moab::HalfFacetRep Class Reference
#include <HalfFacetRep.hpp>
+ Collaboration diagram for moab::HalfFacetRep:
Classes
struct  adj_matrix
struct  LocalMaps2D
 2D local maps More...
struct  LocalMaps3D
 3D local maps More...
Public Member Functions
 HalfFacetRep (Core *impl, ParallelComm *comm=0, moab::EntityHandle rset=0, bool filter_ghosts=true)
 ~HalfFacetRep ()
bool check_mixed_entity_type ()
ErrorCode initialize ()
ErrorCode deinitialize ()
 Deinitialize.
ErrorCode print_tags (int dim)
 Prints the tag values.
ErrorCode get_adjacencies (const EntityHandle source_entity, const unsigned int target_dimension, std::vector< EntityHandle > &target_entities)
 Get the adjacencies associated with an entity.
ErrorCode get_up_adjacencies (EntityHandle ent, int out_dim, std::vector< EntityHandle > &adjents, std::vector< int > *lids=NULL)
 Get the upward incidences associated with an entity.
ErrorCode get_neighbor_adjacencies (EntityHandle ent, std::vector< EntityHandle > &adjents)
 Get the same-dimensional entities connected with an entity.
ErrorCode get_down_adjacencies (EntityHandle ent, int out_dim, std::vector< EntityHandle > &adjents)
 Get the downward adjacent entities connected with an entity.
ErrorCode determine_sibling_halfverts (Range &verts, Range &edges)
ErrorCode determine_incident_halfverts (Range &edges)
ErrorCode get_up_adjacencies_1d (EntityHandle vid, std::vector< EntityHandle > &adjents, std::vector< int > *lvids=NULL)
 Given a vertex, finds the edges incident on it.
ErrorCode get_neighbor_adjacencies_1d (EntityHandle eid, std::vector< EntityHandle > &adjents)
 Given an edge, finds vertex-connected neighbor edges.
ErrorCode determine_sibling_halfedges (Range &faces)
ErrorCode determine_incident_halfedges (Range &faces)
ErrorCode get_up_adjacencies_vert_2d (EntityHandle vid, std::vector< EntityHandle > &adjents)
 Given a vertex, finds the faces incident on it.
ErrorCode get_up_adjacencies_2d (EntityHandle eid, std::vector< EntityHandle > &adjents, std::vector< int > *leids=NULL)
 Given an edge, finds the faces incident on it.
ErrorCode get_up_adjacencies_2d (EntityHandle fid, int leid, bool add_inent, std::vector< EntityHandle > &adj_ents, std::vector< int > *adj_leids=NULL, std::vector< int > *adj_orients=NULL)
 Given a half-edge <fid, leid>, finds the faces incident on it.
ErrorCode get_neighbor_adjacencies_2d (EntityHandle fid, std::vector< EntityHandle > &adjents)
 Given an edge, finds edge-connected neighbor face.
ErrorCode get_down_adjacencies_2d (EntityHandle fid, std::vector< EntityHandle > &adjents)
 Given a face, finds its edges.
int find_total_edges_2d (Range &faces)
 Given a range of faces, finds the total number of edges.
ErrorCode get_face_edges (EntityHandle fid, std::vector< EntityHandle > &edges)
ErrorCode determine_sibling_halffaces (Range &cells)
ErrorCode determine_incident_halffaces (Range &cells)
ErrorCode determine_border_vertices (Range &cells, Tag isborder)
 Given a range of cells, tags all border vertices with a true value.
ErrorCode get_up_adjacencies_vert_3d (EntityHandle vid, std::vector< EntityHandle > &adjents)
 Given a vertex, finds the cells incident on it.
ErrorCode get_up_adjacencies_edg_3d (EntityHandle eid, std::vector< EntityHandle > &adjents, std::vector< int > *leids=NULL)
 Given an edge, finds the cells incident on it.
ErrorCode get_up_adjacencies_edg_3d (EntityHandle cid, int leid, std::vector< EntityHandle > &adjents, std::vector< int > *leids=NULL, std::vector< int > *adj_orients=NULL)
 Given a local edge <cid, leid>, finds the cells incident on it.
ErrorCode get_up_adjacencies_edg_3d_comp (EntityHandle cid, int leid, std::vector< EntityHandle > &adjents, std::vector< int > *leids=NULL, std::vector< int > *adj_orients=NULL)
ErrorCode get_up_adjacencies_face_3d (EntityHandle fid, std::vector< EntityHandle > &adjents, std::vector< int > *lfids=NULL)
 Given an face, finds the cells incident on it.
ErrorCode get_up_adjacencies_face_3d (EntityHandle cid, int lfid, std::vector< EntityHandle > &adjents, std::vector< int > *lfids=NULL)
 Given a local face <cid, lfid>, finds the cells incident on it.
ErrorCode get_neighbor_adjacencies_3d (EntityHandle cid, std::vector< EntityHandle > &adjents)
 Given a cell, finds face-connected neighbor cells.
ErrorCode get_down_adjacencies_edg_3d (EntityHandle cid, std::vector< EntityHandle > &adjents)
 Given a cell, finds its edges.
ErrorCode get_down_adjacencies_face_3d (EntityHandle cid, std::vector< EntityHandle > &adjents)
 Given a cell, finds its faces.
ErrorCode find_total_edges_faces_3d (const Range &cells, int *nedges, int *nfaces)
ErrorCode count_subentities (Range &edges, Range &faces, Range &cells, int *nedges, int *nfaces)
void get_memory_use (unsigned long long &entity_total, unsigned long long &memory_total)
ErrorCode get_half_facet_in_comp (EntityHandle cid, int leid, std::vector< EntityHandle > &ents, std::vector< int > &lids, std::vector< int > &lfids)
HFacet create_halffacet (EntityHandle handle, int lid)
EntityHandle fid_from_halfacet (const HFacet facet, EntityType type)
int lid_from_halffacet (const HFacet facet)
ErrorCode update_entity_ranges (EntityHandle fileset)
ErrorCode resize_hf_maps (EntityHandle start_vert, int nverts, EntityHandle start_edge, int nedges, EntityHandle start_face, int nfaces, EntityHandle start_cell, int ncells)
ErrorCode get_sibling_map (EntityType type, EntityHandle ent, EntityHandle *sib_entids, int *sib_lids, int num_halffacets)
ErrorCode get_sibling_map (EntityType type, EntityHandle ent, int lid, EntityHandle &sib_entid, int &sib_lid)
ErrorCode set_sibling_map (EntityType type, EntityHandle ent, EntityHandle *set_entids, int *set_lids, int num_halffacets)
ErrorCode set_sibling_map (EntityType type, EntityHandle ent, int lid, EntityHandle &set_entid, int &set_lid)
ErrorCode get_incident_map (EntityType type, EntityHandle vid, std::vector< EntityHandle > &inci_entid, std::vector< int > &inci_lid)
ErrorCode set_incident_map (EntityType type, EntityHandle vid, std::vector< EntityHandle > &set_entid, std::vector< int > &set_lid)
bool check_nonmanifold_vertices (EntityType type, EntityHandle vid)
int get_index_in_lmap (EntityHandle cid)
ErrorCode get_entity_ranges (Range &verts, Range &edges, Range &faces, Range &cells)
MESHTYPE get_mesh_type (int nverts, int nedges, int nfaces, int ncells)
EntityHandle * get_rset ()
Public Attributes
MESHTYPE thismeshtype
std::map< EntityType, int > cell_index
Static Public Attributes
static const LocalMaps2D lConnMap2D [2]
static const LocalMaps3D lConnMap3D [4]
Protected Member Functions
 HalfFacetRep ()
int get_index_for_meshtype (MESHTYPE mesh_type)
ErrorCode init_curve ()
ErrorCode init_surface ()
ErrorCode init_volume ()
ErrorCode get_up_adjacencies_2d (EntityHandle he_fid, int he_lid, int *qsize, int *count)
 Contains the local information for 2D entities.
bool find_matching_halfedge (EntityHandle eid, EntityHandle *hefid, int *helid)
 Given an edge, finds a matching half-edge in the surface.
ErrorCode gather_halfedges (EntityHandle vid, EntityHandle he_fid, int he_lid, int *qsize, int *count)
 Gather half-edges to a queue of half-edges.
ErrorCode another_halfedge (EntityHandle vid, EntityHandle he_fid, int he_lid, EntityHandle *he2_fid, int *he2_lid)
 Obtains another half-edge belonging to the same face as the input half-edge.
ErrorCode mark_halfedges (EntityHandle vid, EntityHandle he_fid, int he_lid, Range &faces, std::vector< char > &markHEdgs, HFacet &bnd_hf)
bool collect_and_compare (const EntityHandle vid, const EntityHandle *edg_vert, int *qsize, int *count, EntityHandle *he_fid, int *he_lid)
 Collect and compare to find a matching half-edge with the given edge connectivity.
ErrorCode add_cells_of_single_component (EntityHandle vid, EntityHandle curcid, int curlid, std::multimap< EntityHandle, EntityHandle > &comps, HFacet &hf)
bool find_cell_in_component (EntityHandle vid, EntityHandle cell, std::multimap< EntityHandle, EntityHandle > &comps)
bool find_matching_implicit_edge_in_cell (EntityHandle eid, std::vector< EntityHandle > &cid, std::vector< int > &leid)
 Given an edge, finds a matching local edge in an incident cell.
bool find_matching_halfface (EntityHandle fid, EntityHandle *cid, int *leid)
 Given a face, finds a matching local face in an incident cell.
bool find_match_in_array (EntityHandle ent, EntityHandle *ent_list, int count, bool get_index=false, int *index=NULL)
Protected Attributes
Core * mb
ParallelComm * pcomm
EntityHandle _rset
bool _filterghost
bool mInitAHFmaps
Range _verts
Range _edges
Range _faces
Range _cells
std::vector< HFacet > sibhvs
std::vector< HFacet > v2hv
std::vector< HFacet > sibhes
std::vector< HFacet > v2he
std::vector< HFacet > sibhfs
std::vector< HFacet > v2hf
HFacet >
v2hes
HFacet >
v2hfs
EntityHandle queue_fid [MAXSIZE]
EntityHandle Stkcells [MAXSIZE]
EntityHandle cellq [MAXSIZE]
EntityHandle trackfaces [MAXSIZE]
EntityHandle trackcells [MAXSIZE]
int queue_lid [MAXSIZE]
bool is_mixed
bool chk_mixed
Static Protected Attributes
static const adj_matrix adjMatrix [7]
Detailed Description
Definition at line 76 of file HalfFacetRep.hpp.
moab::HalfFacetRep::HalfFacetRep ( Core *  impl,
ParallelComm *  comm = 0,
moab::EntityHandle  rset = 0,
bool  filter_ghosts = true
Definition at line 45 of file HalfFacetRep.cpp.
References chk_mixed, is_mixed, and mInitAHFmaps.
    : thismeshtype( CURVE ), mb( impl ), pcomm( comm ), _rset( rset ), _filterghost( filter_ghosts )
    assert( NULL != impl );
    mInitAHFmaps = false;
    chk_mixed    = false;
    is_mixed     = false;
Definition at line 54 of file HalfFacetRep.cpp.
Member Function Documentation
ErrorCode moab::HalfFacetRep::add_cells_of_single_component ( EntityHandle  vid,
int  curlid,
std::multimap< EntityHandle, EntityHandle > &  comps,
HFacet &  hf
) [protected]
Definition at line 1960 of file HalfFacetRep.cpp.
References create_halffacet(), moab::error(), ErrorCode, fid_from_halfacet(), find_match_in_array(), moab::Core::get_connectivity(), get_index_in_lmap(), moab::ID_FROM_HANDLE(), lConnMap3D, mb, MB_CHK_ERR, MB_SET_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::HalfFacetRep::LocalMaps3D::num_verts_in_cell, sibhfs, Stkcells, trackcells, moab::Core::type_from_handle(), moab::HalfFacetRep::LocalMaps3D::v2hf, and moab::HalfFacetRep::LocalMaps3D::v2hf_num.
Referenced by determine_incident_halffaces().
    ErrorCode error;
    EntityType ctype = mb->type_from_handle( curcid );
    int index        = get_index_in_lmap( curcid );
    int nvpc         = lConnMap3D[index].num_verts_in_cell;
    int nfpc         = lConnMap3D[index].num_faces_in_cell;
    int Stksize = 0, count = -1;
    Stkcells[0] = curcid;
    hf = create_halffacet( curcid, curlid );
    EntityHandle cur_cid;
    while( Stksize >= 0 )
        cur_cid = Stkcells[Stksize];
        Stksize -= 1;
        bool found = find_match_in_array( cur_cid, trackcells, count );
        if( !found )
            count += 1;
            trackcells[count] = cur_cid;
            // Add the current cell
            comps.insert( std::pair< EntityHandle, EntityHandle >( vid, cur_cid ) );
        // Connectivity of the cell
        const EntityHandle* conn;
        error = mb->get_connectivity( cur_cid, conn, nvpc, true );MB_CHK_ERR( error );
        // Local id of vid in the cell and the half-faces incident on it
        int lv = -1;
        for( int i = 0; i < nvpc; ++i )
            if( conn[i] == vid )
                lv = i;
                break;
        if( lv < 0 ) MB_SET_ERR( MB_FAILURE, "did not find local vertex " );
        int nhf_thisv = lConnMap3D[index].v2hf_num[lv];
        int cidx      = ID_FROM_HANDLE( cur_cid ) - 1;
        // Add new cells into the stack
        EntityHandle ngb;
        HFacet hf_ngb;
        for( int i = 0; i < nhf_thisv; ++i )
            int ind = lConnMap3D[index].v2hf[lv][i];
            hf_ngb  = sibhfs[nfpc * cidx + ind];
            ngb     = fid_from_halfacet( hf_ngb, ctype );
            if( ngb )
                bool found_ent = find_match_in_array( ngb, trackcells, count );
                if( !found_ent )
                    Stksize += 1;
                    Stkcells[Stksize] = ngb;
            else
                hf = create_halffacet( cur_cid, ind );
    // Change the visited faces to false
    for( int i = 0; i < Stksize; i++ )
        Stkcells[i] = 0;
    for( int i = 0; i <= count; i++ )
        trackcells[i] = 0;
    return MB_SUCCESS;
ErrorCode moab::HalfFacetRep::another_halfedge ( EntityHandle  vid,
int  he_lid,
EntityHandle *  he2_fid,
int *  he2_lid
) [protected]
It uses the local maps to find another half-edge that is either incident or outgoing depending on vid and input half-edge
Definition at line 1392 of file HalfFacetRep.cpp.
References moab::error(), ErrorCode, moab::Core::get_connectivity(), lConnMap2D, mb, MB_CHK_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps2D::next, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, moab::HalfFacetRep::LocalMaps2D::prev, and moab::Core::type_from_handle().
Referenced by collect_and_compare(), gather_halfedges(), get_up_adjacencies_vert_2d(), and mark_halfedges().
    ErrorCode error;
    EntityType ftype = mb->type_from_handle( he_fid );
    int nepf         = lConnMap2D[ftype - 2].num_verts_in_face;
    error = mb->get_connectivity( he_fid, conn, nepf, true );MB_CHK_ERR( error );
    *he2_fid = he_fid;
    if( conn[he_lid] == vid )
        *he2_lid = lConnMap2D[ftype - 2].prev[he_lid];
    else
        *he2_lid = lConnMap2D[ftype - 2].next[he_lid];
    return MB_SUCCESS;
Definition at line 131 of file HalfFacetRep.cpp.
References _rset, chk_mixed, moab::Range::empty(), moab::error(), ErrorCode, moab::ScdInterface::find_boxes(), moab::Core::get_entities_by_dimension(), is_mixed, mb, MB_CHK_ERR, MBHEX, MBPOLYGON, MBPOLYHEDRON, MBPRISM, MBPYRAMID, MBQUAD, MBTET, MBTRI, moab::Interface::query_interface(), moab::Range::size(), and moab::Range::subset_by_type().
