MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /**\file SpatialLocator.hpp 00002 * \class moab::SpatialLocator 00003 * \brief Tool to facilitate spatial location of a point in a mesh 00004 * 00005 * SpatialLocator facilitates searching for points in or performing ray traces on collections of 00006 * mesh entities in 2D or 3D. This searching is facilitated by a tree-based decomposition of the 00007 * mesh. Various types of trees are implemented in MOAB and can be used by this tool, but by 00008 * default it uses AdaptiveKDTree (see child classes of Tree for which others are available). 00009 * Parallel and serial searching are both supported. 00010 * 00011 * SpatialLocator can either cache the search results for points or pass back this information in 00012 * arguments. Cached information is kept in locTable, indexed in the same order as search points 00013 * passed in. This information consists of the entity handle containing the point and the 00014 * parametric coordinates inside that element. Information about the points searched, e.g. the 00015 * entities from which those points are derived, can be stored in the calling application if 00016 * desired. 00017 * 00018 * In parallel, there is a separation between the proc deciding which points to search for (the 00019 * "target" proc), and the proc locating the point in its local mesh (the "source" proc). On the 00020 * source proc, location information is cached in locTable, as in the serial case. By default, this 00021 * location information (handle and parametric coords) is not returned to the target proc, since it 00022 * would be of no use there. Instead, the rank of the source proc locating the point, and the index 00023 * of that location info in the source proc's locTable, is returned; this information is stored on 00024 * the target proc in this class's parLocTable variable. Again, information about the points 00025 * searched should be stored in the calling application, if desired. 00026 * 00027 * This class uses the ElemEvaluator class for specification and evaluation of basis functions (used 00028 * for computing parametric coords within an entity). See documentation and examples for that class 00029 * for usage information. 00030 * 00031 */ 00032 00033 #ifndef MOAB_SPATIALLOCATOR_HPP 00034 #define MOAB_SPATIALLOCATOR_HPP 00035 00036 #include "moab/Types.hpp" 00037 #include "moab/Tree.hpp" 00038 #include "moab/Range.hpp" 00039 #include "moab/TupleList.hpp" 00040 #include "moab/BoundBox.hpp" 00041 #include "moab/SpatialLocatorTimes.hpp" 00042 #include "moab/CpuTimer.hpp" 00043 00044 #include <string> 00045 #include <vector> 00046 #include <map> 00047 #include <cmath> 00048 00049 namespace moab 00050 { 00051 00052 class Interface; 00053 class ElemEvaluator; 00054 class ParallelComm; 00055 00056 class SpatialLocator 00057 { 00058 public: 00059 /* constructor */ 00060 SpatialLocator( Interface* impl, Range& elems, Tree* tree = NULL, ElemEvaluator* eval = NULL ); 00061 00062 /* destructor */ 00063 virtual ~SpatialLocator(); 00064 00065 /* add elements to be searched */ 00066 ErrorCode add_elems( Range& elems ); 00067 00068 /* get bounding box of this locator */ 00069 BoundBox& local_box() 00070 { 00071 return localBox; 00072 } 00073 00074 /* get bounding box of this locator */ 00075 const BoundBox& local_box() const 00076 { 00077 return localBox; 00078 } 00079 00080 /* locate a set of vertices, Range variant */ 00081 ErrorCode locate_points( Range& vertices, 00082 EntityHandle* ents, 00083 double* params, 00084 int* is_inside = NULL, 00085 const double rel_iter_tol = 1.0e-10, 00086 const double abs_iter_tol = 1.0e-10, 00087 const double inside_tol = 1.0e-6 ); 00088 00089 /* locate a set of points */ 00090 ErrorCode locate_points( const double* pos, 00091 int num_points, 00092 EntityHandle* ents, 00093 double* params, 00094 int* is_inside = NULL, 00095 const double rel_iter_tol = 1.0e-10, 00096 const double abs_iter_tol = 1.0e-10, 00097 const double inside_tol = 1.0e-6 ); 00098 00099 /* locate a set of vertices or entity centroids, storing results on TupleList in this class 00100 * Locate a set of vertices or entity centroids, storing the detailed results in member 00101 * variable (TupleList) locTable (see comments on locTable for structure of that tuple). 00102 */ 00103 ErrorCode locate_points( Range& ents, 00104 const double rel_iter_tol = 1.0e-10, 00105 const double abs_iter_tol = 1.0e-10, 00106 const double inside_tol = 1.0e-6 ); 00107 00108 /* locate a set of points, storing results on TupleList in this class 00109 * Locate a set of points, storing the detailed results in member variable (TupleList) locTable 00110 * (see comments on locTable for structure of that tuple). 