MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "moab/Core.hpp" 00002 #include "TestUtil.hpp" 00003 #include "moab/BSPTree.hpp" 00004 #include "moab/CartVect.hpp" 00005 #include "moab/BSPTreePoly.hpp" 00006 #include "moab/Range.hpp" 00007 #include <algorithm> 00008 00009 using namespace moab; 00010 00011 void test_set_plane(); 00012 void test_iterator(); 00013 void test_box_iterator(); 00014 void test_tree_create(); 00015 void test_box_tree_create(); 00016 void test_leaf_containing_point_bounded_tree(); 00017 void test_leaf_containing_point_unbounded_tree(); 00018 void test_merge_leaf(); 00019 void test_box_iter_neighbors(); 00020 void test_leaf_sibling(); 00021 void test_leaf_volume( bool box ); 00022 void test_leaf_volume_box() 00023 { 00024 test_leaf_volume( true ); 00025 } 00026 void test_leaf_volume_gen() 00027 { 00028 test_leaf_volume( false ); 00029 } 00030 void test_leaf_splits_intersects(); 00031 void test_leaf_intersects_ray_common( bool box ); 00032 void test_box_leaf_intersects_ray() 00033 { 00034 test_leaf_intersects_ray_common( true ); 00035 } 00036 void test_gen_leaf_intersects_ray() 00037 { 00038 test_leaf_intersects_ray_common( false ); 00039 } 00040 void test_leaf_polyhedron(); 00041 00042 int main() 00043 { 00044 int failures = 0; 00045 00046 failures += RUN_TEST( test_set_plane ); 00047 failures += RUN_TEST( test_iterator ); 00048 failures += RUN_TEST( test_box_iterator ); 00049 failures += RUN_TEST( test_tree_create ); 00050 failures += RUN_TEST( test_box_tree_create ); 00051 failures += RUN_TEST( test_leaf_containing_point_bounded_tree ); 00052 failures += RUN_TEST( test_leaf_containing_point_unbounded_tree ); 00053 failures += RUN_TEST( test_merge_leaf ); 00054 failures += RUN_TEST( test_box_iter_neighbors ); 00055 failures += RUN_TEST( test_leaf_sibling ); 00056 failures += RUN_TEST( test_leaf_volume_box ); 00057 failures += RUN_TEST( test_leaf_volume_gen ); 00058 failures += RUN_TEST( test_leaf_splits_intersects ); 00059 failures += RUN_TEST( test_box_leaf_intersects_ray ); 00060 failures += RUN_TEST( test_gen_leaf_intersects_ray ); 00061 failures += RUN_TEST( test_leaf_polyhedron ); 00062 00063 return failures; 00064 } 00065 00066 // Make CHECK_EQUAL macro work for planes 00067 void check_equal( const BSPTree::Plane& p1, 00068 const BSPTree::Plane& p2, 00069 const char* exp1, 00070 const char* exp2, 00071 int line, 00072 const char* file ) 00073 { 00074 if( fabs( p1.norm[0] - p2.norm[0] ) > 1e-6 || fabs( p1.norm[1] - p2.norm[1] ) > 1e-6 || 00075 fabs( p1.norm[2] - p2.norm[2] ) > 1e-6 || fabs( p1.coeff - p2.coeff ) > 1e-6 ) 00076 { 00077 printf( "Equality Test Failed: %s == %s\n", exp1, exp2 ); 00078 printf( " at line %d of '%s'\n", line, file ); 00079 printf( " Expected: %f x + %f y + %f z + %f = 0\n", p1.norm[0], p1.norm[1], p1.norm[2], p1.coeff ); 00080 printf( " Actual : %f x + %f y + %f z + %f = 0\n", p2.norm[0], p2.norm[1], p2.norm[2], p2.coeff ); 00081 printf( "\n" ); 00082 FLAG_ERROR; 00083 } 00084 } 00085 00086 void test_set_plane() 00087 { 00088 BSPTree::Plane p; 00089 const double points[3][3] = { { 1, 0, 0 }, { 0, 1, 0 }, { 0, 0, 1 } }; 00090 p.set( points[0], points[1], points[2] ); 00091 CHECK_REAL_EQUAL( 0.0, p.distance( points[0] ), 1e-10 ); 00092 CHECK_REAL_EQUAL( 0.0, p.distance( points[1] ), 1e-10 ); 00093 CHECK_REAL_EQUAL( 0.0, p.distance( points[2] ), 1e-10 ); 00094 } 00095 00096 void test_iterator() 00097 { 00098 Core moab; 00099 BSPTree tool( &moab ); 00100 ErrorCode rval; 00101 EntityHandle root; 00102 BSPTreeIter iter; 00103 00104 // create a depth-1 tree 00105 rval = tool.create_tree( root );CHECK_ERR( rval ); 00106 rval = tool.get_tree_iterator( root, iter );CHECK_ERR( rval ); 00107 00108 // check initial state of iterator 00109 CHECK_EQUAL( &tool, iter.tool() ); 00110 CHECK_EQUAL( root, iter.handle() ); 00111 CHECK_EQUAL( 1u, iter.depth() ); 00112 00113 // should fail if at root 00114 BSPTree::Plane p; 00115 rval = iter.get_parent_split_plane( p ); 00116 CHECK_EQUAL( MB_ENTITY_NOT_FOUND, rval ); 00117 00118 // check that step past end returns correct value 00119 rval = iter.step(); 00120 CHECK_EQUAL( MB_ENTITY_NOT_FOUND, rval ); 00121 00122 // reset iterator 00123 rval = tool.get_tree_iterator( root, iter );CHECK_ERR( rval ); 00124 00125 // check that step past start returns correct value 00126 rval = iter.back(); 00127 CHECK_EQUAL( MB_ENTITY_NOT_FOUND, rval ); 00128 00129 // reset iterator 00130 rval = tool.get_tree_iterator( root, iter );CHECK_ERR( rval ); 00131 00132 // insert a single split plane 00133 rval = tool.split_leaf( iter, BSPTree::Plane( 2, 0, 0, 0 ) );CHECK_ERR( rval ); 00134 00135 // check initial location 00136 CHECK_EQUAL( 2u, iter.depth() ); 00137 CHECK( iter.handle() != root ); 00138 00139 // create new iterators at left and right ends 00140 BSPTreeIter left, right; 00141 rval = tool.get_tree_iterator( root, left );CHECK_ERR( rval ); 00142 rval = tool.get_tree_end_iterator( root, right );CHECK_ERR( rval ); 00143 00144 // compare post-split iterator to left 00145 CHECK_EQUAL( left.depth(), iter.depth() ); 00146 CHECK_EQUAL( left.handle(), iter.handle() ); 00147 00148 // step to other leaf 00149 rval = iter.step();CHECK_ERR( rval ); 00150 00151 // check location 00152 CHECK_EQUAL( 2u, iter.depth() ); 00153 CHECK( iter.handle() != root ); 00154 00155 // compare stepped iterator to right 00156 CHECK_EQUAL( right.depth(), iter.depth() ); 00157 CHECK_EQUAL( right.handle(), iter.handle() ); 00158 00159 // step to back to first leaf 00160 rval = iter.back();CHECK_ERR( rval ); 00161 00162 // compare to left 00163 CHECK_EQUAL( left.depth(), iter.depth() ); 00164 CHECK_EQUAL( left.handle(), iter.handle() ); 00165 00166 // check plane 00167 // should have unit normal 00168 left.get_parent_split_plane( p ); 00169 CHECK_EQUAL( BSPTree::Plane( 1, 0, 0, 0 ), p ); 00170 p.norm[0] = 11; 00171 right.get_parent_split_plane( p ); 00172 CHECK_EQUAL( BSPTree::Plane( 1, 0, 0, 0 ), p ); 00173 00174 // check step past ends 00175 rval = left.back(); 00176 CHECK_EQUAL( MB_ENTITY_NOT_FOUND, rval ); 00177 rval = right.step(); 00178 CHECK_EQUAL( MB_ENTITY_NOT_FOUND, rval ); 00179 } 00180 00181 bool compare_hexes( const double expected[8][3], const double actual[8][3], double epsilon ) 00182 { 00183 // for each of three possible rotations 00184 const int rotation_maps[3][8] = { 00185 { 0, 1, 2, 3, 4, 5, 6, 7 }, { 3, 2, 6, 7, 0, 1, 5, 4 }, { 7, 3, 2, 6, 4, 0, 1, 5 } }; 00186 for( int i = 0; i < 3; ++i ) 00187 { 00188 // compare for rotationts about axis from face 4 to 5 00189 for( int j = 0; j < 4; ++j ) 00190 { 00191 bool match = true; 00192 // for each face vertex 00193 for( int k = 0; k < 4 && match; ++k ) 00194 { 00195 // for each coordinate 00196 for( int d = 0; d < 3; ++d ) 00197 { 00198 if( fabs( expected[( j + k ) % 4][d] - actual[rotation_maps[i][k]][d] ) > epsilon || 00199 fabs( expected[( j + k ) % 4 + 4][d] - actual[rotation_maps[i][k + 4]][d] ) > epsilon ) 00200 { 00201 match = false; 00202 break; 00203 } 00204 } 00205 } 00206 00207 if( match ) return true; 00208 } 00209 } 00210 00211 printf( "Hex vertex copmarison failed.\n" ); 00212 printf( " Exected Actual\n" ); 00213 for( int v = 0; v < 8; ++v ) 00214 { 00215 printf( "% 9f % 9f % 9f % 9f % 9f % 9f\n", expected[v][0], expected[v][1], expected[v][2], actual[v][0], 00216 actual[v][1], actual[v][2] ); 00217 } 00218 00219 return false; 00220 } 00221 00222 static void aabox_corners( const double min[3], const double max[3], double corners[8][3] ) 00223 { 00224 const double expt[8][3] = { { min[0], min[1], min[2] }, { max[0], min[1], min[2] }, { max[0], max[1], min[2] }, 00225 { min[0], max[1], min[2] }, { min[0], min[1], max[2] }, { max[0], min[1], max[2] }, 00226 { max[0], max[1], max[2] }, { min[0], max[1], max[2] } }; 00227 memcpy( corners, expt, sizeof( expt ) ); 00228 } 00229 00230 static void aabox_corners( double min_x, 00231 double min_y, 00232 double min_z, 00233 double max_x, 00234 double max_y, 00235 double max_z, 00236 double corners[8][3] ) 00237 { 00238 double min[] = { min_x, min_y, min_z }; 00239 double max[] = { max_x, max_y, max_z }; 00240 aabox_corners( min, max, corners ); 00241 } 00242 00243 void test_box_iterator() 00244 { 00245 Core moab; 00246 BSPTree tool( &moab ); 00247 ErrorCode rval; 00248 EntityHandle root; 00249 BSPTreeBoxIter iter; 00250 const double min[3] = { -1, -2, -3 }; 00251 const double max[3] = { 3, 2, 1 }; 00252 00253 // create a depth-1 tree 00254 rval = tool.create_tree( min, max, root );CHECK_ERR( rval ); 00255 rval = tool.get_tree_iterator( root, iter );CHECK_ERR( rval ); 00256 00257 // check initial state of iterator 00258 CHECK_EQUAL( &tool, iter.tool() ); 00259 CHECK_EQUAL( root, iter.handle() ); 00260 CHECK_EQUAL( 1u, iter.depth() ); 00261 00262 // check initial corner values 00263 double corners[8][3], expt[8][3]; 00264 aabox_corners( min, max, expt ); 00265 rval = iter.get_box_corners( corners );CHECK_ERR( rval ); 00266 CHECK( compare_hexes( expt, corners, 1e-6 ) ); 00267 00268 // should fail if at root 00269 BSPTree::Plane p; 00270 rval = iter.get_parent_split_plane( p ); 00271 CHECK_EQUAL( MB_ENTITY_NOT_FOUND, rval ); 00272 00273 // check that step past end returns correct value 00274 rval = iter.step(); 00275 CHECK_EQUAL( MB_ENTITY_NOT_FOUND, rval ); 00276 00277 // reset iterator 00278 rval = tool.get_tree_iterator( root, iter );CHECK_ERR( rval ); 00279 00280 // check that step past start returns correct value 00281 rval = iter.back(); 00282 CHECK_EQUAL( MB_ENTITY_NOT_FOUND, rval ); 00283 00284 // reset iterator 00285 rval = tool.get_tree_iterator( root, iter );CHECK_ERR( rval ); 00286 00287 // insert a single split plane 00288 rval = tool.split_leaf( iter, BSPTree::Plane( 2, 0, 0, 0 ) );CHECK_ERR( rval ); 00289 00290 // check initial location 00291 CHECK_EQUAL( 2u, iter.depth() ); 00292 CHECK( iter.handle() != root ); 00293 00294 // create new iterators at left and right ends 00295 BSPTreeIter left, right; 00296 rval = tool.get_tree_iterator( root, left );CHECK_ERR( rval ); 00297 rval = tool.get_tree_end_iterator( root, right );CHECK_ERR( rval ); 00298 00299 // compare post-split iterator to left 00300 CHECK_EQUAL( left.depth(), iter.depth() ); 00301 CHECK_EQUAL( left.handle(), iter.handle() ); 00302 00303 // check box 00304 aabox_corners( min, max, expt ); 00305 for( int i = 0; i < 8; ++i ) 00306 if( expt[i][0] > 0 ) expt[i][0] = 0; 00307 rval = iter.get_box_corners( corners );CHECK_ERR( rval ); 00308 CHECK( compare_hexes( expt, corners, 1e-6 ) ); 00309 00310 // step to other leaf 00311 rval = iter.step();CHECK_ERR( rval ); 00312 00313 // check location 00314 CHECK_EQUAL( 2u, iter.depth() ); 00315 CHECK( iter.handle() != root ); 00316 00317 // compare stepped iterator to right 00318 CHECK_EQUAL( right.depth(), iter.depth() ); 00319 CHECK_EQUAL( right.handle(), iter.handle() ); 00320 00321 // check box 00322 aabox_corners( min, max, expt ); 00323 for( int i = 0; i < 8; ++i ) 00324 if( expt[i][0] < 0 ) expt[i][0] = 0; 00325 rval = iter.get_box_corners( corners );CHECK_ERR( rval ); 00326 CHECK( compare_hexes( expt, corners, 1e-6 ) ); 00327 00328 // step to back to first leaf 00329 rval = iter.back();CHECK_ERR( rval ); 00330 00331 // compare to left 00332 CHECK_EQUAL( left.depth(), iter.depth() ); 00333 CHECK_EQUAL( left.handle(), iter.handle() ); 00334 00335 // check box 00336 aabox_corners( min, max, expt ); 00337 for( int i = 0; i < 8; ++i ) 00338 if( expt[i][0] > 0 ) expt[i][0] = 0; 00339 rval = iter.get_box_corners( corners );CHECK_ERR( rval ); 00340 CHECK( compare_hexes( expt, corners, 1e-6 ) ); 00341 00342 // check plane 00343 // should have unit normal 00344 left.get_parent_split_plane( p ); 00345 CHECK_EQUAL( BSPTree::Plane( 1, 0, 0, 0 ), p ); 00346 p.norm[0] = 11; 00347 right.get_parent_split_plane( p ); 00348 CHECK_EQUAL( BSPTree::Plane( 1, 0, 0, 0 ), p ); 00349 00350 // check step past ends 00351 rval = left.back(); 00352 CHECK_EQUAL( MB_ENTITY_NOT_FOUND, rval ); 00353 rval = right.step(); 00354 CHECK_EQUAL( MB_ENTITY_NOT_FOUND, rval ); 00355 } 00356 00357 void test_tree_create() 00358 { 00359 Core moab; 00360 BSPTree tool( &moab ); 00361 ErrorCode rval; 00362 EntityHandle root; 00363 BSPTreeIter iter; 00364 BSPTree::Plane p; 00365 00366 // create a depth-1 tree 00367 rval = tool.create_tree( root );CHECK_ERR( rval ); 00368 rval = tool.get_tree_iterator( root, iter );CHECK_ERR( rval ); 00369 00370 // check initial state of iterator 00371 CHECK_EQUAL( &tool, iter.tool() ); 00372 CHECK_EQUAL( root, iter.handle() ); 00373 CHECK_EQUAL( 1u, iter.depth() ); 00374 00375 // split with z=0 00376 rval = tool.split_leaf( iter, BSPTree::Plane( 0, 0, 0.5, 0 ) );CHECK_ERR( rval ); 00377 CHECK_EQUAL( 2u, iter.depth() ); 00378 00379 // check that parent split plane is correct 00380 rval = iter.get_parent_split_plane( p );CHECK_ERR( rval ); 00381 CHECK_EQUAL( BSPTree::Plane( 0, 0, 1, 0 ), p ); 00382 00383 // split lower leaf with diagonal plane 00384 rval = tool.split_leaf( iter, BSPTree::Plane( 1, 1, 0, 0 ) );CHECK_ERR( rval ); 00385 CHECK_EQUAL( 3u, iter.depth() ); 00386 00387 const double r = 0.5 * sqrt( 2.0 ); 00388 00389 // check that parent split plane is correct 00390 rval = iter.get_parent_split_plane( p );CHECK_ERR( rval ); 00391 CHECK_EQUAL( BSPTree::Plane( r, r, 0, 0 ), p ); 00392 00393 // step to upper leaf 00394 rval = iter.step();CHECK_ERR( rval ); 00395 00396 // split upper leaf with diagonal plane 00397 rval = tool.split_leaf( iter, BSPTree::Plane( -1, 1, 0, 0 ) );CHECK_ERR( rval ); 00398 CHECK_EQUAL( 4u, iter.depth() ); 00399 00400 // check that parent split plane is correct 00401 rval = iter.get_parent_split_plane( p );CHECK_ERR( rval ); 00402 CHECK_EQUAL( BSPTree::Plane( -r, r, 0, 0 ), p ); 00403 00404 // iterate over four leaves 00405 00406 // first leaf 00407 rval = tool.get_tree_iterator( root, iter );CHECK_ERR( rval ); 00408 CHECK_EQUAL( 3u, iter.depth() ); 00409 rval = iter.get_parent_split_plane( p );CHECK_ERR( rval ); 00410 CHECK_EQUAL( BSPTree::Plane( r, r, 0, 0 ), p ); 00411 00412 // second leaf 00413 rval = iter.step();CHECK_ERR( rval ); 00414 CHECK_EQUAL( 4u, iter.depth() ); 00415 rval = iter.get_parent_split_plane( p );CHECK_ERR( rval ); 00416 CHECK_EQUAL( BSPTree::Plane( -r, r, 0, 0 ), p ); 00417 00418 // third leaf 00419 rval = iter.step();CHECK_ERR( rval ); 00420 CHECK_EQUAL( 4u, iter.depth() ); 00421 rval = iter.get_parent_split_plane( p );CHECK_ERR( rval ); 00422 CHECK_EQUAL( BSPTree::Plane( -r, r, 0, 0 ), p ); 00423 00424 // fourth leaf 00425 rval = iter.step();CHECK_ERR( rval ); 00426 CHECK_EQUAL( 2u, iter.depth() ); 00427 rval = iter.get_parent_split_plane( p );CHECK_ERR( rval ); 00428 CHECK_EQUAL( BSPTree::Plane( 0, 0, 1, 0 ), p ); 00429 00430 // no more leaves 00431 rval = iter.step(); 00432 CHECK_EQUAL( MB_ENTITY_NOT_FOUND, rval ); 00433 } 00434 00435 void test_box_tree_create() 00436 { 00437 Core moab; 00438 BSPTree tool( &moab ); 00439 ErrorCode rval; 00440 EntityHandle root; 00441 BSPTreeBoxIter iter; 00442 BSPTree::Plane p; 00443 const double min[3] = { -2, -2, -2 }; 00444 const double max[3] = { 2, 2, 2 }; 00445 00446 // create a depth-1 tree 00447 rval = tool.create_tree( min, max, root );CHECK_ERR( rval ); 00448 rval = tool.get_tree_iterator( root, iter );CHECK_ERR( rval ); 00449 00450 // check initial state of iterator 00451 CHECK_EQUAL( &tool, iter.tool() ); 00452 CHECK_EQUAL( root, iter.handle() ); 00453 CHECK_EQUAL( 1u, iter.depth() ); 00454 00455 // check initial corner values 00456 double corners[8][3], expt[8][3]; 00457 aabox_corners( min, max, expt ); 00458 rval = iter.get_box_corners( corners );CHECK_ERR( rval ); 00459 CHECK( compare_hexes( expt, corners, 1e-6 ) ); 00460 00461 // Try splits that should fail because they 00462 // do not intersect the leaf at all 00463 rval = tool.split_leaf( iter, BSPTree::Plane( 0, 0, 1, 4 ) ); 00464 CHECK_EQUAL( MB_FAILURE, rval ); 00465 rval = tool.split_leaf( iter, BSPTree::Plane( 0, 0, 1, -4 ) ); 00466 CHECK_EQUAL( MB_FAILURE, rval ); 00467 rval = tool.split_leaf( iter, BSPTree::Plane( 0, 1, 0, 4 ) ); 00468 CHECK_EQUAL( MB_FAILURE, rval ); 00469 rval = tool.split_leaf( iter, BSPTree::Plane( 0, 1, 0, -4 ) ); 00470 CHECK_EQUAL( MB_FAILURE, rval ); 00471 rval = tool.split_leaf( iter, BSPTree::Plane( 1, 0, 0, 4 ) ); 00472 CHECK_EQUAL( MB_FAILURE, rval ); 00473 rval = tool.split_leaf( iter, BSPTree::Plane( 1, 0, 0, -4 ) ); 00474 CHECK_EQUAL( MB_FAILURE, rval ); 00475 rval = tool.split_leaf( iter, BSPTree::Plane( -1, -1, -1, 7 ) ); 00476 CHECK_EQUAL( MB_FAILURE, rval ); 00477 rval = tool.split_leaf( iter, BSPTree::Plane( -1, -1, -1, -7 ) ); 00478 CHECK_EQUAL( MB_FAILURE, rval ); 00479 rval = tool.split_leaf( iter, BSPTree::Plane( 1, -1, -1, 7 ) ); 00480 CHECK_EQUAL( MB_FAILURE, rval ); 00481 rval = tool.split_leaf( iter, BSPTree::Plane( 1, -1, -1, -7 ) ); 00482 CHECK_EQUAL( MB_FAILURE, rval ); 00483 rval = tool.split_leaf( iter, BSPTree::Plane( 1, 1, -1, 7 ) ); 00484 CHECK_EQUAL( MB_FAILURE, rval ); 00485 rval = tool.split_leaf( iter, BSPTree::Plane( 1, 1, -1, -7 ) ); 00486 CHECK_EQUAL( MB_FAILURE, rval ); 00487 rval = tool.split_leaf( iter, BSPTree::Plane( -1, 1, -1, 7 ) ); 00488 CHECK_EQUAL( MB_FAILURE, rval ); 00489 rval = tool.split_leaf( iter, BSPTree::Plane( -1, 1, -1, -7 ) ); 00490 CHECK_EQUAL( MB_FAILURE, rval ); 00491 00492 // Try a split that should fail because the 00493 // resulting leaf would not be a hexahedron. 