Referenced by moab::NestedRefine::initialize().
    if( !chk_mixed )
        chk_mixed = true;
        ErrorCode error;
        Range felems, celems;
        error = mb->get_entities_by_dimension( this->_rset, 2, felems );MB_CHK_ERR( error );
        if( felems.size() )
            Range tris, quad, poly;
            tris = felems.subset_by_type( MBTRI );
            quad = felems.subset_by_type( MBQUAD );
            poly = felems.subset_by_type( MBPOLYGON );
            if( ( tris.size() && quad.size() ) || ( tris.size() && poly.size() ) || ( quad.size() && poly.size() ) )
                is_mixed = true;
            if( poly.size() ) is_mixed = true;
            if( is_mixed ) return is_mixed;
        error = mb->get_entities_by_dimension( this->_rset, 3, celems );MB_CHK_ERR( error );
        if( celems.size() )
            Range tet, pyr, prism, hex, polyhed;
            tet     = celems.subset_by_type( MBTET );
            pyr     = celems.subset_by_type( MBPYRAMID );
            prism   = celems.subset_by_type( MBPRISM );
            hex     = celems.subset_by_type( MBHEX );
            polyhed = celems.subset_by_type( MBPOLYHEDRON );
            if( ( tet.size() && pyr.size() ) || ( tet.size() && prism.size() ) || ( tet.size() && hex.size() ) ||
                ( tet.size() && polyhed.size() ) || ( pyr.size() && prism.size() ) || ( pyr.size() && hex.size() ) ||
                ( pyr.size() && polyhed.size() ) || ( prism.size() && hex.size() ) ||
                ( prism.size() && polyhed.size() ) || ( hex.size() && polyhed.size() ) )
                is_mixed = true;
            if( polyhed.size() ) is_mixed = true;
        ScdInterface* scdi = NULL;
        error              = mb->query_interface( scdi );MB_CHK_ERR( error );
        if( scdi )
            Range boxes;
            error = scdi->find_boxes( boxes );MB_CHK_ERR( error );
            if( !boxes.empty() ) is_mixed = true;
    return is_mixed;
bool moab::HalfFacetRep::check_nonmanifold_vertices ( EntityType  type,
EntityHandle  vid
Definition at line 3357 of file HalfFacetRep.cpp.
References moab::ID_FROM_HANDLE(), MB_SET_ERR, MBHEX, MBQUAD, MBTET, MBTRI, v2he, v2hes, v2hf, and v2hfs.
Referenced by moab::NestedRefine::update_global_ahf_3D().
    bool status = false;
    if( type == MBTRI || type == MBQUAD )
        HFacet hf = v2he[ID_FROM_HANDLE( vid ) - 1];
        if( hf == 0 && ( v2hes.find( vid ) != v2hes.end() ) ) status = true;
    else if( type == MBTET || type == MBHEX )
        HFacet hf = v2hf[ID_FROM_HANDLE( vid ) - 1];
        if( hf == 0 && ( v2hfs.find( vid ) != v2hfs.end() ) ) status = true;
    else
        MB_SET_ERR( MB_FAILURE, "Requesting non-manifold vertex checks for either (1) 1D mesh or "
                                "(2) not-implemented entity types" );
    return status;
bool moab::HalfFacetRep::collect_and_compare ( const EntityHandle  vid,
const EntityHandle *  edg_vert,
int *  qsize,
int *  count,
EntityHandle *  he_fid,
int *  he_lid
) [protected]
Given edge connectivity, compare to an input list of half-edges to find a matching half-edge and add a list of half-edges belonging to the one-ring neighborhood to a queue till it finds a match.
Definition at line 1415 of file HalfFacetRep.cpp.
References _faces, another_halfedge(), moab::Range::begin(), moab::error(), ErrorCode, find_match_in_array(), moab::Core::get_connectivity(), get_up_adjacencies_2d(), lConnMap2D, moab::MAXSIZE, mb, MB_CHK_ERR, moab::HalfFacetRep::LocalMaps2D::next, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, queue_fid, queue_lid, trackfaces, and moab::Core::type_from_handle().
Referenced by find_matching_halfedge().
    ErrorCode error;
    EntityType ftype = mb->type_from_handle( *_faces.begin() );
    bool found    = false;
    int num_qvals = 0, counter = 0;
    while( num_qvals < *qsize && counter < MAXSIZE )
        EntityHandle curfid = queue_fid[num_qvals];
        int curlid          = queue_lid[num_qvals];
        num_qvals += 1;
        error = mb->get_connectivity( curfid, conn, nepf, true );MB_CHK_ERR( error );
        int id = lConnMap2D[ftype - 2].next[curlid];
        if( ( ( conn[curlid] == edg_vert[0] ) && ( conn[id] == edg_vert[1] ) ) ||
            ( ( conn[curlid] == edg_vert[1] ) && ( conn[id] == edg_vert[0] ) ) )
            *he_fid = curfid;
            *he_lid = curlid;
            found   = true;
            break;
        bool val = find_match_in_array( curfid, trackfaces, count[0] );
        if( val ) continue;
        count[0] += 1;
        trackfaces[*count] = curfid;
        EntityHandle he2_fid;
        int he2_lid;
        error = another_halfedge( vid, curfid, curlid, &he2_fid, &he2_lid );MB_CHK_ERR( error );
        error = get_up_adjacencies_2d( he2_fid, he2_lid, qsize, count );MB_CHK_ERR( error );
        counter += 1;
    return found;
ErrorCode moab::HalfFacetRep::count_subentities ( Range &  edges,
Range &  faces,
Range &  cells,
int *  nedges,
int *  nfaces
Definition at line 611 of file HalfFacetRep.cpp.
References moab::error(), ErrorCode, find_total_edges_2d(), find_total_edges_faces_3d(), MB_CHK_ERR, MB_SUCCESS, and moab::Range::size().
Referenced by moab::NestedRefine::count_subentities().
    ErrorCode error;
    if( edges.size() && !faces.size() && !cells.size() )
        nedges[0] = edges.size();
        nfaces[0] = 0;
    else if( faces.size() && !cells.size() )
        nedges[0] = find_total_edges_2d( faces );
        nfaces[0] = 0;
    else if( cells.size() )
        error = find_total_edges_faces_3d( cells, nedges, nfaces );MB_CHK_ERR( error );
    return MB_SUCCESS;
Deinitialize.
Definition at line 273 of file HalfFacetRep.cpp.
References MB_SUCCESS.
Referenced by ahf_test().
    return MB_SUCCESS;
Tag border vertices by using the sibhf_cid map. All vertices on half-faces with no sibling half-faces are considered as border vertices.
Parameters:
cellsRange of cells
isborder,:A dense tag over all vertices of size 1. Value is true for a border vertex, otherwise is false.
Definition at line 1920 of file HalfFacetRep.cpp.
References moab::Range::begin(), moab::Range::end(), moab::error(), ErrorCode, fid_from_halfacet(), moab::Core::get_connectivity(), get_index_in_lmap(), moab::HalfFacetRep::LocalMaps3D::hf2v, moab::HalfFacetRep::LocalMaps3D::hf2v_num, moab::ID_FROM_HANDLE(), lConnMap3D, mb, MB_CHK_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::HalfFacetRep::LocalMaps3D::num_verts_in_cell, sibhfs, t, moab::Core::tag_set_data(), and moab::Core::type_from_handle().
    ErrorCode error;
    EntityHandle start_cell = *cells.begin();
    EntityType ctype        = mb->type_from_handle( *cells.begin() );
    int index               = get_index_in_lmap( start_cell );
    int val = 1;
    for( Range::iterator t = cells.begin(); t != cells.end(); ++t )
        error = mb->get_connectivity( *t, conn, nvpc, true );MB_CHK_ERR( error );
        int cidx = ID_FROM_HANDLE( *t ) - 1;
        for( int i = 0; i < nfpc; ++i )
            HFacet hf            = sibhfs[nfpc * cidx + i];
            EntityHandle sib_cid = fid_from_halfacet( hf, ctype );
            if( sib_cid == 0 )
                int nvF = lConnMap3D[index].hf2v_num[i];
                for( int j = 0; j < nvF; ++j )
                    int ind = lConnMap3D[index].hf2v[i][j];
                    error   = mb->tag_set_data( isborder, &conn[ind], 1, &val );MB_CHK_ERR( error );
    return MB_SUCCESS;
Given a range of faces, determines the incident half-edges and stores them into V2HE_FID, V2HE_LEID tags. Compute a map between a vertex and an incident half-edge. This map is not always required, but is essential for local neighborhood searching as it acts like an anchor to start the search.
Parameters:
facesRange of faces
Definition at line 955 of file HalfFacetRep.cpp.
References moab::Range::begin(), create_halffacet(), moab::Range::end(), moab::error(), ErrorCode, moab::Core::get_connectivity(), moab::ID_FROM_HANDLE(), moab::Range::index(), lConnMap2D, mark_halfedges(), mb, MB_CHK_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, moab::Range::size(), moab::Core::type_from_handle(), v2he, and v2hes.
Referenced by init_surface().
    ErrorCode error;
    EntityType ftype = mb->type_from_handle( *faces.begin() );
    std::vector< char > markEdges( nepf * faces.size(), 0 );
    for( Range::iterator it = faces.begin(); it != faces.end(); ++it )
        EntityHandle fid = *it;
        error = mb->get_connectivity( fid, conn, nepf, true );MB_CHK_ERR( error );
        for( int i = 0; i < nepf; ++i )
            EntityHandle v = conn[i];
            int vidx       = ID_FROM_HANDLE( v ) - 1;
            HFacet hf      = v2he[vidx];
            if( hf == 0 && ( v2hes.empty() || ( v2hes.find( v ) == v2hes.end() ) ) )
                // This is the first time a half-facet is assigned to a vertex.
                HFacet nwhf = 0;
                error       = mark_halfedges( v, fid, i, faces, markEdges, nwhf );MB_CHK_ERR( error );
                if( nwhf == 0 ) nwhf = create_halffacet( fid, i );
                v2he[vidx] = nwhf;
            else if( hf != 0 && !markEdges[nepf * faces.index( fid ) + i] )
                // This is the first time a non-manifold vertex is encountered. Copy the existing he
                // in v2he[v] to the multimap.
                v2hes.insert( std::pair< EntityHandle, HFacet >( v, hf ) );
                HFacet nwhf = 0;
                v2hes.insert( std::pair< EntityHandle, HFacet >( v, nwhf ) );
                v2he[vidx] = 0;
            else if( hf == 0 && ( !v2hes.empty() ) && ( v2hes.find( v ) != v2hes.end() ) &&
                // This is check if reached if the vertex is non-manifold and has encountered a
                // half-facet to a new component.
                HFacet nwhf = 0;
    // error = print_tags(2);
    return MB_SUCCESS;
Given a range of cells, determines the incident half-faces and stores them into V2HF_CID, V2HF_LFID tags. Compute a map between a vertex and an incident half-face. This map is not always required, but is essential for local neighborhood searching as it acts like an anchor to start the search.
Parameters:
facesRange of cells
Definition at line 1867 of file HalfFacetRep.cpp.
References add_cells_of_single_component(), moab::Range::begin(), moab::Range::end(), moab::error(), ErrorCode, find_cell_in_component(), moab::Core::get_connectivity(), get_index_in_lmap(), moab::ID_FROM_HANDLE(), lConnMap3D, mb, MB_CHK_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps3D::num_verts_in_cell, v2hf, and v2hfs.
Referenced by init_volume().
    ErrorCode error;
    int index = get_index_in_lmap( *cells.begin() );
    std::multimap< EntityHandle, EntityHandle > comps;
    HFacet nwhf;
    for( Range::iterator cid = cells.begin(); cid != cells.end(); ++cid )
        EntityHandle cell = *cid;
        error = mb->get_connectivity( *cid, conn, nvpc, true );MB_CHK_ERR( error );
            HFacet hf      = v2hf[vidx];
            bool found = find_cell_in_component( v, cell, comps );
            if( hf == 0 && !found && ( v2hfs.empty() || ( v2hfs.find( v ) == v2hfs.end() ) ) )
                nwhf  = 0;
                error = add_cells_of_single_component( v, cell, lConnMap3D[index].v2hf[i][0], comps, nwhf );MB_CHK_ERR( error );
                v2hf[vidx] = nwhf;
            else if( hf != 0 && !found )
                nwhf  = 0;
                v2hfs.insert( std::pair< EntityHandle, HFacet >( v, hf ) );
                v2hfs.insert( std::pair< EntityHandle, HFacet >( v, nwhf ) );
                v2hf[vidx] = 0;
            else if( hf == 0 && !found && ( !v2hfs.empty() ) && ( v2hfs.find( v ) != v2hfs.end() ) )
                nwhf  = 0;
    // error = print_tags(3);
    return MB_SUCCESS;
Given a range of edges, determines the map for incident half-verts and stores them into V2HV_EID, V2HV_LVID tags. Compute a map between a vertex and an incident half-vertex. This map is not always required, but is essential for local neighborhood searching as it acts like an anchor to start the search.
Parameters:
edgesRange of edges
Definition at line 711 of file HalfFacetRep.cpp.
References moab::Range::begin(), create_halffacet(), moab::Range::end(), moab::error(), ErrorCode, fid_from_halfacet(), moab::Core::get_connectivity(), moab::ID_FROM_HANDLE(), mb, MB_CHK_ERR, MB_SUCCESS, MBEDGE, and v2hv.
Referenced by init_curve(), and moab::NestedRefine::update_ahf_1D().
    ErrorCode error;
    for( Range::iterator e_it = edges.begin(); e_it != edges.end(); ++e_it )
        EntityHandle cur_eid = *e_it;
        int num_conn = 0;
        error        = mb->get_connectivity( *e_it, conn, num_conn, true );MB_CHK_ERR( error );
        for( int i = 0; i < 2; ++i )
            HFacet hf        = v2hv[vidx];
            EntityHandle eid = fid_from_halfacet( hf, MBEDGE );
            if( eid == 0 )
                v2hv[vidx] = create_halffacet( cur_eid, i );
    return MB_SUCCESS;
Given a range of faces, determines the sibling half-edges and stores them into SIBHES_FID, SIBHES_LEID tags. Compute all sibling half-edges for all half-edges in the given surface. The sibling half-edges is defined in terms of the containing face and the local id of the edge w.r.t that entity. That is, the map consists of two pieces of information: <EntityHandle fid, int leid>
Parameters:
facesRange of faces
Definition at line 831 of file HalfFacetRep.cpp.
References _verts, moab::Range::begin(), create_halffacet(), moab::Range::end(), moab::error(), ErrorCode, fid_from_halfacet(), moab::Core::get_connectivity(), moab::ID_FROM_HANDLE(), moab::Range::index(), lConnMap2D, mb, MB_CHK_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps2D::next, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, sibhes, moab::Range::size(), and moab::Core::type_from_handle().
