MOAB: Mesh Oriented datABase
(version 5.4.1)
Collaboration diagram for DeformMeshRemap:Public Types | |
| enum | { MASTER = 0, SLAVE, SOLID, FLUID } |
| Enumerator for solid/fluid, master/slave. More... | |
Public Member Functions | |
| DeformMeshRemap (Interface *impl, ParallelComm *master=NULL, ParallelComm *slave=NULL) | |
| ~DeformMeshRemap () | |
| Destructor. | |
| ErrorCode | execute () |
| Execute the deformed mesh process. | |
| ErrorCode | add_set_no (int m_or_s, int fluid_or_solid, int set_no) |
| Add a set number. | |
| ErrorCode | remove_set_no (int m_or_s, int fluid_or_solid, int set_no) |
| Remove a set number. | |
| ErrorCode | get_set_nos (int m_or_s, int fluid_or_solid, set< int > &set_nos) const |
| Get the set numbers. | |
| Tag | x_new () const |
| Get the xNew tag handle. | |
| string | x_new_name () const |
| Get the tag name. | |
| void | x_new_name (const string &name) |
| Set the tag name. | |
| string | get_file_name (int m_or_s) const |
| Get/set the file name. | |
| void | set_file_name (int m_or_s, const string &name) |
| string | xdisp_name (int idx=0) |
| Get/set the x displacement tag names. | |
| void | xdisp_name (const string &nm, int idx=0) |
Private Member Functions | |
| ErrorCode | deform_master (Range &fluid_elems, Range &solid_elems, const char *tag_name=NULL) |
| ErrorCode | read_file (int m_or_s, string &fname, EntityHandle &seth) |
| Read a file and establish proper ranges. | |
| ErrorCode | write_to_coords (Range &elems, Tag tagh, Tag tmp_tag=0) |
| ErrorCode | write_and_save (Range &ents, EntityHandle seth, Tag tagh, const char *filename, bool restore_coords=false) |
| ErrorCode | find_other_sets (int m_or_s, EntityHandle file_set) |
| Find fluid/solid sets from complement of solid/fluid sets. | |
Private Attributes | |
| Interface * | mbImpl |
| moab interface | |
| set< int > | fluidSetNos [2] |
| Material set numbers for fluid materials, for master/slave. | |
| set< int > | solidSetNos [2] |
| Material set numbers for solid materials, for master/slave. | |
| EntityHandle | masterSet |
| Sets defining master/slave meshes. | |
| EntityHandle | slaveSet |
| Range | fluidSets [2] |
| Sets in master/slave meshes. | |
| Range | solidSets [2] |
| Range | fluidElems [2] |
| Elements in master/slave meshes. | |
| Range | solidElems [2] |
| string | masterFileName |
| Filenames for master/slave meshes. | |
| string | slaveFileName |
| Tag | xDisp [3] |
| Tag from file, might be 3. | |
| Tag | xNew |
| Tag used for new positions. | |
| string | xDispNames [3] |
| Tag name used to read disps from file. | |
| string | xNewName |
| Tag name used for new positions. | |
Definition at line 56 of file DeformMeshRemap.cpp.
| anonymous enum |
| DeformMeshRemap::DeformMeshRemap | ( | Interface * | impl, |
| ParallelComm * | master = NULL, |
| ParallelComm * | slave = NULL |
Constructor If master is NULL, the MOAB part is run in serial; If slave is NULL but the master isn't, the slave is copied from the master Create communicators using moab::ParallelComm::get_pcomm
Definition at line 417 of file DeformMeshRemap.cpp.
References xDisp.
| ErrorCode DeformMeshRemap::add_set_no | ( | int | m_or_s, |
| int | fluid_or_solid, | ||
| int | set_no | ||
| ) | [inline] |
Add a set number.
Definition at line 180 of file DeformMeshRemap.cpp.
References MB_INDEX_OUT_OF_RANGE, MB_SUCCESS, and SOLID.
