MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "moab/DiscreteGeometry/HiReconstruction.hpp" 00002 #include "moab/DiscreteGeometry/DGMSolver.hpp" 00003 #include "moab/HalfFacetRep.hpp" 00004 00005 #ifdef MOAB_HAVE_MPI 00006 #include "moab/ParallelComm.hpp" 00007 #endif 00008 #include "MBTagConventions.hpp" 00009 00010 #define HIREC_USE_AHF 00011 00012 #include <cmath> 00013 #include <deque> 00014 #include <iostream> 00015 00016 namespace moab 00017 { 00018 HiReconstruction::HiReconstruction( Core* impl, ParallelComm* comm, EntityHandle meshIn, int minpnts, bool recwhole ) 00019 : mbImpl( impl ), pcomm( comm ), _mesh2rec( meshIn ), _MINPNTS( minpnts ) 00020 { 00021 assert( NULL != impl ); 00022 ErrorCode error; 00023 _MINEPS = 1e-12; 00024 _dim = 0; 00025 _hasfittings = false; 00026 _hasderiv = false; 00027 #ifdef MOAB_HAVE_MPI 00028 if( !pcomm ) 00029 { 00030 pcomm = moab::ParallelComm::get_pcomm( mbImpl, 0 ); 00031 } 00032 #endif 00033 00034 error = initialize( recwhole ); 00035 if( MB_SUCCESS != error ) 00036 { 00037 std::cout << "Error initializing HiReconstruction\n" << std::endl; 00038 exit( 1 ); 00039 } 00040 } 00041 00042 HiReconstruction::~HiReconstruction() 00043 { 00044 #ifdef MOAB_HAVE_AHF 00045 ahf = NULL; 00046 #else 00047 delete ahf; 00048 #endif 00049 } 00050 00051 ErrorCode HiReconstruction::initialize( bool recwhole ) 00052 { 00053 ErrorCode error; 00054 00055 #ifdef HIREC_USE_AHF 00056 std::cout << "HIREC_USE_AHF: Initializing" << std::endl; 00057 ahf = new HalfFacetRep( mbImpl, pcomm, _mesh2rec, false ); 00058 if( !ahf ) 00059 { 00060 return MB_MEMORY_ALLOCATION_FAILED; 00061 } 00062 error = ahf->initialize();MB_CHK_ERR( error ); 00063 #else 00064 ahf = NULL; 00065 #endif 00066 00067 // error = ahf->get_entity_ranges(_inverts,_inedges,_infaces,_incells); MB_CHK_ERR(error); 00068 error = mbImpl->get_entities_by_dimension( _mesh2rec, 0, _inverts );MB_CHK_ERR( error ); 00069 error = mbImpl->get_entities_by_dimension( _mesh2rec, 1, _inedges );MB_CHK_ERR( error ); 00070 error = mbImpl->get_entities_by_dimension( _mesh2rec, 2, _infaces );MB_CHK_ERR( error ); 00071 error = mbImpl->get_entities_by_dimension( _mesh2rec, 3, _incells );MB_CHK_ERR( error ); 00072 if( _inedges.size() && _infaces.empty() && _incells.empty() ) 00073 { 00074 _dim = 1; 00075 _MAXPNTS = 13; 00076 } 00077 else if( _infaces.size() && _incells.empty() ) 00078 { 00079 _dim = 2; 00080 _MAXPNTS = 128; 00081 } 00082 else 00083 { 00084 MB_SET_ERR( MB_FAILURE, "Encountered a non-manifold mesh or a mesh with volume elements" ); 00085 } 00086 00087 // get locally hosted vertices by filtering pstatus 00088 #ifdef MOAB_HAVE_MPI 00089 if( pcomm ) 00090 { 00091 error = pcomm->filter_pstatus( _inverts, PSTATUS_GHOST, PSTATUS_NOT, -1, &_verts2rec );MB_CHK_ERR( error ); 00092 } 00093 else 00094 { 00095 _verts2rec = _inverts; 00096 } 00097 #else 00098 _verts2rec = _inverts; 00099 #endif 00100 _nv2rec = _verts2rec.size(); 00101 00102 if( recwhole ) 00103 { 00104 // compute normals(surface) or tangent vector(curve) for all locally hosted vertices 00105 if( 2 == _dim ) 00106 { 00107 compute_average_vertex_normals_surf(); 00108 } 00109 else if( 1 == _dim ) 00110 { 00111 compute_average_vertex_tangents_curve(); 00112 } 00113 else 00114 { 00115 MB_SET_ERR( MB_FAILURE, "Unknow space dimension" ); 00116 } 00117 _hasderiv = true; 00118 } 00119 return error; 00120 } 00121 00122 /*************************************************** 00123 * User Interface for Reconstruction of Geometry * 00124 ***************************************************/ 00125 00126 ErrorCode HiReconstruction::reconstruct3D_surf_geom( int degree, bool interp, bool safeguard, bool reset ) 00127 { 00128 assert( 2 == _dim ); 00129 if( _hasfittings && !reset ) 00130 { 00131 // This object has precomputed fitting results and user don't want to reset 00132 return MB_SUCCESS; 00133 } 00134 else 00135 { 00136 _initfittings = _hasfittings = false; 00137 } 00138 // initialize for geometric information 00139 initialize_surf_geom( degree ); 00140 ErrorCode error; 00141 double *coeffs, *coords; 00142 int* degree_out; 00143 int ncoeffs = ( degree + 2 ) * ( degree + 1 ) / 2; 00144 00145 // DBG 00146 int dcount = 0; 00147 00148 for( Range::iterator ivert = _verts2rec.begin(); ivert != _verts2rec.end(); ++ivert ) 00149 { 00150 int index = _verts2rec.index( *ivert ); 00151 // for debug 00152 /*if(index==70){ 00153 EntityHandle vid = *ivert; 00154 double vertcoords[3]; 00155 error = mbImpl->get_coords(&vid,1,vertcoords); 00156 }*/ 00157 00158 size_t istr = _vertID2coeffID[index]; 00159 coords = &( _local_coords[9 * index] ); 00160 coeffs = &( _local_fit_coeffs[istr] ); 00161 degree_out = &( _degrees_out[index] ); 00162 _interps[index] = interp; 00163 error = polyfit3d_walf_surf_vertex( *ivert, interp, degree, _MINPNTS, safeguard, 9, coords, degree_out, ncoeffs, 00164 coeffs );MB_CHK_ERR( error ); 00165 00166 // DBG 00167 if( degree_out[0] < degree ) dcount += 1; 00168 } 00169 00170 // DBG 00171 // std::cout<<"Total #points ="<<_verts2rec.size()<<", #degraded points = "<<dcount<<std::endl; 00172 00173 _geom = HISURFACE; 00174 _hasfittings = true; 00175 return error; 00176 } 00177 00178 ErrorCode HiReconstruction::reconstruct3D_surf_geom( size_t npts, 00179 int* degrees, 00180 bool* interps, 00181 bool safeguard, 00182 bool reset ) 00183 { 00184 assert( _dim == 2 ); 00185 if( npts != _nv2rec ) 00186 { 00187 MB_SET_ERR( MB_FAILURE, "Input number of degrees doesn't match number of vertices" ); 00188 } 00189 if( _hasfittings && !reset ) 00190 { 00191 return MB_SUCCESS; 00192 } 00193 else 00194 { 00195 _initfittings = _hasfittings = false; 00196 } 00197 ErrorCode error; 00198 // initialization for fitting 00199 initialize_surf_geom( npts, degrees ); 00200 double *coeffs, *coords; 00201 int* degree_out; 00202 size_t i = 0; 00203 for( Range::iterator ivert = _verts2rec.begin(); ivert != _verts2rec.end(); ++ivert, ++i ) 00204 { 00205 int index = _verts2rec.index( *ivert ); 00206 assert( -1 != index ); 00207 size_t istr = _vertID2coeffID[index]; 00208 coords = &( _local_coords[9 * index] ); 00209 coeffs = &( _local_fit_coeffs[istr] ); 00210 degree_out = &( _degrees_out[index] ); 00211 _interps[index] = interps[i]; 00212 int ncoeffs = ( degrees[i] + 2 ) * ( degrees[i] + 1 ) / 2; 00213 error = polyfit3d_walf_surf_vertex( *ivert, interps[i], degrees[i], _MINPNTS, safeguard, 9, coords, degree_out, 00214 ncoeffs, coeffs );MB_CHK_ERR( error ); 00215 } 00216 _geom = HISURFACE; 00217 _hasfittings = true; 00218 return error; 00219 } 00220 00221 ErrorCode HiReconstruction::reconstruct3D_curve_geom( int degree, bool interp, bool safeguard, bool reset ) 00222 { 00223 assert( _dim == 1 ); 00224 if( _hasfittings && !reset ) 00225 { 00226 return MB_SUCCESS; 00227 } 00228 else 00229 { 00230 _initfittings = _hasfittings = false; 00231 } 00232 initialize_3Dcurve_geom( degree ); 00233 ErrorCode error; 00234 double *coords = 0, *coeffs; 00235 int* degree_out; 00236 int ncoeffs = 3 * ( degree + 1 ); 00237 for( Range::iterator ivert = _verts2rec.begin(); ivert != _verts2rec.end(); ++ivert ) 00238 { 00239 int index = _verts2rec.index( *ivert ); 00240 assert( index != -1 ); 00241 size_t istr = _vertID2coeffID[index]; 00242 coeffs = &( _local_fit_coeffs[istr] ); 00243 degree_out = &( _degrees_out[index] ); 00244 _interps[index] = interp; 00245 error = polyfit3d_walf_curve_vertex( *ivert, interp, degree, _MINPNTS, safeguard, 0, coords, degree_out, 00246 ncoeffs, coeffs );MB_CHK_ERR( error ); 00247 } 00248 _geom = HI3DCURVE; 00249 _hasfittings = true; 00250 return error; 00251 } 00252 00253 ErrorCode HiReconstruction::reconstruct3D_curve_geom( size_t npts, 00254 int* degrees, 00255 bool* interps, 00256 bool safeguard, 00257 bool reset ) 00258 { 00259 assert( _dim == 1 ); 00260 ErrorCode error; 00261 if( npts != _nv2rec ) 00262 { 00263 MB_SET_ERR( MB_FAILURE, "Input number of degrees doesn't match the number of vertices" ); 00264 } 00265 if( _hasfittings && !reset ) 00266 { 00267 return MB_SUCCESS; 00268 } 00269 else 00270 { 00271 _initfittings = _hasfittings = false; 00272 } 00273 // initialize 00274 initialize_3Dcurve_geom( npts, degrees ); 00275 double *coords = 0, *coeffs; 00276 int* degree_out; 00277 size_t i = 0; 00278 for( Range::iterator ivert = _verts2rec.begin(); ivert != _verts2rec.end(); ++ivert, ++i ) 00279 { 00280 int index = _verts2rec.index( *ivert ); 00281 size_t istr = _vertID2coeffID[index]; 00282 coeffs = &( _local_fit_coeffs[istr] ); 00283 degree_out = &( _degrees_out[index] ); 00284 _interps[index] = interps[i]; 00285 int ncoeffs = 3 * ( degrees[i] + 1 ); 00286 error = polyfit3d_walf_curve_vertex( *ivert, interps[i], degrees[i], _MINPNTS, safeguard, 0, coords, degree_out, 00287 ncoeffs, coeffs );MB_CHK_ERR( error ); 00288 } 00289 _geom = HI3DCURVE; 00290 _hasfittings = true; 00291 return error; 00292 } 00293 00294 ErrorCode HiReconstruction::polyfit3d_walf_surf_vertex( const EntityHandle vid, 00295 const bool interp, 00296 int degree, 00297 int minpnts, 00298 const bool safeguard, 00299 const int ncoords, 00300 double* coords, 00301 int* degree_out, 00302 const int ncoeffs, 00303 double* coeffs ) 00304 { 00305 assert( _dim == 2 ); 00306 ErrorCode error; 00307 int ring = estimate_num_rings( degree, interp ); 00308 // std::cout<<"ring = "<<ring<<std::endl; 00309 // get n-ring neighbors 00310 Range ngbvs; 00311 error = obtain_nring_ngbvs( vid, ring, minpnts, ngbvs );MB_CHK_ERR( error ); 00312 // for debug 00313 /*if(_verts2rec.index(vid)==70){ 00314 for(Range::iterator ingb=ngbvs.begin();ingb!=ngbvs.end();++ingb) std::cerr << 00315 _verts2rec.index(*ingb) << " "; std::cout << std::endl; 00316 }*/ 00317 00318 // get coordinates; 00319 size_t nverts = ngbvs.size(); 00320 assert( nverts ); 00321 double* ngbcoords = new double[nverts * 3]; 00322 error = mbImpl->get_coords( ngbvs, ngbcoords );MB_CHK_ERR( error ); 00323 // get normals 00324 double* ngbnrms = new double[nverts * 3]; 00325 error = get_normals_surf( ngbvs, ngbnrms );MB_CHK_ERR( error ); 00326 // switch vid to first one 00327 int index = ngbvs.index( vid ); 00328 assert( index != -1 ); 00329 std::swap( ngbcoords[0], ngbcoords[3 * index] ); 00330 std::swap( ngbcoords[1], ngbcoords[3 * index + 1] ); 00331 std::swap( ngbcoords[2], ngbcoords[3 * index + 2] ); 00332 std::swap( ngbnrms[0], ngbnrms[3 * index] ); 00333 std::swap( ngbnrms[1], ngbnrms[3 * index + 1] ); 00334 std::swap( ngbnrms[2], ngbnrms[3 * index + 2] ); 00335 // local WLS fitting 00336 int degree_pnt, degree_qr; 00337 polyfit3d_surf_get_coeff( nverts, ngbcoords, ngbnrms, degree, interp, safeguard, ncoords, coords, ncoeffs, coeffs, 00338 degree_out, °ree_pnt, °ree_qr ); 00339 delete[] ngbcoords; 00340 delete[] ngbnrms; 00341 return error; 00342 } 00343 00344 ErrorCode HiReconstruction::polyfit3d_walf_curve_vertex( const EntityHandle vid, 00345 const bool interp, 00346 int degree, 00347 int minpnts, 00348 const bool safeguard, 00349 const int ncoords, 00350 double* coords, 00351 int* degree_out, 00352 const int ncoeffs, 00353 double* coeffs ) 00354 { 00355 ErrorCode error; 00356 int ring = estimate_num_rings( degree, interp ); 00357 // get n-ring neighbors 00358 Range ngbvs; 00359 error = obtain_nring_ngbvs( vid, ring, minpnts, ngbvs );MB_CHK_ERR( error ); 00360 // get coordinates 00361 size_t nverts = ngbvs.size(); 00362 assert( nverts ); 00363 double* ngbcoords = new double[nverts * 3]; 00364 error = mbImpl->get_coords( ngbvs, ngbcoords );MB_CHK_ERR( error ); 00365 // get tangent vectors 00366 double* ngbtangs = new double[nverts * 3]; 00367 error = get_tangents_curve( ngbvs, ngbtangs );MB_CHK_ERR( error ); 00368 // switch vid to first one 00369 int index = ngbvs.index( vid ); 00370 assert( index != -1 ); 00371 std::swap( ngbcoords[0], ngbcoords[3 * index] ); 00372 std::swap( ngbcoords[1], ngbcoords[3 * index + 1] ); 00373 std::swap( ngbcoords[2], ngbcoords[3 * index + 2] ); 00374 std::swap( ngbtangs[0], ngbtangs[3 * index] ); 00375 std::swap( ngbtangs[1], ngbtangs[3 * index + 1] ); 00376 std::swap( ngbtangs[2], ngbtangs[3 * index + 2] ); 00377 // local WLS fittings 00378 polyfit3d_curve_get_coeff( nverts, ngbcoords, ngbtangs, degree, interp, safeguard, ncoords, coords, ncoeffs, coeffs, 00379 degree_out ); 00380 delete[] ngbcoords; 00381 delete[] ngbtangs; 00382 return error; 00383 } 00384 00385 /************************************************************** 00386 * User Interface for Evaluation via Reconstructed Geometry * 00387 **************************************************************/ 00388 00389 ErrorCode HiReconstruction::hiproj_walf_in_element( EntityHandle elem, 00390 const int nvpe, 00391 const int npts2fit, 00392 const double* naturalcoords2fit, 00393 double* newcoords ) 00394 { 00395 assert( newcoords ); 00396 ErrorCode error; 00397 // get connectivity table 00398 std::vector< EntityHandle > elemconn; 00399 error = mbImpl->get_connectivity( &elem, 1, elemconn );MB_CHK_ERR( error ); 00400 if( nvpe != (int)elemconn.size() ) 00401 { 00402 MB_SET_ERR( MB_FAILURE, "element connectivity table size doesn't match input size" ); 00403 } 00404 00405 if( !