataSet, fileType, mem_id, dataSpace, ioProp, 0 );
H5Sclose( mem_id );
| static void moab::ReadHDF5Dataset::or_hyperslabs | ( | ) | [inline, static] |
Revert to default select behavior for standard HDF5 library
Definition at line 171 of file ReadHDF5Dataset.hpp.
hyperslabSelectOp = H5S_SELECT_OR;
| void moab::ReadHDF5Dataset::read | ( | void * | buffer, |
| size_t & | rows_read | ||
Read rows of table.
Read up to max_num_rows from data set.
| buffer | Memory in which to store values read from data set |
| rows_read | The actual number of rows read from the table. Will never exceed max_rows . |
Definition at line 240 of file ReadHDF5Dataset.cpp.
References columns(), currOffset, dataSet, dataSetCount, dataSetOffset, dataSpace, dataSpaceRank, dataType, doConversion, moab::Range::const_iterator::end_of_block(), fileType, hyperslabSelectOp, ioProp, MPE_Log_event, mpeDesc, mpeReadEvent, next_end(), null_read(), rangeEnd, readCount, and startID.
herr_t err;
rows_read = 0;
MPE_Log_event( mpeReadEvent.first, (int)readCount, mpeDesc.c_str() );
if( currOffset != rangeEnd )
// Build H5S hyperslab selection describing the portions of the
// data set to read
H5S_seloper_t sop = H5S_SELECT_SET;
Range::iterator new_end = next_end( currOffset );
while( currOffset != new_end )
size_t count = *( currOffset.end_of_block() ) - *currOffset + 1;
if( new_end != rangeEnd && *currOffset + count > *new_end )
count = *new_end - *currOffset;
rows_read += count;
dataSetOffset[0] = *currOffset - startID;
dataSetCount[0] = count;
err = H5Sselect_hyperslab( dataSpace, sop, dataSetOffset, NULL, dataSetCount, 0 );
sop = hyperslabSelectOp; // subsequent calls to select_hyperslab append
currOffset += count;
// Create a data space describing the memory in which to read the data
dataSetCount[0] = rows_read;
hid_t mem_id = H5Screate_simple( dataSpaceRank, dataSetCount, NULL );
// Do the actual read
err = H5Dread( dataSet, fileType, mem_id, dataSpace, ioProp, buffer );
H5Sclose( mem_id );
if( readCount ) --readCount;
if( doConversion )
err = H5Tconvert( fileType, dataType, rows_read * columns(), buffer, 0, H5P_DEFAULT );
else if( readCount )
null_read();
--readCount;
MPE_Log_event( mpeReadEvent.second, (int)readCount, mpeDesc.c_str() );
| void moab::ReadHDF5Dataset::set_all_file_ids | ( | hsize_t | row_count, |
| hid_t | data_type | ||
| row_count | Read buffer size in number of table rows. |
| data_type | The data type of the buffer into which table values are to be read. |
Definition at line 224 of file ReadHDF5Dataset.cpp.
References moab::Range::clear(), moab::Range::insert(), internalRange, rowsInTable, and set_file_ids().
Referenced by moab::ReadHDF5::read_sparse_tag_indices(), and moab::ReadHDF5::read_tag_values_partial().
internalRange.clear();
internalRange.insert( (EntityHandle)1, (EntityHandle)( rowsInTable ) );
set_file_ids( internalRange, 1, row_count, data_type );
| void moab::ReadHDF5Dataset::set_column | ( | unsigned | c | ) |
Definition at line 147 of file ReadHDF5Dataset.cpp.
References dataSetCount, dataSetOffset, and dataSpaceRank.