Referenced by main().
set< int >* this_set;
assert( ( m_or_s == MASTER || m_or_s == SLAVE ) && "m_or_s should be MASTER or SLAVE." );
if( m_or_s != MASTER && m_or_s != SLAVE ) return MB_INDEX_OUT_OF_RANGE;
switch( f_or_s )
case FLUID:
this_set = &fluidSetNos[m_or_s];
break;
case SOLID:
this_set = &solidSetNos[m_or_s];
break;
default:
assert( false && "f_or_s should be FLUID or SOLID." );
return MB_FAILURE;
this_set->insert( set_no );
return MB_SUCCESS;
| ErrorCode DeformMeshRemap::deform_master | ( | Range & | fluid_elems, |
| Range & | solid_elems, | ||
| const char * | tag_name = NULL |
| ) | [private] |
Apply a known deformation to the solid elements, putting the results in the xNew tag; also write current coordinates to the xNew tag for fluid elements
Definition at line 563 of file DeformMeshRemap.cpp.
References moab::BoundBox::bMax, moab::BoundBox::bMin, box(), moab::debug, deform_func(), ErrorCode, fluidElems, moab::Interface::get_adjacencies(), moab::Interface::get_coords(), moab::CartVect::length_squared(), MASTER, masterSet, MB_CHK_ERR, MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_DOUBLE, mbImpl, moab::Range::merge(), moab::Range::size(), solidElems, moab::subtract(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), smoab::UNION, moab::BoundBox::update(), write_and_save(), xDisp, xDispNames, and xNew.
// Deform elements with an analytic function
ErrorCode rval;
// Get all the vertices and coords in the solid
Range solid_verts, fluid_verts;
rval = mbImpl->get_adjacencies( solid_elems, 0, false, solid_verts, Interface::UNION );MB_CHK_SET_ERR( rval, "Failed to get vertices" );
vector< double > coords( 3 * solid_verts.size() ), new_coords( 3 * solid_verts.size() );
rval = mbImpl->get_coords( solid_verts, &coords[0] );MB_CHK_SET_ERR( rval, "Failed to get vertex coords" );
unsigned int num_verts = solid_verts.size();
// Get or create the tag
if( !xDispNames[0].empty() && !xDispNames[1].empty() && !xDispNames[2].empty() )
// 3 tags, specifying xyz individual data, integrate into one tag
rval = mbImpl->tag_get_handle( ( tag_name ? tag_name : "" ), 3, MB_TYPE_DOUBLE, xNew,
MB_TAG_CREAT | MB_TAG_DENSE );MB_CHK_SET_ERR( rval, "Failed to create xnew tag" );
vector< double > disps( num_verts );
for( int i = 0; i < 3; i++ )
rval = mbImpl->tag_get_handle( xDispNames[0].c_str(), 1, MB_TYPE_DOUBLE, xDisp[i] );MB_CHK_SET_ERR( rval, "Failed to get xDisp tag" );
rval = mbImpl->tag_get_data( xDisp[i], solid_verts, &disps[0] );MB_CHK_SET_ERR( rval, "Failed to get xDisp tag values" );
for( unsigned int j = 0; j < num_verts; j++ )
new_coords[3 * j + i] = coords[3 * j + i] + disps[j];
else if( !xDispNames[0].empty() )
rval = mbImpl->tag_get_handle( xDispNames[0].c_str(), 3, MB_TYPE_DOUBLE, xDisp[0] );MB_CHK_SET_ERR( rval, "Failed to get first xDisp tag" );
