MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include <iostream> 00002 #include "moab/Interface.hpp" 00003 #ifndef IS_BUILDING_MB 00004 #define IS_BUILDING_MB 00005 #endif 00006 #include "TestUtil.hpp" 00007 #include "Internals.hpp" 00008 #include "moab/Core.hpp" 00009 00010 #include "moab/GeomTopoTool.hpp" 00011 #include "moab/GeomQueryTool.hpp" 00012 00013 using namespace moab; 00014 00015 GeomTopoTool* GTT; 00016 GeomQueryTool* GQT; 00017 Interface* MBI; 00018 00019 #define CHKERR( A ) \ 00020 do \ 00021 { \ 00022 if( MB_SUCCESS != ( A ) ) \ 00023 { \ 00024 std::cerr << "Failure (error code " << ( A ) << ") at " __FILE__ ":" << __LINE__ << std::endl; \ 00025 return A; \ 00026 } \ 00027 } while( false ) 00028 00029 const std::string input_file = TestDir + "unittest/test_geom.h5m"; 00030 00031 void gqt_load_file() 00032 { 00033 MBI = new moab::Core(); 00034 ErrorCode rval = MBI->load_file( input_file.c_str() ); // open the 00035 CHECK_ERR( rval ); 00036 GTT = new GeomTopoTool( MBI, true ); 00037 GQT = new GeomQueryTool( GTT ); 00038 } 00039 00040 void gqt_load_file_dagmc_build_obb() 00041 { 00042 /* 1 - Test with external moab, load file in GTT/GQT*/ 00043 // make new moab core 00044 ErrorCode rval; 00045 00046 // load a file 00047 MBI = new moab::Core(); 00048 rval = MBI->load_file( input_file.c_str() ); // open the 00049 CHECK_ERR( rval ); 00050 GTT = new GeomTopoTool( MBI ); 00051 GQT = new GeomQueryTool( GTT ); 00052 rval = GQT->initialize();CHECK_ERR( rval ); 00053 } 00054 00055 void gqt_load_file_dagmc_via_moab_build_obb() 00056 { 00057 /* 2 - Test with external moab, load file in MOAB*/ 00058 // build implicit complement and obb trees 00059 ErrorCode rval; 00060 00061 // load file 00062 MBI = new moab::Core(); 00063 rval = MBI->load_file( input_file.c_str() ); // open the file 00064 CHECK_ERR( rval ); 00065 GTT = new GeomTopoTool( MBI ); 00066 GQT = new GeomQueryTool( GTT ); 00067 // create obb trees 00068 rval = GQT->gttool()->setup_implicit_complement();CHECK_ERR( rval ); 00069 rval = GQT->gttool()->construct_obb_trees();CHECK_ERR( rval ); 00070 } 00071 00072 void gqt_load_file_dagmc_internal_build_obb() 00073 { 00074 /* 3 - Test with internal moab, load file in MOAB*/ 00075 // find geomsets, build implicit complement, and construct obb trees 00076 ErrorCode rval; 00077 00078 MBI = new moab::Core(); 00079 rval = MBI->load_file( input_file.c_str() ); // open the 00080 CHECK_ERR( rval ); 00081 GTT = new GeomTopoTool( MBI, true, 0 ); 00082 GQT = new GeomQueryTool( GTT ); 00083 rval = GQT->gttool()->setup_implicit_complement();CHECK_ERR( rval ); 00084 rval = GQT->gttool()->construct_obb_trees();CHECK_ERR( rval ); 00085 } 00086 00087 void gqt_test_obb_retreval() 00088 { 00089 // make new dagmc 00090 std::cout << "test_obb_retreval" << std::endl; 00091 00092 ErrorCode rval; 00093 // load a file 00094 MBI = new moab::Core(); 00095 rval = MBI->load_file( input_file.c_str() ); // open the 00096 CHECK_ERR( rval ); 00097 GTT = new GeomTopoTool( MBI, true, 0 ); 00098 