    ErrorCode error;
    EntityHandle start_face = *faces.begin();
    EntityType ftype        = mb->type_from_handle( start_face );
    int nfaces              = faces.size();
    // Step 1: Create an index list storing the starting position for each vertex
    int nv = _verts.size();
    std::vector< int > is_index( nv + 1 );
    for( int i = 0; i < nv + 1; i++ )
        is_index[i] = 0;
    int index;
    for( Range::iterator fid = faces.begin(); fid != faces.end(); ++fid )
        error = mb->get_connectivity( *fid, conn, nepf, true );MB_CHK_ERR( error );
        for( int i = 0; i < nepf; i++ )
            index = _verts.index( conn[i] );
            is_index[index + 1] += 1;
    is_index[0] = 0;
    for( int i = 0; i < nv; i++ )
        is_index[i + 1] = is_index[i] + is_index[i + 1];
    // Step 2: Define two arrays v2hv_eid, v2hv_lvid storing every half-facet on a vertex
    std::vector< EntityHandle > v2nv( nepf * nfaces );
    std::vector< EntityHandle > v2he_map_fid( nepf * nfaces );
    std::vector< int > v2he_map_leid( nepf * nfaces );
        for( int j = 0; j < nepf; j++ )
            int v                      = _verts.index( conn[j] );
            int nidx                   = lConnMap2D[ftype - 2].next[j];
            v2nv[is_index[v]]          = conn[nidx];
            v2he_map_fid[is_index[v]]  = *fid;
            v2he_map_leid[is_index[v]] = j;
            is_index[v] += 1;
    for( int i = nv - 2; i >= 0; i-- )
        is_index[i + 1] = is_index[i];
    is_index[0] = 0;
    // Step 3: Fill up sibling half-verts map
        int fidx = ID_FROM_HANDLE( *fid ) - 1;
        for( int k = 0; k < nepf; k++ )
            HFacet hf           = sibhes[nepf * fidx + k];
            EntityHandle sibfid = fid_from_halfacet( hf, ftype );
            if( sibfid != 0 ) continue;
            int nidx = lConnMap2D[ftype - 2].next[k];
            int v    = _verts.index( conn[k] );
            int vn   = _verts.index( conn[nidx] );
            EntityHandle first_fid = *fid;
            int first_leid         = k;
            EntityHandle prev_fid = *fid;
            int prev_leid         = k;
            for( index = is_index[vn]; index <= is_index[vn + 1] - 1; index++ )
                if( v2nv[index] == conn[k] )
                    EntityHandle cur_fid = v2he_map_fid[index];
                    int cur_leid         = v2he_map_leid[index];
                    int pidx                        = ID_FROM_HANDLE( prev_fid ) - 1;
                    sibhes[nepf * pidx + prev_leid] = create_halffacet( cur_fid, cur_leid );
                    prev_fid  = cur_fid;
                    prev_leid = cur_leid;
            for( index = is_index[v]; index <= is_index[v + 1] - 1; index++ )
                if( ( v2nv[index] == conn[nidx] ) && ( v2he_map_fid[index] != *fid ) )
                    prev_fid  = cur_fid;
            if( prev_fid != first_fid )
                sibhes[nepf * pidx + prev_leid] = create_halffacet( first_fid, first_leid );
    return MB_SUCCESS;
Given a range of cells, determines the sibling half-faces and stores them into SIBHFS_CID, SIBHFS_LFID tags. Compute all sibling half-faces for all half-faces in the given volume. The sibling half-faces is defined in terms of the containing cell and the local id of the face w.r.t that cell. That is, the map consists of two pieces of information: <EntityHandle cid, int lfid>
Parameters:
facesRange of cells
Definition at line 1727 of file HalfFacetRep.cpp.
References _verts, moab::Range::begin(), create_halffacet(), moab::Range::end(), moab::error(), ErrorCode, fid_from_halfacet(), moab::Core::get_connectivity(), get_index_in_lmap(), moab::HalfFacetRep::LocalMaps3D::hf2v, moab::HalfFacetRep::LocalMaps3D::hf2v_num, moab::ID_FROM_HANDLE(), moab::Range::index(), lConnMap2D, lConnMap3D, mb, MB_CHK_ERR, MB_SET_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps2D::next, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::HalfFacetRep::LocalMaps3D::num_verts_in_cell, moab::HalfFacetRep::LocalMaps2D::prev, sibhfs, moab::Range::size(), and moab::Core::type_from_handle().
    ErrorCode error;
    EntityType ctype        = mb->type_from_handle( start_cell );
        is_index[i] = 0;
    int vindex;
            EntityHandle v = 0;
            for( int k = 0; k < nvF; k++ )
                int id = lConnMap3D[index].hf2v[i][k];
                if( v <= conn[id] ) v = conn[id];
            vindex = _verts.index( v );
            is_index[vindex + 1] += 1;
    is_index[0] = 0;
    // Step 2: Define four arrays v2hv_eid, v2hv_lvid storing every half-facet on a vertex
    std::vector< EntityHandle > v2oe_v1( is_index[nv] );
    std::vector< EntityHandle > v2oe_v2( is_index[nv] );
    std::vector< EntityHandle > v2hf_map_cid( is_index[nv] );
    std::vector< int > v2hf_map_lfid( is_index[nv] );
        for( int i = 0; i < nfpc; i++ )
            std::vector< EntityHandle > vs( nvF );
            EntityHandle vmax = 0;
            int lv            = -1;
                vs[k]  = conn[id];
                if( vmax <= conn[id] )
                    vmax = conn[id];
                    lv   = k;
            int nidx = lConnMap2D[nvF - 3].next[lv];
            int pidx = lConnMap2D[nvF - 3].prev[lv];
            int v                      = _verts.index( vmax );
            v2oe_v1[is_index[v]]       = vs[nidx];
            v2oe_v2[is_index[v]]       = vs[pidx];
            v2hf_map_cid[is_index[v]]  = *cid;
            v2hf_map_lfid[is_index[v]] = i;
            is_index[v] += 1;
    is_index[0] = 0;
        int cidx = ID_FROM_HANDLE( *cid ) - 1;
            EntityHandle sibcid = fid_from_halfacet( hf, ctype );
            if( sibcid != 0 ) continue;
            int lv            = -1;
                vs[k]  = conn[id];
                    vmax = conn[id];
                    lv   = k;
            EntityHandle v1 = vs[pidx];
            EntityHandle v2 = vs[nidx];
            for( int ind = is_index[v]; ind <= is_index[v + 1] - 1; ind++ )
                if( ( v2oe_v1[ind] == v1 ) && ( v2oe_v2[ind] == v2 ) )
                    // Map to opposite hf
                    EntityHandle cur_cid = v2hf_map_cid[ind];
                    int cur_lfid         = v2hf_map_lfid[ind];
                    sibhfs[nfpc * cidx + i] = create_halffacet( cur_cid, cur_lfid );
                    int scidx                       = ID_FROM_HANDLE( cur_cid ) - 1;
                    sibhfs[nfpc * scidx + cur_lfid] = create_halffacet( *cid, i );
    return MB_SUCCESS;
Given a range of edges, determines the map for sibling half-verts and stores them into SIBHVS_EID, SIBHVS_LVID tags. Compute all sibling half-vertices for all half-vertices in the given curve. The sibling half-verts is defined in terms of the containing edge and the local id of the vertex w.r.t that edge. That is, the map consists of two pieces of information: <EntityHandle eid, int lvid>
Parameters:
edgesRange of edges.
Definition at line 634 of file HalfFacetRep.cpp.
References moab::Range::begin(), create_halffacet(), moab::Range::end(), moab::error(), ErrorCode, moab::Core::get_connectivity(), moab::ID_FROM_HANDLE(), moab::Range::index(), mb, MB_CHK_ERR, MB_SUCCESS, sibhvs, and moab::Range::size().
    ErrorCode error;
    int nv = verts.size();
        is_index[i] = 0;
    for( Range::iterator eid = edges.begin(); eid != edges.end(); ++eid )
        int num_conn = 0;
        error        = mb->get_connectivity( *eid, conn, num_conn, true );MB_CHK_ERR( error );
        int index = verts.index( conn[0] );
        index = verts.index( conn[1] );
    is_index[0] = 0;
    std::vector< EntityHandle > v2hv_map_eid( 2 * edges.size() );
    std::vector< int > v2hv_map_lvid( 2 * edges.size() );
        int num_conn = 0;
        for( int j = 0; j < 2; j++ )
            int v                      = verts.index( conn[j] );
            v2hv_map_eid[is_index[v]]  = *eid;
            v2hv_map_lvid[is_index[v]] = j;
            is_index[v] += 1;
    is_index[0] = 0;
    for( Range::iterator vid = verts.begin(); vid != verts.end(); ++vid )
        int v    = verts.index( *vid );
        int last = is_index[v + 1] - 1;
        if( last > is_index[v] )
            EntityHandle prev_eid = v2hv_map_eid[last];
            int prev_lvid         = v2hv_map_lvid[last];
            for( int i = is_index[v]; i <= last; i++ )
                EntityHandle cur_eid = v2hv_map_eid[i];
                int cur_lvid         = v2hv_map_lvid[i];
                int pidx                     = ID_FROM_HANDLE( prev_eid ) - 1;
                sibhvs[2 * pidx + prev_lvid] = create_halffacet( cur_eid, cur_lvid );
                prev_eid  = cur_eid;
                prev_lvid = cur_lvid;
    return MB_SUCCESS;
bool moab::HalfFacetRep::find_cell_in_component ( EntityHandle  vid,
EntityHandle  cell,
) [protected]
Definition at line 2045 of file HalfFacetRep.cpp.
    bool found = false;
    if( comps.empty() ) return found;
    std::pair< std::multimap< EntityHandle, EntityHandle >::iterator,
               std::multimap< EntityHandle, EntityHandle >::iterator >
        rit;
    rit = comps.equal_range( vid );
    for( std::multimap< EntityHandle, EntityHandle >::iterator it = rit.first; it != rit.second; ++it )
        if( it->second == cell )
            found = true;
            break;
    return found;
bool moab::HalfFacetRep::find_match_in_array ( EntityHandle  ent,
EntityHandle *  ent_list,
int  count,
bool  get_index = false,
int *  index = NULL
) [protected]
Definition at line 3138 of file HalfFacetRep.cpp.
Referenced by add_cells_of_single_component(), collect_and_compare(), find_matching_halfface(), find_matching_implicit_edge_in_cell(), get_up_adjacencies_2d(), get_up_adjacencies_edg_3d(), get_up_adjacencies_edg_3d_comp(), get_up_adjacencies_vert_2d(), get_up_adjacencies_vert_3d(), and mark_halfedges().
    bool found = false;
        if( ent == ent_list[i] )
            found = true;
            if( get_index ) *index = i;
            break;
    return found;
bool moab::HalfFacetRep::find_matching_halfedge ( EntityHandle  eid,
EntityHandle *  hefid,
int *  helid
) [protected]
Given an edge eid, it first collects few half-edges belonging to one-ring neighborhood of the starting vertex of the given edge, and then simultaneously searches and adds to the local list of half-edges for searching, till it finds a matching half-edge.
Parameters:
eidEntityHandle of the query edge
hefid,helid,:Returns the matching half-edge corresponding to the query edge.
Definition at line 1318 of file HalfFacetRep.cpp.
References _faces, moab::Range::begin(), collect_and_compare(), moab::error(), ErrorCode, fid_from_halfacet(), gather_halfedges(), moab::Core::get_connectivity(), moab::ID_FROM_HANDLE(), lid_from_halffacet(), mb, MB_CHK_ERR, MB_SUCCESS, queue_fid, queue_lid, trackfaces, moab::Core::type_from_handle(), and v2he.
Referenced by get_up_adjacencies_2d().
    ErrorCode error;
    int num_conn = 0;
    error        = mb->get_connectivity( eid, conn, num_conn, true );MB_CHK_ERR( error );
    EntityHandle vid = conn[0];
    int vidx         = ID_FROM_HANDLE( conn[0] ) - 1;
    if( hf == 0 )
        vidx = ID_FROM_HANDLE( conn[1] ) - 1;
        hf   = v2he[vidx];
        if( hf == 0 )  // The edge is either a dangling edge or attached to two non-manifold
                       // vertices
            return MB_SUCCESS;
        vid = conn[1];
    EntityHandle fid = fid_from_halfacet( hf, ftype );
    int lid          = lid_from_halffacet( hf );
    bool found = false;
    int qsize = 0, count = -1;
    error = gather_halfedges( vid, fid, lid, &qsize, &count );MB_CHK_ERR( error );
    found = collect_and_compare( vid, conn, &qsize, &count, hefid, helid );MB_CHK_ERR( error );
    for( int i = 0; i < qsize; i++ )
        queue_fid[i] = 0;
        queue_lid[i] = 0;
        trackfaces[i] = 0;
    return found;
bool moab::HalfFacetRep::find_matching_halfface ( EntityHandle  fid,
EntityHandle *  cid,
int *  leid
) [protected]
Find a local face with the same connectivity as the input face, belonging to an incident cell.
Parameters:
fidEntityHandle of the face
cidReturns EntityHandle of the incident cell
lfidReturns the local id of the face corresponding to the input face w.r.t the incident cell.
Definition at line 2790 of file HalfFacetRep.cpp.
References _cells, moab::Range::begin(), moab::error(), ErrorCode, fid_from_halfacet(), find_match_in_array(), moab::Core::get_connectivity(), get_index_in_lmap(), moab::ID_FROM_HANDLE(), lConnMap2D, lConnMap3D, mb, MB_CHK_ERR, MB_SET_ERR, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::HalfFacetRep::LocalMaps3D::num_verts_in_cell, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, sibhfs, Stkcells, trackcells, moab::Core::type_from_handle(), moab::HalfFacetRep::LocalMaps3D::v2hf, v2hf, moab::HalfFacetRep::LocalMaps3D::v2hf_num, and v2hfs.
Referenced by get_up_adjacencies_face_3d().
    ErrorCode error;
    EntityHandle start_cell = *_cells.begin();
    EntityType ftype        = mb->type_from_handle( fid );
    int nvF                 = lConnMap2D[ftype - 2].num_verts_in_face;
    const EntityHandle* fid_verts;
    error = mb->get_connectivity( fid, fid_verts, nvF, true );MB_CHK_ERR( error );
    std::vector< EntityHandle > start_cells;
    int vidx, locfv0 = -1;
    HFacet hf = 0;
    for( int i = 0; i < nvF; i++ )
        vidx = ID_FROM_HANDLE( fid_verts[i] ) - 1;
        hf   = v2hf[vidx];
        if( hf != 0 )
            start_cells.push_back( fid_from_halfacet( hf, ctype ) );
            locfv0 = i;
            break;
        else if( hf == 0 && v2hfs.find( fid_verts[i] ) != v2hfs.end() )
            std::pair< std::multimap< EntityHandle, HFacet >::iterator,
                       std::multimap< EntityHandle, HFacet >::iterator >
                it_hfs;
            it_hfs = v2hfs.equal_range( fid_verts[i] );
            for( std::multimap< EntityHandle, HFacet >::iterator it = it_hfs.first; it != it_hfs.second; ++it )
                start_cells.push_back( fid_from_halfacet( it->second, ctype ) );
            locfv0 = i;
            break;
    if( start_cells.empty() ) return false;
    bool found = false;
    for( int i = 0; i < (int)start_cells.size(); i++ )
        Stkcells[i] = start_cells[i];
    Stksize = start_cells.size() - 1;
        Stksize -= 1;
        count += 1;
        int lv[4] = { -1, -1, -1, -1 };
        int cnt   = 0;
        for( int i = 0; i < nvpc; i++ )
            for( int j = 0; j < nvF; j++ )
                if( conn[i] == fid_verts[j] )
                    lv[j] = i;
                    cnt += 1;
        if( cnt == nvF )  // All face verts are part of the cell
            found         = true;
            int nhf_thisv = lConnMap3D[index].v2hf_num[lv[locfv0]];
            int lfid      = -1;
                lfid     = lConnMap3D[index].v2hf[lv[locfv0]][i];
                int lcnt = 0;
                    for( int k = 0; k < nvF; ++k )
                        if( lv[k] == lConnMap3D[index].hf2v[lfid][j] ) lcnt += 1;
                if( lcnt == nvF ) break;
            cid[0] = cur_cid;
            lid[0] = lfid;
            break;
        else
            // Add other cells that are incident on fid_verts[0]
            if( locfv0 < 0 || lv[locfv0] < 0 ) MB_SET_ERR( MB_FAILURE, "did not find local vertex " );
            EntityHandle ngb;
                int ind = lConnMap3D[index].v2hf[lv[locfv0]][i];
                hf      = sibhfs[nfpc * cidx + ind];
                ngb     = fid_from_halfacet( hf, ctype );
                if( ngb )
                    if( !found_ent )
                        Stksize += 1;
        Stkcells[i] = 0;
        trackcells[i] = 0;
    return found;
bool moab::HalfFacetRep::find_matching_implicit_edge_in_cell ( EntityHandle  eid,
std::vector< EntityHandle > &  cid,
std::vector< int > &  leid
) [protected]
Find a local edge with the same connectivity as the input edge, belonging to an incident cell.
Parameters:
eidEntityHandle of the edge
leidReturns the local id of the edge corresponding to the input edge w.r.t the incident cell.
Definition at line 2654 of file HalfFacetRep.cpp.
References _cells, moab::Range::begin(), cellq, moab::error(), ErrorCode, fid_from_halfacet(), find_match_in_array(), moab::Core::get_connectivity(), get_index_in_lmap(), moab::ID_FROM_HANDLE(), lConnMap3D, mb, MB_CHK_ERR, MB_SET_ERR, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::HalfFacetRep::LocalMaps3D::num_verts_in_cell, sibhfs, moab::Core::type_from_handle(), moab::HalfFacetRep::LocalMaps3D::v2hf, v2hf, moab::HalfFacetRep::LocalMaps3D::v2hf_num, and v2hfs.
