MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "TestUtil.hpp" 00002 #include "moab/Core.hpp" 00003 #include "moab/ParallelComm.hpp" 00004 #include "moab/ProgOptions.hpp" 00005 #include "MBParallelConventions.h" 00006 #include "moab/ReadUtilIface.hpp" 00007 #include "MBTagConventions.hpp" 00008 00009 #include <sstream> 00010 00011 using namespace moab; 00012 00013 std::string example = TestDir + "unittest/io/gcrm_r3.nc"; 00014 00015 void test_read_onevar_trivial(); 00016 #if defined( MOAB_HAVE_MPI ) && defined( MOAB_HAVE_ZOLTAN ) 00017 void test_read_onevar_rcbzoltan(); 00018 #endif 00019 00020 void test_read_mesh_parallel_trivial(); 00021 #if defined( MOAB_HAVE_MPI ) && defined( MOAB_HAVE_ZOLTAN ) 00022 void test_read_mesh_parallel_rcbzoltan(); 00023 #endif 00024 00025 void test_gather_onevar_on_rank0(); 00026 void test_gather_onevar_on_rank1(); 00027 00028 void test_multiple_loads_of_same_file(); 00029 00030 // Helper functions 00031 void read_one_cell_var( bool rcbzoltan ); 00032 void read_mesh_parallel( bool rcbzoltan ); 00033 void gather_one_cell_var( int gather_set_rank ); 00034 void multiple_loads_of_same_file(); 00035 00036 std::string read_options; 00037 const double eps = 1e-6; 00038 const int layers = 3; 00039 00040 int main( int argc, char* argv[] ) 00041 { 00042 MPI_Init( &argc, &argv ); 00043 int result = 0; 00044 00045 result += RUN_TEST( test_read_onevar_trivial ); 00046 #if defined( MOAB_HAVE_MPI ) && defined( MOAB_HAVE_ZOLTAN ) 00047 result += RUN_TEST( test_read_onevar_rcbzoltan ); 00048 #endif 00049 00050 result += RUN_TEST( test_read_mesh_parallel_trivial ); 00051 #if defined( MOAB_HAVE_MPI ) && defined( MOAB_HAVE_ZOLTAN ) 00052 result += RUN_TEST( test_read_mesh_parallel_rcbzoltan ); 00053 #endif 00054 00055 result += RUN_TEST( test_gather_onevar_on_rank0 ); 00056 result += RUN_TEST( test_gather_onevar_on_rank1 ); 00057 00058 result += RUN_TEST( test_multiple_loads_of_same_file ); 00059 00060 MPI_Finalize(); 00061 return result; 00062 } 00063 00064 void test_read_onevar_trivial() 00065 { 00066 read_one_cell_var( false ); 00067 } 00068 00069 void test_read_onevar_rcbzoltan() 00070 { 00071 read_one_cell_var( true ); 00072 } 00073 00074 void test_read_mesh_parallel_trivial() 00075 { 00076 read_mesh_parallel( false ); 00077 } 00078 00079 void test_read_mesh_parallel_rcbzoltan() 00080 { 00081 read_mesh_parallel( true ); 00082 } 00083 00084 void test_gather_onevar_on_rank0() 00085 { 00086 gather_one_cell_var( 0 ); 00087 } 00088 00089 void test_gather_onevar_on_rank1() 00090 { 00091 gather_one_cell_var( 1 ); 00092 } 00093 00094 void test_multiple_loads_of_same_file() 00095 { 00096 multiple_loads_of_same_file(); 00097 } 00098 00099 // Helper functions 00100 void read_one_cell_var( bool rcbzoltan ) 00101 { 00102 Core moab; 00103 Interface& mb = moab; 00104 00105 read_options = "PARALLEL=READ_PART;PARTITION_METHOD=TRIVIAL;NO_EDGES;VARIABLE=vorticity"; 00106 if( rcbzoltan ) 00107 read_options = "PARALLEL=READ_PART;PARTITION_METHOD=RCBZOLTAN;NO_EDGES;VARIABLE=vorticity;DEBUG_IO=1"; 00108 00109 ErrorCode rval = mb.load_file( example.c_str(), NULL, read_options.c_str() );CHECK_ERR( rval ); 00110 00111 // Get local edges 00112 Range local_edges; 00113 rval = mb.get_entities_by_type( 0, MBEDGE, local_edges );CHECK_ERR( rval ); 00114 CHECK_EQUAL( (size_t)0, local_edges.size() ); 00115 00116 // Get local cells 00117 Range local_cells; 00118 rval = mb.get_entities_by_type( 0, MBPOLYGON, local_cells );CHECK_ERR( rval ); 00119 // No mixed elements 00120 CHECK_EQUAL( (size_t)1, local_cells.psize() ); 00121 00122 Tag gid_tag = mb.globalId_tag(); 00123 00124 std::vector< int > gids( local_cells.size() ); 00125 rval = mb.tag_get_data( gid_tag, local_cells, &gids[0] ); 00126 Range local_cell_gids; 00127 std::copy( gids.rbegin(), gids.rend(), range_inserter( local_cell_gids ) ); 00128 00129 ParallelComm* pcomm = ParallelComm::get_pcomm( &mb, 0 ); 00130 int procs = pcomm->proc_config().proc_size(); 00131 int rank = pcomm->proc_config().proc_rank(); 00132 00133 // Make check runs this test on two processors 00134 if( 2 == procs ) 00135 { 00136 // Check tag for cell variable vorticity at timestep 0 00137 Tag vorticity_tag0; 00138 rval = mb.tag_get_handle( "vorticity0", layers, MB_TYPE_DOUBLE, vorticity_tag0 );CHECK_ERR( rval ); 00139 00140 // Check tag for cell variable vorticity at timestep 1 00141 Tag vorticity_tag1; 00142 rval = mb.tag_get_handle( "vorticity1", layers, MB_TYPE_DOUBLE, vorticity_tag1 );CHECK_ERR( rval ); 00143 00144 // Get vorticity0 and vorticity1 tag values on 3 local cells 00145 double vorticity0_val[3 * layers]; 00146 double vorticity1_val[3 * layers]; 00147 00148 if( rcbzoltan ) 00149 { 00150 CHECK_EQUAL( (size_t)14, local_cell_gids.psize() ); 00151 00152 if( 0 == rank ) 00153 { 00154 CHECK_EQUAL( (size_t)321, local_cells.size() ); 00155 CHECK_EQUAL( (size_t)321, local_cell_gids.size() ); 00156 00157 CHECK_EQUAL( 3, (int)local_cell_gids[0] ); 00158 CHECK_EQUAL( 162, (int)local_cell_gids[159] ); 00159 CHECK_EQUAL( 640, (int)local_cell_gids[318] ); 00160 00161 EntityHandle cell_ents[] = { local_cells[0], local_cells[159], local_cells[318] }; 00162 rval = mb.tag_get_data( vorticity_tag0, cell_ents, 3, vorticity0_val );CHECK_ERR( rval ); 00163 00164 // Timestep 0 00165 // Layer 0 00166 CHECK_REAL_EQUAL( -0.725999, vorticity0_val[0 * layers], eps ); 00167 CHECK_REAL_EQUAL( -1.814997, vorticity0_val[1 * layers], eps ); 00168 CHECK_REAL_EQUAL( 0.131688, vorticity0_val[2 * layers], eps ); 00169 // Layer 1 00170 CHECK_REAL_EQUAL( -0.725989, vorticity0_val[0 * layers + 1], eps ); 00171 CHECK_REAL_EQUAL( -1.814972, vorticity0_val[1 * layers + 1], eps ); 00172 CHECK_REAL_EQUAL( 0.131686, vorticity0_val[2 * layers + 1], eps ); 00173 00174 rval = mb.tag_get_data( vorticity_tag1, cell_ents, 3, vorticity1_val );CHECK_ERR( rval ); 00175 00176 // Timestep 1 00177 // Layer 0 00178 CHECK_REAL_EQUAL( -0.706871, vorticity1_val[0 * layers], eps ); 00179 CHECK_REAL_EQUAL( -1.767178, vorticity1_val[1 * layers], eps ); 00180 CHECK_REAL_EQUAL( 0.128218, vorticity1_val[2 * layers], eps ); 00181 // Layer 1 00182 CHECK_REAL_EQUAL( -0.706861, vorticity1_val[0 * layers + 1], eps ); 00183 CHECK_REAL_EQUAL( -1.767153, vorticity1_val[1 * layers + 1], eps ); 00184 CHECK_REAL_EQUAL( 0.128216, vorticity1_val[2 * layers + 1], eps ); 00185 } 00186 else if( 1 == rank ) 00187 { 00188 CHECK_EQUAL( (size_t)321, local_cells.size() ); 00189 CHECK_EQUAL( (size_t)321, local_cell_gids.size() ); 00190 00191 CHECK_EQUAL( 1, (int)local_cell_gids[0] ); 00192 CHECK_EQUAL( 366, (int)local_cell_gids[161] ); 00193 CHECK_EQUAL( 1, (int)local_cell_gids[322] ); 00194 00195 EntityHandle cell_ents[] = { local_cells[0], local_cells[161], local_cells[322] }; 00196 rval = mb.tag_get_data( vorticity_tag0, cell_ents, 3, vorticity0_val );CHECK_ERR( rval ); 00197 00198 // Timestep 0 00199 // Layer 0 00200 CHECK_REAL_EQUAL( 3.629994, vorticity0_val[0 * layers], eps ); 00201 CHECK_REAL_EQUAL( -1.512985, vorticity0_val[1 * layers], eps ); 00202 CHECK_REAL_EQUAL( 3.629994, vorticity0_val[2 * layers], eps ); 00203 // Layer 1 00204 CHECK_REAL_EQUAL( 3.629944, vorticity0_val[0 * layers + 1], eps ); 00205 CHECK_REAL_EQUAL( -1.512964, vorticity0_val[1 * layers + 1], eps ); 00206 CHECK_REAL_EQUAL( 3.629944, vorticity0_val[2 * layers + 1], eps ); 00207 00208 rval = mb.tag_get_data( vorticity_tag1, cell_ents, 3, vorticity1_val );CHECK_ERR( rval ); 00209 00210 // Timestep 1 00211 // Layer 0 00212 CHECK_REAL_EQUAL( 3.534355, vorticity1_val[0 * layers], eps ); 00213 CHECK_REAL_EQUAL( -1.473122, vorticity1_val[1 * layers], eps ); 00214 CHECK_REAL_EQUAL( 3.534355, vorticity1_val[2 * layers], eps ); 00215 // Layer 1 00216 CHECK_REAL_EQUAL( 3.534306, vorticity1_val[0 * layers + 1], eps ); 00217 CHECK_REAL_EQUAL( -1.473102, vorticity1_val[1 * layers + 1], eps ); 00218 CHECK_REAL_EQUAL( 3.534306, vorticity1_val[2 * layers + 1], eps ); 00219 } 00220 } 00221 else 00222 { 00223 CHECK_EQUAL( (size_t)321, local_cells.size() ); 00224 CHECK_EQUAL( (size_t)321, local_cell_gids.size() ); 00225 CHECK_EQUAL( (size_t)1, local_cell_gids.psize() ); 00226 00227 EntityHandle cell_ents[] = { local_cells[0], local_cells[160], local_cells[320] }; 00228 rval = mb.tag_get_data( vorticity_tag0, cell_ents, 3, vorticity0_val );CHECK_ERR( rval ); 00229 00230 rval = mb.tag_get_data( vorticity_tag1, cell_ents, 3, vorticity1_val );CHECK_ERR( rval ); 00231 00232 if( 0 == rank ) 00233 { 00234 CHECK_EQUAL( 1, (int)local_cell_gids[0] ); 00235 CHECK_EQUAL( 161, (int)local_cell_gids[160] ); 00236 CHECK_EQUAL( 321, (int)local_cell_gids[320] ); 