_hasfittings ) 00406 { 00407 MB_SET_ERR( MB_FAILURE, "There is no existing fitting results" ); 00408 } 00409 else 00410 { 00411 std::ostringstream convert; 00412 convert << elem; 00413 std::string ID = convert.str(); 00414 for( int i = 0; i < nvpe; ++i ) 00415 { 00416 if( -1 == _verts2rec.index( elemconn[i] ) ) 00417 { 00418 MB_SET_ERR( MB_FAILURE, "There is no existing fitting results for element " + ID ); 00419 } 00420 } 00421 } 00422 // check correctness of input 00423 for( int i = 0; i < npts2fit; ++i ) 00424 { 00425 if( !check_barycentric_coords( nvpe, naturalcoords2fit + i * nvpe ) ) 00426 { 00427 MB_SET_ERR( MB_FAILURE, "Wrong barycentric coordinates" ); 00428 } 00429 } 00430 00431 double* elemcoords = new double[nvpe * 3]; 00432 error = mbImpl->get_coords( &( elemconn[0] ), nvpe, elemcoords );MB_CHK_ERR( error ); 00433 00434 double* coords2fit = new double[3 * npts2fit](); 00435 for( int i = 0; i < npts2fit; ++i ) 00436 { 00437 for( int j = 0; j < nvpe; ++j ) 00438 { 00439 coords2fit[3 * i] += naturalcoords2fit[i * nvpe + j] * elemcoords[3 * j]; 00440 coords2fit[3 * i + 1] += naturalcoords2fit[i * nvpe + j] * elemcoords[3 * j + 1]; 00441 coords2fit[3 * i + 2] += naturalcoords2fit[i * nvpe + j] * elemcoords[3 * j + 2]; 00442 } 00443 } 00444 00445 double* hiproj_new = new double[3 * npts2fit]; 00446 // initialize output 00447 for( int i = 0; i < npts2fit; ++i ) 00448 { 00449 newcoords[3 * i] = newcoords[3 * i + 1] = newcoords[3 * i + 2] = 0; 00450 } 00451 // for each input vertex, call nvpe fittings and take average 00452 for( int j = 0; j < nvpe; ++j ) 00453 { 00454 error = hiproj_walf_around_vertex( elemconn[j], npts2fit, coords2fit, hiproj_new );MB_CHK_ERR( error ); 00455 for( int i = 0; i < npts2fit; ++i ) 00456 { 00457 newcoords[3 * i] += naturalcoords2fit[i * nvpe + j] * hiproj_new[3 * i]; 00458 newcoords[3 * i + 1] += naturalcoords2fit[i * nvpe + j] * hiproj_new[3 * i + 1]; 00459 newcoords[3 * i + 2] += naturalcoords2fit[i * nvpe + j] * hiproj_new[3 * i + 2]; 00460 } 00461 } 00462 delete[] elemcoords; 00463 delete[] coords2fit; 00464 delete[] hiproj_new; 00465 return error; 00466 } 00467 00468 ErrorCode HiReconstruction::hiproj_walf_around_vertex( EntityHandle vid, 00469 const int npts2fit, 00470 const double* coords2fit, 00471 double* hiproj_new ) 00472 { 00473 if( !_hasfittings ) 00474 { 00475 MB_SET_ERR( MB_FAILURE, "There is no existing fitting results" ); 00476 } 00477 else if( -1 == _verts2rec.index( vid ) ) 00478 { 00479 std::ostringstream convert; 00480 convert << vid; 00481 std::string VID = convert.str(); 00482 MB_SET_ERR( MB_FAILURE, "There is no existing fitting results for vertex " + VID ); 00483 } 00484 ErrorCode error; 00485 // get center of local coordinates system 00486 double local_origin[3]; 00487 error = mbImpl->get_coords( &vid, 1, local_origin );MB_CHK_ERR( error ); 00488 // get local fitting parameters 00489 int index = _verts2rec.index( vid ); 00490 bool interp = _interps[index]; 00491 int local_deg = _degrees_out[index]; 00492 double *uvw_coords, *local_coeffs; 00493 if( _geom == HISURFACE ) 00494 { 00495 uvw_coords = &( _local_coords[9 * index] ); 00496 // int ncoeffs = (local_deg+2)*(local_deg+1)>>1; 00497 size_t istr = _vertID2coeffID[index]; 00498 local_coeffs = &( _local_fit_coeffs[istr] ); 00499 walf3d_surf_vertex_eval( local_origin, uvw_coords, local_deg, local_coeffs, interp, npts2fit, coords2fit, 00500 hiproj_new ); 00501 } 00502 else if( _geom == HI3DCURVE ) 00503 { 00504 uvw_coords = &( _local_coords[3 * index] ); 00505 size_t istr = _vertID2coeffID[index]; 00506 local_coeffs = &( _local_fit_coeffs[istr] ); 00507 walf3d_curve_vertex_eval( local_origin, uvw_coords, local_deg, local_coeffs, interp, npts2fit, coords2fit, 00508 hiproj_new ); 00509 } 00510 return error; 00511 } 00512 00513 void HiReconstruction::walf3d_surf_vertex_eval( const double* local_origin, 00514 const double* local_coords, 00515 const int local_deg, 00516 const double* local_coeffs, 00517 const bool interp, 00518 const int npts2fit, 00519 const double* coords2fit, 00520 double* hiproj_new ) 00521 { 00522 double xaxis[3], yaxis[3], zaxis[3]; 00523 for( int i = 0; i < 3; ++i ) 00524 { 00525 xaxis[i] = local_coords[i]; 00526 yaxis[i] = local_coords[3 + i]; 00527 zaxis[i] = local_coords[6 + i]; 00528 } 00529 // double *basis = new double[(local_deg+2)*(local_deg+1)/2-1]; 00530 std::vector< double > basis( ( local_deg + 2 ) * ( local_deg + 1 ) / 2 - 1 ); 00531 for( int i = 0; i < npts2fit; ++i ) 00532 { 00533 double local_pos[3]; 00534 for( int j = 0; j < 3; ++j ) 00535 { 00536 local_pos[j] = coords2fit[3 * i + j] - local_origin[j]; 00537 } 00538 double u, v, height = 0; 00539 u = DGMSolver::vec_innerprod( 3, local_pos, xaxis ); 00540 v = DGMSolver::vec_innerprod( 3, local_pos, yaxis ); 00541 basis[0] = u; 00542 basis[1] = v; 00543 int l = 1; 00544 for( int k = 2; k <= local_deg; ++k ) 00545 { 00546 ++l; 00547 basis[l] = u * basis[l - k]; 00548 for( int id = 0; id < k; ++id ) 00549 { 00550 ++l; 00551 basis[l] = basis[l - k - 1] * v; 00552 } 00553 } 00554 if( !interp ) 00555 { 00556 height = local_coeffs[0]; 00557 } 00558 for( int p = 0; p <= l; ++p ) 00559 { 00560 height += local_coeffs[p + 1] * basis[p]; 00561 } 00562 hiproj_new[3 * i] = local_origin[0] + u * xaxis[0] + v * yaxis[0] + height * zaxis[0]; 00563 hiproj_new[3 * i + 1] = local_origin[1] + u * xaxis[1] + v * yaxis[1] + height * zaxis[1]; 00564 hiproj_new[3 * i + 2] = local_origin[2] + u * xaxis[2] + v * yaxis[2] + height * zaxis[2]; 00565 } 00566 // delete [] basis; 00567 } 00568 00569 void HiReconstruction::walf3d_curve_vertex_eval( const double* local_origin, 00570 const