xNew = xDisp[0];
vector< double > disps( 3 * num_verts );
rval = mbImpl->tag_get_data( xDisp[0], solid_verts, &disps[0] );
for( unsigned int j = 0; j < 3 * num_verts; j++ )
new_coords[j] = coords[j] + disps[j];
else
// Get the bounding box of the solid mesh
BoundBox bbox;
bbox.update( *mbImpl, solid_elems );
deform_func( bbox, &coords[3 * j], &new_coords[3 * j] );
if( debug )
double len = 0.0;
for( unsigned int i = 0; i < num_verts; i++ )
CartVect dx = CartVect( &new_coords[3 * i] ) - CartVect( &coords[3 * i] );
double tmp_len = dx.length_squared();
if( tmp_len > len ) len = tmp_len;
Range tmp_elems( fluid_elems );
tmp_elems.merge( solid_elems );
BoundBox box;
box.update( *mbImpl, tmp_elems );
double max_len =
std::max( box.bMax[2] - box.bMin[2], std::max( box.bMax[1] - box.bMin[1], box.bMax[0] - box.bMin[0] ) );
cout << "Max displacement = " << len << " (" << 100.0 * len / max_len << "% of max box length)" << endl;
if( !xNew )
rval = mbImpl->tag_get_handle( ( tag_name ? tag_name : "" ), 3, MB_TYPE_DOUBLE, xDisp[0],
MB_TAG_CREAT | MB_TAG_DENSE );MB_CHK_SET_ERR( rval, "Failed to get xNew tag" );
xNew = xDisp[0];
// Set the new tag to those coords
rval = mbImpl->tag_set_data( xNew, solid_verts, &new_coords[0] );MB_CHK_SET_ERR( rval, "Failed to set tag data" );
// Get all the vertices and coords in the fluid, set xnew to them
rval = mbImpl->get_adjacencies( fluid_elems, 0, false, fluid_verts, Interface::UNION );MB_CHK_SET_ERR( rval, "Failed to get vertices" );
fluid_verts = subtract( fluid_verts, solid_verts );
if( coords.size() < 3 * fluid_verts.size() ) coords.resize( 3 * fluid_verts.size() );
rval = mbImpl->get_coords( fluid_verts, &coords[0] );MB_CHK_SET_ERR( rval, "Failed to get vertex coords" );
rval = mbImpl->tag_set_data( xNew, fluid_verts, &coords[0] );MB_CHK_SET_ERR( rval, "Failed to set xnew tag on fluid verts" );
if( debug )
// Save deformed mesh coords to new file for visualizing
Range tmp_range( fluidElems[MASTER] );
tmp_range.merge( solidElems[MASTER] );
rval = write_and_save( tmp_range, masterSet, xNew, "deformed_master.h5m", true );MB_CHK_ERR( rval );
return MB_SUCCESS;
Definition at line 266 of file DeformMeshRemap.cpp.
References moab::debug, deform_master(), ErrorCode, moab::Skinner::find_skin(), moab::SpatialLocator::get_tree(), moab::DataCoupler::interpolate(), moab::SpatialLocator::local_num_located(), moab::DataCoupler::locate_points(), MB_CHK_ERR, MB_CHK_SET_ERR, MB_SUCCESS, moab::Range::merge(), MESHSET_SET, moab::LloydSmoother::num_its(), moab::LloydSmoother::perform_smooth(), moab::TreeStats::print(), read_file(), moab::Range::size(), skin(), moab::DataCoupler::spatial_locator(), moab::Tree::tree_stats(), moab::Interface::UNION, moab::DataCoupler::VOLUME, and write_to_coords().