00111 */ 00112 ErrorCode locate_points( const double* pos, 00113 int num_points, 00114 const double rel_iter_tol = 1.0e-10, 00115 const double abs_iter_tol = 1.0e-10, 00116 const double inside_tol = 1.0e-6 ); 00117 00118 /* Count the number of located points in locTable 00119 * Return the number of entries in locTable that have non-zero entity handles, which 00120 * represents the number of points in targetEnts that were inside one element in sourceEnts 00121 * 00122 */ 00123 int local_num_located(); 00124 00125 /* Count the number of located points in parLocTable 00126 * Return the number of entries in parLocTable that have a non-negative index in on a remote 00127 * proc in parLocTable, which gives the number of points located in at least one element in a 00128 * remote proc's sourceEnts. 00129 */ 00130 int remote_num_located(); 00131 00132 #ifdef MOAB_HAVE_MPI 00133 /* locate a set of vertices or entity centroids, storing results on TupleList in this class 00134 * Locate a set of vertices or entity centroids, storing the detailed results in member 00135 * variables (TupleList) locTable and parLocTable (see comments on locTable and parLocTable for 00136 * structure of those tuples). 00137 */ 00138 ErrorCode par_locate_points( ParallelComm* pc, 00139 Range& vertices, 00140 const double rel_iter_tol = 1.0e-10, 00141 const double abs_iter_tol = 1.0e-10, 00142 const double inside_tol = 1.0e-6 ); 00143 00144 /* locate a set of points, storing results on TupleList in this class 00145 * Locate a set of points, storing the detailed results in member 00146 * variables (TupleList) locTable and parLocTable (see comments on locTable and parLocTable for 00147 * structure of those tuples). 00148 */ 00149 ErrorCode par_locate_points( ParallelComm* pc, 00150 const double* pos, 00151 int num_points, 00152 const double rel_iter_tol = 1.0e-10, 00153 const double abs_iter_tol = 1.0e-10, 00154 const double inside_tol = 1.0e-6 ); 00155 #endif 00156 00157 /** \brief Return the MOAB interface associated with this locator 00158 */ 00159 Interface* moab() 00160 { 00161 return mbImpl; 00162 } 00163 00164 /* locate a point */ 00165 ErrorCode locate_point( const double* pos, 00166 EntityHandle& ent, 00167 double* params, 00168 int* is_inside = NULL, 00169 const double rel_iter_tol = 1.0e-10, 00170 const double abs_iter_tol = 1.0e-10, 00171 const double inside_tol = 1.0e-6 ); 00172 00173 /* return the tree */ 00174 Tree* get_tree() 00175 { 00176 return myTree; 00177 } 00178 00179 /* get the locTable 00180 */ 00181 TupleList& loc_table() 00182 { 00183 return locTable; 00184 } 00185 00186 /* get the locTable 00187 */ 00188 const TupleList& loc_table() const 00189 { 00190 return locTable; 00191 } 00192 00193 /* get the parLocTable 00194 */ 00195 TupleList& par_loc_table() 00196 { 00197 return parLocTable; 00198 } 00199 00200 /* get the parLocTable 00201 */ 00202 const TupleList& par_loc_table() const 00203 { 00204 return parLocTable; 00205 } 00206 00207 /* get elemEval */ 00208 ElemEvaluator* elem_eval() 00209 { 00210 return elemEval; 00211 } 00212 00213 /* get elemEval */ 00214 const ElemEvaluator* elem_eval() const 00215 { 00216 return elemEval; 00217 } 00218 00219 /* set elemEval */ 00220 void elem_eval( ElemEvaluator* eval ) 00221 { 00222 elemEval = eval; 00223 if( myTree ) myTree->set_eval( eval ); 00224 } 00225 00226 /** \brief Get spatial locator times object */ 00227 SpatialLocatorTimes& sl_times() 00228 { 00229 return myTimes; 00230 } 00231 00232 /** \brief Get spatial locator times object */ 00233 const SpatialLocatorTimes& sl_times() const 00234 { 00235 return myTimes; 00236 } 00237 00238 private: 00239 #ifdef MOAB_HAVE_MPI 00240 /* MPI_ReduceAll source mesh bounding boxes to get global source mesh bounding box 00241 */ 00242 ErrorCode initialize_intermediate_partition( ParallelComm* pc ); 00243 00244 /* for a given point in space, compute its ijk location in the intermediate decomposition; 00245 * tolerance is used only to test proximity to global box extent, not for local box test 00246 */ 00247 inline ErrorCode get_point_ijk( const CartVect& point, const double abs_iter_tol, int* ijk ) const; 00248 00249 #if 0 00250 /* given an ijk location in the intermediate partition, return the proc rank for that location 00251 */ 00252 inline int proc_from_ijk(const int *ijk) const; 00253 #endif 00254 00255 /* given a point in space, return the proc responsible for that point from the intermediate 00256 * decomp; no tolerances applied here, so first proc in lexicographic ijk ordering is returned 00257 */ 00258 inline int proc_from_point( const double* pos, const double abs_iter_tol ) const; 00259 00260 /* register my source mesh with intermediate decomposition procs 00261 */ 00262 ErrorCode register_src_with_intermediate_procs( ParallelComm* pc, double abs_iter_tol, TupleList& TLreg_o ); 00263 00264 #endif 00265 00266 /** Create a tree 00267 * Tree type depends on what's in myElems: if empty or all vertices, creates a kdtree, 00268 * otherwise creates a BVHTree. 