MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "moab/Core.hpp" 00002 #include "moab/Range.hpp" 00003 #include "moab/ProgOptions.hpp" 00004 #include "moab/CartVect.hpp" 00005 #include "moab/ElemEvaluator.hpp" 00006 #include "moab/CN.hpp" 00007 #include "ElemUtil.hpp" 00008 #include <iostream> 00009 #include <ctime> 00010 #include <cstdlib> 00011 #include <cassert> 00012 #include <sstream> 00013 #include <string> 00014 00015 // Different platforms follow different conventions for usage 00016 #if !defined( _MSC_VER ) && !defined( __MINGW32__ ) 00017 #include <sys/resource.h> 00018 #endif 00019 #ifdef SOLARIS 00020 extern "C" int getrusage( int, struct rusage* ); 00021 #ifndef RUSAGE_SELF 00022 #include </usr/ucbinclude/sys/rusage.h> 00023 #endif 00024 #endif 00025 00026 using namespace moab; 00027 #define CHK( r, s ) \ 00028 do \ 00029 { \ 00030 if( MB_SUCCESS != ( r ) ) \ 00031 { \ 00032 fail( ( r ), ( s ), __FILE__, __LINE__ ); \ 00033 return ( r ); \ 00034 } \ 00035 } while( false ) 00036 00037 const int ELEMEVAL = 0, ELEMUTIL = 1; 00038 00039 static void fail( ErrorCode error_code, const char* str, const char* file_name, int line_number ) 00040 { 00041 std::cerr << str << ", line " << line_number << " of file " << file_name << ", error code " << error_code 00042 << std::endl; 00043 } 00044 00045 double mytime(); 00046 00047 ErrorCode get_ents( Interface& mbi, std::string& filename, int& dim, Range& elems, EntityType& tp, int& nv ) 00048 { 00049 ErrorCode rval = mbi.load_file( filename.c_str(), 0 ); 00050 while( elems.empty() && dim >= 1 ) 00051 { 00052 rval = mbi.get_entities_by_dimension( 0, dim, elems ); 00053 CHK( rval, "get_entities_by_dimension" ); 00054 if( elems.empty() ) dim--; 00055 } 00056 if( elems.empty() ) 00057 { 00058 CHK( MB_FAILURE, "No elements in file" ); 00059 } 00060 00061 // check to see they're all the same type & #vertices 00062 tp = mbi.type_from_handle( *elems.begin() ); 00063 EntityType tp2 = mbi.type_from_handle( *elems.rbegin() ); 00064 if( tp != tp2 ) CHK( MB_FAILURE, "Elements must have same type" ); 00065 00066 int nv2; 00067 const EntityHandle* c1; 00068 rval = mbi.get_connectivity( *elems.begin(), c1, nv ); 00069 CHK( rval, "get_connectivity" ); 00070 rval = mbi.get_connectivity( *elems.rbegin(), c1, nv2 ); 00071 CHK( rval, "get_connectivity" ); 00072 if( nv != nv2 ) 00073 { 00074 CHK( MB_FAILURE, "Elements must have same #vertices" ); 00075 } 00076 00077 return MB_SUCCESS; 00078 } 00079 00080 void parse_options( ProgOptions& opts, int& dim, std::string& filename ) 00081 { 00082 opts.addOpt< int >( std::string( "dim" ), 00083 std::string( "Evaluate 1d/2d/3d elements (default: maximal dimension in mesh)" ), &dim, 00084 ProgOptions::int_flag ); 00085 opts.addOpt< std::string >( std::string( "filename,f" ), std::string( "Filename containing mesh" ), &filename ); 00086 } 00087 00088 ErrorCode get_elem_map( EntityType tp, std::vector< CartVect >& vcoords, int nconn, Element::Map*& elemmap ) 00089 { 00090 switch( tp ) 00091 { 00092 case MBHEX: 00093 if( nconn == 8 ) 00094 { 00095 elemmap = new Element::LinearHex( vcoords ); 00096 break; 00097 } 00098 else if( nconn == 27 ) 00099 { 00100 elemmap = new