00494 // Clip each corner twice using planes with opposing normals 00495 rval = tool.split_leaf( iter, BSPTree::Plane( -1, -1, -1, -4 ) ); 00496 CHECK_EQUAL( MB_FAILURE, rval ); 00497 rval = tool.split_leaf( iter, BSPTree::Plane( 1, 1, 1, 4 ) ); 00498 CHECK_EQUAL( MB_FAILURE, rval ); 00499 rval = tool.split_leaf( iter, BSPTree::Plane( 1, -1, -1, -4 ) ); 00500 CHECK_EQUAL( MB_FAILURE, rval ); 00501 rval = tool.split_leaf( iter, BSPTree::Plane( -1, 1, 1, 4 ) ); 00502 CHECK_EQUAL( MB_FAILURE, rval ); 00503 rval = tool.split_leaf( iter, BSPTree::Plane( 1, 1, -1, -4 ) ); 00504 CHECK_EQUAL( MB_FAILURE, rval ); 00505 rval = tool.split_leaf( iter, BSPTree::Plane( -1, -1, 1, 4 ) ); 00506 CHECK_EQUAL( MB_FAILURE, rval ); 00507 rval = tool.split_leaf( iter, BSPTree::Plane( -1, 1, -1, -4 ) ); 00508 CHECK_EQUAL( MB_FAILURE, rval ); 00509 rval = tool.split_leaf( iter, BSPTree::Plane( 1, -1, 1, 4 ) ); 00510 CHECK_EQUAL( MB_FAILURE, rval ); 00511 rval = tool.split_leaf( iter, BSPTree::Plane( -1, -1, 1, -4 ) ); 00512 CHECK_EQUAL( MB_FAILURE, rval ); 00513 rval = tool.split_leaf( iter, BSPTree::Plane( 1, 1, -1, 4 ) ); 00514 CHECK_EQUAL( MB_FAILURE, rval ); 00515 rval = tool.split_leaf( iter, BSPTree::Plane( 1, -1, 1, -4 ) ); 00516 CHECK_EQUAL( MB_FAILURE, rval ); 00517 rval = tool.split_leaf( iter, BSPTree::Plane( -1, 1, -1, 4 ) ); 00518 CHECK_EQUAL( MB_FAILURE, rval ); 00519 rval = tool.split_leaf( iter, BSPTree::Plane( 1, 1, 1, -4 ) ); 00520 CHECK_EQUAL( MB_FAILURE, rval ); 00521 rval = tool.split_leaf( iter, BSPTree::Plane( -1, -1, -1, 4 ) ); 00522 CHECK_EQUAL( MB_FAILURE, rval ); 00523 rval = tool.split_leaf( iter, BSPTree::Plane( -1, 1, 1, -4 ) ); 00524 CHECK_EQUAL( MB_FAILURE, rval ); 00525 rval = tool.split_leaf( iter, BSPTree::Plane( 1, -1, -1, 4 ) ); 00526 CHECK_EQUAL( MB_FAILURE, rval ); 00527 // Clip each edge 00528 rval = tool.split_leaf( iter, BSPTree::Plane( -1, -1, 0, -2 ) ); 00529 CHECK_EQUAL( MB_FAILURE, rval ); 00530 rval = tool.split_leaf( iter, BSPTree::Plane( 1, -1, 0, -2 ) ); 00531 CHECK_EQUAL( MB_FAILURE, rval ); 00532 rval = tool.split_leaf( iter, BSPTree::Plane( 1, 1, 0, -2 ) ); 00533 CHECK_EQUAL( MB_FAILURE, rval ); 00534 rval = tool.split_leaf( iter, BSPTree::Plane( -1, 1, 0, -2 ) ); 00535 CHECK_EQUAL( MB_FAILURE, rval ); 00536 rval = tool.split_leaf( iter, BSPTree::Plane( 0, -1, -1, -2 ) ); 00537 CHECK_EQUAL( MB_FAILURE, rval ); 00538 rval = tool.split_leaf( iter, BSPTree::Plane( 0, 1, -1, -2 ) ); 00539 CHECK_EQUAL( MB_FAILURE, rval ); 00540 rval = tool.split_leaf( iter, BSPTree::Plane( 0, 1, 1, -2 ) ); 00541 CHECK_EQUAL( MB_FAILURE, rval ); 00542 rval = tool.split_leaf( iter, BSPTree::Plane( 0, -1, 1, -2 ) ); 00543 CHECK_EQUAL( MB_FAILURE, rval ); 00544 rval = tool.split_leaf( iter, BSPTree::Plane( -1, 0, -1, -2 ) ); 00545 CHECK_EQUAL( MB_FAILURE, rval ); 00546 rval = tool.split_leaf( iter, BSPTree::Plane( 1, 0, -1, -2 ) ); 00547 CHECK_EQUAL( MB_FAILURE, rval ); 00548 rval = tool.split_leaf( iter, BSPTree::Plane( 1, 0, 1, -2 ) ); 00549 CHECK_EQUAL( MB_FAILURE, rval ); 00550 rval = tool.split_leaf( iter, BSPTree::Plane( -1, 0, 1, -2 ) ); 00551 CHECK_EQUAL( MB_FAILURE, rval ); 00552 00553 // verify that iterator is still valid after many failed splits 00554 CHECK_EQUAL( &tool, iter.tool() ); 00555 CHECK_EQUAL( root, iter.handle() ); 00556 CHECK_EQUAL( 1u, iter.depth() ); 00557 rval = iter.get_box_corners( corners );CHECK_ERR( rval ); 00558 CHECK( compare_hexes( expt, corners, 1e-6 ) ); 00559 00560 // split with z=0 00561 rval = tool.split_leaf( iter, BSPTree::Plane( 0, 0, 0.5, 0 ) );CHECK_ERR( rval ); 00562 CHECK_EQUAL( 2u, iter.depth() ); 00563 00564 // check that parent split plane is correct 00565 rval = iter.get_parent_split_plane( p );CHECK_ERR( rval ); 00566 CHECK_EQUAL( BSPTree::Plane( 0, 0, 1, 0 ), p ); 00567 00568 // check that box corners are correct 00569 aabox_corners( min, max, expt ); 00570 for( unsigned i = 0; i < 8; ++i ) 00571 if( expt[i][2] > 0.0 ) expt[i][2] = 0.0; 00572 rval = iter.get_box_corners( corners );CHECK_ERR( rval ); 00573 CHECK( compare_hexes( expt, corners, 1e-6 ) ); 00574 00575 // split with z=-1 and normal in opposite direction 00576 rval = tool.split_leaf( iter, BSPTree::Plane( 0, 0, -2, -2 ) );CHECK_ERR( rval ); 00577 CHECK_EQUAL( 3u, iter.depth() ); 00578 for( unsigned i = 0; i < 8; ++i ) 00579 if( expt[i][2] < -1.0 ) expt[i][2] = -1.0; 00580 rval = iter.get_box_corners( corners );CHECK_ERR( rval ); 00581 CHECK( compare_hexes( expt, corners, 1e-6 ) ); 00582 00583 // step to next leaf (z < -1) 00584 rval = iter.step();CHECK_ERR( rval ); 00585 CHECK_EQUAL( 3u, iter.depth() ); 00586 aabox_corners( min, max, expt ); 00587 for( unsigned i = 0; i < 8; ++i ) 00588 if( expt[i][2] > -1.0 ) expt[i][2] = -1.0; 00589 rval = iter.get_box_corners( corners );CHECK_ERR( rval ); 00590 CHECK( compare_hexes( expt, corners, 1e-6 ) ); 00591 00592 // split at x = -1 00593 rval = tool.split_leaf( iter, BSPTree::Plane( -0.1, 0, 0, -0.1 ) );CHECK_ERR( rval ); 00594 CHECK_EQUAL( 4u, iter.depth() ); 00595 00596 // check that parent split plane is correct 00597 rval = iter.get_parent_split_plane( p );CHECK_ERR( rval ); 00598 CHECK_EQUAL( BSPTree::Plane( -1, 0, 0, -1 ), p ); 00599 00600 // check that leaf box is correct 00601 aabox_corners( -1, -2, -2, 2, 2, -1, expt ); 00602 rval = iter.get_box_corners( corners );CHECK_ERR( rval ); 00603 CHECK( compare_hexes( expt, corners, 1e-6 ) ); 00604 00605 // split at x = 1 00606 rval = tool.split_leaf( iter, BSPTree::Plane( 5, 0, 0, -5 ) );CHECK_ERR( rval ); 00607 CHECK_EQUAL( 5u, iter.depth() ); 00608 00609 // check that parent split plane is correct 00610 rval = iter.get_parent_split_plane( p );CHECK_ERR( rval ); 00611 CHECK_EQUAL( BSPTree::Plane( 1, 0, 0, -1 ), p ); 00612 00613 // check that leaf box is correct 00614 aabox_corners( -1, -2, -2, 1, 2, -1, expt ); 00615 rval = iter.get_box_corners( corners );CHECK_ERR( rval ); 00616 CHECK( compare_hexes( expt, corners, 1e-6 ) ); 00617 00618 // split at y = -1 00619 rval = tool.split_leaf( iter, BSPTree::Plane( 0, -1, 0, -1 ) );CHECK_ERR( rval ); 00620 CHECK_EQUAL( 6u, iter.depth() ); 00621 00622 // check that parent split plane is correct 00623 rval = iter.get_parent_split_plane( p );CHECK_ERR( rval ); 00624 CHECK_EQUAL( BSPTree::Plane( 0, -1, 0, -1 ), p ); 00625 00626 // check that leaf box is correct 00627 aabox_corners( -1, -1, -2, 1, 2, -1, expt ); 00628 rval = iter.get_box_corners( corners );CHECK_ERR( rval ); 00629 CHECK( compare_hexes( expt, corners, 1e-6 ) ); 00630 00631 // split at y = 1 00632 rval = tool.split_leaf( iter, BSPTree::Plane( 0, 1, 0, -1 ) );CHECK_ERR( rval ); 00633 CHECK_EQUAL( 7u, iter.depth() ); 00634 00635 // check that parent split plane is correct 00636 rval = iter.get_parent_split_plane( p );CHECK_ERR( rval ); 00637 CHECK_EQUAL( BSPTree::Plane( 0, 1, 0, -1 ), p ); 00638 00639 // check that leaf box is correct 00640 aabox_corners( -1, -1, -2, 1, 1, -1, expt ); 00641 rval = iter.get_box_corners( corners );CHECK_ERR( rval ); 00642 CHECK( compare_hexes( expt, corners, 1e-6 ) ); 00643 00644 // iterate over tree, verifying 00645 rval = tool.get_tree_iterator( root, iter );CHECK_ERR( rval ); 00646 CHECK_EQUAL( 3u, iter.depth() ); 00647 rval = iter.get_parent_split_plane( p );CHECK_ERR( rval ); 00648 CHECK_EQUAL( BSPTree::Plane( 0, 0, -1, -1 ), p ); 00649 aabox_corners( -2, -2, -1, 2, 2, 0, expt ); 00650 rval = iter.get_box_corners( corners );CHECK_ERR( rval ); 00651 CHECK( compare_hexes( expt, corners, 1e-6 ) ); 00652 00653 rval = iter.step();CHECK_ERR( rval ); 00654 CHECK_EQUAL( 7u, iter.depth() ); 00655 rval = iter.get_parent_split_plane( p );CHECK_ERR( rval ); 00656 CHECK_EQUAL( BSPTree::Plane( 0, 1, 0, -1 ), p ); 00657 aabox_corners( -1, -1, -2, 1, 1, -1, expt ); 00658 rval = iter.get_box_corners( corners );CHECK_ERR( rval ); 00659 CHECK( compare_hexes( expt, corners, 1e-6 ) ); 00660 00661 rval = iter.step();CHECK_ERR( rval ); 00662 CHECK_EQUAL( 7u, iter.depth() ); 00663 rval = iter.get_parent_split_plane( p );CHECK_ERR( rval ); 00664 CHECK_EQUAL( BSPTree::Plane( 0, 1, 0, -1 ), p ); 00665 aabox_corners( -1, 1, -2, 1, 2, -1, expt ); 00666 rval = iter.get_box_corners( corners );CHECK_ERR( rval ); 00667 CHECK( compare_hexes( expt, corners, 1e-6 ) ); 00668 00669 rval = iter.step();CHECK_ERR( rval ); 00670 CHECK_EQUAL( 6u, iter.depth() ); 00671 rval = iter.get_parent_split_plane( p );CHECK_ERR( rval ); 00672 CHECK_EQUAL( BSPTree::Plane( 0, -1, 0, -1 ), p ); 00673 aabox_corners( -1, -2, -2, 1, -1, -1, expt ); 00674 rval = iter.get_box_corners( corners );CHECK_ERR( rval ); 00675 CHECK( compare_hexes( expt, corners, 1e-6 ) ); 00676 00677 rval = iter.step();CHECK_ERR( rval ); 00678 CHECK_EQUAL( 5u, iter.depth() ); 00679 rval = iter.get_parent_split_plane( p );CHECK_ERR( rval ); 00680 CHECK_EQUAL( BSPTree::Plane( 1, 0, 0, -1 ), p ); 00681 aabox_corners( 1, -2, -2, 2, 2, -1, expt ); 00682 rval = iter.get_box_corners( corners );CHECK_ERR( rval ); 00683 CHECK( compare_hexes( expt, corners, 1e-6 ) ); 00684 00685 rval = iter.step();CHECK_ERR( rval ); 00686 CHECK_EQUAL( 4u, iter.depth() ); 00687 rval = iter.get_parent_split_plane( p );CHECK_ERR( rval ); 00688 CHECK_EQUAL( BSPTree::Plane( -1, 