Referenced by moab::ReadHDF5::read_nodes().
if( dataSpaceRank != 2 || column >= dataSetCount[1] ) throw Exception( __LINE__ );
dataSetCount[1] = 1;
dataSetOffset[1] = column;
| void moab::ReadHDF5Dataset::set_file_ids | ( | const Range & | file_ids, |
| EntityHandle | start_id, | ||
| hsize_t | row_cout, | ||
| file_ids | List of rows to read from dataset |
| start_id | Rows of dataset are enumerating beginning with this value. Thus the offset row to be read from dataset will be file_ids.begin() - start_id . |
Definition at line 174 of file ReadHDF5Dataset.cpp.
References moab::Range::begin(), bufferSize, currOffset, dataType, doConversion, moab::Range::end(), fileType, MPE_Log_event, mpeDesc, mpeReduceEvent, mpiComm, nativeParallel, next_end(), rangeEnd, readCount, and startID.
Referenced by moab::ReadHDF5VarLen::read_data(), moab::ReadHDF5::read_elems(), moab::ReadHDF5::read_nodes(), moab::ReadHDF5VarLen::read_offsets(), moab::ReadHDF5::read_set_data(), moab::ReadHDF5::read_sparse_tag(), moab::ReadHDF5::read_tag_values_partial(), and set_all_file_ids().
startID = start_id;
currOffset = file_ids.begin();
rangeEnd = file_ids.end();
readCount = 0;
bufferSize = row_count;
// if a) user specified buffer size and b) we're doing a true
// parallel partial read and c) we're doing collective I/O, then
// we need to know the maximum number of reads that will be done.
#ifdef MOAB_HAVE_HDF5_PARALLEL
Range::const_iterator iter = currOffset;
while( iter != rangeEnd )
++readCount;
iter = next_end( iter );
MPE_Log_event( mpeReduceEvent.first, (int)readCount, mpeDesc.c_str() );
unsigned long recv = readCount, send = readCount;
MPI_Allreduce( &send, &recv, 1, MPI_UNSIGNED_LONG, MPI_MAX, *mpiComm );
readCount = recv;
MPE_Log_event( mpeReduceEvent.second, (int)readCount, mpeDesc.c_str() );
#endif
dataType = data_type;
htri_t equal = H5Tequal( fileType, dataType );
if( equal < 0 ) throw Exception( __LINE__ );
doConversion = !equal;
// We always read in the format of the file to avoid stupind HDF5
// library behavior when reading in parallel. We call H5Tconvert
// ourselves to do the data conversion. If the type we're reading
// from the file is larger than the type we want in memory, then
// we need to reduce num_rows so that we can read the larger type
// from the file into the passed buffer mean to accomodate num_rows
// of values of the smaller in-memory type.
if( doConversion )
size_t mem_size, file_size;
mem_size = H5Tget_size( dataType );
file_size = H5Tget_size( fileType );
if( file_size > mem_size ) bufferSize = bufferSize * mem_size / file_size;
| static void moab::ReadHDF5Dataset::set_hyperslab_selection_limit | ( | size_t | val | ) | [inline, static] |
Definition at line 159 of file ReadHDF5Dataset.hpp.
References hyperslabSelectionLimit.
hyperslabSelectionLimit = val;
| bool moab::ReadHDF5Dataset::will_close_data_set | ( | ) | const [inline] |
Definition at line 81 of file ReadHDF5Dataset.hpp.
References closeDataSet.
return closeDataSet;
hsize_t moab::ReadHDF5Dataset::bufferSize [private] |
Definition at line 194 of file ReadHDF5Dataset.hpp.
Referenced by next_end(), and set_file_ids().
bool moab::ReadHDF5Dataset::closeDataSet [private] |
Definition at line 181 of file ReadHDF5Dataset.hpp.
Referenced by close_data_set_on_destruct(), init(), will_close_data_set(), and ~ReadHDF5Dataset().
Definition at line 197 of file ReadHDF5Dataset.hpp.
Referenced by done(), init(), next_file_id(), read(), and set_file_ids().
hid_t moab::ReadHDF5Dataset::dataSet [private] |
Definition at line 183 of file ReadHDF5Dataset.hpp.