// Read master/slave files and get fluid/solid material sets
ErrorCode rval = read_file( MASTER, masterFileName, masterSet );MB_CHK_ERR( rval );
if( solidSetNos[MASTER].empty() || fluidSetNos[MASTER].empty() )
rval = find_other_sets( MASTER, masterSet );MB_CHK_SET_ERR( rval, "Failed to find other sets in master mesh" );
bool have_slave = !( slaveFileName == "none" );
if( have_slave )
rval = read_file( SLAVE, slaveFileName, slaveSet );MB_CHK_ERR( rval );
if( solidSetNos[SLAVE].empty() || fluidSetNos[SLAVE].empty() )
rval = find_other_sets( SLAVE, slaveSet );MB_CHK_SET_ERR( rval, "Failed to find other sets in slave mesh" );
if( debug ) cout << "Constructing data coupler/search tree on master mesh..." << endl;
Range src_elems = solidElems[MASTER];
src_elems.merge( fluidElems[MASTER] );
// Initialize data coupler on source elements
DataCoupler dc_master( mbImpl, src_elems, 0, NULL );
Range tgt_verts;
if( have_slave )
// Locate slave vertices in master, orig coords; do this with a data coupler, so you can
// later interpolate
Range tmp_range = solidElems[SLAVE];
tmp_range.merge( fluidElems[SLAVE] );
rval = mbImpl->get_adjacencies( tmp_range, 0, false, tgt_verts, Interface::UNION );MB_CHK_SET_ERR( rval, "Failed to get target verts" );
// Locate slave vertices, caching results in dc
if( debug ) cout << "Locating slave vertices in master mesh..." << endl;
rval = dc_master.locate_points( tgt_verts );MB_CHK_SET_ERR( rval, "Point location of tgt verts failed" );
int num_located = dc_master.spatial_locator()->local_num_located();
if( num_located != (int)tgt_verts.size() )
rval = MB_FAILURE;
cout << "Only " << num_located << " out of " << tgt_verts.size() << " target points successfully located."
<< endl;
return rval;
// Deform the master's solid mesh, put results in a new tag
if( debug ) cout << "Deforming fluid elements in master mesh..." << endl;
rval = deform_master( fluidElems[MASTER], solidElems[MASTER], "xnew" );MB_CHK_ERR( rval );
{ // To isolate the lloyd smoother & delete when done
if( debug )
// Output the skin of smoothed elems, as a check
// Get the skin; get facets, because we might need to filter on shared entities
Skinner skinner( mbImpl );
Range skin;
rval = skinner.find_skin( 0, fluidElems[MASTER], false, skin );MB_CHK_SET_ERR( rval, "Unable to find skin" );
EntityHandle skin_set;
cout << "Writing skin_mesh.g and fluid_mesh.g." << endl;
rval = mbImpl->create_meshset( MESHSET_SET, skin_set );MB_CHK_SET_ERR( rval, "Failed to create skin set" );
rval = mbImpl->add_entities( skin_set, skin );MB_CHK_SET_ERR( rval, "Failed to add skin entities to set" );
rval = mbImpl->write_file( "skin_mesh.vtk", NULL, NULL, &skin_set, 1 );MB_CHK_SET_ERR( rval, "Failure to write skin set" );
rval = mbImpl->remove_entities( skin_set, skin );MB_CHK_SET_ERR( rval, "Failed to remove skin entities from set" );
rval = mbImpl->add_entities( skin_set, fluidElems[MASTER] );MB_CHK_SET_ERR( rval, "Failed to add fluid entities to set" );
rval = mbImpl->write_file( "fluid_mesh.vtk", NULL, NULL, &skin_set, 1 );MB_CHK_SET_ERR( rval, "Failure to write fluid set" );
rval = mbImpl->delete_entities( &skin_set, 1 );MB_CHK_SET_ERR( rval, "Failed to delete skin set" );
// Smooth the master mesh
if( debug ) cout << "Smoothing fluid elements in master mesh..." << endl;
LloydSmoother ll( mbImpl, NULL, fluidElems[MASTER], xNew );
rval = ll.perform_smooth();MB_CHK_SET_ERR( rval, "Failed in lloyd smoothing" );
cout << "Lloyd smoothing required " << ll.num_its() << " iterations." << endl;
// Transfer xNew to coords, for master
if( debug ) cout << "Transferring coords tag to vertex coordinates in master mesh..." << endl;
rval = write_to_coords( solidElems[MASTER], xNew );MB_CHK_SET_ERR( rval, "Failed writing tag to master fluid verts" );
rval = write_to_coords( fluidElems[MASTER], xNew );MB_CHK_SET_ERR( rval, "Failed writing tag to master fluid verts" );