0, 0, -1 ), p ); 00689 aabox_corners( -2, -2, -2, -1, 2, -1, expt ); 00690 rval = iter.get_box_corners( corners );CHECK_ERR( rval ); 00691 CHECK( compare_hexes( expt, corners, 1e-6 ) ); 00692 00693 rval = iter.step();CHECK_ERR( rval ); 00694 CHECK_EQUAL( 2u, iter.depth() ); 00695 rval = iter.get_parent_split_plane( p );CHECK_ERR( rval ); 00696 CHECK_EQUAL( BSPTree::Plane( 0, 0, 1, 0 ), p ); 00697 aabox_corners( -2, -2, 0, 2, 2, 2, expt ); 00698 rval = iter.get_box_corners( corners );CHECK_ERR( rval ); 00699 CHECK( compare_hexes( expt, corners, 1e-6 ) ); 00700 00701 // no more leaves 00702 rval = iter.step(); 00703 CHECK_EQUAL( MB_ENTITY_NOT_FOUND, rval ); 00704 } 00705 00706 void test_leaf_containing_point_bounded_tree() 00707 { 00708 Core moab; 00709 BSPTree tool( &moab ); 00710 ErrorCode rval; 00711 EntityHandle root; 00712 BSPTreeIter iter; 00713 BSPTreeBoxIter b_iter; 00714 BSPTree::Plane p; 00715 EntityHandle h; 00716 double expected[8][3], corners[8][3]; 00717 00718 /* Build Tree 00719 00720 1.0 +---------+--------------+ 00721 | A | | 00722 | | | 00723 0.7 +---------+ C | 00724 | | | 00725 | | | 00726 | B | | 00727 | +--------------+ 0.3 00728 | | D | 00729 | | | 00730 0.0 +---------+--------------+ 00731 0.0 0.4 1.0 */ 00732 00733 const BSPTree::Plane X_split( 1.0, 0.0, 0.0, -0.4 ); 00734 const BSPTree::Plane AB_split( 0.0, -1.0, 0.0, 0.7 ); 00735 const BSPTree::Plane CD_split( 0.0, -1.0, 0.0, 0.3 ); 00736 00737 const double min[3] = { 0, 0, 0 }; 00738 const double max[3] = { 1, 1, 1 }; 00739 rval = tool.create_tree( min, max, root );CHECK_ERR( rval ); 00740 rval = tool.get_tree_iterator( root, iter );CHECK_ERR( rval ); 00741 00742 rval = tool.split_leaf( iter, X_split );CHECK_ERR( rval ); 00743 00744 rval = tool.split_leaf( iter, AB_split );CHECK_ERR( rval ); 00745 const EntityHandle A = iter.handle(); 00746 00747 rval = iter.step();CHECK_ERR( rval ); 00748 const EntityHandle B = iter.handle(); 00749 00750 rval = iter.step();CHECK_ERR( rval ); 00751 rval = tool.split_leaf( iter, CD_split );CHECK_ERR( rval ); 00752 const EntityHandle C = iter.handle(); 00753 00754 rval = iter.step();CHECK_ERR( rval ); 00755 const EntityHandle D = iter.handle(); 00756 00757 // Test queries inside tree 00758 00759 const double A_point[] = { 0.1, 0.8, 0.5 }; 00760 rval = tool.leaf_containing_point( root, A_point, h );CHECK_ERR( rval ); 00761 CHECK_EQUAL( A, h ); 00762 rval = tool.leaf_containing_point( root, A_point, iter );CHECK_ERR( rval ); 00763 CHECK_EQUAL( A, iter.handle() ); 00764 rval = iter.get_parent_split_plane( p );CHECK_ERR( rval ); 00765 CHECK_EQUAL( AB_split, p ); 00766 rval = tool.leaf_containing_point( root, A_point, b_iter );CHECK_ERR( rval ); 00767 CHECK_EQUAL( A, b_iter.handle() ); 00768 aabox_corners( 0.0, 0.7, 0.0, 0.4, 1.0, 1.0, expected ); 00769 rval = b_iter.get_box_corners( corners );CHECK_ERR( rval ); 00770 CHECK( compare_hexes( expected, corners, 1e-6 ) ); 00771 00772 const double B_point[] = { 0.3, 0.1, 0.6 }; 00773 rval = tool.leaf_containing_point( root, B_point, h );CHECK_ERR( rval ); 00774 CHECK_EQUAL( B, h ); 00775 rval = tool.leaf_containing_point( root, B_point, iter );CHECK_ERR( rval ); 00776 CHECK_EQUAL( B, iter.handle() ); 00777 rval = iter.get_parent_split_plane( p );CHECK_ERR( rval ); 00778 CHECK_EQUAL( AB_split, p ); 00779 rval = tool.leaf_containing_point( root, B_point, b_iter );CHECK_ERR( rval ); 00780 CHECK_EQUAL( B, b_iter.handle() ); 00781 aabox_corners( 0.0, 0.0, 0.0, 0.4, 0.7, 1.0, expected ); 00782 rval = b_iter.get_box_corners( corners );CHECK_ERR( rval ); 00783 CHECK( compare_hexes( expected, corners, 1e-6 ) ); 00784 00785 const double C_point[] = { 0.9, 0.9, 0.1 }; 00786 rval = tool.leaf_containing_point( root, C_point, h );CHECK_ERR( rval ); 00787 CHECK_EQUAL( C, h ); 00788 rval = tool.leaf_containing_point( root, C_point, iter );CHECK_ERR( rval ); 00789 CHECK_EQUAL( C, iter.handle() ); 00790 rval = iter.get_parent_split_plane( p );CHECK_ERR( rval ); 00791 CHECK_EQUAL( CD_split, p ); 00792 rval = tool.leaf_containing_point( root, C_point, b_iter );CHECK_ERR( rval ); 00793 CHECK_EQUAL( C, b_iter.handle() ); 00794 aabox_corners( 0.4, 0.3, 0.0, 1.0, 1.0, 1.0, expected ); 00795 rval = b_iter.get_box_corners( corners );CHECK_ERR( rval ); 00796 CHECK( compare_hexes( expected, corners, 1e-6 ) ); 00797 00798 const double D_point[] = { 0.5, 0.2, 0.9 }; 00799 rval = tool.leaf_containing_point( root, D_point, h );CHECK_ERR( rval ); 00800 CHECK_EQUAL( D, h ); 00801 rval = tool.leaf_containing_point( root, D_point, iter );CHECK_ERR( rval ); 00802 CHECK_EQUAL( D, iter.handle() ); 00803 rval = iter.get_parent_split_plane( p );CHECK_ERR( rval ); 00804 CHECK_EQUAL( CD_split, p ); 00805 rval = tool.leaf_containing_point( root, D_point, b_iter );CHECK_ERR( rval ); 00806 CHECK_EQUAL( D, b_iter.handle() ); 00807 aabox_corners( 0.4, 0.0, 0.0, 1.0, 0.3, 1.0, expected ); 00808 rval = b_iter.get_box_corners( corners );CHECK_ERR( rval ); 00809 CHECK( compare_hexes( expected, corners, 1e-6 ) ); 00810 00811 // Try a couple points outside of the tree 00812 00813 const double above_pt[] = { 0.5, 0.5, 2.0 }; 00814 rval = tool.leaf_containing_point( root, above_pt, b_iter ); 00815 CHECK_EQUAL( MB_ENTITY_NOT_FOUND, rval ); 00816 00817 const double left_pt[] = { -1.0, 0.5, 0.5 }; 00818 rval = tool.leaf_containing_point( root, left_pt, b_iter ); 00819 CHECK_EQUAL( MB_ENTITY_NOT_FOUND, rval ); 00820 } 00821 00822 void test_leaf_containing_point_unbounded_tree() 00823 { 00824 Core moab; 00825 BSPTree tool( &moab ); 00826 ErrorCode rval; 00827 EntityHandle root; 00828 BSPTreeIter iter; 00829 BSPTree::Plane p; 00830 EntityHandle h; 00831 00832 /* Build Tree 00833 00834 \ | 00835 \ C o (0,4,0) 00836 \ | 00837 \ | 00838 \ | 00839 B \ | D 00840 \| 00841 ________o (0,0,0) 00842 \ 00843 \ 00844 A \ 00845 o (1,-2,0) 00846 \ 00847 */ 00848 const BSPTree::Plane X_split( 2.0, 1.0, 0.0, 0.0 ); 00849 const BSPTree::Plane AB_split( 0.0, 1.0, 0.0, 0.0 ); 00850 const BSPTree::Plane CD_split( 1.0, 0.0, 0.0, 0.0 ); 00851 00852 rval = tool.create_tree( root );CHECK_ERR( rval ); 00853 rval = tool.get_tree_iterator( root, iter );CHECK_ERR( rval ); 00854 00855 rval = tool.split_leaf( iter, X_split );CHECK_ERR( rval ); 00856 00857 rval = tool.split_leaf( iter, AB_split );CHECK_ERR( rval ); 00858 const EntityHandle A = iter.handle(); 00859 00860 rval = iter.step();CHECK_ERR( rval ); 00861 const EntityHandle B = iter.handle(); 00862 00863 rval = iter.step();CHECK_ERR( rval ); 00864 rval = tool.split_leaf( iter, CD_split );CHECK_ERR( rval ); 00865 const EntityHandle C = iter.handle(); 00866 00867 rval = iter.step();CHECK_ERR( rval ); 00868 const EntityHandle D = iter.handle(); 00869 00870 // Test queries inside tree 00871 00872 const double A_point[] = { -1000, -1000, -1000 }; 00873 rval = tool.leaf_containing_point( root, A_point, h );CHECK_ERR( rval ); 00874 CHECK_EQUAL( A, h ); 00875 rval = tool.leaf_containing_point( root, A_point, iter );CHECK_ERR( rval ); 00876 CHECK_EQUAL( A, iter.handle() ); 00877 rval = iter.get_parent_split_plane( p );CHECK_ERR( rval ); 00878 CHECK_EQUAL( AB_split, p ); 00879 00880 const double B_point[] = { -3, 1, 100 }; 00881 rval = tool.leaf_containing_point( root, B_point, h );CHECK_ERR( rval ); 00882 CHECK_EQUAL( B, h ); 00883 rval = tool.leaf_containing_point( root, B_point, iter );CHECK_ERR( rval ); 00884 CHECK_EQUAL( B, iter.handle() ); 00885 rval = iter.get_parent_split_plane( p );CHECK_ERR( rval ); 00886 CHECK_EQUAL( AB_split, p ); 00887 00888 const double C_point[] = { -10, 500, 0 }; 00889 rval = tool.leaf_containing_point( root, C_point, h );CHECK_ERR( rval ); 00890 CHECK_EQUAL( C, h ); 00891 rval = tool.leaf_containing_point( root, C_point, iter );CHECK_ERR( rval ); 00892 CHECK_EQUAL( C, iter.handle() ); 00893 rval = iter.get_parent_split_plane( p );CHECK_ERR( rval ); 00894 CHECK_EQUAL( CD_split, p ); 00895 00896 const double D_point[] = { 10, 500, 0 }; 00897 rval = tool.leaf_containing_point( root, D_point, h );CHECK_ERR( rval ); 00898 CHECK_EQUAL( D, h ); 00899 rval = tool.leaf_containing_point( root, D_point, iter );CHECK_ERR( rval ); 00900 CHECK_EQUAL( D, iter.handle() ); 00901 rval = iter.get_parent_split_plane( p );CHECK_ERR( rval ); 00902 CHECK_EQUAL( CD_split, p ); 00903 } 00904 00905 void test_merge_leaf() 00906 { 00907 Core moab; 00908 BSPTree tool( &moab ); 00909 ErrorCode rval; 00910 EntityHandle root; 00911 BSPTreeBoxIter iter; 00912 BSPTree::Plane p; 00913 double expected[8][3], corners[8][3]; 00914 00915 /* Build Tree 00916 00917 1.0 +---------+--------------+ 00918 | A | | 00919 | | | 00920 0.7 +---------+ C | 00921 | | | 00922 | | | 00923 | B | | 00924 | +--------------+ 0.3 00925 | | D | 00926 | | | 00927 0.0 +---------+--------------+ 00928 0.0 0.4 1.0 */ 00929 00930 const BSPTree::Plane X_split( 1.0, 0.0, 0.0, -0.4 ); 00931 const BSPTree::Plane