    ErrorCode error;
    EntityType ctype        = mb->type_from_handle( *_cells.begin() );
    // Find the edge vertices
    const EntityHandle* econn;
    int num_conn = 0;
    error        = mb->get_connectivity( eid, econn, num_conn, true );MB_CHK_ERR( error );
    EntityHandle v_start = econn[0], v_end = econn[1];
    int v1idx = ID_FROM_HANDLE( v_start ) - 1;
    int v2idx = ID_FROM_HANDLE( v_end ) - 1;
    // Find an incident cell to v_start
    HFacet hf1 = v2hf[v1idx];
    HFacet hf2 = v2hf[v2idx];
    int ncomps1 = 0, ncomps2 = 0, ncomp;
    if( hf1 == 0 && !v2hfs.empty() )
        std::pair< std::multimap< EntityHandle, HFacet >::iterator, std::multimap< EntityHandle, HFacet >::iterator >
            it_hes;
        it_hes = v2hfs.equal_range( v_start );
        for( std::multimap< EntityHandle, HFacet >::iterator it = it_hes.first; it != it_hes.second; ++it )
            ncomps1 += 1;
    else if( hf1 != 0 )
        start_cells.push_back( fid_from_halfacet( hf1, ctype ) );
        ncomps1 += 1;
    if( hf2 == 0 && !v2hfs.empty() )
            it_hes;
        it_hes = v2hfs.equal_range( v_end );
            ncomps2 += 1;
    else if( hf2 != 0 )
        start_cells.push_back( fid_from_halfacet( hf2, ctype ) );
        ncomps2 += 1;
    ncomp = std::min( ncomps1, ncomps2 );
    bool found = false;
    if( start_cells.empty() ) return found;
        cellq[i] = start_cells[i];
    int qsize     = start_cells.size();
    int num_qvals = 0;
    while( num_qvals < qsize )
        EntityHandle cell_id = cellq[num_qvals];
        num_qvals += 1;
        error = mb->get_connectivity( cell_id, conn, nvpc, true );MB_CHK_ERR( error );
        int lv0 = -1, lv1 = -1, lv = -1;
        // locate v_origin in poped out tet, check if v_end is in
            if( v_start == conn[i] )
                lv0 = i;
                lv  = lv0;
            else if( v_end == conn[i] )
                lv1 = i;
                lv  = lv1;
        if( ( lv0 >= 0 ) && ( lv1 >= 0 ) )
            found = true;
            cid.push_back( cell_id );
            leid.push_back( lConnMap3D[index].lookup_leids[lv0][lv1] );
            if( (int)cid.size() == ncomp ) break;
        // push back new found unchecked incident tets of v_start
        int cidx      = ID_FROM_HANDLE( cell_id ) - 1;
        for( int i = 0; i < nhf_thisv; i++ )
            HFacet hf        = sibhfs[nfpc * cidx + ind];
            EntityHandle ngb = fid_from_halfacet( hf, ctype );
            if( ngb )
                bool found_ent = find_match_in_array( ngb, &cellq[0], qsize - 1 );
                if( !found_ent )
                    cellq[qsize] = ngb;
                    qsize += 1;
        cellq[i] = 0;
    return found;
Definition at line 1546 of file HalfFacetRep.cpp.
References moab::Range::begin(), moab::Range::end(), moab::error(), ErrorCode, get_up_adjacencies_2d(), moab::Range::index(), lConnMap2D, mb, MB_CHK_ERR, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, moab::Range::size(), and moab::Core::type_from_handle().
Referenced by count_subentities().
    ErrorCode error;
    int total_edges = nepf * nfaces;
    std::vector< int > trackF( total_edges, 0 );
    std::vector< EntityHandle > adj_fids;
    std::vector< int > adj_lids;
    for( Range::iterator f = faces.begin(); f != faces.end(); ++f )
        for( int l = 0; l < nepf; l++ )
            adj_fids.clear();
            adj_lids.clear();
            int id = nepf * ( faces.index( *f ) ) + l;
            if( !trackF[id] )
                error = get_up_adjacencies_2d( *f, l, false, adj_fids, &adj_lids );MB_CHK_ERR( error );
                total_edges -= adj_fids.size();
                for( int i = 0; i < (int)adj_fids.size(); i++ )
                    trackF[nepf * ( faces.index( adj_fids[i] ) ) + adj_lids[i]] = 1;
    return total_edges;
ErrorCode moab::HalfFacetRep::find_total_edges_faces_3d ( const Range &  cells,
int *  nedges,
int *  nfaces
Definition at line 3078 of file HalfFacetRep.cpp.
References moab::Range::begin(), moab::Range::end(), moab::error(), ErrorCode, get_index_in_lmap(), get_up_adjacencies_edg_3d(), get_up_adjacencies_face_3d(), moab::Range::index(), lConnMap3D, MB_CHK_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps3D::num_edges_in_cell, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, and moab::Range::size().
    ErrorCode error;
    int nepc        = lConnMap3D[index].num_edges_in_cell;
    int ncells      = cells.size();
    int total_edges = nepc * ncells;
    int total_faces = nfpc * ncells;
    std::vector< int > trackE( total_edges, 0 );
    std::vector< int > trackF( total_faces, 0 );
    std::vector< EntityHandle > inc_cids, sib_cids;
    std::vector< int > inc_leids, sib_lfids;
    for( Range::iterator it = cells.begin(); it != cells.end(); ++it )
        // Count edges
        for( int i = 0; i < nepc; i++ )
            inc_cids.clear();
            inc_leids.clear();
            int id = nepc * ( cells.index( *it ) ) + i;
            if( !trackE[id] )
                error = get_up_adjacencies_edg_3d( *it, i, inc_cids, &inc_leids );MB_CHK_ERR( error );
                total_edges -= inc_cids.size() - 1;
                for( int j = 0; j < (int)inc_cids.size(); j++ )
                    trackE[nepc * ( cells.index( inc_cids[j] ) ) + inc_leids[j]] = 1;
        // Count faces
            sib_cids.clear();
            sib_lfids.clear();
            int id = nfpc * ( cells.index( *it ) ) + i;
            if( !trackF[id] )
                error = get_up_adjacencies_face_3d( *it, i, sib_cids, &sib_lfids );MB_CHK_ERR( error );
                if( sib_cids.size() == 1 ) continue;
                total_faces -= sib_cids.size() - 1;
                trackF[nfpc * ( cells.index( sib_cids[1] ) ) + sib_lfids[1]] = 1;
    nedges[0] = total_edges;
    nfaces[0] = total_faces;
    return MB_SUCCESS;
ErrorCode moab::HalfFacetRep::gather_halfedges ( EntityHandle  vid,
int  he_lid,
int *  qsize,
int *  count
) [protected]
Given a vertex vid, and a half-edge <he_fid,he_lid>, add another half-edge in the same face sharing the vertex
Definition at line 1366 of file HalfFacetRep.cpp.
References another_halfedge(), moab::error(), ErrorCode, get_up_adjacencies_2d(), MB_CHK_ERR, MB_SUCCESS, queue_fid, queue_lid, and trackfaces.
Referenced by find_matching_halfedge(), get_up_adjacencies_vert_2d(), and mark_halfedges().
    ErrorCode error;
    EntityHandle he2_fid = 0;
    int he2_lid          = 0;
    error = another_halfedge( vid, he_fid, he_lid, &he2_fid, &he2_lid );MB_CHK_ERR( error );
    queue_fid[*qsize] = he_fid;
    queue_lid[*qsize] = he_lid;
    *qsize += 1;
    queue_fid[*qsize] = he2_fid;
    queue_lid[*qsize] = he2_lid;
    *qsize += 1;
    *count += 1;
    trackfaces[*count] = he_fid;
    error = get_up_adjacencies_2d( he_fid, he_lid, qsize, count );MB_CHK_ERR( error );
    return MB_SUCCESS;
ErrorCode moab::HalfFacetRep::get_adjacencies ( const EntityHandle  source_entity,
std::vector< EntityHandle > &  target_entities
Given an entity of dimension d, gather all the adjacent D dimensional entities where D >, = , < d .
Parameters:
source_entityEntityHandle to which adjacent entities have to be found.
target_dimensionInt Dimension of the desired adjacent entities.
target_entitiesVector in which the adjacent EntityHandle are returned.
Definition at line 489 of file HalfFacetRep.cpp.
References adjMatrix, moab::Core::dimension_from_handle(), moab::error(), ErrorCode, get_down_adjacencies(), get_index_for_meshtype(), get_neighbor_adjacencies(), get_up_adjacencies(), initialize(), mb, MB_CHK_ERR, MB_SUCCESS, mInitAHFmaps, thismeshtype, and moab::HalfFacetRep::adj_matrix::val.
Referenced by moab::NestedRefine::get_adjacencies().
    ErrorCode error;
    unsigned int source_dimension = mb->dimension_from_handle( source_entity );
    assert( ( source_dimension <= target_dimension ) || ( source_dimension > target_dimension ) );
    if( mInitAHFmaps == false )
        error = initialize();MB_CHK_ERR( error );
    int mindex       = get_index_for_meshtype( thismeshtype );
    int adj_possible = adjMatrix[mindex].val[source_dimension][target_dimension];
    if( adj_possible )
        if( source_dimension < target_dimension )
            error = get_up_adjacencies( source_entity, target_dimension, target_entities );MB_CHK_ERR( error );
        else if( source_dimension == target_dimension )
            error = get_neighbor_adjacencies( source_entity, target_entities );MB_CHK_ERR( error );
        else
            error = get_down_adjacencies( source_entity, target_dimension, target_entities );MB_CHK_ERR( error );
    else
        return MB_SUCCESS;
    return MB_SUCCESS;
ErrorCode moab::HalfFacetRep::get_down_adjacencies ( EntityHandle  ent,
int  out_dim,
std::vector< EntityHandle > &  adjents
Given an entity of dimension d, gather all the d-1 dimensional entities.
Parameters:
entEntityHandle to which neighbor entities have to be found.
out_dimDimension of the desired downward adjacency.
adjentsVector in which the neighbor entities are returned.
Definition at line 590 of file HalfFacetRep.cpp.
References moab::Core::dimension_from_handle(), moab::error(), ErrorCode, get_down_adjacencies_2d(), get_down_adjacencies_edg_3d(), get_down_adjacencies_face_3d(), mb, MB_CHK_ERR, and MB_SUCCESS.
Referenced by ahf_test(), and get_adjacencies().
    ErrorCode error;
    int in_dim = mb->dimension_from_handle( ent );
    assert( ( in_dim >= 2 && in_dim <= 3 ) && ( out_dim < in_dim ) );
    if( ( in_dim == 2 ) && ( out_dim == 1 ) )
        error = get_down_adjacencies_2d( ent, adjents );MB_CHK_ERR( error );
    else if( ( in_dim == 3 ) && ( out_dim == 1 ) )
        error = get_down_adjacencies_edg_3d( ent, adjents );MB_CHK_ERR( error );
    else if( ( in_dim == 3 ) && ( out_dim == 2 ) )
        error = get_down_adjacencies_face_3d( ent, adjents );MB_CHK_ERR( error );
    return MB_SUCCESS;
Given a face, it first finds incident edges on each vertex of the face, and then it performs a set intersection to gather all the edges of the given face.
Parameters:
fidEntityHandle of the query face
adjentsVector returning its edges
Definition at line 1485 of file HalfFacetRep.cpp.
References moab::error(), ErrorCode, moab::Core::get_connectivity(), get_up_adjacencies_1d(), lConnMap2D, mb, MB_CHK_ERR, MB_SUCCESS, MBTRI, moab::HalfFacetRep::LocalMaps2D::next, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, moab::HalfFacetRep::LocalMaps2D::prev, and moab::Core::type_from_handle().
Referenced by get_down_adjacencies().
    // Returns explicit edges, if any, of the face
    ErrorCode error;
    adjents.reserve( 10 );
    std::vector< EntityHandle > temp;
    // Loop over 2 vertices
    for( int i = 0; i < 2; i++ )
        // Choose the two adjacent vertices for a triangle, and two opposite vertices for a quad
        int l;
        if( ftype == MBTRI )
            l = i;
        else
            l = 2 * i;
        // Get the current, next and prev vertices
        int nidx           = lConnMap2D[ftype - 2].next[l];
        int pidx           = lConnMap2D[ftype - 2].prev[l];
        EntityHandle v     = conn[l];
        EntityHandle vnext = conn[nidx];
        EntityHandle vprev = conn[pidx];
        // Get incident edges on v
        error = get_up_adjacencies_1d( v, temp );MB_CHK_ERR( error );
        // Loop over the incident edges and check if its end vertices match those in the face
        for( int k = 0; k < (int)temp.size(); k++ )
            int num_conn = 0;
            error        = mb->get_connectivity( temp[k], econn, num_conn, true );MB_CHK_ERR( error );
            if( ( econn[0] == v && econn[1] == vnext ) || ( econn[0] == v && econn[1] == vprev ) ||
                ( econn[0] == vnext && econn[1] == v ) || ( econn[0] == vprev && econn[1] == v ) )
                bool found = false;
                for( int j = 0; j < (int)adjents.size(); j++ )
                    if( adjents[j] == temp[k] )
                        found = true;
                        break;
                if( !found ) adjents.push_back( temp[k] );
    return MB_SUCCESS;
Given a cell, it first finds incident edges on each vertex of the cell, and then it performs a set intersection to gather all the edges of the given cell.
Parameters:
cidEntityHandle of the query cell
Definition at line 2953 of file HalfFacetRep.cpp.
References moab::error(), ErrorCode, moab::Core::get_connectivity(), get_index_in_lmap(), get_up_adjacencies_1d(), lConnMap3D, mb, MB_CHK_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps3D::num_verts_in_cell, moab::HalfFacetRep::LocalMaps3D::search_everts, and moab::HalfFacetRep::LocalMaps3D::v2le.
    // TODO: Try intersection without using std templates
    ErrorCode error;
    adjents.reserve( 20 );
    int index = get_index_in_lmap( cid );
    error = mb->get_connectivity( cid, conn, nvpc, true );MB_CHK_ERR( error );
    // Gather all the incident edges on each vertex of the face
    int ns = lConnMap3D[index].search_everts[0];
    for( int i = 0; i < ns; i++ )
        temp.clear();
        int lv0 = lConnMap3D[index].search_everts[i + 1];
        error   = get_up_adjacencies_1d( conn[lv0], temp );MB_CHK_ERR( error );
        int nle   = lConnMap3D[index].v2le[i][0];
        int count = 0;
        for( int j = 0; j < (int)temp.size(); j++ )
            int nvpe = 0;
            error    = mb->get_connectivity( temp[j], econn, nvpe, true );MB_CHK_ERR( error );
            for( int k = 0; k < nle; k++ )
                int lv1 = lConnMap3D[index].v2le[i][k + 1];
                if( ( ( econn[0] == conn[lv0] ) && ( econn[1] == conn[lv1] ) ) ||
                    ( ( econn[1] == conn[lv0] ) && ( econn[0] == conn[lv1] ) ) )
                    adjents.push_back( temp[j] );
                    count += 1;
            if( count == nle ) break;
    return MB_SUCCESS;
Given a cell, it first finds incident faces on each vertex of the cell, and then performs a set intersection to gather all the faces of the given cell.
Parameters:
adjentsVector returning its faces
Definition at line 2998 of file HalfFacetRep.cpp.
References moab::CN::ConnectivityMatch(), moab::error(), ErrorCode, moab::Core::get_connectivity(), get_index_in_lmap(), get_up_adjacencies_vert_2d(), moab::HalfFacetRep::LocalMaps3D::hf2v, moab::HalfFacetRep::LocalMaps3D::hf2v_num, lConnMap3D, mb, MB_CHK_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::HalfFacetRep::LocalMaps3D::num_verts_in_cell, moab::HalfFacetRep::LocalMaps3D::search_fverts, moab::HalfFacetRep::LocalMaps3D::v2hf, and moab::HalfFacetRep::LocalMaps3D::v2hf_num.
