MOAB: Mesh Oriented datABase
(version 5.4.1)
#include <ReaderWriterSet.hpp>
Collaboration diagram for moab::ReaderWriterSet::Handler:Public Member Functions | |
| Handler (reader_factory_t read_f, writer_factory_t write_f, const char *name, const char *desc, const char *const *ext, int num_ext) | |
| const std::string & | name () const |
| const std::string & | description () const |
| void | get_extensions (std::vector< std::string > &list_out) const |
| bool | have_reader () const |
| bool | have_writer () const |
| ReaderIface * | make_reader (Interface *iface) const |
| WriterIface * | make_writer (Interface *iface) const |
| bool | reads_extension (const char *ext) const |
| bool | writes_extension (const char *ext) const |
| bool | operator== (const char *name) const |
Private Attributes | |
| reader_factory_t | mReader |
| writer_factory_t | mWriter |
| std::string | mName |
| std::string | mDescription |
| std::vector< std::string > | mExtensions |
Friends | |
| class | ReaderWriterSet |
Definition at line 103 of file ReaderWriterSet.hpp.
| moab::ReaderWriterSet::Handler::Handler | ( | reader_factory_t | read_f, |
| writer_factory_t | write_f, | ||
| const char * | name, | ||
| const char * | desc, | ||
| const char *const * | ext, | ||
| int | num_ext | ||
Definition at line 248 of file ReaderWriterSet.cpp.
References mExtensions.
: mReader( read_f ), mWriter( write_f ), mName( nm ), mDescription( desc ), mExtensions( num_ext ) { for( int i = 0; i < num_ext; ++i ) mExtensions[i] = ext[i]; }
| const std::string& moab::ReaderWriterSet::Handler::description | ( | ) | const [inline] |
Definition at line 120 of file ReaderWriterSet.hpp.
References mDescription.
return mDescription;
| void moab::ReaderWriterSet::Handler::get_extensions | ( | std::vector< std::string > & | list_out | ) | const [inline] |
Definition at line 124 of file ReaderWriterSet.hpp.
list_out = mExtensions;
| bool moab::ReaderWriterSet::Handler::have_reader | ( | ) | const [inline] |
Definition at line 129 of file ReaderWriterSet.hpp.
References mReader.
Referenced by make_reader().
return NULL != mReader;
| bool moab::ReaderWriterSet::Handler::have_writer | ( | ) | const [inline] |
Definition at line 133 of file ReaderWriterSet.hpp.
References mWriter.
Referenced by make_writer().
return NULL != mWriter;
| ReaderIface* moab::ReaderWriterSet::Handler::make_reader | ( | Interface * | iface | ) | const [inline] |
Definition at line 138 of file ReaderWriterSet.hpp.
References have_reader(), and mReader.
return have_reader() ? mReader( iface ) : NULL;
| WriterIface* moab::ReaderWriterSet::Handler::make_writer | ( | Interface * | iface | ) | const [inline] |
Definition at line 143 of file ReaderWriterSet.hpp.
References have_writer(), and mWriter.
return have_writer() ? mWriter( iface ) : NULL;
| const std::string& moab::ReaderWriterSet::Handler::name | ( | ) | const [inline] |
| bool moab::ReaderWriterSet::Handler::operator== | ( | const char * | name | ) | const |
Definition at line 325 of file ReaderWriterSet.cpp.
| bool moab::ReaderWriterSet::Handler::reads_extension | ( | const char * | ext | ) | const |
Definition at line 292 of file ReaderWriterSet.cpp.
if( !have_reader() ) return false;
std::vector< std::string >::const_iterator siter;
for( siter = mExtensions.begin(); siter != mExtensions.end(); ++siter )
if( !( *siter ).compare( ext ) )
return true;
else if( 0 == strcasecmp( siter->c_str(), ext ) )
return true;
return false;
| bool moab::ReaderWriterSet::Handler::writes_extension | ( | const char * | ext | ) | const |
Definition at line 306 of file ReaderWriterSet.cpp.
if( !have_writer() ) return false;
return true;
return true;
return false;
friend class ReaderWriterSet [friend] |
Definition at line 106 of file ReaderWriterSet.hpp.
std::string moab::ReaderWriterSet::Handler::mDescription [private] |
Definition at line 157 of file ReaderWriterSet.hpp.
Referenced by description().
std::vector< std::string > moab::ReaderWriterSet::Handler::mExtensions [private] |
Definition at line 158 of file ReaderWriterSet.hpp.
Referenced by get_extensions(), and Handler().
std::string moab::ReaderWriterSet::Handler::mName [private] |
Referenced by name().
Definition at line 154 of file ReaderWriterSet.hpp.
Referenced by have_reader(), and make_reader().
Definition at line 155 of file ReaderWriterSet.hpp.
Referenced by have_writer(), and make_writer().