AB_split( 0.0, -1.0, 0.0, 0.7 ); 00932 const BSPTree::Plane CD_split( 0.0, -1.0, 0.0, 0.3 ); 00933 00934 const double min[3] = { 0, 0, 0 }; 00935 const double max[3] = { 1, 1, 1 }; 00936 rval = tool.create_tree( min, max, root );CHECK_ERR( rval ); 00937 rval = tool.get_tree_iterator( root, iter );CHECK_ERR( rval ); 00938 rval = tool.split_leaf( iter, X_split );CHECK_ERR( rval ); 00939 const EntityHandle AB = iter.handle(); 00940 rval = tool.split_leaf( iter, AB_split );CHECK_ERR( rval ); 00941 rval = iter.step();CHECK_ERR( rval ); 00942 rval = iter.step();CHECK_ERR( rval ); 00943 const EntityHandle CD = iter.handle(); 00944 rval = tool.split_leaf( iter, CD_split );CHECK_ERR( rval ); 00945 rval = iter.step();CHECK_ERR( rval ); 00946 00947 rval = tool.get_tree_iterator( root, iter );CHECK_ERR( rval ); 00948 rval = tool.merge_leaf( iter );CHECK_ERR( rval ); 00949 CHECK_EQUAL( AB, iter.handle() ); 00950 CHECK_EQUAL( 2u, iter.depth() ); 00951 rval = iter.get_parent_split_plane( p );CHECK_ERR( rval ); 00952 CHECK_EQUAL( X_split, p ); 00953 aabox_corners( 0.0, 0.0, 0.0, 0.4, 1.0, 1.0, expected ); 00954 rval = iter.get_box_corners( corners );CHECK_ERR( rval ); 00955 CHECK( compare_hexes( expected, corners, 1e-6 ) ); 00956 00957 rval = iter.step();CHECK_ERR( rval ); 00958 rval = iter.step();CHECK_ERR( rval ); 00959 rval = tool.merge_leaf( iter );CHECK_ERR( rval ); 00960 CHECK_EQUAL( CD, iter.handle() ); 00961 CHECK_EQUAL( 2u, iter.depth() ); 00962 rval = iter.get_parent_split_plane( p );CHECK_ERR( rval ); 00963 CHECK_EQUAL( X_split, p ); 00964 aabox_corners( 0.4, 0.0, 0.0, 1.0, 1.0, 1.0, expected ); 00965 rval = iter.get_box_corners( corners );CHECK_ERR( rval ); 00966 CHECK( compare_hexes( expected, corners, 1e-6 ) ); 00967 00968 rval = iter.step(); 00969 CHECK_EQUAL( MB_ENTITY_NOT_FOUND, rval ); 00970 } 00971 00972 static std::vector< int > neighbors( const BSPTreeBoxIter& iter, 00973 const EntityHandle leaves[8], 00974 BSPTreeBoxIter::SideBits side, 00975 double epsilon ) 00976 { 00977 std::vector< BSPTreeBoxIter > list; 00978 ErrorCode rval = iter.get_neighbors( side, list, epsilon );CHECK_ERR( rval ); 00979 00980 std::vector< int > results; 00981 for( size_t i = 0; i < list.size(); ++i ) 00982 results.push_back( std::find( leaves, leaves + 8, list[i].handle() ) - leaves ); 00983 std::sort( results.begin(), results.end() ); 00984 return results; 00985 } 00986 00987 void test_box_iter_neighbors() 00988 { 00989 Core moab; 00990 BSPTree tool( &moab ); 00991 ErrorCode rval; 00992 EntityHandle root; 00993 BSPTreeBoxIter iter; 00994 BSPTree::Plane p; 00995 00996 /* Build Tree */ 00997 00998 const double corners[8][3] = { { 0, 0, 0 }, { 8, 0, 0 }, { 8, 2, 0 }, { 0, 2, 0 }, 00999 { 0, 0, 1 }, { 8, 0, 1 }, { 8, 2, 1 }, { 0, 2, 1 } }; 01000 rval = tool.create_tree( corners, root );CHECK_ERR( rval ); 01001 rval = tool.get_tree_iterator( root, iter );CHECK_ERR( rval ); 01002 EntityHandle leaves[8]; 01003 01004 /* +----------------------------------------+ 01005 | | 01006 | 0* | 01007 | | 01008 +----------------------------------------+ */ 01009 01010 p = BSPTree::Plane( 1, 0, 0, -4 ); 01011 rval = tool.split_leaf( iter, p );CHECK_ERR( rval ); 01012 01013 /* +-------------------+--------------------+ 01014 | | | 01015 | 0* | 1 | 01016 | | | 01017 +----------------------------------------+ */ 01018 01019 p = BSPTree::Plane( -1, 0, 0, 2 ); 01020 rval = tool.split_leaf( iter, p );CHECK_ERR( rval ); 01021 01022 /* +---------+---------+--------------------+ 01023 | | | | 01024 | 1 | 0* | 2 | 01025 | | | | 01026 +----------------------------------------+ */ 01027 01028 p = BSPTree::Plane( 0, 1, 0, -1 ); 01029 rval = tool.split_leaf( iter, p );CHECK_ERR( rval ); 01030 01031 /* +---------+---------+--------------------+ 01032 | | 1 | | 01033 | 2 +---------+ 3 | 01034 | | 0* | | 01035 +----------------------------------------+ */ 01036 01037 leaves[0] = iter.handle(); 01038 rval = iter.step();CHECK_ERR( rval ); 01039 leaves[1] = iter.handle(); 01040 rval = iter.step();CHECK_ERR( rval ); 01041 01042 /* +---------+---------+--------------------+ 01043 | | 1 | | 01044 | 2* +---------+ 3 | 01045 | | 0 | | 01046 +----------------------------------------+ */ 01047 01048 p = BSPTree::Plane( 0, -1, 0, 1 ); 01049 rval = tool.split_leaf( iter, p );CHECK_ERR( rval ); 01050 01051 /* +---------+---------+--------------------+ 01052 | 2* | 1 | | 01053 +---------+---------+ 4 | 01054 | 3 | 0 | | 01055 +----------------------------------------+ */ 01056 01057 leaves[2] = iter.handle(); 01058 rval = iter.step();CHECK_ERR( rval ); 01059 leaves[3] = iter.handle(); 01060 rval = iter.step();CHECK_ERR( rval ); 01061 01062 /* +---------+---------+--------------------+ 01063 | 2 | 1 | | 01064 +---------+---------+ 4* | 01065 | 3 | 0 | | 01066 +----------------------------------------+ */ 01067 01068 p = BSPTree::Plane( 0, 1, 0, -1 ); 01069 rval = tool.split_leaf( iter, p );CHECK_ERR( rval ); 01070 01071 /* +---------+---------+--------------------+ 01072 | 2 | 1 | 5 | 01073 +---------+---------+--------------------+ 01074 | 3 | 0 | 4* | 01075 +----------------------------------------+ */ 01076 01077 p = BSPTree::Plane( 1, 0, 0, -6 ); 01078 rval = tool.split_leaf( iter, p );CHECK_ERR( rval ); 01079 01080 /* +---------+---------+--------------------+ 01081 | 2 | 1 | 6 | 01082 +---------+---------+----------+---------+ 01083 | 3 | 0 | 4* | 5 | 01084 +------------------------------+---------+ */ 01085 01086 leaves[4] = iter.handle(); 01087 rval = iter.step();CHECK_ERR( rval ); 01088 leaves[5] = iter.handle(); 01089 rval = iter.step();CHECK_ERR( rval ); 01090 01091 /* +---------+---------+--------------------+ 01092 | 2 | 1 | 6* | 01093 +---------+---------+----------+---------+ 01094 | 3 | 0 | 4 | 5 | 01095 +------------------------------+---------+ */ 01096 01097 p = BSPTree::Plane( -1, 0, 0, 6 ); 01098 rval = tool.split_leaf( iter, p );CHECK_ERR( rval ); 01099 01100 /* +---------+---------+--------------------+ 01101 | 2 | 1 | 7 | 6 | 01102 +---------+---------+----------+---------+ 01103 | 3 | 0 | 4 | 5 | 01104 +------------------------------+---------+ */ 01105 01106 leaves[6] = iter.handle(); 01107 rval = iter.step();CHECK_ERR( rval ); 01108 leaves[7] = iter.handle(); 01109 01110 /* check all neighbors of each leaf */ 01111 01112 rval = tool.get_tree_iterator( root, iter );CHECK_ERR( rval ); 01113 01114 // NOTE: Several values in the expected result list are 01115 // commented out in the tests below. When the tolerance 01116 // is greater than zero, the search algorithm may or may 01117 // not return leaves that are not face-adjacent (e.g. adjacent 01118 // only along edges or at corners.) The determining factor 01119 // for whether or not such a neighbor is returned is which 01120 // sub-tree of the split that defined the source leaf side 01121 // the neighbor is on. The algorithm will not search the subtree 01122 // of the split that created the side and that contains the 01123 // source leaf. 01124 01125 // check neighbors of leaf 0 01126 std::vector< int > expected; 01127 CHECK_EQUAL( leaves[0], iter.handle() ); 01128 expected.clear(); 01129 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B0154, 1e-6 ) ); 01130 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B3210, 1e-6 ) ); 01131 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B4567, 1e-6 ) ); 01132 expected.push_back( 3 ); 01133 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B3047, -1e-6 ) ); 01134 expected.insert( expected.begin(), 2 ); 01135 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B3047, 1e-6 ) ); 01136 expected.clear(); 01137 expected.push_back( 1 ); 01138 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B2376, -1e-6 ) ); 01139 // See NOTE // expected.push_back( 2 ); expected.push_back( 7 ); 01140 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B2376, 1e-6 ) ); 01141 expected.clear(); 01142 expected.push_back( 4 ); 01143 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B1265, -1e-6 ) ); 01144 expected.push_back( 7 ); 01145 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B1265, 1e-6 ) ); 01146 01147 // check neighbors of leaf 1 01148 CHECK_ERR( iter.step() ); 01149 CHECK_EQUAL( leaves[1], iter.handle() ); 01150 expected.clear(); 01151 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B2376, 1e-6 ) ); 01152 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B3210, 1e-6 ) ); 01153 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B4567, 1e-6 ) ); 01154 expected.push_back( 2 ); 01155 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B3047, -1e-6 ) ); 01156 expected.push_back( 3 ); 01157 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B3047, 1e-6 ) ); 01158 expected.clear(); 01159 expected.push_back( 0 ); 01160 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B0154, -1e-6 ) ); 01161 // See NOTE // expected.push_back( 