    // Returns explicit face, if any of the cell
    ErrorCode error;
    // Get the connectivity of the input cell
    // Collect all the half-faces of the cell
    EntityHandle half_faces[6][4];
        int nvf = lConnMap3D[index].hf2v_num[i];
        for( int j = 0; j < nvf; j++ )
            half_faces[i][j] = conn[ind];
    // Add two vertices for which the upward adjacencies are computed
    int search_verts[2];
    search_verts[0] = lConnMap3D[index].search_fverts[0];
    search_verts[1] = lConnMap3D[index].search_fverts[1];
    temp.reserve( 20 );
        // Get the incident faces on the local vertex
        int lv = search_verts[i];
        temp.clear();
        error = get_up_adjacencies_vert_2d( conn[lv], temp );MB_CHK_ERR( error );
        if( temp.size() == 0 ) continue;
        // Get the half-faces incident on the local vertex and match it with the obtained faces
        int nhfthisv = lConnMap3D[index].v2hf_num[lv];
            int fsize = 0;
            error     = mb->get_connectivity( temp[k], fid_verts, fsize, true );MB_CHK_ERR( error );
            for( int j = 0; j < nhfthisv; j++ )
                // Collect all the vertices of this half-face
                int idx = lConnMap3D[index].v2hf[lv][j];
                int nvF = lConnMap3D[index].hf2v_num[idx];
                if( fsize != nvF ) continue;
                int direct, offset;
                bool they_match = CN::ConnectivityMatch( &half_faces[idx][0], &fid_verts[0], nvF, direct, offset );
                if( they_match )
                    bool found = false;
                    for( int p = 0; p < (int)adjents.size(); p++ )
                        if( adjents[p] == temp[k] )
                            found = true;
                            break;
    return MB_SUCCESS;
ErrorCode moab::HalfFacetRep::get_entity_ranges ( Range &  verts,
Range &  edges,
Range &  faces,
Range &  cells
Definition at line 3652 of file HalfFacetRep.cpp.
References _cells, _edges, _faces, _verts, and MB_SUCCESS.
    verts = _verts;
    edges = _edges;
    faces = _faces;
    cells = _cells;
    return MB_SUCCESS;
Definition at line 1583 of file HalfFacetRep.cpp.
References moab::error(), ErrorCode, moab::Core::get_connectivity(), get_up_adjacencies_1d(), lConnMap2D, mb, MB_CHK_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps2D::next, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, and moab::Core::type_from_handle().
    ErrorCode error;
    edges.clear();
    std::vector< EntityHandle > conn;
    error = mb->get_connectivity( &fid, 1, conn );MB_CHK_ERR( error );
        EntityHandle v0 = conn[i];
        EntityHandle v1 = conn[lConnMap2D[ftype - 2].next[i]];
        std::vector< EntityHandle > e0, e1, ecom;
        error = get_up_adjacencies_1d( v0, e0 );MB_CHK_ERR( error );
        error = get_up_adjacencies_1d( v1, e1 );MB_CHK_ERR( error );
        std::sort( e0.begin(), e0.end() );
        std::sort( e1.begin(), e1.end() );
        std::set_intersection( e0.begin(), e0.end(), e1.begin(), e1.end(), std::back_inserter( ecom ) );
        assert( ecom.size() == 1 || ecom.size() == 0 );
        if( ecom.size() == 0 )
            edges.push_back( 0 );
        else
            edges.push_back( ecom[0] );
    return MB_SUCCESS;
ErrorCode moab::HalfFacetRep::get_half_facet_in_comp ( EntityHandle  cid,
int  leid,
std::vector< EntityHandle > &  ents,
std::vector< int > &  lids,
std::vector< int > &  lfids
Definition at line 3158 of file HalfFacetRep.cpp.
References _cells, moab::Range::begin(), moab::HalfFacetRep::LocalMaps3D::e2hf, moab::HalfFacetRep::LocalMaps3D::e2v, moab::error(), ErrorCode, fid_from_halfacet(), moab::Core::get_connectivity(), get_index_in_lmap(), get_up_adjacencies_edg_3d(), moab::HalfFacetRep::LocalMaps3D::hf2v, moab::HalfFacetRep::LocalMaps3D::hf2v_num, moab::ID_FROM_HANDLE(), lConnMap3D, lid_from_halffacet(), moab::HalfFacetRep::LocalMaps3D::lookup_leids, mb, MB_CHK_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::HalfFacetRep::LocalMaps3D::num_verts_in_cell, sibhfs, and moab::Core::type_from_handle().
    ErrorCode error;
    ents.clear();
    lids.clear();
    EntityType ctype = mb->type_from_handle( cid );
    int index        = get_index_in_lmap( *_cells.begin() );
    // Get all incident cells
    std::vector< EntityHandle > adjents;
    std::vector< int > adjlids;
    error = get_up_adjacencies_edg_3d( cid, leid, adjents, &adjlids );MB_CHK_ERR( error );
    // Get the end vertices of the edge <cid,leid>
    error = mb->get_connectivity( cid, econn, nvpc, true );MB_CHK_ERR( error );
    int id              = lConnMap3D[index].e2v[leid][0];
    EntityHandle vstart = econn[id];
    id                  = lConnMap3D[index].e2v[leid][1];
    EntityHandle vend   = econn[id];
    std::vector< int > mark( adjents.size(), 0 );
    int count = 0;
    for( int k = 0; k < (int)adjents.size(); k++ )
        if( mark[k] != 0 ) continue;
        count += 1;
        mark[k] = count;
        // Loop over each half-face incident on this local edge
            EntityHandle cur_cell = adjents[k];
            int cur_leid          = adjlids[k];
            int lface = i;
            while( true )
                int cidx = ID_FROM_HANDLE( cur_cell ) - 1;
                int lfid = lConnMap3D[index].e2hf[cur_leid][lface];
                HFacet hf = sibhfs[nfpc * cidx + lfid];
                cur_cell  = fid_from_halfacet( hf, ctype );
                lfid      = lid_from_halffacet( hf );
                // Check if loop reached starting cell or a boundary
                if( ( cur_cell == adjents[k] ) || ( cur_cell == 0 ) ) break;
                const EntityHandle* sib_conn;
                error = mb->get_connectivity( cur_cell, sib_conn, nvpc, true );MB_CHK_ERR( error );
                // Find the local edge id wrt to sibhf
                int nv_curF = lConnMap3D[index].hf2v_num[lfid];
                int lv0 = -1, lv1 = -1, idx = -1;
                for( int j = 0; j < nv_curF; j++ )
                    idx = lConnMap3D[index].hf2v[lfid][j];
                    if( vstart == sib_conn[idx] ) lv0 = idx;
                    if( vend == sib_conn[idx] ) lv1 = idx;
                assert( ( lv0 >= 0 ) && ( lv1 >= 0 ) );
                cur_leid = lConnMap3D[index].lookup_leids[lv0][lv1];
                int chk_lfid = lConnMap3D[index].e2hf[cur_leid][0];
                if( lfid == chk_lfid )
                    lface = 1;
                else
                    lface = 0;
                int ind   = std::find( adjents.begin(), adjents.end(), cur_cell ) - adjents.begin();
                mark[ind] = count;
            // Loop back
            if( cur_cell != 0 ) break;
    // Loop over again to find cells on the boundary
    for( int c = 0; c < count; c++ )
        for( int i = 0; i < (int)adjents.size(); i++ )
            if( mark[i] == c + 1 )
                int cidx = ID_FROM_HANDLE( adjents[i] ) - 1;
                for( int j = 0; j < nfpc; j++ )
                    HFacet hf         = sibhfs[nfpc * cidx + j];
                    EntityHandle cell = fid_from_halfacet( hf, ctype );
                    if( cell == 0 )
                        ents.push_back( adjents[i] );
                        lids.push_back( adjlids[i] );
                        lfids.push_back( j );
                        break;
    return MB_SUCCESS;
ErrorCode moab::HalfFacetRep::get_incident_map ( EntityType  type,
EntityHandle  vid,
std::vector< EntityHandle > &  inci_entid,
std::vector< int > &  inci_lid
Definition at line 3535 of file HalfFacetRep.cpp.
References fid_from_halfacet(), moab::ID_FROM_HANDLE(), lid_from_halffacet(), MB_SUCCESS, MBEDGE, MBQUAD, MBTRI, v2he, v2hes, v2hf, v2hfs, and v2hv.
Referenced by moab::NestedRefine::is_vertex_on_boundary(), moab::NestedRefine::update_global_ahf_1D(), moab::NestedRefine::update_global_ahf_1D_sub(), moab::NestedRefine::update_global_ahf_2D(), moab::NestedRefine::update_global_ahf_2D_sub(), moab::NestedRefine::update_global_ahf_3D(), and moab::NestedRefine::update_local_ahf().
    inci_entid.clear();
    inci_lid.clear();
    if( type == MBEDGE )
        HFacet hf = v2hv[ID_FROM_HANDLE( vid ) - 1];
        inci_entid.push_back( fid_from_halfacet( hf, type ) );
        inci_lid.push_back( lid_from_halffacet( hf ) );
    else if( type == MBTRI || type == MBQUAD )
                it_hes;
            it_hes = v2hes.equal_range( vid );
                inci_entid.push_back( fid_from_halfacet( it->second, type ) );
                inci_lid.push_back( lid_from_halffacet( it->second ) );
        else if( hf != 0 )
        else if( hf == 0 && ( v2hes.find( vid ) == v2hes.end() ) )
    else
                it_hes;
            it_hes = v2hfs.equal_range( vid );
        else if( hf != 0 )
        else if( hf == 0 && ( v2hfs.find( vid ) == v2hfs.end() ) )
    return MB_SUCCESS;
int moab::HalfFacetRep::get_index_for_meshtype ( MESHTYPE  mesh_type) [protected]
Definition at line 101 of file HalfFacetRep.cpp.
References moab::CURVE, moab::SURFACE, moab::SURFACE_MIXED, moab::VOLUME, moab::VOLUME_MIXED, moab::VOLUME_MIXED_1, and moab::VOLUME_MIXED_2.
Referenced by get_adjacencies().
    int index = 0;
    switch( mesh_type )
        case CURVE:
            index = 0;
            break;
        case SURFACE:
            index = 1;
            break;
        case SURFACE_MIXED:
            index = 2;
            break;
        case VOLUME:
            index = 3;
            break;
        case VOLUME_MIXED_1:
            index = 4;
            break;
        case VOLUME_MIXED_2:
            index = 5;
            break;
        case VOLUME_MIXED:
            index = 6;
            break;
    return index;
void moab::HalfFacetRep::get_memory_use ( unsigned long long &  entity_total,
unsigned long long &  memory_total
Definition at line 3676 of file HalfFacetRep.cpp.
References sibhes, sibhfs, sibhvs, v2he, v2hf, and v2hv.
    entity_total = memory_total = 0;
    // 1D
    if( !v2hv.empty() ) entity_total += v2hv.capacity() * sizeof( HFacet ) + sizeof( v2hv );
    if( !sibhvs.empty() ) entity_total += sibhvs.capacity() * sizeof( HFacet ) + sizeof( sibhvs );
    // 2D
    if( !v2he.empty() ) entity_total += v2he.capacity() * sizeof( HFacet ) + sizeof( v2he );
    if( !sibhes.empty() ) entity_total += sibhes.capacity() * sizeof( HFacet ) + sizeof( sibhes );
    // 3D
    if( !v2hf.empty() ) entity_total += v2hf.capacity() * sizeof( HFacet ) + sizeof( v2hf );
    if( !sibhfs.empty() ) entity_total += sibhfs.capacity() * sizeof( HFacet ) + sizeof( sibhfs );
    memory_total = entity_total;
MESHTYPE moab::HalfFacetRep::get_mesh_type ( int  nverts,
int  nedges,
int  nfaces,
int  ncells
Definition at line 56 of file HalfFacetRep.cpp.
Referenced by moab::NestedRefine::create_hm_storage_single_level(), and initialize().
    MESHTYPE mesh_type = CURVE;
    if( nverts && nedges && ( !nfaces ) && ( !ncells ) )
        mesh_type = CURVE;
    else if( nverts && !nedges && nfaces && !ncells )
        mesh_type = SURFACE;
    else if( nverts && nedges && nfaces && !ncells )
        mesh_type = SURFACE_MIXED;
    else if( nverts && !nedges && !nfaces && ncells )
        mesh_type = VOLUME;
    else if( nverts && nedges && !nfaces && ncells )
        mesh_type = VOLUME_MIXED_1;
    else if( nverts && !nedges && nfaces && ncells )
        mesh_type = VOLUME_MIXED_2;
    else if( nverts && nedges && nfaces && ncells )
        mesh_type = VOLUME_MIXED;
    return mesh_type;
Get the same-dimensional entities connected with an entity.
Given an entity of dimension d, gather all the entities connected via d-1 dimensional entities. Same as bridge_adjacencies in MOAB.
Parameters:
Definition at line 568 of file HalfFacetRep.cpp.
References moab::Core::dimension_from_handle(), moab::error(), ErrorCode, get_neighbor_adjacencies_1d(), get_neighbor_adjacencies_2d(), get_neighbor_adjacencies_3d(), mb, MB_CHK_ERR, and MB_SUCCESS.
    ErrorCode error;
    assert( in_dim >= 1 && in_dim <= 3 );
    if( in_dim == 1 )
        error = get_neighbor_adjacencies_1d( ent, adjents );MB_CHK_ERR( error );
    else if( in_dim == 2 )
        error = get_neighbor_adjacencies_2d( ent, adjents );MB_CHK_ERR( error );
    else if( in_dim == 3 )
        error = get_neighbor_adjacencies_3d( ent, adjents );MB_CHK_ERR( error );
    return MB_SUCCESS;
Given an edge, finds vertex-connected neighbor edges.
Given an edge, it gathers all the incident edges of each vertex of the edge.
Parameters:
adjentsVector returning neighbor edges
Definition at line 779 of file HalfFacetRep.cpp.
References fid_from_halfacet(), moab::ID_FROM_HANDLE(), lid_from_halffacet(), MB_SUCCESS, MBEDGE, and sibhvs.
Referenced by get_neighbor_adjacencies().
    adjents.clear();
    EntityHandle sibhv_eid;
    int sibhv_lid;
    int eidx = ID_FROM_HANDLE( eid ) - 1;
    for( int lid = 0; lid < 2; ++lid )
        HFacet shf = sibhvs[2 * eidx + lid];
        sibhv_eid  = fid_from_halfacet( shf, MBEDGE );
        sibhv_lid  = lid_from_halffacet( shf );
        if( sibhv_eid != 0 )
            adjents.push_back( sibhv_eid );
            eidx                = ID_FROM_HANDLE( sibhv_eid ) - 1;
            HFacet nhf          = sibhvs[2 * eidx + sibhv_lid];
            EntityHandle hv_eid = fid_from_halfacet( nhf, MBEDGE );
            int hv_lid          = lid_from_halffacet( nhf );
            while( hv_eid != 0 )
                if( hv_eid != eid ) adjents.push_back( hv_eid );
                eidx              = ID_FROM_HANDLE( hv_eid ) - 1;
                HFacet hf         = sibhvs[2 * eidx + hv_lid];
                EntityHandle edge = fid_from_halfacet( hf, MBEDGE );
                if( edge == sibhv_eid ) break;
                hv_eid = edge;
                hv_lid = lid_from_halffacet( hf );
    return MB_SUCCESS;
Given an edge, finds edge-connected neighbor face.
Given an face, it gathers all the neighbor faces of each local edge of the face.
Parameters:
adjentsVector returning neighbor faces
Definition at line 1466 of file HalfFacetRep.cpp.
References moab::error(), ErrorCode, get_up_adjacencies_2d(), lConnMap2D, mb, MB_CHK_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, and moab::Core::type_from_handle().
    ErrorCode error;
    if( fid != 0 )
        for( int lid = 0; lid < nepf; ++lid )
            error = get_up_adjacencies_2d( fid, lid, false, adjents );MB_CHK_ERR( error );
    return MB_SUCCESS;
Given a cell, it gathers all the neighbor cells of each local face of the cell.
Parameters:
adjentsVector returning neighbor cells
Definition at line 2931 of file HalfFacetRep.cpp.
References fid_from_halfacet(), get_index_in_lmap(), moab::ID_FROM_HANDLE(), lConnMap3D, mb, MB_SUCCESS, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, sibhfs, and moab::Core::type_from_handle().
    int cidx         = ID_FROM_HANDLE( cid ) - 1;
    if( cid != 0 )
        for( int lfid = 0; lfid < nfpc; ++lfid )
            if( sibcid != 0 ) adjents.push_back( sibcid );
    return MB_SUCCESS;
Definition at line 544 of file HalfFacetRep.hpp.