Element::QuadraticHex( vcoords ); 00101 break; 00102 } 00103 else 00104 return MB_FAILURE; 00105 case MBTET: 00106 if( nconn == 4 ) 00107 { 00108 elemmap = new Element::LinearTet( vcoords ); 00109 break; 00110 } 00111 else 00112 return MB_FAILURE; 00113 case MBQUAD: 00114 if( nconn == 4 ) 00115 { 00116 elemmap = new Element::LinearQuad( vcoords ); 00117 break; 00118 } 00119 else 00120 return MB_FAILURE; 00121 default: 00122 return MB_FAILURE; 00123 } 00124 00125 return MB_SUCCESS; 00126 } 00127 00128 ErrorCode time_forward_eval( Interface* mbi, 00129 int method, 00130 Range& elems, 00131 std::vector< CartVect >& params, 00132 std::vector< CartVect >& coords, 00133 double& evtime ) 00134 { 00135 evtime = mytime(); 00136 ErrorCode rval; 00137 Range::iterator rit; 00138 unsigned int i; 00139 if( ELEMEVAL == method ) 00140 { 00141 // construct ElemEvaluator 00142 EvalSet eset; 00143 ElemEvaluator eeval( mbi ); 00144 eeval.set_eval_set( *elems.begin() ); 00145 eeval.set_tag_handle( 0, 0 ); // indicates coordinates as the field to evaluate 00146 00147 for( rit = elems.begin(), i = 0; rit != elems.end(); ++rit, i++ ) 00148 { 00149 eeval.set_ent_handle( *rit ); 00150 rval = eeval.eval( params[i].array(), coords[i].array(), 3 ); 00151 #ifndef NDEBUG 00152 if( MB_SUCCESS != rval ) return rval; 00153 #endif 00154 } 00155 } 00156 else if( ELEMUTIL == method ) 00157 { 00158 std::vector< CartVect > vcoords( CN::MAX_NODES_PER_ELEMENT ); 00159 const EntityHandle* connect; 00160 int nconn; 00161 Element::Map* elemmap = NULL; 00162 for( rit = elems.begin(), i = 0; rit != elems.end(); ++rit, i++ ) 00163 { 00164 rval = mbi->get_connectivity( *rit, connect, nconn ); 00165 CHK( rval, "get_connectivity" ); 00166 rval = mbi->get_coords( connect, nconn, vcoords[0].array() ); 00167 CHK( rval, "get_coords" ); 00168 rval = get_elem_map( mbi->type_from_handle( *rit ), vcoords, nconn, elemmap ); 00169 CHK( rval, "get_elem_map" ); 00170 coords[i] = elemmap->evaluate( params[i] ); 00171 } 00172 } 00173 00174 evtime = mytime() - evtime; 00175 return MB_SUCCESS; 00176 } 00177 00178 ErrorCode time_reverse_eval( Interface* mbi, 00179 int method, 00180 Range& elems, 00181 std::vector< CartVect >& coords, 00182 std::vector< CartVect >& params, 00183 double& retime ) 00184 { 00185 retime = mytime(); 00186 ErrorCode rval; 00187 Range::iterator rit; 00188 unsigned int i; 00189 if( ELEMEVAL == method ) 00190 { 00191 EvalSet eset; 00192 ElemEvaluator eeval( mbi ); 00193 eeval.set_eval_set( *elems.begin() ); 00194 eeval.set_tag_handle( 0, 0 ); // indicates coordinates as the field to evaluate 00195 int ins; 00196 for( rit = elems.begin(), i = 0; rit != elems.end(); ++rit, i++ ) 00197 { 00198 eeval.set_ent_handle( *rit ); 00199 rval = eeval.reverse_eval( coords[i].array(), 1.0e-10, 1.0e-6, params[i].array(), &ins ); 00200 assert( ins ); 00201 #ifndef NDEBUG 00202 if( MB_SUCCESS != rval ) return rval; 00203 #endif 00204 } 00205 } 00206 else if( ELEMUTIL == method ) 00207 { 00208 std::vector< CartVect > vcoords( CN::MAX_NODES_PER_ELEMENT ); 00209 const EntityHandle* connect; 00210 int nconn; 00211 Element::Map* elemmap = NULL; 00212 for( rit = elems.begin(), i = 0; rit != elems.end(); ++rit, i++ ) 00213 { 00214 rval = mbi->get_connectivity( *rit, connect, nconn ); 00215 CHK( rval, "get_connectivity" ); 00216 rval = mbi->get_coords( connect, nconn, vcoords[0].array() ); 00217 CHK( rval, "get_coords" ); 00218 rval = get_elem_map( mbi->type_from_handle( *rit ), vcoords, nconn, elemmap ); 00219 CHK( rval, "get_elem_map" ); 00220 coords[i] = elemmap->ievaluate( coords[i], 1.0e-6 ); 00221 } 00222 } 00223 retime = mytime() - retime; 00224 return MB_SUCCESS; 00225 } 00226 00227 ErrorCode time_jacobian( Interface* mbi, int method, Range& elems, std::vector< CartVect >& params, double& jactime ) 00228 { 00229 jactime = mytime(); 00230 ErrorCode rval; 00231 Range::iterator rit; 00232 unsigned int i; 00233 Matrix3 jac; 00234 if( ELEMEVAL == method ) 00235 { 00236 EvalSet eset; 00237 ElemEvaluator eeval( mbi ); 00238 eeval.set_eval_set( *elems.begin() ); 00239 eeval.set_tag_handle( 0, 0 ); // indicates coordinates as the field to evaluate 00240 for( rit = elems.begin(), i = 0; rit != elems.end(); ++rit, i++ ) 00241 { 00242 eeval.set_ent_handle( *rit ); 00243 rval = eeval.jacobian( params[i].array(), jac.array() ); 00244 #ifndef NDEBUG 00245 if( MB_SUCCESS != rval ) return rval; 00246 #endif 00247 } 00248 } 00249 else if( ELEMUTIL == method ) 00250 { 00251 std::vector< CartVect > vcoords( CN::MAX_NODES_PER_ELEMENT ); 00252 const EntityHandle* connect; 00253 int nconn; 00254 Element::Map* elemmap = NULL; 00255 for( rit = elems.begin(), i = 0; rit != elems.end(); ++rit, i++ ) 00256 { 00257 rval = mbi->get_connectivity( *rit, connect, nconn ); 00258 CHK( rval, "get_connectivity" ); 00259 rval = mbi->get_coords( connect, nconn, vcoords[0].array() ); 00260 CHK( rval, "get_coords" ); 00261 rval = get_elem_map( mbi->type_from_handle( *rit ), vcoords, nconn, elemmap ); 00262 CHK( rval, "get_elem_map" ); 00263 jac = elemmap->jacobian( params[i] ); 00264 } 00265 } 00266 jactime = mytime() - jactime; 00267 return MB_SUCCESS; 00268 } 00269 00270 ErrorCode time_integrate( Interface* mbi, int method, Tag tag, Range& elems, double& inttime ) 00271 { 00272 inttime = mytime(); 00273 ErrorCode rval; 00274 double integral = 0.0; 00275 if( ELEMEVAL == method ) 00276 { 00277 EvalSet eset; 00278 ElemEvaluator eeval( mbi ); 00279 eeval.set_eval_set( *elems.begin() ); 00280 eeval.set_tag_handle( 0, 0 ); // indicates coordinates as the field to evaluate 00281 rval = eeval.set_tag_handle( tag, 0 ); 00282 CHK( rval, "set_tag_handle" ); 00283 for( Range::iterator rit = elems.begin(); rit != elems.end(); ++rit ) 00284 { 00285 eeval.set_ent_handle( *rit ); 00286 rval = eeval.integrate( &integral ); 00287 #ifndef NDEBUG 00288 if( MB_SUCCESS != rval ) return rval; 00289 #endif 00290 } 00291 } 00292 else if( ELEMUTIL == method ) 00293 { 00294 std::vector< CartVect > vcoords( CN::MAX_NODES_PER_ELEMENT ); 00295 std::vector< double > tagval( CN::MAX_NODES_PER_ELEMENT ); 00296 const EntityHandle* connect; 00297 int nconn; 00298 Element::Map* elemmap = NULL; 00299 Range::iterator rit; 00300 unsigned int i; 00301 for( rit = elems.begin(), i = 0; rit != elems.end(); ++rit, i++ ) 00302 { 00303 rval = mbi->get_connectivity( *rit, connect, nconn ); 00304 CHK( rval, "get_connectivity" ); 