3 ); expected.push_back( 4 ); 01162 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B0154, 1e-6 ) ); 01163 expected.clear(); 01164 expected.push_back( 7 ); 01165 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B1265, -1e-6 ) ); 01166 expected.insert( expected.begin(), 4 ); 01167 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B1265, 1e-6 ) ); 01168 01169 /* +---------+---------+--------------------+ 01170 | 2 | 1 | 7 | 6 | 01171 +---------+---------+----------+---------+ 01172 | 3 | 0 | 4 | 5 | 01173 +------------------------------+---------+ */ 01174 01175 // check neighbors of leaf 2 01176 CHECK_ERR( iter.step() ); 01177 CHECK_EQUAL( leaves[2], iter.handle() ); 01178 expected.clear(); 01179 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B2376, 1e-6 ) ); 01180 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B3047, 1e-6 ) ); 01181 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B3210, 1e-6 ) ); 01182 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B4567, 1e-6 ) ); 01183 expected.push_back( 3 ); 01184 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B0154, -1e-6 ) ); 01185 // See NOTE // expected.insert( expected.begin(), 0 ); 01186 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B0154, 1e-6 ) ); 01187 expected.clear(); 01188 expected.push_back( 1 ); 01189 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B1265, -1e-6 ) ); 01190 expected.insert( expected.begin(), 0 ); 01191 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B1265, 1e-6 ) ); 01192 01193 // check neighbors of leaf 3 01194 CHECK_ERR( iter.step() ); 01195 CHECK_EQUAL( leaves[3], iter.handle() ); 01196 expected.clear(); 01197 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B0154, 1e-6 ) ); 01198 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B3047, 1e-6 ) ); 01199 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B3210, 1e-6 ) ); 01200 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B4567, 1e-6 ) ); 01201 expected.push_back( 2 ); 01202 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B2376, -1e-6 ) ); 01203 // See NOTE // expected.insert( expected.begin(), 1 ); 01204 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B2376, 1e-6 ) ); 01205 expected.clear(); 01206 expected.push_back( 0 ); 01207 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B1265, -1e-6 ) ); 01208 expected.push_back( 1 ); 01209 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B1265, 1e-6 ) ); 01210 01211 /* +---------+---------+--------------------+ 01212 | 2 | 1 | 7 | 6 | 01213 +---------+---------+----------+---------+ 01214 | 3 | 0 | 4 | 5 | 01215 +------------------------------+---------+ */ 01216 01217 // check neighbors of leaf 4 01218 CHECK_ERR( iter.step() ); 01219 CHECK_EQUAL( leaves[4], iter.handle() ); 01220 expected.clear(); 01221 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B0154, 1e-6 ) ); 01222 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B3210, 1e-6 ) ); 01223 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B4567, 1e-6 ) ); 01224 expected.push_back( 0 ); 01225 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B3047, -1e-6 ) ); 01226 expected.push_back( 1 ); 01227 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B3047, 1e-6 ) ); 01228 expected.clear(); 01229 expected.push_back( 7 ); 01230 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B2376, -1e-6 ) ); 01231 expected.insert( expected.begin(), 6 ); 01232 // See NOTE // expected.insert( expected.begin(), 1 ); 01233 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B2376, 1e-6 ) ); 01234 expected.clear(); 01235 expected.push_back( 5 ); 01236 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B1265, -1e-6 ) ); 01237 // See NOTE // expected.push_back( 6 ); 01238 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B1265, 1e-6 ) ); 01239 01240 // check neighbors of leaf 5 01241 CHECK_ERR( iter.step() ); 01242 CHECK_EQUAL( leaves[5], iter.handle() ); 01243 expected.clear(); 01244 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B0154, 1e-6 ) ); 01245 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B1265, 1e-6 ) ); 01246 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B3210, 1e-6 ) ); 01247 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B4567, 1e-6 ) ); 01248 expected.push_back( 4 ); 01249 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B3047, -1e-6 ) ); 01250 // See NOTE // expected.push_back( 7 ); 01251 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B3047, 1e-6 ) ); 01252 expected.clear(); 01253 expected.push_back( 6 ); 01254 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B2376, -1e-6 ) ); 01255 expected.push_back( 7 ); 01256 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B2376, 1e-6 ) ); 01257 01258 /* +---------+---------+--------------------+ 01259 | 2 | 1 | 7 | 6 | 01260 +---------+---------+----------+---------+ 01261 | 3 | 0 | 4 | 5 | 01262 +------------------------------+---------+ */ 01263 01264 // check neighbors of leaf 6 01265 CHECK_ERR( iter.step() ); 01266 CHECK_EQUAL( leaves[6], iter.handle() ); 01267 expected.clear(); 01268 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B2376, 1e-6 ) ); 01269 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B1265, 1e-6 ) ); 01270 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B3210, 1e-6 ) ); 01271 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B4567, 1e-6 ) ); 01272 expected.push_back( 7 ); 01273 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B3047, -1e-6 ) ); 01274 // See NOTE // expected.insert( expected.begin(), 4 ); 01275 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B3047, 1e-6 ) ); 01276 expected.clear(); 01277 expected.push_back( 5 ); 01278 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B0154, -1e-6 ) ); 01279 expected.insert( expected.begin(), 4 ); 01280 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B0154, 1e-6 ) ); 01281 01282 // check neighbors of leaf 7 01283 CHECK_ERR( iter.step() ); 01284 CHECK_EQUAL( leaves[7], iter.handle() ); 01285 expected.clear(); 01286 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B2376, 1e-6 ) ); 01287 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B3210, 1e-6 ) ); 01288 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B4567, 1e-6 ) ); 01289 expected.push_back( 1 ); 01290 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B3047, -1e-6 ) ); 01291 expected.insert( expected.begin(), 0 ); 01292 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B3047, 1e-6 ) ); 01293 expected.clear(); 01294 expected.push_back( 4 ); 01295 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B0154, -1e-6 ) ); 01296 // See NOTE // expected.insert( expected.begin(), 0 ); 01297 expected.push_back( 5 ); 01298 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B0154, 1e-6 ) ); 01299 expected.clear(); 01300 expected.push_back( 6 ); 01301 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B1265, -1e-6 ) ); 01302 // See NOTE // expected.insert( expected.begin(), 5 ); 01303 CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B1265, 1e-6 ) ); 01304 } 01305 01306 void test_leaf_sibling() 01307 { 01308 Core moab; 01309 BSPTree tool( &moab ); 01310 ErrorCode rval; 01311 EntityHandle root; 01312 BSPTreeIter iter; 01313 01314 /* Build Tree 01315 01316 1.0 +---------+--------------+ 01317 | A | | 01318 | | | 01319 0.7 +---------+ C | 01320 | | | 01321 | | | 01322 | B | | 01323 | +--------------+ 0.3 01324 | | D | 01325 | | | 01326 0.0 +---------+--------------+ 01327 0.0 0.4 1.0 */ 01328 01329 const BSPTree::Plane X_split( 1.0, 0.0, 0.0, -0.4 ); 01330 const BSPTree::Plane AB_split( 0.0, -1.0, 0.0, 0.7 ); 01331 const BSPTree::Plane CD_split( 0.0, -1.0, 0.0, 0.3 ); 01332 01333 const double min[3] = { 0, 0, 0 }; 01334 const double max[3] = { 1, 1, 1 }; 01335 rval = tool.create_tree( min, max, root );CHECK_ERR( rval ); 01336 rval = tool.get_tree_iterator( root, iter );CHECK_ERR( rval ); 01337 rval = tool.split_leaf( iter, X_split );CHECK_ERR( rval ); 01338 rval = tool.split_leaf( iter, AB_split );CHECK_ERR( rval ); 01339 rval = iter.step();CHECK_ERR( rval ); 01340 rval = iter.step();CHECK_ERR( rval ); 01341 rval = tool.split_leaf( iter, CD_split );CHECK_ERR( rval ); 01342 01343 // create two iterators for testing 01344 BSPTreeIter iter1, iter2; 01345 rval = tool.get_tree_iterator( root, iter1 );CHECK_ERR( rval ); 01346 rval = tool.get_tree_iterator( root, iter2 );CHECK_ERR( rval ); 01347 01348 // iter1 == A, iter2 == A 01349 CHECK( !iter1.is_sibling( iter1 ) ); 01350 CHECK( !iter1.is_sibling( iter1.handle() ) ); 01351 CHECK( !iter1.is_sibling( iter2 ) ); 01352 CHECK( iter1.sibling_is_forward() ); 01353 01354 // iter1 == A, iter2 == B 01355 rval = iter2.step();CHECK_ERR( rval ); 01356 CHECK( iter1.is_sibling( iter2 ) ); 01357 CHECK( iter1.is_sibling( iter2.handle() ) ); 01358 CHECK( iter2.is_sibling( iter1 ) ); 01359 