00237 00238 // Timestep 0 00239 // Layer 0 00240 CHECK_REAL_EQUAL( 3.629994, vorticity0_val[0 * layers], eps ); 00241 CHECK_REAL_EQUAL( -1.708188, vorticity0_val[1 * layers], eps ); 00242 CHECK_REAL_EQUAL( 0.131688, vorticity0_val[2 * layers], eps ); 00243 // Layer 1 00244 CHECK_REAL_EQUAL( 3.629944, vorticity0_val[0 * layers + 1], eps ); 00245 CHECK_REAL_EQUAL( -1.708164, vorticity0_val[1 * layers + 1], eps ); 00246 CHECK_REAL_EQUAL( 0.131686, vorticity0_val[2 * layers + 1], eps ); 00247 00248 // Timestep 1 00249 // Layer 0 00250 CHECK_REAL_EQUAL( 3.534355, vorticity1_val[0 * layers], eps ); 00251 CHECK_REAL_EQUAL( -1.663182, vorticity1_val[1 * layers], eps ); 00252 CHECK_REAL_EQUAL( 0.128218, vorticity1_val[2 * layers], eps ); 00253 // Layer 1 00254 CHECK_REAL_EQUAL( 3.534306, vorticity1_val[0 * layers + 1], eps ); 00255 CHECK_REAL_EQUAL( -1.663160, vorticity1_val[1 * layers + 1], eps ); 00256 CHECK_REAL_EQUAL( 0.128216, vorticity1_val[2 * layers + 1], eps ); 00257 } 00258 else if( 1 == rank ) 00259 { 00260 CHECK_EQUAL( 322, (int)local_cell_gids[0] ); 00261 CHECK_EQUAL( 482, (int)local_cell_gids[160] ); 00262 CHECK_EQUAL( 642, (int)local_cell_gids[320] ); 00263 00264 // Timestep 0 00265 // Layer 0 00266 CHECK_REAL_EQUAL( -0.554888, vorticity0_val[0 * layers], eps ); 00267 CHECK_REAL_EQUAL( 2.434397, vorticity0_val[1 * layers], eps ); 00268 CHECK_REAL_EQUAL( -0.554888, vorticity0_val[2 * layers], eps ); 00269 // Layer 1 00270 CHECK_REAL_EQUAL( -0.554881, vorticity0_val[0 * layers + 1], eps ); 00271 CHECK_REAL_EQUAL( 2.434363, vorticity0_val[1 * layers + 1], eps ); 00272 CHECK_REAL_EQUAL( -0.554881, vorticity0_val[2 * layers + 1], eps ); 00273 00274 // Timestep 1 00275 // Layer 0 00276 CHECK_REAL_EQUAL( -0.540269, vorticity1_val[0 * layers], eps ); 00277 CHECK_REAL_EQUAL( 2.370258, vorticity1_val[1 * layers], eps ); 00278 CHECK_REAL_EQUAL( -0.540269, vorticity1_val[2 * layers], eps ); 00279 // Layer 1 00280 CHECK_REAL_EQUAL( -0.540262, vorticity1_val[0 * layers + 1], eps ); 00281 CHECK_REAL_EQUAL( 2.370226, vorticity1_val[1 * layers + 1], eps ); 00282 CHECK_REAL_EQUAL( -0.540262, vorticity1_val[2 * layers + 1], eps ); 00283 } 00284 } 00285 } 00286 } 00287 00288 void read_mesh_parallel( bool rcbzoltan ) 00289 { 00290 Core moab; 00291 Interface& mb = moab; 00292 00293 read_options = "PARALLEL=READ_PART;PARTITION_METHOD=TRIVIAL;PARALLEL_RESOLVE_SHARED_ENTS;VARIABLE="; 00294 if( rcbzoltan ) 00295 read_options = "PARALLEL=READ_PART;PARTITION_METHOD=RCBZOLTAN;PARALLEL_RESOLVE_SHARED_ENTS;VARIABLE="; 00296 00297 ErrorCode rval = mb.load_file( example.c_str(), NULL, read_options.c_str() );CHECK_ERR( rval ); 00298 00299 ParallelComm* pcomm = ParallelComm::get_pcomm( &mb, 0 ); 00300 int procs = pcomm->proc_config().proc_size(); 00301 int rank = pcomm->proc_config().proc_rank(); 00302 00303 rval = pcomm->check_all_shared_handles();CHECK_ERR( rval ); 00304 00305 // Get local vertices 00306 Range local_verts; 00307 rval = mb.get_entities_by_type( 0, MBVERTEX, local_verts );CHECK_ERR( rval ); 00308 00309 int verts_num = local_verts.size(); 00310 if( 2 == procs ) 00311 { 00312 if( rcbzoltan ) 00313 { 00314 if( 0 == rank ) 00315 CHECK_EQUAL( 688, verts_num ); 00316 else if( 1 == rank ) 00317 CHECK_EQUAL( 687, verts_num ); // Not owned vertices included 00318 } 00319 else 00320 { 00321 if( 0 == rank ) 00322 CHECK_EQUAL( 687, verts_num ); 00323 else if( 1 == rank ) 00324 CHECK_EQUAL( 688, verts_num ); // Not owned vertices included 00325 } 00326 } 00327 00328 rval = pcomm->filter_pstatus( local_verts, PSTATUS_NOT_OWNED, PSTATUS_NOT );CHECK_ERR( rval ); 00329 00330 verts_num = local_verts.size(); 00331 if( 2 == procs ) 00332 { 00333 if( rcbzoltan ) 00334 { 00335 if( 0 == rank ) 00336 CHECK_EQUAL( 688, verts_num ); 00337 else if( 1 == rank ) 00338 CHECK_EQUAL( 592, verts_num ); // Not owned vertices excluded 00339 } 00340 else 00341 { 00342 if( 0 == rank ) 00343 CHECK_EQUAL( 687, verts_num ); 00344 else if( 1 == rank ) 00345 CHECK_EQUAL( 593, verts_num ); // Not owned vertices excluded 00346 } 00347 } 00348 00349 // Get local edges 00350 Range local_edges; 00351 rval = mb.get_entities_by_type( 0, MBEDGE, local_edges );CHECK_ERR( rval ); 00352 00353 int edges_num = local_edges.size(); 00354 if( 2 == procs ) 00355 { 00356 if( rcbzoltan ) 00357 { 00358 if( 0 == rank ) 00359 CHECK_EQUAL( 1008, edges_num ); 00360 else if( 1 == rank ) 00361 CHECK_EQUAL( 1007, edges_num ); // Not owned edges included 00362 } 00363 else 00364 { 00365 if( 0 == rank ) 00366 CHECK_EQUAL( 1007, edges_num ); 00367 else if( 1 == rank ) 00368 CHECK_EQUAL( 1008, edges_num ); // Not owned edges included 00369 } 00370 } 00371 00372 rval = pcomm->filter_pstatus( local_edges, PSTATUS_NOT_OWNED, PSTATUS_NOT );CHECK_ERR( rval ); 00373 00374 edges_num = local_edges.size(); 00375 if( 2 == procs ) 00376 { 00377 if( rcbzoltan ) 00378 { 00379 if( 0 == rank ) 00380 CHECK_EQUAL( 1008, edges_num ); 00381 else if( 1 == rank ) 00382 CHECK_EQUAL( 912, edges_num ); // Not owned edges excluded 00383 } 00384 else 00385 { 00386 if( 0 == rank ) 00387 CHECK_EQUAL( 1007, edges_num ); 00388 else if( 1 == rank ) 00389 CHECK_EQUAL( 913, edges_num ); // Not owned edges excluded 00390 } 00391 } 00392 00393 // Get local cells 00394 Range local_cells; 00395 rval = mb.get_entities_by_type( 0, MBPOLYGON, local_cells );CHECK_ERR( rval ); 00396 // No mixed elements 00397 CHECK_EQUAL( (size_t)1, local_cells.psize() ); 00398 00399 int cells_num = local_cells.size(); 00400 if( 2 == procs ) 00401 { 00402 if( rcbzoltan ) 00403 { 00404 if( 0 == rank ) 00405 CHECK_EQUAL( 321, cells_num ); 00406 else 00407 CHECK_EQUAL( 321, cells_num ); 00408 } 00409 else 00410 CHECK_EQUAL( 321, cells_num ); 00411 } 00412 