MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** @class LloydSmoother.cpp \n 00002 * \brief Perform Lloyd relaxation on a mesh and its dual \n 00003 * 00004 * Briefly, Lloyd relaxation is a technique to smooth out a mesh. The centroid of each cell is 00005 * computed from its vertex positions, then vertices are placed at the average of their connected 00006 * cells' centroids, and the process iterates until convergence. 00007 * 00008 * In the parallel algorithm, an extra ghost layer of cells is exchanged. This allows us to compute 00009 * the centroids for boundary cells on each processor where they appear; this eliminates the need 00010 * for one round of data exchange (for those centroids) between processors. New vertex positions 00011 * must be sent from owning processors to processors sharing those vertices. Convergence is 00012 * measured as the maximum distance moved by any vertex. 00013 * 00014 */ 00015 00016 #ifndef LLOYDSMOOTHER_HPP 00017 #define LLOYDSMOOTHER_HPP 00018 00019 #include "moab/Interface.hpp" 00020 00021 namespace moab 00022 { 00023 00024 class ParallelComm; 00025 00026 class LloydSmoother 00027 { 00028 public: 00029 /* \brief Constructor 00030 * Bare constructor, data input to this class through methods. 00031 * \param impl The MOAB instance for this smoother 00032 */ 00033 LloydSmoother( Interface* impl ); 00034 00035 /* \brief Constructor 00036 * Convenience constructor, data input directly 00037 * \param impl The MOAB instance for this smoother 00038 * \param pc The ParallelComm instance by which this mesh is parallel 00039 * \param elems The mesh to be smoothed 00040 * \param cds_tag If specified, this tag is used to get/set coordinates, rather than 00041 * true vertex coordinates 00042 * \param fixed_tag The tag marking which vertices are fixed 00043 * \param abs_tol Absolute tolerance measuring convergence 00044 * \param rel_tol Relative tolerance measuring convergence 00045 */ 00046 LloydSmoother( Interface* impl, 00047 ParallelComm* pc, 00048 Range& elems, 00049 Tag cds_tag = 0, 00050 Tag fixed_tag = 0, 00051 double abs_tol = -1.0, 00052 double rel_tol = 1.0e-6 ); 00053 00054 /* \brief Destructor 00055 */ 00056 ~LloydSmoother(); 00057 00058 /* \brief perform smoothing operation 00059 */ 00060 ErrorCode perform_smooth(); 00061 00062 /* \brief get instance 00063 */ 00064 Interface* mb_impl() 00065 { 00066 return mbImpl; 00067 } 00068 00069 /* \brief get/set ParallelComm 00070 */ 00071 ParallelComm* pcomm() 00072 { 00073 return myPcomm; 00074 } 00075 00076 /* \brief get/set ParallelComm 00077 */ 00078 void pcomm( ParallelComm* pc ) 00079 { 00080 myPcomm = pc; 00081 } 00082 00083 /* \brief get/set elements 00084 */ 00085 Range& elems() 00086 { 00087 return myElems; 00088 } 00089 00090 /* \brief get/set elements 00091 */ 00092 const Range& elems() const 00093 { 00094 return myElems; 00095 } 00096 00097 /* \brief get/set fixed tag 00098 */ 00099 Tag fixed_tag() 00100 { 00101 return fixedTag; 00102 } 00103 00104 /* \brief get/set fixed tag 00105 */ 00106 void fixed_tag( Tag fixed ) 00107 { 00108 fixedTag = fixed; 00109 } 00110 00111 /* \brief get/set coords tag 00112 */ 00113 Tag coords_tag() 00114 { 00115 return coordsTag; 00116 } 00117 00118 /* \brief get/set coords tag 00119 */ 00120 void coords_tag( Tag coords ) 00121 { 00122 coordsTag = coords; 00123 } 00124 00125 /* \brief get/set tolerance 00126 */ 00127 double abs_tol() 00128 { 00129 return absTol; 00130 } 00131 00132 /* \brief get/set tolerance 00133 */ 00134 void abs_tol( double tol ) 00135 { 00136 absTol = tol; 00137 } 00138 00139 /* \brief get/set tolerance 00140 */ 00141 double rel_tol() 00142 { 00143 return relTol; 00144 } 00145 00146 /* \brief get/set tolerance 00147 */ 00148 void rel_tol( double tol ) 00149 { 00150 relTol = tol; 00151 } 00152 00153 /* \brief get/set numIts 00154 */ 00155 int num_its() 00156 { 00157 return numIts; 00158 } 00159 void num_its( int num ) 00160 { 00161 numIts = num; 00162 } 00163 00164 /* \brief get/set reportIts 00165 */ 00166 int report_its() 00167 { 00168 return reportIts; 00169 } 00170 void report_its( int num ) 00171 { 00172 reportIts = num; 00173 } 00174 00175 private: 00176 //- initialize some things in certain cases 00177 ErrorCode initialize(); 00178 00179 //- MOAB instance 00180 Interface* mbImpl; 00181 00182 //- ParallelComm 00183 ParallelComm* myPcomm; 00184 00185 //- elements to smooth 00186 Range myElems; 00187 00188 //- tag for coordinates; if zero, true vertex coords are used 00189 Tag coordsTag; 00190 00191 //- tag marking which vertices are fixed, 0 = not fixed, otherwise fixed 00192 Tag fixedTag; 00193 00194 //- tolerances 00195 double absTol, relTol; 00196 00197 //- number of iterations between reporting 00198 int reportIts; 00199 00200 //- number of iterations taken during smooth 00201 int numIts; 00202 00203 //- keep track of whether I created the fixed tag 00204 bool iCreatedTag; 00205 }; 00206 00207 } // namespace moab 00208 00209 #endif