if( have_slave )
// Map new locations to slave
// Interpolate xNew to slave points
if( debug ) cout << "Interpolating new coordinates to slave vertices..." << endl;
rval = dc_master.interpolate( (int)DataCoupler::VOLUME, "xnew" );MB_CHK_SET_ERR( rval, "Failed to interpolate target solution" );
// Transfer xNew to coords, for slave
if( debug ) cout << "Transferring coords tag to vertex coordinates in slave mesh..." << endl;
rval = write_to_coords( tgt_verts, xNew );MB_CHK_SET_ERR( rval, "Failed writing tag to slave verts" );
if( debug )
string str;
#ifdef USE_MPI
if( pcMaster && pcMaster->size() > 1 ) str = "PARALLEL=WRITE_PART";
#endif
if( debug ) cout << "Writing smoothed_master.h5m..." << endl;
rval = mbImpl->write_file( "smoothed_master.h5m", NULL, str.c_str(), &masterSet, 1 );
if( have_slave )
#ifdef USE_MPI
str.clear();
if( pcSlave && pcSlave->size() > 1 ) str = "PARALLEL=WRITE_PART";
#endif
if( debug ) cout << "Writing slave_interp.h5m..." << endl;
rval = mbImpl->write_file( "slave_interp.h5m", NULL, str.c_str(), &slaveSet, 1 );
} // if have_slave
} // if debug
if( debug ) dc_master.spatial_locator()->get_tree()->tree_stats().print();
return MB_SUCCESS;
| ErrorCode DeformMeshRemap::find_other_sets | ( | int | m_or_s, |
| EntityHandle | file_set | ||
| ) | [private] |
Definition at line 743 of file DeformMeshRemap.cpp.
References moab::debug, dim, moab::Interface::dimension_from_handle(), moab::Range::empty(), ErrorCode, fluidElems, fluidSets, moab::Interface::get_entities_by_handle(), moab::Interface::get_entities_by_type_and_tag(), MASTER, MATERIAL_SET_TAG_NAME, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MBENTITYSET, mbImpl, moab::Range::rbegin(), solidElems, solidSets, moab::Range::subset_by_dimension(), moab::subtract(), and moab::Interface::tag_get_handle().
// Solid or fluid sets are missing; find the other
Range *filled_sets = NULL, *unfilled_sets = NULL, *unfilled_elems = NULL;
if( fluidSets[m_or_s].empty() && !solidSets[m_or_s].empty() )
unfilled_sets = &fluidSets[m_or_s];
filled_sets = &solidSets[m_or_s];
unfilled_elems = &fluidElems[m_or_s];
if( debug )
cout << "Finding unspecified fluid elements in " << ( m_or_s == MASTER ? "master" : "slave" ) << " mesh...";
else if( !fluidSets[m_or_s].empty() && solidSets[m_or_s].empty() )
unfilled_sets = &solidSets[m_or_s];
unfilled_elems = &solidElems[m_or_s];
if( debug )
cout << "Finding unspecified solid elements in " << ( m_or_s == MASTER ? "master" : "slave" ) << " mesh...";
// Ok, we know the filled sets, now fill the unfilled sets, and the elems from those
Tag tagh;
ErrorCode rval = mbImpl->tag_get_handle( MATERIAL_SET_TAG_NAME, tagh );MB_CHK_SET_ERR( rval, "Couldn't get material set tag name" );
Range matsets;
rval = mbImpl->get_entities_by_type_and_tag( file_set, MBENTITYSET, &tagh, NULL, 1, matsets );
if( MB_SUCCESS != rval || matsets.empty() )
MB_SET_ERR( MB_FAILURE, "Couldn't get any material sets" );
*unfilled_sets = subtract( matsets, *filled_sets );
if( unfilled_sets->empty() )
MB_SET_ERR( MB_FAILURE, "Failed to find any unfilled material sets" );
Range tmp_range;
for( Range::iterator rit = unfilled_sets->begin(); rit != unfilled_sets->end(); ++rit )
rval = mbImpl->get_entities_by_handle( *rit, tmp_range, true );MB_CHK_SET_ERR( rval, "Failed to get entities in unfilled set" );
int dim = mbImpl->dimension_from_handle( *tmp_range.rbegin() );
assert( dim > 0 && dim < 4 );
*unfilled_elems = tmp_range.subset_by_dimension( dim );
if( unfilled_elems->empty() )
MB_SET_ERR( MB_FAILURE, "Failed to find any unfilled set entities" );
if( debug )
cout << "found " << unfilled_sets->size() << " sets and " << unfilled_elems->size() << " elements." << endl;
return MB_SUCCESS;
| string DeformMeshRemap::get_file_name | ( | int | m_or_s | ) | const |
Definition at line 388 of file DeformMeshRemap.cpp.