00269 */ 00270 void create_tree(); 00271 00272 /* MOAB instance */ 00273 Interface* mbImpl; 00274 00275 /* elements being located */ 00276 Range myElems; 00277 00278 /* dimension of entities in locator */ 00279 int myDim; 00280 00281 /* tree used for location */ 00282 Tree* myTree; 00283 00284 /* element evaluator */ 00285 ElemEvaluator* elemEval; 00286 00287 /* whether I created the tree or not (determines whether to delete it or not on destruction) */ 00288 bool iCreatedTree; 00289 00290 /* \brief local locations table 00291 * This table stores detailed local location data results from locate_points, that is, location 00292 * data for points located on the local mesh. Data is stored in a TupleList, where each tuple 00293 * consists of (p_i, hs_ul, r[3]_d), where p_i = (int) proc from which request for this point 00294 * was made (0 if serial) hs_ul = (unsigned long) source entity containing the point r[3]_d = 00295 * (double) parametric coordinates of the point in hs 00296 */ 00297 TupleList locTable; 00298 00299 /* \brief parallel locations table 00300 * This table stores information about points located on a local or remote processor. For 00301 * points located on this processor's local mesh, detailed location data is stored in locTable. 00302 * For points located on remote processors, more communication is required to retrieve specific 00303 * location data (usually that information isn't useful on this processor). 00304 * 00305 * The tuple structure of this TupleList is (p_i, ri_i), where: 00306 * p_i = (int) processor rank containing this point 00307 * ri_i = (int) index into locTable on remote proc containing this point's location 00308 * information The indexing of parLocTable corresponds to that of the points/entities passed in. 00309 */ 00310 TupleList parLocTable; 00311 00312 /* \brief Local bounding box, duplicated from tree 00313 */ 00314 BoundBox localBox; 00315 00316 /* \brief Global bounding box, used in parallel spatial location 00317 */ 00318 BoundBox globalBox; 00319 00320 /* \brief Regional delta xyz, used in parallel spatial location 00321 */ 00322 CartVect regDeltaXYZ; 00323 00324 /* \brief Number of regions in each of 3 directions 00325 */ 00326 int regNums[3]; 00327 00328 /* \brief Map from source processor to bounding box of that proc's source mesh 00329 * 00330 */ 00331 std::map< int, BoundBox > srcProcBoxes; 00332 00333 /* \brief Timing object for spatial location 00334 */ 00335 SpatialLocatorTimes myTimes; 00336 00337 /* \brief Timer object to manage overloaded search functions 00338 */ 00339 CpuTimer myTimer; 00340 00341 /* \brief Flag to manage initialization of timer for overloaded search functions 00342 */ 00343 bool timerInitialized; 00344 }; 00345 00346 inline SpatialLocator::~SpatialLocator() 00347 { 00348 if( iCreatedTree && myTree ) delete myTree; 00349 } 00350 00351 inline ErrorCode SpatialLocator::locate_point( const double* pos, 00352 EntityHandle& ent, 00353 double* params, 00354 int* is_inside, 00355 const double rel_iter_tol, 00356 const double abs_iter_tol, 00357 const double inside_tol ) 00358 { 00359 return locate_points( pos, 1, &ent, params, is_inside, rel_iter_tol, abs_iter_tol, inside_tol ); 00360 } 00361 00362 #ifdef MOAB_HAVE_MPI 00363 inline ErrorCode SpatialLocator::get_point_ijk( const CartVect& point, const double abs_iter_tol, int* ijk ) const 00364 { 00365 for( int i = 0; i < 3; i++ ) 00366 { 00367 if( point[i] < globalBox.bMin[i] - abs_iter_tol || point[i] > globalBox.bMax[i] + abs_iter_tol ) 00368 ijk[i] = -1; 00369 else 00370 { 00371 ijk[i] = point[i] - globalBox.bMin[i] / regDeltaXYZ[i]; 00372 if( ijk[i] >= regNums[i] && point[i] <= globalBox.bMax[i] + abs_iter_tol ) ijk[i] = regNums[i] - 1; 00373 } 00374 } 00375 00376 return ( ijk[0] >= 0 && ijk[1] >= 0 && ijk[2] >= 0 ? MB_SUCCESS : MB_FAILURE ); 00377 ; 00378 } 00379 00380 #if 0 00381 inline int SpatialLocator::proc_from_ijk(const int *ijk) const 00382 { 00383 return ijk[2] * regNums[0]*regNums[1] + ijk[1] * regNums[0] + ijk[0]; 00384 } 00385 #endif 00386 00387 inline int SpatialLocator::proc_from_point( const double* pos, const double abs_iter_tol ) const 00388 { 00389 int ijk[3]; 00390 ErrorCode rval = get_point_ijk( CartVect( pos ), abs_iter_tol, ijk ); 00391 if( MB_SUCCESS != rval ) return -1; 00392 00393 return ijk[2] * regNums[0] * regNums[1] + ijk[1] * regNums[0] + ijk[0]; 00394 } 00395 #endif 00396 00397 } // namespace moab 00398 00399 #endif
