MOAB: Mesh Oriented datABase
(version 5.4.1)
#include <verdict.h>
Public Attributes | |
| double | edge_ratio |
| double | max_edge_ratio |
| double | aspect_ratio |
| double | radius_ratio |
| double | med_aspect_frobenius |
| double | max_aspect_frobenius |
| double | skew |
| double | taper |
| double | warpage |
| double | area |
| double | stretch |
| double | minimum_angle |
| double | maximum_angle |
| double | oddy |
| double | condition |
| double | jacobian |
| double | scaled_jacobian |
| double | shear |
| double | shape |
| double | relative_size_squared |
| double | shape_and_size |
| double | shear_and_size |
| double | distortion |
QuadMetricVals is a struct used to return calculated metrics when calling the function v_quad_quality(...)
The following is an example of how this struct is used with Verdict.
Example:
QuadMetricVals quad_metrics = {0}; unsigned long metrics_flag = 0; metrics_flag += V_QUAD_SHAPE; metrics_flag += V_QUAD_DISTORTION; metrics_flag += V_QUAD_AREA; double quad_nodes[4][3]; get_quad_nodes( quad_nodes ); //some user-defined function to load //xyz coordinate info. into array v_quad_quality( 4, quad_nodes, metrics_flag, quad_metrics ); double my_shape = quad_metrics.shape; double my_distortion = quad_metrics.distortion; double my_area = quad_metrics.area;
| double QuadMetricVals::area |
Definition at line 185 of file verdict.h.
Referenced by moab::VerdictWrapper::all_quality_measures(), and v_quad_quality().
| double QuadMetricVals::aspect_ratio |
Definition at line 171 of file verdict.h.
| double QuadMetricVals::condition |
Definition at line 195 of file verdict.h.
| double QuadMetricVals::distortion |
Definition at line 211 of file verdict.h.
| double QuadMetricVals::edge_ratio |
Definition at line 167 of file verdict.h.
| double QuadMetricVals::jacobian |
Definition at line 197 of file verdict.h.
Definition at line 177 of file verdict.h.
Definition at line 169 of file verdict.h.
Definition at line 191 of file verdict.h.
Definition at line 175 of file verdict.h.
Definition at line 189 of file verdict.h.
| double QuadMetricVals::oddy |
Definition at line 193 of file verdict.h.
| double QuadMetricVals::radius_ratio |
Definition at line 173 of file verdict.h.
Definition at line 205 of file verdict.h.
Definition at line 199 of file verdict.h.
| double QuadMetricVals::shape |
Definition at line 203 of file verdict.h.
Definition at line 207 of file verdict.h.
| double QuadMetricVals::shear |
Definition at line 201 of file verdict.h.
Definition at line 209 of file verdict.h.
| double QuadMetricVals::skew |
Definition at line 179 of file verdict.h.
| double QuadMetricVals::stretch |
Definition at line 187 of file verdict.h.
| double QuadMetricVals::taper |
Definition at line 181 of file verdict.h.
| double QuadMetricVals::warpage |
Definition at line 183 of file verdict.h.