switch( m_or_s )
case MASTER:
return masterFileName;
case SLAVE:
return slaveFileName;
default:
assert( false && "m_or_s should be MASTER or SLAVE." );
return string();
| ErrorCode DeformMeshRemap::get_set_nos | ( | int | m_or_s, |
| set< int > & | set_nos | ||
| ) | const [inline] |
Definition at line 233 of file DeformMeshRemap.cpp.
const set< int >* this_set;
switch( f_or_s )
case FLUID:
break;
case SOLID:
break;
default:
return MB_FAILURE;
set_nos = *this_set;
return MB_SUCCESS;
| ErrorCode DeformMeshRemap::read_file | ( | int | m_or_s, |
| string & | fname, | ||
| EntityHandle & | seth | ||
| ) | [private] |
Definition at line 657 of file DeformMeshRemap.cpp.
References moab::Range::clear(), moab::Interface::create_meshset(), moab::debug, dim, moab::Interface::dimension_from_handle(), moab::Range::empty(), moab::Range::end(), ErrorCode, fluidElems, fluidSetNos, fluidSets, moab::Interface::get_entities_by_handle(), moab::Interface::get_entities_by_type_and_tag(), moab::ParallelComm::get_id(), moab::Interface::load_file(), MASTER, MATERIAL_SET_TAG_NAME, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MBENTITYSET, mbImpl, moab::Range::merge(), moab::Range::rbegin(), moab::Range::size(), moab::ParallelComm::size(), solidElems, solidSetNos, solidSets, moab::Range::subset_by_dimension(), and moab::Interface::tag_get_handle().
// Create meshset
ErrorCode rval = mbImpl->create_meshset( 0, seth );MB_CHK_SET_ERR( rval, "Couldn't create master/slave set" );
ostringstream options;
#ifdef USE_MPI
ParallelComm* pc = ( m_or_s == MASTER ? pcMaster : pcSlave );
if( pc && pc->size() > 1 )
if( debug ) options << "DEBUG_IO=1;CPUTIME;";
options << "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;"
<< "PARALLEL_GHOSTS=2.0.1;PARALLEL_COMM=" << pc->get_id();
#endif
rval = mbImpl->load_file( fname.c_str(), &seth, options.str().c_str() );MB_CHK_SET_ERR( rval, "Couldn't load master/slave mesh" );
if( *solidSetNos[m_or_s].begin() == -1 || *fluidSetNos[m_or_s].begin() == -1 ) return MB_SUCCESS;
// Get material sets for solid/fluid
Tag tagh;
for( set< int >::iterator sit = solidSetNos[m_or_s].begin(); sit != solidSetNos[m_or_s].end(); ++sit )
Range sets;
int set_no = *sit;
const void* setno_ptr = &set_no;
rval = mbImpl->get_entities_by_type_and_tag( seth, MBENTITYSET, &tagh, &setno_ptr, 1, sets );
if( MB_SUCCESS != rval || sets.empty() )
MB_SET_ERR( MB_FAILURE, "Couldn't find solid set #" << *sit );
else
solidSets[m_or_s].merge( sets );
// Get solid entities, and dimension
Range tmp_range;
for( Range::iterator rit = solidSets[m_or_s].begin(); rit != solidSets[m_or_s].end(); ++rit )
rval = mbImpl->get_entities_by_handle( *rit, tmp_range, true );MB_CHK_SET_ERR( rval, "Failed to get entities in solid" );
if( !tmp_range.empty() )
solidElems[m_or_s] = tmp_range.subset_by_dimension( dim );
if( debug )
cout << "Read " << solidElems[m_or_s].size() << " solid elements from " << solidSets[m_or_s].size()
