smoab::detail::LoadPoly Class Reference
#include <LoadPoly.h>
+ Collaboration diagram for smoab::detail::LoadPoly:
Public Member Functions
 LoadPoly (const smoab::Range &cells, const smoab::Interface &interface)
const smoab::Range & moabPoints () const
void fill (vtkPolyData *dataSet)
Private Member Functions
void addCoordinates (vtkPointSet *grid)
void addGridsTopology (vtkPolyData *data, vtkIdType numCells, vtkIdType numConnectivity) const
Private Attributes
moab::Interface * Interface
smoab::detail::LinearCellConnectivity CellConn
smoab::Range Points
Detailed Description
Definition at line 23 of file LoadPoly.h.
smoab::detail::LoadPoly::LoadPoly ( const smoab::Range &  cells,
const smoab::Interface &  interface
) [inline]
Definition at line 32 of file LoadPoly.h.
            : Interface( interface.Moab ), CellConn( cells, interface.Moab ), Points()
Member Function Documentation
void smoab::detail::LoadPoly::addCoordinates ( vtkPointSet *  grid) [inline, private]
Definition at line 57 of file LoadPoly.h.
References CellConn, smoab::detail::LinearCellConnectivity::moabPoints(), Points, and moab::Range::size().
Referenced by fill().
            //this is sorta of hackish as moabPoints is only valid
            //after compactIds has been called
            this->CellConn.moabPoints( this->Points );
            //since the smoab::range are always unique and sorted
            //we can use the more efficient coords_iterate
            //call in moab, which returns moab internal allocated memory
            vtkNew< vtkPoints > newPoints;
            newPoints->SetDataTypeToDouble();
            newPoints->SetNumberOfPoints( this->Points.size() );
            //need a pointer to the allocated vtkPoints memory so that we
            //don't need to use an extra copy and we can bypass all vtk's check
            //on out of bounds
            double* rawPoints = static_cast< double* >( newPoints->GetVoidPointer( 0 ) );
            this->Interface->get_coords( this->Points, rawPoints );
            grid->SetPoints( newPoints.GetPointer() );
void smoab::detail::LoadPoly::addGridsTopology ( vtkPolyData *  data,
vtkIdType  numCells,
) const [inline, private]
Definition at line 80 of file LoadPoly.h.
References CellConn, and smoab::detail::LinearCellConnectivity::copyToVtkCellInfo().
            //correct the connectivity size to account for the vtk padding
            const vtkIdType vtkConnectivity = numCells + numConnectivity;
            vtkNew< vtkIdTypeArray > cellArray;
            cellArray->SetNumberOfValues( vtkConnectivity );
            vtkIdType* rawArray = static_cast< vtkIdType* >( cellArray->GetVoidPointer( 0 ) );
            this->CellConn.copyToVtkCellInfo( rawArray );
            vtkNew< vtkCellArray > cells;
            cells->SetCells( numCells, cellArray.GetPointer() );
            data->SetPolys( cells.GetPointer() );
void smoab::detail::LoadPoly::fill ( vtkPolyData *  dataSet) [inline]
Definition at line 44 of file LoadPoly.h.
References addCoordinates(), addGridsTopology(), CellConn, and smoab::detail::LinearCellConnectivity::compactIds().
            //now that CellConn has all the cells properly stored, lets fixup
            //the ids so that they start at zero and keep the same logical ordering
            //as before.
            vtkIdType numCells, connLen;
            this->CellConn.compactIds( numCells, connLen );
            this->addGridsTopology( dataSet, numCells, connLen );
            this->addCoordinates( dataSet );
Definition at line 37 of file LoadPoly.h.
References Points.
            return this->Points;
Member Data Documentation
Definition at line 25 of file LoadPoly.h.
Definition at line 27 of file LoadPoly.h.
Referenced by addCoordinates(), and moabPoints().
List of all members.
