MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include <iostream> 00002 #include "moab/Core.hpp" 00003 #include <cmath> 00004 #include <cstdlib> 00005 #include <cassert> 00006 00007 using namespace std; 00008 00009 namespace moab 00010 { 00011 00012 // make a nice picture. tweak here 00013 // 217: x,y -> [-8, 8] /// z -> [-65, 65] 00014 double physField( double x, double y, double z, double factor ) 00015 { 00016 00017 // 1/r^2 decay from {0,0,0} 00018 // tjt - changing to 1/r 00019 /* 00020 double scale = 1.0/factor; 00021 out = fabs(x*scale) + fabs(y*scale) + fabs(z*scale); 00022 out += 1e-1; // clamp 00023 out = 1/out; 00024 */ 00025 double out = factor * sqrt( x * x + y * y + z * z ); 00026 00027 return out; 00028 } 00029 00030 void putElementField( Interface* mbi, const char* tagname, double factor ) 00031 { 00032 Range elems; 00033 00034 mbi->get_entities_by_dimension( 0, 3, elems ); 00035 00036 const double defVal = 0.; 00037 Tag fieldTag; 00038 ErrorCode rval = mbi->tag_get_handle( tagname, 1, MB_TYPE_DOUBLE, fieldTag, MB_TAG_DENSE | MB_TAG_CREAT, &defVal ); 00039 assert( MB_SUCCESS == rval ); 00040 #ifdef NDEBUG 00041 if( MB_SUCCESS == rval ) 00042 { 00043 }; // Line to avoid compiler warning about unused variable 00044 #endif 00045 00046 int numElems = elems.size(); 00047 00048 for( int i = 0; i < numElems; i++ ) 00049 { 00050 // cout << elems[i] << endl; 00051 EntityHandle elem = elems[i]; 00052 00053 double xyz[3]; 00054 mbi->get_coords( &elem, 1, xyz ); 00055 00056 double fieldValue = physField( xyz[0], xyz[1], xyz[2], factor ); 00057 00058 mbi->tag_set_data( fieldTag, &elem, 1, &fieldValue ); 00059 } 00060 } 00061 00062 void putSpectralElementField( Interface* mbi, int dim, int np, const char* tagname, double factor ) 00063 { 00064 Range elems; 00065 00066 mbi->get_entities_by_dimension( 0, dim, elems ); 00067 00068 const int ndofperE = np * np; 00069 double* defDouble = new double[ndofperE]; 00070 Tag fieldTag; 00071 ErrorCode rval = 00072 mbi->tag_get_handle( tagname, ndofperE, MB_TYPE_DOUBLE, fieldTag, MB_TAG_DENSE | MB_TAG_CREAT, &defDouble ); 00073 std::cout << "rval = " << rval << std::endl; 00074 assert( MB_SUCCESS == rval || rval == MB_ALREADY_ALLOCATED ); 00075 #ifdef NDEBUG 00076 if( MB_SUCCESS == rval || rval == MB_ALREADY_ALLOCATED ) 00077 { 00078 }; // Line to avoid compiler warning about unused variable 00079 #endif 00080 00081 int numElems = elems.size(); 00082 std::vector< double > tData( ndofperE, 0.0 ); 00083 00084 for( int i = 0; i < numElems; i++ ) 00085 { 00086 EntityHandle elem = elems[i]; 00087 00088 double xyz[3]; 00089 mbi->get_coords( &elem, 1, xyz ); 00090 00091 double fieldValue = physField( xyz[0], xyz[1], xyz[2], factor ); 00092 for( int j = 0; j < ndofperE; ++j ) 00093 tData[j] = fieldValue; // same value evaluated at the center; could modify it to use 00094 // GLL points ? 00095 00096 mbi->tag_set_data( fieldTag, &elem, 1, &tData[0] ); 00097 } 00098 00099 delete[] defDouble; 00100 tData.clear(); 00101 } 00102 00103 void putVertexField( Interface* mbi, const char* tagname, double factor ) 00104 { 00105 Range verts; 00106 00107 mbi->get_entities_by_type( 0, MBVERTEX, verts ); 00108 00109 const double defVal = 0.; 00110 Tag fieldTag; 00111 mbi->tag_get_handle( tagname, 1, MB_TYPE_DOUBLE, fieldTag, MB_TAG_DENSE | MB_TAG_CREAT, &defVal ); 00112 00113 int numVerts = verts.size(); 00114 for( int i = 0; i < numVerts; i++ ) 00115 { 00116 EntityHandle vert = verts[i]; //? 00117 00118 double vertPos[3]; 00119 mbi->get_coords( &vert, 1, vertPos ); 00120 00121 double fieldValue = physField( vertPos[0], vertPos[1], vertPos[2], factor ); 00122 00123 mbi->tag_set_data( fieldTag, &vert, 1, &fieldValue ); 00124 } 00125 } 00126 00127 } // namespace moab 00128 00129 // Using moab instead of imesh for dev speed 00130 int main( int argc, char** argv ) 00131 { 00132 00133 using namespace moab; 00134 00135 Interface* mbi = new Core(); 00136 00137 if( argc < 3 ) 00138 { 00139 cout << "Usage: " << argv[0] << " <infile> <outfile> [factor]\n" 00140 << "Writes both vertex and element fields.\n"; 00141 return 0; 00142 } 00143 00144 mbi->load_mesh( argv[1] ); 00145 00146 double factor = 1.0; 00147 if( argc == 4 ) factor = atof( argv[3] ); 00148 00149 putVertexField( mbi, "vertex_field", factor ); 00150 putElementField( mbi, "element_field", factor ); 00151 // putSpectralElementField(mbi, 2, 4, "spectral_element_field", factor); 00152 putSpectralElementField( mbi, 2, 4, "a2oTAG", factor ); 00153 00154 ErrorCode result = mbi->write_mesh( argv[2] ); 00155 if( MB_SUCCESS == result ) 00156 cout << "wrote " << argv[2] << endl; 00157 else 00158 cout << "Failed to write " << argv[2] << endl; 00159 00160 // vector<double> coords; 00161 // mbi->get_vertex_coordinates(coords); 00162 // double xavg = 0; 00163 // for (int i = 0; i < coords.size()/3; i++) xavg += coords[i]; 00164 // cout << xavg << endl; 00165 00166 return 1; 00167 }