References _rset.
        return &_rset;
ErrorCode moab::HalfFacetRep::get_sibling_map ( EntityType  type,
EntityHandle  ent,
EntityHandle *  sib_entids,
int *  sib_lids,
int  num_halffacets
Definition at line 3377 of file HalfFacetRep.cpp.
References _cells, moab::Range::begin(), fid_from_halfacet(), get_index_in_lmap(), moab::ID_FROM_HANDLE(), lConnMap2D, lConnMap3D, lid_from_halffacet(), MB_SET_ERR, MB_SUCCESS, MBEDGE, MBQUAD, MBTRI, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, sibhes, sibhfs, and sibhvs.
Referenced by moab::NestedRefine::is_cell_on_boundary(), moab::NestedRefine::is_edge_on_boundary(), moab::NestedRefine::is_face_on_boundary(), moab::NestedRefine::is_vertex_on_boundary(), moab::NestedRefine::update_global_ahf_1D(), moab::NestedRefine::update_global_ahf_1D_sub(), moab::NestedRefine::update_global_ahf_2D(), moab::NestedRefine::update_global_ahf_2D_sub(), moab::NestedRefine::update_global_ahf_3D(), and moab::NestedRefine::update_local_ahf().
        if( num_halffacets != 2 ) MB_SET_ERR( MB_FAILURE, "Incorrect number of halfvertices." );
        int eidx = ID_FROM_HANDLE( ent ) - 1;
            HFacet hf     = sibhvs[2 * eidx + i];
            sib_entids[i] = fid_from_halfacet( hf, MBEDGE );
            sib_lids[i]   = lid_from_halffacet( hf );
        int nepf = lConnMap2D[type - 2].num_verts_in_face;
        if( num_halffacets != nepf ) MB_SET_ERR( MB_FAILURE, "Incorrect number of halfedges." );
        int fidx = ID_FROM_HANDLE( ent ) - 1;
            HFacet hf     = sibhes[nepf * fidx + i];
            sib_entids[i] = fid_from_halfacet( hf, type );
    else
        int idx  = get_index_in_lmap( *_cells.begin() );
        int nfpc = lConnMap3D[idx].num_faces_in_cell;
        if( num_halffacets != nfpc ) MB_SET_ERR( MB_FAILURE, "Incorrect number of halffaces." );
        int cidx = ID_FROM_HANDLE( ent ) - 1;
    return MB_SUCCESS;
EntityHandle  ent,
int  lid,
EntityHandle &  sib_entid,
int &  sib_lid
Definition at line 3428 of file HalfFacetRep.cpp.
References _cells, moab::Range::begin(), fid_from_halfacet(), get_index_in_lmap(), moab::ID_FROM_HANDLE(), lConnMap2D, lConnMap3D, lid_from_halffacet(), MB_SUCCESS, MBEDGE, MBQUAD, MBTRI, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, sibhes, sibhfs, and sibhvs.
        HFacet hf = sibhvs[2 * eidx + lid];
        sib_entid = fid_from_halfacet( hf, MBEDGE );
        sib_lid   = lid_from_halffacet( hf );
        HFacet hf = sibhes[nepf * fidx + lid];
        sib_entid = fid_from_halfacet( hf, type );
    else
        HFacet hf = sibhfs[nfpc * cidx + lid];
    return MB_SUCCESS;
ErrorCode moab::HalfFacetRep::get_up_adjacencies ( EntityHandle  ent,
int  out_dim,
std::vector< EntityHandle > &  adjents,
std::vector< int > *  lids = NULL
Get the upward incidences associated with an entity.
Given an entity of dimension d, gather all the incident D(>d) dimensional entities. :
Parameters:
entEntityHandle to which incident entities have to be found.
out_dimDimension of the desired incidence information.
adjentsVector in which the incident entities are returned.
local_idSet to false by default. If true, returns the local id's of the half-facets
lidsVector in which the local id's are returned.
Definition at line 528 of file HalfFacetRep.cpp.
References moab::Core::dimension_from_handle(), moab::error(), ErrorCode, get_up_adjacencies_1d(), get_up_adjacencies_2d(), get_up_adjacencies_edg_3d(), get_up_adjacencies_face_3d(), get_up_adjacencies_vert_2d(), get_up_adjacencies_vert_3d(), mb, MB_CHK_ERR, and MB_SUCCESS.
Referenced by ahf_test(), get_adjacencies(), and moab::HiReconstruction::vertex_get_incident_elements().
    ErrorCode error;
    assert( ( in_dim >= 0 && in_dim <= 2 ) && ( out_dim > in_dim ) );
    if( in_dim == 0 )
        if( out_dim == 1 )
            error = get_up_adjacencies_1d( ent, adjents, lids );MB_CHK_ERR( error );
        else if( out_dim == 2 )
            error = get_up_adjacencies_vert_2d( ent, adjents );MB_CHK_ERR( error );
        else if( out_dim == 3 )
            error = get_up_adjacencies_vert_3d( ent, adjents );MB_CHK_ERR( error );
    else if( ( in_dim == 1 ) && ( out_dim == 2 ) )
        error = get_up_adjacencies_2d( ent, adjents, lids );MB_CHK_ERR( error );
    else if( ( in_dim == 1 ) && ( out_dim == 3 ) )
        error = get_up_adjacencies_edg_3d( ent, adjents, lids );MB_CHK_ERR( error );
    else if( ( in_dim == 2 ) && ( out_dim == 3 ) )
        error = get_up_adjacencies_face_3d( ent, adjents, lids );MB_CHK_ERR( error );
    return MB_SUCCESS;
ErrorCode moab::HalfFacetRep::get_up_adjacencies_1d ( EntityHandle  vid,
std::vector< int > *  lvids = NULL
Given a vertex, finds the edges incident on it.
Given a vertex handle, it starts by first finding an incident half-vert by using the incident half-vert map, and then obtaining all the sibling half-verts of the corresponding half-vertex.
Parameters:
vidEntityHandle of the query vertex
adjentsVector returning the incident edges
local_idFalse by default. If true, returns the local vertex id's corresponding to vid
lvidsVector returning the local vertex id's
Definition at line 739 of file HalfFacetRep.cpp.
References fid_from_halfacet(), moab::ID_FROM_HANDLE(), lid_from_halffacet(), MB_SUCCESS, MBEDGE, sibhvs, and v2hv.
Referenced by get_down_adjacencies_2d(), get_down_adjacencies_edg_3d(), get_face_edges(), get_up_adjacencies(), moab::NestedRefine::vertex_to_entities_down(), and moab::NestedRefine::vertex_to_entities_up().
    adjents.clear();
    if( lvids != NULL ) lvids->reserve( 20 );
    int vidx  = ID_FROM_HANDLE( vid ) - 1;
    EntityHandle start_eid = fid_from_halfacet( hf, MBEDGE );
    int start_lid          = lid_from_halffacet( hf );
    EntityHandle eid = start_eid;
    int lid          = start_lid;
    if( eid != 0 )
        adjents.push_back( eid );
        if( lvids != NULL ) lvids->push_back( lid );
        while( eid != 0 )
            if( ( !eid ) || ( eid == start_eid ) ) break;
    return MB_SUCCESS;
ErrorCode moab::HalfFacetRep::get_up_adjacencies_2d ( EntityHandle  eid,
std::vector< int > *  leids = NULL
Given an edge, finds the faces incident on it.
Given an edge, it first finds a matching half-edge corresponding to eid, and then collects all the incident half-edges/faces via the sibhes map.
Parameters:
adjentsVector returning the incident faces
local_idBy default false. If true, returns the local edge id's corresponding to the input edge
leidsVector returning local edge ids
Definition at line 1167 of file HalfFacetRep.cpp.
References moab::error(), ErrorCode, find_matching_halfedge(), MB_CHK_ERR, and MB_SUCCESS.
Referenced by collect_and_compare(), moab::NestedRefine::construct_hm_1D(), moab::NestedRefine::construct_hm_2D(), find_total_edges_2d(), gather_halfedges(), get_neighbor_adjacencies_2d(), get_up_adjacencies(), get_up_adjacencies_vert_2d(), moab::NestedRefine::is_edge_on_boundary(), and mark_halfedges().
    // Given an explicit edge eid, find the incident faces.
    ErrorCode error;
    EntityHandle he_fid = 0;
    int he_lid          = 0;
    // Step 1: Given an explicit edge, find a corresponding half-edge from the surface mesh.
    bool found = find_matching_halfedge( eid, &he_fid, &he_lid );
    // Step 2: If there is a corresponding half-edge, collect all sibling half-edges and store the
    // incident faces.
    if( found )
        error = get_up_adjacencies_2d( he_fid, he_lid, true, adjents, leids );MB_CHK_ERR( error );
    return MB_SUCCESS;
ErrorCode moab::HalfFacetRep::get_up_adjacencies_2d ( EntityHandle  fid,
int  leid,
bool  add_inent,
std::vector< EntityHandle > &  adj_ents,
std::vector< int > *  adj_leids = NULL,
std::vector< int > *  adj_orients = NULL
Given a half-edge <fid, leid>, finds the faces incident on it.
Parameters:
fidEntityHandle of the containing face
leidlocal id of the edge w.r.t to the face
add_inentIf true, adds the input fid into the returning vector of adjents.
local_idBy default false. If true, returns the local edge id's as well.
Definition at line 1191 of file HalfFacetRep.cpp.
References moab::error(), ErrorCode, fid_from_halfacet(), moab::Core::get_connectivity(), moab::ID_FROM_HANDLE(), lConnMap2D, lid_from_halffacet(), mb, MB_CHK_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps2D::next, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, sibhes, and moab::Core::type_from_handle().
    // Given an implicit half-edge <fid, leid>, find the incident half-edges.
    ErrorCode error;
    if( !fid ) return MB_FAILURE;
    adj_ents.reserve( 20 );
    bool local_id = false;
    bool orient   = false;
    if( adj_leids != NULL )
        local_id = true;
        adj_leids->reserve( 20 );
    if( adj_orients != NULL )
        orient = true;
        adj_orients->reserve( 20 );
    if( add_inent )
        adj_ents.push_back( fid );
        if( local_id ) adj_leids->push_back( leid );
    EntityHandle fedge[2] = { 0, 0 };
    if( orient )
        // get connectivity and match their directions
        const EntityHandle* fid_conn;
        error = mb->get_connectivity( fid, fid_conn, nepf, true );MB_CHK_ERR( error );
        int nidx = lConnMap2D[ftype - 2].next[leid];
        fedge[0] = fid_conn[leid];
        fedge[1] = fid_conn[nidx];
    int fidx            = ID_FROM_HANDLE( fid ) - 1;
    HFacet hf           = sibhes[nepf * fidx + leid];
    EntityHandle curfid = fid_from_halfacet( hf, ftype );
    int curlid          = lid_from_halffacet( hf );
    while( ( curfid != fid ) && ( curfid != 0 ) )
    {  // Should not go into the loop when no sibling exists
        adj_ents.push_back( curfid );
        if( local_id ) adj_leids->push_back( curlid );
        if( orient )
            const EntityHandle* conn;
            int nidx = lConnMap2D[ftype - 2].next[curlid];
            if( ( fedge[0] == conn[curlid] ) && ( fedge[1] == conn[nidx] ) )
                adj_orients->push_back( 1 );
            else if( ( fedge[1] == conn[curlid] ) && ( fedge[0] == conn[nidx] ) )
                adj_orients->push_back( 0 );
        int cidx = ID_FROM_HANDLE( curfid ) - 1;
        hf       = sibhes[nepf * cidx + curlid];
    return MB_SUCCESS;
ErrorCode moab::HalfFacetRep::get_up_adjacencies_2d ( EntityHandle  he_fid,
int  he_lid,
int *  qsize,
int *  count
) [protected]
Contains the local information for 2D entities.
Given a face, find the face type specific information
Parameters:
faceEntityHandle. Used to gather info about the type of face for which local info is required
nepf,:Returns the number of vertices/edges for given face type. Contains the local information for 2D entities Given number of edges, returns local indices of next and previous local edges.
nepf,:The number of vertices/edges for given face type.
next,prev,:Local ids of next and previous edges w.r.t to the face
Note: For 2D entities, the number of vertices and edges are same and each local edge is outgoing corresponding to the local vertex, i.e,
v2 v3 __e2__v2 /\ | | e2 / \ e1 e3| |e1 /____\ |______| v0 e0 v1 v0 e0 v1 Given a half-edge as <he_fid,he_lid> , finds the half-edges incident on it and adds them Given an half-edge, obtain all the incident half-edges via the sibhes map and add them to a given queue of half-edges, if they do not already exist in the queue. This function is used to increment the search space for finding a matching half-edge.
Parameters:
he_fidEntityHandle of query half-edge
he_lidLocal id of query half-edge
Definition at line 1274 of file HalfFacetRep.cpp.
References fid_from_halfacet(), find_match_in_array(), moab::ID_FROM_HANDLE(), lConnMap2D, lid_from_halffacet(), mb, MB_SUCCESS, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, queue_fid, queue_lid, sibhes, trackfaces, and moab::Core::type_from_handle().
    int nepf         = lConnMap2D[ftype - 2].num_verts_in_face;
    if( curfid == 0 )
        int index      = 0;
        bool found_ent = find_match_in_array( fid, queue_fid, qsize[0] - 1, true, &index );
        if( ( !found_ent ) || ( ( found_ent ) && ( queue_lid[index] != lid ) ) )
            queue_fid[qsize[0]] = fid;
            queue_lid[qsize[0]] = lid;
            qsize[0] += 1;
        if( !val )
            queue_fid[qsize[0]] = curfid;
            queue_lid[qsize[0]] = curlid;
            qsize[0] += 1;
    return MB_SUCCESS;
ErrorCode moab::HalfFacetRep::get_up_adjacencies_edg_3d ( EntityHandle  eid,
Given an edge, finds the cells incident on it.
Given an edge, it first finds a matching local edge in a cell corresponding to eid, and then collects all the incident cells via the sibhfs map.
Parameters:
adjentsVector returning the incident cells
Definition at line 2165 of file HalfFacetRep.cpp.
References _cells, moab::Range::begin(), cellq, moab::error(), ErrorCode, fid_from_halfacet(), find_match_in_array(), moab::Core::get_connectivity(), get_index_in_lmap(), moab::ID_FROM_HANDLE(), lConnMap3D, mb, MB_CHK_ERR, MB_SET_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::HalfFacetRep::LocalMaps3D::num_verts_in_cell, sibhfs, moab::Core::type_from_handle(), moab::HalfFacetRep::LocalMaps3D::v2hf, v2hf, moab::HalfFacetRep::LocalMaps3D::v2hf_num, and v2hfs.
Referenced by moab::NestedRefine::construct_hm_1D(), find_total_edges_faces_3d(), get_half_facet_in_comp(), get_up_adjacencies(), moab::NestedRefine::is_edge_on_boundary(), and moab::NestedRefine::update_tracking_verts().
    ErrorCode error;
    int nvpc                = lConnMap3D[index].num_verts_in_cell;
    int nfpc                = lConnMap3D[index].num_faces_in_cell;
    if( leids != NULL ) leids->reserve( 20 );
    int num_conn = 0;
    // Find an half-facets incident to each end vertex of the edge
            it_hes;
    else if( hf1 != 0 )
            it_hes;
    else if( hf2 != 0 )
    if( start_cells.empty() ) return MB_SUCCESS;
    std::sort( start_cells.begin(), start_cells.end() );
    std::vector< EntityHandle >::iterator last = std::unique( start_cells.begin(), start_cells.end() );
    start_cells.erase( last, start_cells.end() );
    int num_qvals = 0;
        num_qvals += 1;
                lv0 = i;
                lv  = lv0;
                lv1 = i;
                lv  = lv1;
            adjents.push_back( cell_id );
            if( leids != NULL ) leids->push_back( lConnMap3D[index].lookup_leids[lv0][lv1] );
        if( lv < 0 ) MB_SET_ERR( MB_FAILURE, "did not find local vertex " );
        int nhf_thisv = lConnMap3D[index].v2hf_num[lv];
            int ind          = lConnMap3D[index].v2hf[lv][i];
            if( ngb )
                if( !found_ent )
                    cellq[qsize] = ngb;
                    qsize += 1;
        cellq[i] = 0;
    return MB_SUCCESS;
ErrorCode moab::HalfFacetRep::get_up_adjacencies_edg_3d ( EntityHandle  cid,
int  leid,
std::vector< int > *  leids = NULL,
Given a local edge <cid, leid>, finds the cells incident on it.