<< " sets in " << ( m_or_s == MASTER ? "master" : "slave" ) << " mesh." << endl;
for( set< int >::iterator sit = fluidSetNos[m_or_s].begin(); sit != fluidSetNos[m_or_s].end(); ++sit )
Range sets;
int set_no = *sit;
MB_SET_ERR( MB_FAILURE, "Couldn't find fluid set #" << *sit );
else
fluidSets[m_or_s].merge( sets );
// Get fluid entities, and dimension
tmp_range.clear();
for( Range::iterator rit = fluidSets[m_or_s].begin(); rit != fluidSets[m_or_s].end(); ++rit )
rval = mbImpl->get_entities_by_handle( *rit, tmp_range, true );MB_CHK_SET_ERR( rval, "Failed to get entities in fluid" );
fluidElems[m_or_s] = tmp_range.subset_by_dimension( dim );
if( debug )
cout << "Read " << fluidElems[m_or_s].size() << " fluid elements from " << fluidSets[m_or_s].size()
return rval;
| ErrorCode DeformMeshRemap::remove_set_no | ( | int | m_or_s, |
| int | set_no | ||
| ) | [inline] |
Definition at line 205 of file DeformMeshRemap.cpp.
switch( f_or_s )
case FLUID:
break;
case SOLID:
break;
default:
return MB_FAILURE;
set< int >::iterator sit = this_set->find( set_no );
if( sit != this_set->end() )
this_set->erase( *sit );
return MB_SUCCESS;
return MB_FAILURE;
| void DeformMeshRemap::set_file_name | ( | int | m_or_s, |
| const string & | name | ||
Definition at line 402 of file DeformMeshRemap.cpp.
switch( m_or_s )
case MASTER:
masterFileName = name;
break;
case SLAVE:
slaveFileName = name;
break;
default:
| ErrorCode DeformMeshRemap::write_and_save | ( | Range & | ents, |
| EntityHandle | seth, | ||
| Tag | tagh, | ||
| const char * | filename, | ||
| bool | restore_coords = false |
| ) | [private] |
Write the tag to the vertices, then save to the specified file If restore_coords is true, coords are restored to their initial state after file is written
Definition at line 504 of file DeformMeshRemap.cpp.
References ErrorCode, MB_CHK_ERR, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_DOUBLE, mbImpl, moab::Interface::tag_delete(), moab::Interface::tag_get_handle(), moab::Interface::write_file(), and write_to_coords().
Referenced by deform_master().
Tag tmp_tag = 0;
ErrorCode rval;
if( restore_coords ) rval = mbImpl->tag_get_handle( "", 3, MB_TYPE_DOUBLE, tmp_tag, MB_TAG_CREAT | MB_TAG_DENSE );
rval = write_to_coords( ents, tagh, tmp_tag );MB_CHK_ERR( rval );
rval = mbImpl->write_file( filename, NULL, NULL, &seth, 1 );MB_CHK_ERR( rval );
rval = write_to_coords( ents, tmp_tag );MB_CHK_ERR( rval );
rval = mbImpl->tag_delete( tmp_tag );MB_CHK_ERR( rval );
return rval;
| ErrorCode DeformMeshRemap::write_to_coords | ( | Range & | elems, |
| Tag | tagh, | ||
| Tag | tmp_tag = 0 |
| ) | [private] |
Write the input tag to the coordinates for the vertices in the input elems If non-zero tmp_tag is input, save coords to tmp_tag before over-writing with tag value
Definition at line 525 of file DeformMeshRemap.cpp.
References ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_coords(), MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, moab::Interface::set_coords(), moab::Range::size(), moab::Interface::tag_get_data(), moab::Interface::tag_set_data(), and smoab::UNION.
Referenced by write_and_save().
// Write the tag to coordinates
Range verts;
ErrorCode rval = mbImpl->get_adjacencies( elems, 0, false, verts, Interface::UNION );MB_CHK_SET_ERR( rval, "Failed to get adj vertices" );
vector< double > coords( 3 * verts.size() );
if( tmp_tag )
// Save the coords to tmp_tag first
rval = mbImpl->get_coords( verts, &coords[0] );MB_CHK_SET_ERR( rval, "Failed to get tmp copy of coords" );
rval = mbImpl->tag_set_data( tmp_tag, verts, &coords[0] );MB_CHK_SET_ERR( rval, "Failed to save tmp copy of coords" );
rval = mbImpl->tag_get_data( tagh, verts, &coords[0] );MB_CHK_SET_ERR( rval, "Failed to get tag data" );
rval = mbImpl->set_coords( verts, &coords[0] );MB_CHK_SET_ERR( rval, "Failed to set coordinates" );
return MB_SUCCESS;
| Tag DeformMeshRemap::x_new | ( | ) | const [inline] |
| string DeformMeshRemap::x_new_name | ( | ) | const [inline] |
| void DeformMeshRemap::x_new_name | ( | const string & | name | ) | [inline] |
| string DeformMeshRemap::xdisp_name | ( | int | idx = 0 | ) | [inline] |
Definition at line 256 of file DeformMeshRemap.cpp.
return xDispNames[idx];
| void DeformMeshRemap::xdisp_name | ( | const string & | nm, |
| int | idx = 0 |
Definition at line 261 of file DeformMeshRemap.cpp.
xDispNames[idx] = nm;
Range DeformMeshRemap::fluidElems[2] [private] |
Definition at line 161 of file DeformMeshRemap.cpp.
Referenced by deform_master(), find_other_sets(), and read_file().
set< int > DeformMeshRemap::fluidSetNos[2] [private] |
Definition at line 149 of file DeformMeshRemap.cpp.
Referenced by read_file().
Range DeformMeshRemap::fluidSets[2] [private] |
Definition at line 158 of file DeformMeshRemap.cpp.
Referenced by find_other_sets(), and read_file().
string DeformMeshRemap::masterFileName [private] |
Definition at line 164 of file DeformMeshRemap.cpp.
EntityHandle DeformMeshRemap::masterSet [private] |
Definition at line 155 of file DeformMeshRemap.cpp.
Interface* DeformMeshRemap::mbImpl [private] |
moab interface
Definition at line 141 of file DeformMeshRemap.cpp.
Referenced by deform_master(), find_other_sets(), read_file(), write_and_save(), and write_to_coords().
string DeformMeshRemap::slaveFileName [private] |
EntityHandle DeformMeshRemap::slaveSet [private] |
Range DeformMeshRemap::solidElems[2] [private] |
set< int > DeformMeshRemap::solidSetNos[2] [private] |
Definition at line 152 of file DeformMeshRemap.cpp.
Range DeformMeshRemap::solidSets[2] [private] |
Tag DeformMeshRemap::xDisp[3] [private] |
Definition at line 167 of file DeformMeshRemap.cpp.
Referenced by deform_master(), and DeformMeshRemap().
string DeformMeshRemap::xDispNames[3] [private] |
Definition at line 173 of file DeformMeshRemap.cpp.
Tag DeformMeshRemap::xNew [private] |
Definition at line 170 of file DeformMeshRemap.cpp.
string DeformMeshRemap::xNewName [private] |
Definition at line 176 of file DeformMeshRemap.cpp.