double* local_coords, 00571 const int local_deg, 00572 const double* local_coeffs, 00573 const bool interp, 00574 const int npts2fit, 00575 const double* coords2fit, 00576 double* hiproj_new ) 00577 { 00578 assert( local_origin && local_coords && local_coeffs ); 00579 int ncoeffspvpd = local_deg + 1; 00580 for( int i = 0; i < npts2fit; ++i ) 00581 { 00582 // get the vector from center to current point, project to tangent line 00583 double vec[3], ans[3] = { 0, 0, 0 }; 00584 DGMSolver::vec_linear_operation( 3, 1, coords2fit + 3 * i, -1, local_origin, vec ); 00585 double u = DGMSolver::vec_innerprod( 3, local_coords, vec ); 00586 // evaluate polynomials 00587 if( !interp ) 00588 { 00589 ans[0] = local_coeffs[0]; 00590 ans[1] = local_coeffs[ncoeffspvpd]; 00591 ans[2] = local_coeffs[2 * ncoeffspvpd]; 00592 } 00593 double uk = 1; // degree_out and degree different, stored in columnwise contiguously 00594 for( int j = 1; j < ncoeffspvpd; ++j ) 00595 { 00596 uk *= u; 00597 ans[0] += uk * local_coeffs[j]; 00598 ans[1] += uk * local_coeffs[j + ncoeffspvpd]; 00599 ans[2] += uk * local_coeffs[j + 2 * ncoeffspvpd]; 00600 } 00601 hiproj_new[3 * i] = ans[0] + local_origin[0]; 00602 hiproj_new[3 * i + 1] = ans[1] + local_origin[1]; 00603 hiproj_new[3 * i + 2] = ans[2] + local_origin[2]; 00604 } 00605 } 00606 00607 bool HiReconstruction::get_fittings_data( EntityHandle vid, 00608 GEOMTYPE& geomtype, 00609 std::vector< double >& coords, 00610 int& degree_out, 00611 std::vector< double >& coeffs, 00612 bool& interp ) 00613 { 00614 if( !_hasfittings ) 00615 { 00616 return false; 00617 } 00618 else 00619 { 00620 int index = _verts2rec.index( vid ); 00621 if( -1 == index ) 00622 { 00623 std::cout << "Input vertex is not locally hosted vertex in this mesh set" << std::endl; 00624 return false; 00625 } 00626 geomtype = _geom; 00627 if( HISURFACE == _geom ) 00628 { 00629 coords.insert( coords.end(), _local_coords.begin() + 9 * index, _local_coords.begin() + 9 * index + 9 ); 00630 degree_out = _degrees_out[index]; 00631 interp = _interps[index]; 00632 int ncoeffs = ( degree_out + 2 ) * ( degree_out + 1 ) >> 1; 00633 size_t istr = _vertID2coeffID[index]; 00634 coeffs.insert( coeffs.end(), _local_fit_coeffs.begin() + istr, _local_fit_coeffs.begin() + istr + ncoeffs ); 00635 } 00636 else if( HI3DCURVE == _geom ) 00637 { 00638 coords.insert( coords.end(), _local_coords.begin() + 3 * index, _local_coords.begin() + 3 * index + 3 ); 00639 degree_out = _degrees_out[index]; 00640 interp = _interps[index]; 00641 int ncoeffs = 3 * ( degree_out + 1 ); 00642 size_t istr = _vertID2coeffID[index]; 00643 coeffs.insert( coeffs.end(), _local_fit_coeffs.begin() + istr, _local_fit_coeffs.begin() + istr + ncoeffs ); 00644 } 00645 return true; 00646 } 00647 } 00648 00649 /**************************************************************** 00650 * Basic Internal Routines to initialize and set fitting data * 00651 ****************************************************************/ 00652 00653 int HiReconstruction::estimate_num_rings( int degree, bool interp ) 00654 { 00655 return interp ? ( ( degree + 1 ) >> 1 ) + ( ( degree + 1 ) & 1 ) : ( ( degree + 2 ) >> 1 ) + ( ( degree + 2 ) & 1 ); 00656 } 00657 00658 ErrorCode HiReconstruction::vertex_get_incident_elements( const EntityHandle& vid, 00659 const int elemdim, 00660 std::vector< EntityHandle >& adjents ) 00661 { 00662 ErrorCode error; 00663 assert( elemdim == _dim ); 00664 #ifdef HIREC_USE_AHF 00665 error = ahf->get_up_adjacencies( vid, elemdim, adjents );MB_CHK_ERR( error ); 00666 #else 00667 error = mbImpl->get_adjacencies( &vid, 1, elemdim, false, adjents );MB_CHK_ERR( error ); 00668 #endif 00669 return error; 00670 } 00671 00672 ErrorCode HiReconstruction::obtain_nring_ngbvs( const EntityHandle vid, int ring, const int minpnts, Range& ngbvs ) 00673 { 00674 ErrorCode error; 00675 std::deque< EntityHandle > todo; 00676 todo.push_back( vid ); 00677 ngbvs.insert( vid ); 00678 EntityHandle pre, nxt; 00679 for( int i = 1; i <= ring; ++i ) 00680 { 00681 int count = todo.size(); 00682 while( count ) 00683 { 00684 EntityHandle center = todo.front(); 00685 todo.pop_front(); 00686 --count; 00687 std::vector< EntityHandle > adjents; 00688 error = vertex_get_incident_elements( center, _dim, adjents );MB_CHK_ERR( error ); 00689 for( size_t j = 0; j < adjents.size(); ++j ) 00690 { 00691 std::vector< EntityHandle > elemconn; 00692 error = mbImpl->get_connectivity( &adjents[j], 1, elemconn );MB_CHK_ERR( error ); 00693 int nvpe = elemconn.size(); 00694 for( int k = 0; k < nvpe; ++k ) 00695 { 00696 if( elemconn[k] == center ) 00697 { 00698 pre = k == 0 ? elemconn[nvpe - 1] : elemconn[k - 1]; 00699 nxt = elemconn[( k + 1 ) % nvpe]; 00700 if( ngbvs.find( pre ) == ngbvs.end() ) 00701 { 00702 ngbvs.insert( pre ); 00703 todo.push_back( pre ); 00704 } 00705 if( ngbvs.find( nxt ) == ngbvs.end() ) 00706 { 00707 ngbvs.insert( nxt ); 00708 todo.push_back( nxt ); 00709 } 00710 break; 00711 } 00712 } 00713 } 00714 } 00715 if( _MAXPNTS <= (int)ngbvs.size() ) 00716 { 00717 // obtain enough points 00718 return error; 00719 } 00720 if( !todo.size() ) 00721 { 00722 // current ring cannot introduce any points, return incase deadlock 00723 return error; 00724 } 00725 if( ( i == ring ) && ( minpnts > (int)ngbvs.size() ) ) 00726 { 00727 // reach maximum ring but not enough points 00728 ++ring; 00729 } 00730 } 00731 return error; 00732 } 00733 00734 void HiReconstruction::initialize_surf_geom( const int degree ) 00735 { 00736 if( !_hasderiv ) 00737 { 00738 compute_average_vertex_normals_surf(); 00739 _hasderiv = true; 00740 } 00741 if( !_initfittings ) 00742 { 00743 int ncoeffspv = ( degree + 2 ) * ( degree + 1 ) / 2; 00744 _degrees_out.assign( _nv2rec, 0 ); 00745 _interps.assign( _nv2rec, false ); 00746 _vertID2coeffID.resize( _nv2rec ); 00747 _local_fit_coeffs.assign( _nv2rec * ncoeffspv, 0 ); 00748 for( size_t i = 0; i < _nv2rec; ++i ) 00749 { 00750 _vertID2coeffID[i] = i * ncoeffspv; 00751 } 00752 _initfittings = true; 00753 } 00754 } 00755 00756 void HiReconstruction::initialize_surf_geom( const size_t npts, const int* degrees ) 00757 { 00758 if( !_hasderiv ) 00759 { 00760 compute_average_vertex_normals_surf(); 00761 _hasderiv = true; 00762 } 00763 if( !