MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 #include <stdlib.h> 00017 #include <string.h> 00018 #include <H5Ipublic.h> 00019 #include <H5Tpublic.h> 00020 #include "file-handle.h" 00021 #include "status.h" 00022 #include "util.h" 00023 00024 #define FILE_HANDLE_MAGIC 0xFEEDFEED 00025 00026 int mhdf_check_valid_file( FileHandle* handle, mhdf_Status* status ) 00027 { 00028 if( !handle ) 00029 { 00030 mhdf_setFail( status, "NULL file handle." ); 00031 return 0; 00032 } 00033 00034 if( handle->magic != FILE_HANDLE_MAGIC ) 00035 { 00036 mhdf_setFail( status, "Invalid file handle." ); 00037 return 0; 00038 } 00039 00040 return 1; 00041 } 00042 00043 FileHandle* mhdf_alloc_FileHandle( hid_t hdf_table, hid_t id_type, mhdf_Status* status ) 00044 { 00045 FileHandle* rval; 00046 00047 /* check that id_type is sane */ 00048 if( id_type == -1 ) 00049 { 00050 id_type = H5T_NATIVE_ULONG; 00051 } 00052 else if( H5T_INTEGER != H5Tget_class( id_type ) ) 00053 { 00054 mhdf_setFail( status, "Invalid ID type: not integer class" ); 00055 return 0; 00056 } 00057 00058 rval = (FileHandle*)mhdf_malloc( sizeof( FileHandle ), status ); 00059 if( !rval ) return NULL; 00060 00061 rval->magic = FILE_HANDLE_MAGIC; 00062 rval->hdf_handle = hdf_table; 00063 rval->open_handle_count = 0; 00064 rval->id_type = id_type; 00065 rval->max_id = 0L; 00066 return rval; 00067 }