GQT = new GeomQueryTool( GTT ); 00099 GQT->initialize();CHECK_ERR( rval ); 00100 00101 // write to file 00102 rval = MBI->write_file( "fcad" );CHECK_ERR( rval ); 00103 00104 // cleanup instances 00105 delete GQT; 00106 delete GTT; 00107 delete MBI; 00108 00109 // re-load written file 00110 MBI = new moab::Core(); 00111 rval = MBI->load_file( "fcad" ); // open the 00112 CHECK_ERR( rval ); 00113 GTT = new GeomTopoTool( MBI, true, 0 ); 00114 GQT = new GeomQueryTool( GTT ); 00115 rval = GQT->initialize();CHECK_ERR( rval ); 00116 00117 // remove file 00118 remove( "fcad" ); 00119 } 00120 00121 void gqt_create_impl_compl() 00122 { 00123 ErrorCode rval = GQT->gttool()->setup_implicit_complement();CHECK_ERR( rval ); 00124 } 00125 00126 void gqt_build_obb() 00127 { 00128 ErrorCode rval = GQT->gttool()->construct_obb_trees();CHECK_ERR( rval ); 00129 } 00130 00131 void gqt_num_vols() 00132 { 00133 int expect_num_vols = 2; 00134 int num_vols = GQT->gttool()->num_ents_of_dim( 3 ); 00135 CHECK_EQUAL( expect_num_vols, num_vols ); 00136 } 00137 00138 void gqt_point_in() 00139 { 00140 int result = 0; 00141 int expect_result = 1; 00142 int vol_idx = 1; 00143 double xyz[3] = { 0.0, 0.0, 0.0 }; 00144 EntityHandle vol_h; 00145 00146 // load file and create instances 00147 MBI = new moab::Core(); 00148 ErrorCode rval = MBI->load_file( input_file.c_str() ); // open the 00149 CHECK_ERR( rval ); 00150 GTT = new GeomTopoTool( MBI, true, 0 ); 00151 GQT = new GeomQueryTool( GTT ); 00152 // initialize for geom queries 00153 GQT->initialize(); 00154 00155 // get volume 00156 vol_h = GQT->gttool()->entity_by_id( 3, vol_idx ); 00157 // test point in volume 00158 GQT->point_in_volume( vol_h, xyz, result );CHECK_ERR( rval ); 00159 CHECK_EQUAL( expect_result, result ); 00160 } 00161 00162 void gqt_test_obb_retreval_rayfire() 00163 { 00164 // make new dagmc 00165 std::cout << "test_obb_retreval and ray_fire" << std::endl; 00166 00167 ErrorCode rval; 00168 00169 // load file and initialize 00170 MBI = new moab::Core(); 00171 rval = MBI->load_file( input_file.c_str() ); // open the 00172 CHECK_ERR( rval ); 00173 GTT = new GeomTopoTool( MBI, true, 0 ); 00174 GQT = new GeomQueryTool( GTT ); 00175 GQT->initialize();CHECK_ERR( rval ); 00176 00177 // write to file 00178 rval = MBI->write_file( "fcad" );CHECK_ERR( rval ); 00179 00180 // delete instances 00181 delete GTT; 00182 delete GQT; 00183 delete MBI; 00184 00185 // load the file that was written and initialize 00186 MBI = new moab::Core(); 00187 rval = MBI->load_file( "fcad" ); // open the 00188 CHECK_ERR( rval ); 00189 GTT = new GeomTopoTool( MBI, true, 0 ); 00190 GQT = new GeomQueryTool( GTT ); 00191 rval = GQT->initialize();CHECK_ERR( rval ); 00192 00193 // remove generated test file 00194 remove( "fcad" ); 00195 00196 // now perform full ray fire 00197 double eps = 1.e-6; 00198 int vol_idx = 1; 00199 // note model is cube of side 10, centred at 0,0,0, so ray fire along 00200 // any unit direction should be exactly 5.0 00201 double xyz[3] = { 0.0, 0.0, 0.0 }; 