_initfittings ) 00764 { 00765 assert( _nv2rec == npts ); 00766 _degrees_out.assign( _nv2rec, 0 ); 00767 _interps.assign( _nv2rec, false ); 00768 _vertID2coeffID.resize( _nv2rec ); 00769 size_t index = 0; 00770 for( size_t i = 0; i < _nv2rec; ++i ) 00771 { 00772 _vertID2coeffID[i] = index; 00773 index += ( degrees[i] + 2 ) * ( degrees[i] + 1 ) / 2; 00774 } 00775 _local_fit_coeffs.assign( index, 0 ); 00776 _initfittings = true; 00777 } 00778 } 00779 00780 void HiReconstruction::initialize_3Dcurve_geom( const int degree ) 00781 { 00782 if( !_hasderiv ) 00783 { 00784 compute_average_vertex_tangents_curve(); 00785 _hasderiv = true; 00786 } 00787 if( !_initfittings ) 00788 { 00789 int ncoeffspvpd = degree + 1; 00790 _degrees_out.assign( _nv2rec, 0 ); 00791 _interps.assign( _nv2rec, false ); 00792 _vertID2coeffID.resize( _nv2rec ); 00793 _local_fit_coeffs.assign( _nv2rec * ncoeffspvpd * 3, 0 ); 00794 for( size_t i = 0; i < _nv2rec; ++i ) 00795 { 00796 _vertID2coeffID[i] = i * ncoeffspvpd * 3; 00797 } 00798 _initfittings = true; 00799 } 00800 } 00801 00802 void HiReconstruction::initialize_3Dcurve_geom( const size_t npts, const int* degrees ) 00803 { 00804 if( !_hasderiv ) 00805 { 00806 compute_average_vertex_tangents_curve(); 00807 _hasderiv = true; 00808 } 00809 if( !_hasfittings ) 00810 { 00811 assert( _nv2rec == npts ); 00812 _degrees_out.assign( _nv2rec, 0 ); 00813 _interps.assign( _nv2rec, false ); 00814 _vertID2coeffID.reserve( _nv2rec ); 00815 size_t index = 0; 00816 for( size_t i = 0; i < _nv2rec; ++i ) 00817 { 00818 _vertID2coeffID[i] = index; 00819 index += 3 * ( degrees[i] + 1 ); 00820 } 00821 _local_fit_coeffs.assign( index, 0 ); 00822 _initfittings = true; 00823 } 00824 } 00825 00826 /* ErrorCode HiReconstruction::set_geom_data_surf(const EntityHandle vid, const double* coords, 00827 const double degree_out, const double* coeffs, bool interp) 00828 { 00829 return MB_SUCCESS; 00830 } 00831 00832 ErrorCode HiReconstruction::set_geom_data_3Dcurve(const EntityHandle vid, const double* coords, 00833 const double degree_out, const double* coeffs, bool interp) 00834 { 00835 return MB_SUCCESS; 00836 } */ 00837 00838 /********************************************************* 00839 * Routines for vertex normal/tangent vector estimation * 00840 *********************************************************/ 00841 ErrorCode HiReconstruction::average_vertex_normal( const EntityHandle vid, double* nrm ) 00842 { 00843 ErrorCode error; 00844 std::vector< EntityHandle > adjfaces; 00845 error = vertex_get_incident_elements( vid, 2, adjfaces );MB_CHK_ERR( error ); 00846 int npolys = adjfaces.size(); 00847 if( !npolys ) 00848 { 00849 MB_SET_ERR( MB_FAILURE, "Vertex has no incident 2D entities" ); 00850 } 00851 else 00852 { 00853 double v1[3], v2[3], v3[3], a[3], b[3], c[3]; 00854 nrm[0] = nrm[1] = nrm[2] = 0; 00855 for( int i = 0; i < npolys; ++i ) 00856 { 00857 // get incident "triangles" 00858 std::vector< EntityHandle > elemconn; 00859 error = mbImpl->get_connectivity( &adjfaces[i], 1, elemconn );MB_CHK_ERR( error ); 00860 EntityHandle pre, nxt; 00861 int nvpe = elemconn.size(); 00862 for( int j = 0; j < nvpe; ++j ) 00863 { 00864 if( vid == elemconn[j] ) 00865 { 00866 pre = j == 0 ? elemconn[nvpe - 1] : elemconn[j - 1]; 00867 nxt = elemconn[( j + 1 ) % nvpe]; 00868 break; 00869 } 00870 } 00871 // compute area weighted normals 00872 error = mbImpl->get_coords( &pre, 1, a );MB_CHK_ERR( error ); 00873 error = mbImpl->get_coords( &vid, 1, b );MB_CHK_ERR( error ); 00874 error = mbImpl->get_coords( &nxt, 1, c );MB_CHK_ERR( error ); 00875 DGMSolver::vec_linear_operation( 3, 1, c, -1, b, v1 ); 00876 DGMSolver::vec_linear_operation( 3, 1, a, -1, b, v2 ); 00877 DGMSolver::vec_crossprod( v1, v2, v3 ); 00878 DGMSolver::vec_linear_operation( 3, 1, nrm, 1, v3, nrm ); 00879 } 00880 #ifndef NDEBUG 00881 assert( DGMSolver::vec_normalize( 3, nrm, nrm ) ); 00882 #endif 00883 } 00884 return error; 00885 } 00886 00887 ErrorCode HiReconstruction::compute_average_vertex_normals_surf() 00888 { 00889 if( _hasderiv ) 00890 { 00891 return MB_SUCCESS; 00892 } 00893 ErrorCode error; 00894 _local_coords.assign( 9 * _nv2rec, 0 ); 00895 size_t index = 0; 00896 for( Range::iterator ivert = _verts2rec.begin(); ivert != _verts2rec.end(); ++ivert, ++index ) 00897 { 00898 error = average_vertex_normal( *ivert, &( _local_coords[9 * index + 6] ) );MB_CHK_ERR( error ); 00899 } 00900 return error; 00901 } 00902 00903 ErrorCode HiReconstruction::get_normals_surf( const Range& vertsh, double* nrms ) 00904 { 00905 ErrorCode error = MB_SUCCESS; 00906 if( _hasderiv ) 00907 { 00908 size_t id = 0; 00909 for( Range::iterator ivert = vertsh.begin(); ivert != vertsh.end(); ++ivert, ++id ) 00910 { 00911 int index = _verts2rec.index( *ivert ); 00912 #ifdef MOAB_HAVE_MPI 00913 if( -1 == index ) 00914 { 00915 // ghost vertex 00916 error = average_vertex_normal( *ivert, nrms + 3 * id );MB_CHK_ERR( error ); 00917 } 00918 else 00919 { 00920 nrms[3 * id] = _local_coords[9 * index + 6]; 00921 nrms[3 * id + 1] = _local_coords[9 * index + 7]; 00922 nrms[3 * id + 2] = _local_coords[9 * index + 8]; 00923 } 00924 #else 00925 assert( -1 != index ); 00926 nrms[3 * id] = _local_coords[9 * index + 6]; 00927 nrms[3 * id + 1] = _local_coords[9 * index + 7]; 00928 nrms[3 * id + 2] = _local_coords[9 * index + 8]; 00929 #endif 00930 } 00931 } 00932 else 00933 { 00934 size_t id = 0; 00935 for( Range::iterator ivert = vertsh.begin(); ivert != vertsh.end(); ++ivert, ++id ) 00936 { 00937 error = average_vertex_normal( *ivert, nrms + 3 * id );MB_CHK_ERR( error ); 00938 } 00939 } 00940 return error; 00941 } 00942 00943 ErrorCode HiReconstruction::average_vertex_tangent( const EntityHandle vid, double* tang ) 00944 { 00945 ErrorCode error; 00946 std::vector< EntityHandle > adjedges; 00947 error = vertex_get_incident_elements( vid, 1, adjedges );MB_CHK_ERR( error ); 00948 int nedges = adjedges.size(); 00949 if( !nedges ) 00950 { 00951 MB_SET_ERR( MB_FAILURE, "Vertex has no incident edges" ); 00952 } 00953 else 00954 { 00955 assert( nedges <= 2 ); 00956 tang[0] = tang[1] = tang[2] = 0; 00957 for( int i = 0; i < nedges; ++i ) 00958 { 00959 std::vector< EntityHandle > edgeconn; 00960 error = mbImpl->get_connectivity( &adjedges[i], 1, edgeconn ); 00961 double