Given a local edge, it gathers all the incident cells via the sibhfs map.
Parameters:
cidEntityHandle of the cell containing the local edge
leidlocal edge id w.r.t the cell
Definition at line 2298 of file HalfFacetRep.cpp.
References cellq, moab::HalfFacetRep::LocalMaps3D::e2v, moab::error(), ErrorCode, fid_from_halfacet(), find_match_in_array(), moab::Core::get_connectivity(), get_index_in_lmap(), moab::ID_FROM_HANDLE(), lConnMap3D, moab::HalfFacetRep::LocalMaps3D::lookup_leids, mb, MB_CHK_ERR, MB_SET_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::HalfFacetRep::LocalMaps3D::num_verts_in_cell, sibhfs, moab::Core::type_from_handle(), moab::HalfFacetRep::LocalMaps3D::v2hf, v2hf, moab::HalfFacetRep::LocalMaps3D::v2hf_num, and v2hfs.
    ErrorCode error;
    adjents.clear();
    if( leids != NULL )
        leids->clear();
        adj_orients->clear();
    EntityHandle v_start = econn[id];
    EntityHandle v_end   = econn[id];
            it_hes;
    else if( hf1 != 0 )
            it_hes;
    else if( hf2 != 0 )
    int num_qvals = 0;
        num_qvals += 1;
                lv0 = i;
                lv  = lv0;
                lv1 = i;
                lv  = lv1;
                int cur_leid = lConnMap3D[index].lookup_leids[lv0][lv1];
                int id1      = lConnMap3D[index].e2v[cur_leid][0];
                int id2      = lConnMap3D[index].e2v[cur_leid][1];
                if( ( v_start == conn[id1] ) && ( v_end == conn[id2] ) )
                else if( ( v_start == conn[id2] ) && ( v_end == conn[id1] ) )
            if( ngb )
                if( !found_ent )
                    cellq[qsize] = ngb;
                    qsize += 1;
        cellq[i] = 0;
    return MB_SUCCESS;
ErrorCode moab::HalfFacetRep::get_up_adjacencies_edg_3d_comp ( EntityHandle  cid,
int  leid,
Definition at line 2455 of file HalfFacetRep.cpp.
References cellq, moab::HalfFacetRep::LocalMaps3D::e2v, moab::error(), ErrorCode, fid_from_halfacet(), find_match_in_array(), moab::Core::get_connectivity(), get_index_in_lmap(), moab::ID_FROM_HANDLE(), lConnMap3D, moab::HalfFacetRep::LocalMaps3D::lookup_leids, mb, MB_CHK_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::HalfFacetRep::LocalMaps3D::num_verts_in_cell, sibhfs, moab::Core::type_from_handle(), moab::HalfFacetRep::LocalMaps3D::v2hf, v2hf, moab::HalfFacetRep::LocalMaps3D::v2hf_num, and v2hfs.
Referenced by moab::NestedRefine::update_global_ahf_3D().
    ErrorCode error;
    adjents.clear();
    if( leids != NULL )
        leids->clear();
    error = mb->get_connectivity( cid, econn, nvpc );MB_CHK_ERR( error );
    if( ( hf1 == 0 ) && ( v2hfs.find( v_start ) != v2hfs.end() ) && ( hf2 == 0 ) &&
        ( v2hfs.find( v_end ) != v2hfs.end() ) )
            it_hes;
    else
        return MB_SUCCESS;
    // std::sort(start_cells.begin(), start_cells.end());
    //  std::vector<EntityHandle>::iterator last = std::unique(start_cells.begin(),
    //  start_cells.end()); start_cells.erase(last, start_cells.end());
    for( int c = 0; c < (int)start_cells.size(); c++ )
        cellq[0] = start_cells[c];
        int qsize     = 1;
        int num_qvals = 0;
            num_qvals += 1;
            error = mb->get_connectivity( cell_id, conn, nvpc );MB_CHK_ERR( error );
                    lv0 = i;
                    lv  = lv0;
                    lv1 = i;
                    lv  = lv1;
                    cellq[i] = 0;
                break;
                if( ngb )
                    if( !found_ent )
                        cellq[qsize] = ngb;
                        qsize += 1;
            cellq[i] = 0;
    return MB_SUCCESS;
ErrorCode moab::HalfFacetRep::get_up_adjacencies_face_3d ( EntityHandle  fid,
std::vector< int > *  lfids = NULL
Given an face, finds the cells incident on it.
Given an face, it first finds a matching half-face in a cell corresponding to face, and then collects all the incident cells via the sibhfs map.
Parameters:
local_idBy default false. If true, returns the local face id's corresponding to the input face
leidsVector returning local face ids
Definition at line 2602 of file HalfFacetRep.cpp.
References moab::error(), ErrorCode, find_matching_halfface(), MB_CHK_ERR, and MB_SUCCESS.
Referenced by moab::NestedRefine::construct_hm_2D(), find_total_edges_faces_3d(), get_up_adjacencies(), moab::NestedRefine::is_face_on_boundary(), and moab::NestedRefine::update_tracking_verts().
    ErrorCode error;
    EntityHandle cid = 0;
    int lid          = 0;
    bool found       = find_matching_halfface( fid, &cid, &lid );
    if( found )
        error = get_up_adjacencies_face_3d( cid, lid, adjents, lfids );MB_CHK_ERR( error );
    return MB_SUCCESS;
ErrorCode moab::HalfFacetRep::get_up_adjacencies_face_3d ( EntityHandle  cid,
int  lfid,
Given a local face <cid, lfid>, finds the cells incident on it.
Given a local face, it gathers all the incident cells via the sibhfs map.
Parameters:
lfidlocal face id w.r.t the cell
lfidsVector returning local face ids
Definition at line 2620 of file HalfFacetRep.cpp.
References _cells, moab::Range::begin(), fid_from_halfacet(), get_index_in_lmap(), moab::ID_FROM_HANDLE(), lConnMap3D, lid_from_halffacet(), mb, MB_SUCCESS, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, sibhfs, and moab::Core::type_from_handle().
    int index               = get_index_in_lmap( start_cell );
    adjents.reserve( 4 );
    adjents.push_back( cid );
    if( lfids != NULL )
        lfids->reserve( 4 );
        lfids->push_back( lfid );
    int siblid          = lid_from_halffacet( hf );
    if( sibcid != 0 )
        if( lfids != NULL ) lfids->push_back( siblid );
    return MB_SUCCESS;
Given a vertex, finds the faces incident on it.
Given a vertex, it first finds an incident half-edge via v2he map, and then collects all the incident half-edges/faces via the sibhes map.
Parameters:
Definition at line 1089 of file HalfFacetRep.cpp.
References _faces, another_halfedge(), moab::Range::begin(), moab::error(), ErrorCode, fid_from_halfacet(), find_match_in_array(), gather_halfedges(), get_up_adjacencies_2d(), moab::ID_FROM_HANDLE(), lid_from_halffacet(), mb, MB_CHK_ERR, MB_SUCCESS, queue_fid, queue_lid, trackfaces, moab::Core::type_from_handle(), v2he, and v2hes.
Referenced by get_down_adjacencies_face_3d(), get_up_adjacencies(), moab::NestedRefine::vertex_to_entities_down(), and moab::NestedRefine::vertex_to_entities_up().
    ErrorCode error;
    EntityType ftype = mb->type_from_handle( *_faces.begin() );
    HFacet hf = v2he[vidx];
    std::vector< EntityHandle > start_fids;
    std::vector< int > start_lids;
    if( hf == 0 && ( v2hes.find( vid ) != v2hes.end() ) )
            it_hes;
            start_fids.push_back( fid_from_halfacet( it->second, ftype ) );
            start_lids.push_back( lid_from_halffacet( it->second ) );
    else if( hf != 0 )
        start_fids.push_back( fid_from_halfacet( hf, ftype ) );
        start_lids.push_back( lid_from_halffacet( hf ) );
    if( start_fids.empty() ) return MB_SUCCESS;
    int num_qvals = 0;
    adjents.reserve( (int)start_fids.size() );
    for( int i = 0; i < (int)start_fids.size(); i++ )
        adjents.push_back( start_fids[i] );
        error = gather_halfedges( vid, start_fids[i], start_lids[i], &qsize, &count );MB_CHK_ERR( error );
        EntityHandle curfid = queue_fid[num_qvals];
        int curlid          = queue_lid[num_qvals];
        num_qvals += 1;
        int he2_lid          = 0;
        error                = another_halfedge( vid, curfid, curlid, &he2_fid, &he2_lid );MB_CHK_ERR( error );
        bool val = find_match_in_array( he2_fid, trackfaces, count );
        if( val ) continue;
        count += 1;
        trackfaces[count] = he2_fid;
        error = get_up_adjacencies_2d( he2_fid, he2_lid, &qsize, &count );MB_CHK_ERR( error );
        adjents.push_back( he2_fid );
    // Change the visited faces to false, also empty the queue
    for( int i = 0; i <= qsize; i++ )
        queue_fid[i] = 0;
        queue_lid[i] = 0;
    for( int i = 0; i <= count; i++ )
        trackfaces[i] = 0;
    return MB_SUCCESS;
Given a vertex, finds the cells incident on it.
Given a vertex, it first finds an incident half-face via v2hf map, and then collects all the incident half-faces via the sibhfs map.
Parameters:
Definition at line 2072 of file HalfFacetRep.cpp.
Referenced by get_up_adjacencies(), moab::NestedRefine::vertex_to_entities_down(), and moab::NestedRefine::vertex_to_entities_up().
    ErrorCode error;
    // Obtain a half-face/s incident on v
    HFacet hf = v2hf[vidx];
    if( hf == 0 && ( v2hfs.find( vid ) != v2hfs.end() ) )  // Vertex is non-manifold
            it_hes;
    else if( hf != 0 )
    int index = get_index_in_lmap( start_cells[0] );
    EntityHandle cur_cid;
    int num_qvals = 0;
        cur_cid = cellq[num_qvals];
        num_qvals += 1;
        // Add the current cell to output adj vector
        adjents.push_back( cur_cid );
        // Connectivity of the cell
        error = mb->get_connectivity( cur_cid, conn, nvpc, true );MB_CHK_ERR( error );
        // Local id of vid in the cell and the half-faces incident on it
        int lv = -1;
        for( int i = 0; i < nvpc; ++i )
            if( conn[i] == vid )
                lv = i;
                break;
        // Number of local half-faces incident on the current vertex
        int cidx      = ID_FROM_HANDLE( cur_cid ) - 1;
        // Add new cells into the stack
        EntityHandle ngb;
        for( int i = 0; i < nhf_thisv; ++i )
            if( ngb )
                bool found_ent = find_match_in_array( ngb, cellq, qsize - 1 );
                if( !found_ent )
                    cellq[qsize] = ngb;
                    qsize += 1;
        cellq[i] = 0;
    return MB_SUCCESS;
Definition at line 294 of file HalfFacetRep.cpp.
References _faces, _verts, moab::Range::begin(), determine_incident_halfedges(), determine_sibling_halfedges(), moab::Range::end(), moab::error(), ErrorCode, moab::ID_FROM_HANDLE(), lConnMap2D, moab::MAXSIZE, mb, MB_CHK_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, queue_fid, queue_lid, sibhes, trackfaces, moab::Core::type_from_handle(), and v2he.
Referenced by initialize().
    ErrorCode error;
    int nv = ID_FROM_HANDLE( *( _verts.end() - 1 ) );
    int nf = ID_FROM_HANDLE( *( _faces.end() - 1 ) );
    v2he.resize( nv, 0 );
    sibhes.resize( nf * nepf, 0 );
    // Construct ahf maps
    error = determine_sibling_halfedges( _faces );MB_CHK_ERR( error );
    error = determine_incident_halfedges( _faces );MB_CHK_ERR( error );
    // Initialize queues for storing face and local id's during local search
    for( int i = 0; i < MAXSIZE; i++ )
        queue_fid[i]  = 0;
        queue_lid[i]  = 0;
        trackfaces[i] = 0;
    return MB_SUCCESS;
Definition at line 321 of file HalfFacetRep.cpp.
References _cells, _verts, moab::Range::begin(), cell_index, cellq, determine_incident_halffaces(), determine_sibling_halffaces(), moab::Range::end(), moab::error(), ErrorCode, get_index_in_lmap(), moab::ID_FROM_HANDLE(), lConnMap3D, moab::MAXSIZE, MB_CHK_ERR, MB_SUCCESS, MBHEX, MBPRISM, MBPYRAMID, MBTET, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, sibhfs, Stkcells, trackcells, and v2hf.
    ErrorCode error;
    // Initialize std::map between cell-types and their index in lConnMap3D
    cell_index[MBTET]     = 0;
    cell_index[MBPYRAMID] = 1;
    cell_index[MBPRISM]   = 2;
    cell_index[MBHEX]     = 3;
    int nc    = ID_FROM_HANDLE( *( _cells.end() - 1 ) );
    v2hf.resize( nv, 0 );
    sibhfs.resize( nc * nfpc, 0 );
    // Construct the maps
    error = determine_sibling_halffaces( _cells );MB_CHK_ERR( error );
    error = determine_incident_halffaces( _cells );MB_CHK_ERR( error );
        Stkcells[i]   = 0;
        cellq[i]      = 0;
        trackcells[i] = 0;
    return MB_SUCCESS;
Constructs the sibling-half-facet and vertex-to-incident-half-facet maps for each dimension present in the input. This routine should be called before any calls for adjacency is made.
Definition at line 190 of file HalfFacetRep.cpp.
References _cells, _edges, _faces, _filterghost, _rset, _verts, moab::CURVE, moab::error(), ErrorCode, moab::ParallelComm::filter_pstatus(), moab::Core::get_entities_by_dimension(), get_mesh_type(), init_curve(), init_surface(), init_volume(), mb, MB_CHK_ERR, MB_SUCCESS, mInitAHFmaps, pcomm, PSTATUS_GHOST, PSTATUS_NOT, moab::Range::size(), moab::SURFACE, moab::SURFACE_MIXED, thismeshtype, moab::VOLUME, moab::VOLUME_MIXED, moab::VOLUME_MIXED_1, and moab::VOLUME_MIXED_2.
Referenced by ahf_test(), get_adjacencies(), moab::NestedRefine::initialize(), and moab::HiReconstruction::initialize().
    ErrorCode error;
    if( !mInitAHFmaps )
        mInitAHFmaps = true;
#ifdef MOAB_HAVE_MPI
        if( pcomm && _filterghost )
            moab::Range _averts, _aedgs, _afacs, _acels;
            error = mb->get_entities_by_dimension( this->_rset, 0, _averts, true );MB_CHK_ERR( error );
            error = mb->get_entities_by_dimension( this->_rset, 1, _aedgs, true );MB_CHK_ERR( error );
            error = mb->get_entities_by_dimension( this->_rset, 2, _afacs, true );MB_CHK_ERR( error );
            error = mb->get_entities_by_dimension( this->_rset, 3, _acels, true );MB_CHK_ERR( error );
            // filter based on parallel status
            error = pcomm->filter_pstatus( _averts, PSTATUS_GHOST, PSTATUS_NOT, -1, &_verts );MB_CHK_ERR( error );
            error = pcomm->filter_pstatus( _aedgs, PSTATUS_GHOST, PSTATUS_NOT, -1, &_edges );MB_CHK_ERR( error );
            error = pcomm->filter_pstatus( _afacs, PSTATUS_GHOST, PSTATUS_NOT, -1, &_faces );MB_CHK_ERR( error );
            error = pcomm->filter_pstatus( _acels, PSTATUS_GHOST, PSTATUS_NOT, -1, &_cells );MB_CHK_ERR( error );
        else
            error = mb->get_entities_by_dimension( this->_rset, 0, _verts, true );MB_CHK_ERR( error );
            error = mb->get_entities_by_dimension( this->_rset, 1, _edges, true );MB_CHK_ERR( error );
            error = mb->get_entities_by_dimension( this->_rset, 2, _faces, true );MB_CHK_ERR( error );
            error = mb->get_entities_by_dimension( this->_rset, 3, _cells, true );MB_CHK_ERR( error );
#else
#endif
        int nverts = _verts.size();
        int nedges = _edges.size();
        int nfaces = _faces.size();
        int ncells = _cells.size();
        MESHTYPE mesh_type = get_mesh_type( nverts, nedges, nfaces, ncells );
        thismeshtype       = mesh_type;
        // Initialize mesh type specific maps
        if( thismeshtype == CURVE )
            error = init_curve();MB_CHK_ERR( error );
        else if( thismeshtype == SURFACE )
            error = init_surface();MB_CHK_ERR( error );
        else if( thismeshtype == SURFACE_MIXED )
        else if( thismeshtype == VOLUME )
            error = init_volume();MB_CHK_ERR( error );
        else if( thismeshtype == VOLUME_MIXED_1 )
        else if( thismeshtype == VOLUME_MIXED_2 )
        else if( thismeshtype == VOLUME_MIXED )
    return MB_SUCCESS;
ErrorCode moab::HalfFacetRep::mark_halfedges ( EntityHandle  vid,
int  he_lid,
Range &  faces,
std::vector< char > &  markHEdgs,
HFacet &  bnd_hf
) [protected]
Definition at line 1019 of file HalfFacetRep.cpp.