00202 double dir[3] = { 0.0, 0.0, 1.0 }; 00203 EntityHandle next_surf; 00204 double next_surf_dist; 00205 double expect_next_surf_dist = 5.0; 00206 EntityHandle vol_h; 00207 00208 // get volume handle to fire on 00209 vol_h = GQT->gttool()->entity_by_id( 3, vol_idx ); 00210 // test ray fire 00211 rval = GQT->ray_fire( vol_h, xyz, dir, next_surf, next_surf_dist );CHECK_ERR( rval ); 00212 CHECK_REAL_EQUAL( expect_next_surf_dist, next_surf_dist, eps ); 00213 } 00214 00215 void gqt_rayfire() 00216 { 00217 const double eps = 1e-6; // epsilon for test, faceting tol? 00218 00219 int vol_idx = 1; 00220 // note model is cube of side 10, centred at 0,0,0, so ray fire along 00221 // any unit direction should be exactly 5.0 00222 double xyz[3] = { 0.0, 0.0, 0.0 }; 00223 double dir[3] = { 0.0, 0.0, 1.0 }; 00224 EntityHandle next_surf; 00225 double next_surf_dist; 00226 double expect_next_surf_dist = 5.0; 00227 EntityHandle vol_h; 00228 ErrorCode rval; 00229 00230 MBI = new moab::Core(); 00231 rval = MBI->load_file( input_file.c_str() ); // open the 00232 CHECK_ERR( rval ); 00233 GTT = new GeomTopoTool( MBI, true, 0 ); 00234 GQT = new GeomQueryTool( GTT ); 00235 GQT->initialize();CHECK_ERR( rval ); 00236 00237 vol_h = GQT->gttool()->entity_by_id( 3, vol_idx ); 00238 rval = GQT->ray_fire( vol_h, xyz, dir, next_surf, next_surf_dist );CHECK_ERR( rval ); 00239 CHECK_REAL_EQUAL( expect_next_surf_dist, next_surf_dist, eps ); 00240 } 00241 00242 void gqt_closest_to() 00243 { 00244 const double eps = 1e-6; // epsilon for test, faceting tol? 00245 00246 int vol_idx = 1; 00247 // note model is cube of side 10, centred at 0,0,0, so ray fire along 00248 // any unit direction should be exactly 5.0 00249 double xyz[3] = { -6.0, 0.0, 0.0 }; 00250 double distance; // distance from point to nearest surface 00251 double expect_distance = 1.0; 00252 EntityHandle vol_h; 00253 ErrorCode rval; 00254 00255 // get the volume handle 00256 vol_h = GQT->gttool()->entity_by_id( 3, vol_idx ); 00257 00258 // test closest to location 00259 rval = GQT->closest_to_location( vol_h, xyz, distance );CHECK_ERR( rval ); 00260 00261 // distance should be 1.0 cm 00262 CHECK_REAL_EQUAL( expect_distance, distance, eps ); 00263 } 00264 00265 void gqt_test_boundary() 00266 { 00267 int vol_idx = 1; 00268 EntityHandle vol_h = GQT->gttool()->entity_by_id( 3, vol_idx ); 00269 int surf_idx = 1; 00270 EntityHandle surf_h = GQT->gttool()->entity_by_id( 2, surf_idx ); 00271 00272 double xyz[3] = { 0.0, 0.0, 5.0 }; 00273 double dir[3] = { 0.0, 0.0, 1.0 }; 00274 int result; 00275 int expect_result = 0; 00276 00277 // test vol boundary 00278 ErrorCode rval = GQT->test_volume_boundary( vol_h, surf_h, xyz, dir, result );CHECK_ERR( rval ); 00279 // check ray leaving volume 00280 CHECK_EQUAL( expect_result, result ); 00281 } 00282 00283 void gqt_point_in_box_1() 00284 { 00285 int vol_id = 1; 00286 double origin[3] = { 0.0, 0.0, 0.0 }; 00287 EntityHandle vol_h = GQT->gttool()->entity_by_id( 3, vol_id ); 00288 int result; 00289 ErrorCode rval = GQT->point_in_box( vol_h, origin, result ); 00290 CHECK_EQUAL( rval, moab::MB_SUCCESS ); 00291 CHECK_EQUAL( result, 1 ); // inside 00292 } 00293 00294 void gqt_point_in_box_2() 00295 { 00296 int vol_id = 1; 00297 double origin[3] = { 5.0, 0.0, 0.0 }; 00298 EntityHandle vol_h = GQT->gttool()->entity_by_id( 3, vol_id ); 00299 int result; 00300 ErrorCode rval = GQT->point_in_box( vol_h, origin, result ); 00301 CHECK_EQUAL( rval, moab::MB_SUCCESS ); 00302 CHECK_EQUAL( result, 1 ); // inside 00303 } 00304 00305 void gqt_point_in_box_3() 00306 { 00307 int vol_id = 1; 00308 double origin[3] = { 5.1, 0.0, 0.0 }; 00309 EntityHandle vol_h = GQT->gttool()->entity_by_id( 3, vol_id ); 00310 int result; 00311 ErrorCode rval = GQT->point_in_box( vol_h, origin, result ); 00312 CHECK_EQUAL( rval, moab::MB_SUCCESS ); 00313 CHECK_EQUAL( result, 0 ); // outside 00314 } 00315 00316 void gqt_point_in_box_4() 00317 { 00318 int vol_id = 1; 00319 double origin[3] = { 5.1, 5.1, 5.1 }; 00320 EntityHandle vol_h = GQT->gttool()->entity_by_id( 3, vol_id ); 00321 int result; 00322 ErrorCode rval = GQT->point_in_box( vol_h, origin, result ); 00323 CHECK_EQUAL( rval, moab::MB_SUCCESS ); 00324 CHECK_EQUAL( result, 0 ); // outside 00325 } 00326 00327 void gqt_point_in_box_5() 00328 { 00329 int vol_id = 1; 00330 double origin[3] = { 5.0 - 1.e-308, 5.0 - 1.e-308, 5.0 - 1.e-308 }; 00331 EntityHandle vol_h = GQT->gttool()->entity_by_id( 3, vol_id ); 00332 int result; 00333 ErrorCode rval = GQT->point_in_box( vol_h, origin, result ); 00334 CHECK_EQUAL( rval, moab::MB_SUCCESS ); 00335 CHECK_EQUAL( result, 1 ); // outside 00336 } 00337 00338 void cleanup() 00339 { 00340 // cleanup instances 00341 delete GQT; 00342 delete GTT; 00343 delete MBI; 00344 } 00345 00346 int main( int /* argc */, char** /* argv */ ) 00347 { 00348 int result = 0; 00349 00350 result += RUN_TEST( gqt_load_file ); // test ray fire 00351 result += RUN_TEST( gqt_build_obb ); // build the obb 00352 result += RUN_TEST( gqt_create_impl_compl ); // build the obb 00353 result += RUN_TEST( gqt_num_vols ); // make sure the num of vols correct 00354 cleanup(); 00355 00356 result += RUN_TEST( gqt_load_file_dagmc_build_obb ); // 00357 cleanup(); 00358 00359 result += RUN_TEST( gqt_load_file_dagmc_via_moab_build_obb ); // 00360 cleanup(); 00361 00362 result += RUN_TEST( gqt_load_file_dagmc_internal_build_obb ); // 00363 cleanup(); 00364 00365 result += RUN_TEST( gqt_test_obb_retreval ); // check that we are retreving loaded obbs 00366 cleanup(); 00367 00368 result += RUN_TEST( gqt_test_obb_retreval_rayfire ); // check that we can ray fire on loaded obbs 00369 cleanup(); 00370 00371 result += RUN_TEST( gqt_point_in ); // check entity by point 00372 cleanup(); 00373 00374 result += RUN_TEST( gqt_rayfire ); // ensure ray fire distance is correct 00375 result += RUN_TEST( gqt_closest_to ); // check the distance to surface nearest point 00376 result += RUN_TEST( gqt_test_boundary ); // check particle entering leaving 00377 cleanup(); 00378 00379 return result; 00380 }