istr[3], iend[3], t[3]; 00962 error = mbImpl->get_coords( &( edgeconn[0] ), 1, istr ); 00963 error = mbImpl->get_coords( &( edgeconn[1] ), 1, iend ); 00964 DGMSolver::vec_linear_operation( 3, 1, iend, -1, istr, t ); 00965 DGMSolver::vec_linear_operation( 3, 1, tang, 1, t, tang ); 00966 } 00967 #ifndef NDEBUG 00968 assert( DGMSolver::vec_normalize( 3, tang, tang ) ); 00969 #endif 00970 } 00971 return error; 00972 } 00973 00974 ErrorCode HiReconstruction::compute_average_vertex_tangents_curve() 00975 { 00976 if( _hasderiv ) 00977 { 00978 return MB_SUCCESS; 00979 } 00980 ErrorCode error; 00981 _local_coords.assign( 3 * _nv2rec, 0 ); 00982 size_t index = 0; 00983 for( Range::iterator ivert = _verts2rec.begin(); ivert != _verts2rec.end(); ++ivert, ++index ) 00984 { 00985 error = average_vertex_tangent( *ivert, &( _local_coords[3 * index] ) );MB_CHK_ERR( error ); 00986 } 00987 return error; 00988 } 00989 00990 ErrorCode HiReconstruction::get_tangents_curve( const Range& vertsh, double* tangs ) 00991 { 00992 ErrorCode error = MB_SUCCESS; 00993 if( _hasderiv ) 00994 { 00995 size_t id = 0; 00996 for( Range::iterator ivert = vertsh.begin(); ivert != vertsh.end(); ++ivert, ++id ) 00997 { 00998 int index = _verts2rec.index( *ivert ); 00999 #ifdef MOAB_HAVE_MPI 01000 if( -1 != index ) 01001 { 01002 tangs[3 * id] = _local_coords[3 * index]; 01003 tangs[3 * id + 1] = _local_coords[3 * index + 1]; 01004 tangs[3 * id + 2] = _local_coords[3 * index + 2]; 01005 } 01006 else 01007 { 01008 error = average_vertex_tangent( *ivert, tangs + 3 * id );MB_CHK_ERR( error ); 01009 } 01010 #else 01011 assert( -1 != index ); 01012 tangs[3 * id] = _local_coords[3 * index]; 01013 tangs[3 * id + 1] = _local_coords[3 * index + 1]; 01014 tangs[3 * id + 2] = _local_coords[3 * index + 2]; 01015 #endif 01016 } 01017 } 01018 else 01019 { 01020 size_t id = 0; 01021 for( Range::iterator ivert = vertsh.begin(); ivert != vertsh.end(); ++ivert, ++id ) 01022 { 01023 error = average_vertex_tangent( *ivert, tangs + 3 * id );MB_CHK_ERR( error ); 01024 } 01025 } 01026 return error; 01027 } 01028 01029 /************************************************ 01030 * Internal Routines for local WLS fittings * 01031 *************************************************/ 01032 01033 void HiReconstruction::polyfit3d_surf_get_coeff( const int nverts, 01034 const double* ngbcoords, 01035 const double* ngbnrms, 01036 int degree, 01037 const bool interp, 01038 const bool safeguard, 01039 const int ncoords, 01040 double* coords, 01041 const int ncoeffs, 01042 double* coeffs, 01043 int* degree_out, 01044 int* degree_pnt, 01045 int* degree_qr ) 01046 { 01047 if( nverts <= 0 ) 01048 { 01049 return; 01050 } 01051 01052 // std::cout << "npnts in initial stencil = " << nverts << std::endl; 01053 // std::cout << "centered at (" << ngbcoords[0] << "," << ngbcoords[1] << "," << ngbcoords[2] << 01054 // ")" << std::endl; 01055 01056 // step 1. copmute local coordinate system 01057 double nrm[3] = { ngbnrms[0], ngbnrms[1], ngbnrms[2] }, tang1[3] = { 0, 0, 0 }, tang2[3] = { 0, 0, 0 }; 01058 if( fabs( nrm[0] ) > fabs( nrm[1] ) && fabs( nrm[0] ) > fabs( nrm[2] ) ) 01059 { 01060 tang1[1] = 1.0; 01061 } 01062 else 01063 { 01064 tang1[0] = 1.0; 01065 } 01066 01067 DGMSolver::vec_projoff( 3, tang1, nrm, tang1 ); 01068 #ifndef NDEBUG 01069 assert( DGMSolver::vec_normalize( 3, tang1, tang1 ) ); 01070 #endif 01071 DGMSolver::vec_crossprod( nrm, tang1, tang2 ); 01072 if( 9 <= ncoords && coords ) 01073 { 01074 coords[0] = tang1[0]; 01075 coords[1] = tang1[1]; 01076 coords[2] = tang1[2]; 01077 coords[3] = tang2[0]; 01078 coords[4] = tang2[1]; 01079 coords[5] = tang2[2]; 01080 coords[6] = nrm[0]; 01081 coords[7] = nrm[1]; 01082 coords[8] = nrm[2]; 01083 } 01084 if( !ncoeffs || !coeffs ) 01085 { 01086 return; 01087 } 01088 else 01089 { 01090 assert( ncoeffs >= ( degree + 2 ) * ( degree + 1 ) / 2 ); 01091 } 01092 01093 // step 2. project onto local coordinates system 01094 int npts2fit = nverts - interp; 01095 if( 0 == npts2fit ) 01096 { 01097 *degree_out = *degree_pnt = *degree_qr = 0; 01098 for( int i = 0; i < ncoeffs; ++i ) 01099 { 01100 coeffs[i] = 0; 01101 } 01102 // coeffs[0] = 0; 01103 return; 01104 } 01105 std::vector< double > us( npts2fit * 2 ); // double *us = new double[npts2fit*2]; 01106 std::vector< double > bs( npts2fit ); // double *bs = new double[npts2fit]; 01107 for( int i = interp; i < nverts; ++i ) 01108 { 01109 int k = i - interp; 01110 double uu[3]; 01111 DGMSolver::vec_linear_operation( 3, 1, ngbcoords + 3 * i, -1, ngbcoords, uu ); 01112 us[k * 2] = DGMSolver::vec_innerprod( 3, tang1, uu ); 01113 us[k * 2 + 1] = DGMSolver::vec_innerprod( 3, tang2, uu ); 01114 bs[k] = DGMSolver::vec_innerprod( 3, nrm, uu ); 01115 } 01116 01117 // step 3. compute weights 01118 std::vector< double > ws( npts2fit ); // double *ws = new double[npts2fit]; 01119 int nzeros = compute_weights( npts2fit, 2, &( us[0] ), nverts, ngbnrms, degree, _MINEPS, &( ws[0] ) ); 01120 01121 // step 4. adjust according to zero-weights 01122 if( nzeros ) 01123 { 01124 if( nzeros == npts2fit ) 01125 { 01126 *degree_out = *degree_pnt = *degree_qr = 0; 01127 for( int i = 0; i < ncoeffs; ++i ) 01128 { 01129 coeffs[i] = 0; 01130 } 01131 // coeffs[0] = 0; 01132 return; 01133 } 01134 int index = 0; 01135 for( int i = 0; i < npts2fit; ++i ) 01136 { 01137 if( ws[i] ) 01138 { 01139 if( i > index ) 01140 { 01141 us[index * 2] = us[i * 2]; 01142 us[index * 2 + 1] = us[i * 2 + 1]; 01143 bs[index] = bs[i]; 01144 ws[index] = ws[i]; 01145 } 01146 ++index; 01147 } 01148 } 01149 npts2fit -= nzeros; 01150 assert( index == npts2fit ); 01151 us.resize( npts2fit * 2 ); 01152 bs.resize( npts2fit ); 01153 ws.resize( npts2fit ); 01154 /*us = realloc(us,npts2fit*2*sizeof(double)); 01155 bs = realloc(bs,npts2fit*sizeof(double)); 01156 ws = realloc(ws,npts2fit*sizeof(double));*/ 01157 } 01158 01159 // std::cout<<"npnts after weighting = "<<npts2fit<<std::endl; 01160 01161 // step 5. fitting 01162 eval_vander_bivar_cmf( npts2fit, &( us[0] ), 1, &( bs[0] ), degree, &( ws[0] ), interp, safeguard, degree_out, 01163 degree_pnt, degree_qr ); 01164 01165 // step 6. organize output 01166 int ncoeffs_out = ( *degree_out + 2 ) * ( *degree_out + 1 ) / 2; 01167 assert( ncoeffs_out <= ncoeffs ); 