CHECK( iter2.is_sibling( iter1.handle() ) ); 01360 CHECK( !iter2.sibling_is_forward() ); 01361 01362 // iter1 == A, iter2 == C 01363 rval = iter2.step();CHECK_ERR( rval ); 01364 CHECK( !iter1.is_sibling( iter2 ) ); 01365 CHECK( !iter1.is_sibling( iter2.handle() ) ); 01366 CHECK( !iter2.is_sibling( iter1 ) ); 01367 CHECK( !iter2.is_sibling( iter1.handle() ) ); 01368 CHECK( iter2.sibling_is_forward() ); 01369 01370 // iter1 == B, iter2 == C 01371 rval = iter1.step();CHECK_ERR( rval ); 01372 CHECK( !iter1.is_sibling( iter2 ) ); 01373 CHECK( !iter1.is_sibling( iter2.handle() ) ); 01374 CHECK( !iter2.is_sibling( iter1 ) ); 01375 CHECK( !iter2.is_sibling( iter1.handle() ) ); 01376 CHECK( !iter1.sibling_is_forward() ); 01377 01378 // iter1 == D, iter2 == C 01379 rval = iter1.step();CHECK_ERR( rval ); 01380 CHECK_EQUAL( iter1.handle(), iter2.handle() ); 01381 rval = iter1.step();CHECK_ERR( rval ); 01382 CHECK( iter1.is_sibling( iter2 ) ); 01383 CHECK( iter1.is_sibling( iter2.handle() ) ); 01384 CHECK( iter2.is_sibling( iter1 ) ); 01385 CHECK( iter2.is_sibling( iter1.handle() ) ); 01386 CHECK( !iter1.sibling_is_forward() ); 01387 } 01388 01389 void test_leaf_volume( bool box ) 01390 { 01391 Core moab; 01392 BSPTree tool( &moab ); 01393 ErrorCode rval; 01394 EntityHandle root; 01395 BSPTreeBoxIter b_iter; 01396 BSPTreeIter g_iter; 01397 BSPTreeIter& iter = box ? b_iter : g_iter; 01398 01399 /* Build Tree 01400 01401 1.0 +---------+--------------+ 01402 | A | | 01403 | | | 01404 0.7 +---------+ C | 01405 | | | 01406 | | | 01407 | B | | 01408 | +--------------+ 0.3 01409 | | D | 01410 | | | 01411 0.0 +---------+--------------+ 01412 0.0 0.4 1.0 */ 01413 01414 const BSPTree::Plane X_split( 1.0, 0.0, 0.0, -0.4 ); 01415 const BSPTree::Plane AB_split( 0.0, -1.0, 0.0, 0.7 ); 01416 const BSPTree::Plane CD_split( 0.0, -1.0, 0.0, 0.3 ); 01417 01418 const double min[3] = { 0, 0, 0 }; 01419 const double max[3] = { 1, 1, 1 }; 01420 rval = tool.create_tree( min, max, root );CHECK_ERR( rval ); 01421 rval = tool.get_tree_iterator( root, iter );CHECK_ERR( rval ); 01422 rval = tool.split_leaf( iter, X_split );CHECK_ERR( rval ); 01423 rval = tool.split_leaf( iter, AB_split );CHECK_ERR( rval ); 01424 rval = iter.step();CHECK_ERR( rval ); 01425 rval = iter.step();CHECK_ERR( rval ); 01426 rval = tool.split_leaf( iter, CD_split );CHECK_ERR( rval ); 01427 01428 // reset iterator 01429 rval = tool.get_tree_iterator( root, iter );CHECK_ERR( rval ); 01430 01431 // check leaf volumes 01432 CHECK_REAL_EQUAL( 0.12, iter.volume(), 1e-12 ); // A 01433 CHECK_ERR( iter.step() ); 01434 CHECK_REAL_EQUAL( 0.28, iter.volume(), 1e-12 ); // B 01435 CHECK_ERR( iter.step() ); 01436 CHECK_REAL_EQUAL( 0.42, iter.volume(), 1e-12 ); // C 01437 CHECK_ERR( iter.step() ); 01438 CHECK_REAL_EQUAL( 0.18, iter.volume(), 1e-12 ); // D 01439 } 01440 01441 void test_leaf_splits_intersects() 01442 { 01443 Core moab; 01444 BSPTree tool( &moab ); 01445 ErrorCode rval; 01446 EntityHandle root; 01447 BSPTreeBoxIter iter; 01448 BSPTree::Plane p; 01449 01450 const double min[3] = { 0, 0, 0 }; 01451 const double max[3] = { 1, 2, 3 }; 01452 rval = tool.create_tree( min, max, root );CHECK_ERR( rval ); 01453 rval = tool.get_tree_iterator( root, iter );CHECK_ERR( rval ); 01454 01455 p.set( 1, 0, 0, 1 ); // x == -1 01456 CHECK_EQUAL( BSPTreeBoxIter::MISS, iter.splits( p ) ); 01457 CHECK( !iter.intersects( p ) ); 01458 p.flip(); 01459 CHECK_EQUAL( BSPTreeBoxIter::MISS, iter.splits( p ) ); 01460 CHECK( !iter.intersects( p ) ); 01461 01462 p.set( 1, 0, 0, 0 ); // x == 0 01463 CHECK_EQUAL( BSPTreeBoxIter::NONHEX, iter.splits( p ) ); 01464 p.flip(); 01465 CHECK_EQUAL( BSPTreeBoxIter::NONHEX, iter.splits( p ) ); 01466 01467 p.set( 1, 0, 0, -0.5 ); // x == 0.5 01468 CHECK_EQUAL( BSPTreeBoxIter::SPLIT, iter.splits( p ) ); 01469 CHECK( iter.intersects( p ) ); 01470 p.flip(); 01471 CHECK_EQUAL( BSPTreeBoxIter::SPLIT, iter.splits( p ) ); 01472 CHECK( iter.intersects( p ) ); 01473 01474 p.set( 1, 0, 0, -1 ); // x == 1 01475 CHECK_EQUAL( BSPTreeBoxIter::NONHEX, iter.splits( p ) ); 01476 p.flip(); 01477 CHECK_EQUAL( BSPTreeBoxIter::NONHEX, iter.splits( p ) ); 01478 01479 p.set( 1, 0, 0, -2 ); // x == 2 01480 CHECK_EQUAL( BSPTreeBoxIter::MISS, iter.splits( p ) ); 01481 CHECK( !iter.intersects( p ) ); 01482 p.flip(); 01483 CHECK_EQUAL( BSPTreeBoxIter::MISS, iter.splits( p ) ); 01484 CHECK( !iter.intersects( p ) ); 01485 01486 double pt1[3] = { 0, 0, 1.5 }; 01487 double pt2[3] = { 1, 0, 1.5 }; 01488 double pt3[3] = { 0, 1, 3.0 }; 01489 p.set( pt1, pt2, pt3 ); 01490 CHECK_EQUAL( BSPTreeBoxIter::NONHEX, iter.splits( p ) ); 01491 CHECK( iter.intersects( p ) ); 01492 p.flip(); 01493 CHECK_EQUAL( BSPTreeBoxIter::NONHEX, iter.splits( p ) ); 01494 CHECK( iter.intersects( p ) ); 01495 01496 double pt4[3] = { 0, 2, 2.8 }; 01497 p.set( pt1, pt2, pt4 ); 01498 CHECK_EQUAL( BSPTreeBoxIter::SPLIT, iter.splits( p ) ); 01499 CHECK( iter.intersects( p ) ); 01500 p.flip(); 01501 CHECK_EQUAL( BSPTreeBoxIter::SPLIT, iter.splits( p ) ); 01502 CHECK( iter.intersects( p ) ); 01503 01504 double pta[3] = { 0.8, 0, 0 }; 01505 double ptb[3] = { 0, 0.2, 3 }; 01506 double ptc[3] = { 0.8, 2, 3 }; 01507 p.set( pta, ptb, ptc ); 01508 CHECK_EQUAL( BSPTreeBoxIter::NONHEX, iter.splits( p ) ); 01509 CHECK( iter.intersects( p ) ); 01510 p.flip(); 01511 CHECK_EQUAL( BSPTreeBoxIter::NONHEX, iter.splits( p ) ); 01512 CHECK( iter.intersects( p ) ); 01513 } 01514 01515 #define CHECK_RAY_XSECTS( PT, DIR, T_IN, T_OUT ) \ 01516 do \ 01517 { \ 01518 CHECK( iter.intersect_ray( ( PT ), ( DIR ), t_in, t_out ) ); \ 01519 CHECK_REAL_EQUAL( ( T_IN ), t_in, 1e-6 ); \ 01520 CHECK_REAL_EQUAL( ( T_OUT ), t_out, 1e-6 ); \ 01521 } while( false ) 01522 01523 void test_leaf_intersects_ray_common( bool box ) 01524 { 01525 ErrorCode rval; 01526 Core moab; 01527 BSPTree tool( &moab ); 01528 double t_in, t_out; 01529 01530 /** Start with only root box for initial testing **/ 01531 01532 /* (1,5,-3) (2,5,-3) 01533 o----o 01534 /: / \ 01535 / : / \ 01536 (1,5,-1)o----o \ 01537 | : \ \ 01538 | : Y \ \ 01539 | : ^ \ \ 01540 | : | \ \ 01541 | : +-->X \ \ (6,1,-3) 01542 | o./..........\.......o 01543 | . L \ / 01544 |. Z \ / 01545 o--------------------o 01546 (1,1,-1) (6,1,-1) 01547 */ 01548 EntityHandle root; 01549 const double corners[][3] = { { 1, 1, -3 }, { 6, 1, -3 }, { 2, 5, -3 }, { 1, 5, -3 }, 01550 { 1, 1, -1 }, { 6, 1, -1 }, { 2, 5, -1 }, { 1, 5, -1 } }; 01551 rval = tool.create_tree( corners, root );CHECK_ERR( rval ); 01552 01553 BSPTreeIter gen_iter; 01554 BSPTreeBoxIter box_iter; 01555 BSPTreeIter& iter = box ? static_cast< BSPTreeIter& >( box_iter ) : gen_iter; 01556 rval = tool.get_tree_iterator( root, iter );CHECK_ERR( rval ); 01557 01558 // start with point inside box 01559 const double pt1[] = { 3.5, 3, -2 }; 01560 const double dir1[] = { 0.1, 0.1, 0.1 }; 01561 CHECK_RAY_XSECTS( pt1, dir1, 0, 2.5 ); 01562 const double dir2[] = { 5, 5, 5 }; 01563 CHECK_RAY_XSECTS( pt1, dir2, 0, 0.05 ); 01564 const double pxdir[] = { 1, 0, 0 }; 01565 CHECK_RAY_XSECTS( pt1, pxdir, 0, 0.5 ); 01566 const double nxdir[] = { -1, 0, 0 }; 01567 CHECK_RAY_XSECTS( pt1, nxdir, 0, 2.5 ); 01568 const double pydir[] = { 0, 1, 0 }; 01569 CHECK_RAY_XSECTS( pt1, pydir, 0, 0.5 ); 01570 const double nydir[] = { 0, -1, 0 }; 01571 CHECK_RAY_XSECTS( pt1, nydir, 0, 2 ); 01572 const double pzdir[] = { 0, 0, 1 }; 01573 CHECK_RAY_XSECTS( pt1, pzdir, 0, 1 ); 01574 const double nzdir[] = { 0, 0, -1 }; 01575 CHECK_RAY_XSECTS( pt1, nzdir, 0, 1 ); 01576 01577 // point below box 01578 const double pt2[] = { 3.5, 3, -4 }; 01579 CHECK( !iter.intersect_ray( pt2, dir1, t_in, t_out ) ); 01580 CHECK( !iter.intersect_ray( pt2, dir2, t_in, t_out ) ); 01581 CHECK( !iter.intersect_ray( pt2, pxdir, t_in, t_out ) ); 01582 CHECK( !iter.intersect_ray( pt2, nxdir, t_in, t_out ) ); 01583 CHECK( !iter.intersect_ray( pt2, pydir, t_in, t_out ) ); 01584 CHECK( !iter.intersect_ray( pt2, nydir, t_in, t_out ) ); 01585 CHECK_RAY_XSECTS( pt2, pzdir, 1, 3 ); 01586 CHECK( !iter.intersect_ray( pt2, nzdir, t_in, t_out ) ); 01587 01588 // point right of box 01589 const double pt3[] = { 7, 3, -2 }; 01590 CHECK( !iter.intersect_ray( pt3, dir1, t_in, t_out ) ); 01591 CHECK( !iter.intersect_ray( pt3, dir2, t_in, t_out ) ); 01592 CHECK( !iter.intersect_ray( pt3, pxdir, t_in, t_out ) ); 01593 CHECK_RAY_XSECTS( pt3, nxdir, 3, 6 ); 01594 CHECK( !iter.intersect_ray( pt3, pydir, t_in, t_out ) ); 01595 CHECK( !iter.intersect_ray( pt3, nydir, t_in, t_out ) ); 01596 CHECK( !iter.intersect_ray( pt3, pzdir, t_in, t_out ) ); 01597 CHECK( !iter.intersect_ray( pt3, nzdir, t_in, t_out ) ); 01598 01599 // a few more complex test cases 01600 const double dira[] = { -2, -2, 0 }; 01601 CHECK_RAY_XSECTS( pt3, dira, 0.75, 1.0 ); 01602 const double dirb[] = { -1, -2.1, 0 }; 01603 CHECK( !iter.intersect_ray( pt3, dirb, t_in, t_out ) ); 01604 01605 /** Now split twice and test the bottom right corne **/ 01606 01607 BSPTree::Plane Y3( BSPTree::Y, 3.0 ); 01608 rval = tool.split_leaf( iter, Y3 );CHECK_ERR( rval ); 01609 BSPTree::Plane X2( BSPTree::X, 2.0 ); 01610 rval = tool.split_leaf( iter, X2 );CHECK_ERR( rval ); 01611 rval = iter.step();CHECK_ERR( rval ); 01612 01613 /* 01614 (2,3,-3) 01615 o--------o (4,3,-3) 01616 /: / \ 01617 / : / \ 01618 (2,3,-1)o--------o(4,3,-1)\ (6,1,-3) 01619 | o.......