Referenced by init(), null_read(), read(), and ~ReadHDF5Dataset().
hsize_t moab::ReadHDF5Dataset::dataSetCount[64] [private] |
Definition at line 182 of file ReadHDF5Dataset.hpp.
Referenced by columns(), init(), read(), and set_column().
hsize_t moab::ReadHDF5Dataset::dataSetOffset[64] [private] |
Referenced by init(), read(), and set_column().
hid_t moab::ReadHDF5Dataset::dataSpace [private] |
Definition at line 184 of file ReadHDF5Dataset.hpp.
int moab::ReadHDF5Dataset::dataSpaceRank [private] |
Rank of data set.
Definition at line 188 of file ReadHDF5Dataset.hpp.
hid_t moab::ReadHDF5Dataset::dataType [private] |
Definition at line 185 of file ReadHDF5Dataset.hpp.
bool moab::ReadHDF5Dataset::doConversion [private] |
Definition at line 190 of file ReadHDF5Dataset.hpp.
hid_t moab::ReadHDF5Dataset::fileType [private] |
Definition at line 186 of file ReadHDF5Dataset.hpp.
Referenced by init(), null_read(), read(), set_file_ids(), and ~ReadHDF5Dataset().
bool moab::ReadHDF5Dataset::haveMPEEvents = false [static, private] |
Definition at line 200 of file ReadHDF5Dataset.hpp.
Referenced by ReadHDF5Dataset().
size_t moab::ReadHDF5Dataset::hyperslabSelectionLimit = DEFAULT_HYPERSLAB_SELECTION_LIMIT [static, private] |
Definition at line 205 of file ReadHDF5Dataset.hpp.
Referenced by default_hyperslab_selection_limit(), next_end(), and set_hyperslab_selection_limit().
H5S_seloper_t moab::ReadHDF5Dataset::hyperslabSelectOp = H5S_SELECT_OR [static, private] |
Definition at line 206 of file ReadHDF5Dataset.hpp.
Referenced by append_hyperslabs(), or_hyperslabs(), and read().
Range moab::ReadHDF5Dataset::internalRange [private] |
Definition at line 179 of file ReadHDF5Dataset.hpp.
Referenced by init(), and set_all_file_ids().
hid_t moab::ReadHDF5Dataset::ioProp [private] |
Definition at line 187 of file ReadHDF5Dataset.hpp.
Referenced by null_read(), read(), ReadHDF5Dataset(), and ~ReadHDF5Dataset().
std::string moab::ReadHDF5Dataset::mpeDesc [private] |
Definition at line 203 of file ReadHDF5Dataset.hpp.
Referenced by get_debug_desc(), read(), and set_file_ids().
std::pair< int, int > moab::ReadHDF5Dataset::mpeReadEvent [static, private] |
Definition at line 201 of file ReadHDF5Dataset.hpp.
Referenced by read(), and ReadHDF5Dataset().
std::pair< int, int > moab::ReadHDF5Dataset::mpeReduceEvent [static, private] |
Definition at line 202 of file ReadHDF5Dataset.hpp.
Referenced by ReadHDF5Dataset(), and set_file_ids().
const Comm* moab::ReadHDF5Dataset::mpiComm [private] |
Definition at line 195 of file ReadHDF5Dataset.hpp.
bool moab::ReadHDF5Dataset::nativeParallel [private] |
Definition at line 191 of file ReadHDF5Dataset.hpp.
Referenced by done(), init(), next_end(), read(), and set_file_ids().
hsize_t moab::ReadHDF5Dataset::readCount [private] |
Definition at line 193 of file ReadHDF5Dataset.hpp.
Referenced by done(), get_read_count(), read(), and set_file_ids().
hsize_t moab::ReadHDF5Dataset::rowsInTable [private] |
Definition at line 189 of file ReadHDF5Dataset.hpp.
EntityHandle moab::ReadHDF5Dataset::startID [private] |
Definition at line 198 of file ReadHDF5Dataset.hpp.