01168 coeffs[0] = 0; 01169 for( int j = 0; j < ncoeffs_out - interp; ++j ) 01170 { 01171 coeffs[j + interp] = bs[j]; 01172 } 01173 // delete [] us; delete [] bs; delete [] ws; 01174 } 01175 01176 void HiReconstruction::eval_vander_bivar_cmf( const int npts2fit, 01177 const double* us, 01178 const int ndim, 01179 double* bs, 01180 int degree, 01181 const double* ws, 01182 const bool interp, 01183 const bool safeguard, 01184 int* degree_out, 01185 int* degree_pnt, 01186 int* degree_qr ) 01187 { 01188 // step 1. adjust the degree according to number of points to fit 01189 int ncols = ( ( ( degree + 2 ) * ( degree + 1 ) ) >> 1 ) - interp; 01190 while( 1 < degree && npts2fit < ncols ) 01191 { 01192 --degree; 01193 ncols = ( ( ( degree + 2 ) * ( degree + 1 ) ) >> 1 ) - interp; 01194 } 01195 *degree_pnt = degree; 01196 01197 // std::cout << "degree_pnt: " << *degree_pnt << std::endl; 01198 01199 // step 2. construct Vandermonde matrix, stored in columnwise 01200 std::vector< double > V; // V(npts2fit*(ncols+interp)); //double *V_init = new double[npts2fit*(ncols+interp)]; 01201 DGMSolver::gen_vander_multivar( npts2fit, 2, us, degree, V ); 01202 // remove the first column of 1s if interpolation 01203 if( interp ) 01204 { 01205 V.erase( V.begin(), V.begin() + npts2fit ); 01206 } 01207 /*double* V; 01208 if(interp){ 01209 V = new double[npts2fit*ncols]; 01210 std::memcpy(V,V_init+npts2fit,ncols*npts2fit*sizeof(double)); 01211 delete [] V_init; V_init = 0; 01212 }else{ 01213 V = V_init; 01214 }*/ 01215 01216 // step 3. Scale rows to assign different weights to different points 01217 for( int i = 0; i < npts2fit; ++i ) 01218 { 01219 for( int j = 0; j < ncols; ++j ) 01220 { 01221 V[j * npts2fit + i] *= ws[i]; 01222 } 01223 for( int k = 0; k < ndim; ++k ) 01224 { 01225 bs[k * npts2fit + i] *= ws[i]; 01226 } 01227 } 01228 01229 // step 4. scale columns to reduce condition number 01230 std::vector< double > ts( ncols ); // double *ts = new double[ncols]; 01231 DGMSolver::rescale_matrix( npts2fit, ncols, &( V[0] ), &( ts[0] ) ); 01232 01233 // step 5. Perform Householder QR factorization 01234 std::vector< double > D( ncols ); // double *D = new double[ncols]; 01235 int rank; 01236 DGMSolver::qr_polyfit_safeguarded( npts2fit, ncols, &( V[0] ), &( D[0] ), &rank ); 01237 01238 // step 6. adjust degree of fitting according to rank of Vandermonde matrix 01239 int ncols_sub = ncols; 01240 while( rank < ncols_sub ) 01241 { 01242 --degree; 01243 if( degree == 0 ) 01244 { 01245 // surface is flat, return 0 01246 *degree_out = *degree_qr = degree; 01247 for( int i = 0; i < npts2fit; ++i ) 01248 { 01249 for( int k = 0; k < ndim; ++k ) 01250 { 01251 bs[k * npts2fit + i] = 0; 01252 } 01253 } 01254 return; 01255 } 01256 else 01257 { 01258 ncols_sub = ( ( ( degree + 2 ) * ( degree + 1 ) ) >> 1 ) - interp; 01259 } 01260 } 01261 *degree_qr = degree; 01262 01263 // std::cout << "degree_qr: " << *degree_qr << std::endl; 01264 01265 /* DBG 01266 * std::cout<<"before Qtb"<<std::endl; 01267 std::cout<<std::endl; 01268 std::cout<<"bs = "<<std::endl; 01269 std::cout<<std::endl; 01270 for (int k=0; k< ndim; k++){ 01271 for (int j=0; j<npts2fit; ++j){ 01272 std::cout<<" "<<bs[npts2fit*k+j]<<std::endl; 01273 } 01274 } 01275 std::cout<<std::endl;*/ 01276 01277 // step 7. compute Q'b 01278 DGMSolver::compute_qtransposeB( npts2fit, ncols_sub, &( V[0] ), ndim, bs ); 01279 01280 /* DBG 01281 * std::cout<<"after Qtb"<<std::endl; 01282 std::cout<<"bs = "<<std::endl; 01283 std::cout<<std::endl; 01284 for (int k=0; k< ndim; k++){ 01285 for (int j=0; j<npts2fit; ++j){ 01286 std::cout<<" "<<bs[npts2fit*k+j]<<std::endl; 01287 } 01288 } 01289 std::cout<<std::endl;*/ 01290 01291 // step 8. perform backward substitution and scale the solution 01292 // assign diagonals of V 01293 for( int i = 0; i < ncols_sub; ++i ) 01294 { 01295 V[i * npts2fit + i] = D[i]; 01296 } 01297 01298 // backsolve 01299 if( safeguard ) 01300 { 01301 // for debug 01302 // std::cout << "ts size " << ts.size() << std::endl; 01303 DGMSolver::backsolve_polyfit_safeguarded( 2, degree, interp, npts2fit, ncols_sub, &( V[0] ), ndim, bs, 01304 &( ts[0] ), degree_out ); 01305 } 01306 else 01307 { 01308 DGMSolver::backsolve( npts2fit, ncols_sub, &( V[0] ), 1, bs, &( ts[0] ) ); 01309 *degree_out = degree; 01310 } 01311 /*if(V_init){ 01312 delete [] V_init; 01313 }else{ 01314 delete [] V; 01315 }*/ 01316 } 01317 01318 void HiReconstruction::polyfit3d_curve_get_coeff( const int nverts, 01319 const double* ngbcors, 01320 const double* ngbtangs, 01321 int degree, 01322 const bool interp, 01323 const bool safeguard, 01324 const int ncoords, 01325 double* coords, 01326 const int ncoeffs, 01327 double* coeffs, 01328 int* degree_out ) 01329 { 01330 if( !nverts ) 01331 { 01332 return; 01333 } 01334 // step 1. compute local coordinates system 01335 double tang[3] = { ngbtangs[0], ngbtangs[1], ngbtangs[2] }; 01336 if( coords && ncoords > 2 ) 01337 { 01338 coords[0] = tang[0]; 01339 coords[1] = tang[1]; 01340 coords[2] = tang[2]; 01341 } 01342 if( !coeffs || !ncoeffs ) 01343 { 01344 return; 01345 } 01346 else 01347 { 01348 assert( ncoeffs >= 3 * ( degree + 1 ) ); 01349 } 01350 // step 2. project onto local coordinate system 01351 int npts2fit = nverts - interp; 01352 if( !npts2fit ) 01353 { 01354 *degree_out = 0; 01355 for( int i = 0; i < ncoeffs; ++i ) 01356 { 01357 coeffs[0] = 0; 01358 } 01359 return; 01360 } 01361 std::vector< double > us( npts2fit ); // double *us = new double[npts2fit]; 01362 std::vector< double > bs( npts2fit * 3 ); // double *bs = new double[npts2fit*3]; 01363 double uu[3]; 01364 for( int i = interp; i < nverts; ++i ) 01365 { 01366 int k = i - interp; 01367 DGMSolver::vec_linear_operation( 3, 1, ngbcors + 3 * i, -1, ngbcors, uu ); 01368 us[k] = DGMSolver::vec_innerprod( 3, uu, tang ); 01369 bs[k] = uu[0]; 01370 bs[npts2fit + k] = uu[1]; 01371 bs[2 * npts2fit + k] = uu[2]; 01372 } 01373 01374 // step 3. copmute weights 01375 std::vector< double > ws( npts2fit ); 01376 int nzeros = compute_weights( npts2fit, 1, &( us[0] ), nverts, ngbtangs, degree, _MINEPS, &( ws[0] ) ); 01377 assert( nzeros <= npts2fit ); 01378 01379 // step 4. adjust according to number of zero-weights 01380 if( nzeros ) 01381 { 01382 if( nzeros == npts2fit ) 01383 { 01384 // singular case 01385 *degree_out = 0; 01386 for( int i = 0; i < ncoeffs; ++i ) 01387 { 01388 coeffs[i] = 0; 01389 } 01390 return; 01391 } 01392 int npts_new = npts2fit - nzeros; 01393 std::vector< double > bs_temp( 3 * npts_new ); 01394 int index = 0; 01395 for( int i = 0; i < npts2fit; ++i ) 01396 { 01397 if( ws[i] ) 01398 { 01399 if( i > index ) 01400 { 01401 us[index] = us[i]; 01402 ws[index] = ws[i]; 01403 } 01404 bs_temp[index] = bs[i]; 01405 bs_temp[index + npts_new] = bs[i + npts2fit]; 01406 bs_temp[index + 2 * npts_new] = bs[i + 2 * npts2fit]; 01407 ++index; 01408 } 01409 } 01410 assert( index == npts_new ); 01411 npts2fit = npts_new; 01412 us.resize( index ); 01413 ws.resize( index ); 01414 bs = bs_temp; 01415 // destroy bs_temp; 01416 std::vector< double >().swap( bs_temp ); 01417 } 01418 01419 // step 5. fitting 01420 eval_vander_univar_cmf( npts2fit, &( us[0] ), 3, &( bs[0] ), degree, &( ws[0] ), interp, safeguard, degree_out ); 01421 // step 6. write results to output pointers 01422 int ncoeffs_out_pvpd = *degree_out + 1; 01423 assert( ncoeffs >= 3 * ncoeffs_out_pvpd ); 01424 // write to coeffs consecutively, bs's size is not changed by eval_vander_univar_cmf 01425 coeffs[0] = coeffs[ncoeffs_out_pvpd] = coeffs[2 * ncoeffs_out_pvpd] = 0; 01426 for( int i = 0; i < ncoeffs_out_pvpd - interp; ++i ) 01427 { 01428 coeffs[i + interp] = bs[i]; 01429 coeffs[i + interp + ncoeffs_out_pvpd] = bs[i + npts2fit]; 01430 coeffs[i + interp + 2 * ncoeffs_out_pvpd] = bs[i + 2 * npts2fit]; 01431 } 01432 } 01433 01434 void HiReconstruction::eval_vander_univar_cmf( const int npts2fit, 01435 const double* us, 01436 const int ndim, 01437 double* bs, 01438 int degree, 01439 const double* ws, 01440 const bool interp, 01441 const bool safeguard, 01442 int* degree_out ) 01443 { 01444 // step 1. determine degree of polynomials to fit according to number of points 01445 int ncols = degree + 1 - interp; 01446 while( npts2fit < ncols && degree >= 1 ) 01447 { 01448 --degree; 01449 ncols = degree + 1 - interp; 01450 } 01451 if( !degree ) 01452 { 01453 if( interp ) 01454 { 01455 for( int icol = 0; icol < ndim; ++icol ) 01456 { 01457 bs[icol * npts2fit] = 0; 01458 } 01459 } 01460 for( int irow = 1; irow < npts2fit; ++irow ) 01461 { 01462 for( int icol = 0; icol < ndim; ++icol ) 01463 { 01464 bs[icol * npts2fit + irow] = 0; 01465 } 01466 } 01467 *degree_out = 0; 01468 return; 01469 } 01470 // step 2. construct Vandermonde matrix 01471 std::vector< double > V; // V(npts2fit*(ncols+interp)); 01472 DGMSolver::gen_vander_multivar( npts2fit, 1, us, degree, V ); 01473 01474 if( interp ) 01475 { 01476 V.erase( V.begin(), V.begin() + npts2fit ); 01477 } 01478 01479 // step 3. scale rows with respect to weights 01480 for( int i = 0; i < npts2fit; ++i ) 01481 { 01482 for( int j = 0; j < ncols; ++j ) 01483 { 01484 V[j * npts2fit + i] *= ws[i]; 01485 } 01486 for( int k = 0; k < ndim; ++k ) 01487 { 01488 bs[k * npts2fit + i] *= ws[i]; 01489 } 01490 } 01491 01492 // step 4. scale columns to reduce condition number 01493 std::vector< double > ts( ncols ); 01494 DGMSolver::rescale_matrix( npts2fit, ncols, &( V[0] ), &( ts[0] ) ); 01495 01496 // step 5. perform Householder QR factorization 01497 std::vector< double > D( ncols ); 01498 int rank; 01499 DGMSolver::qr_polyfit_safeguarded( npts2fit, ncols, &( V[0] ), &( D[0] ), &rank ); 01500 01501 // step 6. adjust degree of fitting 01502 int ncols_sub = ncols; 01503 while( rank < ncols_sub ) 01504 { 01505 --degree; 01506 if( !degree ) 01507 { 01508 // matrix is singular, consider curve on flat plane passing center and orthogonal to 01509 // tangent line 01510 *degree_out = 0; 01511 for( int i = 0; i < npts2fit; ++i ) 01512 { 01513 for( int k = 0; k < ndim; ++k ) 01514 { 01515 bs[k * npts2fit + i] = 0; 01516 } 01517 } 01518 } 01519 ncols_sub = degree + 1 - interp; 01520 } 01521 01522 // step 7. compute Q'*bs 01523 DGMSolver::compute_qtransposeB( npts2fit, ncols_sub, &( V[0] ), ndim, bs ); 01524 01525 // step 8. perform backward substitution and scale solutions 01526 // assign diagonals of V 01527 for( int i = 0; i < ncols_sub; ++i ) 01528 { 01529 V[i * npts2fit + i] = D[i]; 01530 } 01531 // backsolve 01532 if( safeguard ) 01533 { 01534 DGMSolver::backsolve_polyfit_safeguarded( 1, degree, interp, npts2fit, ncols, &( V[0] ), ndim, bs, ws, 01535 degree_out ); 01536 } 01537 else 01538 { 01539 DGMSolver::backsolve( npts2fit, ncols_sub, &( V[0] ), ndim, bs, &( ts[0] ) ); 01540 *degree_out = degree; 01541 } 01542 } 01543 01544 int HiReconstruction::compute_weights( const int nrows, 01545 const int ncols, 01546 const double* us, 01547 const int nngbs, 01548 const double* ngbnrms, 01549 const int degree, 01550 const double toler, 01551 double* ws ) 01552 { 01553 assert( nrows <= _MAXPNTS && ws ); 01554 bool interp = false; 01555 if( nngbs != nrows ) 01556 { 01557 assert( nngbs == nrows + 1 ); 01558 interp = true; 01559 } 01560 double epsilon = 1e-2; 01561 01562 // First, compute squared distance from each input piont to the center 01563 for( int i = 0; i < nrows; ++i ) 01564 { 01565 ws[i] = DGMSolver::vec_innerprod( ncols, us + i * ncols, us + i * ncols ); 01566 } 01567 01568 // Second, compute a small correction termt o guard against zero 01569 double h = 0; 01570 for( int i = 0; i < nrows; ++i ) 01571 { 01572 h += ws[i]; 01573 } 01574 h /= (double)nrows; 01575 01576 // Finally, compute the weights for each vertex 01577 int nzeros = 0; 01578 for( int i = 0; i < nrows; ++i ) 01579 { 01580 double costheta = DGMSolver::vec_innerprod( 3, ngbnrms, ngbnrms + 3 * ( i + interp ) ); 01581 if( costheta > toler ) 01582 { 01583 ws[i] = costheta * pow( ws[i] / h + epsilon, -1 * (double)degree / 2.0 ); 01584 } 01585 else 01586 { 01587 ws[i] = 0; 01588 ++nzeros; 01589 } 01590 } 01591 return nzeros; 01592 } 01593 bool HiReconstruction::check_barycentric_coords( const int nws, const double* naturalcoords ) 01594 { 01595 double sum = 0; 01596 for( int i = 0; i < nws; ++i ) 01597 { 01598 if( naturalcoords[i] < -_MINEPS ) 01599 { 01600 return false; 01601 } 01602 sum += naturalcoords[i]; 01603 } 01604 if( fabs( 1 - sum ) > _MINEPS ) 01605 { 01606 return false; 01607 } 01608 else 01609 { 01610 return true; 01611 } 01612 } 01613 } // namespace moab