\.......o 01620 | . \ / 01621 |. \ / 01622 o---------------o 01623 (2,1,-1) (6,1,-1) 01624 */ 01625 01626 // start with point inside box 01627 const double pt4[] = { 4, 2, -2 }; 01628 CHECK_RAY_XSECTS( pt4, dir1, 0, 5 ); 01629 CHECK_RAY_XSECTS( pt4, dir2, 0, 0.1 ); 01630 CHECK_RAY_XSECTS( pt4, pxdir, 0, 1 ); 01631 CHECK_RAY_XSECTS( pt4, nxdir, 0, 2 ); 01632 CHECK_RAY_XSECTS( pt4, pydir, 0, 1 ); 01633 CHECK_RAY_XSECTS( pt4, nydir, 0, 1 ); 01634 CHECK_RAY_XSECTS( pt4, pzdir, 0, 1 ); 01635 CHECK_RAY_XSECTS( pt4, nzdir, 0, 1 ); 01636 01637 // point below box 01638 const double pt5[] = { 4, 2, -4 }; 01639 CHECK( !iter.intersect_ray( pt5, dir1, t_in, t_out ) ); 01640 CHECK( !iter.intersect_ray( pt5, dir2, t_in, t_out ) ); 01641 CHECK( !iter.intersect_ray( pt5, pxdir, t_in, t_out ) ); 01642 CHECK( !iter.intersect_ray( pt5, nxdir, t_in, t_out ) ); 01643 CHECK( !iter.intersect_ray( pt5, pydir, t_in, t_out ) ); 01644 CHECK( !iter.intersect_ray( pt5, nydir, t_in, t_out ) ); 01645 CHECK_RAY_XSECTS( pt5, pzdir, 1, 3 ); 01646 CHECK( !iter.intersect_ray( pt5, nzdir, t_in, t_out ) ); 01647 01648 // point right of box 01649 const double pt6[] = { 7, 2, -2 }; 01650 CHECK( !iter.intersect_ray( pt6, dir1, t_in, t_out ) ); 01651 CHECK( !iter.intersect_ray( pt6, dir2, t_in, t_out ) ); 01652 CHECK( !iter.intersect_ray( pt6, pxdir, t_in, t_out ) ); 01653 CHECK_RAY_XSECTS( pt6, nxdir, 2, 5 ); 01654 CHECK( !iter.intersect_ray( pt6, pydir, t_in, t_out ) ); 01655 CHECK( !iter.intersect_ray( pt6, nydir, t_in, t_out ) ); 01656 CHECK( !iter.intersect_ray( pt6, pzdir, t_in, t_out ) ); 01657 CHECK( !iter.intersect_ray( pt6, nzdir, t_in, t_out ) ); 01658 01659 // a few more complex test cases 01660 const double dird[] = { -2, -2, 0 }; 01661 CHECK_RAY_XSECTS( pt6, dird, 0.5, 0.5 ); 01662 const double dire[] = { -3, -2, 0 }; 01663 CHECK_RAY_XSECTS( pt6, dire, 0.4, 0.5 ); 01664 const double dirf[] = { -2, -2.1, 0 }; 01665 CHECK( !iter.intersect_ray( pt6, dirf, t_in, t_out ) ); 01666 } 01667 01668 static void box( const double pts[], int num_pts, double minpt[3], double maxpt[3] ) 01669 { 01670 minpt[0] = maxpt[0] = pts[0]; 01671 minpt[1] = maxpt[1] = pts[1]; 01672 minpt[2] = maxpt[2] = pts[2]; 01673 for( int i = 1; i < num_pts; ++i ) 01674 { 01675 for( int d = 0; d < 3; ++d ) 01676 { 01677 if( pts[3 * i + d] < minpt[d] ) minpt[d] = pts[3 * i + d]; 01678 if( pts[3 * i + d] > maxpt[d] ) maxpt[d] = pts[3 * i + d]; 01679 } 01680 } 01681 } 01682 01683 static EntityHandle build_tree( const double points[], int num_points, BSPTree& tool ) 01684 { 01685 // create points 01686 ErrorCode rval; 01687 std::vector< EntityHandle > pts( num_points ); 01688 for( int i = 0; i < num_points; ++i ) 01689 { 01690 rval = tool.moab()->create_vertex( points + 3 * i, pts[i] );CHECK_ERR( rval ); 01691 } 01692 01693 // calculate bounding box of tree 01694 double minpt[3], maxpt[3]; 01695 box( points, num_points, minpt, maxpt ); 01696 01697 // create initial (1-node) tree 01698 EntityHandle root; 01699 rval = tool.create_tree( minpt, maxpt, root );CHECK_ERR( rval ); 01700 01701 BSPTreeIter iter; 01702 rval = tool.get_tree_iterator( root, iter );CHECK_ERR( rval ); 01703 01704 rval = tool.moab()->add_entities( root, &pts[0], pts.size() );CHECK_ERR( rval ); 01705 01706 // build tree 01707 std::vector< EntityHandle > left_pts, right_pts; 01708 std::vector< CartVect > coords( num_points ), tmp_coords; 01709 for( ; MB_SUCCESS == rval; rval = iter.step() ) 01710 { 01711 pts.clear(); 01712 rval = tool.moab()->get_entities_by_handle( iter.handle(), pts );CHECK_ERR( rval ); 01713 while( pts.size() > 1 ) 01714 { 01715 01716 coords.resize( pts.size() ); 01717 rval = tool.moab()->get_coords( &pts[0], pts.size(), coords[0].array() );CHECK_ERR( rval ); 01718 01719 // find two points far apart apart 01720 std::vector< CartVect >* ptr; 01721 if( coords.size() < 10 ) 01722 ptr = &coords; 01723 else 01724 { 01725 tmp_coords.resize( 16 ); 01726 CartVect pn, px; 01727 box( coords[0].array(), coords.size(), pn.array(), px.array() ); 01728 tmp_coords[8] = pn; 01729 tmp_coords[9] = CartVect( px[0], pn[1], pn[2] ); 01730 tmp_coords[10] = CartVect( px[0], px[1], pn[2] ); 01731 tmp_coords[11] = CartVect( pn[0], px[1], pn[2] ); 01732 tmp_coords[12] = CartVect( pn[0], pn[1], px[2] ); 01733 tmp_coords[13] = CartVect( px[0], pn[1], px[2] ); 01734 tmp_coords[14] = px; 01735 tmp_coords[15] = CartVect( pn[0], px[1], px[2] ); 01736 for( int i = 0; i < 8; ++i ) 01737 { 01738 tmp_coords[i] = coords[0]; 01739 for( size_t j = 1; j < coords.size(); ++j ) 01740 if( ( coords[j] - tmp_coords[i + 8] ).length_squared() < 01741 ( tmp_coords[i] - tmp_coords[i + 8] ).length_squared() ) 01742 tmp_coords[i] = coords[j]; 01743 } 01744 tmp_coords.resize( 8 ); 01745 ptr = &tmp_coords; 01746 } 01747 01748 size_t pt1 = 0, pt2 = 0; 01749 double lsqr = -1; 01750 for( size_t i = 0; i < ptr->size(); ++i ) 01751 { 01752 for( size_t j = 0; j < ptr->size(); ++j ) 01753 { 01754 double ls = ( ( *ptr )[i] - ( *ptr )[j] ).length_squared(); 01755 if( ls > lsqr ) 01756 { 01757 lsqr = ls; 01758 pt1 = i; 01759 pt2 = j; 01760 } 01761 } 01762 } 01763 01764 // if all points are coincident 01765 if( lsqr <= 1e-12 ) break; 01766 01767 // define normal orthogonal to line through two points 01768 CartVect norm = ( *ptr )[pt1] - ( *ptr )[pt2]; 01769 norm.normalize(); 01770 01771 // find mean position for plane 01772 double coeff = 0.0; 01773 for( size_t i = 0; i < coords.size(); ++i ) 01774 coeff -= norm % coords[i]; 01775 coeff /= coords.size(); 01776 01777 // left/right sort points 01778 left_pts.clear(); 01779 right_pts.clear(); 01780 for( size_t i = 0; i < coords.size(); ++i ) 01781 { 01782 double d = -( norm % coords[i] ); 01783 if( d >= coeff ) 01784 left_pts.push_back( pts[i] ); 01785 else 01786 right_pts.push_back( pts[i] ); 01787 } 01788 01789 rval = tool.split_leaf( iter, BSPTree::Plane( norm.array(), coeff ), left_pts, right_pts );CHECK_ERR( rval ); 01790 CHECK( !left_pts.empty() && !right_pts.empty() ); 01791 pts.swap( left_pts ); 01792 } 01793 01794 // printf("Leaf %d contains %d vertices: ", (int)ID_FROM_HANDLE(iter.handle()), 01795 // (int)(pts.size()) ); 01796 // for (size_t i = 0; i < pts.size(); ++i) 01797 // printf( "%d, ", (int)ID_FROM_HANDLE(pts[i])); 01798 // printf("\n"); 01799 } 01800 01801 CHECK( rval == MB_ENTITY_NOT_FOUND ); 01802 01803 // verify that tree is constructed correctly 01804 for( int i = 0; i < num_points; ++i ) 01805 { 01806 CartVect pt( points + 3 * i ); 01807 EntityHandle leaf; 01808 rval = tool.leaf_containing_point( root, pt.array(), leaf );CHECK_ERR( rval ); 01809 Range ents; 01810 rval = tool.moab()->get_entities_by_handle( leaf, ents );CHECK_ERR( rval ); 01811 bool found = false; 01812 for( Range::iterator j = ents.begin(); j != ents.end(); ++j ) 01813 { 01814 CartVect ent_coords; 01815 rval = tool.moab()->get_coords( &*j, 1, ent_coords.array() );CHECK_ERR( rval ); 01816 if( ( pt - ent_coords ).length_squared() < 1e-6 ) found = true; 01817 } 01818 CHECK( found ); 01819 } 01820 01821 return root; 01822 } 01823 01824 void test_leaf_polyhedron() 01825 { 01826 // array of 20 points used to construct tree 01827 static const double points[] = { 7, 6, 3, 5, 3, 5, 9, 2, 6, 7, 2, 1, 3, 9, 0, 6, 0, 6, 1, 6, 01828 2, 9, 7, 8, 2, 0, 2, 5, 7, 3, 2, 2, 9, 7, 9, 8, 1, 6, 3, 3, 01829 9, 2, 4, 9, 1, 4, 8, 7, 3, 0, 5, 0, 1, 6, 2, 3, 6, 1, 6, 0 }; 01830 const int num_pts = sizeof( points ) / ( 3 * sizeof( double ) ); 01831 01832 ErrorCode rval; 01833 Core moab; 01834 BSPTree tool( &moab ); 01835 EntityHandle root = build_tree( points, num_pts, tool ); 01836 01837 BSPTreeIter iter; 01838 rval = tool.get_tree_iterator( root, iter );CHECK_ERR( rval ); 01839 01840 std::vector< EntityHandle > pts; 01841 std::vector< CartVect > coords; 01842 01843 for( ; rval == MB_SUCCESS; rval = iter.step() ) 01844 { 01845 BSPTreePoly poly; 01846 rval = iter.calculate_polyhedron( poly );CHECK_ERR( rval ); 01847 01848 CHECK( poly.is_valid() ); 01849 CHECK( poly.volume() > 0.0 ); 01850 01851 pts.clear(); 01852 rval = tool.moab()->get_entities_by_handle( iter.handle(), pts );CHECK_ERR( rval ); 01853 CHECK( !pts.empty() ); 01854 coords.resize( pts.size() ); 01855 rval = tool.moab()->get_coords( &pts[0], pts.size(), coords[0].array() );CHECK_ERR( rval ); 01856 01857 for( size_t i = 0; i < pts.size(); ++i ) 01858 CHECK( poly.is_point_contained( coords[i] ) ); 01859 } 01860 }
