MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** \brief This test shows how to perform local point-in-element searches with MOAB's new tree 00002 * searching functionality. 00003 * 00004 * MOAB's SpatialLocator functionality performs point-in-element searches over a local or parallel 00005 * mesh. SpatialLocator is flexible as to what kind of tree is used and what kind of element basis 00006 * functions are used to localize elements and interpolate local fields. 00007 */ 00008 00009 #include <iostream> 00010 #include <cstdlib> 00011 #include <cstdio> 00012 00013 #include "moab/Core.hpp" 00014 #include "moab/Interface.hpp" 00015 #include "moab/Range.hpp" 00016 #include "moab/AdaptiveKDTree.hpp" 00017 #include "moab/ElemEvaluator.hpp" 00018 #include "moab/CN.hpp" 00019 #include "moab/SpatialLocator.hpp" 00020 00021 using namespace moab; 00022 using namespace std; 00023 00024 #ifdef MOAB_HAVE_HDF5 00025 string test_file_name = string( MESH_DIR ) + string( "/64bricks_512hex_256part.h5m" ); 00026 #else 00027 string test_file_name = string( MESH_DIR ) + string( "/mbtest1.vtk" ); 00028 #endif 00029 int main( int argc, char** argv ) 00030 { 00031 int num_queries = 1000000; 00032 00033 if( argc > 3 ) 00034 { 00035 cout << "Usage: " << argv[0] << " <filename> [num_queries]" << endl; 00036 return 0; 00037 } 00038 else if( argc == 3 ) 00039 { 00040 test_file_name = argv[1]; 00041 num_queries = atoi( argv[2] ); 00042 } 00043 else 00044 { 00045 num_queries = 100; 00046 } 00047 00048 // Instantiate 00049 Core mb; 00050 00051 // Load the file 00052 ErrorCode rval = mb.load_file( test_file_name.c_str() );MB_CHK_SET_ERR( rval, "Error loading file" ); 00053 00054 // Get all 3d elements in the file 00055 Range elems; 00056 rval = mb.get_entities_by_dimension( 0, 3, elems );MB_CHK_SET_ERR( rval, "Error getting 3d elements" ); 00057 00058 // Create a tree to use for the location service 00059 AdaptiveKDTree tree( &mb ); 00060 00061 // Specify an evaluator based on linear hexes 00062 ElemEvaluator el_eval( &mb ); 00063 00064 // Build the SpatialLocator 00065 SpatialLocator sl( &mb, elems, &tree ); 00066 00067 // Get the box extents 00068 CartVect box_extents, pos; 00069 BoundBox box = sl.local_box(); 00070 box_extents = box.bMax - box.bMin; 00071 00072 // Query at random places in the tree 00073 CartVect params; 00074 int is_inside = 0; 00075 int num_inside = 0; 00076 EntityHandle elem; 00077 for( int i = 0; i < num_queries; i++ ) 00078 { 00079 pos = box.bMin + CartVect( box_extents[0] * .01 * ( rand() % 100 ), box_extents[1] * .01 * ( rand() % 100 ), 00080 box_extents[2] * .01 * ( rand() % 100 ) ); 00081 rval = sl.locate_point( pos.array(), elem, params.array(), &is_inside, 0.0, 0.0 );MB_CHK_ERR( rval ); 00082 if( is_inside ) num_inside++; 00083 } 00084 00085 cout << "Mesh contains " << elems.size() << " elements of type " 00086 << CN::EntityTypeName( mb.type_from_handle( *elems.begin() ) ) << endl; 00087 cout << "Bounding box min-max = (" << box.bMin[0] << "," << box.bMin[1] << "," << box.bMin[2] << ")-(" 00088 << box.bMax[0] << "," << box.bMax[1] << "," << box.bMax[2] << ")" << endl; 00089 cout << "Queries inside box = " << num_inside << "/" << num_queries << " = " 00090 << 100.0 * ( (double)num_inside ) / num_queries << "%" << endl; 00091 00092 return 0; 00093 }