References another_halfedge(), create_halffacet(), moab::error(), ErrorCode, fid_from_halfacet(), find_match_in_array(), gather_halfedges(), moab::Core::get_connectivity(), get_up_adjacencies_2d(), moab::ID_FROM_HANDLE(), moab::Range::index(), lConnMap2D, mb, MB_CHK_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, queue_fid, queue_lid, sibhes, trackfaces, and moab::Core::type_from_handle().
Referenced by determine_incident_halfedges().
    ErrorCode error;
    EntityType ftype = mb->type_from_handle( he_fid );
    int num_qvals = 0;
    error = gather_halfedges( vid, he_fid, he_lid, &qsize, &count );MB_CHK_ERR( error );
        num_qvals += 1;
        int fidx = ID_FROM_HANDLE( curfid ) - 1;
        error = mb->get_connectivity( curfid, conn, nepf, true );MB_CHK_ERR( error );
        if( !markHEdgs[nepf * faces.index( curfid ) + curlid] && ( conn[curlid] == vid ) )
            markHEdgs[nepf * faces.index( curfid ) + curlid] = 1;
            HFacet hf                                        = sibhes[nepf * fidx + curlid];
            EntityHandle sibfid                              = fid_from_halfacet( hf, ftype );
            if( sibfid == 0 ) bnd_hf = create_halffacet( curfid, curlid );
        int he2_lid          = 0;
        if( !markHEdgs[nepf * faces.index( curfid ) + he2_lid] && ( conn[he2_lid] == vid ) )
            markHEdgs[nepf * faces.index( curfid ) + he2_lid] = 1;
            HFacet hf                                         = sibhes[nepf * fidx + he2_lid];
            if( sibfid == 0 ) bnd_hf = create_halffacet( he2_fid, he2_lid );
        if( val ) continue;
        count += 1;
        queue_fid[i] = 0;
        queue_lid[i] = 0;
        trackfaces[i] = 0;
    return MB_SUCCESS;
Prints the tag values.
Definition at line 356 of file HalfFacetRep.cpp.
References _cells, _edges, _faces, _verts, moab::Range::begin(), moab::Range::end(), fid_from_halfacet(), get_index_in_lmap(), moab::ID_FROM_HANDLE(), lConnMap2D, lConnMap3D, lid_from_halffacet(), mb, MB_SUCCESS, MBEDGE, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, sibhes, sibhfs, sibhvs, moab::Core::type_from_handle(), v2he, v2hf, v2hfs, and v2hv.
    if( dim == 1 )
        EntityHandle start_edge = *_edges.begin();
        std::cout << "start_edge = " << start_edge << std::endl;
        std::cout << "<SIBHVS_EID,SIBHVS_LVID>" << std::endl;
        for( Range::iterator i = _edges.begin(); i != _edges.end(); ++i )
            EntityHandle eid[2];
            int lvid[2];
            int eidx   = ID_FROM_HANDLE( *i ) - 1;
            HFacet hf1 = sibhvs[2 * eidx];
            HFacet hf2 = sibhvs[2 * eidx + 1];
            eid[0]     = fid_from_halfacet( hf1, MBEDGE );
            eid[1]     = fid_from_halfacet( hf2, MBEDGE );
            lvid[0]    = lid_from_halffacet( hf1 );
            lvid[1]    = lid_from_halffacet( hf2 );
            std::cout << "Entity = " << *i << " :: <" << eid[0] << "," << lvid[0] << ">"
                      << "<" << eid[1] << "," << lvid[1] << ">" << std::endl;
        std::cout << "<V2HV_EID, V2HV_LVID>" << std::endl;
        for( Range::iterator i = _verts.begin(); i != _verts.end(); ++i )
            int vidx         = ID_FROM_HANDLE( *i ) - 1;
            HFacet hf        = v2hv[vidx];
            EntityHandle eid = fid_from_halfacet( hf, MBEDGE );
            int lvid         = lid_from_halffacet( hf );
            std::cout << "Vertex = " << *i << " :: <" << eid << "," << lvid << ">" << std::endl;
    else if( dim == 2 )
        EntityHandle start_face = *_faces.begin();
        std::cout << "start_face = " << start_face << std::endl;
        std::cout << "<SIBHES_FID,SIBHES_LEID>" << std::endl;
        for( Range::iterator i = _faces.begin(); i != _faces.end(); ++i )
            int fidx = ID_FROM_HANDLE( *i ) - 1;
            std::cout << "Entity = " << *i;
            for( int j = 0; j < nepf; j++ )
                HFacet hf        = sibhes[nepf * fidx + j];
                EntityHandle sib = fid_from_halfacet( hf, ftype );
                int lid          = lid_from_halffacet( hf );
                std::cout << " :: <" << sib << "," << lid << ">"
            std::cout << std::endl;
        std::cout << "<V2HE_FID, V2HE_LEID>" << std::endl;
            EntityHandle fid = fid_from_halfacet( hf, ftype );
            std::cout << "Vertex = " << *i << " :: <" << fid << "," << lid << ">" << std::endl;
    else if( dim == 3 )
        std::cout << "start_cell = " << start_cell << std::endl;
        std::cout << "<SIBHES_CID,SIBHES_LFID>" << std::endl;
        for( Range::iterator i = _cells.begin(); i != _cells.end(); ++i )
            int cidx = ID_FROM_HANDLE( *i ) - 1;
                EntityHandle sib = fid_from_halfacet( hf, ctype );
        std::cout << "<V2HF_CID, V2HF_LFID>" << std::endl;
        EntityHandle cid;
        int lid;
            if( hf == 0 && ( v2hfs.find( *i ) != v2hfs.end() ) )
                    it_hfs;
                it_hfs = v2hfs.equal_range( *i );
                    cid = fid_from_halfacet( it->second, ctype );
                    std::cout << "Vertex = " << *i << " :: <" << cid << "," << lid << ">" << std::endl;
            else
                cid = fid_from_halfacet( hf, ctype );
    return MB_SUCCESS;
ErrorCode moab::HalfFacetRep::resize_hf_maps ( EntityHandle  start_vert,
int  nverts,
EntityHandle  start_edge,
int  nedges,
EntityHandle  start_face,
int  nfaces,
EntityHandle  start_cell,
int  ncells
Definition at line 3276 of file HalfFacetRep.cpp.
References _cells, _edges, _faces, _verts, moab::Range::begin(), moab::Range::end(), get_index_in_lmap(), moab::ID_FROM_HANDLE(), lConnMap2D, lConnMap3D, mb, MB_SET_ERR, MB_SUCCESS, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, sibhes, sibhfs, sibhvs, moab::Core::type_from_handle(), v2he, v2hf, and v2hv.
Referenced by moab::NestedRefine::create_hm_storage_single_level().
    int nwsz = 0, insz = 0;
    if( nedges )
        if( ID_FROM_HANDLE( ( *( _edges.end() - 1 ) + 1 ) ) != ID_FROM_HANDLE( start_edge ) )
            nwsz = ( ID_FROM_HANDLE( start_edge ) - ID_FROM_HANDLE( *_edges.end() ) + nedges ) * 2;
        else
            nwsz = nedges * 2;
        insz = sibhvs.size();
        sibhvs.resize( insz + nwsz, 0 );
        if( v2hv.empty() )
            if( ( !v2he.empty() ) )
                insz = v2he.size();
            else if( ( !v2hf.empty() ) )
                insz = v2hf.size();
            else
                MB_SET_ERR( MB_FAILURE, "Trying to resize ahf maps for a mesh with no edges, faces and cells" );
        else
            insz = v2hv.size();
        if( ID_FROM_HANDLE( *( _verts.end() - 1 ) + 1 ) != ID_FROM_HANDLE( start_vert ) )
            nwsz = ID_FROM_HANDLE( start_vert ) - ID_FROM_HANDLE( *_verts.end() ) + nverts;
        else
            nwsz = nverts;
        v2hv.resize( insz + nwsz, 0 );
    if( nfaces )
        if( ID_FROM_HANDLE( ( *( _faces.end() - 1 ) + 1 ) ) != ID_FROM_HANDLE( start_face ) )
            nwsz = ( ID_FROM_HANDLE( start_face ) - ID_FROM_HANDLE( *_faces.end() ) + nfaces ) * nepf;
        else
            nwsz = nfaces * nepf;
        insz = sibhes.size();
        sibhes.resize( insz + nwsz, 0 );
        else
            nwsz = nverts;
        insz = v2he.size();
        v2he.resize( insz + nwsz, 0 );
    if( ncells )
        if( ID_FROM_HANDLE( ( *( _cells.end() - 1 ) + 1 ) ) != ID_FROM_HANDLE( start_cell ) )
            nwsz = ( ID_FROM_HANDLE( start_cell ) - ID_FROM_HANDLE( *_cells.end() ) + ncells ) * nfpc;
        else
            nwsz = ncells * nfpc;
        insz = sibhfs.size();
        sibhfs.resize( insz + nwsz, 0 );
        else
            nwsz = nverts;
        insz = v2hf.size();
        v2hf.resize( insz + nwsz, 0 );
    return MB_SUCCESS;
ErrorCode moab::HalfFacetRep::set_incident_map ( EntityType  type,
EntityHandle  vid,
std::vector< EntityHandle > &  set_entid,
std::vector< int > &  set_lid
Definition at line 3607 of file HalfFacetRep.cpp.
References create_halffacet(), moab::ID_FROM_HANDLE(), MB_SUCCESS, MBEDGE, MBQUAD, MBTRI, v2he, v2hes, v2hf, v2hfs, and v2hv.
Referenced by moab::NestedRefine::update_global_ahf_1D(), moab::NestedRefine::update_global_ahf_1D_sub(), moab::NestedRefine::update_global_ahf_2D(), moab::NestedRefine::update_global_ahf_2D_sub(), moab::NestedRefine::update_global_ahf_3D(), and moab::NestedRefine::update_local_ahf().
        v2hv[ID_FROM_HANDLE( vid ) - 1] = create_halffacet( set_entid[0], set_lid[0] );
        if( set_entid.size() == 1 )
            v2he[ID_FROM_HANDLE( vid ) - 1] = create_halffacet( set_entid[0], set_lid[0] );
        else
            HFacet hf = 0;
            for( int i = 0; i < (int)set_entid.size(); i++ )
                hf = create_halffacet( set_entid[i], set_lid[i] );
                v2hes.insert( std::pair< EntityHandle, HFacet >( vid, hf ) );
    else
            v2hf[ID_FROM_HANDLE( vid ) - 1] = create_halffacet( set_entid[0], set_lid[0] );
        else
            HFacet hf = v2hf[ID_FROM_HANDLE( vid ) - 1];
            if( hf != 0 )
                v2hf[ID_FROM_HANDLE( vid ) - 1] = 0;
                v2hfs.insert( std::pair< EntityHandle, HFacet >( vid, hf ) );
    return MB_SUCCESS;
ErrorCode moab::HalfFacetRep::set_sibling_map ( EntityType  type,
EntityHandle  ent,
EntityHandle *  set_entids,
int *  set_lids,
int  num_halffacets
Definition at line 3462 of file HalfFacetRep.cpp.
References _cells, moab::Range::begin(), create_halffacet(), get_index_in_lmap(), moab::ID_FROM_HANDLE(), lConnMap2D, lConnMap3D, MB_SET_ERR, MB_SUCCESS, MBEDGE, MBQUAD, MBTRI, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, sibhes, sibhfs, and sibhvs.
        if( num_halffacets != 2 ) MB_SET_ERR( MB_FAILURE, "Incorrect number of halfvertices" );
            sibhvs[2 * eidx + i] = create_halffacet( set_entids[i], set_lids[i] );
        for( int i = 0; i < nepf; i++ )
            sibhes[nepf * fidx + i] = create_halffacet( set_entids[i], set_lids[i] );
    else
        for( int i = 0; i < nfpc; i++ )
            sibhfs[nfpc * cidx + i] = create_halffacet( set_entids[i], set_lids[i] );
    return MB_SUCCESS;
EntityHandle  ent,
int  lid,
EntityHandle &  set_entid,
int &  set_lid
Definition at line 3506 of file HalfFacetRep.cpp.
References _cells, moab::Range::begin(), create_halffacet(), get_index_in_lmap(), moab::ID_FROM_HANDLE(), lConnMap2D, lConnMap3D, MB_SUCCESS, MBEDGE, MBQUAD, MBTRI, moab::HalfFacetRep::LocalMaps3D::num_faces_in_cell, moab::HalfFacetRep::LocalMaps2D::num_verts_in_face, sibhes, sibhfs, and sibhvs.
        sibhvs[2 * eidx + lid] = create_halffacet( set_entid, set_lid );
        sibhes[nepf * fidx + lid] = create_halffacet( set_entid, set_lid );
    else
        sibhfs[nfpc * cidx + lid] = create_halffacet( set_entid, set_lid );
    return MB_SUCCESS;
Member Data Documentation
Definition at line 555 of file HalfFacetRep.hpp.
Definition at line 554 of file HalfFacetRep.hpp.
Referenced by check_mixed_entity_type(), get_rset(), and initialize().
Initial value:
    { { { 0, 1, 0, 0 }, { 1, 1, 0, 0 }, { 0, 0, 0, 0 }, { 0, 0, 0, 0 } } },
    { { { 0, 0, 1, 0 }, { 0, 0, 0, 0 }, { 1, 0, 1, 0 }, { 0, 0, 0, 0 } } },
    { { { 0, 1, 1, 0 }, { 1, 1, 1, 0 }, { 1, 1, 1, 0 }, { 0, 0, 0, 0 } } },
    { { { 0, 0, 0, 1 }, { 0, 0, 0, 0 }, { 0, 0, 0, 0 }, { 1, 0, 0, 1 } } },
    { { { 0, 1, 0, 1 }, { 1, 1, 0, 1 }, { 0, 0, 0, 0 }, { 1, 1, 0, 1 } } },
    { { { 0, 0, 1, 1 }, { 0, 0, 0, 0 }, { 1, 0, 1, 1 }, { 1, 0, 1, 1 } } },
    { { { 0, 1, 1, 1 }, { 1, 1, 1, 1 }, { 1, 1, 1, 1 }, { 1, 1, 1, 1 } } } }
Definition at line 578 of file HalfFacetRep.hpp.
std::map< EntityType, int > moab::HalfFacetRep::cell_index
Definition at line 538 of file HalfFacetRep.hpp.
Referenced by get_index_in_lmap(), and init_volume().
Definition at line 583 of file HalfFacetRep.hpp.
Referenced by check_mixed_entity_type(), and HalfFacetRep().
bool moab::HalfFacetRep::is_mixed [protected]
Definition at line 582 of file HalfFacetRep.hpp.
Definition at line 556 of file HalfFacetRep.hpp.
Referenced by get_adjacencies(), HalfFacetRep(), and initialize().
Definition at line 553 of file HalfFacetRep.hpp.
List of all members.
