MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "moab/LocalDiscretization/LinearHex.hpp" 00002 #include "moab/Matrix3.hpp" 00003 #include "moab/Forward.hpp" 00004 #include <cmath> 00005 #include <limits> 00006 00007 namespace moab 00008 { 00009 00010 const double LinearHex::corner[8][3] = { { -1, -1, -1 }, { 1, -1, -1 }, { 1, 1, -1 }, { -1, 1, -1 }, 00011 { -1, -1, 1 }, { 1, -1, 1 }, { 1, 1, 1 }, { -1, 1, 1 } }; 00012 00013 /* For each point, its weight and location are stored as an array. 00014 Hence, the inner dimension is 2, the outer dimension is gauss_count. 00015 We use a one-point Gaussian quadrature, since it integrates linear functions exactly. 00016 */ 00017 const double LinearHex::gauss[1][2] = { { 2.0, 0.0 } }; 00018 00019 ErrorCode LinearHex::jacobianFcn( const double* params, 00020 const double* verts, 00021 const int /*nverts*/, 00022 const int ndim, 00023 double*, 00024 double* result ) 00025 { 00026 assert( params && verts ); 00027 Matrix3* J = reinterpret_cast< Matrix3* >( result ); 00028 *J = Matrix3( 0.0 ); 00029 for( unsigned i = 0; i < 8; ++i ) 00030 { 00031 const double params_p = 1 + params[0] * corner[i][0]; 00032 const double eta_p = 1 + params[1] * corner[i][1]; 00033 const double zeta_p = 1 + params[2] * corner[i][2]; 00034 const double dNi_dparams = corner[i][0] * eta_p * zeta_p; 00035 const double dNi_deta = corner[i][1] * params_p * zeta_p; 00036 const double dNi_dzeta = corner[i][2] * params_p * eta_p; 00037 ( *J )( 0, 0 ) += dNi_dparams * verts[i * ndim + 0]; 00038 ( *J )( 1, 0 ) += dNi_dparams * verts[i * ndim + 1]; 00039 ( *J )( 2, 0 ) += dNi_dparams * verts[i * ndim + 2]; 00040 ( *J )( 0, 1 ) += dNi_deta * verts[i * ndim + 0]; 00041 ( *J )( 1, 1 ) += dNi_deta * verts[i * ndim + 1]; 00042 ( *J )( 2, 1 ) += dNi_deta * verts[i * ndim + 2]; 00043 ( *J )( 0, 2 ) += dNi_dzeta * verts[i * ndim + 0]; 00044 ( *J )( 1, 2 ) += dNi_dzeta * verts[i * ndim + 1]; 00045 ( *J )( 2, 2 ) += dNi_dzeta * verts[i * ndim + 2]; 00046 } 00047 ( *J ) *= 0.125; 00048 return MB_SUCCESS; 00049 } // LinearHex::jacobian() 00050 00051 ErrorCode LinearHex::evalFcn( const double* params, 00052 const double* field, 00053 const int /*ndim*/, 00054 const int num_tuples, 00055 double*, 00056 double* result ) 00057 { 00058 assert( params && field && num_tuples != -1 ); 00059 for( int i = 0; i < num_tuples; i++ ) 00060 result[i] = 0.0; 00061 for( unsigned i = 0; i < 8; ++i ) 00062 { 00063 const double N_i = 00064 ( 1 + params[0] * corner[i][0] ) * ( 1 + params[1] * corner[i][1] ) * ( 1 + params[2] * corner[i][2] ); 00065 for( int j = 0; j < num_tuples; j++ ) 00066 result[j] += N_i * field[i * num_tuples + j]; 00067 } 00068 for( int i = 0; i < num_tuples; i++ ) 00069 result[i] *= 0.125; 00070 00071 return MB_SUCCESS; 00072 } 00073 00074 ErrorCode LinearHex::integrateFcn( const double* field, 00075 const double* verts, 00076 const int nverts, 00077 const int ndim, 00078 const int num_tuples, 00079 double* work, 00080 double* result ) 00081 { 00082 assert( field && verts && num_tuples != -1 ); 00083 double tmp_result[8]; 00084 ErrorCode rval = MB_SUCCESS; 00085 for( int i = 0; i < num_tuples; i++ ) 00086 result[i] = 0.0; 00087 CartVect x; 00088 Matrix3 J; 00089 for( unsigned int j1 = 0; j1 < LinearHex::gauss_count; ++j1 ) 00090 { 00091 x[0] = LinearHex::gauss[j1][1]; 00092 double w1 = LinearHex::gauss[j1][0]; 00093 for( unsigned int j2 = 0; j2 < LinearHex::gauss_count; ++j2 ) 00094 { 00095 x[1] = LinearHex::gauss[j2][1]; 00096 double w2 = LinearHex::gauss[j2][0]; 00097 for( unsigned int j3 = 0; j3 < LinearHex::gauss_count; ++j3 ) 00098 { 00099 x[2] = LinearHex::gauss[j3][1]; 00100 double w3 = LinearHex::gauss[j3][0]; 00101 rval = evalFcn( x.array(), field, ndim, num_tuples, NULL, tmp_result ); 00102 if( MB_SUCCESS != rval ) return rval; 00103 rval = jacobianFcn( x.array(), verts, nverts, ndim, work, J[0] ); 00104 if( MB_SUCCESS != rval ) return rval; 00105 double tmp_det = w1 * w2 * w3 * J.determinant(); 00106 for( int i = 0; i < num_tuples; i++ ) 00107 result[i] += tmp_result[i] * tmp_det; 00108 } 00109 } 00110 } 00111 00112 return MB_SUCCESS; 00113 } // LinearHex::integrate_vector() 00114 00115 ErrorCode LinearHex::reverseEvalFcn( EvalFcn eval, 00116 JacobianFcn jacob, 00117 InsideFcn ins, 00118 const double* posn, 00119 const double* verts, 00120 const int nverts, 00121 const int ndim, 00122 const double iter_tol, 00123 const double inside_tol, 00124 double* work, 00125 double* params, 00126 int* is_inside ) 00127 { 00128 assert( posn && verts ); 00129 return EvalSet::evaluate_reverse( eval, jacob, ins, posn, verts, nverts, ndim, iter_tol, inside_tol, work, params, 00130 is_inside ); 00131 } 00132 00133 int LinearHex::insideFcn( const double* params, const int ndim, const double tol ) 00134 { 00135 return EvalSet::inside_function( params, ndim, tol ); 00136 } 00137 00138 ErrorCode LinearHex::normalFcn( const int ientDim, 00139 const int facet, 00140 const int nverts, 00141 const double* verts, 00142 double normal[3] ) 00143 { 00144 // assert(facet < 6 && ientDim == 2 && nverts == 8); 00145 if( nverts != 8 ) MB_SET_ERR( MB_FAILURE, "Incorrect vertex count for passed hex :: expected value = 8 " ); 00146 if( ientDim != 2 ) MB_SET_ERR( MB_FAILURE, "Requesting normal for unsupported dimension :: expected value = 2 " ); 00147 if( facet > 6 || facet < 0 ) MB_SET_ERR( MB_FAILURE, "Incorrect local face id :: expected value = one of 0-5" ); 00148 00149 int id0 = CN::mConnectivityMap[MBHEX][ientDim - 1].conn[facet][0]; 00150 int id1 = CN::mConnectivityMap[MBHEX][ientDim - 1].conn[facet][1]; 00151 int id2 = CN::mConnectivityMap[MBHEX][ientDim - 1].conn[facet][3]; 00152 00153 double x0[3], x1[3]; 00154 00155 for( int i = 0; i < 3; i++ ) 00156 { 00157 x0[i] = verts[3 * id1 + i] - verts[3 * id0 + i]; 00158 x1[i] = verts[3 * id2 + i] - verts[3 * id0 + i]; 00159 } 00160 00161 double a = x0[1] * x1[2] - x1[1] * x0[2]; 00162 double b = x1[0] * x0[2] - x0[0] * x1[2]; 00163 double c = x0[0] * x1[1] - x1[0] * x0[1]; 00164 double nrm = sqrt( a * a + b * b + c * c ); 00165 00166 if( nrm > std::numeric_limits< double >::epsilon() ) 00167 { 00168 normal[0] = a / nrm; 00169 normal[1] = b / nrm; 00170 normal[2] = c / nrm; 00171 } 00172 return MB_SUCCESS; 00173 } 00174 00175 } // namespace moab