00413 rval = pcomm->filter_pstatus( local_cells, PSTATUS_NOT_OWNED, PSTATUS_NOT );CHECK_ERR( rval ); 00414 00415 cells_num = local_cells.size(); 00416 if( 2 == procs ) 00417 { 00418 if( rcbzoltan ) 00419 { 00420 if( 0 == rank ) 00421 CHECK_EQUAL( 321, cells_num ); 00422 else 00423 CHECK_EQUAL( 321, cells_num ); 00424 } 00425 else 00426 CHECK_EQUAL( 321, cells_num ); 00427 } 00428 00429 std::cout << "proc: " << rank << " verts:" << verts_num << "\n"; 00430 00431 int total_verts_num; 00432 MPI_Reduce( &verts_num, &total_verts_num, 1, MPI_INT, MPI_SUM, 0, pcomm->proc_config().proc_comm() ); 00433 if( 0 == rank ) 00434 { 00435 std::cout << "total vertices: " << total_verts_num << "\n"; 00436 CHECK_EQUAL( 1280, total_verts_num ); 00437 } 00438 00439 std::cout << "proc: " << rank << " edges:" << edges_num << "\n"; 00440 00441 int total_edges_num; 00442 MPI_Reduce( &edges_num, &total_edges_num, 1, MPI_INT, MPI_SUM, 0, pcomm->proc_config().proc_comm() ); 00443 if( 0 == rank ) 00444 { 00445 std::cout << "total edges: " << total_edges_num << "\n"; 00446 CHECK_EQUAL( 1920, total_edges_num ); 00447 } 00448 00449 std::cout << "proc: " << rank << " cells:" << cells_num << "\n"; 00450 00451 int total_cells_num; 00452 MPI_Reduce( &cells_num, &total_cells_num, 1, MPI_INT, MPI_SUM, 0, pcomm->proc_config().proc_comm() ); 00453 if( 0 == rank ) 00454 { 00455 std::cout << "total cells: " << total_cells_num << "\n"; 00456 CHECK_EQUAL( 642, total_cells_num ); 00457 } 00458 00459 #ifdef MOAB_HAVE_HDF5_PARALLEL 00460 std::string write_options( "PARALLEL=WRITE_PART;" ); 00461 00462 std::string output_file = "test_gcrm"; 00463 if( rcbzoltan ) output_file += "_rcbzoltan"; 00464 output_file += ".h5m"; 00465 00466 mb.write_file( output_file.c_str(), NULL, write_options.c_str() ); 00467 #endif 00468 } 00469 00470 void gather_one_cell_var( int gather_set_rank ) 00471 { 00472 Core moab; 00473 Interface& mb = moab; 00474 00475 EntityHandle file_set; 00476 ErrorCode rval = mb.create_meshset( MESHSET_SET, file_set );CHECK_ERR( rval ); 00477 00478 read_options = "PARALLEL=READ_PART;PARTITION_METHOD=TRIVIAL;PARALLEL_RESOLVE_SHARED_ENTS"; 00479 std::ostringstream gather_set_option; 00480 gather_set_option << ";GATHER_SET=" << gather_set_rank; 00481 read_options += gather_set_option.str(); 00482 00483 rval = mb.load_file( example.c_str(), &file_set, read_options.c_str() );CHECK_ERR( rval ); 00484 00485 ParallelComm* pcomm = ParallelComm::get_pcomm( &mb, 0 ); 00486 int procs = pcomm->proc_config().proc_size(); 00487 int rank = pcomm->proc_config().proc_rank(); 00488 00489 // Make sure gather_set_rank is valid 00490 if( gather_set_rank < 0 || gather_set_rank >= procs ) return; 00491 00492 Range cells, cells_owned; 00493 rval = mb.get_entities_by_type( file_set, MBPOLYGON, cells );CHECK_ERR( rval ); 00494 00495 // Get local owned cells 00496 rval = pcomm->filter_pstatus( cells, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &cells_owned );CHECK_ERR( rval ); 00497 00498 EntityHandle gather_set = 0; 00499 if( gather_set_rank == rank ) 00500 { 00501 // Get gather set 00502 ReadUtilIface* readUtilIface; 00503 mb.query_interface( readUtilIface ); 00504 rval = readUtilIface->get_gather_set( gather_set );CHECK_ERR( rval ); 00505 assert( gather_set != 0 ); 00506 } 00507 00508 Tag vorticity_tag0, gid_tag; 00509 rval = mb.tag_get_handle( "vorticity0", layers, MB_TYPE_DOUBLE, vorticity_tag0, MB_TAG_DENSE );CHECK_ERR( rval ); 00510 00511 gid_tag = mb.globalId_tag(); 00512 00513 pcomm->gather_data( cells_owned, vorticity_tag0, gid_tag, gather_set, gather_set_rank ); 00514 00515 if( gather_set_rank == rank ) 00516 { 00517 // Get gather set cells 00518 Range gather_set_cells; 00519 rval = mb.get_entities_by_type( gather_set, MBPOLYGON, gather_set_cells );CHECK_ERR( rval ); 00520 CHECK_EQUAL( (size_t)642, gather_set_cells.size() ); 00521 CHECK_EQUAL( (size_t)1, gather_set_cells.psize() ); 00522 00523 // Check vorticity0 tag values on 4 gather set cells: first cell, two median cells, and last 00524 // cell 00525 EntityHandle cell_ents[] = { gather_set_cells[0], gather_set_cells[320], gather_set_cells[321], 00526 gather_set_cells[641] }; 00527 double vorticity0_val[4 * layers]; 00528 rval = mb.tag_get_data( vorticity_tag0, &cell_ents[0], 4, vorticity0_val );CHECK_ERR( rval ); 00529 00530 // Only check first two layers 00531 // Layer 0 00532 CHECK_REAL_EQUAL( 3.629994, vorticity0_val[0 * layers], eps ); 00533 CHECK_REAL_EQUAL( 0.131688, vorticity0_val[1 * layers], eps ); 00534 CHECK_REAL_EQUAL( -0.554888, vorticity0_val[2 * layers], eps ); 00535 CHECK_REAL_EQUAL( -0.554888, vorticity0_val[3 * layers], eps ); 00536 // Layer 1 00537 CHECK_REAL_EQUAL( 3.629944, vorticity0_val[0 * layers + 1], eps ); 00538 CHECK_REAL_EQUAL( 0.131686, vorticity0_val[1 * layers + 1], eps ); 00539 CHECK_REAL_EQUAL( -0.554881, vorticity0_val[2 * layers + 1], eps ); 00540 CHECK_REAL_EQUAL( -0.554881, vorticity0_val[3 * layers + 1], eps ); 00541 } 00542 } 00543 00544 void multiple_loads_of_same_file() 00545 { 00546 Core moab; 00547 Interface& mb = moab; 00548 00549 // Need a file set for nomesh to work right 00550 EntityHandle file_set; 00551 ErrorCode rval; 00552 rval = mb.create_meshset( MESHSET_SET, file_set );CHECK_ERR( rval ); 00553 00554 // Read first only header information, no mesh, no variable 00555 read_options = "PARALLEL=READ_PART;PARTITION;NOMESH;VARIABLE=;PARTITION_METHOD=TRIVIAL"; 00556 00557 rval = mb.load_file( example.c_str(), &file_set, read_options.c_str() );CHECK_ERR( rval ); 00558 00559 // Create mesh, no variable 00560 read_options = "PARALLEL=READ_PART;PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;PARTITION_METHOD=" 00561 "TRIVIAL;VARIABLE="; 00562 00563 rval = mb.load_file( example.c_str(), &file_set, read_options.c_str() );CHECK_ERR( rval ); 00564 00565 // Read variable vorticity at timestep 0, no mesh 00566 read_options = "PARALLEL=READ_PART;PARTITION;PARTITION_METHOD=TRIVIAL;NOMESH;VARIABLE=" 00567 "vorticity;TIMESTEP=0"; 00568 00569 rval = mb.load_file( example.c_str(), &file_set, read_options.c_str() );CHECK_ERR( rval ); 00570 00571 Range local_verts; 00572 rval = mb.get_entities_by_type( file_set, MBVERTEX, local_verts );CHECK_ERR( rval ); 00573 00574 Range local_edges; 00575 rval = mb.get_entities_by_type( file_set, MBEDGE, local_edges );CHECK_ERR( rval ); 00576 00577 Range local_cells; 00578 rval = mb.get_entities_by_type( file_set, MBPOLYGON, local_cells );CHECK_ERR( rval ); 00579 // No mixed elements 00580 CHECK_EQUAL( (size_t)1, local_cells.psize() ); 00581 00582 ParallelComm* pcomm = ParallelComm::get_pcomm( &mb, 0 ); 00583 int procs = pcomm->proc_config().proc_size(); 00584 int rank = pcomm->proc_config().proc_rank(); 00585 00586 // Make check runs this test on two processors 00587 if( 2 == procs ) 00588 { 00589 CHECK_EQUAL( (size_t)321, local_cells.size() ); 00590 00591 // Check tag for cell variable vorticity at timestep 0 00592 Tag vorticity_tag0; 00593 rval = mb.tag_get_handle( "vorticity0", layers, MB_TYPE_DOUBLE, vorticity_tag0 );CHECK_ERR( rval ); 00594 00595 // Get vorticity0 tag values on 3 local cells 00596 double vorticity0_val[3 * layers]; 00597 EntityHandle cell_ents[] = { local_cells[0], local_cells[160], local_cells[320] }; 00598 rval = mb.tag_get_data( vorticity_tag0, cell_ents, 3, vorticity0_val );CHECK_ERR( rval ); 00599 00600 if( 0 == rank ) 00601 { 00602 CHECK_EQUAL( (size_t)687, local_verts.size() ); 00603 CHECK_EQUAL( (size_t)1007, local_edges.size() ); 00604 00605 // Layer 0 00606 CHECK_REAL_EQUAL( 3.629994, vorticity0_val[0 * layers], eps ); 00607 CHECK_REAL_EQUAL( -1.708188, vorticity0_val[1 * layers], eps ); 00608 CHECK_REAL_EQUAL( 0.131688, vorticity0_val[2 * layers], eps ); 00609 // Layer 1 00610 CHECK_REAL_EQUAL( 3.629944, vorticity0_val[0 * layers + 1], eps ); 00611 CHECK_REAL_EQUAL( -1.708164, vorticity0_val[1 * layers + 1], eps ); 00612 CHECK_REAL_EQUAL( 0.131686, vorticity0_val[2 * layers + 1], eps ); 00613 } 00614 else if( 1 == rank ) 00615 { 00616 CHECK_EQUAL( (size_t)688, local_verts.size() ); 00617 CHECK_EQUAL( (size_t)1008, local_edges.size() ); 00618 00619 // Layer 0 00620 CHECK_REAL_EQUAL( -0.554888, vorticity0_val[0 * layers], eps ); 00621 CHECK_REAL_EQUAL( 2.434397, vorticity0_val[1 * layers], eps ); 00622 CHECK_REAL_EQUAL( -0.554888, vorticity0_val[2 * layers], eps ); 00623 // Layer 1 00624 CHECK_REAL_EQUAL( -0.554881, vorticity0_val[0 * layers + 1], eps ); 00625 CHECK_REAL_EQUAL( 2.434363, vorticity0_val[1 * layers + 1], eps ); 00626 CHECK_REAL_EQUAL( -0.554881, vorticity0_val[2 * layers + 1], eps ); 00627 } 00628 } 00629 }