00305 rval = mbi->get_coords( connect, nconn, vcoords[0].array() ); 00306 CHK( rval, "get_coords" ); 00307 rval = get_elem_map( mbi->type_from_handle( *rit ), vcoords, nconn, elemmap ); 00308 CHK( rval, "get_elem_map" ); 00309 rval = mbi->tag_get_data( tag, connect, nconn, &tagval[0] ); 00310 CHK( rval, "tag_get_data" ); 00311 integral = elemmap->integrate_scalar_field( &tagval[0] ); 00312 } 00313 } 00314 inttime = mytime() - inttime; 00315 std::cout << "integral = " << integral << std::endl; 00316 return MB_SUCCESS; 00317 } 00318 00319 ErrorCode put_random_field( Interface& mbi, Tag& tag, Range& elems ) 00320 { 00321 Range verts; 00322 ErrorCode rval = mbi.get_adjacencies( elems, 0, false, verts, Interface::UNION ); 00323 CHK( rval, "get_adjacencies" ); 00324 rval = mbi.tag_get_handle( "mytag", 1, MB_TYPE_DOUBLE, tag, MB_TAG_CREAT | MB_TAG_DENSE ); 00325 CHK( rval, "tag_get_handle" ); 00326 std::vector< double > tag_vals( verts.size() ); 00327 for( unsigned int i = 0; i < verts.size(); i++ ) 00328 tag_vals[i] = ( (double)rand() ) / RAND_MAX; 00329 rval = mbi.tag_set_data( tag, verts, &tag_vals[0] ); 00330 return rval; 00331 } 00332 00333 ErrorCode elem_evals( Interface* mbi, 00334 int method, 00335 Range& elems, 00336 Tag tag, 00337 std::vector< CartVect >& params, 00338 std::vector< CartVect >& coords, 00339 double& evtime, 00340 double& retime, 00341 double& jactime, 00342 double& inttime ) 00343 { 00344 evtime = 0, retime = 0, jactime = 0, inttime = 0; // initializations to avoid compiler warning 00345 00346 // time/test forward evaluation, putting results into vector 00347 ErrorCode rval = time_forward_eval( mbi, method, elems, params, coords, evtime ); 00348 CHK( rval, "time_forward_eval" ); 00349 00350 // time/test reverse evaluation, putting results into vector 00351 rval = time_reverse_eval( mbi, method, elems, coords, params, retime ); 00352 CHK( rval, "time_reverse_eval" ); 00353 00354 // time/test Jacobian evaluation 00355 rval = time_jacobian( mbi, method, elems, params, jactime ); 00356 CHK( rval, "time_jacobian" ); 00357 00358 // time/test integration 00359 rval = time_integrate( mbi, method, tag, elems, inttime ); 00360 CHK( rval, "time_integrate" ); 00361 00362 return rval; 00363 } 00364 00365 int main( int argc, char* argv[] ) 00366 { 00367 // parse options 00368 ProgOptions opts; 00369 std::string filename; 00370 int dim = 3; 00371 parse_options( opts, dim, filename ); 00372 opts.parseCommandLine( argc, argv ); 00373 if( filename.empty() ) 00374 CHK( MB_FAILURE, "No file specified" ); 00375 else if( dim < 1 || dim > 3 ) 00376 CHK( MB_FAILURE, "Dimension must be > 0 and <= 3" ); 00377 00378 // read mesh file & gather element handles 00379 Core mbi; 00380 Range elems; 00381 int nv; 00382 EntityType tp; 00383 ErrorCode rval = get_ents( mbi, filename, dim, elems, tp, nv ); 00384 if( MB_SUCCESS != rval ) return 1; 00385 00386 // construct (random) parameter values for queries 00387 unsigned int ne = elems.size(); 00388 std::vector< CartVect > params( ne ), coords( ne ); 00389 srand( time( NULL ) ); 00390 for( unsigned int i = 0; i < ne; i++ ) 00391 { 00392 params[i][0] = -1 + 2 * ( (double)rand() ) / RAND_MAX; 00393 if( dim > 1 ) params[i][1] = -1 + 2 * ( (double)rand() ) / RAND_MAX; 00394 if( dim > 2 ) params[i][2] = -1 + 2 * ( (double)rand() ) / RAND_MAX; 00395 } 00396 00397 // put random field on vertices 00398 Tag tag; 00399 rval = put_random_field( mbi, tag, elems ); 00400 CHK( rval, "put_random_field" ); 00401 double evtime[2], retime[2], jactime[2], 00402 inttime[2]; // initializations to avoid compiler warning 00403 00404 rval = elem_evals( &mbi, ELEMEVAL, elems, tag, params, coords, evtime[0], retime[0], jactime[0], inttime[0] ); 00405 CHK( rval, "new elem_evals" ); 00406 00407 rval = elem_evals( &mbi, ELEMUTIL, elems, tag, params, coords, evtime[1], retime[1], jactime[1], inttime[1] ); 00408 CHK( rval, "old elem_evals" ); 00409 00410 std::cout << filename << ": " << elems.size() << " " << CN::EntityTypeName( tp ) << " elements, " << nv 00411 << " vertices per element." << std::endl 00412 << std::endl; 00413 std::cout << "New, old element evaluation code:" << std::endl; 00414 std::cout << "Evaluation type, time, time per element:" << std::endl; 00415 std::cout << " New Old (New/Old)*100" << std::endl; 00416 std::cout << "Forward evaluation " << evtime[0] << ", " << evtime[0] / elems.size() << " " << evtime[1] << ", " 00417 << evtime[1] / elems.size() << " " << ( evtime[0] / ( evtime[1] ? evtime[1] : 1 ) ) * 100.0 00418 << std::endl; 00419 std::cout << "Reverse evaluation " << retime[0] << ", " << retime[0] / elems.size() << " " << retime[1] << ", " 00420 << retime[1] / elems.size() << " " << ( retime[0] / ( retime[1] ? retime[1] : 1 ) ) * 100.0 00421 << std::endl; 00422 std::cout << "Jacobian " << jactime[0] << ", " << jactime[0] / elems.size() << " " << jactime[1] 00423 << ", " << jactime[1] / elems.size() << " " << ( jactime[0] / ( jactime[1] ? jactime[1] : 1 ) ) * 100.0 00424 << std::endl; 00425 std::cout << "Integration " << inttime[0] << ", " << inttime[0] / elems.size() << " " << inttime[1] 00426 << ", " << inttime[1] / elems.size() << " " << ( inttime[0] / ( inttime[1] ? inttime[1] : 1 ) ) * 100.0 00427 << std::endl; 00428 } 00429 00430 #if defined( _MSC_VER ) || defined( __MINGW32__ ) 00431 double mytime2( double& tot_time, double& utime, double& stime, long& imem, long& rmem ) 00432 { 00433 utime = (double)clock() / CLOCKS_PER_SEC; 00434 tot_time = stime = 0; 00435 imem = rmem = 0; 00436 return tot_time; 00437 } 00438 #else 00439 double mytime2( double& tot_time, double& utime, double& stime, long& imem, long& rmem ) 00440 { 00441 struct rusage r_usage; 00442 getrusage( RUSAGE_SELF, &r_usage ); 00443 utime = (double)r_usage.ru_utime.tv_sec + ( (double)r_usage.ru_utime.tv_usec / 1.e6 ); 00444 stime = (double)r_usage.ru_stime.tv_sec + ( (double)r_usage.ru_stime.tv_usec / 1.e6 ); 00445 tot_time = utime + stime; 00446 #ifndef LINUX 00447 imem = r_usage.ru_idrss; 00448 rmem = r_usage.ru_maxrss; 00449 #else 00450 system( "ps o args,drs,rss | grep perf | grep -v grep" ); // RedHat 9.0 doesnt fill in actual 00451 // memory data 00452 imem = rmem = 0; 00453 #endif 00454 return tot_time; 00455 } 00456 #endif 00457 double mytime() 00458 { 00459 double ttime, utime, stime; 00460 long imem, rmem; 00461 return mytime2( ttime, utime, stime, imem, rmem ); 00462 }
